Most likely like last time. But SwOS bootable too. So, we can set this as normal L2 Switch without RouterOS interference.mrz can you tell us what cpu is inside? Is there wirespeed L3 performance over a ASIC or like before?
Using it, just that SwOS makes RB260 drop within "slightly smarter dumb-switch".Do you really want to use SwOS? No SNMPv2/3, no STP, no CLI, ...
You are not the only one wishing to buy Mikrotik hardware with more 10g ports and more routing capability. We are also into that. We are a small datacenter looking to push 10G switches TOR (top of the rack), but we need an aggregation switch to interconnect them. We are very excited about this new switch, looking forward in buying it!I'm very interested if we are the only company being interested in such a device from Mikrotik.
Thanks for the answers.
Kasper
As far as I know, all Routerboards perform LACP on CPU. So no Mikrotik device can provide wirespeed LACP, for instance, 20gbit/s passing through two aggregated 10G SPF+ ports. Gentlemen, am I correct about this or am I missing something?LACP support?
Picture shown in original post showed two LEDs with PSU1 and PSU2 next to them. That'll be a definitive yes.Finally, are there dual power supply options?
Forgive me Normis but....what does "accelerated routing and MPLS" mean. Fast path?We are working on LACP support and also on accelerated routing and MPLS (including for this product). But since it is not ready yet, I did not want to make early promises.
And it will probably support Fast Reroute, EVPN, L3 VPN for IPv6, and every MPLS feature you could ever want.....Thanks for the teaser Normis.
My interest in this device has doubled!
Hopefully it has MPLS push/pop in hardware and not just label switching.
Unicorns Loading....And it will probably support Fast Reroute, EVPN, L3 VPN for IPv6, and every MPLS feature you could ever want.....
BUT.....
Not until v7![]()
I think this heatsink looks exactly the same as one in CCR1009-PC so my blind guess is that it's passive because this heatsink internally looks like that:So it seems from the looks of it on the back we see a heatsink. Does that mean that this switch will be fully fanless? Or will it have a fan on the inside?
That's the ASIC I guess: Marvell Prestera 98DX8216It is for this device. The CPU has features that allow it. I can't say more at the moment.
Very nice! Would love if this mechanic could be added to the other CSS/CRS RM models as well.The system runs silently, but there are two fans for situations where ambient temperature gets close to maximum. They will run automatically and only when it gets too hot.
I agree it's incredibly awesome feature enabling those machines to be placed around other people, not only in dedicated, isolated server rooms which are not always available. I wish more enterprise hardware would be able to run passively/actively on demand. As security system integrator I usually work with rackmount network devices on desk for initial config. Loud blowers are really annoying - not only for me but also for co-workers who atm write documentation or do other stuff that requires them to focus. In the end we connect device and 1 laptop and itgenerates so much noise as if it's processing traffic of 100 000 workstations lol...Very nice! Would love if this mechanic could be added to the other CSS/CRS RM models as well.The system runs silently, but there are two fans for situations where ambient temperature gets close to maximum. They will run automatically and only when it gets too hot.
Welp... I guess you can say then that you use the only unmanaged full 10G switch in the market xDSo .. I got landed with a batch of 3 of these .... and so far, VLans can't be configured in RouterOS/Winbox at all. Nevermind MPLS etc.
Looks like the hardware hit the market before the software was ready.
/M
Try out the latest release candidate version. It contains the latest bridge implementation with Winbox support and MPLS HW offloading.So .. I got landed with a batch of 3 of these .... and so far, VLans can't be configured in RouterOS/Winbox at all. Nevermind MPLS etc.
/M
That doesn't fix the issue with the lack of being able to configure VLans though.
Try out the latest release candidate version. It contains the latests bridge implementation with Winbox support and MPLS HW offloading.
What exactly are you missing? Vlan configuration in the latest release candidate version is moved to Bridge section.That doesn't fix the issue with the lack of being able to configure VLans though.
/M
Hi Emils,We have responded to your ticket on Monday. Are you sure you have not received a response? Can you check the spam folder?
I´m dreaming of "Ethernet Over IP" (EoIP) with hardware acceleration on CRS317, .i.e. 10Gbit/s EoIP tunnels for Vmware VMotion (layer 2 interconnect). Would this be possible with the CRS317?Data Centre Interconnect - VPLS will be able to be used to "backhaul" Layer2 traffic between data centres.
+1I´m dreaming of "Ethernet Over IP" (EoIP) with hardware acceleration on CRS317, .i.e. 10Gbit/s EoIP tunnels for Vmware VMotion (layer 2 interconnect). Would this be possible with the CRS317?
If anything I think you will see VXLAN tunnel support, as this is supported by the ASIC used in the CRS317.I´m dreaming of "Ethernet Over IP" (EoIP) with hardware acceleration on CRS317, .i.e. 10Gbit/s EoIP tunnels for Vmware VMotion (layer 2 interconnect). Would this be possible with the CRS317?Data Centre Interconnect - VPLS will be able to be used to "backhaul" Layer2 traffic between data centres.
Agree with you 100%. it's nice to have the hardware forwarding purely as a P router, but the PE functionality is where the magic isSo with the 6.41rc releases Mikrotik have added "MPLS Forwarding" to the CRS317.
In my opinion just being able to forward MPLS packets based on the label is pointless. It wont make me buy the CRS317 over any other plain Layer2 switch.
The MPLS features that would make me buy a CRS317 over another device are:
VPLS (PW) encap/decap
Description:
Tunnels are configured via RouterOS, BGP/RSVP/LDP running on the Control Plane provide signalling, the Control Plane then configures the Data Plane to push/pop labels for this tunnel in hardware.
Use Cases:
(w)ISP Backhaul - CRS3xx installed at remote POP can encapsulate traffic from AP's inside VPLS and backhaul it to a central PPPoE/IPoE concentrator.
Layer 2 VPN Services - CRS3xx can encapsulate all traffic from a port into a VPLS tunnel at customer Site-A and then decapsulate it at customer Site-B allowing ISP's to offer "value added" services.
L3VPN forwarding in Hardware
Description:
VRF's are configured via RouterOS and RD/RT settings configured. RouterOS signals these in the control plane using BGP to other routers. RouterOS Control Plane updates the Data Plane (FIB) to forward VRF packets in HW and to push/pop labels to remote locations.
Use Cases:
Customer VPN's - (w)ISP's can offer MPLS VPN services to their customers and deliver them using Mikrotik CRS3xx devices at site. The CRS3xx device can host multiple VRF's e.g. Customer-WAN, Customer-DMZ, Internet to provide L3 services to the customer, each with different routing tables (hence security boundries)
FYI these features are currently available on the Brocade CER/CES, Extreme Networks x460/x670, Juniper QFX/ACX, Nokia 7210 SAS series. Having these features available on the CRS3xx would provide Mikrotik a competitive advantage over the guys just selling L2/L3 switches, especially at the price point Mikrotik have.
I think Mikrotik doesn´t need VXLAN, as there is EoIP support.If anything I think you will see VXLAN tunnel support, as this is supported by the ASIC used in the CRS317.
I disagree. EoIP is a proprietary Mikrotik protocol. VXLAN (RFC 7348) is the industry standard, with "Fast Path" support across multiple vendors and chipsets, e.g. Broadcom Trident/Tomahawk, Marvell Prestera, Mellanox Spectrum, Intel xl710(i40e).I think Mikrotik doesn´t need VXLAN, as there is EoIP support.
Unlikely. While EoIP is very similar to GRE/NVGRE it is not the same. The Prestera chipset likely only has support for the specific frame/header formats specified by the standards.- According to the Marvell Prestera DX homepage: "Support for the newest Tag formats (VXLAN, NVGRE, Geneve) and congestion management capabilities (PFC, ETS)"
- According to Mikrotik´s wiki for EoIP: "Ethernet over IP (EoIP) Tunneling is a MikroTik RouterOS protocol that creates an Ethernet tunnel between two routers on top of an IP connection." "The EoIP protocol encapsulates Ethernet frames in GRE (IP protocol number 47) packets (just like PPTP) and sends them to the remote side of the EoIP tunnel. "
- According to wikipedia: VXLAN: "It uses a VLAN-like encapsulation technique to encapsulate MAC-based OSI layer 2 Ethernet frames within layer 3 UDP packets,"
- According to wikipedia: NVGRE: "Network Virtualization using Generic Routing Encapsulation (NVGRE) is a network virtualization technology that attempts to alleviate the scalability problems associated with large cloud computing deployments. It uses Generic Routing Encapsulation (GRE) to tunnel layer 2 packets over layer 3 networks."
So, hardware support of EoIP might be possible with the CRS317?
LACP is only supported in SwOS atm. I checked with support. Massive bummer.Is LACP supported with VLANs on CRS317-1G-16S+RM using the new bridge method?
If so how?
Essentially, trunking VLANs over LACP (hardware based) and then also using the same VLANs for tagging or native on the various SFP+ ports?
Both features are supported on CRS317-1G-16S+ :Damn.
Haven't tried SW/OS, but does this support VLANs?
We basically are after 10Gb switch, with good VLAN support, LACP, RSTP. Nothing layer 3.
No Q-in-Q support though in SwOS.Both features are supported on CRS317-1G-16S+ :Damn.
https://wiki.mikrotik.com/wiki/SwOS/CRS317
Under-promise, over-deliver. Wirespeed L3 routing is "some feature", alright!:There will be wirespeed L2 switching on the CRS317.
There will be no ASIC features, wirespeed L3 routing or MPLS switching. Some features may be added via software updates.
wowUnder-promise, over-deliver. Wirespeed L3 routing is "some feature", alright!:There will be wirespeed L2 switching on the CRS317.
https://wiki.mikrotik.com/wiki/Manual:C ... Offloading
