David1234
dude won't connect on windows 10
Tue Dec 13, 2016 4:46 pm
Hello ,
I have installed dude v6.36.4 on my computer (x86) ,
but when I try to connect as localhost he said he can't
I have disable the firewall and also open ports 2211\2210 - and nothing
what else should I do ?
GreySer
Re: dude won't connect on windows 10
Thu Dec 15, 2016 10:04 am
Maybe you're using a non-standard port for winbox? Then it is necessary to use it dude.
krisjanis
Thu Dec 15, 2016 10:07 am
New software builds no longer have windows server option available.
http://wiki.mikrotik.com/wiki/Manual:Th ... n#Overview
amyacker
Thu Dec 15, 2016 1:28 pm
error code: 0x801901F7 on windows 10 :(
Adonis3a
Mon Dec 19, 2016 10:42 am
i Had same problem but i change the manual port to defult port
like 8291 i start working or if not change to port 50 i hope it will be work
Users browsing this forum: No registered users and 11 guests
