krisjanis
The Dude, v6.38rc test builds.
Mon Sep 26, 2016 10:19 am
Changes in v6.38rcX:
*) Added support for The Dude configuration from CLI; (work in progress).
*) Added option to use dns name in smtp server.
All entries below are already confirmed and reported to DEV for fixing.
Higher priority problems:
* Client updater broken.
Lower priority problems:
* Adapt dude link labels to be able to show 10G traffic and larger (snmp part left to fix);
Enhancement requests:
* Add option to use functions and oids in notification messages;
* Add AES encryption method to dude side snmp v3 profiles;
* Add option to configure user in a way to allow access only to certain panels;
Unrelated to v6.38rc builds:
Link to v6.37 web release topic: http://forum.mikrotik.com/viewtopic.php?f=8&t=112598
paulct
Re: The Dude, v6.38rc test builds.
Mon Sep 26, 2016 10:28 am
Hi
Any chance for radius login to the dude?
docmarius
Mon Sep 26, 2016 10:34 am
Any chance of getting the dude on PPC?
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
jchmelik
Tue Sep 27, 2016 10:40 am
CyberTod wrote:
Some variables in notifications seem to be missing, for example :
[Service.Status]
[Service.ProblemDescription]
Thank you. The fix for this will be included in next release.
This is a very serious bug.
This bug means that in fact, notifications not working.
Please give a quick fix.
I don't want to downgrade from version 6.37 to 6.36rcXX (there are many changes associated with DB).
Thank you.
saschap
Tue Sep 27, 2016 1:10 pm
+1 Any change for radius login to the dude?
facubertran
Tue Sep 27, 2016 4:44 pm
Permit only login to hesitate, not allowing api, winbox web, etc.
+1 Radius login
Serious problem..
[Service.Status]
LifeGame
Wed Sep 28, 2016 8:49 pm
Please add
ipsec vpn interface
Lakis
Forum Veteran
Forum Veteran
Thu Sep 29, 2016 12:47 pm
Can u reproduce this problem
As u can see on the picture (in label appearance) Dude can read two functions but probe says "time out"
After rebooting Mikrotik Device - where Dude is installed all back to normal for some time
Edit. I inspected the problem, I come to this findings
For some reason Dude stop reading values from device, as u can see on picture values are wrong they are "stuck" at the point where dude probably lost connection to the device but for some reason Dude cant reprobe or cant get new values from the Device
But when I try dabble click on device in RouterOS TAB - Interfaces I can see interfaces as it should be (on ether1 bits are rolling every second as traffic passing by)
That mean Dude have access to the device
After Rebooting Dude server Functions- start reading again and Probes go up again.
Another thing on Device label as u can see two from tree probes are down Device have orange colour as normal but there is no info about 2 probes on label [Device.ServicesDown]
Function are made using ros_command for example "ros_command(":put [/system resource get cpu-load]")" and etc. etc.
nemke
Thu Sep 29, 2016 9:55 pm
+1
kolorasta
Sun Oct 02, 2016 5:21 am
I upgraded from 6.37rc15 to 6.38rc7 and my email notifications doesn't work anymore
i get ERROR SENDING EMAIL: DNS RESOLVE FAILED
it was working before upgrade. My email server is a local smtp server and I put the ip in the SERVER IP field.
i try sending emails with tools/email and it works
FFAMax
Sun Oct 02, 2016 4:58 pm
Hi!
No client for rc version =(
Please keep at site actual link for newbies.
http://download2.mikrotik.com/routeros/ ... .38rc7.exe
Axel
Sun Oct 02, 2016 7:26 pm
Will the Russian language on the client?
Ham
Mon Oct 03, 2016 4:39 am
Lakis we are having a similar problem, SNMP queries will stop going out from the DUDE server after a short while.
We confirmed that there was no SNMP request leaving the dude server after about 5 minuets of operation, a reboot will get it working again for a short while.
We are running the dude from CHR, are you also running the dude from CHR?
Lakis
Forum Veteran
Forum Veteran
Mon Oct 03, 2016 12:08 pm
To Ham
Glad to hear that its not just me, I've searched the source of the problem for days, probably it's just a bug.
I m running my Dude on x86
jchmelik
Mon Oct 03, 2016 2:43 pm
I have installed 6.38rc7.
Bug with missing some variables in notifications ([Service.Status], [Service.ProblemDescription] etc.) is now fixed.
But there is a new bug - popup and flash notifications not working me. In the previous version (6.37 final) that was okay
esmir
Tue Oct 04, 2016 12:50 pm
+1 Radius login
Serious problem..
[Service.Status]
I have totally the same problems with notifications.
For example:
Subject: device-name-01: Service ping is now [Service.Status]
Content:
Service ping on device-name-01 is now [Service.Status] ([Service.ProblemDescription])
Comment: [Service.NotesCommaList]
Time Last Down: [Service.TimeLastDown]
Time Last Up: [Service.TimeLastUp]
Services on Device (LastStatus):
UP: ping, Ubnt6_ccqHistory, Ubnt6_ccqUnder92, Ubnt6_connections Services DOWN: Ubnt6_ConnectionRateHistory, Ubnt6_ConnectionRateUnder78Mbit
Unstable: http
Unknown:
Acked:
szalkerous
Wed Oct 05, 2016 2:52 am
ERROR: missing dude-6.37.1-tile.npk (on Current/Stable channel)
ERROR: missing dude-6.38rc8-tile.npk (on Release Candidate channel)
My Devices: CCR1009 Primary Router+Firewall / CRS328 main switch / 3x cAP AC / BaseBox 2 (RB912) 2.4Ghz AP / NetBox 5 (RB911G) 5Ghz AP / Handful of RB260GS switches.
kolorasta
Wed Oct 05, 2016 4:51 pm
try now.... 6.38rc9 is available
macgaiver
Wed Oct 05, 2016 5:33 pm
you know there are old fashion way of upgrading - downloading packages manually, uploading them to the router and rebooting :)
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
kolorasta
Wed Oct 05, 2016 5:49 pm
upgraded to 6.38rc9 ....
can't connect via WINBOX (after login automatically closes)
can connect via ssh
can connect via thedude_client
TheDude email notifications still doesn't work
kolorasta
Wed Oct 05, 2016 5:52 pm
TheDude package 6.38rc8 download link in the MT website was broken too.
macgaiver
Wed Oct 05, 2016 6:14 pm
otgooneo
Trainer
Trainer
Wed Oct 05, 2016 8:59 pm
Is it possible to upgrade only dude package to 6.38rc on the CCR side?
Want to learn more and more...
kolorasta
Wed Oct 05, 2016 9:10 pm
I think it's not possible. All packages must be same version
otgooneo
Trainer
Trainer
Wed Oct 05, 2016 10:47 pm
This is release still doesn`t have possibility to add device with mandatory basic values.
PaulsMT
Thu Oct 06, 2016 3:01 pm
Thank you all for testing and reporting.
For some reason Dude stop reading values from device - Dude cant reprobe or cant get new values from the Device
These values will keep updating, but it might take some time, we will see if we can improve it.
Fixed in 6.38rc9
Fixed in 6.38rc9
Will try to reproduce the problem.
Reported for fixing.
No you have to update the system package too.
otgooneo:
Can you please give more detail ? Could not see any problems with adding devices.
kubaver
Thu Oct 06, 2016 4:37 pm
After update to 6.38rc10 still can't connect via WINBOX...
GreySer
Fri Oct 07, 2016 9:04 am
Me too :(. support says - Must remove dude server from mikrotik, when winbox is works.
kubaver
Fri Oct 07, 2016 2:29 pm
But just Dude server is the reason for my testing rc versions :-)
Eagerly I await the opportunity to place an one object on several maps (or move object on other map without lost their history data).
asik
Thu Oct 13, 2016 12:40 pm
6.38rc14 (Release candidate)
my requests
1. all alerts that have occurred in non-active time for such notifications for example between 00:00-08:00, should be added to the queue and be send at the beginning of an active time. If by that time the service started to function, the notification shall be removed from the queue.
2. If the main map contains several submaps, and added there devices are set depending on (parents), and when the device is not working in the tree above, I should get one notification about device failure which is highest on the tree even if it is on a different submap. Now i have many alerts. Maybe I have problem configuration of the DUDE?
asik
Thu Oct 13, 2016 1:01 pm
asking for adding zoom settings for each of the charts separately or finally for the all charts one settings.
I keep my fingers crossed for your good work. ;)
laguten
Mon Oct 17, 2016 2:16 pm
Will the Telegram notification support?
derr12
Wed Oct 19, 2016 1:41 am
any progress on the notifications bug?
Service ping on x is now [Service.Status] ([Service.ProblemDescription])
DaveBrowning
Thu Oct 20, 2016 9:35 am
Just upgraded to 6.38rc15
Radius user login = "radius authentication is not supported for old challenges"
Also, when logged in as standard user. Screen flickers and jumps between maps.
What gives?
sparker
Sun Oct 23, 2016 10:54 am
+1 Radius Login problem
Sorry for my English.
claymen
Tue Oct 25, 2016 12:54 am
Please add in notifications any metod to post messages
/fetch from Router os
/tool fetch url=”https://api.telegram.org/bot153358077:A ... unnel_DOWN” keep-result=no
or native telegram support (https://1spla.ru/blog/telegram_bot_for_mikrotik/)
is it really so difficult?
Great monitor but can not notify anybody.
Thanks for you WORK.
laguten
Tue Oct 25, 2016 7:18 pm
Thanks for you advice! It is not really so difficult and I've done it before my question. But I interested by telegram notifications from The Dude. I think that for this advantage would be enough add functionality /fetch to The Dude.
May be it very difficult for developers... (?)
chizh
Wed Oct 26, 2016 10:46 am
+1
krisjanis
Wed Oct 26, 2016 2:09 pm
Changes for builds up to v6.38rc19:
*) Added - AES encryption method for snmp v3
*) Added - Dude configuration interface in Winbox (Requires latest Winbox version 3.7)
*) Added - Dude configuration interface in Webfig
** Maps are view-able in web mode.
*) Agents - Now any RouterOS device can be used as The Dude agent. It no longer requires
server package and ROS login. THIS FEATURE BECOMES AVAILABLE STARTING WITH v6.37rc18
*) Agents - Old agent section removed from client.
*) Fixed - Bandwidth test tool. (broken since v6.37)
*) Fixed - Auto-discovery was adding devices with non-usable characters in name field.
*) Fixed - SNMP server didn't work without dns name. (broken since v6.38rcX)
*) Fixed - Some notification types:(flash, popup, log event) didn't work properly. (broken since v6.38rcX)
*) Fixed - Fixed some issues with client where menus didn't display correctly at first access after upgrade. (broken since v6.38rcX)
*) Fixed - It wasn't possible to delete some elements from network map. (broken since v6.38rcX)
*) Fixed - Default variable [Device.RosVersion] didn't return correct value. (broken since v6.38rcX)
*) Fixed - Issues with link not changing color when traffic grows.
*) Fixed - It wasn't possible to open multiple simultaneous panels. (broken since v6.38rcX)
*) Some improvements for DB data write in store.
PS. to use ROS device as agent you do need to have valid user login and "Router OS" check-box marked.
raffav
Wed Oct 26, 2016 3:56 pm
testing the winbox dude session
on device i put a mk device and iam getting connect failed: Connection refused(111)
EDIT:
find it, winbox port
i cant understand way it is still not possible to set the on witch port Dude need to connect,
mmandrino
Wed Oct 26, 2016 4:00 pm
I am running Dude on CHR - v 6.37.1 now, and looking for futher updates.
Here are the issues so far:
- Slow response when double clicking on device - changing Agents from default to server speeds up to no delay, but we are not using Agents now, so default should be server ?
- Users in read only mode cannot change own passwords
krisjanis
Wed Oct 26, 2016 4:29 pm
EDIT:
find it, winbox port i cant understand way it is still not possible to set the on witch port Dude need to connect,
Because server is now using winbox port. It no longer has separate port to access.
1. Is this CHR still using free license level? Usually with CHR / The Dude setups with free license level the 1Mbps limit on interface is causing that Client/Server performance issues.
2. Which exact password do you mean?
mmandrino
Wed Oct 26, 2016 4:39 pm
EDIT:
No, we have P1 full licence.
Also after a connection breakes (VPN, wireless) the users cannot login, and CPU spikes until broken connection timeouts!!!! Winbox or dude cannot login!!
I mean user password for dude login / we setup password for users but would like to let them have option to change from client (users with dude access no winbox)
raffav
Wed Oct 26, 2016 4:40 pm
EDIT:
Yes i know but i dont use default winobox port 8291 for security reason it will be very nice to be possible to tell dude on witch winbox port connect
Lakis
Forum Veteran
Forum Veteran
Thu Oct 27, 2016 2:32 pm
Sorry for been annoying
This is not fixed yet
If Dude lose connection to Some device, device go red - normal but values like cpu, mem are stuck showing last value on device appearance
When device is on-line again, dude ping service is up but other SNMP services are down (timeout). I tried Reprobe - not helping
Only when I reboot Dude Server all service are up again.
ste
Thu Oct 27, 2016 3:46 pm
Great move! So I guess winbox will be dude client.
9939781
Fri Oct 28, 2016 9:06 am
my ccr1072 have a lots of ip-mac info.but i not need it.i need dude show ccr1072 interface traffic only.becouse show the ip-mac and the other will use more cpu,and i found ccr1072 one core 100% always.i need dude show interface traffic only,
I need a about mikrotik job
Welcome to my blog:http://www.cat-home.org
PaulsMT
Fri Oct 28, 2016 10:34 am
You can specify probe port under device settings => Services => routeros mangement => Probe Port
Latest RC versions have improvements for label refresh, when device is not reachable,
so you should not see [device_performance()] when the host is down. When the host is up, the snmp probes will start to refresh after few minutes.
It's also possible to disable SNMP under device => General => Snmp Profile => no-snmp, for interface traffic you can use Mastering Type - Routeros
Lakis
Forum Veteran
Forum Veteran
Fri Oct 28, 2016 12:38 pm
Yes I know it should work like that, as it works in v3.6, ok maybe I am wrong in something I'll rebuild new test map and observe, in meantime if somebody has same experience please inform.
Thanks.
edited: Yes SNMP are working (with big delay) but Functions with ros command's are not, after dude failed to reach device
simple Dude can't get from device ros_command(":put [/system resource get cpu-load]") or ros_command(":put [/system healt get voltage] and etc.
but on map in device RouterOS TAB I can see that dude has access. After reboot dude start to read values using ros_command
can you reproduce this problem?
raffav
Fri Oct 28, 2016 3:55 pm
sorry but i didn't find it or understand well
9939781
Sat Oct 29, 2016 4:07 am
It's also possible to disable SNMP under device => General => Snmp Profile => no-snmp, for interface traffic you can use Mastering Type - Routeros[/quote]
thank for your reply.if that,the dude will use winbox mode login.but i can not let dude user to login winbox.so have a the other solve plan?
ste
Mon Oct 31, 2016 11:07 am
I have some problems with the dude client and window tiles.
I normaly use a 3 pane layout. One is the map where I click thru on the bottom, and two panes at the top with active outages and with chart of our uplinks.
Making the tiles at the top somtimes work, sometimes not. Reopening the panel the upper two tiles are empty.
Under Panels there are 2 with IP Address of client. Tried to remove them but both are claimed to be used. I have only one client connected.
Dude runs on CCR/6.38rc19 client is Win10.
tberg
Mon Oct 31, 2016 10:42 pm
The Snmpwalk tool appears to not work with 6.38rc19. I've tried on a number of devices and get a timeout for all of them. All of these devices have various SNMP services working correctly. Snmpwalk was working with 6.37.
ilunne
Mon Oct 31, 2016 11:10 pm
here too
tberg
Tue Nov 01, 2016 4:35 pm
More info. SNMP values are being collected and displayed correctly in appearance and SNMP tab of device. It is just snmpwalk tool that times out.
PaulsMT
Thu Nov 03, 2016 5:07 pm
New release candidate version (6.38rc24) is available!
http://www.mikrotik.com/download
Changes since v6.38rc19:
*) Removed - Link label will not change colour on link speed change.
*) Fixed - Allow users without FTP policy to connect to dude server (access to files will be restricted).
*) Fixed - Discovery stayed in "finishing" status.
*) Fixed - Devices showed device_performance even if the host were down.
*) Fixed - Snmpwalk were broken on X86 devices.
*) Fixed - History charts was flapping if the monitored device were down.
*) Fixed - v4 backup import fail.
*) Fixed - Multi-core devices showed CPU usage only from one core.
939781 wrote:
"if that,the dude will use winbox mode login.but i can not let dude user to login winbox.so have a the other solve plan?"
You can create a new user group with policies=read,dude, and add new user to this group. So this user will not be able to connect to your RouterOS.
ilunne
Fri Nov 04, 2016 12:00 am
Dude server package is offline
yarda
Fri Nov 04, 2016 12:37 pm
PaulsMT
Fri Nov 04, 2016 1:37 pm
Thanks for reporting, links are updated now.
raffav
Fri Nov 04, 2016 1:46 pm
Hello, i still trying to figure out how i can make the dude server to read RouterOS info on a RB device that dont use the default Winbox Port
PaulsMT
Fri Nov 04, 2016 1:57 pm
There are two opttions available to read RouterOS info:
1) Use default Winbox port.
2) Make firewall NAT rule on your monitored RouterOS device, to redirect the dude server form default Winbox port to your custom Winbox port.
Chupaka
Fri Nov 04, 2016 2:32 pm
isn't that visually the same as NOT changing winbox port? :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
raffav
Fri Nov 04, 2016 3:06 pm
thanks
danayalop
Fri Nov 04, 2016 9:04 pm
I understand then that the labels will become ever more to change color to increase traffic? It was a very useful tool when maps are minimized.
Lakis
Forum Veteran
Forum Veteran
Sat Nov 05, 2016 12:09 pm
ver rc24, I tested and retested Services, probes finally are working correctly, also some device appearance issues are fixed - please don't brake it :).
I have demand if its possible to be added wireless access list TAB in device RouterOS TAB?
Also probably there is a reason why upload is disabled, when will be re enabled?
ilunne
Sun Nov 06, 2016 3:27 pm
I created a skin to allow certain User web access only to network maps. It worked well, however, I noticed that after logging, displays the list of dude files, which in this case should not be allowed by the skin. I wish this were checked. Also, I would like a feature was added: Ability to define groups for network maps, so, too, be feasible through a skin and also the dude client, allow certain users to interact only with the maps in one or ais groups selected.
My Skin File:
    'Quick Set': 0,
    CAPsMAN: 0,
    Wireless: 0,
    Interfaces: 0,
    PPP: 0,
    Bridge: 0,
    Mesh: 0,
    IP: 0,
    MPLS: 0,
    Routing: 0,
    System: 0,
    Queues: 0,
    Files: 0,
    Log: 0,
    Radius: 0,
    'New Terminal': 0,
    Tools: 0,
    Dude: {
        Devices: 0,
        Functions: 0,
        Links: 0,
        Mibs: 0,
        'Network Maps': {
            'Network Map Elements': 0,
            Discoveries: 0,
            'Network Map': {
                '&': { remove: 0, set: 0, name: 'Mapa da Rede:', title: 'Mapas de Rede' },
                General: {
                    'Default Zoom': 0,
                    Status: 0,
                    tab: 'Imagem',
                    Name: { ro: true, name: 'Nome:' }
                Polling: {
                    Enabled: 0,
                    'Probe Interval': 0,
                    'Probe Timeout': 0,
                    'Probe Down Count': 0,
                    'Use Notifications': 0,
                    Notifications: 0
                Appearance: {
                    'Label Refresh Interval': 0,
                    Background: 0,
                    Device: 0,
                    Network: 0,
                    Submap: 0,
                    Static: 0,
                    Link: 0
                Color: 0,
                Image: 0,
                Scale: 0,
                Tile: 0,
                Label: 0,
                'Link Color': 0,
                'Link Full Color': 0,
                'Link Label Color': 0,
                Thickness: 0
        Networks: 0,
        Notifications: 0,
        Probes: 0,
        'RouterOS Info': 0,
        'SNMP Profiles': 0,
        'Server Config': 0,
        Services: 0,
        Settings: 0,
        'Syslog Rules': 0,
        Tools: 0,
        Charts: {
            Chart: {
                Name: { ro: true }
            'Chart Line': 0,
            'Data Source': 0,
    'Make Supout.rif': 0,
    Undo: 0,
    Redo: 0,
    'Hide Menu': 0,
    'Hide Passwords': 0,
    'Safe Mode': 0,
    Manual: 0,
    License: 0,
    Graphs: 0
kolorasta
Mon Nov 07, 2016 9:14 pm
SNMP still doesn't work work for me... i can't get some devices values via snmp
i'm using v6.38rc25
ilunne
Mon Nov 07, 2016 10:25 pm
Hi, switch to snmpv2, try it.
Here work when i change
i'm using v6.38rc25
kolorasta
Mon Nov 07, 2016 10:45 pm
i switch to snmpv2 and i had to restart switch and now it works...thank you,
Lakis
Forum Veteran
Forum Veteran
Tue Nov 08, 2016 12:05 pm
Its not your job, but how did you upload pictures?
ilunne
Tue Nov 08, 2016 7:08 pm
FTP, or Winbox
kolorasta
Tue Nov 08, 2016 7:39 pm
Pictures in the dude?
Used to upload vía thedude client, but now it's only possible via winbox or ftp... or SMB too
Lakis
Forum Veteran
Forum Veteran
Wed Nov 09, 2016 3:52 pm
Thanks, yes I can upload via Winbox or FTP but the problem for example how do I place some picture in dude/files/default/images dir so I can use it in dude client
For Example: I try to upload via Winbox picture "omnitik.png" directly in dude/files/default/images nothing happens
I can upload picture to / dir but when I try to move it to dude/files/default/images I receive Couldn't change file <omnitik.png> action failed (6)?
tberg
Wed Nov 09, 2016 4:54 pm
Try putting the image files in the dude/files/images dir. Mibs go in the dude/files/mibs dir. I found it much easier to use ftp than Winbox.
krisjanis
Wed Nov 09, 2016 5:20 pm
Default dir in files is now automatically generated by server. It creates symlinks there of default files(img, mib, etc). This way it easier to avoid corrupted default server content and also it pretty much saves space that way.
Your custom files can be stored in files dir or any sub-dir that you create there.
amt
Long time Member
Long time Member
Thu Nov 10, 2016 7:48 am
Hi All,
I upgrade dude to V6.38rc25 and now when i click on devices and select router os, almost all device gives this error " std failure: not allowed (9), next attempt at Nov/10 10:28:56 " and dude cant log in to devices so i cant see the graphs also. what can be the problem ?
krisjanis
Thu Nov 10, 2016 11:09 am
Hi All,
ROS login seems to be working ok with lab devices w/ rc25 server.
1. Is login credentials correct in device settings?
2. On monitored device in group policy winbox and dude policies should be makred otherwise server wont be able to access the device
Lakis
Forum Veteran
Forum Veteran
Fri Nov 11, 2016 12:22 am
x86 /dude/files/ dir it works thanks
amt
Long time Member
Long time Member
Fri Nov 11, 2016 11:38 am
Hi All,
login credentials are correct in device settings, when i select winbox from tool menu of dude , i can enter to the device without problem. before upgrade there was no problem. also On monitored device in group policy winbox and dude policies makred
strzinek
Fri Nov 11, 2016 9:24 pm
Hello, I upgraded from 6.37.1 to 6.38rc29 and moved from CCR router to vSphere x86 CHR VM because of continuous restarts of Dude caused by CPU and memory exhaustion.
The CPU and memory utilization now seems ok, but I found few annoying bugs:
- color gradation of stressed links and link labels not working
- status flags of network maps in left tree contents panel are missing
- snmp walk tool not working
- drag&drop file transfers between PC and Dude not working in either direction
While upgrading RouterOS to v6.38rc29 I also noticed that SMB server implementation on RouterOS is broken as my automated DudeDB backups started to fail.
What I would also really appreciate in new Dude version:
- ability to filter snmp oid arrays by regular expressions in Dude functions (or at least by substring match)
- support of live db backup (or ability to export Dude configuration with no history data), whithout needing to stop the Dude server
cgaspar
Sat Nov 12, 2016 3:07 pm
Hello, I've updated The Dude to 6.38rc29 version and the e-mail notification is not working. Any changes with the variables at all?
{ Body: Service [Probe.Name] on [Device.Name] is now [Service.Status] ([Service.ProblemDescription]) }
kolorasta
Sun Nov 13, 2016 4:12 pm
Hi. Email notifications are working fine here. I use rc29. Variables used to be broken en previous rc versions. Since rc20 approx they are working fine.
PaulsMT
Mon Nov 14, 2016 9:41 am
Changes since v6.38rc25:
*) Fixed - Error on dude RADIUS authentication.
*) Fixed - In some setups dude server caused memory leak on X86/CHR.
*) Added - Dude server now supports spectral scan up to 7Ghz.
Starting from 6.38.X link labels will no more change colour. Link itself changes colour depending on the link rate, and actual link traffic.
File transfers using dude have been disabled, instead you can use Winbox, Webfig or ftp.
Snmpwalk will be fixed in next rc version.
Can you please specify, what you want to achieve using snmp oid regex filtering ?
Quick tests didn't show any problems with SMB server on the latest RouterOS. Can you please give us more details about this issue ?
Also didn't found problems using email notifications on 6.38rc29
amt
Long time Member
Long time Member
Mon Nov 14, 2016 2:29 pm
Problem Continue also on V6.38rc29.. dude cant login devices and gives same error. but from dude we can enter devices from tool>>winbox
strzinek
Mon Nov 14, 2016 6:53 pm
Thank you for explanation.
With snmp oid array filtering I would be able to monitor values in sub-arrays, which I can't now (array_find with array_element gives me just first occurrence in array). For example I need to count particular process instances on server, or to sum up disk space of particular data storage type on vSphere server, e.g. based on volume name prefix "/vmfs/volumes/x.*".
About SMB problems: I have only one SMB share, configured as hidden ("share$"), and one user with RO rights and simple password. When I connect to this share for the first time after RouterOS reboot, connection succeeds from Windows client, but then when I try to mount that same share from linux machine, this times out with message "mount error 112 = Host is down". After that I'm not able to connect to share from any other host. I do not have FW configured on RouterOS, and this share just worked fine on v6.37.1.
FlavioCamacho
Trainer
Trainer
Mon Nov 14, 2016 10:31 pm
Hi
Any chance for radius login to the dude and back the WebServer on port 80?
Att.
Mikrotik Training Partner
maxkrok
Tue Nov 15, 2016 1:35 pm
The Dude does not save any data after reboot on HEXgr3 neither on flash nor on the SDcard. After reboot the SD "disk1" becomes "disk2" if Dude is installed on it. If you change Dude path to "disk2" then the name of the SDcard would again becomes "disk1" after another reboot.. It is like a hell... I couldn't save any data on Dude after RB reboot.. What is it? The OS version is 6.38RC25
PS... On 6.37.1 - the same dulls
On this it was answered here - http://forum.mikrotik.com/viewtopic.php ... 90#p567650 as everyone in Mikrotik knows about this, but nothing is changed in the new releases...
aTan
Wed Nov 16, 2016 11:37 am
Is there a changelog for 6.38rc31? Or nothing have been changed?
PaulsMT
Wed Nov 16, 2016 1:56 pm
Changes since v6.38rc29:
*) Fixed - Snmpwalk was broken starting from 6.38rc27
*) Fixed - Dude db-import failed if dude wasn't enabled
amt - such error is showed if the connection is restricted from the router side, I wasn't able to reproduce such problem, maybe it's because of monitored device configuration. If monitored device is RouterOS, please send us the supout file from it.
support@mikrotik.com
strzinek - we have found possible bug for SMB related problem, it's now reported.
FlavioCamacho - currently it's possible to monitor / manage dude using web interface through webfig tool.
maxkrok - thanks, this issue is known, and also reported.
strzinek
Wed Nov 16, 2016 4:34 pm
Thank you for correcting the snmpwalk.
I found other bug in rc31: missing graph captions in device history panel.
maxkrok
Wed Nov 16, 2016 5:27 pm
MMIPS (RB750gr3)
In 6.38rc30 you can add custom files (images, font,etc) into dude dir tree using winbox (when dude is stopped) and in 6.38rc31 you cannot. I'm back to 6.38rc30. The sdcard disk1 | disk2 mess is still a headache during reboot and if dude is running when rebooting... Please make available adding custom files to dude dir tree using dude client.
denser
Thu Nov 17, 2016 8:35 am
Please, fix dude, i cant connect to dude server since 6.37.
When i connect - it says me "getting stuff" , client rx becomes about 10MBps and then goes to 300-600 kbps and stays on login page. I update to RC 6.38rc31 - same here. Seems you fix autoupdate but still wont show me DUDE. Stuck on login.
What should i do?
leoktv
Trainer
Trainer
Thu Nov 17, 2016 8:57 am
What should i do?
I got the same problem after upgrading to rc31 from rc25.
i did a snapshot on the VM before but eaven after reverting back to rc25 i get the same problem. any ide to the problem.
_________________
Leo De Geer, Mikrotik Certified Consultant/Trainer #TR0003, MTCNA, MTCRE, MTCWE, MTCTCE, MTCINE, MTCUME, MTCIPv6E MTCSE MTCASE MTCSWE & MikroTik Distributor
http://www.mikrotik.se
support[at]mikrotik.se
Office: +46 325 660 650
denser
Thu Nov 17, 2016 9:13 am
What should i do?
i did a snapshot on the VM before but even after reverting back to rc25 i get the same problem. any ide to the problem.
I get some workaround and here: i delete dude, delete files. Install clean dude and can connect. So reason - dude db. How we can debug it? May be some files are corrupted or language or encoding? I have dude since 3 version with Russian language.
leoktv
Trainer
Trainer
Thu Nov 17, 2016 11:58 am
What should i do?
This did not help i also delited all registry entrys left behind but no luck.
_________________
PaulsMT
Thu Nov 17, 2016 1:23 pm
Very good, thanks, and can you please clarify, is this problem only in device pop-up window (history graphs), or you also see the same in device > history charts ? Seems like there is issue only if some service is down on monitored device.
maxkrok - This is known issue, and it's in our priority list.
denser and leoktv - Please generate a supout file from the dude server, and send it with description to support@mikrotik.com. We will try to reproduce and fix it.
flaviojunior
Trainer
Trainer
Thu Nov 17, 2016 6:31 pm
The changes with syslog are not good!!
We need to separete the log from each router and save the file for like one month!!
Return the syslog like it was is better.
Mikrotik Certified Trainer, Network Specialist.
Number 1 consultant Brazil, Rio de Janeiro
MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE, MTCSE
strzinek
Thu Nov 17, 2016 7:09 pm
This happens to me only in device history charts panel, not in pop-up window. And only sometimes, so it might be related to some device state.
denser
Fri Nov 18, 2016 7:37 am
Thankyou, sent info.
leoktv
Trainer
Trainer
Fri Nov 18, 2016 9:10 am
Sent as requested
_________________
onega
Fri Nov 18, 2016 4:38 pm
DUDE FEATURE REQUEST:
Ability to specify custom port number for Winbox connections (e.g. to connect to multiple MTiks behind single public IP).
Many thanks for consideration.
...also is there a dedicated thread to post DUDE feature requests?
Ayapov8
Mon Nov 21, 2016 4:59 am
Update my CCR to RouteOS 37.1 and DUDE. Problem: Dude no send syslog to remove server. Pleas help me
strzinek
Mon Nov 21, 2016 11:49 am
Another problems with latest RC versions:
When I schedule dude db backup on RouterOS (with
/dude export-db
command), I always get my custom font removed from disk after the operation and not available in Dude any more.
I also noticed that custom MIB, font and image files are contained in backup file, but do not get restored with
/dude import-db
command. I have to copy these files manually afterwards through WinBox and restart the Dude to be able to use them.
celeritynetworks
Tue Nov 22, 2016 2:16 am
Email seems to be broken in 6.38rc30 and 31.
This is what I see in RouterOS log when I try to test email send from an email notification in Dude.
Here is how the notification is setup:
I've tried removing all the fields so that it just uses RouterOS Email settings, but no change. I looked in email server logs and it's not even trying to send it to the SMTP server.
When I send a test email from RouterOS using Winbox, it works just fine.
Chupaka
Tue Nov 22, 2016 2:05 pm
Shouldn't TLS Mode be not 'no' for that port?..
maxkrok
Tue Nov 22, 2016 6:31 pm
Since 6.38rc30 I cannot add any custom files (images, etc) to the Dude directories.. Even it happens if Dude is stopped and it's directory is changed at another path. I use RB750gr3 - MMIPS. Please help.. the disk1|disk2 switching problem is still annoying on RC34..
maxkrok
Tue Nov 22, 2016 6:45 pm
which hardware do you use?
strzinek
Tue Nov 22, 2016 7:17 pm
I'm using Dude on CHR v6.38rc31 on vSphere server 5.5 right now, because on CCR the stable version 6.37.1 was exhausting memory and CPU.
strzinek
Tue Nov 22, 2016 7:20 pm
Thanks for fixing the smb crash in v6.38rc34, it is working ok now.
Keep up the good work :)
doush
Long time Member
Long time Member
Tue Nov 22, 2016 8:46 pm
Adding a user with only a "dude" permission doesnt work. User cannot login
HiltonT
Wed Nov 23, 2016 12:10 am
This is where RoMON comes in handy. Configure RoMON on the gateway MikroTik device and set a password. Configure RoMON on the internal MikroTik devices and use the same password. Then in WinBox, select the gateway MikroTik device and choose "Connect to RoMON" and WinBox will connect to the gateway MikroTik device, change the bottom tab to "RoMON Neighbors" and you will see all the devices listed by MAC Address, with their Identities shown.
If you choose to Add/Set a RoMON device, it will add it to the main "Managed" tab with the "Address" listed as the MAC Address. I then group these under each client's code and then add a Note so I can tell more easily which internal device this is.
- Hilton
Regards,
Hilton Travis
denser
Wed Nov 23, 2016 8:03 am
Guys, if there any ability to do such thing - connect links not in one point but in edge of object? When i want to draw 50 ports it become such a mess.
May be it should be able to make curves or polylines?
jarda
Wed Nov 23, 2016 8:05 am
That is something I was planning to ask for too. I am for it!
Chupaka
Wed Nov 23, 2016 2:03 pm
+1 (for multiple links betwee devices, for example)
also, it would be nice to have a possibility to set Interface for both ends of the link (to see that the link is from port 5 of switch1 to port 7 of switch 2)
sup5
Wed Nov 23, 2016 2:42 pm
Currently I solve this issue by putting a static-item inbetween a link.
This allows for
- links with angles
- setting both ends of a link with interface (and stats)
- drawing more than one link between two devices.
Chupaka
Wed Nov 23, 2016 2:47 pm
I was thinking about this, but...
PaulsMT
Wed Nov 23, 2016 3:11 pm
Version 6.38rc35 has been released.
Changes since v6.38rc32:
*) Fixed - Dude client stuck on "getting stuff state".
*) Fixed - Disk name were changed on RB hEX if the dude was used on USB flash or mSD card.
For security reasons it's suggested to make backups before upgrade.
http://wiki.mikrotik.com/wiki/Manual:Th ... ort_export
If you experience version related issues, give us detailed steps how to reproduce problem.
Also thank you all for suggestions and reports, we will take a look what we can improve in the Dude.
jarda
Re: RE: Re: The Dude, v6.38rc test builds.
Wed Nov 23, 2016 3:26 pm
This allows for
- links with angles
I have been using it for years also. But it is very poor solution.
I need multiple links between the same devices also. The idea to make link independently configurable by the endpoint devices / interfaces is the same I had in mind. It is also necessary to be able to replug the ends of the link from one old device to other new device without loosing the graph data.
leoktv
Trainer
Trainer
Wed Nov 23, 2016 5:39 pm
The problem with Dude client stuck on "getting stuff state" are confirmed solwed thanks MikroTik
_________________
nje431
Wed Nov 23, 2016 9:03 pm
Now that the Dude supports maps in Webfig, I updated our test Dude from 6.37rc15 to 6.38rc35. A few things I'm seeing with the Webfig maps:
Can't click on a sub-map from the primary map to display it.
Background images take forever to display.
It's not displaying the temperature symbol correctly. It's adding the additional  in front of the ° character. It displays correctly in both the 6.38rc35 Dude client, and in our 4.3 production Dude and Web clients. Appearance label: [Site_Temperature_Display()] °
maxkrok
Wed Nov 23, 2016 10:52 pm
Yes! Now Dude does not make disk name to be changed, but I cannot add any custom files to its directories even directly to RB/Files.. Please repair it and make available to add custom files over client...
HiltonT
Thu Nov 24, 2016 1:21 am
So, so yes!!!
And also, why is the "Wireless" link so... big?
Regards,
Hilton Travis
HiltonT
Thu Nov 24, 2016 1:22 am
+1
Regards,
Hilton Travis
denser
Thu Nov 24, 2016 10:48 am
Dude, please make links more cool, i even make White Russian for you :)
sparrow
Thu Nov 24, 2016 3:46 pm
Why on "link full" the colour don't change like in previous version 4.0beta or version 3?
Thanks for support
Attached image of dude 6.37.2
MTCNA - MTCRE - MTCWE
sparrow
Thu Nov 24, 2016 4:43 pm
And also if a service come back up from down, status on service outage does not change, is it normal??And its not possible to remove Resolved outages.........
Attached image below.
sparrow
Fri Nov 25, 2016 11:12 am
I have this message also:
dude,critical queued 33758554 bytes for write to db. Please consider faster storage otherwise out of memory condition or data loss can occur
Im using an ssd and ros is installed on a vmware machine to test the system before to make it in production
strzinek
Sat Nov 26, 2016 10:33 am
Still no graph labels in Device -> history tab in rc37.
denser
Mon Nov 28, 2016 8:06 am
Guys, in 37rc i get dude works! Thx goes to Pauls
- email support. But i have some troubles now.
1. I put font arial.ttf - its gone. Afetr i connect i see rectangles instead of russian letters. I put it again - wow, russian letters there again. Close Dude for a while. Run again - rectangles again, look into files - arial.ttf gone(whata...) Put it again - works for now.
2. Cant see snmp values on links. If i goes to node in snmp tab i can see speed on ports.
3. I have two monitors. If i open dude on 2nd and open preferences it can jump to 1st monitor. RRRRRR make me mad :)
PaulsMT
Mon Nov 28, 2016 9:33 am
Version 6.38rc37 has been released.
*) Fixed - default files will be stored in dude files folder if the file system does not support symlinks (fat32)
*) Fixed - avoid going into loop (Dude client could get stuck in loading phase)
Note !
Since dude has received major changes in recent versions, some fixes will be included only in 6.38+
Some bugs might be reproducable only on specific hardware, server and network configuration, etc..
List of recently reported problems:
strzinek - /dude export-db|import-db, and device -> graph issue.
Problem not reproduced, please give us remote access.
celeritynetworks - dude email notification is configured under notifications -> type email. If there are any problems in Ros/Dude email, enable email debug logs, to see where it stucks.
maxkrok - should be able to add custom files to dude/files dir.
doush - minimum polices for user to use dude is read + dude.
sparrow - monitored service types, like cpu, memory, disk... will take more time to reload, this means you will still see device in outage tab even it is recently came up.
Button "remove resolved" will remove only services without active status.
Also will take a look at denser reported issues.
If you still can reproduce problem using the latest RC, please allow us remote acces to your dude server, with
ability to install special debug package on this device, if it's will be necessary. Send all information to support@mikrotik.com,
also describe steps how to repeat the problem.
Reproduced issues:
nje431 - Background image load, ° symbol problem.
Recent feature requests for consideration:
*) Ability to specify custom port number
*) Links with edges
*) Multiple links between devices curves or polylines
*) Specify link port on both ends
*) Can't click on a sub-map from the primary map to display it. (webfig)
asik
Mon Nov 28, 2016 12:12 pm
my requests
no solution for these problems?
dcolli
Tue Nov 29, 2016 1:26 am
The execute on Server dont run script.
denser
Tue Nov 29, 2016 6:17 am
Some worksaround. Arial.ttf vanishes when old dude client connects and update itself.... Strange behavior.
Have another request (not onlu dude. capsman too) - autoload fresh versions of packages: analyse devices (caps in capsman) and download in prorep folder all needed files - files/packages on dude and folder pointed in properties in capsman.
chimaster
Wed Nov 30, 2016 1:29 am
Hey Dudes,
What happened to Address Lists?
Ok, that was brief, I'll Edit this up. Struggling with stability on 6.37.1,2,3 on x86, have tried to put our Dude onto CCR but that is also perfing out. x86 is based around SSL / CPU load, CCR is I don't know why. No idea why it's suddenly so unstable.
So trying to move to 6.38.something in the hope stability is there but it appears address lists have dissapeared. :( Can't find any mention of this in changelogs so assuming it's a bug, address list still turns up in /ip firewall address-list but they're pretty useless hanging over there as its our documentation when setting up routers / links in the dude.
Rock and a hard place over here with limited stability on "stable" releases and limited information / changes to core function (bugs) on unstable test builds.
We've got 2900 Access points and routers lulling around waiting for their admins to give them love, but right now.. the love.. it's .. .gone.
Can someone please think of the routers!?
Percanta
Thu Dec 01, 2016 6:09 pm
address list are on routeros now, /ip firewall address , so its working blacklist again (y)
maxkrok
Thu Dec 01, 2016 9:32 pm
6.38rc38 again adding custom files is not possible AT ALL.... Please repair...
maxkrok
Sat Dec 03, 2016 12:43 pm
6.38rc40 again adding custom files on MMIPS 750gr3 is not possible AT ALL.... Please repair...
PaulsMT
Tue Dec 06, 2016 3:08 pm
Changes since 6.38rc37
*) Fixed - File upload to dude/file directory caused client crash
*) Fixed - Background images could disappear on version change
*) Fixed - Snmpwalk was not working properly in recent versions
asik
At the moment it's not in schedule, but the request is stored, thanks.
dcolli
Few quick tests didn't show problem here. Make sure your dude user has the same policies as your script.
Test it with some simple script, to see if problem is not in the script itself.
If issue remains, send supout file to support@mikrotik.com.
denser
suggestion reported to developers
chimaster
address list is removed from dude v6.38.x
Please use address list from RouterOS
Also it would be great if you could provide us with remote access to device with SSL load problem.
maxkrok
Problem not reproduced. Works with USB/SD card as data storage path, tested with Winbox. FTP.
Make sure you are placing files in dude/file directory.
If you can repeat problem, please write to support@mikrotik.com.
Lakis
Forum Veteran
Forum Veteran
Wed Dec 07, 2016 12:59 am
chimaster
I confirm this, there is some SSL load problem on x86 OS 6.38rc40, reboot fixed for now
Next time I'll give you remote.
aTan
Wed Dec 07, 2016 10:25 am
I've already reported high cpu load by SSL problem (the Dude is unusable) on both CCR and x86 to Mikrotik support three weeks ago. But I can't give a remote access for now. So if anyone has the same issue, please provide a remote access, so it can be investigated and solved.
strzinek
Wed Dec 07, 2016 11:22 am
When I copy built-in tool to new one, I can't get rid of it afterwards. The copy cannot be removed. It says "cannot change built in (x)", although it is a copy and I can give it custom name and command. It shows star in flag column also as if it was really built-in tool.
mylek
Thu Dec 08, 2016 12:56 am
Before migrating from version 3.6 to the latest stop us lack of feature allowing to dump the list of devices in the form of a table: [map name where the device is] [device name] [IP address]. We use similar feature in Dude 3.6 via HTTP to export the device list with IP and location on the map to external databases (eg. smokeping). Any plans to add similar feature?
maxkrok
Thu Dec 08, 2016 12:29 pm
I cannot repeat it... It is permanent.. Please test on MMIPS RB750gr3. On RC44 the same problem... The dude directory is read only or something like that... Other directories - OK... Wrote to support..
UPDATE! All DUDE files are is being rebuit after each dude restart/reboot.. All custom files get vanished after that.. On sd disk - fat32 you can add custom files to the dude directories (images, etc) but after reboot/restart everything is default again.. All logs also get vanished.. Please help!
derr12
Thu Dec 08, 2016 8:38 pm
Im still having background images disappear from the disk at random times on X86 (xenproject hypervisor) on rc30. have to re-upload one or two weekly.
alfonzz
Thu Dec 08, 2016 9:15 pm
i use dude v6.38rc43 on new hex and there is maybe bug with RAM eating.
Hex stay up for 2 and half day and then reboot, for this time hour by hour eating the RAM until device reboot.
On dude i have about 1000 devices, monitoring by ping, some SNMP sonds etc.
It happens on earlier versions too.
alfonzz
Fri Dec 09, 2016 1:09 pm
All i want for Christmas is stable dude 6.38 :-)
FiShYmAn
Sat Dec 10, 2016 1:24 am
I am running dude 6.38 rc46, the last few builds have not been saving any changes for me, i have added new sites and devices in over 3-4 days and then the dude just reverts back to what it was like previous days ago - very frustrating.
Happy to setup remote access for support to look into it, ive lost several days work and would like a solution asap.
I've been using the dude since the beginning, loving the improvements, but this is a major bug.
Cheers,
Matt
2frogs
Long time Member
Long time Member
Sat Dec 10, 2016 6:57 am
Upgrade from v6.38rc40 to v6.38rc46 on CHR has removed the Dude Package. I had a Dude session open when it upgrade...
Lakis
Forum Veteran
Forum Veteran
Mon Dec 12, 2016 1:09 pm
Still SSL cpu load problem v6.38rc47
deathmagicmedia
Wed Dec 14, 2016 1:21 am
Agreed. It would be great if they added HTTP Notification as a notification type with custom parameters.
In the meantime, we created a Google Cloud App, which receives an email from the Dude server, converts the data, and then sends the data to Telegram. Our team will receive the data via our Telegram bot.
MikroTik Certified Network Associate (MTCNA)
Ubiquiti Broadband Wireless Specialist (UBWS)
Ubiquiti Broadband Wireless Admin (UBWAv2)
aTan
Wed Dec 14, 2016 3:52 pm
I managed to "fix" SSL high cpu problem (Ticket#2016111422000785) by increasing Connection timeout from 10s to 1m in Settings-RouterOS. On CCR it took a couple of minutes to get rid of SSL load after reboot, but it took much more time on x86 (4 cores). The problem was caused by hundreds parallel timed out connections to RouterOS (alive) devices and constantly repeating reconnections. After a successful connection to all RouterOS devices SSL load was gone.
PaulsMT
Tue Dec 20, 2016 2:11 pm
Version 6.38rc51 has been released.
Changes since 6.38rc41
*) Fixed - Changed SSL connection timeouts. SSL connections caused CPU overload
*) Fixed - Minor changes in Dude fonts
*) Added - Dude icon in Winbox/Webfig
The SSL problem should be fixed with this version, please test and report if problem repeats.
Also note that if you have very large network map, with lot of securely connected devices, you will still get relatively high SSL usage by CPU.
maxkrok - we suggest to use only ext3 file system, it's more stable for dude, and more tested. Here only solution seems remote access > support@mikrotik.com
For other reports, please send an email with description to support. Each report is checked individually.
deathmagicmedia -
Please give us more details what would be the best HTTP Notification method
aTan - thanks for detailed SSL report.
Chupaka
Tue Dec 20, 2016 2:29 pm
Is it hard to replace embedded WinBox loader version 2 with current version 3?
just an ability to make GET/POST HTTP requests. I was surprised when did not found that type of notification in Dude v3 :)
francisconeto
Trainer
Trainer
Tue Dec 20, 2016 2:30 pm
What about the commands terminal ?
ticket2016120822001445
/dude device print ==> show only the name of devices
/dude device-type print ==> show only the name
/dude service print ==> shiow nothing
/dude device device-group ==> Not exist
/dude probe print ==> show only the name
/dude notification print ==> show only the name
aTan
Tue Dec 20, 2016 3:05 pm
deathmagicmedia -
Calling https url with custom uri part with replaceable variables would be enough for me. And it should be usable in functions.
e.g. https://example.com/?api_key=my_api_key&ip=[Device.Address]&service=[Probe.Name]&state=[Service.Status]&another_custom_parameter=hello
PS: enabling/disabling ssl certificate verification would be also useful. Something like CURLOPT_SSL_VERIFYPEER and CURLOPT_SSL_VERIFYHOST in Curl.
digicomtech
Tue Dec 20, 2016 4:22 pm
deathmagicmedia -
Currently, we use this probe for HTTP and it works great:
Probe Type: TCP
Port: 80
Send: Authorization: Basic xxxxxxxxxxxxxt\r\n\r\nGET /state.xml HTTP/1.1\r\n\r\n
Receive: <input1state>0</input1state>
You can replace send with whatever HTTP request you want to send, and figure what you should receive.
You can use packet sniffer to help you find what is needed.
Using dude 6.38 rc 48 and it works good.
Don't know if it can suit for https stuff...
Regards,
Michael
RafaelUrsoft
Tue Dec 20, 2016 4:33 pm
In my case it still has not been solved, SSL is very high and the CPU stays at 100% all the time. I have enough devices, but in version 6.36 opened and now I could not open the monitoring once.
aTan
Tue Dec 20, 2016 4:52 pm
deathmagicmedia -
Probe Type: TCP
Port: 80
Regards,
Michael
But I need to send a notification through http request (service is up, service is down). There is no such type of notification as 'TCP Probe'. And it doesn't allow TLS/SSL connection.
PS: option to add custom headers is also a good idea.
OnixJonix
Tue Dec 20, 2016 9:39 pm
Vector graphic for dude - all Mikroti Devices???
maxkrok
Tue Dec 20, 2016 11:57 pm
Thanx for expanations.. You should mention that custom files are available for upload to files directory only.. I tried images directory.. It is readonly..
RedM
Wed Dec 21, 2016 4:23 am
I'm getting connection closed on both Winbox and The Dude with a number of users connected to The Dude server.
My only solution is to either get one of them to log out or reboot the machine and hope I get in to what I want before anyone else does.
I'm on 6.38rc51.
ste
Wed Dec 21, 2016 9:28 am
As the old dude ran into problems we migrated to the new dude on hex with a 2GB SD Card.
Runs smooth so far.
1166 Devices, 437 Service items, Polling interval 5min cpu 20-40%.
ste
Wed Dec 21, 2016 9:32 am
Device->General Router OS Status: "connect failed ... next attempt at: <time>"
shows a time 1 hour before actual time. The Hex the dude runs on shows correct time.
Version: 6.38.rc51
ste
Wed Dec 21, 2016 9:39 am
Feature request:
We have customers powering their device only at times they want to go online.
I would like:
- to see last time the device was online (to see if it is used at all).
- schedule an update in dude when he is able to connect this devices
ste
Wed Dec 21, 2016 9:50 am
Got a ping outage of a device. Right clicked on the device and selected Ack. The device gets blue on map. But the service is still in state outage (red flag). The dude flag in taskbar is blue.
6.38rc51 on hex.
alfonzz
Wed Dec 21, 2016 12:55 pm
pls update winbox loader to v3 in DUDE!!! Thanks
PaulsMT
Wed Dec 21, 2016 2:11 pm
Version 6.38rc52 has been released.
Changes since last version
*) Removed - Since default Winbox used in the Dude wasn't fully compatible with all RouterOS devices, we removed it completely.
*) Fixed - Increased default ping packet size to 54bytes - there was some devices who wasn't able to respond with 32 byte ICMP packets, this caused ping corruption.
Note that you can still use Winbox in the Dude, by simply adding it as a custom tool:
Here is the quick example:
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Tools
ste - Check if the ping issue remains in recent version, if it does, write to support
aTan
Wed Dec 21, 2016 2:26 pm
Is the Dude client autoupdate functional? I've tried it with several 6.38rc and it downloads something and then just shutdowns.
PaulsMT
Wed Dec 21, 2016 2:29 pm
Should be fine to autoupdate from all recent versions, just make sure that you run the Dude as administrator. Does anybody else have seen similar problems recently ?
aTan
Wed Dec 21, 2016 3:00 pm
%HOMEPATH%\Desktop\winbox.exe doesn't work (Windows 10) in Tools, works in File Explorer. Ordinary users can place files only inside of their windows profile and each profile has its own path based on username.
Didn't work for rc49->rc51 and rc51->rc52 (as Administrator). I had to update it manually. Also would it be possible to allow update without Administrator rights? Many companies doesn't allow to have Administrator rights. And updating it only by company's network admin makes updating to a higher version very problematic.
ste
Wed Dec 21, 2016 3:14 pm
Another option would be to keep Dude client unchanged if only server is updated.
ste
Wed Dec 21, 2016 5:31 pm
Typo: "Authetication Failed" on Server Configuration Tab RouterOS
ste
Wed Dec 21, 2016 5:34 pm
Winbox->Dude->Notification->Command: editable but Apply/Ok does not save changes.
asik
Wed Dec 21, 2016 7:59 pm
its important to find solution for this.
Another bug in tools/bandwith_test/ when - always "auth. fail" when start this tool
asik
Wed Dec 21, 2016 8:02 pm
when i upgrade to rc51 version background image is disapear AGAIN, when i upgrade to rc52 too.
alfonzz
Thu Dec 22, 2016 12:22 am
OMG.. nice solution :-(
Is there any chance to locate winbox.exe on router SDcard and run it from that location? with this "override" solution.
PaulsMT
Thu Dec 22, 2016 10:41 am
Should be fixed in next release:
%HOMEPATH% variable resolve from Dude tool
Reported:
bandwith_test - auth. fail
aTan - Autoupgrade tested with multiple devices, multiple versions, should be something specific.
asik - background image disapear not repeated, remote access will be apriciated !
alfonzz - No the tool should be accessible from your Dude client, this means on OS where the Dude client is installed.
Also note that you can pass arguments to Winbox - IP, usrename, password, so the Winbox tool should work as before.
Code:
%HOMEPATH%\Desktop\winbox.exe [Device.FirstAddress] [Device.UserName] "[Device.Password]"
normis
Thu Dec 22, 2016 12:46 pm
It must be in your Windows PC, not in the router.
celeritynetworks
Tue Dec 27, 2016 6:16 am
Devs: thanks for all the work so far, appreciate it! Sorry I didn't reply with update to email notification issue not working. Original email problem (post #104) was resolved. Was originally on CHR. Loaded new x86 VM and email notifications started working so seemed to be something with that specific load of RouterOS.
I can confirm our map background images randomly disappear from disk, too. We are on 6.38rc40 and have had to replace a background image twice and it ultimately disappears from disk. It is missing again now.
PaulsMT
Tue Dec 27, 2016 8:56 am
1. Please update your Dude server to the latest - 6.38rc version
2. If you can reproduce the problem, send mail with description to support@mikrotik.com
Ciambot
Wed Dec 28, 2016 10:06 am
In my case works only with this command:
C:\...\winbox.exe [Device.FirstAddress] [Device.UserName] [Device.Password]
also, if you wrong something in your path, error message shows clearly your password! :(
macsrwe
Forum Veteran
Forum Veteran
Thu Dec 29, 2016 4:22 am
I confirm this behavior as well. Not just the background image, but also some locally-added device images, such as CCR, RB2011, LHG -- only a few of them, not all of them. They disappear from dude/files/images and have to be re-uploaded. Problem seems to be triggered by release updates, and does not reoccur until next update. Reported this back on October 7.
I can also confirm the maddening "auth. failed" problem running bandwidth test in Dude. Reported it November 12, hoped it would be fixed by now. It forces me to turn off authentication on every device before I can run bandwidth test on it.
PaulsMT
Thu Dec 29, 2016 11:57 am
macsrwe - thanks for clarifying.
"auth. failed" problem is fixed, but we haven't released version where the fix is included. (next 6.38rc or stable 6.38)
Also please make sure, that all custom files are stored in dude/files directory only, as it is stated in the manual:
Your custom uploaded mibs/images/etc need to be stored in: "(data-path)/files/" directory.
http://wiki.mikrotik.com/wiki/Manual:Th ... 37_release
Ciambot - also the fix for windows variables is not released yet.
macsrwe
Forum Veteran
Forum Veteran
Fri Dec 30, 2016 12:34 am
Thanks, I didn't realize that.
Is it OK if we organize our custom images by creating a new subfolder under dude/files, e.g., dude/files/custom-images/, or will that cause problems as well? I imagine the custom images would no longer automatically "take priority over 'defaults' in case of duplicates," but I haven't been depending on that behavior anyway.
sparrow
Fri Dec 30, 2016 10:43 am
Mastering Type "routerOS" doesn't work, dude map show me all "?" SNMP works good
PaulsMT
Fri Dec 30, 2016 12:56 pm
macsrwe - Yes you can also place your custom folder under dude/files
sparrow - check if you can receive RouterOS data from that device - under RouterOS -> Interface. You should see the same results as in your link label
"?" will be shown if no data has been received.
Filip92
Fri Dec 30, 2016 6:40 pm
Hello everyone,
I want to report a problem with the upload file function in v6.38RC52 on mmips RB750GR3 - in this version and with this device, traditional "drag and drop" does not work, but there is a new button "upload"
because the device has only 15 megabytes of embedded memory, it should be possible to choose the destination disk (SD card or Pendrive)...
PaulsMT
Mon Jan 02, 2017 12:58 pm
Hello everyone,
Test from Windows / Linux didn't show problems with drag&drop
Maybe some OS related problem. Try to open files window, and drop file in some folder
aTan
Mon Jan 02, 2017 4:05 pm
Is there a changelog for the Dude 6.38 final release?
PaulsMT
Mon Jan 02, 2017 4:42 pm
Version 6.38 is released
Full changelog and discussions will be on this topic:
http://forum.mikrotik.com/viewtopic.php?f=21&t=116356
Users browsing this forum: No registered users and 15 guests
