rea1ity
Is there have no alternative solution for FAN NOISE of CCR?
Fri Oct 21, 2016 12:19 am
I have CCR-1009-8G-1S THAT makes fan noise so much in the home.
So I tried to change the fans as silmilar with original fans but it didn't worked.
Also, I tried to attached rubber gasket to the fans but the noise didn't reduced.
If you have the solution to reduce fan noise, please let me know it would be appreciate.
Yoon.
InoX
Re: Is there have no alternative solution for FAN NOISE of CCR?
Fri Oct 21, 2016 1:51 am
Cut the + wire and add a 100ohm resistor. Or buy those adapters from the picture.
https://www.quietpc.com/images/products ... -large.jpg
jarda
Fri Oct 21, 2016 9:14 am
Or swap the fan. Or made a fan mod.
planetcoop
Sat Oct 22, 2016 12:58 am
here is my ccr1036 on a wall board with custom fans. maybe not to everyones liking, but its quiet, cool, and processing 10gbps. :)
https://www.dslreports.com/forum/r30537527-
Users browsing this forum: No registered users and 54 guests
