nichky
Long time Member
Long time Member
MikroTik doesn't read external hdd
Tue Nov 22, 2016 12:57 am
i've been plug in external hdd (from laptop) to MikroTik like FTP server.MikroTik doesn't read, but when I'm plaguing normal usb stick working fine. Does anywan know why?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
jarda
Re: MikroTik doesn't read external hdd
Tue Nov 22, 2016 9:02 am
Are you feeding it enough?
Check the current requirements.
nichky
Long time Member
Long time Member
Tue Nov 22, 2016 10:59 am
i was locking out, i found = "problem in power USB in mikrotik not enough"
I'm wondering MikroTik is giving 5v output same as laptop. How can i do FTP with external HDD? If im plug in SSD will be same?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
rossiza
Tue Nov 22, 2016 11:30 am
An SSD will generally use less power, but it may not be enough. You could also use an external drive with it's own power supply if it's an option.
ISP Billing and Radius in the Cloud - https://ibill.io/
nichky
Long time Member
Long time Member
Tue Nov 22, 2016 12:12 pm
which one, let me know
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
cszolee79
Tue Nov 22, 2016 3:38 pm
I have a very old Samsung S2 500gb USB2 drive, it works without problem in RB951G-2HnD and RB3011 as well.
You need to format it to fat32 though, and then share it in ip/smb, you need to add smb user and smb share (/disk1).
Won't be too fast though, on the MIPS model i got maybe 3-4mb/s, with the ARM it was 30mb/s.
One... Hundred... BILLION DOLLARS!
nichky
Long time Member
Long time Member
Wed Nov 23, 2016 12:12 am
Maybe that's is the problem, my hdd has exFAT and NTFS, Doesn't have FAT32 (default). im guessing NTFS needs more feeding.
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
Users browsing this forum: No registered users and 110 guests
