I have problem with configuration VPN using PPTP. I'll explain what I want to do:
- one client had access only to host e.g. 192.168.15.10
- other client had access only to hosts e.g 192.168.18.26 and 192.168.21.18
My configuration:
Code: Select all
[admin@MikroTik Router] /interface> pptp-server server print
enabled: yes
max-mtu: 1450
max-mru: 1450
mrru: disabled
authentication: mschap2
keepalive-timeout: 30
default-profile: VPN_profile
[admin@MikroTik Router] /interface> /ppp secret print detail
Flags: X - disabled
0 name="user1" service=pptp caller-id="" password="12345" profile=VPN_profile local-address=192.168.51.1 remote-address=192.168.51.150 limit-bytes-in=0 limit-bytes-out=0 last-logged-out=oct/18/2016 11:31:28
1 name="user2" service=pptp caller-id="" password="54321" profile=VPN_profile local-address=192.168.51.1 remote-address=192.168.51.160 limit-bytes-in=0 limit-bytes-out=0 last-logged-out=dec/08/2016 11:20:55
[admin@MikroTik Router] /interface> /ppp profile print
Flags: * - default
0 * name="default" use-mpls=default use-compression=default use-encryption=default only-one=default change-tcp-mss=yes use-upnp=default address-list="" on-up="" on-down=""
1 name="VPN_profile" use-mpls=default use-compression=default use-encryption=yes only-one=default change-tcp-mss=default use-upnp=default address-list="" dns-server=8.8.8.8 on-up="" on-down=""
2 * name="default-encryption" use-mpls=default use-compression=default use-encryption=yes only-one=default change-tcp-mss=yes use-upnp=default address-list="" on-up="" on-down=""
