MayestroPW
Adding dynamic interfaces to interface list.
Tue Nov 01, 2016 7:37 pm
Hi there,
I have a problem with MikroTik. I need to make a script which adds my dynamic interface from PPTP to interface list when user connects, but I don't know how the script would look like.
/interface list member add interface=[find interface=<pptp*] list=LAN
MikroTik creates dynamic interface as user connects, and I wan't to add this interface to my list LAN.
pukkita
Trainer
Trainer
Re: Adding dynamic interfaces to interface list.
Tue Nov 01, 2016 9:47 pm
Maybe through the use of PPP profile Script On Up / On Down section?
MayestroPW
Tue Nov 01, 2016 10:53 pm
Actually i'm using this, but I don't know how to code it.
pukkita
Trainer
Trainer
Wed Nov 02, 2016 10:28 am
I moved this post to the Scripting forum, a more suitable place to get help regarding this.
Additionally, you can refer to the Wiki
May I ask why do you need to add the ppp interfaces to an interface list?
MayestroPW
Wed Nov 02, 2016 6:43 pm
Because my firewall blocks traffic which is not coming from LAN and going to the WAN.
ditonet
Forum Veteran
Forum Veteran
Thu Nov 03, 2016 12:09 am
Maybe you should change firewall logic from 'interface list' to 'address list'?
It's pretty simple to add dynamic PPTP interface's address to address list.
HTH,
MayestroPW
Thu Nov 03, 2016 3:15 pm
I'd rather to keep firewall like is now.
ollit
Sun Aug 06, 2017 12:18 pm
I have the same Problem. Is there any solution for or don't work like this?
KR
Oliver
efaden
Sun Aug 06, 2017 1:27 pm
On up and on down should work.
Sent from my Pixel XL using Tapatalk
