David1234
can I make interactive script?
Thu Dec 15, 2016 5:02 pm
hello ,
can I make an interactive script where I waiting for replay and then save it?
mrz
Re: can I make interactive script?
Thu Dec 15, 2016 5:11 pm
You mean interaction with the user? That is not possible directly with ROS script.
David1234
Thu Dec 15, 2016 5:29 pm
so only with API?
not in ssh script?
PackElend
Wed May 18, 2022 10:01 pm
YES YOU CAN
      :local input1 do={:return};
      :put "Input Name: "
      :local name [$input1];
      :local input2 do={:return};
      :put "Input Surname: ";
      :local surname [$input2];
      :put "The full name is : $name $surname."
rextended
Thu May 19, 2022 2:14 am
Only unique function can be sufficent:
      :local requestvalue do={:put $1 ; :return}
      :local name    [$requestvalue "Insert the name"]
      :local surname [$requestvalue "Insert the surname"]
      :put "The full name is: $name $surname"
kevinds
Long time Member
Long time Member
Mon May 23, 2022 10:18 pm
hello ,
*if* you could, what would you want it to do?
Basically, why do you want to?
rextended
Mon May 23, 2022 10:29 pm
Probably, my supposition, for autoconfig script, that once executed (on interactive terminal, obviously)
ask for SSID, passwords, RouterOS users names and passwords, IP???, etc.
I already use that when the CPE is installed to end user: the technician launch the script and do not forget nothing, all is requested.
On error something like this appear on terminal, etc.
(for see the example, paste it on terminal)
/terminal style error;:put "Caratteri non validi nell'SSID"
(IT: Caratteri non validi nell'SSID = EN: Invalid characters on SSID)
Just for test a joke:
      :local name    [$requestvalue "Insert test as value"]
      :if ($name != "test") do={
          :put "you have not written test"
      } else={
          /terminal style syntax-old
          :put "welldone"
kevinds
Long time Member
Long time Member
Mon May 23, 2022 10:52 pm
So a replacement for Quick-Set?
rextended
Mon May 23, 2022 10:56 pm
Quick-Set?
What is? :evil:
At least as a working replacement...
Users browsing this forum: complexxL9 and 182 guests
