freakneck
Error handling?
Fri Oct 07, 2016 11:35 pm
I've got system out there at a couple different f/w levels.
At some point in the f/w development cycle, MT added error handling to scripting.
Also, at some point, under /system ntp client the mode setting had been removed. When it was initially removed, mode would still show up as a possible choice if you pressed TAB after the SET keyword.
Anyway.....
In an attempt to create a single script to support f/w's that did and didn't have that setting any longer, I thought error handling would be a good choice here.
So I came up with this....
:do {/system ntp client set mode=unicast
} err={};
...but it still throws an error!!!! I know that the mode setting was removed, and that it should error out there, if I wasn't using an error handler!!!
What gives?
CsXen
Re: Error handling?
Wed Dec 14, 2016 2:32 pm
Hi.
I tried it for hours... but i concluded, that error handling works just for internal commands (which starts with : like ":resolv"),
and not works for path commands (which starts with /like "/tool dns-update..."
In the first case you can catch an error with on-error={} , in the second, command aborts the script with it's own error.
So we must send a feature request to Mikrotik... if we want to catch error in all commands. :)
Best regards: CsXen
CTSsean
Re: Error handling?
Tue May 15, 2018 4:27 pm
Going to resurrect this as I found this during my runtime error handling testing.
The syntax format has to be very specific to process the error handling properly.
Example:
:do {/interface bridge add name=loopback; } on-error={:put "loopback exists"}
So its
:do {whatever command you want to run; } on-error={whatever command you want to run if it errors}
Be mindful of the curlys and semi colons.
I recommend when trying to do error handling per command, you keep the error handling on the same line.
damianivereigh
Re: Error handling?
Sat Mar 09, 2019 2:06 pm
I think I have to the solution to this issue. If you put the code that may have a syntax error into :parse, then you can execute that inside a do { } on-error={} and it will catch syntax errors too.
So to use your example...
:global mycode [:parse "/system ntp client set mode=unicast" ]
:do { $mycode } on-error={}
rextended
Re: Error handling?
Thu Sep 09, 2021 5:36 pm
Start to coding correctly and you do not have problems:
# wrong coding
# translating: create loopback, if you got an error because already exist, ignore it
# on short: create it, hoping not already exist
# right coding
:if ([:len [:find where name="loopback"]] = 0) do={add name=loopback}
# translating: if the result of the count of interface named loopback are zero, create the interface
# on short: if not exist, create it
and about NTP, simply check first the RouterOS version...
and use this example for know if the NPT package are installed and enabled or not:
(example for Jotne for Splunk)
:local ntpstatus ""
:if ([:len [/system package find where !disabled and name=ntp]] > 0) do={
    :set ntpstatus [/system ntp client get status]
} else={
    :if ([:typeof [/system ntp client get last-update-from]] = "nil") do={
        :set ntpstatus "using-local-clock"
    } else={
        :set ntpstatus "synchronized"
:log info message="script=ntp status=$ntpstatus"
Users browsing this forum: No registered users and 82 guests
