MUM Europe 2020
carnevale
iPHONE VPN with Mikrotik
Thu Nov 17, 2016 5:40 am
Someone have one step by step config to make possible connect to VPN using iPhone ?
Can be L2TP or IKE or IPSEC. Any guide that really Works.
I appreciate any help.
thanks
2frogs
Long time Member
Long time Member
Re: iPHONE VPN with Mikrotik
Thu Nov 17, 2016 6:15 am
normis
Thu Nov 17, 2016 12:44 pm
in QuickSet, click the "VPN" checkbox, and a L2TP+IPsec setup will be made automatically, and you can connect right away. So just one click in QuickSet page.
erlinden
Thu Nov 17, 2016 1:21 pm
This is really nice! Will this also add necessary firewall rules?
normis
Thu Nov 17, 2016 1:22 pm
Yes, it does
kylepmorris5
Thu Nov 17, 2016 1:23 pm
You can check the step by step guide of How to setup VPN on Iphone in this Cheap VPN's post: https://www.bestvpnprovider.com/buy-cheap-vpn/.
normis
Thu Nov 17, 2016 1:26 pm
Yes, if you need more settings, you can create the same by hand
Sent from my iPhone using Tapatalk
Morcegolas
Sat Jul 29, 2017 1:08 pm
I tried to edit the previous post with no luck.
Forwarding ports 500 and 4500 UPD to mikrotik worked!
Thanks for the tip of configuring vpn in quickset! TOP
Enviado do meu iPad usando o Tapatalk Pro
Users browsing this forum: DoubleDB and 56 guests
