Toby7
PPPoE IPv6 address / Dual stack
Mon Oct 03, 2016 10:19 pm
my local ISP provides a dual stack configuration for my internet access by ADSL. I wann test this but I am not able to get a IPv6 address. The PPPoE connection is running fine and there I get a valid IPv4 address. Now the question is how to a IPv6 address? I set up an DHCPv6 Client on the PPPoE connection but it is stuck in the "searching" status.
Before I did use an FritzBox to verify the IPv6 dual stack configuration and there it simply works. Ipv4 and v6 addresses are received.
Do you have any idea? Is it necessary to set up an own PPPoE connection for the IPv6 address or can I use one for both?
Thanks!
mbeauverd
Re: PPPoE IPv6 address / Dual stack
Tue Oct 04, 2016 11:17 am
I had to do so on my side.
It is working fine :)
Users browsing this forum: brg3466, martinclaro and 111 guests
