sofia.marques
RB112 vs RB5xx
Tue Oct 10, 2006 1:55 pm
Hi
What's the major difference between RB112 and RB500 series? The hardware packages for 2.4GHz comes with a RB112.
normis
Tue Oct 10, 2006 2:04 pm
RB500 is faster, and has more ports.
sergejs
Tue Oct 10, 2006 2:09 pm
In addtion to Normis post, detailed RouterBOARDs hardware specification is given here,
http://www.routerboard.com/products.html
balimore
Forum Veteran
Forum Veteran
Re: RB112 vs RB5xx
Tue Oct 10, 2006 2:18 pm
Hi
simple answer,
RB112 designed CPE for, other one is possible Ap-Bridge or CPE.
Hasbullah.com
samsoft08
Long time Member
Long time Member
Tue Oct 10, 2006 11:40 pm
does this mean that i cant use RB112 as nodes in WDS setup ?
normis
Wed Oct 11, 2006 3:48 pm
you can, it all depends on details. will you do queues and firewall? if no - no problem
akarif
Minimum RAM
Fri Oct 13, 2006 9:00 pm
RB112 has only 16MB RAM, RB153 or RB532 has 32MB, and RB532A has 64 MB. Does it mean :
- RB112 only enough for plain router/bridge, no
queues, firewall, OSPF, etc.
- RB153 or 532 could do the above tasks until certain level
- RB532A is more flexible
Please advise.
Any information we can learn to calculate the required RAM ?
samsoft08
Long time Member
Long time Member
Mon Oct 16, 2006 2:32 am
what if i run cach drive in a RB node , ist right or wrong ? that RB node is one of 3 NODES in a WDS setup and its not the main ..
