strods
v6.39rc [release candidate] is released
Mon Jan 02, 2017 4:51 pm
What's new in 6.39rc4 (2016-Dec-30 07:16):
!) ppp - completely rewritten internal fragmentation algorithm (when MRRU is used), optimized for multicore;
*) capsman - added CAP discovery interface list support;
*) ethernet - renamed "rx-lose" to "rx-loss" in ethernet statistics;
*) health - report fan speed for RB800 and RB1100 when 3-pin fan is being used;
*) led - show warning on print when "modem-signal-threshold" is not available;
*) lte - added error handling for remote AT execute;
*) wAP ac - improved 2.4GHz wireless performance;
*) wireless - added "station-roaming" setting (cli only);
*) wireless - show comment on "security-profile" if it is set (cli only);
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
lekozs
Re: v6.39rc [release candidate] is released
Mon Jan 02, 2017 5:21 pm
Would you be so kind and shed some light on this line in the changelog:
uldis
Mon Jan 02, 2017 7:25 pm
Here is information about this station-roaming:
http://wiki.mikrotik.com/wiki/Manual:In ... on_Roaming
Now you can disable station-roaming if you do not want it or, for example, if you have P2P using 802.11 protocol were you don't have another AP to connect to.
nz_monkey
Tue Jan 03, 2017 11:12 am
Hi Guys,
Can I please have more info on *) wAP ac - improved 2.4GHz wireless performance;
e.g. under what situations is performance "improved" ?
I ask as we have had issues with the wAP AC's 2.4Ghz radios and performance to Samsung android devices, as well as WPA group-key issues..
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
plisken
Tue Jan 03, 2017 3:32 pm
When I installed the firmware 6.39 rc4 was my ovpn connection interrupted.
After back downgrade to 6:36 bugfix everything was ok.
This somehow seems like a bug
hknet
Tue Jan 03, 2017 10:25 pm
"ppp optimized for multicore" - on all platforms?
plisken
Tue Jan 03, 2017 10:37 pm
I forgot to mention that the firmware proved a rb3011.
Mikrotik will have to resolve this isseu. This is a bug.
coylh
Wed Jan 04, 2017 2:15 am
I hope this one: http://forum.mikrotik.com/viewtopic.php?f=7&t=115180
I'll try the RC and see if it helps.
Hi Guys,
timtasse
Wed Jan 04, 2017 11:56 pm
are there plans to add NAT for IPv6 ?
at home i have dynamic ipv6 from the provider and a static ipv6 net with no flatrate at tunnelprovider.
the simplest solution is to NAT unknown networks und known networks without NAT for static firewall config.
sakirozkan
Thu Jan 05, 2017 10:30 am
Station Roaming feature is available only for 802.11 wireless protocol. when we use background scan on nv2 and use station roaming. is there any work for nv2.
deathmagicmedia
Thu Jan 05, 2017 11:46 am
Please add HTTP POST and HTTP GET to the Dude's notification feature.
This will allow integration into 3rd-party applications such as Telegram (https://core.telegram.org/bots/api).
Quite important to allow toggling between secure and non-secure connections.
MikroTik Certified Network Associate (MTCNA)
Ubiquiti Broadband Wireless Specialist (UBWS)
Ubiquiti Broadband Wireless Admin (UBWAv2)
normis
Thu Jan 05, 2017 11:50 am
It is clarified in the manual: http://wiki.mikrotik.com/wiki/Manual:In ... on_Roaming
strods
Thu Jan 05, 2017 4:14 pm
Version 6.39rc7 has been released.
Changes since previous rc:
*) bridge - fixed MAC address learning from switch master-port;
*) capsman - support for communicating frame priority between CAP and CAPsMAN;
*) dhcpv6-client - fixed dhcpv6 rebind on startup;
*) dns - fixed typo in regexp error message;
*) dude - (changes discussed here: http://forum.mikrotik.com/viewtopic.php?f=21&t=116471);
*) firewall - nat action "netmap" now requires to-addresses to be specified;
*) ike2 - allow empty selectors to reach policy handler;
*) ike2 - fixed error packet from initiator on responder reply;
*) ike2 - fixed ph1 initial-contact rare desync;
*) ike2 - fixed traffic selector prefix calculation;
*) ike2 - show peer identity of connected peers;
*) ike2 - update also local port when peer changes port;
*) ipsec - fixed flush speed and SAs on startup;
*) ipsec - fixed peer port export;
*) ipsec - port is used only for initiators;
*) leds - added lte modem access technology trigger;
*) log - added warning when winbox/dude sessions was denied;
*) log - improved firewall log messages when NAT has changed only connection ports;
*) mmips - improved general stability;
*) ovpn - fixed address acquisition when ovpn-in interface becomes slave;
*) proxy - fixed "max-cache-object-size" export;
*) proxy - speed-up almost empty disk cache clean-up;
*) rb1100ahx2 - fixed random counter resets for ether12,13;
*) ssh - fixed high memory consumption when transferring file over ssh tunnel;
*) wireless - fixed issue when wireless interfaces might not show up in CAP mode;
*) wireless - fixed occasional crash on interface disabling;
Cha0s
Thu Jan 05, 2017 4:30 pm
I've requested this 2 years ago but the NAT Nazis say "it's wrong". Because some IPv6/end2end connectivity ideologists said so.
Those 'No-NAT-on-IPv6' people are becoming worse than Apple fanboys :P
http://forum.mikrotik.com/viewtopic.php?f=19&t=90564
And a more comprehensive post about NAT usefulness in IPv6 by ZeroByte http://forum.mikrotik.com/viewtopic.php?f=1&t=110925
strods
Thu Jan 05, 2017 4:52 pm
Please do not hijack versoin topic with questions which are not related to release itself.
timtasse, deathmagicmedia - You should create new topic with your request and/or write to support.
Kalpar
Thu Jan 05, 2017 6:19 pm
Hello
Can you clarify if this adds any new features for PPP / MRRU? Does this mean that you have added (or will add) PPP Fragmentation reordering / buffering to fix the case where MRRU fragments come in our of order?
--Greg
benoga
Fri Jan 06, 2017 9:24 am
LED off is only for "Currently "RB cAP 2n" and "RB cAP 2nD" ?
I've got the Error on my HAP AC (mipsbe):
[benoga@HAP_AC] > /system leds setting set all-leds-off=immediate
missing values (5)
When HAP AC not support this, then please disable the Setting in CLI and Winbox :)
greez
strods
Fri Jan 06, 2017 10:41 am
Kalpar - Yes, that is exactly what was done! MRRU works in same way as it did before, but it is now adjusted/updated to multi core age
JHV
Issue with DHCPv6 partially solved
Sat Jan 07, 2017 1:22 pm
Rebinding or renewing? And only on startup?
However, the new version solves my problem at least partially.
As I have already described in this thread, DHCPv6 is broken for me since v6.34, If the connection is lost, renewing and rebinding takes 20 minutes. Since v6.39rc this time has been reduced to 10 minutes.
Before v6.34:
PPPoE connected ---> status: bound
After v6.34:
PPPoE connected ---> status: rebinding ---> 10 minutes waiting ---> status: renewing ---> 10 Minutes waiting ---> status: bound
After v6.39rc:
PPPoE connected ---> status: rebinding ---> 10 minutes waiting --- status: bound
msatter
Re: Issue with DHCPv6 partially solved
Sat Jan 07, 2017 11:34 pm
Before v6.34:
After v6.34:
After v6.39rc:
http://forum.mikrotik.com/viewtopic.php ... 16#p575316
I used this command when I scheduled a PPPoE reconnect: ipv6 dhcp-client release 0;
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47.1 / Winbox 3.24 / MikroTik APP 1.3.14
kujo
Sat Jan 07, 2017 11:51 pm
Can we use L2TP + MRRU over one WAN link of PPPoE provider 1492 MTU/MRU?
Sent from my iPhone using Tapatalk
qiet72
Sun Jan 08, 2017 2:59 pm
Hi
I have just tried 6.39rc7 on a RB2011UiAS-2HnD-IN. A lot of client equipment seem to connect fine with or without encryption. Unfortunately, an old Intel 2200BG client cannot connect to it no matter if I use WPA2 encryption on it or not. To confirm that the Intel 2200BG card worked, I tested it up against a Broadcom based access point and it connected fine with or without encryption.
I have debug logs turned on. The logs say "disconnected, extensive data loss" when I try with wpa2 encryption. If I use no encryption, the logs say "disconnected, received disassoc: unspecified (1)".
Qiet72
JHV
Sun Jan 08, 2017 4:16 pm
Before v6.34:
After v6.34:
After v6.39rc:
Thank you for your advice. It works indeed, but needs a delay between enabling PPPoE and dhcp-client release.
Therefore I have altered my script as follows:
/interface pppoe-client disable [find name="pppoe-out1"];
/ipv6 dhcp-client disable [find interface="pppoe-out1"];
/interface pppoe-client enable [find name="pppoe-out1"];
/ipv6 dhcp-client enable [find interface="pppoe-out1"];
This script lacks elegance, but at least it works.
AlexHam
Mon Jan 09, 2017 12:58 am
Doesn't work VLANS between two devices on this firmware.
First device RB1100AHx2 (ppc)
Second device RB750UPr2 (mipsbe).
I installed v6.39rc on both devices.
on both devices I make configure:
RB750UPr2:
add name=LAN
add name=TRUNC
/interface vlan
add interface=TRUNC name=vlan4 vlan-id=4
add bridge=TRUNC interface=ether1
add bridge=LAN interface=ether2
add bridge=LAN interface=vlan4
add address=192.168.77.1/24 interface=LAN network=192.168.77.0
RB1100AHx2:
add name=LAN
add name=TRUNC
/interface vlan
add address=192.168.77.2/24 interface=LAN network=192.168.77.0
Connect Routers by eth1 ports.
Connect laptop to RB750UPr2 to eht2 port.
I can connect to RB750UPr2. But cannot connect to RB1100AHx2.
This configuration successfully work on 6.37 firmware.
This bug only between RB750UPr2 and RB1100AHx2.
If I use, example, RB750UPr2 and RB Metal 2SHPn, this configuration is work.
irico
Mon Jan 09, 2017 7:10 pm
On a new CHR machine (v6.39rc7 vhdx image), I have an error creating new IPSec Peer from Winbox (v3.7):
- Could not add new IPsec peer - Property not supported (6)
The problem is in the NAT-T property. If winbox is set to "false" the error occurs. It would be good to hide this property for IKE2.
pe1chl
Mon Jan 09, 2017 8:30 pm
Please add another release channel between "bugfix" and "current", e.g. named "previous".
This should be set to the previous "current" version whenever the latest "release candidate" is released as "current".
Often just after release, a lot of new bugs get noticed because people now first run the new "current", and there is
no easy way to install the previous and usually more stable "current" version without going all the way back to "bugfix".
Another option would be to add a "custom" channel with an input field where a certain base version, e.g. 6.37, can be
entered or selected from a reasonable list, and the channel will track the latest minor version within that.
docmarius
Mon Jan 09, 2017 9:07 pm
Now this is a good idea.
I had to downgrade to 6.36.4 instead of 6.37.3, since manual downgrade and reinstalling additional packages is not quite trivial and fast on a running system.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
pe1chl
Mon Jan 09, 2017 10:06 pm
And on the new-style "only 16MB flash" models it is even more difficult...
msatter
Tue Jan 10, 2017 3:56 pm
I checked how long it took to reconnect. I disconnected my PPPoE and stopped the DHCPv6 Client. Started my DHCPv6 Client and then again the PPPoE and the client got bound within two seconds. I have added a while ago the Prefix hint in the DHCPv6 and you can end it with "::" with /subnet then check what the reconnect time is.
Running:
pe1chl
Tue Jan 10, 2017 6:03 pm
XS4ALL? It is a bug at their side.
You can work around it by setting up a tool->netwatch of some internet IP (e.g. the nexthop you get for the default route)
and putting this in the "UP script":
/ipv6 dhcp-client release [find status=bound]
This makes the client release and then request the IPv6 prefix when the interface comes up (within a minute).
Dude2048
Tue Jan 10, 2017 11:16 pm
Maybe I overlooked it but what do you mean with : capsman - added CAP discovery interface list support? (Release notes)
mariuslazar
Wed Jan 11, 2017 10:18 am
Broken:
DHCP over EOIP (no encription)
Some devices don't get IP's even directly connected - Panasonic VOIP phone. Works fine in 3.37.3
pe1chl
Wed Jan 11, 2017 10:50 am
The packet sniffer in WebFig always shows status "unknown" in the top left instead of "running" or "stopped".
uldis
Wed Jan 11, 2017 12:32 pm
Broken:
Please make support output file and send it to support@mikrotik.com so we could see your configuration and reproduce this problem
msatter
Wed Jan 11, 2017 9:12 pm
If you have more information we could ask Mike to look i to it if it can be changed on their side to make it more compatible besides the AVM routers.
Running:
pe1chl
Wed Jan 11, 2017 9:17 pm
Mike says it cannot be changed, and he thinks it is a bug in the router that it keeps the lease when the PPPoE goes down and does
not request a new release immediately when it comes back up. But this is only "common practice", it is not written in the standard.
My workaround with netwatch works, but I would prefer when MikroTik adds a specific "script run when interface comes up" feature.
msatter
Wed Jan 11, 2017 10:39 pm
Thanks and I have now added the Netwatch and I found that only this one worked for me: /ipv6 dhcp-client release [find status=rebinding...]
When I down and up the PPPoE the "bound" will change directly in "rebinding..." and I have set a 5 second check.
This also works: /ipv6 dhcp-client release [find status!=bound]
Running:
pe1chl
Thu Jan 12, 2017 12:31 am
It may be that the required command is different for 6.39rc because changes were made to try to fix it.
Maybe it is better to select on some other value as there usually will be only one entry and that is the one to be released.
msatter
Thu Jan 12, 2017 1:10 am
So the behaviour (6.39RC7) is now to renew and if necessary to rebind and that is a I think the normal way. Then as an exception on this there could be a option to choose for release when renew does not fetch the address. Or to renew-->rebind-->release-->renew-->rebind-->release-->etc. as default fetch.
I did see the communication with Mike on this and many thanks for that!
Running:
pe1chl
Thu Jan 12, 2017 10:33 am
I now use this command:
/ipv6 dhcp-client release [find interface=pppoe-xs4all]
it now is independent of the state. Of course the interface name has to be adjusted to the locally used name.
(default is pppoe-out1)
efka
Thu Jan 12, 2017 10:41 am
hAP ac .6.39rc7. Winbox 3.7.
Couldn't change LED settings:
<Coldn't change LED Settings - action failed (5)>
strods
Fri Jan 13, 2017 1:26 pm
6.39rc12 has been released.
Changes since previous version:
!) quickset - configuration changes are now applied only on "OK" and "Apply" (not on mode change);
!) winbox - minimal required version is v3.8 (because of new quickset);
*) bridge - disallow manual removal of dynamic bridge ports;
*) bridge - fixed access loss to device through bridge if master port had a loop (introduced in v6.38);
*) bridge - fixed rare conflicts between hardware and software STP (introduced in v6.38);
*) certificate - added year cap (invalid-after date will not exceed year 2039);
*) certificate - allow CRL address to be specified as DNS name;
*) certificate - fixed fail on import from CAPs when both key and name already exist;
*) dhcpv6-server - fixed server removal crash if static binding was present;
*) fan - improved RPM monitor on CCR1009;
*) firewall - fixed import of exported configuration that had updated "limit" setting;
*) graphs - fixed graph disappearance after power outage;
*) ike1 - fixed ph1 rekey in setups with mode-cfg;
*) ike2 - auto-negotiate split nets;
*) ike2 - default to tunnel mode in setups without policy;
*) ike2 - fixed initiator TS updating;
*) ike2 - fixed policy setting for /0 selector with different address families;
*) ike2 - fixed split policy active flag;
*) ike2 - fixed xauth add check;
*) ike2 - include identity in peer address info;
*) ike2 - log empty TS payload;
*) ike2 - minor logging update;
*) ike2 - traffic selector improvements;
*) ike2 - use first split net for empty TS;
*) ike2 - use standard retransmission timers for DPD;
*) ike2 - xauth like auth method with user support;
*) ipsec - added ability to kill particular remote-peer;
*) ipv6 - added warning about having interface MTU less than minimal IPv6 packet fragment (1280);
*) leds - added LTE modem access technology trigger;
*) leds - do not update single LED state when it is not changed;
*) license - fixed demo license expiration after installation on x86;
*) logs - work on false CPU/RAM overclocked alarms;
*) mpls - fixed crash on active tunnel loss in MPLS TE setups;
*) ppp - fixed rare kernel failure on PPP client connection;
*) pppoe - make default keepalive 10s for PPPoE clients;
*) profile - classify ethernet driver activity properly in ARM architecture;
*) quickset - various small changes;
*) rb751u - fixed ethernet LEDs (broken since 6.38rc16);
*) tr069-client - added connection request authentication;
*) tr069-client - added parameters for DNS client management support;
*) tr069-client - generate random connection request target path;
*) webfig - allow shorten bytes to k,M,G in firewall "connection-bytes" and "connection-rates";
*) webfig - show properly large BGP AS numbers;
*) winbox - added "add-relay-info" and "relay-info-remote-id" to DHCP relay;
*) winbox - added "group-key-update" to CAPsMAN security settings;
*) winbox - added "make-static" to IPv6 DHCP server bindings;
*) winbox - added "prefix-pool" to DHCPv6 server binding;
*) winbox - added IPsec to radius services;
*) winbox - added upstream flag to IGMP proxy interfaces;
*) winbox - allow shorten bytes to k,M,G in bridge firewall just like in "/ip firewall";
*) winbox - allow shorten bytes to k,M,G in firewall "connection-bytes" and "connection-rates";
*) winbox - allow to change user password to empty one;
*) winbox - allow to specify "connection-bytes" & "connection-rate" for any protocol in "/ip firewall" rules;
*) winbox - allow to specify "sip-timeout" under ip firewall service-ports;
*) winbox - allow to specify certificate type when exporting it;
*) winbox - allow to specify interfaces that CAPsMAN can use for management;
*) winbox - do not create empty rates.vht-basic/supported-mcs if not specified in CAPsMAN;
*) winbox - do not create time field when copying CAPsMAN access list entry;
*) winbox - do not try to disable dynamic items from firewall tables;
*) winbox - fixed typo in "/system resources pci" list;
*) winbox - hide "nat-traversal" setting in IPsec peer if IKEv2 is selected;
*) winbox - removed "sfp-rate-select" setting from ethernet interface;
*) winbox - show dynamic IPv6 pools properly;
*) winbox - show errors on IPv6 addresses ;
*) winbox - specify metric for "/ip dns cache-used" setting;
*) winbox - updated fan management menu;
*) wireless - added "station-roaming" setting;
*) wireless - fixed rare wireless ac interface lockup;
*) wireless - show comment on "security-profile" if it is set;
Valexus
Fri Jan 13, 2017 1:56 pm
Please tell me that this is the problem on the "hap AC" when the wireless interface is running but not visible or flapping?
amokkatmt
Fri Jan 13, 2017 3:45 pm
Can anyone confirm this viewtopic.php?f=21&t=116821&p=577546 ?
Chupaka
Fri Jan 13, 2017 4:16 pm
yep, WinBox 3.8 doesn't allow to edit src/dst-port even on previous versions of ROS
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
nz_monkey
Sat Jan 14, 2017 12:27 am
Wow that's a massive changelog for a RC.
Some awesome stuff in there.
cheeze
Sat Jan 14, 2017 1:18 am
Can we ask what this entails?
liamalxd
Sat Jan 14, 2017 8:47 pm
woo :) very happy about this.
LynxChaus
Mon Jan 16, 2017 5:35 pm
wireless still broken. my old phone Lenovo A660 can't connect to AP after 6.37 migration anymore.
notToNew
Mon Jan 16, 2017 5:44 pm
Stay at 6.36.4 or disable encryption in newer releases as workaround ;-)
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
strods
Tue Jan 17, 2017 9:15 am
Version 6.39rc13 has been released,
*) capsman - fixed SGI (Short Guard Interval) support;
*) firewall - added "fasttrack" dummy rule to "/ip firewall raw" table;
*) ike2 - also kill IKEv2 connections on proposal change;
*) ike2 - fixed ph2 state when sending notify;
*) ike2 - fixed proposal change crash;
*) ike2 - fixed responder TS updating on wild match;
*) ipsec - keep policy in kernel even with bad proposal;
*) ipsec - kill ph2 on policy removal;
*) lte - added support for Vodafone R216 (Huawei);
*) switch - fixed crash when trying to configure second master port on the same chipset (RB3011, RB2011, CCR1009-8G-1S+);
nz_monkey
Tue Jan 17, 2017 9:32 am
Nice work guys.
It is looking like 6.39 is going to be another massive release.
diegotormes
Tue Jan 17, 2017 5:47 pm
http://forum.mikrotik.com/viewtopic.php?f=14&t=116270
notToNew
Wed Jan 18, 2017 11:46 am
Not good that you stopped supporting 6.36.x and replaced it with 6.37.4!! Not at all!
antonsb
Wed Jan 18, 2017 4:28 pm
Hi
Qiet72
About Intel 2200bg
Last Windows version that supports drivers for this card is Windows XP, last time drivers got update was on 12/10/2009 this card is already legacy
This wireless card had updates fixing various problems problems with authentication. Please update to latest driver version, if that does not help -
Please change your wireless card or stick to older RouterOS releases - WPA2 support workaround for this card won't be added!
Edit:
Should be fixed from 6.39rc33
notToNew
Wed Jan 18, 2017 6:10 pm
Hi
About Intel 2200bg [..] WPA2 support workaround for this card won't be added!
Last supported version for Intel 2200bg 6.36.4
A Client has >50 IP-Cams which does not work with newer ROS, so they are all stuck at 6.36.4?
So why don't you decide to offer the old wireless-cm2 package for newer ROS just for compatibily to such legacy devices?
This will be a deal-breaker for a lot of my customers, who use Mikrotik-Devices on a Campsite! A lot of Caravans and guests
have build-in devices like this, and it is just not possible to explain all those users that their wifi is too old.
Currently are 3007 Clients connected to >100 Mikrotiks, and 6 of them don't work with wireless-rep and newer. I just tested
other hardware of other several other companies, all of them worked.
So I try to suggest 2 possible solutions:
# continou to support 6.36.4 as "old-bugfix".
# offer optional wireless-cm2 package for ROS > 6.39
macgaiver
Wed Jan 18, 2017 6:25 pm
I'm sorry, but what is wrong with that? Very good and recent version. I have some applications that are restricted to v5.26 for similar reasons. Or all the mipsle devices that are stuck @ v6.32.4
It is impossible to support all the legacy stuff all the time - at some time you have to move on.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
notToNew
Wed Jan 18, 2017 6:43 pm
You might be right, but other vendors do support this devices. If they stop the support for 6.36.4 now,
it will be old within a year at lest, exactly the timeframe i neew to switch to other hardware.
The only thing I'd like to hear is if MT plans to give some "enhanced" or "longterm" support to 6.36.4 or
if I do have to make plans about exchanging my AP-Devices.
pe1chl
Wed Jan 18, 2017 7:01 pm
It should be no problem to keep your access points at 6.36.4 when you want to support old clients,
after all most of the new functionality and important fixes e.g. for security will only affect the router
functions, and are not important in access points operating in bridge mode.
strods
Fri Jan 20, 2017 2:11 pm
Version 6.39rc15 has been released.
*) bridge - do not add dynamic hardware STP ports if master port isn't capable of hardware STP;
*) dhcpv4-server - do some lease checks only on enabled object;
*) firewall - do not show ipv4 fastpath as active if route cache is disabled;
*) ike1 - fixed responder xauth trailing null;
*) ike2 - always limit empty remote selector;
*) ike2 - fixed state when sending delete packet;
*) ipsec - added last-seen parameter to active connection list;
*) leds - fixed defaults for RBSXT5HacD2nr2;
*) lte - added initial support for Quectel ec25;
*) lte - fixed IPv6 address prefix on interface
*) lte - fixed older standard CEREG parsing;
*) lte - fixed support for Huawei R216;
*) traceroute - small fix;
Zorro
Long time Member
Long time Member
Sun Jan 22, 2017 4:50 pm
im afraid that not true.
arches(either that was mips, arm, ppc or x86 branch)that marked "deprecated" ans phased-out from linux toolchain(and kernel thus not be updated as much or at all)aren't supported by, regardless vendor. and few one that still backporting thing trying to keep alive(cicsco/linksys, juniper, etc)doing it not for long.
heck, some vendors aren't properly support(with mission/time-citical security fixes atleast) their Current devices, let alone Legacy. google for example how frequent updates of say alpha or ubiquity or belkin, flextronix or oher ODM or OEM are done.
so nope despite "being pathetic" or "spend too much on PR"(esp compared with "engineering") other vendors usually not bring.
pe1chl
Sun Jan 22, 2017 11:58 pm
After updating to v6.39rc15 I noticed something that I have seen before and disregarded as a coincidence:
By doing the update using "check updates" on the WebGUI I downloaded 6.39rc15 while running 6.39rc7 and
after the reboot the PPPoE interface to my ISP refuses to come up. Disabling and enabling it does not fix it.
Doing another reboot fixes it: PPPoE interface comes up without problem.
As I often have done a second reboot after update for other reasons it never really occurred to me that
this is happening, but I did notice it before.
There may be an issue here, and it could be troublesome as I now also have deployed two routers that I
maintain remotely over the internet and that have PPPoE as well. I would have to go to the site to update them.
pe1chl
Mon Jan 23, 2017 11:36 am
After update to 6.39rc15 I noticed my IPv6 was down. The router did not announce itself on the LAN and WiFi networks
anymore. I went back to 6.38.1 and that fixed it. The PPPoE problem mentioned above did not occur during this downgrade.
strods
Mon Jan 23, 2017 5:26 pm
Version 6.39rc17 has been released.
*) capsman - added save-channel option to speed up frequency selection on CAPsMAN restart;
*) capsman - added support for static virtual interfaces on CAP;
*) hotspot - fixed rare kernel crash on multicore systems;
*) ike2 - default to /32 peer address mask;
*) ike2 - fixed EAP message length;
*) ike2 - update calling_station_id radius attribute;
*) ike2 - update radius attributes;
*) ipsec - better responder flag calculator for console;
*) ipsec - hide sa-addrs for transport policies;
*) wireless - apply broadcast bit to DHCP requests when using station-pseudobridge mode;
*) wireless - update Thailand country frequency settings;
ditonet
Forum Veteran
Forum Veteran
Tue Jan 24, 2017 12:12 am
@strods
Any chance to fix VLAN and bridge problem described here:
http://forum.mikrotik.com/viewtopic.php ... 37#p578951
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
lexbrugman
Tue Jan 24, 2017 1:02 am
I am affected by the following problem since 6.38: http://forum.mikrotik.com/viewtopic.php ... 44#p567223 this is affecting two devices on separate networks for road warrior l2tp/ipsec vpn with psk and radius auth. Version 6.37 and lower work fine with the same configuration.
The post I'm referring to mentions this would've been fixed in one of the 6.38 rc's, but both the 6.38 final and 6.39 rc are still affected.
himvas
Tue Jan 24, 2017 4:52 pm
About
*) wap-ac - fixed performance problems with 2.4GHz wireless (additional reboot after upgrade required);
I have same issue with wAP (RBwAP2nD) - in the same place there are D-Link DAP-2310 and just buyed wAP. I connect from the same device and run iperf. D-Link gives about double speed above wAP. Of course there are only one AP (D-Link or wAP) switched on. And D-Link TX power and sensitivity lower, than wAP. I fighting second day , try all possible modes for wAP - no result.
Maybe there are similar solution for wAP as for wAP AC?
uldis
Tue Jan 24, 2017 5:59 pm
About
Regular wAP doesn't have such problem. Please contact support@mikrotik.com with detailed explanation on your test, we will try to assist in your problem with wAP board.
facubertran
Tue Jan 24, 2017 10:37 pm
Hi, i need a function similar to "show running config", to be able show the config in CLI. It's possible?
andriys
Tue Jan 24, 2017 11:13 pm
That's exactly what /export does.
notToNew
Wed Jan 25, 2017 1:16 pm
I'm afraid, thats not the full truth aswell. It doesn't seem that MT did change the kernel in 6.37.x, as they planned to change the kernel in 7.x. If you know more, just tell me.
Anyway, I need a device where most of my customer-devices work, so i need the information if ROS 6.36.4 will still get an update if they find a security-whole in any of the other components.
It seems that they stopped this kind of support, and that's why I have to consider a change of the Hardware. I currently test ruckus (which works), FortiAP (which Works) and a cheap netgear, which works with those old devices aswell.
strods
Wed Jan 25, 2017 1:41 pm
Version 6.39rc19 has been released.
*) bridge - fixed STP/RSTP packet receive on all types of bridge ports;
*) ike2 - fixed ISA handler object removal on SA delete;
*) ippool - return proper error message when trying to create duplicate name;
*) leds - changed error message on unsupported board;
*) lte - fixed network mode selection for me909u, mu609;
*) lte - fixed user-command;
*) tr069-client - added DHCP server support;
*) tr069-client - added support for managing "/system/identity/" value;
*) tr069-client - added support for memory and CPU load parameters;
facubertran
Wed Jan 25, 2017 5:43 pm
Yes, but for example, ssh admin@192.168.88.1 show-config | Grep ether1 is not possible with export, or yes?
andriys
Wed Jan 25, 2017 5:59 pm
This:
ssh admin@192.168.88.1 "/export"
works like a charm for me. Have you even bothered to try it yourself before asking?
mrz
Wed Jan 25, 2017 6:04 pm
Probably he asked built in grep. RouterOS does not have that, but you can still do on linux
ssh admin@x.x.x.x "/export" | grep ether1
facubertran
Wed Jan 25, 2017 6:17 pm
This:
works like a charm for me. Have even bothered to try it yourself before asking?
I apologize, it's true, when I tried it a while back I had not worked but then I did not try again. Thank you.
asik
Thu Jan 26, 2017 12:27 pm
On device QRT AC, winbox 3.10, ROS 6.38 - 6.38.1 and 6.39rc19 release i don't see settings for HT MCS on wlan interface.
strods
Thu Jan 26, 2017 1:17 pm
asik - Thank you for your report. We will try to fix this as soon as possible.
baragoon
Thu Jan 26, 2017 1:59 pm
same on hap ac lite with 6.39rc19
strods
Fri Jan 27, 2017 12:33 pm
Version 6.39rc20 has been released.
!) filesystem - fixed rare situation when filesystem went into read-only mode (some configuration might have gotten lost on reboot);
!) filesystem - fixed rare situation when filesystem failed to read all configuration on startup;
*) rb3011 - fixed noise from buzzer after silent boot;
*) tr069-client - added basic stats parameters for some interface types;
*) usb - added missing USB ethernet drivers to arm & tile architecture;
*) webfig - added menubar to quickly select between Webfig, Quickset and Terminal;
*) webfig - fixed tab ordering on Google Chrome;
*) webfig - make Terminal window work within Webfig window;
*) winbox - added H flag to "/ip arp" ;
*) winbox - added missing "use-fan2" and "active-fan2" to "/system health";
*) winbox - added save-selected setting under CAPsMAN channels;
*) winbox - added static-virtual to wireless CAP;
*) winbox - do not hide 00:00:00:00:00:00 MAC address in unpublished ARPs;
*) winbox - fixed matching "connection-state=untracked" connections;
*) winbox - fixed misleading error when trying to export certificate;
*) winbox - increased maximal number of Winbox sessions 20->100;
*) winbox - make "power-cycle-after" show correct value;
*) winbox - make "power-cycle-interval" not to depend on "power-cycle-ping-enabled" in PoE settings;
macgaiver
Fri Jan 27, 2017 12:39 pm
Any more detailed explanation on these? Is this the one that caused some configuration loss issues in v6 since the beginning?
strods
Fri Jan 27, 2017 5:10 pm
macgaiver - Yes, that is correct. However this was really rare situation and could cause issues like - unable to write anything in memory (also add and save configuration since it would be lost after reboot).
pe1chl
Sat Jan 28, 2017 6:21 pm
That is great! Even better would be when it lands on the Webfig page after login, maybe only on Quickset when no config has been done before.
NetworkPro
Mon Jan 30, 2017 4:31 pm
6.39rc20 address-list problem
had address list edning in 0/24 changed it to start_ip-dash-end_ip and it broke
the start ip -> dash -> end ip syntax (192.168.1.1-254) does not even work
192.168.1.1-192.168.1.254 - this more explicit one, works
tried to change it again - cant change it anymore to anything
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
lopar
Mon Jan 30, 2017 5:55 pm
your hyper-v client is a dhcp-client receiving the address from the DHCP server?
Yes. Mikrotik - DHCP server. Guest OS on HOST and HOST himself - clients
In addition - when described error is occurred, the affected clients remaining in "offering" state in DHCP server - Leases table with cycled 30s timeout. Seems like synthethic NIC dont answer on offer from DHCP, while real ones work as usual. In ROS 6.37 all work fine with both NIC.
We have observed exactly this with a UniFi UAP-LR and a Soekris Engineering Net4801 board. We have reverted to 6.37.3 to restore correct DHCP behaviour.
Giles.
We also observed exactly this with CRS125 24G-1S-RM and RB2011UiAS-RM routers. 6.38.1 did not fix it. We have reverted to 6.37.3 too. Should it be fixed in future patches?
strods
Tue Jan 31, 2017 9:36 am
NetworkPro - Thank you for report. We will try to fix this as soon as possible.
msatter
Wed Feb 01, 2017 11:42 pm
Today I wanted to readout through a script the IP address present in the "/ip ipsec remote-peers" and I ended up each time with a blank field.
The used code is:
:put [/ip ipsec remote-peers get 0 remote-address];
Then I ran the "print" command in the screen and saw that really the remote-address was present......now when running the script the IP address is show.
Disconnecting and connecting again shows the remote-address in Winbox but not in script until I do a print again.
I don't know if this behaviour is only present in RC20 or also in earlier versions.
Running:
Chupaka
Thu Feb 02, 2017 12:27 am
indices were never meant to be used without 'print'. correct form is the following:
:put [/ip ipsec remote-peers get [find where something=blabla] remote-address];
colanderman
Thu Feb 02, 2017 5:22 am
Also, radio name and regulatory domain disappeared in 6.38, and tx power table is missing for 5 GHz.
strods
Thu Feb 02, 2017 10:09 am
colanderman - Are you sure that Advanced Mode is enabled on wireless interface?
strods
Thu Feb 02, 2017 10:22 am
Version 6.39rc25 has been released.
!) bridge - added "fast-forward" setting and counters (enabled by default only for new bridges) (CLI only);
!) bridge - added support for special and faster case of fastpath called "fast-forward" (available only on bridges with 2 interfaces);
*) address - fixed crash when address is assigned to another bridge port;
*) bridge - fixed rare crash when hardware STP capable interface gets new “master-port” which already is in bridge;
*) bridge - fixed rare situation when port flapping occurs on bridge ports;
*) bridge - minor improvements in performance when "master-port" is bridge port;
*) graphing - fixed graphing crash when high amount of traffic is processed;
*) tr069-client - added architecture name parameter (X_MIKROTIK_ArchName - vendor specific);
*) tr069-client - added ping diagnostics support;
*) tr069-client - increased performance on GetParameterValues;
*) webfig - added menu bar to quickly select between Webfig, Quickset and Terminal;
*) webfig - fixed delays on key press in terminal;
nz_monkey
Thu Feb 02, 2017 10:54 am
fast-forward is an exciting development :)
It would be great if Mikrotik did a wiki article on this feature, explaining the use cases and limitations. That way I wont spam support with a bunch of tickets asking you ;)
macgaiver
Thu Feb 02, 2017 3:05 pm
i did some tests with traffic generator on first board i could find (RB750Gr2) - ~20% increase in max throughput, not bad, not bad at all.
BartoszP
Thu Feb 02, 2017 3:57 pm
I have upgraded RB433 to 6.39rc25.
On the other side there is RB3011@6.37.3
I have defined GRE tunnel on both sides, assigned IPs, but only on RB433 I have specified IPSec Secret.
GRE tunnel is working despite the fact that on RB3011 there is no IPSecret specified.
Deactivated tunnels on one, the other, both sides ... no change.
Am I doing sth wrong or IPSec Secret is ignored ?
Real admins use real keyboards.
pe1chl
Thu Feb 02, 2017 7:21 pm
This is normal when you do not pay special attention to the firewall.
The IPsec config is only a shortcut to IPsec to setup a Peer and Policy for GRE traffic, but as long as the
IPsec association is not established the GRE traffic (or other traffic with similar config) will simply be sent
in the clear. When this makes it through to the other side, apparently you are allowing GRE traffic that is
in the clear through your firewall. Not good, I would say.
So, make sure your firewall entries are correct. Like:
add action=accept chain=input ipsec-policy=in,ipsec protocol=gre
colanderman
Thu Feb 02, 2017 10:09 pm
Yes, Advanced Mode or not, these fields do not appear.
strods
Thu Feb 02, 2017 10:49 pm
colanderman - Before you connect to router go to Tools/Clear Cache on Winbox loader and try to test this afterwards.
BartoszP
Thu Feb 02, 2017 11:38 pm
The IPsec config is only a shortcut to IPsec to setup a Peer and Policy for GRE traffic, but as long as the...
I do not understand. It is obvious that there should be proper firewall set of rules to pass GRE and IPSec connection but what is such firewall rule for? How it deals with password?
I assume that I am assigning IPs to secured connection so I assume that addresses are assigned not to pure GRE but to IPSec over GRE so if there is no matching password pair then the IPSec should not be established = no traffic from side to side.
I'm expecting sending data over encrypted tunnel not over simple GRE which carries IPSec traffic.
More, if I have no such rule then there should be no chance to make secured connection so traffic should be blocked.
ditonet
Forum Veteran
Forum Veteran
Thu Feb 02, 2017 11:39 pm
@strods
Any info about VLAN belonging to bridge problem described here:
http://forum.mikrotik.com/viewtopic.php ... 37#p578886
Is this bug confirmed by MT staff?
Regards,
msatter
Fri Feb 03, 2017 12:19 am
Thanks, however in that part there seems nothing can be found to hook with "find where" so I looked again into printing. I am now issuing now "/ip ipsec remote-peers print value-list;" before the line.
Running:
pe1chl
Fri Feb 03, 2017 12:27 am
You expect a lot, but it does not work like that!
IPsec policies define what traffic is encrypted and all traffic that does not match the policies is simply sent unencrypted.
As the policies are dynamically generated (first a phase1 association with the peer as defined in the tunnel interface setup and
then a phase2 policy generated from there), in case the IPsec is not defined at both ends there simply is no encryption.
Many examples for using firewall entries for tunnel over IPsec for MikroTik are simply incorrect. E.g. for GRE/IPsec they list
that protocol 47 is to be allowed, for L2TP/IPsec they list that UDP port 1702 is to be allowed. That is simply wrong, the
extra qualifier ipsec-policy=in,ipsec as mentioned above should be present for those allow rules or else unencrypted traffic
for that protocol will be allowed as well! When you would not allow plain incoming GRE traffic the connection would not
be established. And when you are very worried about sending unencrypted traffic, probably you should also use output
rules to drop GRE traffic when not ipsec-policy=out,ipsec ...
colanderman
Fri Feb 03, 2017 1:06 am
Oh sorry! I mean in webfig, not winbox.
Chupaka
Fri Feb 03, 2017 1:26 pm
If there's only one peer, then just use [find], without 'where' part
parham
Fri Feb 03, 2017 2:16 pm
In iPad Safari terminal tab seems ok but won't bring the keyboard up. with out the keyboard can't do anything.
msatter
Fri Feb 03, 2017 2:32 pm
Indeed that works and there is a problem is when the first IPSEC connect did not work and you had to reconnect. Then there are more connections active of which the invalid ones will timeout eventually. Only one remote-dynamic-address isn't working and I get than an error that the template is invalid.
So I get then as message "invalid internal item number" so I will stick with the "print value-list" and then I can check each line.
:put /ip ipsec remote-peers> :put [/ip ipsec remote-peers get [find] remote-address ];
Thanks again for the help on this.
Running:
BartoszP
Fri Feb 03, 2017 5:28 pm
...You expect a lot, but it does not work like that!....
IPsec policies define what traffic is encrypted and all traffic that does not match the policies is simply sent unencrypted. ....
Thank you for long explanation but I expect, seems that I am wrong at this point, that If I specify passwords, the tunnel will not pass traffic if there is no match of password for both ends. Traffic should not be carried without encryption despite the method of generating policies.
pe1chl
Fri Feb 03, 2017 6:55 pm
With the proper firewall entries at both ends that would be true.
Put this in your input chain at both sides BEFORE the Established/Related entry.
add action=reject chain=input comment="reject unprotected GRE" ipsec-policy=in,none protocol=gre reject-with=icmp-admin-prohibited
w32pamela
Sat Feb 04, 2017 4:56 pm
Just to echo colanderman, Frequency Mode, Country & Antenna Gain are missing from webfig Wireless details in Advanced Mode. This problem is present in v6.38 and continues in v6.39RC. If I open Winbox and go to wireless advanced mode before I open Webfig then they appear.
The Terminal button does not bring up a functional terminal window in Chrome, Firefox, or IE with Windows 10. All I get is white window without a cursor.
strods
Tue Feb 07, 2017 10:58 am
Version 6.39rc26 has been released.
*) dhcp - do not listen on IPv4/IPv6 client to IPv6 MLD packets;
*) email - check for errors during SMTP exchange process;
*) hotspot - added access to HTTP headers using $(http-header-name);
*) ike1 - added more Radius accounting attributes - "event-timestamp", "acct-session-id", "acct-authentic", "acct-session-time";
*) ipsec - do not require "sa-dst-address" if "action=none" or "action=discard";
*) ipsec - fixed "mode-cfg" verbose export;
*) log - added tr069 topic;
*) tr069-client - added traceroute diagnostics support;
me9
Tue Feb 07, 2017 1:06 pm
Hi.
rb750gr3
anuser
Wed Feb 08, 2017 12:24 pm
- WAP AC 6.39rc26
- users reported that their clients get disconnected randomely
- I watched caps,info logging and found concurrent "disconnected, group key timeout" messages for multiple clients running on 2.4Ghz,
i.e. 5 clients (e.g. with different MAC addresses starting with: 3CE072, F48E92, E0DB10, 64CC2E,5CF7:E6) get dropped at once in this case. I do not know whether this is the reason for this problem...
- Note: This seems to be only on WAP AC devices with serial number starting with 711E06..... (with MAC address starting with 6C:3B:6B) I bought 10 of those last week. On older devices with serial number 65710/69A50/6CBA06 no problems have been reported so far.
uldis
Wed Feb 08, 2017 1:20 pm
- WAP AC 6.39rc26
Could you please write to support@mikrotik.com with the exact SN that experience this problem?
Also if possible maybe you could make a support output file on the wAP ac when this problem happens?
strods
Thu Feb 09, 2017 2:03 pm
Version 6.39rc27 has been released.
*) dhcp-client - added "script" option which executes script on state changes (CLI only);
*) firewall - do not allow to set "time" parameter to 0s for "limit" option;
*) ike2 - always replace empty TSi with configured address if it is available;
*) ipsec - fixed "/ip ipsec policy group export verbose";
*) lte - fixed "/interface lte info X once";
*) ppp-client - added support for Datacard 750UL and DWR-730;
*) snmp - added SSID to CAPsMAN registration table;
*) snmp - improved response speed when multiple requests are received within short period of time;
*) userman - allow access to User Manager users page only through "/user" URL;
*) webfig - improved field layout;
andriys
Thu Feb 09, 2017 3:18 pm
Yay!!!
alexjhart
Fri Feb 10, 2017 1:08 am
cool. now I can react to lease instead of scheduling script to do ddns, address-lists, etc. ? :)
Didn't know this was in the works. Looked through release notes. Happy to see it though!
Looks like minor bug though:
`/caps-man registration-table print oid` reports 1.3.6.1.4.1.14988.1.1.1.4.1...
but snmpwalk shows that it is really 1.3.6.1.4.1.14988.1.1.1.5.1...
Alex Hart
The Brothers WISP
sergejs
Fri Feb 10, 2017 11:07 am
Thank you very much for the report about capsman oid values.
jaxx
Fri Feb 10, 2017 6:46 pm
Hi everyone,
I don't post that often, but since 6.38 (now .1 ) (I believe, as I don't recall having the issue before) my CRS is acting very bad, actually, waking me up at night sometimes.
It manages to restart on it's own, but crashes hard enough to leave the remote side of an SFP+ in a bad state (Mellanox cards get over it fine, but I have an Intel Dual AF DA card that never manages to reset itself, (even an ifdown&&rmmod&&modprobe&&ifup doesn't do a thing, needing a warm reboot of the server))... Since this switch is core of my home network, including my ISPs GPON access on a vlan, the good old unbreakable (besides it's PSU) RB1100AH doesn't get along that much neither, sticking DHCP in a "searching" state until I renew manually.
In contrast, when I reboot the switch intentionally, from the CLI or Winbox: everything connected device reacts perfectly fine
I see in the changelog stability improvements for MMIPS, any chance you fixed some stuff on MIPSBE as well ?
Are RCes safe enough to give it a try (afterall it's "just" home, not my real workplace)
Or, what downgrade paths can I go through? seeing many changes on 6.38.x is it even possible ?
Supout.rif doesn't seem to give anything, and it's generated after the crash anyways, but I hooked up a console port and got some non consistent stack traces:
grabserial with timestamping:
# grabserial -T -b 115200 -d /dev/ttyUSB0 -v
Opening serial port /dev/ttyUSB0
115200:8N1:xonxoff=0:rtscts=0
Printing absolute timing information for each line
Use Control-C to stop...
[18:14:36.570195 0.000002] -=< Watchdog IRQ >=-
[18:14:36.593493 0.031310] Call Trace:
[18:14:36.593796 0.000305] <4>{c3ee1ae0} dump_stack+0x8/0x30
[18:14:36.594533 0.000736] <4>{c3ee1ba8} 0xc32742d8 [music_dog@0xc3274000]
[18:14:36.595548 0.001016] <4>{c3ee1bc0} handle_irq_event_percpu+0x64/0x25c
[18:14:36.596584 0.001036] <4>{c3ee1c00} handle_irq_event+0x38/0x68
[18:14:36.597481 0.000897] <4>{c3ee1c18} handle_level_irq+0xc8/0xe8
[18:14:36.598352 0.000871] <4>{c3ee1c30} generic_handle_irq+0x28/0x44
[18:14:36.599264 0.000912] <4>{c3ee1c48} do_IRQ+0xb0/0xc0
[18:14:36.599940 0.000676] <4>{c3ee1c60} music_irq_dispatch+0x50/0x7c
[18:14:36.600867 0.000927] <4>{c3ee1c88} handle_irq_event_percpu+0x64/0x25c
[18:14:36.601928 0.001061] <4>{c3ee1cc8} handle_percpu_irq+0x54/0x84
[18:14:36.602837 0.000909] <4>{c3ee1ce8} generic_handle_irq+0x28/0x44
[18:14:36.603763 0.000927] <4>{c3ee1d00} do_IRQ+0xb0/0xc0
[18:14:36.604461 0.000697] <4>{c3ee1d18} ret_from_irq+0x0/0x4
[18:14:36.605211 0.000750] <4>more trace (sp:c3ee1d80):
[18:14:36.605854 0.000643] <4>{c3ee1d80} addrlist_get_list+0x128/0x1f4 [packet_hook@0xc3000000]
[18:14:36.607333 0.001479] <4>{c3ee1dc0} 0xc24f0118 [music_gmac@0xc24f0000]
[18:14:36.608369 0.001036] <4>{c3ee1de8} 0xc24f0560 [music_gmac@0xc24f0000]
[18:14:36.609411 0.001042] <4>{c3ee1e28} 0xc24f2688 [music_gmac@0xc24f0000]
[18:14:36.610452 0.001041] <4>{c3ee1e68} process_one_work+0x2dc/0x484
[18:14:36.611412 0.000960] <4>{c3ee1ea0} worker_thread+0x23c/0x3e0
[18:14:36.612329 0.000917] <4>{c3ee1ee0} kthread+0x88/0x90
[18:14:36.613784 0.001455] <4>{c3ee1f18} kernel_thread_helper+0x10/0x18
[18:14:36.619372 0.005588] <4>
[18:14:39.089481 2.470104]
[18:14:39.089613 0.000136]
[18:14:39.089665 0.000053] RouterBOOT booter 3.22
[18:14:39.090193 0.000528]
[18:14:39.090243 0.000050] CRS226-24G-2S+
[18:14:39.092686 0.002442]
[18:14:39.092739 0.000054] CPU frequency: 400 MHz
[18:14:39.095527 0.002787]   Memory size:  64 MiB
[18:14:39.100394 0.004867]     NAND size: 128 MiB
[18:14:39.209472 0.109074]
[18:14:39.209592 0.000124] Press any key within 2 seconds to enter setup..
[18:14:41.241416 2.031820]
[18:14:41.241529 0.000118] loading kernel from nand... OK
[18:14:43.523657 2.282122] setting up elf image... OK
[18:14:43.664576 0.140921] jumping to kernel code
[18:14:47.950500 4.285923] Starting...
[18:14:59.544603 11.594102] Starting services...
[18:15:16.490655 16.946053]
[18:15:16.493766 0.003115] mtk-core-switch Login: -=< Watchdog IRQ >=-
[18:37:36.215519 1339.721749] Call Trace:
[18:37:36.218042 0.002527] <4>{c3ee1ad8} dump_stack+0x8/0x30
[18:37:36.221096 0.003054] <4>{c3ee1ba0} 0xc32882d8 [music_dog@0xc3288000]
[18:37:36.224452 0.003357] <4>{c3ee1bb8} handle_irq_event_percpu+0x64/0x25c
[18:37:36.229146 0.004694] <4>{c3ee1bf8} handle_irq_event+0x38/0x68
[18:37:36.232361 0.003215] <4>{c3ee1c10} handle_level_irq+0xc8/0xe8
[18:37:36.235556 0.003194] <4>{c3ee1c28} generic_handle_irq+0x28/0x44
[18:37:36.241172 0.005617] <4>{c3ee1c40} do_IRQ+0xb0/0xc0
[18:37:36.243154 0.001982] <4>{c3ee1c58} music_irq_dispatch+0x50/0x7c
[18:37:36.246397 0.003242] <4>{c3ee1c80} handle_irq_event_percpu+0x64/0x25c
[18:37:36.252114 0.005717] <4>{c3ee1cc0} handle_percpu_irq+0x54/0x84
[18:37:36.255332 0.003219] <4>{c3ee1ce0} generic_handle_irq+0x28/0x44
[18:37:36.257564 0.002232] <4>{c3ee1cf8} do_IRQ+0xb0/0xc0
[18:37:36.260583 0.003018] <4>{c3ee1d10} ret_from_irq+0x0/0x4
[18:37:36.266012 0.005429] <4>more trace (sp:c3ee1da8):
[18:37:36.267971 0.001959] <4>{c3ee1da8} 0xc339853c [music_gmac@0xc3398000]
[18:37:36.271336 0.003365] <4>{c3ee1de8} 0xc339853c [music_gmac@0xc3398000]
[18:37:36.277050 0.005714] <4>{c3ee1e28} 0xc339a688 [music_gmac@0xc3398000]
[18:37:36.280422 0.003372] <4>{c3ee1e68} process_one_work+0x2dc/0x484
[18:37:36.285009 0.004588] <4>{c3ee1ea0} worker_thread+0x23c/0x3e0
[18:37:36.288212 0.003203] <4>{c3ee1ee0} kthread+0x88/0x90
[18:37:36.291237 0.003025] <4>{c3ee1f18} kernel_thread_helper+0x10/0x18
[18:37:36.296519 0.005282] <4>
[18:37:38.768090 2.471566]
[18:37:38.768223 0.000137]
[18:37:38.768275 0.000053] RouterBOOT booter 3.22
[18:37:38.768736 0.000461]
[18:37:38.768782 0.000046] CRS226-24G-2S+
[18:37:38.771277 0.002494]
[18:37:38.771333 0.000057] CPU frequency: 400 MHz
[18:37:38.773122 0.001789]   Memory size:  64 MiB
[18:37:38.777983 0.004860]     NAND size: 128 MiB
[18:37:38.887068 0.109081]
[18:37:38.887186 0.000123] Press any key within 2 seconds to enter setup..
[18:37:40.919999 2.032808]
[18:37:40.920113 0.000119] loading kernel from nand... OK
[18:37:43.202189 2.282072] setting up elf image... OK
[18:37:43.342161 0.139971] jumping to kernel code
[18:37:47.629077 4.286916] Starting...
[18:37:59.209126 11.580047] Starting services...
[18:38:16.450197 17.241073]
[/size]
I sense the CPU gets hogged up quite easily, but as much as I can say, I've not used anything that might be out of a purely hardware switch-chip managed configuration (besides giving it an IP and the LCD), the cpu is generally under low load, including at night when I have ~200Mbs of internet traffic going through it twice (ISP>CRS>RB>CRS>SFP attached server)
Well, merely a bottle in the sea, hoping I'm not the only one seeing odd things :)
Anyway of making kernel related messages and crashes more verbose on the console ?
Thanks,
JaXX
For the curious: here's the dmesg of the server with the Intel Card when the switch crash-reboots on it's own: I've updated kernel from old 3.x to a 4.9 with the exact same phenomenon
(An Intel Dual AF-DA in a Proliant Micro Server Gen3)
[Sun Feb  5 09:46:53 2017] ------------[ cut here ]------------
[Sun Feb  5 09:46:53 2017] WARNING: CPU: 0 PID: 0 at /home/zumbi/linux-4.9.2/net/sched/sch_generic.c:316 dev_watchdog+0x220/0x230
[Sun Feb  5 09:46:53 2017] NETDEV WATCHDOG: eth1 (ixgbe): transmit queue 1 timed out
[Sun Feb  5 09:46:53 2017] Modules linked in: tun rfcomm bnep parport_pc bluetooth ppdev lp rfkill parport xt_multiport iptable_filter ip_tables x_tables fuse nfsd auth_rpcgss nfs_acl nfs lockd grace fscache sunrpc bridge 8021q garp mrp stp llc loop amd64_edac_mod amdkfd edac_mce_amd edac_core kvm_amd radeon kvm ttm irqbypass pcspkr k10temp drm_kms_helper evdev drm i2c_algo_bit tpm_infineon acpi_cpufreq tpm_tis button tpm_tis_core sp5100_tco tpm i2c_piix4 shpchp ext4 crc16 jbd2 fscrypto mbcache dm_mod raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic md_mod hid_generic usbhid hid sr_mod cdrom sg sd_mod ata_generic ohci_pci tg3 pata_atiixp libphy ixgbe ahci libahci libata ehci_pci ohci_hcd dca ptp pps_core mdio ehci_hcd scsi_mod fjes usbcore usb_common
[Sun Feb  5 09:46:53 2017] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.0-0.bpo.1-amd64 #1 Debian 4.9.2-2~bpo8+1
[Sun Feb  5 09:46:53 2017] Hardware name: HP ProLiant MicroServer, BIOS O41     07/29/2011
[Sun Feb  5 09:46:53 2017]  0000000000000000 ffffffffbe32a1f5 ffff97969fc03e38 0000000000000000
[Sun Feb  5 09:46:53 2017]  ffffffffbe077884 0000000000000001 ffff97969fc03e90 ffff9796960e0000
[Sun Feb  5 09:46:53 2017]  0000000000000000 ffff979696ada740 0000000000000020 ffffffffbe0778ff
[Sun Feb  5 09:46:53 2017] Call Trace:
[Sun Feb  5 09:46:53 2017]  <IRQ>
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe32a1f5>] ? dump_stack+0x5c/0x77
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe077884>] ? __warn+0xc4/0xe0
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe0778ff>] ? warn_slowpath_fmt+0x5f/0x80
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe51fc30>] ? dev_watchdog+0x220/0x230
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe51fa10>] ? dev_deactivate_queue.constprop.27+0x60/0x60
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe0e6210>] ? call_timer_fn+0x30/0x130
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe0e7085>] ? run_timer_softirq+0x215/0x4b0
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe333434>] ? timerqueue_add+0x54/0xa0
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe0e82c8>] ? enqueue_hrtimer+0x38/0x80
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe5fcce6>] ? __do_softirq+0x106/0x292
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe07db08>] ? irq_exit+0x98/0xa0
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe5fcaee>] ? smp_apic_timer_interrupt+0x3e/0x50
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe5fbe02>] ? apic_timer_interrupt+0x82/0x90
[Sun Feb  5 09:46:53 2017]  <EOI>
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe5f9a22>] ? native_safe_halt+0x2/0x10
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe5f9748>] ? default_idle+0x18/0xd0
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe02fb48>] ? amd_e400_idle+0x58/0xd0
[Sun Feb  5 09:46:53 2017]  [<ffffffffbe0bc070>] ? cpu_startup_entry+0x1f0/0x260
[Sun Feb  5 09:46:53 2017]  [<ffffffffbed49f84>] ? start_kernel+0x46d/0x48d
[Sun Feb  5 09:46:53 2017]  [<ffffffffbed49120>] ? early_idt_handler_array+0x120/0x120
[Sun Feb  5 09:46:53 2017]  [<ffffffffbed495b9>] ? x86_64_start_kernel+0x152/0x176
[Sun Feb  5 09:46:53 2017] ---[ end trace 1b654a01d52cecd3 ]---
[Sun Feb  5 09:46:53 2017] ixgbe 0000:02:00.0 eth1: initiating reset due to tx timeout
[Sun Feb  5 09:46:53 2017] ixgbe 0000:02:00.0 eth1: Reset adapter
[Sun Feb  5 09:46:53 2017] ixgbe 0000:02:00.0 eth1: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[Sun Feb  5 09:46:53 2017] ixgbe 0000:02:00.0 eth1: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[Sun Feb  5 09:46:56 2017] ixgbe 0000:02:00.0 eth1: detected SFP+: 0
[Sun Feb  5 09:46:58 2017] ixgbe 0000:02:00.0 eth1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[Sun Feb  5 09:47:08 2017] ixgbe 0000:02:00.0 eth1: initiating reset due to tx timeout
[Sun Feb  5 09:47:08 2017] ixgbe 0000:02:00.0 eth1: Reset adapter
[Sun Feb  5 09:47:08 2017] ixgbe 0000:02:00.0 eth1: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[Sun Feb  5 09:47:08 2017] ixgbe 0000:02:00.0 eth1: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[Sun Feb  5 09:47:11 2017] ixgbe 0000:02:00.0 eth1: detected SFP+: 0
[Sun Feb  5 09:47:13 2017] ixgbe 0000:02:00.0 eth1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[Sun Feb  5 09:47:23 2017] ixgbe 0000:02:00.0 eth1: initiating reset due to tx timeout
[Sun Feb  5 09:47:23 2017] ixgbe 0000:02:00.0 eth1: Reset adapter
[Sun Feb  5 09:47:23 2017] ixgbe 0000:02:00.0 eth1: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[Sun Feb  5 09:47:23 2017] ixgbe 0000:02:00.0 eth1: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[Sun Feb  5 09:47:26 2017] ixgbe 0000:02:00.0 eth1: detected SFP+: 0
[Sun Feb  5 09:47:28 2017] ixgbe 0000:02:00.0 eth1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[Sun Feb  5 09:47:38 2017] ixgbe 0000:02:00.0 eth1: initiating reset due to tx timeout
[Sun Feb  5 09:47:38 2017] ixgbe 0000:02:00.0 eth1: Reset adapter
[Sun Feb  5 09:47:38 2017] ixgbe 0000:02:00.0 eth1: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[Sun Feb  5 09:47:38 2017] ixgbe 0000:02:00.0 eth1: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[Sun Feb  5 09:47:41 2017] ixgbe 0000:02:00.0 eth1: detected SFP+: 0
[/size]
alexjhart
Re: v6.39rc [release candidate] is released
Fri Feb 10, 2017 8:14 pm
Happy to help :)
Alex Hart
The Brothers WISP
gtj
Sat Feb 11, 2017 8:30 pm
Whose ever idea it was to add a "Terminal" button to the top of the WebFig pages deserves a BIG PAY RAISE!
pe1chl
Sat Feb 11, 2017 10:11 pm
And even more important (the terminal button was already in the left menu): finally the Quickset interface is hidden once you
no longer need it, no more risk to disturb the whole config by clicking a wrong button on the startpage! Hooray!
gtj
Sun Feb 12, 2017 5:50 pm
To be honest the left menu makes me NUTS because the items can be in different places even on 2 identical devices. Maybe it has something to do with the order packages are installed but IPv6 and PPP seem to be the biggest offenders. Sometimes IPv6 is above IP, sometimes below and on my ccr, it's between Tools and Radius.
pe1chl
Sun Feb 12, 2017 8:27 pm
Interesting, I have not seen that problem. IPv6 is in a strange position (not just below IP) but it does not vary for me.
Maybe it depends on the browser or the way the system was installed.
dalil
Mon Feb 13, 2017 2:17 pm
msatter
Thu Feb 16, 2017 10:10 am
I am still on RC25 and read that the DHCP-Client has got script fields. Is this also available on up/down of IPv6?
The Wiki is updated with variables for DHCP-IPv6: http://wiki.mikrotik.com/index.php?titl ... 062#Script
It is possible to add a script that will be executed when a prefix or an address is acquired and applied or expires and is removed using DHCP client. There are separated sets of variables that will have the value set by the client depending on prefix or address status change as the client can acquire both and each of them can have a different effect on the router configuration.
Available variables for dhcp-client
pd-valid - value - 1 or 0 - if prefix is acquired and it is applied or not
pd-prefix - value ipv6/num (ipv6 prefix with mask) - the prefix inself
na-valid - value - 1 or 0 - if address is acquired and it is applied or not
na-address - value - ipv6 address - the address
Thanks for working on the Wiki to keep it up to date and it great to use to implement/lookup things and a must read before posting in the forum.
Running:
strods
Fri Feb 17, 2017 1:32 pm
Version 6.39rc33 has been released.
!) winbox - minimal required version is v3.11;
*) chr - fixed problem when transmit speed was reduced by interface queues;
*) defconf - fixed Groove 52 ac band settings;
*) dhcp-client - added "script" option which executes script on state changes;
*) dhcpv4-server - added "lease-hostname" script parameter;
*) dhcpv6-server - require "address-pool" to be specified;
*) export - do not show "read-only" IRQ entries;
*) gps - added "fix-quality" and "horizontal-dilution" parameters;
*) ike1 - fixed unnecessary Radius accounting requests;
*) ike1 - fixed "xauth" Radius login;
*) ike2 - update peer identity after successful EAP authentication;
*) irq - properly detect all IRQ entries;
*) log - added "gps" topic;
*) log - make SNMP logs more compact;
*) lte - buffer AT events while info command is active;
*) snmp - "No Such Instance" error message is replaced with "No Such Object";
*) snmp - fixed "/tool snmp-get" crash on session timeout;
*) snmp - fixed CAPsMAN registration table OID print;
*) snmp - fixed situation when SNMP could not read "/system health" values after reboot;
*) tile - added initial support for NVMe SSD disk drives;
*) tr069-client - fixed "traceroute" parameter IDs;
*) userman - show warning when no users are selected for CSV file generation;
*) winbox - added GPS menu;
*) winbox - allow to not specify certificate in IPSec peer settings;
*) winbox - allow unhide SNMP passwords;
*) winbox - do not hide "power-cycle-after" option;
*) winbox - do not show empty LTE fields in Info menu;
*) winbox - hide advertise tab in Hotspot user profile configuration if "transparent-proxy" is not enabled;
*) winbox - properly name CAP Interface on new interface creation;
*) winbox - properly show BGP communities in routing filters table filter;
*) wireless - added Egypt 5.8 country settings;
*) wireless - fixed scan tool stuck in background;
*) wireless - improved compatibility with Intel 2200BG wireless card;
*) x86 - added support for NVMe SSD disk drives;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
MayestroPW
Fri Feb 17, 2017 2:22 pm
What it means?
andriys
Fri Feb 17, 2017 2:39 pm
What it means?
As I understand, now you should be able to create child (virtual) interfaces under the physical interface that's being managed by CAPsMAN. I have not tried it myself yet, though.
MayestroPW
Fri Feb 17, 2017 3:03 pm
That function was already
andriys
Fri Feb 17, 2017 3:16 pm
Nope. It was possible to added slave interface on CAPsMAN (controller), but you could not add slave interface locally on a CAP (managed board) itself. It appears to be possible now.
MayestroPW
Fri Feb 17, 2017 4:03 pm
When you connect CAP to CAPsMAN virtual interface on CAP becomes disabled. I just tested it, and it works same as 6.38.1. So it's not it, but would be awesome if it was that ;)
sergejs
Fri Feb 17, 2017 4:15 pm
What it means?
CAP supports static interfaces instead of dynamic ones, they do not disappear after reboot and count number is not changed all the time (recognised by mac-address).
td32
Fri Feb 17, 2017 6:19 pm
So it seams you don't have to do the copy caps setting to a new one just to set a custom name and make the cap static. nice!
Edit:
mm perhaps i didn't understand it right
what i wrote up can already be done by adding a cap manually.
alexjhart
Fri Feb 17, 2017 8:08 pm
I'm still getting the same incorrect output.
Alex Hart
The Brothers WISP
korniza
Sat Feb 18, 2017 6:35 pm
Help people!
I have a script that was reading snmp individual mac address from capsman registration table. After upgrade I can not read any of them.
What is the SNMP oid to get all the wireless clients MAC on capsman (not the count)???!
alexjhart
Re: RE: Re: v6.39rc [release candidate] is released
Sat Feb 18, 2017 6:41 pm
Help people!
I posted above (ignore the minor bug they're working on)
So if you walk that, you'll see stats for all registered capsman clients, including mac address. Does that make sense?
Alex Hart
The Brothers WISP
korniza
Sat Feb 18, 2017 6:47 pm
Help people!
I get the following which does not have any MAC address of the clients :?
 snmpwalk -c public -v 2c 192.168.10.1 1.3.6.1.4.1.14988.1.1.1.5.1
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.0.4.32.239.134.9.195 = Timeticks: (140225400) 16 days, 5:30:54.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.40.16.123.35.106.44.202 = Timeticks: (114602300) 13 days, 6:20:23.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.44.240.238.73.164.89.204 = Timeticks: (101436600) 11 days, 17:46:06.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.60.51.0.51.170.194.202 = Timeticks: (151901200) 17 days, 13:56:52.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.72.238.12.124.113.215.201 = Timeticks: (290717300) 33 days, 15:32:53.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.92.207.127.1.138.227.193 = Timeticks: (160445600) 18 days, 13:40:56.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.92.207.127.129.10.170.195 = Timeticks: (160445300) 18 days, 13:40:53.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.148.16.62.205.37.201.204 = Timeticks: (304600) 0:50:46.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.164.119.51.168.68.54.194 = Timeticks: (160439000) 18 days, 13:39:50.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.164.119.51.239.164.100.193 = Timeticks: (3174200) 8:49:02.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.168.129.149.141.101.106.195 = Timeticks: (160424800) 18 days, 13:37:28.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.176.197.84.1.85.60.200 = Timeticks: (26533200) 3 days, 1:42:12.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.176.197.84.2.156.36.201 = Timeticks: (290776200) 33 days, 15:42:42.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.176.197.84.3.112.103.201 = Timeticks: (290739400) 33 days, 15:36:34.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.176.197.84.5.105.150.202 = Timeticks: (131831600) 15 days, 6:11:56.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.3.238.34.128.108.26.145.206 = Timeticks: (271971200) 31 days, 11:28:32.00
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.0.4.32.239.134.9.195 = Counter32: 5821244
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.40.16.123.35.106.44.202 = Counter32: 73790913
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.44.240.238.73.164.89.204 = Counter32: 14501780
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.60.51.0.51.170.194.202 = Counter32: 3251847
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.72.238.12.124.113.215.201 = Counter32: 428737
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.92.207.127.1.138.227.193 = Counter32: 135337
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.92.207.127.129.10.170.195 = Counter32: 480132
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.148.16.62.205.37.201.204 = Counter32: 2090
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.164.119.51.168.68.54.194 = Counter32: 68642196
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.164.119.51.239.164.100.193 = Counter32: 498267
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.168.129.149.141.101.106.195 = Counter32: 72654044
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.176.197.84.1.85.60.200 = Counter32: 47798728
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.176.197.84.2.156.36.201 = Counter32: 230505304
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.176.197.84.3.112.103.201 = Counter32: 11839456
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.176.197.84.5.105.150.202 = Counter32: 11044643
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.4.238.34.128.108.26.145.206 = Counter32: 2126093
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.0.4.32.239.134.9.195 = Counter32: 1536484
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.40.16.123.35.106.44.202 = Counter32: 1608283769
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.44.240.238.73.164.89.204 = Counter32: 1464379
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.60.51.0.51.170.194.202 = Counter32: 3173338763
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.72.238.12.124.113.215.201 = Counter32: 829923
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.92.207.127.1.138.227.193 = Counter32: 104828
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.92.207.127.129.10.170.195 = Counter32: 511559
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.148.16.62.205.37.201.204 = Counter32: 4048
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.164.119.51.168.68.54.194 = Counter32: 6079397
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.164.119.51.239.164.100.193 = Counter32: 170935
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.168.129.149.141.101.106.195 = Counter32: 5243963
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.176.197.84.1.85.60.200 = Counter32: 1952933251
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.176.197.84.2.156.36.201 = Counter32: 908878507
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.176.197.84.3.112.103.201 = Counter32: 2161636
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.176.197.84.5.105.150.202 = Counter32: 541918651
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.5.238.34.128.108.26.145.206 = Counter32: 5897834
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.0.4.32.239.134.9.195 = Counter32: 17605
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.40.16.123.35.106.44.202 = Counter32: 1127441
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.44.240.238.73.164.89.204 = Counter32: 11616
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.60.51.0.51.170.194.202 = Counter32: 35534
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.72.238.12.124.113.215.201 = Counter32: 7080
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.92.207.127.1.138.227.193 = Counter32: 1268
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.92.207.127.129.10.170.195 = Counter32: 7985
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.148.16.62.205.37.201.204 = Counter32: 32
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.164.119.51.168.68.54.194 = Counter32: 64529
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.164.119.51.239.164.100.193 = Counter32: 1744
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.168.129.149.141.101.106.195 = Counter32: 61812
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.176.197.84.1.85.60.200 = Counter32: 878525
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.176.197.84.2.156.36.201 = Counter32: 4235450
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.176.197.84.3.112.103.201 = Counter32: 87886
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.176.197.84.5.105.150.202 = Counter32: 177603
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.6.238.34.128.108.26.145.206 = Counter32: 26254
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.0.4.32.239.134.9.195 = Counter32: 18520
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.40.16.123.35.106.44.202 = Counter32: 1360940
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.44.240.238.73.164.89.204 = Counter32: 12007
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.60.51.0.51.170.194.202 = Counter32: 5942883
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.72.238.12.124.113.215.201 = Counter32: 8389
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.92.207.127.1.138.227.193 = Counter32: 1323
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.92.207.127.129.10.170.195 = Counter32: 8088
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.148.16.62.205.37.201.204 = Counter32: 48
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.164.119.51.168.68.54.194 = Counter32: 49427
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.164.119.51.239.164.100.193 = Counter32: 1304
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.168.129.149.141.101.106.195 = Counter32: 64913
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.176.197.84.1.85.60.200 = Counter32: 4306854
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.176.197.84.2.156.36.201 = Counter32: 9719647
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.176.197.84.3.112.103.201 = Counter32: 33413
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.176.197.84.5.105.150.202 = Counter32: 3597021
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.7.238.34.128.108.26.145.206 = Counter32: 81421
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.0.4.32.239.134.9.195 = Gauge32: 120000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.40.16.123.35.106.44.202 = Gauge32: 65000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.44.240.238.73.164.89.204 = Gauge32: 104000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.60.51.0.51.170.194.202 = Gauge32: 150000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.72.238.12.124.113.215.201 = Gauge32: 150000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.92.207.127.1.138.227.193 = Gauge32: 48000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.92.207.127.129.10.170.195 = Gauge32: 72200000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.148.16.62.205.37.201.204 = Gauge32: 26000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.164.119.51.168.68.54.194 = Gauge32: 65000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.164.119.51.239.164.100.193 = Gauge32: 58500000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.168.129.149.141.101.106.195 = Gauge32: 72200000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.176.197.84.1.85.60.200 = Gauge32: 150000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.176.197.84.2.156.36.201 = Gauge32: 57700000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.176.197.84.3.112.103.201 = Gauge32: 65000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.176.197.84.5.105.150.202 = Gauge32: 108000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.8.238.34.128.108.26.145.206 = Gauge32: 270000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.0.4.32.239.134.9.195 = Gauge32: 54000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.40.16.123.35.106.44.202 = Gauge32: 72200000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.44.240.238.73.164.89.204 = Gauge32: 130000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.60.51.0.51.170.194.202 = Gauge32: 81000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.72.238.12.124.113.215.201 = Gauge32: 150000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.92.207.127.1.138.227.193 = Gauge32: 48000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.92.207.127.129.10.170.195 = Gauge32: 18000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.148.16.62.205.37.201.204 = Gauge32: 135000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.164.119.51.168.68.54.194 = Gauge32: 65000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.164.119.51.239.164.100.193 = Gauge32: 65000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.168.129.149.141.101.106.195 = Gauge32: 72200000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.176.197.84.1.85.60.200 = Gauge32: 150000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.176.197.84.2.156.36.201 = Gauge32: 52000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.176.197.84.3.112.103.201 = Gauge32: 65000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.176.197.84.5.105.150.202 = Gauge32: 27000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.9.238.34.128.108.26.145.206 = Gauge32: 243000000
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.0.4.32.239.134.9.195 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.40.16.123.35.106.44.202 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.44.240.238.73.164.89.204 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.60.51.0.51.170.194.202 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.72.238.12.124.113.215.201 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.92.207.127.1.138.227.193 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.92.207.127.129.10.170.195 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.148.16.62.205.37.201.204 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.164.119.51.168.68.54.194 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.164.119.51.239.164.100.193 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.168.129.149.141.101.106.195 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.176.197.84.1.85.60.200 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.176.197.84.2.156.36.201 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.176.197.84.3.112.103.201 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.176.197.84.5.105.150.202 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.10.238.34.128.108.26.145.206 = INTEGER: 0
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.0.4.32.239.134.9.195 = INTEGER: -60
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.40.16.123.35.106.44.202 = INTEGER: -39
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.44.240.238.73.164.89.204 = INTEGER: -65
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.60.51.0.51.170.194.202 = INTEGER: -49
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.72.238.12.124.113.215.201 = INTEGER: -66
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.92.207.127.1.138.227.193 = INTEGER: -69
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.92.207.127.129.10.170.195 = INTEGER: -55
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.148.16.62.205.37.201.204 = INTEGER: -66
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.164.119.51.168.68.54.194 = INTEGER: -59
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.164.119.51.239.164.100.193 = INTEGER: -41
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.168.129.149.141.101.106.195 = INTEGER: -44
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.176.197.84.1.85.60.200 = INTEGER: -61
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.176.197.84.2.156.36.201 = INTEGER: -57
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.176.197.84.3.112.103.201 = INTEGER: -51
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.176.197.84.5.105.150.202 = INTEGER: -55
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.11.238.34.128.108.26.145.206 = INTEGER: -62
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.0.4.32.239.134.9.195 = INTEGER: 4607184
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.40.16.123.35.106.44.202 = INTEGER: 4596448
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.44.240.238.73.164.89.204 = INTEGER: 4596072
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.60.51.0.51.170.194.202 = INTEGER: 4597208
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.72.238.12.124.113.215.201 = INTEGER: 4664576
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.92.207.127.1.138.227.193 = INTEGER: 4602992
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.92.207.127.129.10.170.195 = INTEGER: 4600792
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.148.16.62.205.37.201.204 = INTEGER: 4596960
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.164.119.51.168.68.54.194 = INTEGER: 4619216
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.164.119.51.239.164.100.193 = INTEGER: 4584736
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.168.129.149.141.101.106.195 = INTEGER: 4544520
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.176.197.84.1.85.60.200 = INTEGER: 4601120
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.176.197.84.2.156.36.201 = INTEGER: 4607384
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.176.197.84.3.112.103.201 = INTEGER: 4664208
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.176.197.84.5.105.150.202 = INTEGER: 4538888
SNMPv2-SMI::enterprises.14988.1.1.1.5.1.12.238.34.128.108.26.145.206 = INTEGER: 4542200
looking around I see that THERE IS NO oid for MAC address as there was before! Mikrotik fixed wrong entry issue removing the MAC entry? :(
 0 uptime=.1.3.6.1.4.1.14988.1.1.1.4.1.3.176.197.84.2.156.36.201 tx-bytes=.1.3.6.1.4.1.14988.1.1.1.4.1.4.176.197.84.2.156.36.201 rx-bytes=.1.3.6.1.4.1.14988.1.1.1.4.1.5.176.197.84.2.156.36.201
   tx-packets=.1.3.6.1.4.1.14988.1.1.1.4.1.6.176.197.84.2.156.36.201 rx-packets=.1.3.6.1.4.1.14988.1.1.1.4.1.7.176.197.84.2.156.36.201 tx-rate=.1.3.6.1.4.1.14988.1.1.1.4.1.8.176.197.84.2.156.36.201
   rx-rate=.1.3.6.1.4.1.14988.1.1.1.4.1.9.176.197.84.2.156.36.201 tx-signal=.1.3.6.1.4.1.14988.1.1.1.4.1.10.176.197.84.2.156.36.201 rx-signal=.1.3.6.1.4.1.14988.1.1.1.4.1.11.176.197.84.2.156.36.201
   ssid=.1.3.6.1.4.1.14988.1.1.1.4.1.12.176.197.84.2.156.36.201
alexjhart
Sat Feb 18, 2017 7:04 pm
Help people!
Well, look at that. Not only did they not fix the misprint of oid, they did in fact remove mac from the tree. I'm guessing someone just removed they wrong thing by accident. They'll need to fix that clearly.
In the meantime, I am able to get the mac-address values in rc31 for entries there using a mikrotik script (your original issue?). For example:
> foreach client in=[/caps-man registration-table find] do={put [/caps-man registration-table get $client mac-address]}
Alex Hart
The Brothers WISP
alexjhart
Sat Feb 18, 2017 7:19 pm
I could have sworn it was in there, but I downgraded to the last release (rc27) and still didn't see mac listed in oid tree. So either that changed in an earlier version (perhaps unintentionally) or this just needs to be a feature request. It's gotta be in there in the future though, right?
Alex Hart
The Brothers WISP
korniza
Sat Feb 18, 2017 7:31 pm
I do not know if there was on rc27 because I jumped to the latest (6.39rc33) from the 6.38. I hope to be fixed fast as the script I use to get mac address is a geo-location script that reports users availability on the network. fingers crossed!
alexjhart
Sat Feb 18, 2017 7:42 pm
Yeah, I also jumped from 6.38rc to 6.39rc, so could have been lost in an earlier version. If we both thought it was there, maybe it was? Either way, I've asked in my ticket they make sure to add it.
Alex Hart
The Brothers WISP
korniza
Sat Feb 18, 2017 7:43 pm
6.38.1 is a good version to downgrade and get back mac address oid. I just did it and all are back to normal
alexjhart
Sat Feb 18, 2017 7:44 pm
Thanks for taking the time and effort to confirm that. Odds are in our favor they will add that back in then :)
Alex Hart
The Brothers WISP
korniza
Sat Feb 18, 2017 7:52 pm
I hope for a quick fix as I had mentioned the wrong oid months ago on http://forum.mikrotik.com/viewtopic.php?f=13&t=107522
Till then still they have wrong output on oid on console that snmp-walk. And now they broke it. Shall we will wait months to get back the previous functionality and get matched oid? Hoping for the best....
expert
Sat Feb 18, 2017 9:17 pm
Is the RSTP problem (which I reported here http://forum.mikrotik.com/viewtopic.php ... 50#p582781 ) fixed?
Zorro
Long time Member
Long time Member
Sun Feb 19, 2017 8:42 pm
noticed that last RC's of 639 both upgrade and Boot-Up MUCH faster than before.
not big deal, but not bad thing either.
mducharme
Trainer
Trainer
Sun Feb 19, 2017 10:32 pm
If you can fix in an upcoming RC - in the TR-069 data model, the MAC address for Ethernet interfaces seems to be missing. I can still see the MAC addresses for the wireless interfaces, but they are gone for the Ethernet interfaces. I have many other stats, ex. byte counts for all ethernet interfaces, but no MAC addresses. This looks like a strange oversight. It is useful for us to collect the MAC address of our managed devices, particularly the ether1 interface, so I would really like to have this data.
strods
Mon Feb 20, 2017 10:29 am
OIDs for CAPsMAN will be fixed in next rc release. MAC-Address parameter is removed since it was already available and this was a duplicate entry,
VASCO108
Mon Feb 20, 2017 3:48 pm
Hi everyone
I have 10g ports on my router and graphs look like this:
I am using version: 6.38.1
3G everything looks good, after exceeding this value, it begins to fall apart.
What could be the reason?
I will add that any problems with the link no :) The cacti looks normal.
ps: I apologize in advance for my English :(
alexjhart
Mon Feb 20, 2017 5:06 pm
Hi everyone
Looks like a 32 vs 64 bit counter rollover problem. Lots of info if you do a Google search on that. Here is one example:
https://www.google.com/amp/s/gorthx.wor ... -like/amp/
Alex Hart
The Brothers WISP
alexjhart
Mon Feb 20, 2017 5:07 pm
Where else is it included that we aren't finding (I say we because others are posting about this being gone too, so it's not just me missing it)?
Alex Hart
The Brothers WISP
kujo
Mon Feb 20, 2017 5:10 pm
Thank you!
VASCO108
Mon Feb 20, 2017 6:37 pm
Hi everyone
Thank you very much for your answer. I understand the question of whether and when the dude will support 64bit?
mducharme
Trainer
Trainer
Mon Feb 20, 2017 10:40 pm
Where is it available? I do not see the MAC address anywhere in TR-069 data returned from device, except for the MAC addresses for the WiFi interfaces. What I want is the ethernet interface MAC addresses, primarily ether1 so that I can see what MAC address the customer has on their WAN port. I have gone through the entire TR-069 data returned from my device and from what I can see this is not present.
alexjhart
Mon Feb 20, 2017 10:44 pm
I think that is a reply regarding snmp, not tr-069
Alex Hart
The Brothers WISP
mducharme
Trainer
Trainer
Mon Feb 20, 2017 10:50 pm
Ahh, thanks - I didn't realize there was another post about MAC addresses with SNMP in the thread that strods was probably replying to.
rah
Mon Feb 20, 2017 11:47 pm
In the same boat as well. I updated to the latest 6.39rc33 for the virtual static ap for capsmam feature, which works great! But it broke the snmp capsman registration table Mac address oid. Hopefully it can be fixed soon.
alexjhart
Tue Feb 21, 2017 12:22 am
So based on some of my own digging, I found that the entries for capsman can be looked up in the bridge mib.
As an example, this client:
1.3.6.1.4.1.14988.1.1.1.5.1.[3-12].0.14.88.171.21.21.14
has a mac address here:
1.3.6.1.2.1.17.4.3.1.1.0.14.88.171.21.21 = Hex-STRING: 00 02 B3 AB C1 DE
Based on the conversation in my ticket so far, it seems as if they expect us to use that. I'm waiting on confirmation.
Alex Hart
The Brothers WISP
rah
Tue Feb 21, 2017 3:53 am
Thanks for the info. It looks like the mac entries are a lookup table. To see if a client is disconnected or connected, would have to check the client by the snmp id addresses and not the macs. Not super useful for my application as I used the snmp macs in the capsman registration table to determine if people are home or not for some home automation. Ideally they can bring this back. However I did some more digging and found macs (wired and wireless) are also listed in the 'ipNetToMediaPhysAddress' with the OID prefix of: 1.3.6.1.2.1.4.22.1.2.9. This so far seems to working for my application.
strods
Tue Feb 21, 2017 1:02 pm
This is an example about SNMP CAPsMAN registration table.
We run SNMPwalk to device. As a result we get different OIDs. For example:
iso.3.6.1.4.1.14988.1.1.1.5.1.12..587
In this case:
iso.3.6.1.4.1.14988.1.1.1.5.1.12 - CAPsMAN registration table specific entry;
xx.xx.xx.xx.xx.xx - MAC address in decimal system
587 - specific ID to avoid duplicates
alexjhart
Tue Feb 21, 2017 9:00 pm
In this case:
I see now, so what you mean is the mac address is part of the OID, just in decimal form instead of hexadecimal.
for example, mac address 00:DB:9A:B0:E4:72 would be converted to 0.219.154.176.228.114 and it's stats would then be iso.3.6.1.4.1.14988.1.1.1.5.1.12.0.219.154.176.228.114.1
or, mac address DB:DB:DB:DB:DB:DB would become 219.219.219.219.219.219
While I can see this works, it does seem to be easier to have a Hex-String or String conversion automatically done for us in an additional OID. Since the code was there already and it makes things easier on folks, why not just leave it (put it back)?
Alex Hart
The Brothers WISP
rah
Wed Feb 22, 2017 6:15 am
Thanks for the example and help Strods. I understand it now however I agree with Alex that it's much easier to have the strings even though it is somewhat redundant. Much appreciated if it can be placed back in!
mducharme
Trainer
Trainer
Wed Feb 22, 2017 1:36 pm
I have found what might be a bug in the TR-069 client. If I try setting any parameter to a value with an ampersand (ex. changing identity from MikroTik to Mikro&Tik) through my ACS (GenieACS) it goes crazy and gets stuck in an endless repeating communication loop trying to set the value over and over again unsuccessfully hundreds of times per second until I not only cancel the task in GenieACS but also disable and re-enable the TR-069 on the MikroTik.
The GenieACS developer was not able to reproduce this problem with his non-MikroTik devices. This makes me wonder if it is a bug in the TR-069 stack on MikroTik - can any TR-069 users reproduce this issue?
andriys
Wed Feb 22, 2017 2:36 pm
That's additional data to be sent over the wire, which may be significant on a busy system with lots of registered clients. I believe keeping the SNMP traffic as low as possible by eliminating the duplicates is a good thing.
mducharme
Trainer
Trainer
Wed Feb 22, 2017 2:59 pm
Update: The GenieACS developer says there is a bug in MikroTik's TR-069 client. Any SetParameterValues request that includes an ampersand in the value causes an empty reply to be sent to the ACS by the MikroTik. This in turn causes a problem in GenieACS which is not expecting an empty reply from the MikroTik and resends the request, causing a loop.
normis
Wed Feb 22, 2017 3:05 pm
Yes, we are already investigating this issue
strods
Wed Feb 22, 2017 4:27 pm
Version 6.39rc35 has been released.
Changes since previous version:
*) snmp - fixed CAPsMAN registration table SSID type;
*) snmp - optimized bridge table processing;
*) tr069-client - added "Ethernet.Interface.{i}.MACAddress" parameter;
alexjhart
Wed Feb 22, 2017 5:16 pm
It doesn't get sent over the wire unless requested. Having it there as an option doesnt seem bad. Just don't request it on those busy systems.
Alex Hart
The Brothers WISP
kez
Wed Feb 22, 2017 5:36 pm
I saw this on RB750Gr3. System / Routerboard / Settings. It's possible to see and change RAM frequency via CLI but not via Winbox.
CLI keeps telling me there is a RAM overclock when I run /export, now running at 1200MHz and I didn't changed it.
There is no change log available for Routerboot version 3.35.
Running 6.38.1, posting here because I think this post it's a good place to talk about bugs. If not, I'm sorry.
anuser
Wed Feb 22, 2017 10:48 pm
I am asking myself, whether it is possible to get the values of the amount of users, connected to a specific SSID for a single CAP with SNMP polling the CAPSMAN controller?
alexjhart
Wed Feb 22, 2017 11:07 pm
Looks like you guys got it this time! Thanks for the quick fix.
Still sad you are being stubborn about leaving/adding back the mac OID in there. I think redundancy is a poor argument and believe myself and others will benefit from this being available. So many standard MIBs, including ones you are using (like bridge mib) provide this even if the mac is encoded in the OID in decimal format. Also, using the bridge and arp tables as previously mentioned in this thread are incomplete workarounds in my opinion since the entries in those tables can timeout (or never exist depending on configuration) even when a wireless client is still connected. Most tools don't have a built in way for parsing and converting the mac address from the OID, rather they rely on SNMP index and data provided in the table.
Alex Hart
The Brothers WISP
napismizpravu
Thu Feb 23, 2017 1:56 pm
RB433UAH 6.39rc35 microSD, 2x USB Flash disk, (power 24V 2A)
one USB Flash disk lost (6.38.1. works)
pe1chl
Thu Feb 23, 2017 4:33 pm
IMHO the MAC should always be encoded in the OID as 6 decimal numbers, not as a binary string.
It causes difficulty in scripts that are not binary transparent.
I think it was first started by copying some OID values used by Ubiquiti e.g. for reporting link parameters on an AP by client.
But using 6 decimal numbers instead of the 6-byte binary is much better.
zcybercomputing
Thu Feb 23, 2017 9:24 pm
Does the black list function in the discover info window of the dude client for windows work right in this build? In 6.38.3, and previous versions I don't see the . or ... buttons shown in the manual here.
http://wiki.mikrotik.com/wiki/Manual:Th ... _discovery
There is a related bug where dude discovers phantom devices on the broadcast and subnet IP addresses during discovery discussed here:
http://forum.mikrotik.com/viewtopic.php?f=8&t=118250
strods
Fri Feb 24, 2017 3:01 pm
Version 6.39rc38 has been released.
!) routeros - added support for new products and RouterOS features which will be announced at MUM EU (https://mum.mikrotik.com/2017/EU/info/EN);
*) capsman - fixed "/caps-man manager interface" compact export;
diegotormes
Sun Feb 26, 2017 12:14 am
Good call. We have a month to try it, but at least tell us where to search!
PtDragon
Sun Feb 26, 2017 12:51 am
Yeah, it will be good to know WHAT we are having xD
CCR1036-12G-4S +6x100Mbit ^_^
alexjhart
Sun Feb 26, 2017 2:01 am
Nice plug to get people to attend MUM EU? :)
Alex Hart
The Brothers WISP
korniza
Sun Feb 26, 2017 7:36 am
In this case:
I totally agree! we have to rebuild so many scripts, so many waste of time and many 3rd party software keep failing. Let them as it was!
athurdent
Sun Feb 26, 2017 11:27 am
This version (Edit: no necessarily this specific version, but rc4 is perfectly fine for example) completely broke DFS for me in Germany. My wAP AC resides on the top floor, sometimes no 5GHz clients connected. As soon as I come near it with a client (tested with iPhone 6s, multiple times) it logs something like pasted below. I'm pretty sure it interprets clients looking for WLAN APs as RADAR. Please fix this! It's the same for a hAP AC with the current stable version (v6.38.3).
Feb 26 10:06:12 mikrotik-wap-ac wireless,info wlan2: radar detected on 5580000
Feb 26 10:06:17 mikrotik-wap-ac wireless,debug wlan2: must select channel
Feb 26 10:06:17 mikrotik-wap-ac wireless,debug wlan2: radar reported on 5580000
Feb 26 10:06:17 mikrotik-wap-ac wireless,debug wlan2: radar reported on 5260000
Feb 26 10:06:17 mikrotik-wap-ac wireless,debug wlan2: selected channel 5500000
Feb 26 10:06:17 mikrotik-wap-ac wireless,debug wlan2: search for radars on 5500000
Feb 26 10:07:17 mikrotik-wap-ac wireless,debug wlan2: no radar detetected, start network
at 10:07 I was already back downstairs, going up again and leaving the phone there the following happens:
Feb 26 10:20:14 mikrotik-wap-ac wireless,info wlan2: radar detected on 5500000
Feb 26 10:20:19 mikrotik-wap-ac wireless,debug wlan2: must select channel
Feb 26 10:20:19 mikrotik-wap-ac wireless,debug wlan2: radar reported on 5580000
Feb 26 10:20:19 mikrotik-wap-ac wireless,debug wlan2: radar reported on 5260000
Feb 26 10:20:19 mikrotik-wap-ac wireless,debug wlan2: radar reported on 5500000
Feb 26 10:20:19 mikrotik-wap-ac wireless,debug wlan2: selected channel 5180000
after selecting a non-DFS channel I see my iPhone connecting to the AP in the logs.
mducharme
Trainer
Trainer
Mon Feb 27, 2017 2:42 am
Now that TR-069 support is basically here and working, I would like to request a change to the RouterOS Main Package:
Could you please have the IPv6 package enabled by default instead of disabled? Or at least provide a means of enabling the package in NetInstall?
We want our TR-069 managed customer routers to have IPv6 enabled and configured when they receive them - the way things are set up currently, the customer router needs to be rebooted after they boot it up for the first time in order to enable IPv6 and apply the IPv6 config. Our defaults script applied by NetInstall can enable the IPv6 package but can't configure the settings until the router is rebooted because the package isn't active yet. This makes things much more awkward for us.
Thanks.
sergejs
Mon Feb 27, 2017 11:42 am
alexjhart, MAC-address is not present in /interface wireless registration-table print oid either, and it is calculated in the same way as for capsman table OIDs.
alexjhart
Tue Feb 28, 2017 5:18 pm
It's there in the bridge table and i wouldn't mind it for the wireless registration table too, but I was focused on capsman here. Especially since it was there, then removed. Feel free to add it for the wireless registration table too. :)
Alex Hart
The Brothers WISP
normis
Wed Mar 01, 2017 10:08 am
thanks for the report, the next RC will have fix for this
mducharme
Trainer
Trainer
Wed Mar 01, 2017 7:14 pm
Great!
And for the IPv6 package, any way of having that enabled by default in the main package with NetInstall? We need a solution for that - before it didn't matter so much, but now that you have TR-069, we need IPv6 turned on when the router first boots up after NetInstall.... Maybe you could just put up a second copy of each RouterOS main package which was the same except had IPv6 enabled by default, in a different folder on your web server, for those who needed it?
ex. regular package at https://download2.mikrotik.com/routeros ... 39rc38.npk and ipv6 default enabled package at https://download2.mikrotik.com/routeros ... 39rc38.npk
Thanks.
Sob
Wed Mar 01, 2017 7:30 pm
Or it could be simply made enabled by default for everyone. It's 2017 already, about time...
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
mducharme
Trainer
Trainer
Wed Mar 01, 2017 7:55 pm
Yes, either/or.. However I suspect that they haven't been switching the main package to IPv6 enabled because then they would need a default IPv6 firewall config (at least a basic one to block all input except from the local bridge so that people on the WAN subnet can't login with webfig or winbox via IPv6), and existing devices would not have this in their factory default config scripts. However at least putting up this package as an alternative main package for people who use NetInstall and replace the default config script anyway - that should be safe, and it strikes me as something that they could do almost immediately.
soonwai
Thu Mar 02, 2017 12:33 pm
RB2011UAS-2HnD on 6.39rc38
No scripts scheduled. Freshly rebooted. I have these environment variables. Any ideas what they are?
strods
Thu Mar 02, 2017 1:14 pm
Version 6.39rc40 has been released.
!) l2tp - added fastpath support when MRRU is enabled;
!) ppp - implemented internal algorithm for "change-mss", no mangle rules necessary;
!) pppoe - added fastpath support when MRRU and MLPPP are enabled;
*) hotspot - show Host table commentaries also in Active tab and vice versa;
*) ike2 - fixed responder subsequent new child creation when PFS is used;
*) ipsec - deducted policy SA src/dst address from src/dst address;
*) ipsec - fixed SA address check in policy lookup;
*) ipsec - updated tilera classifier for UDP encapsulated ESP;
*) snmp - added back MAC address OID in "/caps-man registration-table" (introduced in 6.39rc33);
*) tr069-client - added basic support for "/ip firewall filters";
*) tr069-client - added support for escaped entity references (& < > &apos; &quot);
*) tr069-client - close connection if CPE considers XML as invalid;
*) tr069-client - fixed special escape characters on XML data send;
*) tr069-client - general improvements on reducing storage space;
*) usb - added support for more CP210X devices;
*) wireless - do not allow equal MAC addresses between multiple Virtual APs when same master interface is used;
*) wireless - fixed rare crash on nv2 configurations;
ulysses
Thu Mar 02, 2017 1:26 pm
I LOVE the new script property of DHCP client. But something very basic seems to be missing - in my case the DHCP server is _not_ the gateway. However I don't see the gateway-address or like variable available. Any chance this can be added soon?
BTW, although offtopic, is there a way to inspect :local variables in the current scope? like environment but for the current scope including the local variables?
psannz
Thu Mar 02, 2017 1:46 pm
Does this fix the IPSEC packet re-ordering problem?
viewtopic.php?f=1&t=112545
Chupaka
Thu Mar 02, 2017 1:48 pm
as a workaround:
:put [ /ip dhcp-server network get [ find $leaseActIP in address ] gateway ];
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
soonwai
Thu Mar 02, 2017 2:46 pm
RB2011UAS-2HnD updated to 6.39rc40.
PPPoE client connects. Local and remote address acquired but nothing works.
• RB2011 unable to ping 8.8.8.8
• "/system package update check-for-updates " unable to resolve dns.
Edit: Just noticed the default route to remote address is unreachable.
PPP profile's "Change TCP MSS" is and has always been Yes.
MTU & MRU not set (1480)
FastTrack is currently disabled.
Not sure how to diagnose.
Disabled PPPoE client. Changed to my backup link (routed through my neighbour) and everything is fine.
strods
Thu Mar 02, 2017 4:16 pm
soonwai - This seems to be an issue which we managed to reproduce locally. If it is the same problem, then it will be fixed in next rc release.
soonwai
Thu Mar 02, 2017 5:00 pm
Awesome, thanks for the quick reply.
msatter
Thu Mar 02, 2017 8:20 pm
Same problem here of PPPoe working but no traffic shall pass. Torching the PPPoe connection makes it active till you stop torching it. :?
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47.1 / Winbox 3.24 / MikroTik APP 1.3.14
alexjhart
Thu Mar 02, 2017 9:05 pm
Details?
Alex Hart
The Brothers WISP
alexjhart
Thu Mar 02, 2017 9:06 pm
Many thanks :)
Alex Hart
The Brothers WISP
macsrwe
Forum Veteran
Forum Veteran
Thu Mar 02, 2017 11:39 pm
No dude client on the MikroTik website for this release, and auto-update attempt from older dude gives error: bad http response from cloud. Help!
msatter
Fri Mar 03, 2017 12:07 pm
To which posting of Soonwai did you respond because I see the posting about the Variables and the one about PPPoE.
I have the same problem with PPPoE working but no traffic until I torch the connection and I have to keep torching. I am now back on the current release of RouterOS and can't go back to a working (lower) version of RC anymore.
Running:
bennyh
Fri Mar 03, 2017 1:02 pm
I have too problem with PPPoE in RC40 with RB3011. When I ping the RB's address from pppoe client, there is no answer.
Torch trick is working, until it running I can ping the RB.
msatter
Fri Mar 03, 2017 1:23 pm
I did already downgrade so if you are still om RC40 check if the default route present in menu "IP" "Routes"?
line: DAS 0.0.0.0/0 xxx.xxx.xxx.xxx reachable pppoe-out 1
Running:
citko
Fri Mar 03, 2017 1:50 pm
I have a problem with ipsec and xauth. If the xauth user name is longer than 30 characters, in the log you can see "Trimming Xauth user name". The Xauth login fail. If I cut the Xauth name to 30 characters or less, the Xauth login succeed. The original Xauth user name was "Luedenscheid_luedenscheid-aussenstellen".
With RouterOS 6.37.4 there is no problem.
11:15:58 ipsec,info respond new phase 1 (Identity Protection): 111.11.56.87[500]<=>99.231.204.198[500]
11:15:58 ipsec,info ISAKMP-SA established 111.11.56.87[4500]-99.231.204.198[4500] spi:6a36407b8d013957:e691c0e0be04100d
11:15:58 ipsec,error Trimming Xauth user name
11:15:58 ipsec,info No mode-cfg configured
11:15:58 ipsec,info XAuth login failed for user: Luedenscheid_luedenscheid-auss
11:16:02 ipsec,info respond new phase 1 (Identity Protection): 111.11.56.87[500]<=>99.231.204.198[500]
11:16:02 ipsec,info ISAKMP-SA established 111.11.56.87[4500]-99.231.204.198[4500] spi:436a58d94cf6c650:75a152295ad122d1
11:16:02 ipsec,info XAuth login succeeded for user: Luedenscheid_luedenscheid-a
11:21:18 system,info device added by admin
msatter
Fri Mar 03, 2017 2:38 pm
Here you can read about the lead up to this "trimming":
viewtopic.php?f=21&t=116354&p=576081&hi ... th#p576081
Running:
citko
Fri Mar 03, 2017 2:54 pm
Thanks, but I have the problem with the Xauth user and not with the password!
blajah
Fri Mar 03, 2017 3:15 pm
Confirming PPPoE went down on RC40. Cannot test torch trick atm.
I have bigger routing table.
strods
Fri Mar 03, 2017 3:30 pm
Version 6.39rc41 has been released.
soonwai
Fri Mar 03, 2017 4:58 pm
Thanks strods, that was quick.
Just tested, 6.39rc41 fixes both the environment vars and pppoe-client problems.
blajah
Fri Mar 03, 2017 7:17 pm
Tnx for quick fix. Confirming PPPoE is working as expected.
napismizpravu
Fri Mar 03, 2017 7:37 pm
6.39rc40 working
6.39rc41 no working
power off/on no test
pietroscherer
Trainer
Trainer
Fri Mar 03, 2017 9:16 pm
Somebody with performance problems on 6.39RC38? Neither updates it's possible to do :(
I think that netinstall is needed.
https://drive.google.com/file/d/0B1G8TB ... sp=sharing
* I'm using hap lite and system resources are ok. CPU at 2% and RAM at 50%.
Pietro Scherer
http://www.tchesolutions.com.br [ISPs Consulting and Training]
http://www.routermage.com [Backup and Automation System]
:D
ulysses
Sat Mar 04, 2017 6:34 pm
as a workaround:
Thanks! Can't yet try it; is the dhcp-server already configured by the time the script runs?
ulysses
Sun Mar 05, 2017 11:41 am
Thanks for the hint, Chupaka, used it to make the code that actually works for the usecase.
:local gatewayAddress [/ip dhcp-client get [find dhcp-server=$"server-address"] gateway]
@Mikrotik team
Paste is not working in the terminal window.
macOs , Chrome Version 56.0.2924.87 (64-bit)
expert
Sun Mar 05, 2017 3:35 pm
Is the RSTP problem fixed? viewtopic.php?t=118320&f=13#p585480
soonwai
Sun Mar 05, 2017 6:05 pm
RB2011UAS-2HnD-IN ROS v6.39rc41
Can't copy & paste in WebFig Terminal. Tested on Mac OS X 10.8.4, Chrome 49.0.2623.112 (64-bit) & Firefox 48.0.2.
Unable to login to WebFig using Safari on iPad 1 iOS 5.1.1. ERROR: Internal Server Error after clicking Login.
Chupaka
Sun Mar 05, 2017 11:18 pm
Huh, my bad, I was thinking about dhcp-server when I was writing the answer. Glad you still found it useful :)
citko
Mon Mar 06, 2017 11:14 am
In RouterOS 6.39rc41 we have still the problem with ipsec and xauth. If the xauth user name is longer than 30 characters, in the log you can see "Trimming Xauth user name". The Xauth login fail. If I cut the Xauth name to 30 characters or less, the Xauth login succeed. The original Xauth user name was "Luedenscheid_luedenscheid-aussenstellen".
With RouterOS 6.37.4 and before there is no problem.
nescafe2002
Long time Member
Long time Member
Mon Mar 06, 2017 11:19 am
"If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash."
Please report your issue to support, no need to repost here every N days. Support usually responds within a few business days.
strods
Tue Mar 07, 2017 2:02 pm
Version 6.39rc45 has been released.
!) firewall - discontinued support for p2p matcher (old rules will become invalid);
*) hotspot - fixed redirect to URL where escape characters are used (requires newly generated HTML files);
*) l2tp-client - fixed IPSec policy generation after reboot;
*) l2tp-client - require working IPSec encryption if "use-ipsec=yes";
*) l2tp-server - added "use-ipsec=required" option;
*) lcd - show fan2 speed only if it is available;
*) tr069-client - fixed "AddObjectResponse" “InstanceNumber†value;
*) tr069-client - set CHR license ID as ".SerialNumber" value to avoid "no serial number" error in ACS;
athurdent
Tue Mar 07, 2017 2:15 pm
Any news on the DFS issues? Haven't heard back from my ticket either...
BartoszP
Tue Mar 07, 2017 2:22 pm
What is the reason to drop it ?
Real admins use real keyboards.
raffav
Tue Mar 07, 2017 2:25 pm
I think that is because it not so much efficient in this days any more
Enviado de meu XT1580 usando Tapatalk
normis
Tue Mar 07, 2017 2:28 pm
Three reasons:
1. None of the protocols in the p2p filter are used today. Limeware? Kazaa? Really ... ?
2. This matcher also caught non-p2p traffic and interrupted normal communcations
3. You can duplicate the functionality with l7 filters. In fact, p2p filter is the same as L7 filter, but L7 has more customisation
BartoszP
Tue Mar 07, 2017 4:31 pm
Thank you for explanation.
aboiles
Tue Mar 07, 2017 6:27 pm
CHR v6.39rc45 update error, the interfaces are missing.
console error- info failed: std failure: timeout (13)
system reboots at 16% when trying to run supout.
restored from backup (6.39rc41) and retried the package update, same results.
rzirzi
Tue Mar 07, 2017 7:40 pm
RB493G - THE SAME - BRICKED! after update to 6.39rc45.
Its...... loading and ...reboots ... loading and ...reboots ... loading and ...reboots ... loading and ...reboots
Only Netinstall to 6.38.3 - helped.
So - version 6.39rc45 have a BIG BUG!
rextended
Tue Mar 07, 2017 9:37 pm
Three reasons:
4. Most of the actual P2P protocol use https / ssl / tls = no readable packets
5. MikroTik staff do not waste time to identifyng all p2p protocol, but is better to think about 17GHz, 24GHz, 60GHz, 802.11ad, MU-MIMO 5GHz (802.11ac Wave 2), powerline (homeplug) etc. ;)
I'm Italian, not English. Sorry for my imperfect grammar.
poizzon
Tue Mar 07, 2017 11:41 pm
v6.39rc45
CCR1009-8G-S-S+ - Bricked
951G-2HnD - Working
poi
soomanyquestions
Wed Mar 08, 2017 8:00 am
Rb2011 and hap ac bricked also
gargola
Wed Mar 08, 2017 9:43 am
RB1100aHX2 BRICKED, man, this is a RC, not an alpha, can't even think how this happend.
Trying to downgrade to earlier version, unfortunately at this time i'm 250 miles away from the RB, so only can connect through layer2 (MAC) and i'm lossing the connection every X seconds and I can't upload de 11MB system file.
Sob
Wed Mar 08, 2017 11:12 am
The trouble is, MikroTik's naming is not exactly what many people expect. Personally I'd call their "RC" beta if I'd like to be nice, or alpha if I want to be safe.
td32
Wed Mar 08, 2017 11:41 am
you are searching for troubles messing with RC while being 250 miles away...
BartoszP
Wed Mar 08, 2017 12:46 pm
RB411, RB2011, RB962 - upgraded to RC45.
raffav
Wed Mar 08, 2017 1:02 pm
I have 433,433ah, Chr, crs125, base no 2, upgrade to. 45 ok.
But I get 450g that I lost access after updating,
I think is some configuration, that cause the crash and not related to hardware
raffav
Wed Mar 08, 2017 1:06 pm
Just checked, I got a 450g updated normal to 45,so this crash is very specific.
soonwai
Wed Mar 08, 2017 1:46 pm
By any chance, did you have PCQ simple queues on the affected 450G?
raffav
Re: RE: Re: RE: Re: v6.39rc [release candidate] is released
Wed Mar 08, 2017 1:48 pm
No,
I only use simple queue, default settings
One different from both 450
is that on crashed one I have ipv6 packages disabled, and working one it is enabled
strods
Wed Mar 08, 2017 2:28 pm
Seems that we have managed to reproduce this crash which was introduced in last rc release. We will try to fix it as soon as possible and release new version with fix included.
raffav
Wed Mar 08, 2017 2:40 pm
Can you tell what is causing?
gargola
Wed Mar 08, 2017 7:54 pm
Yeap, I'll prefer to name them like that.
Lesson learned with Mikrotik.
BartoszP
Wed Mar 08, 2017 8:51 pm
"Lesson learned ...."
There are three branches: bugfix, current and RC (read it as beta/alpha/test version)
It should be obvious that production system should not go further than "current" despite the name of device manufacturer.
gargola
Wed Mar 08, 2017 8:58 pm
"Lesson lerned ...."
I was having issues with the DHCP offered lease without success, that is why I took the risk.
Fortunately, I just recovered the router with remote hands support. Connected directly I was able to upload the system file through the MAC address winbox connection, just downgrade and we are back in business.
strods
Thu Mar 09, 2017 3:44 pm
Version 6.39rc49 has been released.
!) www - fixed http server vulnerability;
*) capsman - improved CAP status querying;
*) defconf - fixed default configuration generation when wireless package is disabled;
*) ike2 - check child state before allowing rekey;
*) ike2 - send EAP identity as user-name RADIUS attribute;
*) lte - added LTE signal level reading for Cinterion modems;
*) queue - fixed reboot loop when queues were used (introduced in 6.39rc42);
*) rb3011 - added partitioning support;
*) tr069-client - added "Device.Hosts.Host.{i}." support;
*) userman - fixed rare crash when User Manager requested file does not exist on router;
*) wireless - fixed RBSXT5HacD2nr2 small channel support;
rextended
Thu Mar 09, 2017 3:48 pm
please add more details!!!
version affected?
what type of vulnerability?
thanks.
normis
Thu Mar 09, 2017 3:49 pm
version affected?
thanks.
Good morning! :)
viewtopic.php?f=21&t=119308
roneyeduardo
Thu Mar 09, 2017 11:19 pm
Is it about the pppoe-server or just the client?
Thanks.
andriys
Thu Mar 09, 2017 11:48 pm
I guess this is client only.
I don't remember fastpath support for PPPoE server ever being promised.
mducharme
Trainer
Trainer
Fri Mar 10, 2017 4:04 am
A friendly bump on my request to have the IPv6 package enabled by default in the main RouterOS package. :)
We want to get purchasing and rolling out hundreds of MikroTik TR-069 routers to our customers but are holding off until we are able to do this.
MartijnVdS
Fri Mar 10, 2017 7:46 am
Try contacting support by email. They may know of a way to do this, or get you a custom package (especially if you're buying hundreds of CPEs).
rextended
Fri Mar 10, 2017 10:48 am
version affected?
thanks.
Good morning! :)
I think too much to MUM :shock:
normis
Fri Mar 10, 2017 10:49 am
We also need a proper set of firewall rules, simply enabling ipv6 is not enough
strods
Fri Mar 10, 2017 3:22 pm
Version 6.39rc51 has been released.
!) tile - fixed IPsec hardware acceleration out-of-order packet problem, significantly improved performance;
*) tr069-client - fixed write for "Device.ManagementServer.URL";
onnoossendrijver
Fri Mar 10, 2017 6:26 pm
Can you tell more about this?
Does this also improve IPsec on other multicore platforms like RB750GR3?
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
alexjhart
Fri Mar 10, 2017 6:31 pm
This is specifically for the CCR series (both problem and solution). More information here: viewtopic.php?f=1&t=112545
Alex Hart
The Brothers WISP
strn
Fri Mar 10, 2017 8:40 pm
Did anyone else experienced the issue that the complete NAT configuration was gone after rebooting into rc51?
I had to manually rebuild the whole NAT cfg :/
Gesendet von iPad mit Tapatalk
msatter
Sat Mar 11, 2017 12:11 am
No problem over here with the NAT or any other rules.
Running:
Beone
Sun Mar 12, 2017 11:46 am
CAPSMAN controller: CCR1009
Wifi CAPS: WAP AC + HAP AC
v6.36.4:
working fine, reference speed wireless: 250-260Mbit/s
v6.38.x :
- massive wireless issues with capsman (continous disconnects, slow speeds)
- RSTP causing forwarding issues (traffic not forwarding, DHCP not getting through)
v6.39rcXX-51:
- Wireless speed issue: speed only half (~ 140Mbit/s; half speed compared to v6.36.4; downgrading back to 6.36.4 results in higher speed)
Zorro
Long time Member
Long time Member
Mon Mar 13, 2017 11:15 am
is any chance for fix for recent linux breach ?
eg this one:
https://security-tracker.debian.org/tra ... -2017-2636
macgaiver
Mon Mar 13, 2017 11:22 am
eg this one:
... in the Linux kernel through 4.10.1...
RouterOS v6 uses v3.3.6 and don't have hdlc ...you are safe.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
biatche
Mon Mar 13, 2017 1:05 pm
6.38.x severe issues.
setup: gw = rb750gr3 <-> sw = crs125 <-> LAN & ap = wap ac / hap ac
Things have been operational in 6.37.1 750g3,crs125 and 1x wap ac. I have 3 vlans, 1 for management, 2 for lan. I bought another few wap ac and hap ac to add to the network.
First, I upgraded from 6.37.1 to 6.38.5. (some weird stuff happened upgrading CRS125.. more on this in another thread post later that led me to believe that the CRS had become faulty). Anwyay, found that the CRS lost connectivity to the hex although I wasn't yet aware it was a version issue. Hex couldn't mac ping CRS. It was intermittent, after several configuration resets on the CRS, I could get the hex to ping/mac ping the CRS. Thought I had stablized it after that. After solving that, I went on to plug in and out devices. Plugged in the HAP AC to the CRS resulted in the CRS losing connectivity to the hex. SPENT 8 HOURS straight thinking its my configuration issue since its a production environment. Finally, for some reason, I realized it could be a version issue and so I went on to downgrade all the mikrotik devices to the old working version -- 6.37.1. Voila, things seem to be stable again. Also, related or not, while i was on 6.38.5, HAP AC had difficult time (intermittent) picking up a dhcp client ip from the hex.. whether or not its due to the CRS being in between. After downgrading, it picked up the dhcp client ip pretty much immediately. WAP AC was fine though, had always picked up a dhcp address without any issues. So of course it also misled me from thinking theres a version issue.
Alright, I'm very furious. So much wasted time and no profit. What's going on here? is 6.37.x = stable ; 6.38 = beta while 6.39 = alpha? Does Mikrotik warrant their users for such trouble? ALSO Lost a lot of credibility by my client here. I still look forward to IKEv2 so staying on 6.37 is really no solution.
Edit: Do move this post to the 6.38.5 thread, my mistake for posting here.
biatche
Mon Mar 13, 2017 1:11 pm
v6.36.4:
v6.38.x :
v6.39rcXX-51:
I think the issues you mentioned may be related to what I mentioned in #260. Infuriating.
pe1chl
Mon Mar 13, 2017 2:28 pm
Are you sure this is not the issue related to (changes in) spanning tree?
Zorro
Long time Member
Long time Member
Mon Mar 13, 2017 3:43 pm
eg this one:
well, since "3.2 and above(up to 4.11?)" listed as "vulnerable" unless "particular security fix" delivered - it IS VULNERABLE, i guess.
how do you Know(!) that ROS lack "drivers/tty/n_hdlc" in it ?
do you had ROS source-code access ?
macgaiver
Mon Mar 13, 2017 3:57 pm
have you seen HDLC protocol frames anywhere in RouterOS? I haven't...
Just lets take random piece of code from linux and then just assume that it is used in RouterOS and assume that it has the same vulnerability...
This is ridiculous.
JanezFord
Mon Mar 13, 2017 5:40 pm
I have had issues like you on several of the networks I manage and learned the hard way to disable rstp on every mikrotik bridge in the network if using 6.38.x or later version ... guess something is severely broken in bridge rstp. It just doesn't work as expected and makes other devices disappear from network. You will find many posts regarding this issue on the forum. It is not a solution, because rstp is there for a reason but only a workaround if you really need IKEv2.
JF.
biatche
Mon Mar 13, 2017 6:03 pm
JF.
I do not follow how this can be let to happen in a "current" version. My setup is fairly simple and I'm no veteran. I had always had the impression that Mikrotik devices are utilized in corporate environments, schools, banks, etc. and this issue caused major outages. Worst of all I was oblivious to it, not realizing it could be a version issue due to a certain sequence of events. If it had been a simple "I upgraded, and issue started appearing" then I would have suspected its a version issue.
Anyway, as mentioned in post #260, I would like to share what made me think the CRS went faulty.
Initially, the setup was 1x Hex, 1x CRS, 1x WAP AC. Everything was working. I had decided to upgrade to the latest version before deploying more WAP AC and HAP AC. I had upgraded the Hex & WAP AC and they worked. From winbox on the HEx router, I used mac telnet to access the CRS. I tried to initiate the upgrade on the CRS by doing /system package update download which I did on WAP AC and it says "downloading now or something".. but this time it complained being unable to connect and then /system package update install which also complained the same thing. It was only then I realized I had forgotten to set the DNS on the switch. Here's the thing, RIGHT AFTER doing a /ip dns set address=8.8.8.8, i lost connectivity to the switch. WAP AC and clients connected to the switch were still pingable however. It was only a bit later I realized by "neighbors" that the version had been upgraded to 6.38.5. HEre's where I thought I did a bad flash. After resetting the device configuration several times, the device was pingable which also led me to believe that it had a borked flash. The point is: Why the heck did the upgrade happen when it complained that it can't locate the download server which is understoodable because there was no DNS set. Why did upgrade happen on its own after setting DNS? I even thought that bad flash happened because I keyed in the command twice (in similarity)
hedele
Mon Mar 13, 2017 10:05 pm
Well here's the thing. I'm guessing 90% of those corporate, school, bank, whatever networks are definitely _not_ running "current" or "rc" code. In fact, I believe most of them aren't even running "bugfix" code, but even more well-proven, older releases (even if Mikrotiks standard response to literally every single problem report ever is "try current version to see if it is fixed"). I know of several decently-sized ISP networks even that still run on ROS 5.x for that reason.
Once you learn that indeed "bugfix" is the absolute border of what you will want to run in any more-than-lab-sized production network without previous testing, it's really not too bad. I am running 6.37.5 without any trouble at all on a bunch of different (CHR, x86, mmips, mipsbe, tile) devices and generally never had trouble sticking to the "bugfix" tree. If you really really need a new feature or fix in a current or rc version, give that one a thorough lab test followed by a limited production rollout and another testing period before actually rolling it out everywhere. If you don't want or can't follow that procedure, you're better off waiting for the particular fix or feature to soak down into "bugfix" releases.
It's not an issue that's isolated to Mikrotik either. I dare you to go grab the most recent ED IOS versions that Cisco gives away for their kit and carelessly throw it onto your devices. I'm pretty sure _something_ will probably go wrong, somewhere - which is why you'd want to choose a MD branch that's had a couple rebuilds already. Which is what "bugfix" is, more or less.
patrick7
Mon Mar 13, 2017 10:46 pm
I hope banks etc run Cisco, Juniper, or something like this.
mducharme
Trainer
Trainer
Tue Mar 14, 2017 2:39 am
JF.
Did you read the changelog before upgrading? The big warning they have? The issues you are having really sound like they are related to that change:
What's new in 6.38 (2016-Dec-30 11:33):
Important note!!!
RouterOS v6.38 contains STP/RSTP changes which makes bridges compatible with IEEE 802.1Q-2014 by sending and processing BPDU packets without VLAN tag.
To avoid STP/RSTP compatibility issues with older RouterOS versions, upgrade RouterOS to v6.38 on all routers in Layer2 networks with VLAN and STP/RSTP configurations.
The recommended procedure is to start by upgrading the remotest routers and gradually do it to the Root Bridge device.
If after upgrade you experience loss of connectivity, then disabling STP/RSTP on RouterOS bridge interface will restore connectivity so you can complete upgrade process on your network.
In other words, you needed to upgrade the spoke device first (probably the WAP), followed by the CRS and then the Hex, or disable STP first.
biatche
Tue Mar 14, 2017 2:59 am
JF.
Important note!!!
Actually I've been looking/waiting for you on IRC for two days.
normis
Tue Mar 14, 2017 8:28 am
eg this one:
1) RouterOS is not affected
2) Even if it would be, RouterOS users have no ability to run their own programs. It couldn't be applicable anyway.
strods
Wed Mar 15, 2017 4:37 pm
6.39rc54 has been released.
Changes since previous version;
*) ike1 - fixed ph2 ID logging;
*) ipsec - allow mixing aead algorithms in proposal;
*) ipsec - show hardware accelerated authenticated SAs;
*) lte - added initialization for Cinterion;
*) netinstall - fixed typos;
*) ppp-client - added support for Datacard 750UL, DWR-730 and K4607-Zr;
*) snmp - added optical table;
*) snmp - added fan-speed OIDs in "/system health print oid";
*) snmp - fixed rare crash;
*) snmp - improved getall filter;
*) tr069-client - added "Device.WiFi.NeighboringWiFiDiagnostic." support;
*) tr069-client - added Upload RPC "2 Vendor Log File" support;
*) tr069-client - fixed "Device.ManagementServer." value update;
*) tr069-client - fixed crash on =acs-url change special case;
*) userman - allow "name-for-user" to be empty and not unique;
*) wireless - fixed false positive DFS radar detection caused by iPhone 6s devices;
alexjhart
Wed Mar 15, 2017 10:43 pm
Where can this be found?
Alex Hart
The Brothers WISP
Sob
Wed Mar 15, 2017 11:38 pm
I don't see anything in WinBox, but CLI has new flag "H - hw-authenc" in "/ip ipsec installed-sa print".
alexjhart
Thu Mar 16, 2017 12:04 am
Thanks. Not sure how I missed that when printing before. Guess I was looking for a yes/no value, not flag. Makes sense.
Alex Hart
The Brothers WISP
IntrusDave
Thu Mar 16, 2017 12:46 am
Is there any possibility that WinBox could highlight the algorithms that are hardware accelerated on each platform?
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
alexjhart
Thu Mar 16, 2017 1:10 am
You mean putting this information into winbox? https://wiki.mikrotik.com/wiki/Manual:I ... encryption. Couldn't hurt. I could see it being useful to make that information more readily available in the data sheets/brochures on routerboard.com too.
Alex Hart
The Brothers WISP
IntrusDave
Thu Mar 16, 2017 1:13 am
Yes, exactly.
David Joyce
Beone
Thu Mar 16, 2017 1:47 am
- Wireless + CAPSMAN: what about airtime fairness and bandsteering?
alexjhart
Thu Mar 16, 2017 1:50 am
Probably best requested as new reply in viewtopic.php?f=1&t=45934 or topic in viewforum.php?f=1 (might already exist too)
Alex Hart
The Brothers WISP
nz_monkey
Thu Mar 16, 2017 9:28 am
I have requested this a few times, and each time I get pointed at the Wiki..
I really wish they would do this, even if it was under "/system resources" and showed which algorithms are accelerated in hardware.. It's all there in dmesg so the dev's can easily obtain the information.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
strods
Thu Mar 16, 2017 1:12 pm
Version 6.39rc55 has been released.
!) bridge - fixed BPDU rx/tx when protocol-mode=none;
*) api - fixed double dynamic flags for "/ip firewall address-list print";
*) console - fixed DHCP/PPP add-default-route distance minimal value to 1;
*) console - fixed "/ip neighbor discovery" export;
*) console - fixed crash;
*) console - fixed incorrect ":put [/lcd get enabled]" value;
*) userman - automatically select all newly created users to generate vouchers;
biatche
Thu Mar 16, 2017 8:01 pm
before you release final version, which i do feel is drawing near..... please test vlans on CRS bridge + HAP AC.. all on the latest version.
bajodel
Long time Member
Long time Member
Thu Mar 16, 2017 8:06 pm
can we have more information on this? thanks
athurdent
Fri Mar 17, 2017 9:13 am
This is not fixed, the problem still persists.
vmiro
Mon Mar 20, 2017 2:38 pm
I had a problem on one of my WAP ac where the wlan interfaces are not added to the bridge. Clients can connect but there is no communication with the router. And the protocol mode was set to none...
WAP ac have enabled cap and is getting the configuration from CAPsMAN. This is how the problem reflects on my configuration ;)
mIRO
strods
Mon Mar 20, 2017 4:08 pm
athurdent - Please write to support@mikrotik.com and send supout file from device with this version and after you have tested this fix
athurdent
Mon Mar 20, 2017 6:51 pm
strods - I already have a ticket open, Uldis asked me for remote access last Friday. Have not heard back yet, but you should already be able to access my device.
JimmyNyholm
Tue Mar 21, 2017 1:17 pm
Fixed as in now we do forward all bpdu's transparrently or now we eat all transparrently What is done exactly?
Need to know so we may plan for the changed behaviour.
anuser
Wed Mar 22, 2017 3:09 pm
v6.36.4:
v6.38.x :
v6.39rcXX-51:
I´m in the same situation: throughput is rather low. I have CAPSMAN with WAP AC devices.
Chupaka
Wed Mar 22, 2017 3:12 pm
In WebFig, it's possible to move (drag'n'drop) rules even if the list is sorted not by rule number. In WinBox it's not possible :)
uldis
Wed Mar 22, 2017 6:04 pm
v6.39rcXX-51:
We need more info how to reproduce this problem. Step by step so we could try to reproduce this problem.
What wireless packages you used on the 6.36.4 and did you downgrade both CAPsMAN and CAP?
palhaland
Fri Mar 24, 2017 9:27 am
I think I have found an issue with the RC.
Steps to reproduce:
1. On a RouterOS 6.38.x create a backup of the setup.
2. Upgrade to 6.39rcXX-xx
3. Reset the board.
4. Apply backup
5. After reboot RouterBoard has no configuration.
BartoszP
Fri Mar 24, 2017 11:22 am
Backup should be restored to same version of ROS as i have been made.
You should try /export your configuration if you want to restore it to the newer version of ROS
anuser
Fri Mar 24, 2017 12:45 pm
v6.39rcXX-51:
So I tested with CAPSMAN => Configuration => Distance set to indoors AND CAPSMAN => Configuration => Rates empty setting.
distance between laptop and accesspoint: ~30cm
CAPSMAN Controller (x86) version is: 6.39rc55
- So I tested with an HAP AC with serial number: 673706EDxxxx, Windows 10 Pro with Intel 4965AGN
6.36.4(5GHz): ~5MB/s
6.37.5(5GHz): ~7MB/s
6.38.5(5GHz): ~50KB/s to 1,7MB/s . Throughput is going up and down. Mostly at KB/s speed
6.39rc55(5GHz): ~8MB/s.
- New test with an WAP AC with serial number: 69A505A1xxxx, Windows 10 Pro with Intel 4965AGN
6.38.1(5Ghz): ~7,2 MB/s
6.38.5(5GHz): ~7MB/s
6.39rc55(5GHz): ~5MB/s to ~7,5 MB/s
- New test with an WAP AC with serial number 711E06ECxxxx, Windows 10 Pro with Intel 4965AGN
6.35.4(5Ghz): 6,4MB/s
6.36.4(5Ghz): 6,5MB/s
6.38.5(5 GHz): 6,2 MB/s
6.39.rc55(5 Ghz): 4,4MB/s to 6,4MB/s
6.39.rc55(2.4Ghz): 2,4MB/s to 3 MB/s
strods
Fri Mar 24, 2017 12:50 pm
Version 6.39rc58 has been released.
*) certificate - SCEP client now supports FQDN URL and port;
*) ethernet - added "voltage-too-low" status for single port power injector devices;
*) ethernet - fixed unnecessary power cycle of powered device when changing any poe-out related setting on single port power injector devices;
*) ethernet - reversed poe-priority on hEX PoE and OmniTIK 5 PoE to make "poe-priority" consistent to all other RouterOS priorities;
*) fetch - added "http-data" and "http-method" parameters to allow delete, get, post, put methods (content-type=application/x-www-form-urlencoded by default);
*) ike2 - fixed CTR mode;
*) ike2 - remove old SA after rekey;
*) ipsec - fixed SA authentication flag;
*) lte - added log entry for SMS delivery report;
*) ntp - restart NTP client when it is stuck in error state;
*) smb - fixed different memory leaks and crashes;
*) smb - fixed share path on devices with "/flash" directory;
*) userman - fixed rare web interface crash while using Users section;
pe1chl
Fri Mar 24, 2017 4:58 pm
What does "all other RouterOS priorities" mean?
Note that packet priorities are inconsistent with queue priorities.
(when setting a packet priority e.g. "from DSCP high 3 bits", value 7 is higher priority than value 0, but when setting up a queue tree,
a lower priority value means higher priority for that entry)
And then we do not even consider that in 802.11p, the place where the packet priority is used, the priorities from low to high are like
this: 1 0 2 3 4 5 6 7 because 0 is the default priority leaving no room for a below-normal priority.
picacho99
Sat Mar 25, 2017 9:15 pm
A RB3011 with a regular configruation when upgraded from v6.38.5 to v6.39.55 or v6.39.58 device becomes unusable: reboots again and again until it is recovered with reset and netinstall.
palhaland
Sat Mar 25, 2017 10:05 pm
Does this apply to upgrading from 6.38 as well? Currently it clears all configuration when upgrading as well
IntrusDave
Sun Mar 26, 2017 8:02 pm
I has this same issue. I think it may be from the addition of the partition support.
David Joyce
zcybercomputing
Mon Mar 27, 2017 3:18 am
I had this problem going from v6.38.4 to 6.38.5 on the RB3011 also. Unfortunantly the router is one of my main routers, and I didn't have a spare so I couldn't debug. I did have extra packages installed and was running dude.
Users browsing this forum: eworm, Spirch and 37 guests
