MUM Europe 2020
ropeba
Block file sharing on WDS network
Thu Oct 19, 2006 1:28 pm
how?
tneumann
Sat Oct 21, 2006 4:23 pm
Exactly what do you mean when you talk about "file sharing"? Do you mean P2P apps such as Gnutelle, eDonkey, etc. or are we talking about windows file sharing (SMB, NetBIOS)?
--Tom
simonkizi
Re: Block file sharing on WDS network
Sun Oct 22, 2006 3:21 am
how?
Just block port 445 for smb. Check in the Mikrotik Manual for suggestions of other ports to block.
ropeba
Fri Oct 27, 2006 9:06 pm
i have blocked port 135-139 and 445, but I still can access to some shared folders on computers in network...
jo2jo
Forum Veteran
Forum Veteran
Fri Oct 27, 2006 10:05 pm
I may be wrong but is this not because WDS is a bridge and the computers may be using netbios NOT over tcp to communicate?
tneumann
Fri Oct 27, 2006 10:46 pm
Even if they are running NetBIOS over IP (in contrast to some other option, like NetBEUI, which would also be possible over a bridged network), then any filter placed in /ip firewall filter will be ignored for that traffic because these filters only work in the IP forwarding chain, and as long as everyone doing NetBIOS over IP is in the same layer 2 network no IP forwarding will actually take place. Look into bridge filters if your network is designed like that.
--Tom
ropeba
Sun Oct 29, 2006 6:06 pm
yes i use wds + bridge, how I can block file sharing?
valens
Trainer
Trainer
Sun Oct 29, 2006 6:32 pm
You can try to disable the default forward in wireless setting.
And do bridge filter also.
Users browsing this forum: quackyo and 16 guests
