grigoryx
Feature Request: TACACS/TACACS+
Tue Dec 20, 2016 9:05 am
I would be cool if TACACS/TACACS+ would be supported in next ROS version. Is it planned in ROSv6/ROSv7 or not?
janisk
Re: Feature Request: TACACS/TACACS+
Tue Dec 20, 2016 11:15 am
Isn't that a protocol that RADIUS was/is based on?
paoloaga
Tue Dec 20, 2016 12:46 pm
Why don't you just use RADIUS? I wrote a TACACS server for dial-up connections early in 1996 ... switched to RADIUS around year 2000.
agfjpcs
Fri Dec 23, 2016 7:25 am
Wow.... Bit surprised to see a MikroTik employee asking this sort of question
Snip from http://www.tacacs.net/docs/TACACS_Advantages.pdf
The primary functional difference between RADIUS and
TACACS+ is that TACACS+ separates out the Authorization
functionality, where RADIUS combines both Authentication and
Authorization. Though this may seem like a small detail, it makes
a world of difference when implementing administrator AAA in a
network environment.
RADIUS doesn’t log the
commands used by the
administrator. It will only log
the start, stop, and interim
records of that session. This
means that if there are two or
more administrators logged at
any one time, there is no way
of telling which administrator
entered which commands.
RADIUS can include privilege information in the authentication reply; however, it can only provide the
privilege level, which means different things to different vendors. Because there is no standard between
vendor implementations of RADIUS authorization, each vendor’s attributes often conflict, resulting in
inconsistent results. Even if this information were consistent, the administrator would still need to manage the
privilege level for commands on each device. This will quickly become unmanageable.
RADIUS doesn’t log the commands used by the administrator. It will only log the start, stop, and interim
records of that session. This means that if there are two or more administrators logged at any one time, there
is no way to tell from the RADIUS logs which administrator entered which commands.
TACACS+ is far better than RADIUS if you need more than a simple 'Oh yep, that user account is allowed'
barkas
Fri Dec 23, 2016 10:51 am
Tacacs is the proper solution for network device user management.
I would very much like to have that, too.
janisk
Wed Dec 28, 2016 10:01 am
while your whole answer is based on TACACS+ that is later creation than RADIUS. However, DIAMETER is even newer and addresses many drawbacks of RADIUS and is compatible with the RADIUS.
and on the off-note, I am sure you know what sarcasm is.
TheIPGuy
Mon Apr 24, 2017 11:53 pm
RADIUS has it's place, however, I think we can agree from a network administration perspective TACACS+ does have some nice features. One such feature is extremely granular centralized command authorization based on user permissions assigned by the server. Also, Tacacs was ported to linux, all though a bit roughly, via tac_plus. RADIUS user authentication for management purposes is nice if you want a read only or read/write access only, but is lacking when more granular control is required. Let's please keep a constructive dialog going on this issue as RADIUS and TACACS were intended for different purposes fundamentally. Sarcasm from a Mikrotik employee to mock a contributor on a valid point is childish.
+1 for TACACS support
bruins0437
Thu Jul 20, 2017 3:05 pm
+1 for TACACS/TACACS+ support
tricksol
Mon Jul 31, 2017 3:11 am
eric101
Mon Aug 07, 2017 3:54 pm
+1 for tacacs+ support, I think this would make a lot of people happy.
gidoos
Wed Aug 23, 2017 10:57 am
+1 for this. Will defnitely be a big plus point for big networks.
YourWordIsTruth
Mon Sep 18, 2017 5:48 pm
+1 for TACACS+ support, many companies don't consider your product, if you will, "Enterprise Grade", without TACACS+ support and frankly with security being the #1 issue in the enterprise TACACS+ is needed to not only secure a multitude of devices in complex networks, but also to provide auditing trails of admin usage when those pesky auditors come around yearly/quarterly :-)
branto
Sun Oct 22, 2017 1:06 am
+1 for this this request. TACACS+ also encrypts the communications channel between client and server; RADIUS does not.
idlemind
Mon Oct 23, 2017 1:38 am
I wonder if IPSec could be used to secure the RADIUS traffic between endpoints and an auth server. This would only cover the encryption side of the discussion not the feature differences.
tonny
Fri May 25, 2018 12:43 pm
mlenhart
Fri May 25, 2018 1:26 pm
networkfudge
Trainer
Trainer
Fri May 25, 2018 11:50 pm
+ 1
MTCNA MTCWE MTCRE MTCINE MTCTCE UWBS UWBA
sep
Fri Aug 31, 2018 3:25 pm
IPANetEngineer
Trainer
Trainer
Fri Aug 31, 2018 3:30 pm
I would like to see TACACS+ support as well. Being able to restrict the commands that a user can execute is incredibly important.
Especially with all of the attacks against MikroTik devices - it provides another layer of protection in addition to the firewall if a lower level user account is compromised.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Dude2048
Fri Aug 31, 2018 3:56 pm
+1 Tacacs
TheCiscoGuy
Mon Sep 03, 2018 7:42 pm
At least disable the local users if AAA is configured and reachable. TACACS would be nice, but the current radius is functional, just doesnt disable local accounts.
Network Solutions Engineer and Trainer
Cisco | Juniper | Mikrotik | Ubiquiti
maznu
Mon Sep 03, 2018 8:31 pm
Why not just set your one local admin account to have an impossible IP address restriction, and then you've still got console-level access should your connectivity to TACACS go fubar...?
Marek
caiot5
Tue Sep 18, 2018 4:51 pm
+1 for TACACS+ support.
alessio79
Tue Sep 18, 2018 6:06 pm
+1 for TACACS+
mAineAc
Mon Oct 08, 2018 9:32 pm
+1 on tacacs+ support.
Faceless
Fri Nov 02, 2018 1:27 pm
+1 for TACACS+
nz_monkey
Mon Nov 05, 2018 12:59 pm
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
around
Fri Jan 11, 2019 7:54 pm
around
Fri Jan 11, 2019 7:59 pm
leoeletronics
Mon Jan 14, 2019 5:00 pm
+1 TACACS
Kampfwurst
Thu Jan 17, 2019 12:54 pm
+1 TACACS
Cha0s
Forum Veteran
Forum Veteran
Sat Mar 02, 2019 8:49 pm
Jotne
Sun Mar 03, 2019 10:44 am
As long as Router OS does not log all commands run by who, I would also ask for TACACS support.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
nimbo78
Sat Mar 09, 2019 3:50 pm
As long as Router OS does not log all commands run by who I would also ask for TACACS support.
that's why +1 for TACACS+
TaBo
Tue Apr 02, 2019 8:11 am
+1 for TACACS+
mutinsa
Sun Apr 07, 2019 10:32 pm
+1.
Sergey Mutin
Certified Mikrotik Consultant
MikroTik: MTCNA, MTCRE, MTCIPv6E, MTCTCE, MTCUME, MTCINE, MTCWE | Cisco: CCNA R&S | Juniper: JNCIA-Junos | Zabbix: ZCU | Asterisk: dCAA | IPv6 Forum Certified Network Engineer (Silver) | HE.net IPv6: Sage
Users browsing this forum: No registered users and 14 guests
