dcosta
Can I install Cloud Hosted Router (CHR) on XEN server?
Tue Sep 13, 2016 3:30 pm
Can I install Cloud Hosted Router on XEN server?
If yes what image should I use?
If not is it planned to be available?
I haven’t found information about this on http://wiki.mikrotik.com/wiki/Manual:CHR
Thanks,
David Costa
pukkita
Trainer
Trainer
Re: Can I install Cloud Hosted Router (CHR) on XEN server?
Tue Sep 13, 2016 4:45 pm
Have a look or search that forum...
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
BartoszP
Tue Sep 13, 2016 6:05 pm
Real admins use real keyboards so Make Forum Great Again. Post, Reply & Quote Smart.
NetHorror
Mon Oct 24, 2016 1:25 pm
any updates?
MTCNA, MTCRE, MTCTCE, MTCWE
maznu
Thu Nov 24, 2016 12:41 am
I've had no problems getting CHR to run under Ganeti with Xen as the hypervisor. That's not necessarily the same thing as "Xen Server", but it will run under a Xen dom0. I used a HVM domU, but specified paravirtual NICs and IOEMU for the HDD. I've not yet found a way to get it to run as a paravirtual guest. Here's a relevant config file. Maybe that'll help you? :)
builder = 'hvm'
memory = 1024
maxmem = 1024
vcpus = 2
pae = 1
acpi = 1
viridian = 0
apic = 1
device_model = '/bin/true'
boot = 'cd'
sdl = 0
usb = 1
usbdevice = 'tablet'
vnc = 1
vnclisten = '0.0.0.0'
serial = 'pty'
vif = ['ip=169.254.0.0, mac=aa:00:00:62:22:2a, type=paravirtualized, script=/etc/xen/scripts/vif-ganeti-ovs, bridge=bridgenamegoeshere']
disk = ['phy:/var/run/ganeti/instance-disks/hostname.goes.here:0,hda,w']
on_poweroff = 'preserve'
on_reboot = 'restart'
on_crash = 'restart'
Marek
gamerxp
Fri Dec 09, 2016 3:13 am
I can confirm that CHR working fine with XenServer.
[MTCNA] 1608NA602
Buster2
Fri Dec 23, 2016 9:56 pm
Does live migration work with this setup? I've still issues with XenServer 6.5 and RouterOS 6.38rc52 as described in this post.
jonathandick
Thu Feb 16, 2017 7:52 am
We are able to install on xen-server but the disk is read-only so we can not save any settings. Any advice on how to make disk writeable?
Mapik
Wed Jun 07, 2017 12:54 pm
Use XenServer 6.5 or newer and it will be OK...
emersonschuede
Thu Aug 17, 2017 7:58 pm
i use here, with xen 7.2 and routerOS 6.39.2, work's perfectly with 1gb of ram
Users browsing this forum: No registered users and 1 guest
