MUM Europe 2020
triac
How to know real bandwidth of a radio link?
Tue Oct 17, 2006 8:27 pm
Hi, this is my problem:
I have a wireless link (2x RB532 with CM9 cards) and the tx/rx rate is 54 Mbps but when I try to test the link with bandwidth test I have these results:
UDP only Receive=6.7 Mbps
UDP only Send= 10.9 Mbps
TCP only Receive = 5.3 Mbps
TCP only send = 6.7 Mbps
I have about same values on a 24 Mbps link... why?
There is a method for calculate real bandwidth of a wireless link?
How the processor speed can influence the speed of the data transfer?
Thank You
Paolo
Paolo Torri
sergejs
Wed Oct 18, 2006 8:39 am
Paolo,
first of all it is better to run bandwidth test trough wireless link, connect two powerful worskstations on both ends,
PC1==Router1---Wireless---Router2==PC2, run bandwidth from PC1 to PC2.
Bandwidth test takes a lot of CPU resources, if you running tests directly to router.
triac
Sat Oct 21, 2006 6:36 pm
Hi Sergejs, Thank's for answer
I've tried with two PC connected to the routers but results are about the same.... :(
Any suggestion?
Paolo Torri
provoshane
Tue Oct 31, 2006 11:59 pm
Try running in turbo mode.
Users browsing this forum: No registered users and 18 guests
