Feroz
NO PING !!
Sun Nov 27, 2016 9:40 am
hi,
I have two RB33A, both link are connected, but from terminal not ping each other
[admin@MikroTik Energya] > ip address print detail
0 ;;; default configuration
address=192.168.88.2/24 network=192.168.88.0 interface=ether1
actual-interface=bridge1
Feroz
Re: NO PING !!
Sun Nov 27, 2016 10:37 am
please anyone respond my question .......
nichky
Long time Member
Long time Member
Re: NO PING !!
Sun Nov 27, 2016 12:16 pm
show us your conf on bowt MT, and also which OS version are you using?
RouterOS does not have a random function. Many has tried to make script to make random text, but all seems to be flawed.
viewtopic.php?f=9&t=160183
!) Safe Mode is your friend;
Feroz
Re: NO PING !!
Sun Nov 27, 2016 12:19 pm
Thanks for your reply. I will give you access to the router, can u connect pls ?
nichky
Long time Member
Long time Member
Re: NO PING !!
Sun Nov 27, 2016 12:21 pm
give me 30 min. i will do, oki
Feroz
Re: NO PING !!
Sun Nov 27, 2016 12:28 pm
I am waiting...
nichky
Long time Member
Long time Member
Re: NO PING !!
Sun Nov 27, 2016 12:29 pm
skype: nichki2
Feroz
Re: NO access to GATEWAY
Wed Dec 14, 2016 6:02 pm
i have site A and site B, using bridge connection. both link are up and i can able to ping both side, now dsl router on Site B can ping dsl gatway 1.1 but site A cannot ping gateway or x.x.1.0/024. i need to fix this issue soon as possible am almost screwed up.
olkitu
Re: NO PING !!
Fri Dec 23, 2016 2:26 pm
Please make some picture on your network setup so it's easier figure how your network should working.
Okay i try figure how this shoud working, example:
Site A - B connected with Ethernet cable, A (ether1) to B (ether2 what is also bridge1). Site B connected via ether1 to DSL modem ethernet port?
Site A:
ether11
IP: 192.168.88.2/24
Site B:
ether2 / bridge
IP: 192.168.88.1/24
ether1
from DHCP 192.168.1.2/24 (example)
DSL modem
IP: 192.168.1.0/24
So A - B working because it's same /24 network but because DSL modem is different network you should make src-nat to Site B. Then you can ping. Then DSL modem can return package back to A. It think this is solution?
Add this to Site B:
/ip firewall nat add action=masquerade chain=srcnat out-interface=ether1
Network Specialist
Need know where is cellular tower? Try CellMapper to get know where is cellular tower:
https://www.cellmapper.net/map
Users browsing this forum: blingblouw and 22 guests
