MUM Europe 2020
zosselp
CAPsMAN VAP problem
Tue Oct 25, 2016 3:33 pm
I've recently configured CAPsMAN for managing two AP's. Everything is working fine but when trying to add additional Virtual AP on one of the cap's, nothing happens at all. CAPsMAN is not adding any additional VAP.
Here's my current config:
Provisioning:
Flags: X - disabled
 0   radio-mac=E4:8D:8C:CB:7E:BD hw-supported-modes="" identity-regexp=""
     common-name-regexp="" ip-address-ranges="" action=create-dynamic-enabled
     master-configuration=guestAP-cfg slave-configurations="" name-format=cap
     name-prefix=""
 1   radio-mac=E4:8D:8C:9C:BB:0F hw-supported-modes="" identity-regexp=""
     master-configuration=BiuroAP-cfg slave-configurations=guestAP2-cfg
     name-format=cap name-prefix=""
Configuration:
 0 name="guestAP-cfg" mode=ap ssid="Stolarczyk" country=poland hw-retries=4
   security=guestAP-security datapath=guest_vlan_700 channel=GuestAP-channel13
 1 name="BiuroAP-cfg" mode=ap ssid="StolarczykNet" hide-ssid=yes country=poland
   security=BiuroAP-security datapath=StolarczykNet channel=BiuroAP-channel1
 2 name="guestAP2-cfg" mode=ap ssid="test" security=test datapath=guest_vlan_600
Datapath:
 0 name="guest_vlan_700" local-forwarding=yes vlan-mode=use-tag vlan-id=700
 1 name="StolarczykNet" bridge=bridge-local
 2 name="guest_vlan_600" local-forwarding=yes vlan-mode=use-tag vlan-id=600
VLAN:
Any suggestions ?
juanvi
Re: CAPsMAN VAP problem
Tue Oct 25, 2016 4:38 pm
Is there in CAP vlan to gateway defined?
¡vʞvdnX puv ···SOɹǝʇnoɹ ʞıʇoɹʞıW oʇ sʞuvHʇ
Deaqui
Wed Oct 26, 2016 1:45 am
Have you associated vlan to an interface before ?
I'm not sure but,I think you must add the bridge in the corresponding Datapath of the vlan 600 and 700.
Users browsing this forum: No registered users and 27 guests
