Cascuda
Usage GPON module SFP in Spain
Mon Jan 02, 2017 6:53 pm
Hello
I live in Spain and my provider "Orange" usage PLOAM psw to indentify the ONT in the OLT. This method its used by other ISP as Movistar, Vodafone and etc. These companies usage the normative ITU-T Rec. G.984.3 that sayed in step 10.2.2 "ONU state specification" the metod of valitation:
Operation state (O5)
Once in this state, the ONU can send upstream data and PLOAM messages as directed by
the OLT. Additional connections can be established with the ONU as required while in this
state. Once the network is ranged, and all the ONUs are working with their correct
equalization delay, all upstream bursts will be synchronized together between all the ONUs.
The upstream transmissions will arrive separately, each one in its correct location within
the upstream GTC frame
I can usage others models of ONT "Alcatel Lucent G-010G-P - Huawei HG8240 or Edge Core GG-11000" but before, I have to modify the value PLOAM psw or IdOnt "IdONT is equal to PLOAM psw" and next the ONT run well in the network of ISP.
My questios is, how can I send the PLOAM psw from the GPON Mikrotik?
CarlitoxxPro
Re: Usage GPON module SFP in Spain
Tue Jan 10, 2017 12:44 pm
Actually we tested the module many times and don't get stablish the connection whit the OLT for this reason. The ID ONT is no way to set/send through a ploam messsage to the OLT with this module.
We have a many custommers interested in this solution, to use a more cheap and robust hardware like mikrotik, and avoid the poor hardware of their ISP's, but for the moment mikrotik no respond the questions, and I think the best option is go away to another brand like cisco or telnet, a little bit more expensive but they offer this solution.
regards
pukkita
Trainer
Trainer
Tue Jan 10, 2017 12:48 pm
Write to support directly asking and reasoning (or linking to this post) the need.
Cascuda
Tue Jan 10, 2017 1:49 pm
Hello Pukkita,
I've talked with support and they responded:
There is a new firmware in development at the moment. When it's released then it will be possible to change various registration ID's and Passwords in the module. At the moment however it is not yet know when it's going to be released.
Also current batch modules will only be upgradable through OLT.
Best regards,
Krisjanis
MikroTik.com
Come to the MUM conferences, registration open in Central America (Guatemala City), Colombia, Khabarovsk, Novosibirsk, Europe (Milan), Vietnam, Cambodia!
http://mum.mikrotik.com/
Then the users of the Spain Comunity, we'll have to wait by one solution...
CarlitoxxPro
Tue Jan 10, 2017 5:21 pm
We sent a few messages to mikrotik support and we sended the questions to others resellers/distributors to know if they have a solution for this but any have a solution.
How it's possible than mikrotik no have an estimated date to release the new firmware? and can be possible configure the module with the ONT ID like any other conventional ONT
We think the configuration of the ONT ID should be via a new configuration section on the router, via console or winbox. that is the correct and the easy way.
regards
pukkita
Trainer
Trainer
Tue Jan 10, 2017 11:14 pm
All companies have limited resources and have to prioritize their goals, moreso in the Disruptive Tecnologies market segment, where companies need to move fast and adapt to market conditions.
As far as I could read Support has said that ONTs with current, non-configurable firmware will require an OLT to be upgraded to the new firmware when it's released, but nowhere is said it won't be configurable by the user once it has been upgraded to the new firmware.
I'm asumming you're speaking from a FTTH user perspective (not provider). In such case, I usually setup the ISP ONT in bridge mode, and connect a suitable routerboard for the bandwidth (RB951Ui, hAP AC/AC lite, RB3011...) most times is cheaper.
Alferez
Wed Jan 11, 2017 10:35 am
I'm in the same situation with Movistar.
Today I received a Huawei SFP that I try to change the Idont directly when reading and writing the eprom of the SFP.
This option is because after consulting the support the answer was that it was not possible to change this parameter.
Correct or wrong i will comment the result in this post.
Regards.
Hola,
Yo estoy en la misma situación con Movistar.
Precisamente hoy he recibido un SFP de Huawei al que pretendo/intentaré cambiarle directamente el Idont al leer y escribir la eprom del SFP.
La única opción era esta precisamente porque después de consultar al soporte la respuesta fue que no era posible cambiar este parámetro.
Salga bien o salga mal iré comentando en este mismo post el resultado.
Un saludo.
Cascuda
Wed Jan 11, 2017 10:44 am
In my case, I want it for my house and is to have only a router.
Now I have my “RB2011UiAS-2HnD-IN” mikrotik and the “Alcatel Lucent G-010G-P” ont of Orange to connecting to Internet. But always you have a dispositive where you not have the all control about him. :oops:
As me, other people and companies of Spain or other countries are looking for the same solution... and I have hope to Mikrotik can help to get it.
Cascuda
Wed Jan 11, 2017 10:53 am
Regards.
Hola,
Un saludo.
All the comments are well received.
I hope you have chance of is firts person on connect to the OLT of ISP without the electronic from them.I hope to read your results soon
CarlitoxxPro
Thu Jan 19, 2017 1:41 pm
We receive this documentation from MOVISTAR (spain), where is detailed how it works the FTTH service.
https://www.telefonica.es/documents/254 ... 31d6b3955a (in spanish)
The interested part is this: "6.5.2 PROCESO DE ACTIVACIÓN BASADO EN PLOAM PASSWORD" ----> Trans: 6.5.2 Activation process basen on PLOAM PASSWORD
The Mikrotik SFP-ONU have write-protection?. if interesting if anyone have a eeprom programer to try set the S/N and LOID/idONT/PLOAM PW values of the old ONT(ISP Provided) in the SFP module and try if works.
We have the SFP-ONU module but not the eeprom programer (is expensive 260€ aprox).
Alferez
Fri Jan 20, 2017 3:34 pm
In spanish:
Esto confirma lo que yo comentaba. Esta es la prueba que tengo pendiente. Tengo para poder programar tengo un sfp de huawei para cambiar el s/n. Desconozco si el de Mikrotik está protegido.
Primero probaré con este que es el que tengo a la mano e indicaré si ha funcionado o no.
Lo que entiendo es que ese S/N que ellos llaman es el famoso IDont que tiene configurada, ya que el S/N de mi ONT no corresponde con mi IDont y si fuera el S/N Físico no se podría cambiar una ONT por otra sólo con ese número.
In BAD English:
This confirms what I said. This is the test that I have pending. I have to be able to program I have a huawei sfp to change the s / n. I do not know if Mikrotik is protected.
First I will try with this one that is the one that I have at hand and will indicate if it has worked or not.
What I understand is that the S / N they call is the famous IDont that they have configured, since the S / N of my ONT does not correspond with my IDont and if it was the Physical S / N it would not be possible to change an ONT for another Only with that number.
Alferez
Wed Jan 25, 2017 12:05 am
He estado buscando más información, ya que tengo que tirar la fibra hasta el mikrotik desde la ont.
He encontrado los distintos métodos :
SN authentication: The OLT detects the serial number (SN) reported by an ONT. If the SN is consistent with the OLT configuration, authentication is passed and the ONT goes online. This mode requires recording all ONT SNs. Hence, it is used to confirm auto discovery ONTs and is not applicable to adding ONTs in batches.
Password authentication: The OLT detects the password reported by an ONT. If the password is consistent with the OLT configuration, the ONT goes online normally. This mode requires planning ONT passwords and does not require manually recording ONT SNs. Hence, it is applicable to adding ONTs in batches. The password authentication provides two discovery modes: always-on and once-on.
always-on: After first password authentication is passed, no SN is allocated and password authentication is always used in subsequent authentications. This discovery mode is easy for future maintenance. In the always-on discovery mode, configuration is not required to be modified when an ONT is replaced and only the password is required. The always-on discovery mode has lower security. If other users know the password, the users will illegally have service permissions.
Once-on: After first password authentication is passed, an SN is automatically allocated and password+SN authentication is used in subsequent authentications. An ONT can go online only after the correct password and SN are entered. The once-on authentication mode has high security. After an ONT is replaced or the password is mistakenly changed, the ONT needs to be configured again, which requires more maintenance effort.
SN+password authentication: The OLT detects the password and SN reported by an ONT. If the password and SN are consistent with the OLT configuration, the ONT goes online normally. This authentication mode has the highest security but it requires manually recording ONT SNs.
LOID+CHECKCODE authentication: defined by a telecom operator. In this authentication mode, LOID has 24 bytes, and CHECKCODE has 12 bytes and is optional. Whether 24 bytes or 36 bytes are used for authentication depends on data planning, which is unified over the entire network. The OLT determines whether LOID+CHECKCODE reported by the ONT is the same as the configured one. If they are the same, the ONT authentication is passed. If they are different, the OLT obtains the ONT password and compares it with the last 10 bytes of the LOID. If they are the same, the ONT authentication is also passed. This operation is for compatibility with the ONTs using password authentication.
Entiendo que nosotros usamos sólo password porque podemos cambiar sin problemas el ont por otro, por ejemplo un hgu,y ahí cambiamos la Mac pero sigue funcionando siempre y cuando pongamos el idont.
Por lo que leo éste otro post de aquí :
http://forum.mikrotik.com/viewtopic.php?t=103383
From China, LOID not is Module Vendor SN,
Vendor SN in EEPROM A0H, Address 68~83 Byte, Size is 16 Byte,
Loid in EEPROM A2H, Address 190~213 Byte, Size is 24 Byte
And....
Password for Loid in EEPROM A2H, Address 214~225 Byte, Size is 12 Byte
So....
Your need wirte to EEPROM for change Loid
aarango
Thu Jan 26, 2017 8:52 am
Hola a ambos. Disculpad por entrometerme en un tema sobre GPON y SFP, pero tengo una duda en cuanto a la ONT - Mikrotik y aprovecho el habla hispana para decirlo ya que veo que tenéis algo montado similar a lo que pretendo.
Tenemos fibra con Movistar y quiero enchufar la ONT al router Mikrotik (CCR1016), ¿qué configuración debo hacer en el router de Movistar para que todo el tráfico pase al router Mikrotik y sea este quien gestione todo? ¿Poner el router movistar como Bridge en el panel del router? ¿alguna extra configuración?
Gracias.
Cascuda
Thu Jan 26, 2017 11:23 am
Gracias.
Spanish:
Tienes que poner el HGU de Movistar "Todo en Uno" en modo Bridge y luego en tu Mikrotik levantas la conexion PPoE. Lo malo de esta configuracion, es que la gestion de las Vlan's la sigue gestionando el HGU de Movistar. A mayores, si quieres usar un Softphone dentro de tu red "Mikrotik" tu tendras que habilitar en el HGU "Enable IGMP Multicast Proxy" y luego en tu Mikrotik hacer una ruta static de este poll 10.0.0.0/ 8 hacia el HGU.
English:
You've to put the HGU MOVISTAR "All in Onel" in bridge mode and then in your mikrotik router configurate the PPoE connection. A problem this configuracion is that the HGU MOVISTAR continue with the Vlan management. Also if you want configurate a Softphone on your mikrotik network, you has to enable in the HGU "Enable IGMP Multicast Proxy" and next in your mikrotik you have to configurate a static route 10.0.0.0/8 submit to HGU Router.
Sorry moderators for writing in Spanish.
pukkita
Trainer
Trainer
Thu Jan 26, 2017 11:31 am
Being this a country-specific usability issue, there's no problem as long as you post on both languages.
aarango
Fri Jan 27, 2017 8:10 am
Gracias.
Spanish:
English:
First, I'm sorry to use spanish in this post.
Spanish:
Vaya fastidio que no podamos deshacernos del router de Movistar de ninguna manera. Entonces entiendo que a grandes rasgos es poner el router Movistar en Bridge y luego configurar el PPoE server en el router Mikrotik con los datos de conexión y listo, ¿no?
Gracias
English:
Its a shit that we can't drop out our Movistar's router. I understand that I should setup Movistar's routre as bridge and after setup PPoE server on Mikrotik with details connetion. dont?
Thanks.
Alferez
Fri Jan 27, 2017 11:36 pm
Yes, but first you need activate vlan 2 and 6 in ethernet cable. Vlan 2 with dhcp for voip and vlan6 with ppoe client for internet conection.
Cascuda
Mon Jan 30, 2017 1:49 pm
If have the HGU rouuter "All in One" this point it's not necesary.
pukkita
Trainer
Trainer
Mon Jan 30, 2017 2:38 pm
Spanish:
Gracias
English:
Its a **it that we can't drop out our Movistar's router. I understand that I should setup Movistar's routre as bridge and after setup PPoE server on Mikrotik with details connetion. dont?
Thanks.
Cliente PPPoE, no server PPPoE. Dependiendo del sitio, la ONT en bridge pasa la conexion de datos por Vlan6 o no.
En todos los sitios que he mirado recientemente ya no pasan las VLANs en modo bridge, por lo que has de "colgar" el cliente PPPoE directamente de la ether que conectes a la ONT.
In English:
PPPoE client, not PPPoE server. Depending on location, the bridged ONT will use Vlan6 for data, or not.
Most recent installs I've been looking at no longer hand out VLANs in bridged mode, so you need to put the PPPoE client directly on the ether interface connected to the ONT.
CarlitoxxPro
Mon Jan 30, 2017 4:35 pm
Our Parthner SFPTotal try to help us in this case and this is their response about that:
If I understand correctly, we are talking about Mikrotik SFP GPON ONU.
It's ONU in the form factor of SFP based on Marvel SoC. This module working on Linux OS (Mikrotik firmware) and have XML configuration files, which contain all PON connection parameters. Often ISPs use the GPON ONU authentication procedure using the serial number and PLOAM password as unique client code (ITU-T G.984.3).
This is config file:
<?xml version="1.0"?>
<cnfg>
    <PON>
        <!--  PON serial number - up to 8 symbols   -->
        <PON_serial_num>MKTK00010203</PON_serial_num>
        <!--  PON serial source: 0 - xml, 1 - digit part is taken from MAC lower 4 bytes-->
        <PON_serial_src>1</PON_serial_src>
        <!--  PON password - up to 10 symbols   -->
        <PON_passwd>1234567890</PON_passwd>
        <!--  PON SN disabled: 0 = FALSE, 1 = TRUE    -->
        <PON_dis_sn>0</PON_dis_sn>
        <!--  gem reset on fiber disconnect: 0 = FALSE, 1 = TRUE    -->
        <PON_gem_reset>0</PON_gem_reset>
        <!--  tcont reset on fiber disconnect: 0 = FALSE, 1 = TRUE    -->
        <PON_tcont_reset>1</PON_tcont_reset>
        <!--  PON Dying Gasp polarity: 0 = low, 1 = high    -->
        <PON_DG_polarity>0</PON_DG_polarity>
        <!--  PON XVR Burst Enable Polarity: 0 - high; 1 - low    -->
        <PON_XVR_burst_enable_polarity>0</PON_XVR_burst_enable_polarity>
        <!--  PON XVR Polarity: 0 - high; 1 - low    -->
        <PON_XVR_polarity>1</PON_XVR_polarity>
        <!--  P2P XVR burst enable polarity: 0 - high; 1 - low    -->
        <P2P_XVR_burst_enable_polarity>1</P2P_XVR_burst_enable_polarity>
        <!--  P2P XVR Polarity: 0 - high; 1 - low    -->
        <P2P_XVR_polarity>0</P2P_XVR_polarity>
        <!--  gem ports restore after return from State 7: 0 = FALSE, 1 = TRUE -->
        <PON_gem_restore>1</PON_gem_restore>
        <!--  Psa FEC Ind Bit Hyst: number of fram 1-4 -->
        <PON_fec_hyst>1</PON_fec_hyst>
        <!--  Coupling Mode: 0 = DC, 1 = AC -->
        <PON_coupling_mode>1</PON_coupling_mode>
    </PON>
</cnfg>
We had to open the module and remove the memory chip to get this information.
Unfortunately, our programming boards can't help you in this issue, because they are designed to program modules throught I2C interface.
To change config file you should demount SPI flash and fix image of the memory,
or connect to console of the module through serial port interface. It possible, but we haven't information about contacts on PCB.
If you find better way to solve this issue, pls, let us know.
Why mikrotik does not help us with this issue adding a feature in the routerOS to modify these values like a conventional ONT?
They can sell many more sfp-onu modules, routers/switches, not just individuals, but also that we, as a company, would create commercial channels to take them to a much wider market.
Alferez
Mon Jan 30, 2017 4:50 pm
Yes, it is absurd because they themselves close commercial options with it. When companies like TP-Link create ONT devices you can configure IDont without problems. Hopefully not a feature left for RouterOS 7
Si, es absurdo porque ellos mismos se cierran puertas comerciales con ello. Cuando empresas como TP-Link crean dispositivos ONT que puedes configurar el IDont sin problemas. Esperemos que no sea una característica dejada para RouterOS 7
aarango
Tue Jan 31, 2017 8:41 am
Muchas gracias a todos por vuestra ayuda. Finalmente no he tenido mayores problemas, no necesité configurar el PPoE cliente (no sé si esto irá en perjuicio del servicio o no), ¿debería ponerlo con PPoE?. Mi router es el de "All in one".
Tiré un cable desde la ONT a la boca 1 ethernet del router Mikrotik y luego la boca 2 la puse a un switch para llegar a todos los equipos.
En el router de Movistar no toqué nada (lo deje por default), y en el router Mikrotik, sí que configuré la ethernet1 con una IP del router (ej: 192.168.1.2), luego la boca 2 puse un rango mio (192.168.100.0/24), le puse una ruta (en route) que fuera la GW del router de Movistar y ya tuve conexión a internet sin problemas.
Ya que estoy, aprovecho para una 2ª duda, ¿qué pasos debería dar para conectar una segunda línea de internet al mismo router Mikrotik? Quiero conectar dos líneas en Mikrotik, no a modo de balanceo, si no por tener dos líneas y que ambas pasen el tráfico por Mikrotik y poder controlarlo.
Gracias.
English:
Thanks you for our help. Finally, I hadn't problems. I didn't need setup PPoE client (should I do it?). My router is "All in One".
I used a cable from ONT to port 1 ethernet of router Mikrotik. After I connected port 2 to switch.
In Movistar's router I didn't setup anything (all default), and in the router Mikrotik, I configured eth1 with same Ip router Movistar (ej: 192.168.1.1) and after eth2 I used a own range (192.168.100.0/24). I setup a route on Mikrotik with same GW Movistar and I successfully had connection without problems.
BTW, I have a doubt, what steps should I do to connect a second connection to same router Mikrotik? Not rolling, only to keep control 2 lines.
CarlitoxxPro
Tue Jan 31, 2017 11:12 am
And....
So....
you have success changing the ploam password from the A2h memory block?
Cascuda
Tue Jan 31, 2017 5:03 pm
I hope this information can help to Increase interest of Mikrotik to develop a new version of Soft
pukkita
Trainer
Trainer
Tue Jan 31, 2017 8:03 pm
Cascuda: remember to upgrade to this new version, an OLT will be required, as the only interface to the EEPROM is SPI...
Cascuda
Wed Feb 01, 2017 10:42 pm
Yes, you are right. But I hope buy a new GPON with the new firmware upgrade.
CarlitoxxPro
Thu Feb 02, 2017 12:07 pm
That information is not completly correct, let me explaint. to upgrade firmware version on ONU's, you have many methods to perform this.
-the first and the more common is the telecharge via OLT
-the second is using a EEPROM SFP programmer like a revelprog is + sfp adapter or in worst case, using the Adapter SOIC-16/DIL-8 300mil ZIF (FLASH SPI)
-the third is load .bin file directly on ONT (conventional ONT's) via WEB/GUI / Console connection.
-the fourth method, and the we proposed for this case, update directly on a routerboard/routerOS (feature) uploading the .bin from file or auto download/telecharge from mikrotik servers.
for the last method and thinking than routerboard needs to support many ONU-SFP vendors, they need prepare a compatibility table of the diferent models soported for this feature (Update Firmware/ update specific info like Serial / ID / pass) because a few vendors have re-write protections on they modules and a password is required for this operations. but all mothules have the same logic structure, stablished on the standards like SFF-8079 and others.
pukkita
Trainer
Trainer
Thu Feb 02, 2017 12:16 pm
That isn't electronically feasible with current modules, but will with next generation batch according to Krisjanis support email::
I highly doubt Mikrotik doing this, what would be the point? On a scenario where the router would be a mikrotik, and the SFP ONU a different vendor's, SFP ONU will be matched to same vendor OLT. Why would Mikrotik complicate theirselves having to support other vendor's, or would you need to reprogram it?
CarlitoxxPro
Thu Feb 02, 2017 12:50 pm
It is totally possible, but that is not in the hand of anyone
mikrotik should offer support in the older version of SFP-ONU module and a viable method to upgrade the older firmwares to all customer level's, (Service Providers, Home/Office Users, Resellers, ETC)
At least just for mikrotik modules
Alferez
Thu Feb 02, 2017 10:50 pm
Sorry for the delay but I've been disconnected for other problems.
Today I tried to take up the problem and read the eeprom of the Huawei sfp.
I am accessing with a raspberry via i2c, but I can not access the a2h memory map. If I access the a0h.
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 03 04 01 71 33 00 00 00 01 10 99 03 0d 00 14 c8 ???q3...?????.??
10: 00 00 00 00 48 55 41 57 45 49 20 20 20 20 20 20 ....HUAWEI
20: 20 20 20 20 00 00 00 00 48 50 53 50 32 31 32 30 ....HPSP2120
30: 20 20 20 20 20 20 20 20 00 00 00 00 05 1e 00 68 ....??.h
40: 00 1c 00 00 30 36 30 35 36 35 36 54 44 XX XX XX .?..0605656TDXXX -------> Edited
50: XX XX XX XX 31 33 30 39 32 34 31 34 58 80 03 fc XXXX13092414X??? -------> Edited
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Connector Type = SC
Transceiver is 10GBase-ER
Wavelength = 1310.0
Vendor = HUAWEI
Partnumber = HPSP2120
Serial = 0605656TDXXXXXXX ---------> Edited
date = 13092414
cc_base = 68, sum = 68
extended cc_base = fc and sum = fc
Internal SFP Temperature = 0.67C
Internal supply voltage = 0.07V
TX bias current = 1.02mA
Optical power Tx = 2.76 dBm
Optical power Rx = -inf dBm
Can someone help me try to access that memory position?
SmileoffA
Sat Feb 04, 2017 6:14 am
How did you get write access to the addresses A0H? describe the way!
Alferez
Sat Feb 04, 2017 8:41 pm
For write i use this:
i2cset -y 1 0x50 0x1b 0x20
access to 0x50 at position 0x1b and write 0x20
omnigoro
Sun Feb 05, 2017 1:36 pm
English:
Spanish:
Hola, soy nuevo en el foro y en redes, yo también estoy tratando de montar una configuración similar. Tengo el HGU (Askey) de Movistar y la próxima semana me llega el Mikrotik rb3011. Me gustaría usar el Mikrotik como router neutro y dejar que el HGU (modo bridge) gestione la IPtv y la VoIP, dejando al rb3011 la gestión de la LAN interna, pero también estoy interesado en poder utilizar un softphone desde la LAN interna. El problema es que debido a mi inexperiencia no veía como hacer toda esta configuración posible. Por lo que veo tu has conseguido hacer que funcione perfectamente una configuración similar. Estaría enormemente agradecido si pudieras compartir los detalles de tu configuración via script o similar. Muchísimas gracias por adelantado!
English:
Hi, I a newbie in the forum and about networks, and I also trying to do a similar configuration like yours. Movistar has just installed an HGU router (Askey) and next week it will arrive the Mikrotik rb3011. I'd like to use the Mikrotik as a neutral router an let the HGU (bridge mode) manage IPtv and VoIP, with the rb3011 managing the internal LAN. But I'm also interested in using a softphome from the internal LAN. The problem is that due to my lack of experience I can't figure out how arrange things to make this configuration works! However, as I can see, you've got it with a very similar configuration. I would be greatly grateful if you could share the details of your configuration via script or something like that. Thank you so much in advance!
Alferez
Sun Feb 05, 2017 3:05 pm
Spanish:
Debes poner el router en modo bridge o en este modelo es monousuario si no recuerdo mal.
Tienes que configurar en el mikrotik tanto la vlan2 (voz) como la vlan6 (datos), en la vlan2 levantas un dhcp y en la 6 el cliente ppoe.
Para que la voz pueda pasar debes realizar unas cuantas configuraciones en el router. Te dejo un ejemplo https://www.alferez.es/configurar-hgu-m ... ar-voz-ip/ (si los administradores lo ven oportuno eliminen el enlace)
English:
You must put the router in bridge mode or in this model is monousuario if I remember correctly.
You have to configure in the mikrotik both the vlan2 (voice) and the vlan6 (data), in the vlan2 you raise a dhcp and in the 6 the client ppoe.
In order for the voice to pass you must make a few configurations on the router. I leave you an example https://www.alferez.es/configurar-hgu-m ... ar-voz-ip/ (if the administrators see fit, delete the link)
omnigoro
Re: RE: Re: Usage GPON module SFP in Spain
Sun Feb 05, 2017 6:51 pm
Spanish:
Gracias, la parte del HGU la tengo más o menos clara. Con respecto a la configuración del mikrotik, tenía entendido que no había que configurar ninguna VLAN, que ya se las pasaba el HGU, al menos la de datos! Y sí, sabía que hay que configurar el PPPoe en el interfaz WAN (ether1) y el dhcp-server en el interfaz LAN (ether6) de donde cuelgo un switch que conecta mis dispositivos. Pero, por ejemplo, no es necesario definir, también, un dhcp-client en el interfaz pppoe-out1, para recibir una IP del HGU?? Me pierdo con los detalles, sobre todo la parte de la configuración de VOip en el mikrotik!!
English:
Thanks, the HGU's configuration is more or less clear. As for Mikrotik's one I had understood that it wasn't necessary any VLAN configuration because HGU passed the VLANs to the Mikrotik, at least the data VLAN (VLAN 6). And yes, I knew that it's necessary to configure the PPPoe on interface WAN (ether1) and dhcp-server on interface LAN (ether6) where is connected a switch which connects my home devices. However, isn't also necessary to define a dhcp-client on interface pppoe-out1 in order to receive an IP address from HGU?? I'm lost in details, specially as it concerns to VOip's configuration on Mikrotik!!
Enviado desde mi Nexus 5 mediante Tapatalk
Cascuda
Mon Feb 06, 2017 9:35 am
Spanish:
Hola onmigoro, the Router HGU "Todo en Uno" ya gestiona las VLAN. Tu solo tienes que configurar en el Mikrotik el cliente PPoE, un servidor DHCP para que de direcciones Ip en tu red y luego una simple configuración de Firewall.
Si necesitas más ayuda, házmelo saber.
English
Hello omnigoro, the HGU router "All in One" alredy gestion the VLAN. You only have to configurate in the Mikrotik the PPoE client, DHCP server for to give IP in your network and then one simple firewall configuration.
If you need more help let me know
omnigoro
Mon Feb 06, 2017 10:00 am
Spanish:
English
Spanish:
Gracias Cascuda! Entonces, no hace falta también un dhcp-client en el interfaz pppoe-out1 para que coja una IP de la red del HGU? Este finde cuando me llegue el router me pondré manos a la obra. Tengo miedo meter la pata y dejar a mi hijo sin poder jugar a la PS4 y a mi mujer sin internet! Luego, cuando funcione lo básico me gustaría que me contarás los detalles de la configuración de VoIP en el mikrotik para poder usar un softphone desde la LAN. Gracias de nuevo!
English:
Thank you Cascuda! So, isn't necessary a dhcp-client on pppoe-out1 in order to obtain an IP address from the HGU'S network? This weekend, when the Mikrotik router arrive, I'll try to do the job. I'm afraid to make a mistake and leave my son without being able to play PS4 and my wife without internet access! Then, once the basic configuration works fine I'll be very pleased if you could tell me the details of VOip's configuration on Mikrotik for being able to use a softphone from internal LAN. Thanks again!!
Cascuda
Mon Feb 06, 2017 11:44 am
Spanish:
Si es necesario. Pero en mi caso, yo lo tengo configurado una IP fija en el Mikrotik para poder acceder al HGU y desabilidado en el HGU el Servidor DHCP. "Cuando tenia Movistar"
English
if is need. But in my case, I have configurate an ip fixed on the Mikrotik Router to acces the HGU Router and also I have disconnected the DHCP server in the HGU Router
omnigoro
Re: RE: Re: RE: Re: Usage GPON module SFP in Spain
Mon Feb 06, 2017 11:54 am
Spanish:
English
Spanish:
English:
Spanish:
English
Spanish:
Ah, tiene sentido! Pero si se deshabilita el dhcp-server del HGU, como coge IP el desco de Movistar tv?
English:
Ah, it makes sense! But if you disable dhcp-server on HGU how is assigned the IP address for Movistar's tv desco?
CarlitoxxPro
Mon Feb 06, 2017 3:29 pm
For Everyone
This forum theme is only for relevant information about SFP-ONU modules not for any other types of consults (already answered and documented in many webs)
https://www.adslzone.net/postt311611.html
http://comunidad.movistar.es/t5/Soporte ... 33#M172376
if you have a other type of issue not related with the SFP-ONU modules please feel free to open a new topic on the forum.
Cordial Regards.
omnigoro
Re: RE: Re: RE: Re: RE: Re: Usage GPON module SFP in Spain
Mon Feb 06, 2017 6:10 pm
For Everyone
Cordial Regards.
Sorry, it was my fault! If you don't mind, any other doubts about router configuration will be placed on the Router OS forum under a more appropriate topic!
Regards
iperezandres
Fri Feb 17, 2017 11:14 am
I am another user pretty interested in having my Mikrotik as the unique device connected to my ISP fiber optic network, instead of having an ONT in the middle.
The solution for this problem relies on Mikrotik developing a firmware capable of changing the SN of the SFP module with our ONT's SN, and being able to set the ONT ID or PLOAM PWD manually (in my ISP case, it is equal to the ONT SN).
Thanks to you guys, this thread might "help" Mikrotik to face this issue.
Regards.
Cascuda
Mon Feb 20, 2017 11:07 am
This is another user pretty interested in having my Mikrotik as unique device to connect to my ISP fiber optic network.
As far as I have been reading around, this solution for this problem relies on Mikrotik developing a firmware capable of changing the SN of the SFP module with our ONT's SN, and being able to set the ONT ID or PLOAM PWD manually (in my ISP case, it is equal to the ONT SN).
Thanks to you guys, this thread may be able to "force" mikrotik to face this issue.
Regards.
Yes...We will have to wait by Mkrotik
Ergheiz
Fri Feb 24, 2017 3:07 am
Hi there,
Thumbs up with this post. How it's possible to sell a GPON module for FTTx, and say "all the configuration should be done on the ISP side"?? What is "no configuration required"? FTTx excludes FTTH?? The information on Mikrotik website make you understand that you can introduce the PLOAM in some section inside RouterOS and it already works, or how Mikrotik pretend to identify ourselves towards the ISP?? I dunno if it's possible to ask the ISP to add your module in other countries, but in Spain... surely not. It doesn't make sense to buy this module in Spain, unless the PLOAM it's programmable in the "not too distant future". Very disappointed about this. What solution does plan Mikrotik offer to the "current" GPON module batch owners? A pat on the back and a "bad luck" while smiling, or something? It's the only you understand with the Krisjanis response. This isn't serious. Adapt the business to the market dynamics involves studying it first. Now I understand why this module is refunded so often in this country.
Regards,
Alferez
Sat Feb 25, 2017 1:18 am
Finalmente he podido realizar la tirada de fibra y ya tengo la fibra junto al Mikrotik.
Acabo de conectar el SFP GPON al Mikrotik con el cable de fibra puesto y por lo menos observo que lee valores.
Esta es la información que Mikrotik me devuelve:
status: no-link
auto-negotiation: done
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-lose: yes
sfp-tx-fault: no
sfp-type: SFP-or-SFP+
sfp-connector-type: SC
sfp-link-length-9um: 20000m
sfp-vendor-name: HUAWEI
sfp-vendor-part-number: HPSP2120
sfp-vendor-serial: 0605656TD901XXXX
sfp-wavelength: 1310nm
sfp-temperature: 158C
sfp-supply-voltage: 3.382V
sfp-tx-bias-current: 11mA
sfp-tx-power: 2.759dBm
sfp-rx-power: -28.719dBm
eeprom-checksum: good
eeprom: 0000: 03 04 01 71 33 00 00 00 01 10 99 03 0d 00 14 c8 ...q3... ........
0010: 00 00 00 00 48 55 41 57 45 49 20 20 20 20 20 20 ....HUAW EI
0020: 20 20 20 20 00 00 00 00 48 50 53 50 32 31 32 30 .... HPSP2120
0030: 20 20 20 20 20 20 20 20 00 00 00 00 05 1e 00 68 .......h
0040: 00 1c 00 00 30 36 30 35 36 35 36 54 44 39 30 31 ....0605 656TD901
0050: XX XX XX XX 31 33 30 39 32 34 31 34 58 80 03 fc XXXX1309 2414X...
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0080: 00 ef 00 80 00 ef 00 80 02 f2 02 6b 02 d0 02 8d ........ ...k....
0090: 14 08 00 cd 14 08 00 cd ff ff 00 00 ff ff 00 00 ........ ........
00a0: 02 01 00 09 02 01 00 09 00 00 00 00 00 00 00 00 ........ ........
00b0: 00 00 00 00 00 00 00 00 b1 dc fb 9e 36 bf d3 96 ........ ....6...
00c0: b8 2b db 40 3f eb 8c d3 bf 36 c7 9f 09 c0 00 00 .+.@?... .6......
00d0: 01 00 00 00 dc b7 91 35 30 a6 fe 5a 00 00 00 3d .......5 0..Z...=
00e0: 00 b7 02 b2 02 57 49 bf 00 14 00 00 00 00 00 00 .....WI. ........
00f0: 00 40 00 00 00 40 00 00 00 00 00 00 00 00 00 00 .@...@.. ........
Aunque tiene el cable puesto y recibe los valores de la fibra, marca como link No.
Finally I was able to perform the fiber spin and I already have the fiber next to the Mikrotik.
I just connected the SFP GPON to the Mikrotik with the fiber cable put and at least I noticed it reads values.
This is the information that Mikrotik returns me:
status: no-link
advertising:
sfp-rx-lose: yes
sfp-tx-fault: no
Although it has the cable on and receives the values of the fiber, mark as link No.
Alferez
Sat Feb 25, 2017 1:20 am
Tengo que decir que todo esto ha sido sin poder modificar el valor del ID en la memoria a2 que sigo con esto pendiente.
Conozco a alguien que tiene un operador WISP y fibra que le pregunté sobre el aprovisionamiento de los equipos, tengo pendiente a ver cuando podemos quedar y llevarme el sfp para ver su central que reconoce que hay pinchado y si una vez conociendo el ID puedo localizarlo de alguna manera en la eeprom y modificarlo.
I have to say that all this has been without being able to modify the value of the ID in memory a2 that I continue with this pending.
I know someone who has a WISP and fiber operator who asked about the provisioning of the equipment, I have pending to see when we can stay and take the sfp to see its central that recognizes that there is puncture and if once knowing the ID I can locate it from Some way in the eeprom and modify it.
Alferez
Sun Feb 26, 2017 3:08 am
I continue searching information about it:
Bytes 123 – 126 contain write-only RAM for entry of a 32 bit password that allows
access to user writable EEPROM at locations 128-247. The default password for
Finisar devices is 0, however it can be set to any value at the factory to insure security
of the user writable EEPROM contents. Please contact your Finisar sales
representative for details on setting up a custom password. Once the password has
been entered into locations 123 – 126, a ‘1’ should be written to address 127 (readable
and writeable RAM cell). Note that the power-on default value of byte 127 is ‘0’. Once
these two steps have been completed, EEPROM at locations 128 – 247 is readable and
writable. The EEPROM remains readable and writable until either the password is
changed or byte 127 is set to 0.
Table 3.19: Password Addresses (2-Wire Address A2h)
Byte Bit Name Description
120-122 All Reserved Reserved
123 All Password Byte 3 High order byte of 32 bit password
124 All Password Byte 2 Second highest order byte of 32 bit password
125 All Password Byte 1 Second lowest byte of 32 bit password
126 All Password Byte 0 Low order byte of 32 bit password
127 All User EEPROM Select ‘1’ selects user writable EEPROM at locations 128 - 247
https://www.finisar.com/sites/default/f ... eivers.pdf
But my ID is F2XXXXXXXXXXXX
pukkita
Trainer
Trainer
Sun Feb 26, 2017 3:05 pm
Alferez, are we talking about the Mikrotik SFP GPON module? or a Huawei one???
Alferez
Sun Feb 26, 2017 4:04 pm
Mi sfp is Huawei HPSP2120.
This information are generic of sfp, y think that are same for Gpon.
Cascuda
Mon Mar 13, 2017 10:27 am
Hello Alferez
Do you've any new about Huawei Gpon?
isoria
Fri Mar 17, 2017 9:01 pm
Any improvement about this?
Alferez
Sat Mar 18, 2017 1:31 pm
Hello Alferez
Sorry for not being able to answer before.
I have not been able to do the tests yet since it does not just depend on me, so I do not know that "idont" has my sfp, and until I do not have the idont I will not be able to search it inside the eeprom and make the modification.
Cascuda
Tue Mar 21, 2017 2:58 pm
If we have help by mikrotik, we could have a solution.... The help is simple, only had to update your Gpon and that permit the modifcation of idONT.
Alferez
Tue Apr 04, 2017 3:54 pm
Finally I was able to deliver the sfp today so this person will put it in their network and try to get the idon that appears to him in the registry.
With Idont observer, I will try to look for it in the eeprom and make the change.
I go slow, but I hope to get good results.
iceking2nd
Fri Apr 14, 2017 10:13 pm
Is there any new infomation of the new firmware?
Cascuda
Mon Apr 17, 2017 10:08 am
We be pending of the libration by Mikrotik of new firw. We haven't more info....
Alferez
Mon Apr 17, 2017 10:29 am
In my case, a people that can check my sfp on their equipment, His system no detect my sfp. :(
Does anyone know of any other options to try to detect the sfp idont?
Mikrotik release new sfp module firmware at same time that ros 7????
crc666
Mon Apr 17, 2017 10:08 pm
Not exactly what you are looking for but for the time being... a cheap solution (30euro) and it talks to NaranjaES
Cascuda
Tue Apr 18, 2017 2:22 pm
Do you have a TP-LINK TX-6610 work fine with Orange Spain? We also want this solution but with the SFP of Mikrotik or other manufacturers.
When you installed this ONU, Did you have to talk witn Orange Spain for change? or you only, change the IdONT and all oK ¿?¿?
More info about TP-LINK TX-6610 --> http://www.tp-link.es/products/details/ ... -6610.html
vicentnb1
Tue Apr 18, 2017 10:27 pm
Why in god's name Tp-link can make it and not mikrotik? :lol:
Cascuda
Wed Apr 19, 2017 6:29 pm
I think that Mikrotik haven't interest in update your GPON or create a new GPON... I hope to be wrong....
Cascuda
Wed Apr 19, 2017 6:59 pm
@normis Can you tell us something about this topic? You're of support Mikrotik, Can you tell a expected date for the new firmware of your gpon?
CarlitoxxPro
Wed Apr 19, 2017 7:03 pm
I think like you, they are not interested in exploiting this feature, They do not really care what the customer needs, it is sad, but it is reality, They do not confirm anything or even give a clear answer on this topic.
msatter
Wed Apr 19, 2017 9:19 pm
I read this in the beginning of the thread.
Best regards,
Krisjanis
I can understand that it takes a long time now and the tone is getting bitter reading the last posting. Just politely talk to support and inquire if there is an update on the new firmware.
A lot of things are waiting on the moment for Mikrotik to be tackled and this request is one of many.
crc666
Fri Apr 21, 2017 1:08 am
It synchronizes fast and works well on the optical level. SN and password was taken from my Livebox Fibra (Arcadyan PRV3399B-B-LT) Call to support was not needed.
When I switched to TX-6610 existing routing was still in place. New DHCP renewal/request is currently not possible. It fails the DHCP Option 90 - Authentication.
I found plenty of information on French forums about their Option 90 format (fti/xxxxxx) but not much of information on Spanish forums.
Chinese marketplace website - aliexpress, lists many affordable SFP modules from diffrent manufacturers. I am going to order 2 SFP modules and try to read/write the SN location. Will report back.
Alferez
Fri Apr 21, 2017 3:19 pm
I am trying and for the time the result is not the expected. I can read the eeprom and write it, but the famous idont is elsewhere in memory that I'm not sure whether or not I have access.
iceking2nd
Sat Apr 29, 2017 12:39 pm
New firmware do not have ETA :cry:
alligator57
Mon May 01, 2017 4:32 pm
After reading the last comment, Im very dissapointed with Mikrotik, I have been waiting for this more than a year, and finally mikrotik do nothing for his customer.
Cisco or Huawei can solve that problem, so Bye Bye Mikrotik....
CarlitoxxPro
Wed May 31, 2017 4:50 pm
After an exaustive research and testing, we find the way to reprogram our sfp modules to work with our ISP where idONT (password) is required to authenticate and join into the GPON network
1st: is imposible to reprogram entirely sfp module using a eeprom programer via SFP adapter, the only way is extracting the memory chip (Marvell Avanta MC-88F6601), using an hot airflow pistol to desoldering
after of this you can access to the entirely memory where you find an embeded linux version over and squashfs filesystem.
2 nd: dump the memory content, decompile and modify the file /etc/xml_params/gpon_xml_cfg_file.xml with the followed values:
<PON_serial_num>MKTK00010203</PON_serial_num>  (with the GPON serial number of your old ONT, careful is not the sn of the sticker of the ONT)
<PON_passwd>1234567890</PON_passwd>   the password
3 rd: recompile the rom and reflash the sfp module
4 th: resoldering the memory chip reassambling the module
5 th: inser on your Router/switch and configure to fowarding the connection over this interface, remember configure VLANs if you ISP works with them, and check if all works great, (you need to be sure than the memory checksum is correct or your module dont be recognize correctly by your router/switch)
i hope than this info can help you, Since, none of us receive support from mikrotik and they are not interested in solving the needs of their customers.
Alferez
Thu Jun 01, 2017 10:56 am
Did it work?
Congratulations!!!!
I have in mind another option, since as you say can not be reprogrammed.
I have a second ONT that has integrated fiber optic module.
The idea was to get the pinout of that module and compare it with the sfp.
If it matches (I think I remember what I had already seen is yes) solder an sfp adapter instead of the fiber optic module, in this way try to configure the IDONT on the ONT in the hope that this is written in the sfp.
Here you can see ONT
DeVlL
Fri Jun 02, 2017 12:35 am
I am also from Spain and I have optical fiber with movistar. It would be nice to be able to put any SFP and configure it in the mikrotik directly. Hopefully in the next firmware can be done.
DeVlL
Sun Jun 04, 2017 2:53 pm
Can you take a picture of the inside of the SFP Huawei HPSP2120?
I want to see what chip you have so you can unsolder it and try to change the s / n idont
Thank you
Spanish:
¿Me puedes hacer una foto de la parte interior del SFP Huawei HPSP2120?
Quiero ver que chip tiene para así poder desoldarlo y intentar cambian el s/n idont
Gracias
ntam
Mon Jun 12, 2017 5:32 pm
Hi, I am also want the feature requested in this post, It could be very handy such feature in the routerOS and the GPON compatibility would increase the sales and helps the advanced users.
Mikrotik, take care of this and push up the new firmware with this features..
thanks in advance
Regards,
Nelson.
Alferez
Wed Jun 14, 2017 12:52 pm
Thank you
Spanish:
Gracias
Sorry for the delay
Those are the ones I have on hand and I know they are not very thin, because I left it to try it and have not yet returned it. I hope to have it by the end of next week back.
Perdona que no te contestara antes.
Image Image
Esas son las que tengo a mano y se que no son muy finas, porque lo dejé para que lo probasen y aun no me lo han devuelto. Espero tenerlo a finales de la próxima semana de vuelta.
Alferez
Wed Jun 14, 2017 12:56 pm
I just reviewed my photo and one found here: viewtopic.php?t=88041&start=50
And is my imagination or the SFP of Mikrotik is exactly the same as the one I have?
Acabo de revisar mi foto y una encontrada aquí: viewtopic.php?t=88041&start=50
¿Y es mi imaginación o el SFP de Mikrotik es exactamente el mismo que el que yo tengo?
DeVlL
Fri Jun 16, 2017 8:23 pm
The photos you put do not let the chip see. They are blurred.
In contrast the photos that you comment of the link, the one of the forum of mikrotik already had seen them. Is the chip that has your SFP and the photo shown at viewtopic.php?t=88041&start=50 the same?
Las fotos que has puesto no dejan ver el chip. Están borrosas.
En cambio las fotos que comentas del link, el del foro de mikrotik ya las habia visto. ¿El chip que tiene tu SFP y la foto que se muestra en viewtopic.php?t=88041&start=50 son iguales?
ntam
Mon Jul 10, 2017 12:54 pm
@Mikrotik's team, any news about this? when will You will free the version that let us change the serial (idont )and password for the GPON device?
hurry up!
Regards,
ntam.
souf
Tue Jul 11, 2017 12:29 pm
I'm waiting too for a solution for change the serial (idont) and password for the GPON device.
Regards
Cascuda
Sun Jul 23, 2017 11:18 am
If mikrotik can't help ... We seek a solution to your SFP module and we can say to we have, a module that works well with Orange Spain.
More info --> https://goo.gl/ZfGVfm
CarlitoxxPro
Mon Jul 24, 2017 5:34 pm
Its correct, we found a way to configure correctly a module SFP GPON ONU to work very well with our routers mikrotik and differents ISP in spain like ORANGE, MOVISTAR and JAZZTEL, updating the firmware of our module and setting the SN, SLID(password) and other things required by some ISP like ORANGE and JAZZTEL, via web ui and telnet, no configurations needed on router mikrotik, this works like a traditional ONT (external).
Is very sad than mikrotik doesn't care their customers and dont provide any type of solution to this topic, but our effort to get the solution gived the success and now we are very happy with this solution, after a huge quantity of hours of test and fails, we got it..
+info here: https://www.facebook.com/CarlitoxxPro/
Shadeofspirit
Mon Jul 24, 2017 6:32 pm
good news! it looks like solution not only for your problem! in Belarus is the same situation
Alferez
Tue Aug 01, 2017 2:40 pm
Congratulations!!!!
I guess the sfp itself has a web interface where you configure Idont / Ploam and the connection you make it directly on the sfp just like we had the cable connected to the ont port now.
It is right?
Cascuda
Thu Aug 24, 2017 1:35 pm
Congratulations!!!!
It is right?
Hello friend,
I have the next articule with more explain about how can you simulate the same configuration that we. ---> https://goo.gl/xfKX83
veleth
Wed Oct 11, 2017 12:39 pm
Hi! Such good work here! Has Mikrotik any eta on its own spf module firmware upgrade to make it more "flexible"? I am very disappointed with the Mikrotik GPON-ONU module...
gastonet
Wed Oct 11, 2017 3:38 pm
I'm from Argentina, also waiting for Mikrotik's firmware update.
For now, I only have a paperweight.
Melody5781
Thu Oct 12, 2017 9:34 am
@crc666 Agree. And I know another Chinese web site that do good at fiber optics. In many theads I have seen lists of workable transceivers with Mikrotik gears and the goods from FiberStore was among them. The owners of the other manufacturers' module reported back the testing result to confirm whether it works or not. So the thread also lists not-work transceivers, you can avoid using them if you own exact the same gear.
NoellEagan
Thu Oct 12, 2017 8:06 pm
Hi...i am a new user here. As per my knowledge there are many people, to use a more cheap and robust hardware like mikrotik, and avoid the poor hardware of their ISP's, but for the moment mikrotik no respond the questions, and I think the best option is go away to another brand like cisco or telnet, a little bit more expensive but they offer this solution.
turnkey pcb
Alferez
Mon Oct 16, 2017 7:03 pm
i don't know any other brand that offer this solution. i don't know a ONT Router from Cisco with this feature. In Spain the ISP use a combo with Idont + Serial Number and/or with version number. Mikrotik no aswered because no have this solution only it's compatible with standard or manual systems. Same as Ubiquiti.
Other brands that Zisa make that ONT only have one interface and no is a ethernet, it's a sfp interface.
With this ONT/SFP you can put into a mikrotik, cisco, ubiquiti, because at this device you are conneting a SFP, no a fiber.
d3m0
Thu Nov 23, 2017 4:00 pm
Any update about this topic? I've read all posts in thread but links to valero-torres.es shows website is under manteniance. Anybody has copy of this info? It will be great to include in mikrotik's wiki (although they don't be worth of it)
Thanks!
Delboy
Fri Nov 24, 2017 7:33 pm
d3m0
Sat Nov 25, 2017 12:47 am
Thanks!
jlpedrosa
Wed Dec 13, 2017 3:14 pm
Hi
I´m also interested in this thread A LOT. I´m going to have 1Gb simetric, and I´ll need a good router with ipsec. If Mikrotic would have support to configure all the gpon settings required would be an excellent option.
Any update on the firmware? I´ve seen in other threads that the software version numbers must be configurable to get it up and running, so this also should be a value to be configured
Lisendra
Wed Dec 13, 2017 10:55 pm
Hi
At this moment the main problem is that the SFP GPON (ONT) module isn't configurable at all, from mikrotik, it cast his ID to the OLT of your provider, without password or anything, and it's not some traditional PPPOE connection or similar , the ISP provider will have to accept your ONT SN into his pool on the OLT and it's gonna have to configure it's without a Vlan, there more into this, but just the fact that the ISP has to accept your ONT serial , is the number 1 problem here, most of them see it ( i would also) as a possible security breach since they won't have access on the customer's ONT, won't be able to applie updates for potencial security breach, they will have to follow one more manufacturer's devices for possible critical security breach and so on.
Your best bet is to buy another SFP (there chiness good one actually) and use it since mikrotik isn't able or doesn't want to provide more feature into this product.
I hope this answer help you as best as possible.
Lise.
jlpedrosa
Thu Dec 14, 2017 1:31 pm
For orange spain they even check the Software versions, and they must match the ones they have registered in the OLT, so we need a GPON SFP that is able to do so.
They guy in this forum that manged to do it with the chinse SFP had to re write the firmware manually to cheat the versions.
Do you know of one that has all those settings configurable without making too much magic?
Thanks!
JL
Lisendra
Thu Dec 14, 2017 3:51 pm
Thanks!
JL
Please don't take my word for it, if i remember correctly it was a "ZISA op151s gpon onu ont sfp" the price was in a fork of 50/150EUR piece, but honnestly i would strongly advise to avoid this for now with the mikrotik equipment, the best for you is to just use the ISP's router in Bridge mode , and get everything in the mikrotik by ethernet (the mikrotik does the PPPOE connection throught the ISP's router, it's the best.
I personaly wanted to have my mikrotik direktly connected with the ISP to reduce device faillure and control everything from the source, but honestly if your gonna go for some chiness GPON module that isn't supported officialy by the routerOS then , maybe the best is still to use the ISP equipment, so the ISP isn't gonna start to investigate and freak out on the next software update when your GPON isn't updating like every other ONT from there network.
GPON on mikrotik isn't for tomorow it seem unfortunatly,
best regards,
Lise.
kesthers
Thu Dec 14, 2017 5:12 pm
I recently buyed an ZISA OP151S GPON SFP module,
I successfuly change SN and SLID to match with my ISP (Movistar)
however, I can not establish a connection.
Hal# -----------------ONT Info-----------------
OMCC state : Ready
ONU ID : 1
SN : MSTC2bXXXXXX
Password : F2017XXXXXXXXXXXXXXX
Power Level : 1
Ont State : O5 OPERATION
Ranging State: UNKNOWN
Admin state : UNLOCK
I think problem is in ranging state, that is unknown.
Can anyone help me to find the solutions?
Regards
jlpedrosa
Fri Dec 22, 2017 11:35 pm
Hi Guys
I got a SFP from Zisa, but after pluging it to the router, I don't have a clue how to access the SFP, I've tried telnet from the mikrotik itself or from a lan conencted to the mikrotic, but no signal from ip 192.168.1.1, I've also tried to asign that ip range to the interface, but no luck. Can anyone explain me how to connect to the SFP to connect to it?
Thanks!
jlpedrosa
Sat Dec 23, 2017 6:00 am
Hi
I think you're almost there, I think now you need to create the vlan in the interface (6 for data) and enable dhcp client to get your pub IP and def route. Could you please post the exact steps you followed to get to that state? What values (and how do they look like) for movistar?
Also: I can only connect to the sfp through telnet, when the fiber is connected and only if i open the telnet from the router, it does not work from any pc.. any hint for this?
thanks jl
souf
Sun Dec 24, 2017 1:14 pm
OMCC state : Ready
ONU ID : 1
SN : MSTC2bXXXXXX
Power Level : 1
Regards
do you have any update? works?
Regards
d3m0
Mon Dec 25, 2017 2:44 pm
I'm in the same situation as last posts. I'm trying to get movistar ftth working with Zisa gpon sfp+ module. In my particular case SN matches mac address from HGU all-in-one router/ont/crap provided by ISP movistar.
Hal# show ont-----------------ONT Info-----------------
OMCC state : Ready
ONU ID : 56
SN : e8d1XXXXXXXX
Password : F2017XXXXXXXXX000000
Power Level : 1
any updates?
cfragoso
Mon Jan 08, 2018 2:54 pm
Any updates about this? After reading some of your posts I have bought the ZISA SFP module recently and I will be playing with it as soon as I receive it.
I have a Huawei ONT provided by Movistar/Telefonica (Spain) and a Mikrotik CRS210-8G-2S+IN device as CPE.
If anyone can provide me some insights regarding how to obtain/identify the parameters necessary for negotiation from SFP unit to OLT Telco side.
Anyone already played to substitute Movistar ONTs?
Thanks!
fersat
Wed Jan 10, 2018 7:23 am
Who knows how change mac-address on ZISA SFP? I have downloaded firmware form https://www.valero-torres.es and unpacked it via 7-zip - now I can change etc/config/network. How build modified firmare back with correct checksumms?
huygensvlc
Fri Feb 09, 2018 10:48 pm
I'm in the same situation than you. Any progress with zisa module in Movistar Spain FTTH?
BR
OMCC state : Ready
ONU ID : 1
SN : MSTC2bXXXXXX
Power Level : 1
Regards
huygensvlc
Fri Feb 09, 2018 10:49 pm
Check the SN, I think there are always 4 letters that identify the manufacturer + 8 numbers.
OMCC state : Ready
ONU ID : 56
SN : e8d1XXXXXXXX
Power Level : 1
any updates?
huygensvlc
Mon Feb 12, 2018 9:57 pm
I'm in the same situation than you. Any update?
OMCC state : Ready
ONU ID : 1
SN : MSTC2bXXXXXX
Power Level : 1
Regards
jlpedrosa
Mon Feb 19, 2018 2:22 am
Hi
To configure the Zisa, you need to plug the fiber in, plug the sfp into the router. When it comes online you need to configure an ip into that router sfp leg, of the range 192.168.1.0/24 except .1 which is the IP of the sfp.
then FROM the router, you can connect to 192.168.1.1 with telnet and use user/passd "twmanu" then follow the instructions here: https://www.valero-torres.es
Kr
spaxton
Sun Apr 15, 2018 1:14 am
Hello friends,
I've read it all... I am not from Spain but I have the same situation. I also have HPSP2120 and I wanted to use it with RB953GS but... NO LINK (RX LOSE when I connect the cable). I have seen the solution from @CarlitoxxPro but it seems to be very complicated. Is there any way to easily reprogram this module? Is there any other module which is easily programmable or via MikroTik ROS? Desoldering and programming the chip from it is so hardcore. :D Has anybody found a way to reprogram it without desoldering the chip ?
Best Regards.
ayeranu
Mon Apr 16, 2018 12:41 pm
I've read this and another forums, but I'm not sure to buy the Mikrotik spf gpon module. Not almost the provider develope an official firmware. Are there any news of this?
spaxton
Mon Apr 16, 2018 10:52 pm
How do You mean Mikrotik SFP module? You mean this one https://mikrotik.com/product/SFPONU ? I would buy it if it is going to work... but, what I have learned is that every ONU/ONT must be authorized on OLT side by the provider. They are authorized with the serial number and some of them also with MAC address. If this one from mikrotik allows us to change these parameters then we would be able to use it instead of cheap trash routers. You can check this thread and You will find one post where our mikrotik friend from Spain explains what he did... He had to desolder the chip from SFP module and then program it using the hardware eeprom programmer in order to set a different serial number and other parameters. I hope so some of them will make a post about this to explain us with more details and steps.
Best regards.
spaxton
Mon Apr 16, 2018 11:40 pm
Dear Friend,
Can You let us know what You have exactly did here? Can You make some procedure with steps how did You make it work? Is this with Huawei HPSP2120 or with Mikrotik GPON module?
Best Regards.
vladod
Mon Apr 23, 2018 10:40 pm
Hello to all of you...
I have a similar situation with the OP151S GPON!
But I managed to setup GEMPORT-s and VLAN for IPTV.
So I'm able to se IPTV stream and I can decode it and watch it with VLC,
but my problem is that I can not set up properly UpStram GEMPORT so
I'm no abele to make WAN working!
Does any one know how to set properly WAN on OP151S ???
Best regards!
OMCC state : Ready
ONU ID : 1
SN : ISKTXXXXXXXX
Password : XXXXXXXXXXXXXXXXXX
Power Level : 1
Alferez
Tue Apr 24, 2018 6:23 pm
Dear Friend,
Best Regards.
No it's possible because hpsp is a tradicional sfp module, but disa is a router same as your company's ont, you configure from disa internal website, no from mikrotik interface.
I try use Huawei HPSP2120, at start of post you can see photos, i try rewrite eeprom, but in can't access to memory map zone, and it's more difficult than disa.
andreacoppini
Trainer
Trainer
Fri May 11, 2018 6:24 pm
Just did this, with Orange Spain. Worked straight away.
Goodbye Livebox!
Thanks!
vladod
Sat May 12, 2018 12:46 pm
Nice work andreacoppini!
Could you help me with OP151S which stuck in 05-OPERATION mode (see previous post).
I can manually add GEMPORT-s and then I can see IPTV traffic.
But DHCP is not working and I'm getting error when my ISP provider ty to
attach GEMPORT-s like error = 3009.
Regards!
andreacoppini
Trainer
Trainer
Sun May 13, 2018 6:35 pm
I don't know how to help you. I'm still learning about GPON and I just followed the OP's thread above since I'm with the same ISP using the same SFP.
In your situation, I would start by setting up a known good setup (ie. use the ISP's own ONT/Router/IPTV Box) then sniff the packets by putting a MikroTik between Router and IPTV box and using a bridge.
fernandf
Sat May 19, 2018 7:23 pm
Someone has got the Zisa module working with movistar?
In this link they say it is working with Orange and that it should work with Movistar. https://www.valero-torres.es/2017/08/24 ... de-orange/
How do you get the SLID and the PLOAM from your current ONT?
Any hope to have a Mikrotik solution for this? Do we have an ETA for that indev firmware?
pateutz
Sat May 19, 2018 11:58 pm
Hi Guys,
any news about GPON configuration / solution for RCS-RDS in Romania.
Best Regards,
Daniel
andreacoppini
Trainer
Trainer
Mon May 21, 2018 12:38 am
Orange's LiveBox (ONT+Router+AP combo) actually shows this on the WebUI. When I had Movistar I had a separate ONT + Router, maybe there is a way to get onto the ONT (not the router)'s WebUI and take it from there?
Cascuda
Mon May 21, 2018 12:52 pm
Goodbye Livebox!
Thanks!
Thanks by confirmate the good operation of SFP module with Orange SPAIN.
Cascuda
Mon May 21, 2018 12:57 pm
I can't help now with Movistar (SAPIN) ISP... I think that my partner Carlos to worked more with Movistar and if can... he will write in of forum.
Alferez
Tue Jun 05, 2018 1:27 pm
I configured the Zisa with Yoigo / Masmovil and it worked without problems.
After obtaining the data and configuring it, it worked without problems and the first time.
stbnrivas
Thu Jun 28, 2018 10:08 pm
Howdy! I want to add me to this request to Mikrotik for they implements IdONT via PLOAM into SFP Module because I will can replace ISP's Hardware by Mikrotik's hardware into small companies to get a elegant solution. By now i will buy Zisa Stick to try until I can ... keep a calm and setup Mikrotik
I want give a thanks to Cascuda, CarlitoxxPro, Alferez. They are heroes and this thread is pure gold
vladod
Sat Jul 14, 2018 11:39 pm
HI to all... Can anyone halp me to configure VLAN 100 on OP151S GPON. SO like wan --> wan.100 interface, so i can start udhcpc client to obtain IP address?
andreacoppini
Trainer
Trainer
Sun Jul 15, 2018 6:04 am
Simply add a VLAN interface putting the master interface as the SFP port.
vladod
Sun Jul 15, 2018 10:35 pm
HI andreacoppini,
may be I was a bit unclear. I can't get OP151S SFP in mode to send any data through GPON optics, but I can configure it to be in state 5-OPERATIONAL with ranging UNKNOWN. Even with ranging unknown I can receive packets. I can also configure GEMPORT-s to watch neighbor IPTV traffic, but I can't set the DHCP Client on OP151S to get my IP address. To do that I must set VLAN ID to be 100 (I had sniffed packets on my ISP router). So when I'm using telnet to OP151S I can see 4 interfaces and the wan is configured without VLAN. So if I set vlan manually like wan.100 I can't get any traffic to pass wan except tx packets. Is it possible to put OP151S in bridge mode? My ISP is using VLAN 802.1q and 802.1ad (QinQ), but OP151S is only supports VLAN set through OMCI protocol which is not provided by my ISP.
andreacoppini
Trainer
Trainer
Sun Jul 15, 2018 10:54 pm
Yeah, like I said, you need to define a VLAN subinterface on the Sfp1 port and set your DHCP client (and Nat rules) on the VLAN interface, not SFP.
Most of the time it’s not QinQ but service tag, try setting the VLAN interface to “Service Tag” mode.
If it’s really QinQ, you can configure this on MikroTik too... check the wiki docs
Cascuda
Sun Sep 09, 2018 1:23 pm
I have a new post in my web, where I talk of new gpon module of my partner CarlosxxPro. This module is very customizable and I hope it is the future for new modules from other manufacturers.
Link --> https://goo.gl/gPrjJz
Alferez
Sun Sep 09, 2018 1:55 pm
The one with OpenWRT installed already gives you more options in the configuration.
d3m0
Sun Sep 09, 2018 4:55 pm
Do you mean that zisa module can be flashed with openwrt?
Cascuda
Mon Sep 10, 2018 12:05 pm
You need the CalitosxxPro "GPON-ONU-STICK-CPGOS03-0490" module to use openwrt.
andreacoppini
Trainer
Trainer
Wed Oct 03, 2018 7:14 pm
So I've tried to do this again on a new Orange Spain connection, but this time I can't get it past the INIT stage.
I did change the Serial Number and the PLOAN (ONT Password) on the ZISA SFP, but I suspect that Orange are no checking for firmware version too, but I don't know how to change these on the ZISA.
My Orange Livebox has "AR_LBFIBRA_sp-00.03.05.211D" which seems to have been compiled on Wed Jun 20 17:04:34 2018.
Does anyone know how to change the reported firmware version on the ZISA?
PS: I got in touch with Carlitoxx to buy their SFP, but they are currently out of stock. I'll buy their SFP as soon as they get stock anyway, as theirs is compatible with CCRs and is much easier to configure.
grawerpl
Mon Nov 05, 2018 3:56 am
@Cascuda is there a reason why you blocking access to your page https://www.valero-torres.es form other countries like Poland ?? every time i try i get "403 forbidden access"???
Cascuda
Wed Nov 14, 2018 1:18 pm
Sorry, but i've not blocked any country. It is possible that your public address is on a blacklist, then you can not connect to my website.
Chupaka
Wed Nov 14, 2018 1:57 pm
I get only "Sorry, your request cannot be accepted." (http 403) in my office, in my home and on my phone via mobile operator. Looks like your blacklist is quite big :)
Miracle
Wed Nov 14, 2018 1:59 pm
Only 127.0.0.1 in white list
Cascuda
Wed Nov 14, 2018 5:44 pm
Can you try again ? I've purge the blacklist :D
Chupaka
Wed Nov 14, 2018 5:46 pm
Works now =)
grawerpl
Fri Nov 16, 2018 12:46 am
Now its working :P
Delboy
Sat Dec 08, 2018 3:02 am
Those who bought gpon sfp stick from CarlitoxxPro (CPGOS03-0490), can someone upload flash dump of firmware from it?
d3m0
Sun Dec 23, 2018 3:22 pm
I have a spare Zisa gpon module for sale. If there is someone interested please PM me.
Free shipping to Spain :)
mohands
Tue Jan 01, 2019 11:39 am
is this carlito one or what ?
andreacoppini
Trainer
Trainer
Tue Jan 01, 2019 12:09 pm
Not the carlito one. This is the ZISA module. The one referenced in the above documents before Carlito developed their own SFP (which is never available :-( )
d3m0
Tue Jan 01, 2019 1:09 pm
Yeah that’s right, the first one
mohands
Tue Jan 01, 2019 1:12 pm
contact carlito on facebook, I think he ship, I have this one S-Gpon-Onu from mikrotik, but I don't know why mikrotik doesn't make it easy to change S/N and other papramters to suit ISP ones. Most of ISPs use autoconfiguration for their onu units, and it's impossible that they can allow yours to access their networks
mrspeccy
Tue Feb 19, 2019 2:04 pm
Hi, unfortunately I cannot send you PMs for unclear reasons. I am interested in buying this Zisa module if still available. How much for shipping to Denmark be?
d3m0
Wed Feb 20, 2019 4:50 pm
I cannot send you PM also. Please give me an email or Skype.
thanks!
andreacoppini
Trainer
Trainer
Wed Feb 20, 2019 4:51 pm
Andrea at tacoppini dot com
mrspeccy
Mon Mar 04, 2019 9:38 am
Sorry for the late reply. I was not informed about your post by e-mail and just saw it by coincidence - something seems to be wrong with the forum software.
My e-mail address is hans.laude (at) web.de
fushigi
Tue Mar 19, 2019 2:49 am
Donde puedo conseguir el módulo SFP ONU Stick CPGOS03-0490
Estoy interesado en uno para mí RB4011iGS+RM
Gracias
Where can I get the SFP module ONU Stick CPGOS03-0490
I am interested in one for me RB4011iGS + RM
Thank you
Enviado desde mi SM-G965F mediante Tapatalk
mrspeccy
Tue Mar 19, 2019 9:28 am
@Cascuda
How did you create the modified firmware images for the ZISA OP151S that can be downloaded from https://www.valero-torres.es/? I can study the structure of the files with binwalk, find header, kernel and squashfs and can modify everything with the firmware-mod-kit (https://github.com/rampageX/firmware-mod-kit/wiki). However, the repacked image won't be accepted due to a checksum mismatch.
It seems to me that the first 1024 bytes of the firmware files contain a couple of checksums, e.g. at addresses
0x68
0x208
0x21c
0x220
How are these checksums computed? Any ideas?
elpeter
Tue Mar 19, 2019 11:14 am
Hello everyone!
I'm interested in getting rid of the "All-In-One" router from Movistar and I got excited reading this post and CarlitoxxPro&Valero's work thinking hat there's a slighyhly chance to do it. I was thinking in buying the Mikrotik SFP GPON ONU but I've seen here that there's no way to change it's SN and so on to make the OLT think that it's one of it's ONTs so my question here is, where can I manage to get one of hte Zisa's SFP GPON ONT? I wrote directly to Zisa but they're out of stock and I wrote also to CarlitoxxPro but no answer yet (I wrote to him yesterday thoug).
Thanks for the all the work and keep up the nice job :)
Regards,
Pedro
andreacoppini
Trainer
Trainer
Tue Mar 19, 2019 12:52 pm
Hola Pedro, I have a ZISA stick I’m selling. It used to work for me perfectly on Orange in Barcelona, but I have since moved to Sevilla and moved my Orange service with me and it doesn’t work here. I think the providers have tightened up their ONT checks in the ‘newer’ rollouts - or I’m just unlucky.
Send me an email (scroll up a bit, I wrote it in a previous message), and we can agree on a price.
fushigi
Fri Mar 22, 2019 3:55 am
Aún lo tienes?
d3m0
Fri Mar 22, 2019 10:11 am
Aún lo tienes?
Si, aun lo tengo. Mandame un privado
fushigi
Fri Mar 22, 2019 7:17 pm
Aún lo tienes?
No me me deja mandar mp
d3m0
Sat Mar 23, 2019 1:03 am
Aún lo tienes?
Escríbeme a demo2k6 arroba gmail.com
elpeter
Tue Mar 26, 2019 2:01 pm
Did anybody manage to get the Zisa GPON working with Movistar? If so, please do you mind to share it with us? some screenshots or some Mikrotik terminal commands would be highly appreciated.
Thanks!!
fushigi
Sat Mar 30, 2019 6:53 pm
Has anyone tried the FGS202 GPON SFP ONT module?
mgarcia
Fri Apr 05, 2019 1:46 am
Dear all,
after a long fight with this Zisa SFP I´ll explain my situation:
My Hardware: Mikrotik CCR1036-12G-4S (ROS 6.44.2) + ZISA OP151S
When received the modeule I had to update the firmware to be able change LoID/PloamPWD/IdONT.
After that, logged by Telnet and updated Serial Number by the one of my Mitrastar and cloned also MAC of my ONT. Still not working. (i changed MAC of SFP1) by terminal in my Mikrotik.
I used the steps explained in the link below. Except the mac address change that was my decision after test all other possibilities.
I Can say that I didn't update files nº2 and nº3 that are mentioned in te link. I'm not sure that are extremely necessary in my scenario with Movist.
LOGED IN MITRASTAR by WEB:
192.168.1.1/instalación: 1234/"Mitrastar Password"
- Here we can read IDont, serial and MAC address.
LOGED IN MITRASTAR by SSH: admin/"Mitrastar pass"
> ponshowmac (shows ONT mac address)
> transmitterinfo ( shows vendor name, vendor SN in Mitrastar )
mine shows:
Vendor Name: MSTC_GN25L95
Vendor SN: S180Yxxxxxxxx
I'm not 100% sure but I think there are around 4 left possible causes that are affecting me:
1st: Serial Number to change in Zisa are the ones shown in Mitrastar by ("transmitterinfo" command or the one shown in 192.168.1.1/instalación)
- I can imagine the one in 192.168.1.1/instalación. is the only one that have 4 letters and 8 characters.
2nd: MAC address have to be changed? if true Could we use Mikrotik Terminal? or is can be changed by telnet in Zisa Gpon? I'll still checking.
3rd: Sometimes when Mikrotik shows SFP info like voltage etc.. Mikrotik reboots. (tile/rOS incompatibility) link goes up when fiber plug.. seems all ok. but. (not always shows sfp parameters) I think the most provable cause of fail.
4th: and the most strange thing: we know that this ISP I mentioned uses vlan 6,3,2. when we setup by web interface in Mitrastar router all vlans are created as that vlan ID's.
but: by SSH when in Mitrastar I type command below shows:
> vlantable
Upstream:
TCONT_number GEMport VLAN_id UNI_interface Service Name
273 273 950 ppp0.1 6
274 274 5 veip0.3 2
276 276 3 veip0.2 3
ID 950?
ID 5?
I'll still fighting
Many thanks!
Alferez
Fri Apr 05, 2019 4:03 pm
Zisa is not compatible with Tilera, I have not tried it, but that is what was said.
fushigi
Fri Apr 05, 2019 9:08 pm
Dear all,
Where did you buy the ZISA OP151S module?
mgarcia
Sat Apr 06, 2019 2:03 am
Dear all,
Answering Fushigi: I bought in Alibaba. I bought it for 60€ aprox + premium shipping 4 days. + tax = around 120€ aprox.
well: finally the problem was the firmware version. after update and changing (idONT, Serial Number, MAC ) services are working in Movist. ISP in Spain, for sure the rest also will work. I don't know if MAC have to be changed, but I did it for safety. I heard that ID and Serial are enough.
Firmware Link: segurasoft.es/zisa/TW2362H-CDEL-TW-R01B010D35befddf-CN.squashfs.upf
I have vlan6, vlan3 working, except vlan2 (TV) what for sure is something wrong in my Mikrotik configuration.
when all ready and tested I'll post news.
kind regards to all, and keep pushing!
Error0x29A
Sat Apr 13, 2019 2:37 am
I tried. Module itself is compatible, same Lantiq(Intel) family chipset PEB98036ETV13 (like OP151S)
Facing similar problem as previously: changing Serial Number to match the one from Livebox Fibra.
One of users posted flash dumps if anyone wants to take a closer look.
https://forum.turris.cz/t/orange-france ... ter/3776/4
Error0x29A
Thu Apr 18, 2019 7:32 pm
How is your experience with Zisa? On the Alibaba they mention after-sale support and access to the firmware.
Can you get different firmware versions or ask them to make one, specifically for your needs?
mgarcia
Thu Apr 18, 2019 10:41 pm
Still waiting answer.. I sent some mail but nothing.
If finally you use Zisa try default firmware, my problem was a firmware that became in freezes when trying to upgrade idONT by web, then I found a list of all telnet menu options and was easy to manage in telnet.
after upgrading my firmware to the one I posted few days ago, upgrading idONT from web was fine and the rest by telnet.
Now works really fine the following:
PPPoE over vlan6 for Data, vlan3 for VoIP that works fine also.
What I'm still trying is setup the vlan2 wich is used for IPTV. I have all routes in RIP, interfaces in IGMP Proxy setting etc. All config required by the ISP was configured and checked.
I Understand that if Vlan3 wich is used for VoIP service works vlan2 would be fine too. I don't know if wrong setup by my side or ISP change some setting in that service because was just contracted 2 or 3 weeks ago.
If someone is fighting also with this we can work together.
zlobster
Fri Apr 19, 2019 12:31 pm
Can anyone please post a link where this OP151S can be bought?
All I'm getting some fishy hits on Google... :roll:
saper2
Fri Apr 19, 2019 12:56 pm
Like mgarcia have written, you can find it on Alibaba: https://www.alibaba.com/trade/search?fs ... ext=op151s
Sent from my VTR-L29 using Tapatalk
Error0x29A
Fri Apr 19, 2019 3:24 pm
and don't forget to check "Ready to Ship" option otherwise you will get many irrelevant results.
fushigi
Fri Apr 19, 2019 9:57 pm
Until June they do not have loose units to send in Alibaba.
At least they will be bulk orders.
I got in touch with ZISA CO LTD.
(How many you want to buy for OP151S? because the sample is out of the stocked,so just can provide with bulk orders,there is quantity limit,but the price will lower.)
zlobster
Fri Apr 19, 2019 11:37 pm
Thanks, everyone!
I just want 1 or 2 to try outsmarting the Huawei OLT.
I have a great success with UBNT (hence my avatar) but I will be extremely happy if I can get a working SFP, in order to consolidate the devices needed.
saper2
Sat Apr 20, 2019 1:42 am
You mean ONU/ONT , OLT is in ISP cabinet :)
I'm sorry for off-topic, I hope you're forgive my curiosity ;) : Can you tell what Huawei ONT model you've got from ISP?
zlobster
Sat Apr 20, 2019 9:30 am
No, I really meant outsmarting the OLT (by tricking it to think it is working with an original EchoLife, while it is not).
saper2
Sun Apr 21, 2019 12:49 pm
Right, sorry :) I don't know how I missed the "outsmarting" word :? - my mistake.
Could you share what ONT (the model) you got from ISP ?
zlobster
Sun Apr 21, 2019 1:49 pm
HG8245H by Huehuehuewie
saper2
Sun Apr 21, 2019 3:16 pm
Thanks, the Huehuehuewie made my day [emoji23][emoji1787][emoji23] [emoji106]
portmap
Tue Apr 23, 2019 12:56 am
I’ve got the hg8311 and the zisa gpon stick, i’m trying to get the gpon stick to work and get rid of the huawei device, how can I determine what the idONT, Serial Number, MAC is for the hg8311?
and is that all I need for the gpon stick to work?
Thanks!
Error0x29A
Tue Apr 23, 2019 2:59 am
Thanks!
Look at the box and label. Most information should be there. Huawei devices use the same format:
MAC: 8866390A1F9B
GPON Serial Number: HWTC071F9B93
GPON password should be 10 digits long if listed in ASCII format: 4703578867 or hex(34 37 30 33 35 37 38 38 36 37)
Where is it located?
It will depend on the device or provider. I would start by login to the device by using web and telnet and looking around.
login: 192.168.100.1
username: root
password: admin
Error0x29A
Sat Jun 15, 2019 2:58 am
Has anyone was able to get OP151S modules lately?
I get signals that only supplier is out and will only resume production with minimum order of 100
Are there any other alternatives available?
iperezandres
Sat Jun 15, 2019 10:32 am
I've seen it in alibaba for 60-70$, minimum 1 unit.
Error0x29A
Wed Jun 19, 2019 3:19 am
Thanks.
Even it shows 1 unit, they are Out of Stock at this moment.
iperezandres
Wed Jun 19, 2019 10:27 am
Good to know, we will have to wait...
AntonioLON
Sun Jul 14, 2019 8:38 pm
Hola Friends
Very happy to find this forum. My ZIZA OP151S is working well for my girlfriend in Madrid. I did the serial change and other changes :D
On github I collected packing software for Ziza https://github.com/kovalenko/SFP-GPON
fushigi
Tue Jul 16, 2019 2:33 pm
Alibaba msg
(We need to collect 50pcs to produce,it's minimum quantity,at this moment,there is only 30pcs demand from clients)
Is someone else going to buy?
https://app.alibaba.com/dynamiclink?tou ... cene=buyer
zlobster
Tue Jul 16, 2019 2:56 pm
Alibaba msg
Count me in! I can pay later for my piece(s) via PayPal later.
I may even get 2 SFP.
AntonioLON
Mon Jul 29, 2019 6:46 pm
Hola Friends
friend in Valencia asked for me help. he got good SFP stick. lot of options to modify serial\vendor\part number\ and more. sticks have open source openwrt
login web 192.168.1.57 or telnet to sfp
OEM company\\ dipperoptics\dpoptics stick numero D23446
Licensee company \\ hilinktech\ stick number HL23446
andreacoppini
Trainer
Trainer
Mon Jul 29, 2019 7:13 pm
Where did you buy it?
AntonioLON
Mon Jul 29, 2019 7:41 pm
let me check with friend, I think it was alibabba
saper2
Mon Jul 29, 2019 7:56 pm
Hola Friends
Here is this SFP [emoji3] :
http://www.dpoptics.com/col.jsp?id=290 (in main menu is link to their Alibaba account).
Here is hilink:
https://www.hilinktech.com/pon-sfp-xfp/ ... h-mac.html
Error0x29A
Thu Aug 15, 2019 5:11 pm
sticks have open source openwrt login web 192.168.1.57 or telnet to sfp
What is the benefit of running openwrt on SFP? There's no wireless.
saper2
Thu Aug 15, 2019 8:56 pm
Openwrt is is for routers (for routing) not just for managing ap wifi. Openwrt have that same purpose like RouterOS from Mikrotik, but openwrt is open source [emoji3]
vdias
Mon Aug 19, 2019 12:58 pm
Hola Friends
How can i buy this SFP? Does your friend have it working with movistar?
AntonioLON
Tue Aug 20, 2019 1:13 am
Hola Friend,
contact companies on alibaba. our friend saper2 gives link to dipperoptics. other company also lives on alibaba
https://hilinktech.en.alibaba.com/search/product?SearchText=stick
chinese friends are not easy. they want to sell 50, 30, 20 pieces to you. stay on alibaba messenger, she will goto manager, after 1-2 hour maybe sell 1 piece
5 euros more gives you SFP temperature Industrial
my friend in Valencia lucky. all working cause good OLT in community.
HL23446 is Alcatel clone. lot of options to configure serial number/vendorID/MAC and 3 profiles for OLT
i Ask my friend to send some examplas
vdias
Wed Aug 21, 2019 11:40 am
Shop owner replied saying that they don't have APC type sfp... does the UPC version work here in Spain?
saper2
Wed Aug 21, 2019 11:43 am
You mean fiber optic connector SC/APC? Then just use patchcord cable with SC/APC to SC/UPC connectors (and SC/APC adapter).
Alferez
Wed Aug 21, 2019 11:55 am
You only need this cable:
Green: SC/APC
Blue: SC/UPC
saper2
Wed Aug 21, 2019 12:03 pm
Green: SC/APC
Blue: SC/UPC
Yes exactly.
I mentioned adapter because in my country ISP's rarely install a wall SC/APC socket, instead they attach directly to fiber cable (that going directly from wall) the SC/APC plug to the router.
vdias
Thu Aug 22, 2019 4:46 pm
Chinese seller answer: "Sorry, dear. My engineer told me that our GPON stick can't compatible with Mikrotik"
1 second after... she send me this invoice... don't really understand...
fushigi
Thu Aug 22, 2019 5:14 pm
The model is hl23446-sshe
I have also asked for one.
vdias
Thu Aug 22, 2019 6:18 pm
i bit expensive... :(
Error0x29A
Thu Aug 22, 2019 6:24 pm
$30 shipping, that's a lot. Unless you are in hurry. 14 days by China Air should not be more than $10-$12
Regarding compatibility with Mikrotik. I had the same problem with SFP FGS202. It works on some models and firmwares and sometimes it does not.
According to SFP MSA specifications pin 6 on SFP modules should be connected to the ground. Pin 6 is called MOD_ABS (module absent)
When inserted into a router by providing the ground on that particular pin, it will indicate the module presence. If firmware algorithm is more advanced(bigger size) it may try to detect SFP module by other means.
On some SFP they don't provide the ground on pin 6 because is used to output diagnostic data over uart-serial protocol.
If you have a chance, ask the engineer how the pin 6(mod_abs) is connected.
fushigi
Thu Aug 22, 2019 7:56 pm
Error0x29A
Thu Aug 22, 2019 9:15 pm
Note 3, Grounded in Module
These specs are not always followed by manufacturers. Large clients may request different pin assignments.
On some networking site they did comparison of several GPON modules. Not all of them had ground connected to pin 6.
fushigi
Thu Aug 22, 2019 9:23 pm
They sent me those specifications.
saper2
Thu Aug 22, 2019 9:41 pm
In datasheet is pinout, pin 6 is connected to ground [emoji2]
Error0x29A
Thu Aug 22, 2019 9:57 pm
Great. Can't wait for reviews and configuration guides :)
saper2
Thu Aug 22, 2019 10:38 pm
Look at sshe file, there is how to connect to the sfp and get optical link parameters (and how to put them into excel) - I just scrolled through the file only so I might be wrong [emoji6]
Setting access to module on mikrotik might be a tricky but possible ( I managed to setup hg612 with access to it via single cable , while all guides was saying that is not possible with only one cable).
Error0x29A
Fri Aug 23, 2019 1:39 am
The document have some interesting information. I wish I had a module in my hands to experiment with :)
Part about using SmartBits 600B performance testing certainly will not apply to me. Can't afford such equipment. On the page 4 they included instructions about optical calibration by transmitting 1.25G of random 1's and 0's continuosly toward network. IMO those lines should be removed.
Error0x29A
Mon Sep 09, 2019 6:35 pm
Any updates? Did you receive the Gpon-hl23446-sshe module?
How well is it working with Orange or Movistar?
MrAlester
Tue Sep 17, 2019 5:43 am
Hi, is there someone out there selling Zisa's or Carlitos SFP?
I tried contacting Zisa but they wouldn't sell me one.
AntonioLON
Sun Sep 22, 2019 9:07 pm
Hola Friends,
I share configuration guide for you for SFP modulo D23446/HL23446
D23446/HL23446 initial configuration V.01
Warning!!!
Do not modify any optical parameters(GOI). Avoid direct exposure to a laser beam!
Network stack will become available approximately 80 seconds after power up.
Run the Telnet software on PC, such as the TeraTerm
https://osdn.net/projects/ttssh2/releases/
Set the Host as <192.168.1.57> (the GPON STICK’s IP address), choose the Service as <Telnet> and connect
Quick Setup (Serial Number and GPON password change)
fw_setenv ont_serial ARLT12345678
uci set gpon.ploam.nPassword='0x30 0x36 0x32 0x32 0x38 0x36 0x53 0x30 0x34 0x34'
uci commit
reboot
1. Build Info
OpenWrt - (14.07_ltq) --- Lantiq Edition for GPON
Linux SFP 3.10.49
2. Partition layout
dev:    size   erasesize  name
mtd0: 00040000 00010000 "uboot"
mtd1: 00080000 00010000 "uboot_env"
mtd2: 00740000 00010000 "linux"
mtd3: 00618322 00010000 "rootfs"
mtd4: 00420000 00010000 "rootfs_data"
mtd5: 00800000 00010000 "image1"
3. Flash Info
uboot -     0x040000
uboot_env - 0x080000
image0 -    0x740000
image1 -    0x800000
total -    0x1000000 16MB
4. Memory (DRAM) info
memory size - 0x4000000 64MB
5. Display all GPON Stick variables. Copy and store it in a safe place
root@SFP:/# fw_printenv
root@SFP:/# uci show
6. Verify if the u-boot environment variable 'target' is set
root@SFP:/# fw_printenv target
target=oem-generic
Each configuration value if present in the startup file sys.sh will be overwritten
Conventions:
# - \s is used to place a space (ASCII 0x20)
# - \0 is used to place ASCII 0
# - enclose "a b c" in quotes (either single or double) to interpret it as one attribute
Display and edit the file /etc/init.d/sys.sh with your current ONT values
root@SFP:/# cat /etc/init.d/sys.sh
       oem-generic)
                uci set sys.target.name=oem-generic
                uci set sys.features.mib_customized=1
                uci set sys.features.igmp_fast_leave=1
                uci set sys.features.dying_gasp_enabled=0
                uci set sys.features.suppress_power_level=0
                uci set sys.features.eeprom_sync_option='1'
                uci set sys.mib.vendor_id='ARLT'                    # 4 char Vendor ID left-aligned
                uci set sys.mib.ont_version='ARLTLBFIB2.0.0'   # 14 char Hardware Version left-aligned padded with zeros
                uci set sys.mib.equipment_id='PRV3399B_B_LT\0\0\0'  # 16 char model name left-aligned padded with zeros
use vi editor to update Vendor ID, Hardware Version, Model Name
root@SFP:/# vi /etc/init.d/sys.sh
7. Update serial number, password, MAC address, image version
fw_setenv image0_version AR_LBFIBRA_sp-00.03.04.091
fw_setenv image1_version AR_LBFIBRA_sp-00.03.04.095
uci set network.host.macaddr='e4:3e:d7:69:be:ef'
uci commit
reboot
8.Emulated EEPROM commands
sfp_i2c command will automatically calculate correct A0h checksums at offsets 63(0x3F) 95(0x5F)
indexes [-i] are written in decimal and converted to hex
a. Display stored soft eeprom data values
root@SFP:/# uci show sfp_eeprom.default.data_eeprom_0
b. Reset eeprom to default values (LANTIQ,NO_PART_NUMBER,0001,NO_SERIAL_NUMBER,140101)
root@SFP:/# sfp_i2c -d yes
c. Write to eeprom your ONT values
sfp_i2c -i 0 -s "HUWAWAWEI"         # 16 bytes(ASCII) Vendor Name left-aligned
sfp_i2c -i 1 -s "PRV3399B_B_LT"     # 16 bytes(ASCII) Part Number left-aligned
sfp_i2c -i 2 -s "0001"              #  4 bytes(ASCII) Part Number Rev. left-aligned
sfp_i2c -i 3 -s "ARLT567890123456"  # 16 bytes(ASCII) Serial Number left-aligned
sfp_i2c -i 4 -s "181224"            # 8 bytes Date Code(mandatory)
sfp_i2c -i 36 -w 0xe43ed7 -4 -m 0x00FFFFFF          # 3 bytes MAC address Vendor OUI
8. For some applications LAN port speed can be set to 2.5G
a. Set LAN port speed to 2.5G
fw_setenv sgmii_mode 5
b. Remove LAN port speed 2.5G (back to default 1G)
9. asc0 mode pin configuration
Turn off UART. Set pin#6 of 20 to low(module availability indication)
fw_setenv asc0 1
Troubleshooting (bricked device)
Set asc0 to 0 temporarily, change back asc0 to 1 when finished.
fw_setenv asc0 0
Connect USB UART adapter to pin#3 of 20(RX) and pin#6 of 20(TX)
Press SPACE to delay and Ctrl-C to abort autoboot in 5 seconds to modify environment variables
FALCON => printenv asc0
asc0=1
FALCON => setenv asc0 0
FALCON => saveenv
Saving Environment to SPI Flash...
SF: Detected GD25Q127C with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Erasing SPI flash...Writing to SPI flash...done
Valid environment: 1
Ignore Ctrl-C, wait for the full console (asc0=0) then press Enter
root@SFP:/#
fushigi
Re: Usage GPON module SFP in Spain
Mon Sep 23, 2019 8:18 pm
Hola Friends,
Warning!!!
uci commit
reboot
1. Build Info
Linux SFP 3.10.49
2. Partition layout
3. Flash Info
uboot -     0x040000
image0 -    0x740000
image1 -    0x800000
target=oem-generic
Conventions:
       oem-generic)
uci commit
reboot
fw_setenv asc0 1
fw_setenv asc0 0
asc0=1
FALCON => saveenv
root@SFP:/#
I can't get into telnet. :(
Putting on the host pc 192.168.1.1 and destination 192.168.1.57
If the easiest doesn't work for me.
Edit
My PON unit has IP 192.168.1.1
fushigi
Mon Sep 23, 2019 9:35 pm
Hola Friends,
Warning!!!
uci commit
reboot
1. Build Info
Linux SFP 3.10.49
2. Partition layout
3. Flash Info
uboot -     0x040000
image0 -    0x740000
image1 -    0x800000
target=oem-generic
Conventions:
       oem-generic)
uci commit
reboot
fw_setenv asc0 1
fw_setenv asc0 0
asc0=1
FALCON => saveenv
root@SFP:/#
It works and with mikrotik
MASMOVIL
It is another model that sent me is entered by web and is configured as an ONT ZTE.
Error0x29A
Mon Sep 23, 2019 11:07 pm
fushigi, please explain. Your model from the picture is not HL23446. What did you get?
I want to get one for myself before week ends.
Error0x29A
Mon Sep 23, 2019 11:19 pm
oem-generic)
The configuration code is somewhat similar to https://www.valero-torres.es/2018/09/08 ... de-orange/
As CarlitoxxPro explained in another post only 1-2 companies make original sfp. Rest are clones.
fushigi
Mon Sep 23, 2019 11:27 pm
They sold me this HL-190822
Error0x29A
Tue Sep 24, 2019 11:06 pm
Good for you. Another happy fiber user :)
Search on the "DFP-34G-2C2" keyword from your picture brings a Chinese company named usourcetech. They could be the original supplier.
http://www.usourcetech.com/web/userfiles/download/GPONSTICKSFPCLASSB-2B_Rev01.pdf
I'm more concerned with advanced configuration screens. GPON sticks like Zisa, Hilink, CarlitoxxPro have many options important for Orange/Jazztel users.
What do you have on the PON screen? Anything more if telnet is used?
fushigi
Wed Sep 25, 2019 12:41 am
http://www.usourcetech.com/web/userfile ... _Rev01.pdf
PON
LOID and SN can be changed.
Telnet screenshot
DeVlL
Wed Sep 25, 2019 12:01 pm
PON
Telnet screenshot
Good. How does the SFP module behave? Does it get very hot? Can you give me more information?
I have the pepephone connection (orange network) and I want to remove the ONT. I'm waiting for CarlitosPRO to have stock but it never arrives.
Thank you
Error0x29A
Wed Sep 25, 2019 5:28 pm
fushigi,thank you for your time answering our questions.
In the previous post you mentioned RB4011. Does that mean your new HL-190822 works with RB4011? What is the Mikrotik software version ?
fushigi
Wed Sep 25, 2019 7:00 pm
Mikrotik model: RB4011iGS+
RouterOS: 6.45.6
fushigi
Wed Sep 25, 2019 7:08 pm
PON
Telnet screenshot
Thank you
I have it working 2 days and for the time being fine.
The stick is at 54 ° with room temperature of 27 ° I have it in a rack.
DeVlL
Wed Sep 25, 2019 9:21 pm
PON
Telnet screenshot
Thank you
Okay. It seems to look very good.
The model I buy is the HL-190822? And above it has a web interface to configure it easily.
What was the cost with shipping costs (I am from Spain like you)
Regards
fushigi
Wed Sep 25, 2019 9:24 pm
Some heatsinks and temperature going down xD
fushigi
Wed Sep 25, 2019 9:28 pm
PON
Telnet screenshot
Thank you
Regards
Only 79 $ with shipping to Barcelona
DeVlL
Fri Sep 27, 2019 11:44 am
PON
Telnet screenshot
Thank you
Regards
Okay. It is well priced. How do I buy it and what payment method do I use?
Petronas
Tue Oct 01, 2019 2:32 pm
I have the dpoptics model and it doesn't work, :(
comment on my experience
Buy at " DPOPTICS D23446 STHE " company, and sendme " SOURCEPHOTONICS SPS3424THPTDFO " .
Oh my god !! :?
I look inside stick and are from third-party manufacturers, look pictures :oops:
In this equipment the configuration is only done by telnet and I do not have access to the configurator via the Web. The IP is 192.168.1.10 and does not work.
I have a beautiful paperweight.
Any help would be welcome.
To whom the support now belongs to dpoptics? or sourcephotonics ?
Be careful with the Chinese, there is a mobsters between them, they are not honest.
fushigi
Tue Oct 01, 2019 6:47 pm
Buy at " DPOPTICS D23446-STHE " company, and sendme " SOURCEPHOTONICS SPS3424THPTDFO " .
Oh my god !! :?
https://ibb.co/zXbZd8y
Have you tested with IP 192.168.1.1 , 192.168.1.50 and enter via telnet, web ?
JeanPierre
Tue Oct 01, 2019 9:16 pm
Oh my god !! :?
Long time reader of this forum first time poster
SPS3424THPTDFO and telnet IP is 192.168.1.10 reminds me our Alcatel units. same login IP, same serial SPS on unconfigured units. In Canada we are connected to Nokia/Alcatel or Huawei optical splitters. ISP supplies users with three types of units Huawei - ma5671a Alcatel/Nokia - g-010s-a or g-010s-p
Don't worry what you see on the Mikrotik screen. it uses i2c bus to read eprom's "burned" serial number. Your gpon module will get serial and password from environment variables area.
My tv box came originally with g-010s-a which later I swapped for g-010s-p. The unit is very well tuned(important if you live far from the optical splitter)
pass and snumber change took me 5 minutes. very easy, couple of commands and you are set. Check my notes
onu gtcsng ------------>>> display gtc serial number (gtc_serial_number_get)
onu gtcpg ------------->>> display gtc password (gtc_password_get)
Login as ONTUSER@192.168.1.10 (protocol ssh) or telnet 192.168.1.10 (protocol telnet)
BusyBox v1.19.4 (2015-02-14 18:25:19 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
ATTITUDE ADJUSTMENT (Attitude Adjustment, 12.09_ltq)
root@SFP:/# onu gtcsng
errorcode=0 serial_number=ALCL98765432
root@SFP:/# onu gtcpg
errorcode=0 password=1234567890
root@SFP:/#
Set password and serial
root@SFP:/# fw_setenv nPassword 1234567890
root@SFP:/# fw_setenv nSerial ALCL98765432
Erase nSerial/nPassword
nSerial is vendor+8 characters
nPassword is exactly 10 characters
Petronas
Tue Oct 01, 2019 9:46 pm
Oh my god !! :?
Hello.
Yes I test 192.168.1.1, and others
Only conect 192.168.1.10 ssh, does not connect via web any Ip
I do a port scanner and Ip that is the only available 192.168.1.10 that sends the stick
No web service is active.
I Just connect via ssh enter the commands to configure the manual, without success.
my locality Spain too
It seems that we have different versions of firmware
Error0x29A
Wed Oct 02, 2019 12:04 am
Hello.
I did a Google search. ONTUSER is a login name for Alcatel-Lucent ONT
https://www.adslzone.net/foro/fibra-opt ... 252/page-2
Please tell us your partition setup. Someone must have similar firmware. Execute command cat /proc/mtd
OpenWrt - (14.07_ltq) --- Lantiq Edition for GPON is the same firmware version like posted by AntonioLON in the post #210
Did you try his quick setup commands?
text to hex converter https://online-toolz.com/tools/text-hex-convertor.php
Petronas
Wed Oct 02, 2019 4:04 pm
Oh my god !! :?
root@SFP:/#
Thx.. 8)
I managed to burn the integrated with the "sfp_i2c" commands shown above
But command strings don't work.writing.
:oops: :evil:
If they can read but do not write, I check again and they are not recorded.
JeanPierre
Wed Oct 02, 2019 4:48 pm
Antonio's commands make more sense to me. He's on 14.07_ltq. I am on 12.09_ltq
** remove 12.09 variables **
fw_setenv nPassword
fw_setenv nSerial
** use 14.07 (Antonio post #210) **
fw_setenv ont_serial HWTN12345678
convert password to hex in rapidtables https://www.rapidtables.com/convert/num ... o-hex.html ---->> 0123456789 hex=30 31 32 33 34 35 36 37 38 39
uci set gpon.ploam.nPassword='0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39'
uci commit
reboot
** verify after reboot **
Petronas
Wed Oct 02, 2019 8:24 pm
fw_setenv nPassword
fw_setenv nSerial
uci commit
reboot
I write these commands and write correctly, then I check and they have not been written
JeanPierre
Wed Oct 02, 2019 10:46 pm
Without an actual unit in my hand I'm out of ideas. You may wish to dump and examine results of uci show and fw_printenv. List directories /etc/config and /etc/init.d
Examine closely files gpon sys onu.sh for env names used by the system. If possible post them on pastebin.com for others to see
Error0x29A
Wed Oct 02, 2019 10:58 pm
Petronas,
Two questions. Did you ask the Chinese company for setup instructions? What is your Mikrotik model and software version?
Thank you.
Petronas
Thu Oct 03, 2019 9:35 pm
:D
SFP_GPON "uci show"
https://pastebin.com/pxqkL9S0
SFP_GPON "fw_printenv"
https://pastebin.com/Fjc6f3dX
SFP_GPON " List directories /etc/config and /etc/init.d "
https://pastebin.com/XkdVFskn
What path are the files on? files gpon sys onu.sh ??
I write several emails to the seller and not answer, just sendme a small useless manual, with only ONTUSER and password.
Saying that the configuration of the equipment is also done by Web Page.
Also I understand that ONTUSER is a user with administrator privileges but is not superuser, root. :?:
Mk model: CRS125-24G-1S
Firm: 6.45.6 (stable)
JeanPierre
Fri Oct 04, 2019 6:47 am
onu.sh and sys.sh are in /etc/init.d gpon in /etc/config
One variable inside of fw_printenv on the pastebin site has some private info, I recommend to remove it.
Maybe http daemon is on port 8080 or 8000
root@SFP:/# ps | grep http
Try netstat for verifcation of all running programs with open ports
root@SFP:/# netstat -antp
Is 66 a typo? (from your uci show) nPassword must be exactly 10 characters, each prefixed with 0x
gpon.ploam.nPassword=66 0x32 0x30 0x31 0x32
In fw_printenv I see too many potentially conflicting variables present in your environment which make sense for my g-010s-p module. Start by removing duplicates and errors.
root@SFP:/# fw_setenv image0_verison
If your provider decided not use a password, I recommend applying 10 zeros.
root@SFP:/# uci set gpon.ploam.nPassword='0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30'
root@SFP:/# uci commit
root@SFP:/# reboot
connect fiber when ready and check the registration status looking for 5
root@SFP:/# onu ploamsg
errorcode=0 curr_state=5 previous_state=4 elapsed_msec=30428
if curr_state=5 you may continue with vlan pppoe/dhcp setup.
I hope it helps. I used Antonio's notes and my g-010s-p module for comparison. Some variables and commands may react differently on each module version.
DeVlL
Fri Oct 04, 2019 2:22 pm
Good lords. I asked the manufacturer of alibaba the hl23446-sshe and I was asked the connector I want for the STICK.
Looking at the previous messages of this thread there are two.
Green: SC / APC
Blue: SC / UPC
The one that puts the ISPs in Spain is the Verde: SC / APC, right?
saper2
Fri Oct 04, 2019 3:08 pm
Mostly sfp modules have SC/UPC (blue). In plastic modems you can find APC (green), or (blue) UPC. So, if you have a green APC plug from wall , you just need a SC APC to SC UPC patchcord and SC APC (simplex) adapter.
Sorry, I can't answer exactly what you want to know, but using adapter and patchcord works fine, if you don't have yet fiber then look for what you need after you have installed modem from ISP because they can install modem with SC/APC or SC/UPC (depends what they have at hand)
Petronas
Sat Oct 05, 2019 9:07 pm
root@SFP:/# reboot
sys.sh
https://pastebin.com/86kXkL7R
gpon
https://pastebin.com/69WDpWbR
ps | grep http
https://pastebin.com/KcEJP3nP
netstat -antp
https://pastebin.com/iiMgV4Mz
onu ploamsg
https://pastebin.com/QFFqbd7c
In my stick, the HTTP service to configure is not activated.
I do not understand very well the string to be introduced is more than 10 characters but my record is more. although I change it for HEX data.
JeanPierre
Sun Oct 06, 2019 2:48 am
Thank you for the last picture. HG8240 has already converted values to hex. Examples with fake numbers.
00f201200048 -->> serial number
f2012000443688011024 --->> gpon password f2 01 20 00 44 36 88 01 10 24
prefix each pair in password with 0x
0xf2 0x01 0x20 0x00 0x44 0x36 0x88 0x01 0x10 0x24
root@SFP:/# uci set gpon.ploam.nPassword='0xf2 0x01 0x20 0x00 0x44 0x36 0x88 0x01 0x10 0x24'
root@SFP:/# fw_setenv ont_serial 00f201200048
root@SFP:/# reboot
osquetar
Sun Oct 06, 2019 10:36 am
Yeah, but I need that my Mikrotik, with a transceiver S-85DLC05D inside, works. Only one device and only one power unit.
If the next RouterOS 6.xx or 7.00 don't do so, why to continue with Mikrotik? Sure I'll find another brand.
Any advice?
msatter
Sun Oct 06, 2019 5:31 pm
This thread goes about using a SFP in a Mikrotik, which should not be posible because the ISP/provider does not allow that to happen using their service.
Now it is posible if not easy.
AntonioLON
Sun Oct 06, 2019 6:41 pm
Holla msatter,
Spaniards Italians French are about life. always easy to work SFP with Mikrotik in those countries. i work in London now. cameras surveillance firewalls gates. in diciembre i come back to Spain. money is better here but i don't want a paranoid life.
Petronas
Mon Oct 07, 2019 6:49 pm
root@SFP:/# reboot
:shock: Sorry, Now I understand the syntax.. :oops:
Change "curr_state=5"
https://pastebin.com/vHBZ1ug4
command " gtop+e "
MikroUser
Mon Oct 07, 2019 7:33 pm
PON
Telnet screenshot
Thank you
Regards
Hi, what is default telnet password for DFP-34G-2C2, root\admin not working :(
Petronas
Mon Oct 07, 2019 7:37 pm
I have another problem seems not to be well registered.
## Error: "Target" not defined
look file cat /etc/init.d/sys.sh to be empty :?:
Change mouth input sfp1 does not work
fushigi
Mon Oct 07, 2019 9:42 pm
Thank you
Regards
Hello [emoji3]
Here it is.
root\Pon521
MikroUser
Mon Oct 07, 2019 11:43 pm
root\Pon521
Thanks, logged in. have you any ideas how to make this sfp work with bdcom olt? I always got GPON State Init State, mikrotik shows link ok, but pppoe doesnt up (
Petronas
Tue Oct 08, 2019 7:59 pm
I disassemble the stick. :shock: :roll:
So that we can all identify the different Chinese teams and clones.
Here are more pictures 8)
Enjoy the show :roll:
https://mega.nz/#!AUYQWYAY!qIu1il8-umT6 ... -lnCzMFEv0
Model Chips & Laser transceiver :
Winbond 25Q128JVEQ (W25Q128JVEQ) -->> https://www.winbond.com/resource-files/ ... 20plus.pdf
ISSI 1735 IS43DR16320E -->>http://www.issi.com/WW/pdf/43-46DR86400E-16320E.pdf
Intel S912NN07 SLLC5
DSN 181 9 1120-022420-01
Maybe someone else can put pictures of their equipment sticks around here. :-D :lol:
Petronas
Thu Oct 17, 2019 4:23 pm
Someone can put pictures of their optical stick here ?
JeanPierre
Thu Oct 17, 2019 9:57 pm
g-010s-a
https://ibb.co/hWRkTHw
g-010s-p and ma5671a
https://ibb.co/Gtxf14G
op151s top and bottom
DeVlL
Fri Oct 18, 2019 11:51 am
Regards
Hello [emoji3]
Here it is.
root\Pon521
I'm going to buy the module from the same supplier that I bought and I have a question. Did you have to buy a fiber optic cable SC / APC to SC / UPC right?
Regards
msatter
Fri Oct 18, 2019 12:22 pm
Normally you need to get the sc/upc (blue) and the difference you can read about here:
http://www.fiber-optic-cable-sale.com/f ... c-upc.html
Lisendra
Sat Oct 19, 2019 10:13 am
Regards
can you provide url again to buy the module with web interface?
best regards,
JeanPierre
Mon Oct 21, 2019 5:33 am
DFP-34G-2C2
DFP-34G-2C2
Hi MikroUser, fushigi, AntonioLON, DeVlL
If it is not too inconvenient for you, please provide software images for HL23446 and DFP-34G-2C2. In the past I have successfully reflashed images between different brands. As long they have similar hardware design, processor, RAM and flash size, it will work fine. Chinese sfp are usually generic. Should not contain private informations.
At minimum, images of "uboot_env" and "linux/image0" known as mtd1 and mtd2 are needed for this test. For your own backup save all partitions except: rootfs rootfs_data
sfp partition mapping can be obtained by command.
root@SFP:/# cat proc/mtd
mtd3: 0061eedc 00010000 "rootfs"
mtd4: 00370000 00010000 "rootfs_data"
to transfer mtd partition search for and use live linux distribution. e.g. Ubuntu
On the linux computer setup a fixed IP (same subnet as sfp stick) e.g. 192.168.1.12. Open terminal.
root@ubuntu:/# nc -l -p 4444 > mtd1.bin
-l listen
-p port number
now on the sfp stick send the mtd to the linux pc
root@SFP:/# cat /dev/mtd1 | nc 192.168.1.12 4444
Repeat for mtd2. Zip the files and post it on the Mega.nz site
For testing I will use sfp modules popular in Canada: g-010s-a, g-010s-p and ma5671a. If all works well I will share the flash and recovery procedure after all tests are done.
jblankfeld
Mon Oct 21, 2019 12:36 pm
Hello friends,
Thank you for this great thread. I'm also interested in replacing SERCOMM FGS202 that is provided by Orange, my ISP.
The module works fine in a Mikrotik hAP AC but it does not work on a board I have (ClearFog GT 8K) that runs mainline linux (no link detected)
Did you eventually manage to have one of the clone working ? Is it stable enough ? I'd like to purchase HL23446 of DFP-34G-2C2 but I'd like some of your inputs first.
Thank you guys.
fushigi
Mon Oct 21, 2019 6:32 pm
Picture of DFP-34G-2C2
Error0x29A
Mon Oct 21, 2019 7:44 pm
fushigi, do you know technical specification for this ponstick? Can you post what you get when dmesg command is used?
dimcom
Tue Oct 22, 2019 12:03 pm
You do not know how to change the pon sn of the ma5671a module. Access to it is available only on port 22 via CLI
Petronas
Tue Oct 22, 2019 8:01 pm
DFP-34G-2C2
DFP-34G-2C2
-l listen
-p port number
8)
Here is my backup file 8)
SOURCEPHOTONICS_SPS3424THPTDFO
https://mega.nz/#!YE5jDKJT!k_exNoXRLmHT ... yU5bvyhuJw
JeanPierre
Tue Oct 22, 2019 11:21 pm
Hi Petronas,
Thank you for posting flash images. Do you mind sharing ssh password @192.168.1.10 for this image?
mtd3.bin(rootfs) and mtd4.bin(rootfs_data) may contain running system info. mtd1.bin may contain serial info. These commands should be used to erase it before running an image dump.
root@SFP:/# fw_setenv sfp_a0_low_128
Petronas
Wed Oct 23, 2019 12:35 pm
Hi Petronas,
Reupload file inside pw
AntonioLON
Wed Oct 23, 2019 4:01 pm
images for HL23446
[/quote]
hola amigo. i see to it when i am back in Spain
JeanPierre
Wed Oct 23, 2019 11:28 pm
Hi Petronas,
Thank you for sharing the login pass. I locked myself out for a day :lol: I agree with you, this image version is limited, no http. We need an image from Hilink HL23446 or Carlitoxx CPGOS03-0490 to have many configuration options. Maybe someone will post it.
Petronas
Thu Oct 24, 2019 6:33 pm
Hi Petronas,
It is a pleasure also your help with the commands and advice, :)
I activate the web interface, but with few configuration options. :roll:
I followed this guide
https://www.dslreports.com/forum/r32458588-
Inform the people who read us in the forum. !!
Be careful with the command lines you can leave the stick dead even via web. Changing some settings may make it dead and not operational !!! .
If you don't know what you do ...
JeanPierre
Thu Oct 24, 2019 11:04 pm
I'm out of town this and next week.The user shell is limited. Let me check after I'm back.
JeanPierre
Thu Oct 24, 2019 11:09 pm
Hi Petronas,
Great pictures. Good contribution.
The web interface has more options than one would hope for.
Delboy
Sun Oct 27, 2019 2:47 am
@Petronas
Thanks for the image dump
Also note that even the SoC is the same, optical transmitter may not be the same across different brands and models, and that is why goi_config variables exist.
I have Alcatel G-010S-P that were cheap on ebay some time ago, and managed to re flash it with zisa firmware and got a working gpon sync.
JeanPierre
Sun Oct 27, 2019 3:15 pm
@Delboy
Flashing between G-010S-P and SPS3424THPTDFO or Carlitoxx CPGOS03-0490 is easy. Same partition layout. Flash is 16MB
I looked up the Zisa OP151S. It has different partition layout and smaller flash (8MB)
root@SFP:/# cat /proc/mtd
mtd0: 00060000 00010000 "Boot"
mtd1: 00010000 00010000 "Env"
mtd2: 00390000 00010000 "ImageA"
mtd3: 00390000 00010000 "ImageB"
mtd4: 00060000 00010000 "Config"
mtd5: 00010000 00010000 "SECTION_EGIS"
mtd6: 00250000 00010000 "rootfs"
mtd7: 00010000 00010000 "rootfs_data"
How did you manage to re-flash it with zisa firmware and transfer goi_config from your G-010S-P
mrspeccy
Thu Oct 31, 2019 2:22 pm
Hi all,
I have internet via GPON provider here in Denmark and would like to replace its fiber modem with a GPON stick that fits into my router. I contacted HiLink and thought they would send me the HL23446. What I received is a GPON stick that carries the following information on its sticker:
GPON_ONU_STICK
1.244 Gbps 1310nm/1490nm
S/N HLZ2019092XXXXX (I masked the last 5 digits of this serial number).
That's all. No real product number/name.
Any idea what kind of hardware this is? The stick does have a web interface on port 80 and a telnet interface on port 23 as well, but I do not know how to log in. Combinations admin/admin etc. do not work. Also, the IP of the stick is 192.168.1.1 which, as I understand, is different from the 192.168.1.57 of the HL23446.
Error0x29A
Thu Oct 31, 2019 3:29 pm
Hi all,
GPON_ONU_STICK
Did you try root\Pon521
Can you post a picture of the stick. It will be easier to identify...
mrspeccy
Thu Oct 31, 2019 4:36 pm
You mean root as username and Pon521 as password? Does not work, unfortunately. Here is an image
https://ibb.co/DbYSMgW
Error0x29A
Thu Oct 31, 2019 5:39 pm
ssh login also fails? Contact the hilink. They provided pass to fushigi and others
Can someone identify the main chip from the post #258 by fushigi?
viewtopic.php?f=3&t=116364#p756126
Delboy
Thu Oct 31, 2019 5:55 pm
I flashed whole 8MB flash from zisa Op151s to image1 partition of G-010S-P. I think i had to change something to get egis partition to mount, but i'm not sure as i did this a year ago.
Also I had to set some u-boot env variables to properly boot zisa firmware
addmtdparts0=setenv mtdparts mtdparts=sflash:256k(uboot)ro,512k(uboot_env),7424k(linux),8192k(image1)
addmtdparts1=setenv mtdparts mtdparts=sflash:256k(uboot)ro,512k(uboot_env),7424k(image0),384k(Boot)ro,64k(Env),3648k(ImageA),3648k(ImageB),384k(Config),64k(SECTION_EGIS),2368k@13568k(rootfs) ACTIVE=B softMode=NORMAL
boot_image0=run kernel0_from_sf flashargs addip addmtdparts0 addmisc && bootm ${ram_addr}
boot_image1=run kernel1_from_sf flashargs addmtdparts1 addmisc && bootm ${ram_addr}
image1_addr=0xB0800000
image1_is_valid=0
image1_version=3.2.16_160606
kernel1_from_sf=sf probe 0;sf read ${ram_addr} ${kernel1_offs} ${max_kernel_size}
kernel1_offs=0xC00200
For goi_config I had copied files to egis partition in /tmp/egis/ but i'm not sure if that is all that needs to be done to make it right, as some optic variables I got from running "otop" on both firmwares are different.
To test new image, it is best to boot default alcatel firmware and from it's shell set env variable to boot from image1 only once, that way if something fails on reboot, it boots back to alcatel fw:
fw_setenv flash_flash "setenv flash_flash run select_image boot_image && saveenv && run boot_image1"
Link for image1 partition dump and u-boot env variables: https://www.dropbox.com/s/v1sxo2js25t0c ... -p.7z?dl=1
spaxton
Fri Nov 01, 2019 10:17 am
Hello everyone,
It's been a long time since I wrote a message to this thread. Long time since I tried to make this work for the first time but I was trying constantly from time to time...
I have Zisa OP151s and yesterday I finally figured out that all changes I made were successful and the module register to OLT but it doesn't open VLANs. DHCP client works fine on the interface itself and I could open IPTV but VoIP and internet are tagged traffic and this module doesn't forward it for some reason. After some time (lets say one hour) it obtained an IP address on VoIP VLAN but after restart I had the same situation like I described above.
Anyone had this experience?
It seems like the module has some bugs..
Anybody knows why it behaves like this?
Best Regards,
mrspeccy
Fri Nov 01, 2019 4:41 pm
There is no ssh service on my stick. I have written to HiLink and am waiting for reply.
Error0x29A
Fri Nov 01, 2019 9:51 pm
Hello everyone,
Best Regards,
hello spaxton, did you clone original ONT MAC address to your Microtik WAN interface? DHCP servers may not respond with IP assignment if MAC address is wrong.
can you install and run tcpdump on your Zisa OP151S LAN/WAN interfaces and look for Vlan frames?
big thanks to user Petronas for sharing the link on how to install extra packages and plenty of pictures
viewtopic.php?f=3&p=758116#p756735
http://archive.openwrt.org/barrier_brea ... ages/base/
spaxton
Sat Nov 02, 2019 12:08 am
Hello Error0x29A,
Many thanks for Your reply!
Well, I didn't clone the MAC address but I also think there is no need (by bridging the telecom router, I can get an IP address on my laptop or any other device). Here is the scenario:
ONT status is O5
sfp1 obtains IP address of IPTV (until today I didn't test if it really works but the receiver updates the clock. No TV channel streaming available)
VLAN1 (VoIP) "hardly" obtains an IP address (It actually obtains an IP address after some time and it will obtain it again after this if I disable and enable the interface. I am able to ping the gateway)
VLAN2 (Internet) gets nothing. It doesn't "see" the PPPoE server on the other side
What concerns me is if the SFP ZISA OP151S has some bugs or I may misconfigured it. Please check the screenshot and let me know what for are UP FEC, DOWN FEC, ENCRYPT and why they are disabled?
Best Regards
Error0x29A
Sat Nov 02, 2019 12:49 am
Forward Error Correction (FEC) feature can improve the quality and reach of an optical link allowing the receiver to detect and correct transmission errors.
Every ONT receives each downstream frame and picks up only that data addressed to it by the OLT. Optionally, FEC coding and AES encryption are applied to the user data.
They are optional, on my Spanish provider they are also not turned on. I don't have much experience in troubleshooting PPPoE over Vlan, I get IP from DHCP over Vlan.
Have a look at OP151S Orange ES setup and link to firmwares
spaxton
Sat Nov 02, 2019 2:23 pm
Thanks for explanation.
I remember this Valero Torres page. This was available even before I bought the module. Maybe one year ago. Now I am not sure if his firmware is newer or older than the one I have in the module already. Also, he has 3 files... Active software, passive software, firmware. To be honest, I have no idea what for 3 files are used. :D :D :D
Is it easy to upgrade?
Error0x29A
Sat Nov 02, 2019 8:10 pm
I posted the link for comparison. With only one SFP in my router I don't feel comfortable loading another firmware. Yet. I leave it to other guys in this thread :D
No significant difference between all three files. First firmware is a factory generic. Second and third have firmware version names tailored for Orange ES.
In my opinion to solve the issue - put yourself in the middle. 1. Install tcpdump on OP151S. 2. login to OP151S 3. capture traffic on the sfp interface. 4. look for VLANS and PPPoE data.
Petronas
Mon Nov 04, 2019 7:30 pm
You can explain something better like you do. :?: :?:
how to transfer the image, how to mount the unit., step by step
I am doing a full backup to my stick.
I can resurrect the stick in failure, full backup
*** The party starts taking a seat and popcorn watching the show. :lol: **
AntonioLON
Mon Nov 04, 2019 8:08 pm
hola amigos
i propose move discusion to openwrt forum, more help, more more flashing/uboot experts
https://forum.openwrt.org/c/hardware-qu ... mendations
JeanPierre
Tue Nov 05, 2019 7:58 am
Hi Delboy
Thank you for your explanation, so there is more is involved than simple re-flash. It's easy to get this module bricked when messing with a firmware. I did it again this weekend :shock: not going to risk it anymore, got a brand new G-010S-P from a local bussiness. It is running hardcoded Alcatel omci manager and parser. Had to uncomment couple lines to switch to a generic omci daemon to receive IP address. Edit the file /etc/init.d/omcid.sh if you run into similar problem (O5 received but no IP address)
OMCID_BIN=/opt/lantiq/bin/omcid
#OMCI_MGR_BIN=/opt/lantiq/bin/omciLibMgr
#OMCI_PARSER_BIN=/opt/lantiq/bin/omciLibParser
${OMCID_BIN} -d3 ${uni2lan} -p $mib_file -o$omcc_version > /dev/console 2> /dev/console &
# ${OMCI_MGR_BIN} > /dev/console 2> /dev/console &
# sleep 5
# ${OMCI_PARSER_BIN} > /dev/console 2> /dev/console &
JeanPierre
Tue Nov 05, 2019 8:05 am
That's exactly what I need. Where did you get "mod tweezers" ?
JeanPierre
Tue Nov 05, 2019 8:07 am
hola amigos
I agree. Much better venue.
JeanPierre
Tue Nov 05, 2019 8:25 pm
My first try running OP151S on G-010S-P failed :( still investigating...
SF: Detected S25FL128S_64K with page size 256 Bytes, erase size 64 KiB, total 16 MiB
SF: 1572864 bytes @ 0xc00200 Read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
On my new stick G-010S-P i applied recovery options in case it is bricked again, good also for SPS3424THPTDFO and MA5671A with full shell access
removing 'intput 100' from preboot enables "Press SPACE to delay and Ctrl-C "
root@SFP:/# fw_setenv preboot gpio input 105\;gpio input 106\;gpio input 107\;gpio input 108\;gpio set 3
root@SFP:/# fw_setenv bootdelay 5
root@SFP:/# fw_setenv asc0 0
now i can connect USB serial UART adapter to stick's PIN2(tx) and PIN7(rx)
with access to uboot shell I can change environment variables
ROM: V1.1.4
ROM: CFG 0x00000006
ROM: SFLASH-4
Chip:  FALCON-S (A22)
Bootmode: 0x06
Reset cause: Software
CPU Clock: 400 MHz
Net:   SGMII, SERDES [PRIME]
gpio: pin 105 (gpio 105) value is 0
gpio: pin 106 (gpio 106) value is 1
gpio: pin 107 (gpio 107) value is 1
gpio: pin 108 (gpio 108) value is 1
gpio: pin 3 (gpio 3) value is 1
FALCON =>
FALCON =>
FALCON => printenv
spaxton
Tue Nov 05, 2019 11:56 pm
Hello friend,
where did you buy this SFP module? I see it has many options. Did you buy it like this or you installed this firmware in it and can this be installed in zisa op151s? Please jelp with some info or link where this is available to buy.
Best Regards.
JeanPierre
Wed Nov 06, 2019 9:08 am
Save backup of mtd1 and fw_printenv. apply recovery procedure from post #288
do not use for production (missing calibration files)
@Delboy
thank you for sharing with us these steps
Steps for running OP151S image on G-010S-P
fw_setenv addmtdparts1 setenv mtdparts mtdparts=sflash:256k\(uboot\)ro,512k\(uboot_env\),7424k\(image0\),384k\(Boot\)ro,64k\(Env\),3648k\(ImageA\),3648k\(ImageB\),384k\(Config\),64k\(SECTION_EGIS\),2368k@13568k\(rootfs\) ACTIVE=B softMode=NORMAL
fw_setenv image1_version 3.2.16_160606
fw_setenv kernel1_offs 0xC00200
fw_setenv image1_addr 0xB0C00200
transfer the mtd5 uploaded by Delboy. on linux pc must have ssh server running (sshd)
sfp stick
root@SFP:/# cd /tmp/
root@SFP:/# scp jean@192.168.1.12:/tmp/mtd5 mtd5
root@SFP:/tmp# mtd -e image1 write mtd5 image1
Unlocking image1 ...
Erasing image1 ...
Writing from mtd5 to image1 ...
root@SFP:/tmp#
reboot into OP151S. telnet 192.168.1.1 as admin/admin
enter linux shell
T&W# linuxshell
start the optics script
root@SFP:/# /etc/init.d/optic.sh start
spaxton
Tue Nov 12, 2019 1:21 pm
Hello Friends,
I have found some new SFP module to buy and it has the same interface like DFP-34G-2C2 . Please take a look...
I have seen in this thread someone had an experience with this kind of module. Please, can someone confirm if this kind of module works or not. I need IPTV, Telephony and Internet (last two things are delivered via different VLANs)
Best Regards.
minhng99
Fri Nov 15, 2019 3:30 pm
Hi Delboy
# sleep 5
Thank you, PPPoE dialing worked for me after this
minhng99
Sat Nov 16, 2019 10:15 am
Anyone know how I could do IGMP forwarding (multicast) with this Openwrt-based stick? I have a Sercomm and it worked fine but this Openwrt-based one fromm Nokia doesn't
Petronas
Thu Nov 21, 2019 3:02 pm
Sorry delay.... all this took a while
It is a creation made by me.
Use the normal clamp and place some very thin pins on the pliers.
It works with the chip soldered on the board, I can read and write. Happy !!
I use the programmer CH341A for my chip
Also have another programmer "minipro" but need to update and be more expensive and will have to wait to be updated, for now I am working with the CH341A.
I would like to expand the menus and improve the firmware but I am not an OpenWrt expert just a baby of Linux and have no knowledge of an expert, so I am limited. Now I look more confident and be able to open a new discussion in the OpenWrt forum.
In case of breaking something I can start over again
All this would not have started if mikrotik had finished its SFP GPON ONU which seems to be a shame that the product is discontinued.
Maybe with a simple stick update job it would have been enough
It would be a great product if they were back to support and new modules .
Maybe someone from mikrotik could read this great thread and see the needs of the Users
Thanks for the explanations.
hugomon
Mon Nov 25, 2019 3:56 pm
Hi, I have problems with my ONT Alcatel-Lucent O-010S-P, I can't even connect by SSH. I have tried 192.168.1.10, among others, but there is no ping.
Does anyone know this model, and if it is compatible?
AndreHro
Wed Nov 27, 2019 12:28 am
Hi everybody. I’m also interested in replacing a Movistar router by a Mikrotik hex S and sfp module. I could get one UGP-N1S GPON like mention above. Hope it will work.
Does anybody know if it’s possible to use this configuration for ipv6 too? So for my understanding over the gpon stick a pppoe connection is initiated and I get a IP address?
spaxton
Wed Nov 27, 2019 11:56 pm
Hola Friends
Hello friend,
I am trying to replace my huawei router for a long time. I own ZISA OP151s but it doesnt work for me. Can You, please, let me know if the module You showed here works for You? Can You attach some web interface photos?
Best Regards.
spaxton
Thu Nov 28, 2019 12:04 am
Hi there,
I have the ZISA one. It won't work with my provider so I don't need it. Interested?
Best Regards.
spaxton
Thu Nov 28, 2019 12:10 am
Guys,
Can anyone confirm that DFP-34G-2C2 actually works? Changing serial, VLANs? IPTV ? Everything works with it?
Best Regards.
JeanPierre
Thu Nov 28, 2019 6:51 am
hugomon
My model ONT G-010S-P responds to pings in Mikrotik. Please check my steps.
1. Assign sfp1 as WAN interface (it will remove sfp1 from the bridge)
2. G-010S-P and other models will not expose ethernet interface unless fiber cable is connected (link-ok, rate 1Gbps)
[admin@MikroTik] > interface ethernet monitor sfp1
                    status: link-ok
          auto-negotiation: done
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: SC
       sfp-link-length-9um: 20000m
           sfp-vendor-name: ALCATELLUCENT
3. Add IP address to the sfp1 interface
[admin@MikroTik] > ip address add address=192.168.1.15/24 interface=sfp1
4. [admin@MikroTik] > ping 192.168.1.10
SEQ HOST SIZE TTL TIME STATUS
0 192.168.1.10 56 64 0ms
1 192.168.1.10 56 64 0ms
2 192.168.1.10 56 64 1ms
3 192.168.1.10 56 64 3ms
5. telnet or ssh
[admin@MikroTik] > system telnet 192.168.1.10
[admin@MikroTik] > system ssh user=ONTUSER address=192.168.1.10
Users browsing this forum: No registered users and 7 guests
