ishtiak
How to create Redundancy
Wed Nov 09, 2016 10:58 pm
Dear Please see my topology diagram attached… I am running PPPOE and DHCP server on 2 interfaces on MKT-1. After long distance my Both LAN links are close together and I have configured MKT-2 and MKT-3 (Both in Bridge Mode) on both LAN segment and attached MKT2- and MKT-3 via a switch.
In case of Single LAN Bridge port become 1 as designated and other as backup while in this scenario both ports remain designated in root bridge MKT while in other MKT one become root port
I want to create redundancy if my LAN1 segment fails, disconnected segment should be connected through LAN 2 to my main router MKT-1.. Currently i have disabled bridge port which connects to MKT3 on other LAN segment. Please help me in this regard
MrcS
Re: How to create Redundancy
Thu Nov 10, 2016 7:49 am
easy to solve using routing protocols like ospf
Sent from my SM-N910C using Tapatalk
ishtiak
Thu Nov 10, 2016 10:20 am
Dear i would appreciate if you guide me in details
how pppoe client will reach to MKT-1 for authentication ?
Caci99
Thu Nov 10, 2016 1:23 pm
Thing is, both pppoe and dhcp clients will find the server by broadcast packets. The way you have created the network, if the two routerboards have arp=proxy-arp in their bridge interface, means that every device is in the same broadcast domain. So every device will find either server 1 or server 2 on the core router, depending on which responds first. You don't need any extra config if all you want is clients find the server.
-Toni-
Don't crash the ambulance, whatever you do
ishtiak
Thu Nov 10, 2016 9:03 pm
Dear Understood,
But here i want the link between router boards as a backup link...
if any of one routerboard disconnected from the core router due to cable or any switch fault...
It should be connected via 2nd RouterBoard..
MrcS
Re: RE: Re: How to create Redundancy
Thu Nov 10, 2016 11:00 pm
Dear Understood,
then you should read about link failover using ospf
Miracle
Fri Nov 11, 2016 2:59 pm
Dear Understood,
Make 2 vlan from R1, then add them to bridge as backup link ?
Users browsing this forum: McSee and 67 guests
