apr
system,error,critical login failure for user admin from [...] via winbox
Fri Dec 09, 2016 10:48 am
My RB3111UiAS (arm) running fine, uptime 79days.
Suddenly in the log I see the followings for each day always the same time.
My firewall only allows inbound connection for 25/443/5444 (sstp vpn), nothing more.
In MAC server all interface disabled for WinBox (tested I cannot connect from local network via mac address)
The strange logs (happens once each day with the same timestamp):
dec/08 07:23:30 system,error,critical login failure for user admin from 10.0.0.1 via winbox
dec/08 07:23:30 system,error,critical login failure for user admin from [my wan ip] via winbox
How can I fix this?
apr
Re: system,error,critical login failure for user admin from [...] via winbox
Thu Dec 15, 2016 2:35 pm
Update os to v6.37.3, and the log changed to:
system,error,critical login failure for user admin from 10.0.0.1 via dude
So dude server(?) try to log in (from where?) as admin. But I have no admin user at all (renamed the default admin).
How can we fix this?
kiano
Wed Jun 20, 2018 9:36 am
still actually
login failure for user admin from 127.0.0.1 via dude
Steveocee
Wed Jun 20, 2018 12:14 pm
Can you post an export of your firewall? If you are getting login attempts from your WAN IP then something is still open.
What local address range are using?
Do you use Dude in your network?
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
Users browsing this forum: anitamh, Baidu [Spider], Chaosphere64, HristoRaykov, justarankamateur and 56 guests
