ErfanDL
Re: v6.37.1 [current] is released!
Fri Oct 28, 2016 10:15 am
RB951Ui after some minutes Bandwidth test crashing and reboot
snix
Fri Oct 28, 2016 11:04 am
mrz
Here is an example from RB1100AHx2:
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  RS ether1bond                          ether            1500  1598       9498 12:34:56:78:90:18
 1  RS ether2bond                          ether            1500  1598       9498 12:34:56:78:90:19
 2  R  bond                                bond             1500                  12:34:56:78:90:18
 3  R  vlan                                vlan             1500                  12:34:56:78:90:18
My questions now are:
- Why isn't L2MTU visible on the physical interface on the CHR ? Probably driver doesn't support it? Why is L2MTU visible on the bonded interface than?
- Why isn't L2MTU visible on the bond interface on the RB1100AHx2 ?
- Why can a VLAN be configured with 1500 MTU directly on a physical interface but not on a bonded interface on the CHR?
- Why can a VLAN be configured with 1500 MTU on a bonded interface on the RB1100AHx2?
Thank you again for your response.
mrz
Fri Oct 28, 2016 12:18 pm
1. Interface does not support l2mtu
2.Probably because on RB1100 you have an old version, shows l2mtu on mine:
[admin@rack1_b6] /interface> print
5 RS ether6 ether 1500 1598 9498 4C:5E:0C:48:B1:2A
6 RS ether7 ether 1500 1598 9498 4C:5E:0C:48:B1:2B
13 R bonding1 bond 1500 1598
3.,4. because L2MTU supports more than 1500.
BlackVS
Sun Oct 30, 2016 7:32 pm
Had working config on RB951G, v.6.34
After upgrade to 6.37.1 found issue with wrong masquerade behavior:
I have PPTP server on one side (CCR) and PPTP client (RB951G) on other side.
Behind CCR we have a lot of work networks.
Behind RB951 we have home network.
Due to I don't want add routes on CCR for home network I did masquerade for forwarded via PPTP packets from home network (i.e hid home network).
Before upgrade source address during masquerade was changed to the client's PPTP address. It is correct.
After upgrade router uses WAN address as new masquerade source address for packets forwarded from LAN via PPTP tunnel. It is wrong.
Bug?
To correct this I changed from masquerade to src-nat rule and set manually needed ip for forwarded packets.
Aug
Sun Oct 30, 2016 11:27 pm
Well THAT didn't go well... Upgraded a RB750G from v6.35.2 to v6.37.1 and:
- CPU usage spiked after the update and remained high on a router that normally never goes above 5% CPU load
- Firewall filter rules based on ConnTracking connection state lost that setting. Rather than connection-state=invalid or connection-state=established it showed connection-state=""
I promptly unplugged the external connection, downgraded to v6.34.6 restored my config from backup, and triple checked everything.
Same problem with firewall rules. They used to be correct. All on RB411's.
With 5.26 it's
add chain=forward comment="allow established connections" connection-state=established
add chain=forward comment="allow related connections" connection-state=related
add action=drop chain=forward comment="drop invalid connections" connection-state=invalid
With 6.37.1 it's this.
add action=accept chain=forward comment="allow established connections" connection-state=""
add action=accept chain=forward comment="allow related connections" connection-state=""
add action=drop chain=forward comment="drop invalid connections" connection-state=""
Aug
BlackVS
Mon Oct 31, 2016 6:45 am
Thanks, now I understand why these checkboxes were cleared on one of my routers too...
Now I have to recheck all routers for this.
Damn.
omidkosari
Trainer
Trainer
Tue Nov 01, 2016 11:36 am
Since upgrade fro 6.34.6 to 6.37.1 , most of schedules doesn't run !! Same behavior on 5 different routers with different schedules and scripts .
Note1: Running that script manually works .
Note2: Few schedules work and i am investigating the difference between them .
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
darkprocess
Tue Nov 01, 2016 2:41 pm
Hello same behaviour here, i had to recreate the schedules to make it work
Envoyé de mon SM-G925F en utilisant Tapatalk
omidkosari
Trainer
Trainer
Tue Nov 01, 2016 3:06 pm
Found the bug and solution.
Any simple schedule for running need at least these permissions.
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive
mrz
Tue Nov 01, 2016 3:29 pm
If your script has more permissions that scheduler then scheduler will not be able to execute the script.
omidkosari
Trainer
Trainer
Tue Nov 01, 2016 3:37 pm
Before upgrade to this version your sentence was correct but now it is not correct anymore .
Now any schedule SIMPLE script need those permissions to run . It is a bug
MrcS
Tue Nov 01, 2016 4:28 pm
Hello there, this is my first post in this forum. Well, I'm facing an issue with IPv6 since the first time my ISP offered it, a few months ago.
My problem is this: I have a link with two RBs, one RB750 as modem client and one RB433 as last mile in my home.
The ISP offers me a /64 and an IPv6 address as usual.
The /64 I send to a pool and that pool is used by the DHCPv6 Server in the RB750.
It goes fine with the RB433 getting the block with DHCPv6 Client and the route is created ok in the RB750. OK till here!
BUT if the RB750 gets rebooted by any reason, it's DHCPv6 Server generates a dynamic route to my /64 pointing to nothing.
And thus, my valid route loses preference and my /64 becomes unreachable until I manually delete that single dynamic route (the other is correct).
Edit: I'm posting this here as It still hasn't been fixed and affects this version too.
strods
Tue Nov 01, 2016 5:11 pm
Aug - This issue will be fixed in next rc release.
morze
Tue Nov 01, 2016 5:46 pm
Hello everyone! Using CHR 10Gbit on ESXi 6.5 with 5 vmxnet adapters, I was very surprised with this update! First after update it did not boot. А hour search for a solution let me to think that too little RAM (128 MiB!). After setting RAM to 512 MB it's started and worked, I have used it for two weaks and there was very strange hangs with google and youtube sites (some time normal after reboot and again and again). Have downgraded to 6.36.4 and all working fine now and memory usage is 75 MiB (was >200 with this update).
To be honest, I did not understand this "update". Nothing personal, it's better to remove it from official releases, Sorry for poor English, hope this helps to do RouterOS better! :)
morze
Tue Nov 01, 2016 6:09 pm
Killed my CHR at home. Unable to communicate with the router via IP. Cloud logon via console (hyper-v) but unable to list interfaces. Service timeout and the same thing with trying to create a supout.rif. Thank god for snapshots :-) Rollback via snapshot took 10 seconds!
Tested again and if I do not logon I get this in Hyper-V console: Mikrotik Login: Info failed: std failure timeout (13)
Still unable to get a supout.rif. I can however export the entire machine and send it to support (after an upgrade). If imported to the a Windows Server 2012 R2 Hyper-V you can access the .vhdx file and read everything you like.
I'm going to e-mail support.
Edit:
[Ticket#2016100322001305]
Did you find a fix? I have same Issue in different versions of hyper-v 2012r2 and 2016... Also tried upgrade and clear install...
I think the "fix" is to set more RAM (>300 MiB) and may be some more disk space for VM, but it's better do not upgrade. At least this time, something went wrong... =)
mrz
Tue Nov 01, 2016 6:18 pm
No it does not require such policies to run a script, unless script itself require such policies.
[admin@rack1_hexv3_up] /system script> print
Flags: I - invalid
0 name="script3" owner="admin" policy=write last-started=nov/01/2016 16:11:39
run-count=12 source=:log info "ptest3"
[admin@rack1_hexv3_up] /system scheduler> print detail
Flags: X - disabled
0 name="schedule3" start-date=nov/01/2016 start-time=16:10:19 interval=10s
on-event=script3 owner="admin" policy=write run-count=10 next-run=16:12:19
Such scheduler executes a script with only "write" policy, so your statement is wrong.
Now if I change script policies to "write,test", then scheduler with only "write" policy will not be able to execute the script.
Kindis
Tue Nov 01, 2016 6:52 pm
Edit:
It has 1 GB of RAM and 1 GB of disk. The problem according to guesses is the use of synthetic network cards. Waiting fot fix still.
Chupaka
Wed Nov 02, 2016 4:30 pm
I faced that weird behaviour this night after upgrading one of our x86 routers: VLAN interface is here on bonding, but it's not working, and after disabling it it was impossible to enable it back ("error enabling VLAN - cannot set mtu" or something like that). The solution was just "/interface set bonding1 l2-mtu=1504". The bad thing is that you cannot change L2-MTU via WinBox (so it was not obvious that it IS changeable), and you cannot change l2-mtu via, for example, "/interface bond set" menu - you need to use exactly "/interface set"
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
ste
Thu Nov 03, 2016 4:04 pm
The AP selection mechanism has changed.
All our APs have the same SSID. We direct the CPEs to APs using Accesslists. So all CPEs are forbidden by default and only allowed on one sector we want them to connect.
With new wireless package not all available APs are tested. The cpe tries only to connect to 2 of them and if not allowed at this 2 it does not connect to an available third AP. We see "wlan1: failed to connect, not allowed" with 2 different frequencies. So after updating some CPEs never reconnect.
Not mentioned in changelog and not easy to see in lab :-(.
Chupaka
Sun Nov 06, 2016 9:36 pm
okay, VLANs on Bonding are completely unusable in this version. the router rebooted, l2-mtu is back to 1500 and now I can't even change it:
[admin@Beta] > /interface
[admin@Beta] /interface> print where name=bonding1
 0  R  bonding1                            bond             1500  1500
[admin@Beta] /interface> set 0 l2mtu=1504
this evening was a bit painful...
UPD: l2-mtu of bonding is unchangeable now on any actual version: 6.36.4, 6.37.1, 6.38rc24 :shock:
Rolled back to 6.33. VLAN is working...
msatter
Sun Nov 06, 2016 10:32 pm
I am on a new RB750Gr3 and have a problem that the IPv6 is not getting bound when using "renew". I have now to do the following before I gets bound correctly:
interface pppoe-client set pppoe-xs4all-inet max-mtu=1480;
interface pppoe-client set pppoe-xs4all-inet max-mtu=1500;
ipv6 dhcp-client release 0;
Config:
/ipv6 address
add address=2001:x:x:0:1::2 interface=pppoe-xs4all-inet
add address=2001:x:x:0:2::1 advertise=no comment="Advertise off so clients won't get an external IPv6 automatic. interface=2-uplink-switch-master
/ipv6 dhcp-client
add add-default-route=yes interface=pppoe-xs4all-inet pool-name=xs4all-v6prefix pool-prefix-length=48 request=prefix use-peer-dns=no
/ipv6 nd - set [ find default=yes ] hop-limit=64 ra-lifetime=2h
/ipv6 settings - set max-neighbor-entries=1024
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.19 / MikroTik APP 1.3.4
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
jobo
Mon Nov 07, 2016 10:37 am
Looks like IPv6 is gone in CCR 1072 after upgrading. CCR1016 still got IPv6 with 6.37.1 tho.
IPv6 is gone after disabling wireless package?
strods
Mon Nov 07, 2016 3:30 pm
jobo - Please use "Tool/Clear Cache" in Winbox loader before you connect to device. Then it should be back.
Cha0s
Forum Veteran
Forum Veteran
Mon Nov 07, 2016 3:48 pm
I have multiple vlans under bonding and even under vrrp under bonding and I don't have the issue you describe with 6.37.1.
L2MTU on the bonding interface is 1598
L2MTU on the VRRP interface is 1598
L2MTU on the VLAN interfaces is 1594
MTU is 1500 on all interfaces.
Both routers where I have this configuration have over 14days uptime.
I don't recall when L2MTU stopped being 'editable'. I've never had to change it tbh.
SamSpade
Mon Nov 07, 2016 4:27 pm
I am running Dude as a CHR on HyperV. I imported database from old version of Dude and everything seems ok except I got no custom pictures of devices I set-up on previous instalation.
Second thing: legend field is empty on all link graphs (see picture)
Does anybody knows solution to this problems?
jobo
Mon Nov 07, 2016 4:39 pm
OK this helped thanks!
Chupaka
Mon Nov 07, 2016 11:58 pm
please check l2-mtu of ethernets in bonding. mine are empty - looks like it can be the reason:
[admin@TestPlace] > interface print where name~"(bonding1|ether6|ether7)"
 0  RS ether6              ether            1500                  00:50:56:BE:1F:E4
 1  RS ether7              ether            1500                  00:50:56:BE:08:9C
 2  R  bonding1            bond             1500  1500            00:50:56:BE:1F:E4
[admin@TestPlace] >
this is from ESXi VM, but on hardware router I have the same behaviour
Cha0s
Forum Veteran
Forum Veteran
Tue Nov 08, 2016 12:03 am
[cha0s@****] > interface print where name~"(bonding1|ether1-|ether2)"
 0  RS ether1-switch1-port1                ether            1500  1598       4074 D4:CA:6D:**:**:**
 1  RS ether2-switch2-port1                ether            1500  1598       4074 D4:CA:6D:**:**:**
 2  R  bonding1                            bond             1500  1598            D4:CA:6D:**:**:**
These are from an RB2011UiAS-RM.
Cha0s
Forum Veteran
Forum Veteran
Tue Nov 08, 2016 12:24 am
I confirm that on an esxi VM L2MTU is empty on 6.37.1
[cha0s@MikroTik] > interface print where name~"(ether1|ether2)"
 0  R  ether1-public                       ether            1500                  00:50:56:84:58:2E
 1  R  ether2-lan                          ether            1500                  00:50:56:84:78:D9
I checked arm, mipsbe, ppc, tile and all show L2MTU properly. Probably an x86-only bug?
Chupaka
Tue Nov 08, 2016 1:14 am
it's driver-dependent. here's my router in subject:
[x@y] > int print
 0  RS ether1                              ether            1500
 1  RS ether2                              ether            1500
 2  R  ether3                              ether            1500
 3  R  ether4                              ether            1500
 4     ether5                              ether            1500  9014
 5  R  Core                                vlan             1500
 6  R  bonding1                            bond             1500
ether5 has l2-mtu for some reason :) it's Intel 82574L, and ether1-4 are 82576
SpartanX
Tue Nov 08, 2016 1:55 am
I'm just reporting an odd glitch I had when I upgraded to this release on Sunday morning. It might not be important, but...
I upgraded at about 8:10am Sunday. Today, I became aware of some UDP packet loss with an online application I use; averaging around 4% loss. As a first step I rebooted my FTTC modem and 850Gx2 router via the web interfaces. Nothing changed. I went through a load of troubleshooting including even replacing my NIC.
Then I remembered I use a ping-recording service, so I checked that and saw packet loss there, from the moment I upgraded the firmware. The router answers the pings. Graphs are attached below.
After checking more things and rebooting (via the web interface) again with no change, it occurred to me to properly power-cycle the router by remote. It's on an APC remote PDU.
That immediately stopped the packet loss. It was definitely what fixed it. In the graphs (which you can see better if you click on them) it is apparent when the packet loss started on the first graph. The time correlates with the router's log showing the upgrade. The second graph shows when I power cycled the router and the packet loss stopping.
Moral of the story: don't trust a software restart!
BlackVS
Tue Nov 08, 2016 7:25 am
One more strange thing happened on one router (CCR1016) with 6.37.1.
It has two WANs with loadbalancing/backup and few days ago one channel down.
I thought that it is provider related problem (due to I couldn't ping gate, physical link was ok) and even started to contact with him but looked at log and saw a lot of fcs erors on this port (broken checksums).
Hm... I just disabled/enabled port and all channel up again.
I'm not sure is it provider related problem or router/firmware.
It was first time such channel down.
I reverted to the stable 6.36.4 - no problem...
Kindis
Tue Nov 08, 2016 7:15 pm
Edit:
Ok now I know that this is related to Network Adapters in Hyper-V on Windows Server 2012 R2 and possible older versions.
If I test with Legacy Network Adapters everything works except that performance takes a bit hit.
Running on Windows 10 Hyper-V works with these Network Adapters so this is related to 2012 R2 or older.
Still waiting for a fix.
amtisrac
Thu Nov 10, 2016 1:17 pm
Edit:
I'm try downgrade to 6.36.4, same results.
Latest stable version is 6.36.3 (on my hyper-v 2012 r2)
On the 6.36.4 changelog I see two thing, probably these are the reasons:
*) ethernet - added support for LAN9514 ethernet dongle;
*) ethernet - allow to force mtu value when actual-mtu is already the same;
MTCNA, MTCWE, MTCUME, MTCRE, MTCTCE, MTCINE
pikpik
Thu Nov 10, 2016 2:26 pm
  status: radar-detecting
                channel: 5640/20-eC/an/DP (3440)
            noise-floor: -111dBm
  authenticated-clients: 0
      current-tx-powers: 6Mbps:19(19/22),9Mbps:19(19/22),12Mbps:19(19/22),18Mbps:19(19/22),24Mbps:19(19/22),36Mbps:16(16/19),48Mbps:14(14/17),
                         54Mbps:13(13/16),HT20-0:19(19/22),HT20-1:18(18/21),HT20-2:17(17/20),HT20-3:17(17/20),HT20-4:16(16/19),HT20-5:14(14/17),
                         HT20-6:13(13/16),HT20-7:12(12/15),HT40-0:18(18/21),HT40-1:17(17/20),HT40-2:16(16/19),HT40-3:16(16/19),HT40-4:15(15/18),
                         HT40-5:13(13/16),HT40-6:12(12/15),HT40-7:11(11/14)
    notify-external-fdb: no
Why i can connect only on 3 channels from all ? Country poland.
Kindis
Thu Nov 10, 2016 6:38 pm
Edit:
This is related to using Network Adapters in Hyper-V on server 2012 R2. Tested on Windows 10 and that works with same setup.
If you switch the network cards to Legacy Network adapters it will work on 2012 R2 Hyper-v but performance turns to shit.
I have noted this to Mikrotik who have only tested on Windows 10 which is a different version of Hyper-V.
Will update when I get response from support.
akarag
Sun Nov 13, 2016 8:48 pm
I have some issues with version 6.37.1 on a hex v3. I upgraded one from 6.36.3 to 6.37.1 and noticed two issues
1. On the ethernet interfaces, the information concerning the master port, TX/RX and switch port are missing. This was extremely useful in order to quickly check the settings of the interfaces (swict port)
2. The log window is not automatically scrolled in the occurrence of new events. I need to close the log window and reopen it in order to see the last events in the log list.
stroebs
Mon Nov 14, 2016 10:53 pm
Unable to run scripts by referring to their names in 6.37.1...
This happens when called from other scripts or from terminal.
mrz
Tue Nov 15, 2016 11:51 am
Script that you are trying to run tries to access something that does not exist in current configuration.
alext8409
Thu Nov 17, 2016 8:55 am
Still terrible behavior of the vpn server since v6.34. L2tp ipsec server is up, remote client connects successfully, then after a while it just hangs up and terminating the session. Another great thing happens on v6.38 - the client connects and stays connected as long as you need until you start to transfer data via the tunnel, 1-2 minutes of copying (direction doesn't matter) ang hungup again! I just can't get it how such a vital and useful function of a router can behavior this way. I would probably leave the v.6.34, where the vpn connection is stable as a rock, but there is another bug - when you change proposal settings, the dynamic peer just dissapears and you have to restore from the backup! Fix this please!
Temches
Sun Nov 20, 2016 9:49 am
Device: hAp lite
Problem with old legacy wireless devices (for example Intel(R) PRO/Wireless 2200BG) still persist in 6.37.1 and 6.38rc7 ... can`t connect to network with WPA or WPA2 encryption. without - all fine.
Always getting "extensive data loss".
After downgrading to 6.34.6 - all fine, wireless-cm2 package works perfecty!
This is a major issue for me as well! Please consider creating a 6.36.4 as bugfix-version because it is the lastest version supporting wireless-cm2.I have >50 devices with Intel(R) PRO/Wireless 2200BG and >40 older wireless IP-Cams which do not work wir current wireless-package. I'm also running a big camtsite-installation where the clients have thousands of different devices. I worry that some clients cannot use our wifi.
Same problem, my old smartphone philips w732 could not connect to wifi router. On 6.36.4 works just fine. Is any fixes for this?
notToNew
Mon Nov 21, 2016 9:43 am
Yes, this is the new "feature". If you use unencrypted wifi (clear the WPA-encryption), it works. (Thats why I moved to 6.36.4, and i'm happy that they support 6.36 as the last version with the old workung packet in the bugfix-branch. I hope they create a kind of an LTS-Version of this branch.)
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
novelty22
Mon Nov 21, 2016 8:00 pm
edit: Sorry, wrong thread
105547111
Tue Nov 22, 2016 12:21 am
6.37.2 is released, where's the announcement?
strods
Tue Nov 22, 2016 9:15 am
6.37.2 has been released. Please read changelog before upgrade:
http://forum.mikrotik.com/viewtopic.php?f=21&t=114926
Users browsing this forum: No registered users and 6 guests
