MUM Europe 2020
RLithgo
WebFig doesn't load in IE 11
Mon Dec 12, 2016 1:00 am
After logging in to RouterOS v6.37.1 in IE 11, instead of the usual WebFig UI, it just shows a grey page and the IE process becomes unresponsive (as does my PC until i close the IE tab).
Clearing browser cache doesn't help.
It works fine on chrome.
normis
Re: WebFig doesn't load in IE 11
Mon Dec 12, 2016 10:23 am
Have you tried another PC?
I just tested with IE11 and also the newer Microsoft Edge. It works fine for both. Did you try Edge?
pe1chl
Mon Dec 12, 2016 10:37 am
In my experience (I exclusively use WebFig) it is better to use a browser like Firefox or Chrome instead of IE.
With IE the load times of pages with long lists on them are very slow, and I also have occasional difficulty
when setting things up (e.g. a field with ipaddress/bits is rejected as having invalid netmask).
This is however with IE 10, I did not try IE 11.
normis
Mon Dec 12, 2016 10:42 am
Also, it is a good idea to use a newer browser.
IE10 --> IE11 --> EDGE
pe1chl
Mon Dec 12, 2016 11:22 am
Sure, but Microsoft has decided that each newer version is only available on a newer OS.
With Firefox and Chrome, that problem does not exist that much.
Users browsing this forum: dirman, durrsaku and 85 guests
