newlord
RB953GS-5HnT-RP + LTE HUAWEI ME909s-120 Not Recognized
Sat Sep 10, 2016 12:40 am
I bought RB953GS-5HnT-RP and 2 LTE HUAWEI ME909s-120 MiniPCI-e because there stated that they are compatible
but the modem is not recognized
If I use PCIE MINI Converted to USB the card LTE HUAWEI ME909s-120 then everything works
But I need to work with the port MiniPCI-e
please help me!
newlord
Re: RB953GS-5HnT-RP + LTE HUAWEI ME909s-120 Not Recognized
Sun Sep 11, 2016 9:04 pm
I found a post with a similar problem
Quared
Trainer
Trainer
Mon Sep 12, 2016 9:26 pm
just to make sure:
1. you're operating a miniPCIe-module with RB953 which is properly fixed :) (have seen some troublesome fixed modules as well)
2. you set the USB mode to mini PCIe
3. you rebooted the system
then open a terminal window issuing
 /system routerboard settings set init-delay=4
reboot again and check if the lte interface is present
please report your findings back
greets
newlord
Mon Sep 12, 2016 9:39 pm
just to make sure:
greets
Thank you for your help
1. Well fixed
2. yes
3. yes
4. Execute the command - yes
Unfortunately it did not help. LTE interface does not appear.
What firmware version LTE HUAWEI ME909s-120 do you use?
hursta
Mon Sep 12, 2016 10:51 pm
seems this workaround works with RB922UAGS-5HPacD but not with RB953GW-5Hnt-RP boards.
Greetings, Andreas
newlord
Tue Sep 13, 2016 7:51 am
Greetings, Andreas
somebody write what version of firmware LTE HUAWEI ME909s-120 works?
Quared
Trainer
Trainer
Tue Sep 13, 2016 11:27 am
got several ME909s-120 working flawlessly,
Huawei firmware 11.617.01.00.00
latest RouterOS release (6.36.3) and latest firmware per device
greets
kristaps
Tue Sep 13, 2016 5:44 pm
If you are experiencing issues with ME909s card in RouterOS or in RouterBoard please send us email support@mikroptik.com
Also you can try to set this setting as mentioned before.
/system routerboard settings set init-delay=5
hursta
Tue Sep 13, 2016 9:31 pm
RB922UAGS-5HPacD and ME909s-120 works fine
- V6.37rc32 / firmware 3.34
- 11.617.01.00.00
however RB953GW-5Hnt-RP board and ME909s-120 not!!
- 11.617.01.00.00
- > NO lte1 Interface!
/system routerboard settings set init-delay=5 -> does not fix that issue.
I double checked that with two RB953GW boards and ME909s-120 modules. Always the same!
Quared
Trainer
Trainer
Tue Sep 13, 2016 10:00 pm
@Hursta:
Please proceed with Kristaps' hint to find the issue.
Generate supout.rif file from your system (RB + ME909s) and mail it to support@mikrotik.com
Greets
pege
Wed Sep 20, 2017 11:34 am
@Hursta:
Greets
Soooooo was there never any answer to this?
Bfalk
Thu Oct 19, 2017 10:31 pm
I have the same problem, how can i fix it?
leon84
Thu Dec 21, 2017 1:17 pm
Please,
I'm trying to use Huawei ME909s-120 with RB411 but nothing. I have also changed capacitor n routerboard.
Dear Mikrotik, please, can you send me an official answer please? I bought a lot of ME909s-120and RB411 and I can't use it.
Users browsing this forum: No registered users and 84 guests
