mrz
Re: RB750Gr3 - Report and questions
Mon Oct 31, 2016 12:01 pm
I am not impressed with the new RB750Gr3. Mainly, a lot of things working differently.
Cannot make static address in DHCP, when address is not in any pool, .
The worst thing, if i change DHCP range on Quick Set page and click on Apply, lost it's ip address and the device will be inaccessible. Then reset, load last working configuration and go on...
Waiting for a new, working release.
Could you try it again with a more current version of Winbox?
The result is same with Webfig and the latest version of Winbox.
Never use quickset to make some changes if you already started to configure router manually.
G2Dolphin
Tue Nov 01, 2016 9:48 am
Never use quickset
That's enough in 90% times. :D
CCR1009-7G-1C-1S+PC, RB3011UiAS-IN (2011 case+3011-RM), hAP ac, mAP2n/mAP2nD, wAP ac LTE6
There's nothing wrong with your Internet connection, I have a broken avatar. :)
proximus
Tue Nov 01, 2016 2:38 pm
Definitely met expectations of better CPU performance. Below we have the my original RB2011 replaced with the RB750Gr3, same config. The hourly CPU spikes are a Talos IP block list updating (currently around 46,000 address list entries). This resulted in a significant and measurable impact on throughput. Now it's not an issue.
I added a Transcend 16GB High Endurance microSD card.
My only disappointment is the 16MB flash. I'm a huge proponent of partitions. There have been times where I have had to revert back after upgrading, due to a bug. Nothing like being able to just boot the other partition! I would be willing to pay the extra $2 to have 32 or 64MB flash. ;-)
bajodel
Long time Member
Long time Member
Sat Nov 05, 2016 1:04 am
Amen .. +1
risk
Sat Nov 05, 2016 10:06 am
Amen .. +1
I like A-B booting in principle (e.g on Chromebooks), but how would it work in this case, would revert to old partition be automated or manual - how would it be triggered? A software watchdog? A hardware watchdog? A switch on the outside? Would an admin need to confirm new version is alright by issuing an explicit command?
proximus
Sat Nov 05, 2016 2:27 pm
Auto or manual. Partitions are nothing new: http://wiki.mikrotik.com/wiki/Manual:Partitions Just need to build the box to support it.
DmitryAVET
Wed Nov 09, 2016 12:45 am
Now i have 2 x RB750Gr3 on test.
Configuration:
1) WAN <=> WAN (same Layer 2)
2) Firewall enabled
3) NAT enabled
4) Static routes
In general, typical configuration from REAL life.
Tests with IPSec SHA1/SHA256 and AES128/AES256б, real speed (user data):
512/1400/1518 bytes - 230 Mbits
64 bytes - 135 Mbits
32 bytes - 60 Mbits
Or up to 180-200 Mbits in duplex.
As traffic generator i use iPerf and TCP protocol. Traffic generator - PC on FX-8320 (8 cores, avg load <80%), as iperf server - notebook on Core-i5 (avg load <60%).
Zorro
Long time Member
Long time Member
Wed Nov 09, 2016 1:50 pm
sfp port ? what for ? SFP+ in 10GBps -capable devices make sense for uplink interfaces, but for generic devices - not really any use for.
in such case - simpler to use media converter. unless if you need to use something exotic, like SFP/SFP+ -cased VDSL modem, EPON interface or LTE interface, but thats niche application and solvable w/o SFP usage.
CCR's had SFP and some of RB3011 and RB2011 if you desperately need it :)
SFP is just another interface type, we use it extensively for runs where conduits are tight, TV over fibre, distance etc. SFP doesn't just mean FAST speeds. It is merely another form of connectivity. I prefer not installing media converters as it is just another thing that requires power and space. I do like the Hex POE with SFP that came out recently, have not gotten my hands on one yet - but that would fit our installs nicely (except the pasive POE) - hence why a non POE RB750Gr3 with an SFP would be great.
technically its "interface for interface or interfaces" with full case/mount for devices in.
SPF+ had other advantages aside speed.
for lower than 10Gbps speed there is no need for SFP/SFP+ port, basically.
surely many "prefer not" many thing, and expect it "as granted" within devices for prices as they are without it. and then other consumers start become whine about their over-pricing or more frequently downperforming, because money saved on essentials from design/production budget, wasted for irrelevant for 90% uses(outside backbone or SMB border of med-size or huge networks), SFP/SFP+ interfaces.
personally i would like routers to be able to make me coffee and tell me fresh anecdotes and help me catch cool chicks and do it for free, of course, but thats not likely to happen. same with SFP within SOHO or most SMB devices.
but talking practically - you may notice that RB 2011/RB3011 and CCR(and some of PPC devices?)have SFP ports, so likely they may design later such model you requested, just within another product line.
likely it would be something like RB2011r2 or something like that. MIkrotik tend to hade several Different models: 1. one most basicmodelwithout wifi or SFP, with slightly downclocked(no need for relevant CPU, happly) and bit smaller RAM(bottleneck, so make much sense too). 2. one model with wifi. 3. one model with wifi and sfp. 4. one model with wifi, sfp 5. and one model with SFP only. but it would be labeled or cased as rb750Gr3 or alike that but separated products, i guess. also as i pointed 4x-core chip on similar core(cost as much as already used, one watt hungrier)also exist and open some options too.
paulct
Wed Nov 09, 2016 2:36 pm
Ended up getting 50 of the Hex POE units with SFP. Fits our installs nicely - can be powered by 803.at via our netgear switch. Backhaul via fibre via the SFP port. Well done Mikrotik. I am sure they can save on the costs of supplying POE on all ports - and design a new router based on the CPU that is in the RB750gr3 that has an SFP port. We would have gone with the HAP AC - but it was too expensive - especially as we didn't need the onboard wireless. We would have also gone with the Ubiquiti edgerouter X - but hey we like Mikrotik. Either way to me a SFP port in mandatory, I do realize it is not to everyone - but at least we know now the HEX POE can do the job well.
schmeltm
Wed Nov 09, 2016 11:11 pm
Hi all,
i have 2 RB750Gr3 and tried to get VLAN´s via Switch chip working.
I have read the following wiki article: http://wiki.mikrotik.com/wiki/Manual:Sw ... p_Features
But if i configure the vlans to the ports i will be locked out and have to reset the device ...
Somebody who has examples fot switch config on this device?
@Mikrotik: Do you plan to describe the switch cip features somewhere in the wiki?
Br
Markus
becs
Thu Nov 10, 2016 4:12 pm
RB750Gr3 switch chip does not have full VLAN tagging/untagging support yet, it is planned to implement it in future. Currently, you should use RB750Gr3 switch chip only for basic switching.
RB750Gr3 is also powerful enough to handle software based VLANs: http://wiki.mikrotik.com/wiki/Manual:In ... p_examples
schmeltm
Thu Nov 10, 2016 4:45 pm
Thanks for the info!
pe1chl
Thu Nov 10, 2016 5:32 pm
I just received my RB750Gr3 and to my surprise the ports 2-5 cannot be separated, they are always slave of the same master.
This makes it difficult to use it for other things than a basic Internet NAT router...
Normally we use individual ports for separate links in the network and it can be done by removing the master port on an ethernet port.
I have always assumed that internally this is handled by programming the switch to do an untagged VLAN on that port and set
a tagged VLAN with an internally generated VLAN tag on the internal port, configure a VLAN interface at the CPU side, and
tell the user that is the "ether5" port, for example.
Is that how it really works and is it not yet available on the RB750Gr3 for exactly that reason?
schmeltm
Thu Nov 10, 2016 5:57 pm
Hi pe1chl,
i have try it out and i can seperate the interfaces.
/interface ethernet set master-port=none ether5-slave-local
Or set "Master Port" to "none" via winbox on Interface General Tab.
pe1chl
Thu Nov 10, 2016 6:02 pm
Ok thanks I tried it and indeed it works via commandline. The option is not shown in WebFig.
(I never use Winbox)
ingtegration
Wed Nov 16, 2016 10:44 pm
Try to do 100M+ on copper!
Guy Boisvert, ing.
MTCRE
IngTegration inc. - Montréal, Canada
http://www.ingtegration.com
ingtegration
Wed Nov 16, 2016 11:30 pm
I just did a quick test with 2x RB750Gr3 in tunnel mode and was able to quite happily get ~436Mbps:
Note this was running RouterOS 6.38rc15.
I wonder how you can reach those numbers. I'm testing with ROS 6.38rc31 and i get:
user@IngTegration:~$ iperf3  -c 172.16.1.120
Connecting to host 172.16.1.120, port 5201
[  4] local 192.168.89.224 port 47172 connected to 172.16.1.120 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec  41.6 MBytes   349 Mbits/sec   10    382 KBytes
[  4]   1.00-2.00   sec  40.8 MBytes   342 Mbits/sec    1    362 KBytes
[  4]   2.00-3.00   sec  41.4 MBytes   347 Mbits/sec    1    348 KBytes
[  4]   3.00-4.00   sec  40.5 MBytes   339 Mbits/sec    3    329 KBytes
[  4]   4.00-5.00   sec  40.3 MBytes   338 Mbits/sec   10    335 KBytes
[  4]   5.00-6.00   sec  41.3 MBytes   346 Mbits/sec    5    318 KBytes
[  4]   6.00-7.00   sec  39.5 MBytes   332 Mbits/sec   19    311 KBytes
[  4]   7.00-8.00   sec  40.1 MBytes   337 Mbits/sec    2    293 KBytes
[  4]   8.00-9.00   sec  39.6 MBytes   332 Mbits/sec    1    277 KBytes
[  4]   9.00-10.00  sec  40.1 MBytes   337 Mbits/sec    0    372 KBytes
[  4]   0.00-10.00  sec   405 MBytes   340 Mbits/sec   52             sender
[  4]   0.00-10.00  sec   403 MBytes   338 Mbits/sec                  receiver
Tested with SHA1 / AES128cbc / modp1024
What i find strange is that i get same throughput using 3DES.
NAT is disabled. I have only 2 firewall rules: accept forward and accept input.
Config (SHA1 / 3DES):
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/ip ipsec peer
add address=172.16.2.1/32 enc-algorithm=3des nat-traversal=no secret=password
/ip ipsec policy
set 0 disabled=yes dst-address=0.0.0.0/0 src-address=0.0.0.0/0
add dst-address=172.16.2.1/32 sa-dst-address=172.16.2.1 sa-src-address=172.16.2.3 src-address=172.16.2.3/32 tunnel=yes
Guy Boisvert, ing.
MTCRE
ingtegration
Thu Nov 17, 2016 2:47 am
Result when adding GRE to the mix (to support OSPF):
[  4] local 192.168.89.224 port 49950 connected to 172.16.1.120 port 5201
[  4]   0.00-1.00   sec  18.0 MBytes   151 Mbits/sec    3    261 KBytes
[  4]   1.00-2.00   sec  18.1 MBytes   151 Mbits/sec    2    237 KBytes
[  4]   2.00-3.00   sec  18.5 MBytes   156 Mbits/sec    0    288 KBytes
[  4]   3.00-4.00   sec  18.4 MBytes   155 Mbits/sec    1    245 KBytes
[  4]   4.00-5.00   sec  18.4 MBytes   155 Mbits/sec    0    294 KBytes
[  4]   5.00-6.00   sec  18.3 MBytes   154 Mbits/sec    7    253 KBytes
[  4]   6.00-7.00   sec  18.3 MBytes   154 Mbits/sec    0    302 KBytes
[  4]   7.00-8.00   sec  18.2 MBytes   153 Mbits/sec    9    261 KBytes
[  4]   8.00-9.00   sec  18.6 MBytes   156 Mbits/sec    2    219 KBytes
[  4]   9.00-10.00  sec  18.0 MBytes   151 Mbits/sec    0    273 KBytes
[  4]   0.00-10.00  sec   183 MBytes   153 Mbits/sec   24             sender
[  4]   0.00-10.00  sec   182 MBytes   153 Mbits/sec                  receiver
Guy Boisvert, ing.
MTCRE
nz_monkey
Thu Nov 17, 2016 9:42 am
@ingtegration thats a pretty good result!
Hopefully with all the IPSEC changes recently, Mikrotik developers find the time to add IPSEC VTI.
Having VTI support would mean that GRE is not required to run OSPF between the IPSEC endpoints, and in turn remove that overhead.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
dhoulbrooke
Thu Nov 17, 2016 12:24 pm
When I'm back in the office I'll give rc31 a test. The only change from the default config was:
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
pe1chl
Thu Nov 17, 2016 2:43 pm
I think there would be no difference in overhead between IPsec in tunnel mode (VTI) and IPIP tunnel over IPsec in transport mode.
GRE tunnel has a few bytes of extra overhead because it can transport other protocols as well, but VTI cannot do that, so compare
it with IPIP not GRE.
mchillinger
Thu Dec 01, 2016 1:02 pm
I agree that by concept the CPU should be powerful enough to handle software based VLAN tagging and routing BUT there seems to be a problem in all current of RouterOS installable on the RB750Gr3 [6.37.1 through 6.37.3]:
If even a single VLAN interface is added to a bridge device, the entire router will no longer
* work as a DHCP client
* route packets over any bridge
Minimal example code looks like this:
On ether1 there is untagged network traffic as well as tagged network traffic with VLAN tag 5. Both Networks have a working DHCP Server running.
works:
add name=br-vlan5
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=ether1
does not work:
add name=br-vlan5
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/interface vlan
add interface=ether1name=ether1-vlan5 vlan-id=5
add bridge=br-vlan5 interface=ether1-vlan5
As covered by an earlier post switch VLAN processing is not available yet. As a result RB750Gr3 seems to be unable to handle VLAN traffic with the current software revision
Can this conclusion be verified or did I miss a major point here? We are unable to replicate setups working with RB750Gr2 on the r3 systems
Thanks a lot guys.
Splash
Thu Dec 01, 2016 1:15 pm
I noticed that the master-port option (ethernet interface) is not visible in winbox where its still configurable within the CLI.
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME, MTCSE
Splash
Thu Dec 01, 2016 1:17 pm
Ive also noticed a problem with the auto-negotiation for 1Gbs. On a number of 1Gbs devices running on the RB750Gr2 work fine, however moving them to a Gr3, they refuse to run 1Gbs and can only work at 100Mbs....
Wlanfr3ak
Fri Dec 09, 2016 3:27 am
my 750GR3 is in a BootLoop after i upload the dude-6.38rc45-mmips.npk and want to reboot the RB to install the Dude:
Before i installed the Dude i have updated the RB to routeros-mmips-6.38rc45.npk and make a reboot, after that i updated the Firmware too and reboot again. The Extracted all_packages-mmips-6.38rc45.zip files installed with a reboot but then i want to install The Dude Server ...
Here is the Ouput of Serial/UART Interface:
Rebooting in 1 seconds..Oops[#1]:
Cpu 3
$ 0   : 00000000 00000001 00000000 00000001
$ 4   : 8f449000 811e8700 8f438a00 8021c50c
$ 8   : 803f3394 803f3394 00000001 0000055c
$12   : 8044d2b0 00000001 0000055b 8f438a80
$16   : 8f449000 8040a410 8021bf84 8f438100
$20   : 00000001 00000001 8f438080 00000000
$24   : 00000008 00427ba0
$28   : 8fc30000 8fc31db8 7fd99824 8021be88
Hi    : 00000003
Lo    : 00000000
epc   : 8021be80 squashfs_kill_sb+0x14/0x38
    Not tainted
ra    : 8021be88 squashfs_kill_sb+0x1c/0x38
Status: 1100d803    KERNEL EXL IE
Cause : 80800008
BadVA : 00000000
PrId  : 0001992f (MIPS 1004Kc)
Process init (pid: 1, threadinfo=8fc30000, task=8fc28000, tls=00456460)
Stack : 00000000 00000000 000000a4 80251d3c 8f449000 801bec9c 8f449000 00000001
        8021bf84 8f438100 00000001 8f449000 ffffffea 801bf9fc 80455308 80450000
        801be9a0 803f0000 804552ec 8fcd9480 8040a410 8040a410 8f438100 801c0798
        00000000 801d8b40 ffffffea 8040a410 8f438080 8f438100 8fcd9480 8040a410
        8f438080 801da2a4 8f438080 801d8e34 8ffe3011 00000000 00000001 8f438100
Call Trace:
{8fc31db8} squashfs_kill_sb+0x14/0x38
{8fc31dd0} deactivate_locked_super+0x84/0xc8
{8fc31df0} mount_nodev+0x68/0xd4
{8fc31e18} mount_fs+0x20/0xe8
{8fc31e40} vfs_kern_mount+0x58/0xd8
{8fc31e70} do_kern_mount+0x44/0xf4
{8fc31ea0} do_mount+0x574/0x6c8
{8fc31ef0} sys_mount+0x94/0xe4
{8fc31f30} stack_done+0x20/0x44
Code: afb00010  8c8201e8  00808021 <0c06f88f> 8c440000  0c06fa95  02002021  8fbf0014  8e0401e8
---[ end trace d47c101a91ab90ba ]---
Kernel panic - not syncing: Attempted to kill init!
Reset and Reset to Netinstall doesnt work and the Output is the same. Over Serial i cannot send Inputs.
Have anybody an Idea ?
pe1chl
Fri Dec 09, 2016 10:41 am
Doesn't a full netinstall including format of the flash fix that?
fragma
Fri Dec 09, 2016 2:50 pm
...after that i updated the Firmware too...
Why did you have to upgrade the firmware, was there a problem ?
[and now you bricked the device ?]
pe1chl
Fri Dec 09, 2016 4:56 pm
It does not appear this was caused by the RouterOS and firmware update, but by the install of Dude.
I think the filesystem has been corrupted, maybe it was full (those new devices have that tiny 16GB flash...)
But in that case a full netinstall of RouterOS should fix it.
Wlanfr3ak
Fri Dec 09, 2016 7:15 pm
I have tested with Netinstall but im not running with Windows, so i have to try a other Computer. But the Bootloop is so fast that the Link on the Cable not seem coming before the Board restart, i have to tried that with a Windows Computer and NetInstall again, i hope that this will work :-/
Memodota
Wed Dec 14, 2016 4:01 pm
Hello guys!
Have already trying to config RB750Gr3 for a week. Didn't sleep well for 4 days :)
But i can't make port forwarding work.
First of all i made 2 WAN Balancing with PCC - works great. Then tried to config port forwarding and got nothing (51413, 80 and 22-23 ports).
add action=dst-nat chain=dstnat dst-port=51413 in-interface=ether1 log=no protocol=tcp to-addresses=192.168.88.100 to-ports=51413
I know about firewall mangle. Made rules for input and forward chains to tag connections and made rules to route traffic into right WAN, It didn't work. So after 2 days of no luck i've tried to make clean config.
1)Made clean config from scratch, configured just WAN, Eth5 (Ubuntu Server) and Eth2 (my Windows PC with Winbox);
2)Made masquerading rule for source address 192.168.88.0/24. Internet works nice on Windows PC;
3)Made no rules in Firewall (so all incoming connections should work);
4)Incoming connection from Internet to Routers Web Page is working;
5) Turned off IP Service (http 80 port), so canceled all connections from previous point.
6) Made rule
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1 log=no protocol=tcp to-addresses=192.168.88.100 to-ports=80
Aaaand - NOTHING!!!
I see 3 packets incoming on that rule each time i try to connect but no response from the server.
Firewall on Ubuntu server is turned off. And i make connections from mobile phone so there is no hairpin problem.
Memodota
Thu Dec 15, 2016 11:56 am
Problem solved :)
An error occured on the linux Server. In the network settings were set gateway but this is not enough. Should be set a default gateway.
godlike
Thu Dec 15, 2016 7:18 pm
Thanks guys for fixing CPU profiling on mmips devices.
I hope implementing hw switch functionality will be next :)
dragon2611
Sat Dec 17, 2016 2:08 pm
I've been suspicious about VLANs, since Ubiquiti Edgerouter-x doesn't support them either, Mediatek seems to have screwed the pooch on delivering well documented switch drivers to their customers.
The ER-X does support VLANs on the switch, needs EdgeOS 1.85 or later if I remember rightly.
Regarding the RB750Gr3 any idea on the SSTP performance?
Wlanfr3ak
Sat Dec 17, 2016 2:23 pm
I tried to test again with a Windows Computer, the same Problem. Link doesnt came up and the RouterBOARD restart to fast, no Chance to press a key or something. This is a really bad taste for a Mikrotik Product :-( No i have to send it back ...
dragon2611
Sat Dec 17, 2016 2:48 pm
Try a switch between the RB and the PC
Agromahdi123
Tue Dec 20, 2016 10:49 pm
So just to confirm what i am reading, Hex v3 to Strongswan ipsec in transport will yeild somewhere around 100Mbits, and in tunnel can yield more? I want to put one of these in front of my 2011 for the aes128 HW encryption wanna make sure i can hit at least 75/75
pimmie
Wed Dec 21, 2016 12:44 pm
Finally received a RB750Gr3 yesterday to also replace a RB2011, these are my results for a gre over aes256-sha1-modp4096 ipsec tunnel to strongswan on a 180/30Mbit/s connection (cpu usage ~50%, probably limited to 1 core?):
Ascendo
Wed Dec 21, 2016 1:03 pm
Not bad at all. Wish they'd make a "cheap rackmount" version of this too!
pe1chl
Wed Dec 21, 2016 4:42 pm
Maybe someone will make a bracket that can hold 1-3 of these in a 1U panel?
Could be made to fit some other MikroTik models as well...
pimmie
Wed Dec 21, 2016 5:10 pm
Already exists, MaxxWave MW-RA-750-3 ;)
macgaiver
Wed Dec 21, 2016 5:53 pm
/system resources cpu shows you per core load
/tool profile allows you to see what is taking total CPU time and each core individually what is doing - make sure you run latest 6.38RC, profiler was fixed there
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Agromahdi123
Thu Dec 22, 2016 5:20 pm
Thanks for this response! just placed my order, ive decided to just place it in front of my 2011 and just do a dual NAT thing so the 2011 will do most of the routing to network, and all the Hex needs to do is pass route to it.
sallen
Thu Dec 22, 2016 10:41 pm
Well that seems slightly silly. Why the double NAT? Just have the Hex do all the routing and turn the 2011 into a switch and AP (if your's is wireless). The Hex has a better CPU and more memory.
pimmie
Fri Dec 23, 2016 12:54 pm
I fully agree with this, the Hex is much faster in (almost?) all aspects. What I did was export my config on the rb2011 (in terminal: `/export file=rb2011_20161223.rsc`) and downloaded that file. Then I manually changed the interface/bridge configuration to incorporate the 6 less ports (5ether + sfp) and removed all wireless configuration (as I was not running CAPsMAn yet). Then I uploaded and imported that file to/on the Hex (`/import hex_20161223.rsc`). After that I re-configured my wireless configuration in CAPsMAN and set the correct password for the admin user. Actually I am not using my rb2011 at the moment, I added a hAP ac lite as switch and cap device so I also have 5Ghz wifi.
The only problem I had is that when you import the configuration on the hex and you are changing master ports, your connection is terminated and therefore also the import. So I had to check manually until which line the configuration was imported and then re-run the import with `/import hex_20161223.rsc from-line=XX`
pe1chl
Fri Dec 23, 2016 3:56 pm
This method of transferring configuration must be used with care.
For example, the exported config contains MAC addresses for some interfaces, and you will duplicate
them in the new router this way. When both routers end up being on the same network and the original
place where the MAC address was used is not deleted there, this may cause "interesting" problems later.
Also, note that importing a config does not erase existing config of those same items already present
in the new router. For example, firewall rules will be added at the end but the default rules will not be
deleted.
However, with the proper care for this and other potential problems, it is a quick way of getting everything
setup.
yams
Mon Dec 26, 2016 7:45 pm
Hi
I have a problem with the rsc file. It seems that the RouterBOARD 750G r3 doesn't excute the file when i reset it and execute the file with no default configuration.
i did a test with a minimum of information in the rsc file and it doesn't seems that the file is excuted
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
if i import the file manually in the console, it does work and i don't have any error in the verbose.
Does anyone have this kind of problems ? Did i miss something ?
pe1chl
Tue Dec 27, 2016 12:17 am
Yes, I have seen this problem before. It is not related to the RB750Gr3, it is related to recent RouterOS versions.
I have no idea what is really causing it and for me too the only workaround is to manually paste new configuration in a terminal session.
yams
Tue Dec 27, 2016 2:18 pm
Hi pe1chl
Thanks for your answers.
I hope it will be fix soon.
nescafe2002
Long time Member
Long time Member
Tue Dec 27, 2016 2:25 pm
Could be due to (absence of) /system routerboard settings boot-delay feature.
This time is needed to initialize interface etc.
Try adding a delay in your script, e.g.:
# mar/02/2016 04:00:00 by RouterOS 6.35rc15
# software id = XXXX-XXXX
:delay 15s
add name=bridge-lan
yams
Tue Dec 27, 2016 2:30 pm
:delay 15s
add name=bridge-lan
Hi nescafe2002
I tried that too but it didn't work.
I add like 30 secondes of delay and the router start before this time (Like it didn't take this value)
pe1chl
Tue Dec 27, 2016 7:19 pm
I have been fighting with the "reset with no defaults and import specified script" on another router (RB951)
and I have not been able to get it to work in 6.37 and I think 6.36.
I am sure it worked OK on 6.29 but somewhere after that it has been broken. I have no idea how to debug
this on such a router. On a router with RS232 port I can look at the output there and login to see what is
happening, but on the new devices without RS232 it is not possible to diagnose it.
I have reported it to support and they told me they would look into it, and also took my suggestion of writing
a debug log to a file that we can later download, and to continue processing the script even when a minor
error occurs (as it is now it will stop at the first error). However, as you can see this has not resulted in
improvement yet.
yams
Tue Dec 27, 2016 7:29 pm
Hi nescafe2002
In fact you were right :) It solved my problems
I tried before with a delay but my syntax was not good
I took the syntax you wrote in your exemple and it's solved my problems.
thank you :)
a1x0
Tue Dec 27, 2016 11:39 pm
As Wlanfr3ak I update ROS to 6.37.3 by installing extra packages and now router loop reboot. Netinstall and configuration reset not work :(
Raice
Thu Dec 29, 2016 11:44 am
Could you share your ROS and StrongSwan config files?
a1x0
Sat Jan 07, 2017 5:14 pm
Can anybody help?
msatter
Sat Jan 07, 2017 11:43 pm
Can anybody help?
Contact Mikrotik support how to recover your box now normal ways did not work.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47 / Winbox 3.24 / MikroTik APP 1.3.14
Biker111
Mon Oct 30, 2017 4:44 am
As a customer, where do we get such information before we buy the product?
Really, really strange guessing game,- on your main product description page there is no such information?
I know, after some time with Mikrotik one learns to follow up and consult pages like https://wiki.mikrotik.com/wiki/Manual:S ... p_Features
But such information should be told the customer directly on the main product page.
soosp
Sun Nov 19, 2017 9:14 pm
One year has been gone since this "promise" was written. Are ther any development in this question?
rognick
Wed Dec 27, 2017 4:57 pm
Can anybody help?
The problem with VLAN tagging / untagging is fixed with version v6.41
Cybernet1k
Wed Jan 17, 2018 11:09 am
Hello.
The documentation has information that the device can work with disabled switching and enabled switching:
https://i.mt.lv/routerboard/files/RB750 ... 140316.png
https://i.mt.lv/routerboard/files/RB750 ... 152443.png
How disable switching? Is it enough to remove all ports from the bridge and bridge itself?
sebastia
Wed Jan 17, 2018 10:31 pm
That is my understanding too: I've asked support but didn't got conclusive answer.
viewtopic.php?f=3&t=128729
ashpri
Tue Jun 04, 2019 9:23 am
I can confirm that as of today, the HEX (RB750GR3) with v6.44.3 cannot yet implement vlan in switch chip (with hardware offloading).
I have a HAPAC2 with switch chip vlan enabled and the same settings does not work on the HEX.
pe1chl
Tue Jun 04, 2019 10:29 am
I think the first level of VLAN (in hardware) is used to emulate 5 ports on a chip that has only 2.
When you configure ether1, ether2, ether3, ether4 and ether5 you are in fact internally configuring some VLANs that are mapped in the internal switch to exit on that specific port untagged.
Now, when you want to configure tagged VLANs on those ports that is another level of VLAN which is always software because this switch does not support 2 levels of VLAN.
This same issue is present in other MikroTik products as well, but not in all of them. E.g. the more powerful switches use chips that fully support multiple levels of VLAN, and the RB2011 has a better chip on ports 1-5 than on ports 6-10.
The new "filtered bridge" configuration method does not solve this because once you use VLANs on such a bridge, the hardware accel automatically becomes disabled.
The old "switch" configuration method is more powerful in that it can sometimes do VLAN configurations (which then have hardware accel), but not on this model.
Users browsing this forum: Google [Bot] and 26 guests
