Omega16
Torch not working with CRS226-24G-2S+
Mon Oct 10, 2016 9:33 pm
I have a CRS226-24G-2S+ and I cant get torch tool to work. Even if the selected interface has traffic, there is no output.
Factory firmware is: 3.22
RouterOS version: 6.36.3
I will upgrade to latest version, but I do not think this will resolve issue.
Thank you
jeroenp
Re: Torch not working with CRS226-24G-2S+
Tue Oct 11, 2016 9:53 am
See http://forum.mikrotik.com/viewtopic.php?t=68619#p348979
If you want to see the traffic in torch, use "/interface bridge". You are using the "master-port" function which is different. Take a look at the diagrams in this wiki article: http://wiki.mikrotik.com/wiki/Manual:Sw ... _Switching
Using the "master-port" the traffic is processed directly in the switch chip, torch is done at the CPU, but using "master-port" packets dont get to the CPU.
mpreissner
Tue Oct 11, 2016 5:30 pm
But, when using Bridge, all ports share a single 1 gbps link to the CPU, so your layer 2 performance will suffer horribly. If you need to see all the traffic from a single port when using Master/slave port configuration, use port mirroring.
Michael Preissner
CISSP, CCSP, CEH, PMP
jeroenp
Tue Oct 11, 2016 9:02 pm
Interesting! What steps are needed to set that up?
--jeroen
mpreissner
Sat Oct 15, 2016 1:14 am
Michael Preissner
jeroenp
Sun Oct 16, 2016 7:40 pm
Users browsing this forum: Bing [Bot], Lifz, mitjax, sarada, stoser and 160 guests
