MUM Europe 2020
wireless12
Request time out and only few operating frequencies
Fri Sep 16, 2016 10:16 am
Dear Frds,
i have got a PTP wireless link having RB Metal 5SHPn at both end with 27 dbi grid antenna.
issue:
1) only frequencies in dark bold font ( Pic attached of Access point ) are workable, if i select any other frequency other then the bold font the link do not work, how ever i have selected superchannel as frequency mode in both radios
2) when i see wireless table it shows a separate WDS name while the default WDS name is = wds1 (Pic attached of Access Point)
(3) when i ping the station from Access point then there numerous timeout to the station ( Pic attached)
IP address of Access Point = 192.168.XXX.56
Ip address of Station is = 192.168.XXX.57
i m just not able to understand why it is happening, did i configure it wrong, kindly help, its urgent
wireless12
Re: Request time out and only few operating frequencies
Fri Sep 16, 2016 8:38 pm
plz help
jarda
Sat Sep 17, 2016 8:26 am
Why you think that is necessary to hide 229 from the address? Can you check signal tab of both ends after at least 5 minutes of connection and at least 10mbits of sustained both way simultaneous traffic?
Can you check long-term spectral scan on both ends?
IntrusDave
Sat Sep 17, 2016 8:47 am
The bold are the usable channels.
Why are you using 802.11a on hardware that supports N?
It has much better range and is more robust.
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
Users browsing this forum: No registered users and 22 guests
