Hi All
I have a wireless canon printer that i can connect perfectly when the printer is connected to the CAPsMAN router (MAIN) and my mac is connected to the main router as well.
The problem is that the printer is nearer the AP (CAP) and when my mac is connected to the AP as well as the printer they cant find each other.
Why would this be? is there a block that i look for?
# sep/28/2016 16:34:49 by RouterOS 6.37
# software id = P9CW-JBX7
add name=StudyNet
add admin-mac=E4:8D:8C:4B:A1:E8 auto-mac=no name=bridge-local
set [ find default-name=ether2 ] comment="D-Link Router in the study" name="Access Point"
set [ find default-name=ether1 ] comment="Port that connects to Netgear" name=Internet
set [ find default-name=ether4 ] comment="All media content stored here" master-port="Access Point" name=Media-Pc
set [ find default-name=ether3 ] comment="Apple Tv / Viera Tv" master-port="Access Point" name="Tv Area"
set [ find default-name=ether5 ] master-port="Access Point" name=ether5-slave-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge \
ssid=3_stanley_road wireless-protocol=802.11
/interface pptp-client
add connect-to=162.218.235.112 keepalive-timeout=disabled name="IPXCore VPN" password=user=
/ip neighbor discovery
set "Access Point" comment="D-Link Router in the study"
set Internet comment="Port that connects to Netgear" discover=no
set Media-Pc comment="All media content stored here"
set "Tv Area" comment="Apple Tv / Viera Tv"
/caps-man configuration
add datapath.bridge=StudyNet name=StudyNet security.authentication-types=wpa2-psk security.encryption=aes-ccm \
security.group-encryption=aes-ccm security.passphrase=0824145666 ssid=3_stanley_road_AP
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=0824145666 \
wpa2-pre-shared-key=0824145666
/ip hotspot profile
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=10.10.10.2-10.10.10.254
add name=dhcp_pool2 ranges=192.168.89.2-192.168.89.254
add address-pool=dhcp authoritative=yes disabled=no interface=bridge-local name=default
add address-pool=dhcp_pool2 disabled=no interface=StudyNet name=dhcp1
/system logging action
set 1 disk-file-name=log
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=StudyNet name-prefix=StudyAP
add bridge=bridge-local interface="Access Point"
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface="Access Point" network=192.168.88.0
add address=192.168.89.1/24 comment="Study DHCP" interface=StudyNet network=192.168.89.0
/ip arp
add address=192.168.88.250 interface=bridge-local mac-address=80:E6:50:14:F1:F8
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=Internet
add address=192.168.88.0/24 comment="Default Pool" gateway=192.168.88.1
add address=192.168.89.0/24 comment="Study Pool" gateway=192.168.89.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
/ip firewall address-list
add address=8.8.8.4 list=GOOGLE_DNS
add address=8.8.8.8 list=GOOGLE_DNS
add address=108.175.32.0/20 list=GOOGLE_DNS
add address=198.38.96.0/19 list=GOOGLE_DNS
add address=198.45.48.0/20 list=GOOGLE_DNS
add address=185.2.220.0/22 list=GOOGLE_DNS
add address=23.246.0.0/18 list=GOOGLE_DNS
add address=37.77.184.0/21 list=GOOGLE_DNS
add address=45.57.0.0/17 list=GOOGLE_DNS
add address=192.168.88.248 list=NETWORK_DEVICES
add address=192.168.88.249 list=NETWORK_DEVICES
add address=192.168.88.253 list=NETWORK_DEVICES
add address=192.168.88.254 list=NETWORK_DEVICES
add address=192.168.88.51 list=NETWORK_DEVICES
add action=drop chain=forward comment="netflix drop rules" disabled=yes dst-address-list=GOOGLE_DNS
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established,related
add action=accept chain=input comment=winbox dst-port=8291 protocol=tcp
add action=drop chain=input comment="default configuration --- place rules above here " in-interface=Internet
add action=fasttrack-connection chain=forward comment="default configuration" connection-state=established,related
add action=accept chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=Internet
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes new-routing-mark=IPXCore passthrough=yes src-address-list=NETWORK_DEVICES
add action=dst-nat chain=dstnat comment="netflix dns redirect" disabled=yes dst-address-list=GOOGLE_DNS to-addresses=192.168.88.1
add action=masquerade chain=srcnat comment="default configuration" out-interface=Internet
add action=masquerade chain=srcnat disabled=yes out-interface="IPXCore VPN"
add action=masquerade chain=srcnat src-address=10.10.10.0/24
add disabled=yes distance=1 gateway="IPXCore VPN" routing-mark=IPXCore
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=4080
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name=Garage
/system leds
set 5 interface=wlan1 leds=""
/system logging
add action=remote topics=dhcp
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
/tool mac-server
add interface="Access Point"
add interface="Tv Area"
add interface=Media-Pc
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
