cfragoso
Re: Usage GPON module SFP in Spain
Mon Jan 08, 2018 2:54 pm
Any updates about this? After reading some of your posts I have bought the ZISA SFP module recently and I will be playing with it as soon as I receive it.
I have a Huawei ONT provided by Movistar/Telefonica (Spain) and a Mikrotik CRS210-8G-2S+IN device as CPE.
If anyone can provide me some insights regarding how to obtain/identify the parameters necessary for negotiation from SFP unit to OLT Telco side.
Anyone already played to substitute Movistar ONTs?
Thanks!
fersat
Wed Jan 10, 2018 7:23 am
Who knows how change mac-address on ZISA SFP? I have downloaded firmware form https://www.valero-torres.es and unpacked it via 7-zip - now I can change etc/config/network. How build modified firmare back with correct checksumms?
huygensvlc
Fri Feb 09, 2018 10:48 pm
I'm in the same situation than you. Any progress with zisa module in Movistar Spain FTTH?
BR
I recently buyed an ZISA OP151S GPON SFP module,
I successfuly change SN and SLID to match with my ISP (Movistar)
however, I can not establish a connection.
Hal# -----------------ONT Info-----------------
OMCC state : Ready
ONU ID : 1
SN : MSTC2bXXXXXX
Password : F2017XXXXXXXXXXXXXXX
Power Level : 1
Ont State : O5 OPERATION
Ranging State: UNKNOWN
Admin state : UNLOCK
I think problem is in ranging state, that is unknown.
Can anyone help me to find the solutions?
Regards
huygensvlc
Fri Feb 09, 2018 10:49 pm
Check the SN, I think there are always 4 letters that identify the manufacturer + 8 numbers.
I'm in the same situation as last posts. I'm trying to get movistar ftth working with Zisa gpon sfp+ module. In my particular case SN matches mac address from HGU all-in-one router/ont/crap provided by ISP movistar.
Hal# show ont-----------------ONT Info-----------------
OMCC state : Ready
ONU ID : 56
SN : e8d1XXXXXXXX
Password : F2017XXXXXXXXX000000
Power Level : 1
any updates?
huygensvlc
Mon Feb 12, 2018 9:57 pm
I'm in the same situation than you. Any update?
OMCC state : Ready
ONU ID : 1
SN : MSTC2bXXXXXX
Power Level : 1
Regards
jlpedrosa
Mon Feb 19, 2018 2:22 am
Hi
To configure the Zisa, you need to plug the fiber in, plug the sfp into the router. When it comes online you need to configure an ip into that router sfp leg, of the range 192.168.1.0/24 except .1 which is the IP of the sfp.
then FROM the router, you can connect to 192.168.1.1 with telnet and use user/passd "twmanu" then follow the instructions here: https://www.valero-torres.es
Kr
spaxton
Sun Apr 15, 2018 1:14 am
Hello friends,
I've read it all... I am not from Spain but I have the same situation. I also have HPSP2120 and I wanted to use it with RB953GS but... NO LINK (RX LOSE when I connect the cable). I have seen the solution from @CarlitoxxPro but it seems to be very complicated. Is there any way to easily reprogram this module? Is there any other module which is easily programmable or via MikroTik ROS? Desoldering and programming the chip from it is so hardcore. :D Has anybody found a way to reprogram it without desoldering the chip ?
Best Regards.
ayeranu
Mon Apr 16, 2018 12:41 pm
I've read this and another forums, but I'm not sure to buy the Mikrotik spf gpon module. Not almost the provider develope an official firmware. Are there any news of this?
spaxton
Mon Apr 16, 2018 10:52 pm
How do You mean Mikrotik SFP module? You mean this one https://mikrotik.com/product/SFPONU ? I would buy it if it is going to work... but, what I have learned is that every ONU/ONT must be authorized on OLT side by the provider. They are authorized with the serial number and some of them also with MAC address. If this one from mikrotik allows us to change these parameters then we would be able to use it instead of cheap trash routers. You can check this thread and You will find one post where our mikrotik friend from Spain explains what he did... He had to desolder the chip from SFP module and then program it using the hardware eeprom programmer in order to set a different serial number and other parameters. I hope so some of them will make a post about this to explain us with more details and steps.
Best regards.
spaxton
Mon Apr 16, 2018 11:40 pm
Its correct, we found a way to configure correctly a module SFP GPON ONU to work very well with our routers mikrotik and differents ISP in spain like ORANGE, MOVISTAR and JAZZTEL, updating the firmware of our module and setting the SN, SLID(password) and other things required by some ISP like ORANGE and JAZZTEL, via web ui and telnet, no configurations needed on router mikrotik, this works like a traditional ONT (external).
Is very sad than mikrotik doesn't care their customers and dont provide any type of solution to this topic, but our effort to get the solution gived the success and now we are very happy with this solution, after a huge quantity of hours of test and fails, we got it..
+info here: https://www.facebook.com/CarlitoxxPro/
Dear Friend,
Can You let us know what You have exactly did here? Can You make some procedure with steps how did You make it work? Is this with Huawei HPSP2120 or with Mikrotik GPON module?
Best Regards.
vladod
Mon Apr 23, 2018 10:40 pm
Hello to all of you...
I have a similar situation with the OP151S GPON!
But I managed to setup GEMPORT-s and VLAN for IPTV.
So I'm able to se IPTV stream and I can decode it and watch it with VLC,
but my problem is that I can not set up properly UpStram GEMPORT so
I'm no abele to make WAN working!
Does any one know how to set properly WAN on OP151S ???
Best regards!
OMCC state : Ready
ONU ID : 1
SN : ISKTXXXXXXXX
Password : XXXXXXXXXXXXXXXXXX
Power Level : 1
Alferez
Tue Apr 24, 2018 6:23 pm
Dear Friend,
Best Regards.
No it's possible because hpsp is a tradicional sfp module, but disa is a router same as your company's ont, you configure from disa internal website, no from mikrotik interface.
I try use Huawei HPSP2120, at start of post you can see photos, i try rewrite eeprom, but in can't access to memory map zone, and it's more difficult than disa.
Visit my Blog about Networking, IOT and Mikrotik
MTCNA | MTCRE | MTCINE | MTCTCE | MTCIPv6E | MTCSE
andreacoppini
Trainer
Trainer
Fri May 11, 2018 6:24 pm
Just did this, with Orange Spain. Worked straight away.
Goodbye Livebox!
Thanks!
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
vladod
Sat May 12, 2018 12:46 pm
Nice work andreacoppini!
Could you help me with OP151S which stuck in 05-OPERATION mode (see previous post).
I can manually add GEMPORT-s and then I can see IPTV traffic.
But DHCP is not working and I'm getting error when my ISP provider ty to
attach GEMPORT-s like error = 3009.
Regards!
andreacoppini
Trainer
Trainer
Sun May 13, 2018 6:35 pm
I don't know how to help you. I'm still learning about GPON and I just followed the OP's thread above since I'm with the same ISP using the same SFP.
In your situation, I would start by setting up a known good setup (ie. use the ISP's own ONT/Router/IPTV Box) then sniff the packets by putting a MikroTik between Router and IPTV box and using a bridge.
fernandf
Sat May 19, 2018 7:23 pm
Someone has got the Zisa module working with movistar?
In this link they say it is working with Orange and that it should work with Movistar. https://www.valero-torres.es/2017/08/24 ... de-orange/
How do you get the SLID and the PLOAM from your current ONT?
Any hope to have a Mikrotik solution for this? Do we have an ETA for that indev firmware?
pateutz
Sat May 19, 2018 11:58 pm
Hi Guys,
any news about GPON configuration / solution for RCS-RDS in Romania.
Best Regards,
Daniel
andreacoppini
Trainer
Trainer
Mon May 21, 2018 12:38 am
Orange's LiveBox (ONT+Router+AP combo) actually shows this on the WebUI. When I had Movistar I had a separate ONT + Router, maybe there is a way to get onto the ONT (not the router)'s WebUI and take it from there?
Cascuda
Mon May 21, 2018 12:52 pm
Goodbye Livebox!
Thanks!
Thanks by confirmate the good operation of SFP module with Orange SPAIN.
Cascuda
Mon May 21, 2018 12:57 pm
I can't help now with Movistar (SAPIN) ISP... I think that my partner Carlos to worked more with Movistar and if can... he will write in of forum.
Alferez
Tue Jun 05, 2018 1:27 pm
I configured the Zisa with Yoigo / Masmovil and it worked without problems.
After obtaining the data and configuring it, it worked without problems and the first time.
stbnrivas
Thu Jun 28, 2018 10:08 pm
Howdy! I want to add me to this request to Mikrotik for they implements IdONT via PLOAM into SFP Module because I will can replace ISP's Hardware by Mikrotik's hardware into small companies to get a elegant solution. By now i will buy Zisa Stick to try until I can ... keep a calm and setup Mikrotik
I want give a thanks to Cascuda, CarlitoxxPro, Alferez. They are heroes and this thread is pure gold
vladod
Sat Jul 14, 2018 11:39 pm
HI to all... Can anyone halp me to configure VLAN 100 on OP151S GPON. SO like wan --> wan.100 interface, so i can start udhcpc client to obtain IP address?
andreacoppini
Trainer
Trainer
Sun Jul 15, 2018 6:04 am
Simply add a VLAN interface putting the master interface as the SFP port.
vladod
Sun Jul 15, 2018 10:35 pm
HI andreacoppini,
may be I was a bit unclear. I can't get OP151S SFP in mode to send any data through GPON optics, but I can configure it to be in state 5-OPERATIONAL with ranging UNKNOWN. Even with ranging unknown I can receive packets. I can also configure GEMPORT-s to watch neighbor IPTV traffic, but I can't set the DHCP Client on OP151S to get my IP address. To do that I must set VLAN ID to be 100 (I had sniffed packets on my ISP router). So when I'm using telnet to OP151S I can see 4 interfaces and the wan is configured without VLAN. So if I set vlan manually like wan.100 I can't get any traffic to pass wan except tx packets. Is it possible to put OP151S in bridge mode? My ISP is using VLAN 802.1q and 802.1ad (QinQ), but OP151S is only supports VLAN set through OMCI protocol which is not provided by my ISP.
andreacoppini
Trainer
Trainer
Sun Jul 15, 2018 10:54 pm
Yeah, like I said, you need to define a VLAN subinterface on the Sfp1 port and set your DHCP client (and Nat rules) on the VLAN interface, not SFP.
Most of the time it’s not QinQ but service tag, try setting the VLAN interface to “Service Tag” mode.
If it’s really QinQ, you can configure this on MikroTik too... check the wiki docs
Cascuda
Sun Sep 09, 2018 1:23 pm
I have a new post in my web, where I talk of new gpon module of my partner CarlosxxPro. This module is very customizable and I hope it is the future for new modules from other manufacturers.
Link --> https://goo.gl/gPrjJz
Alferez
Sun Sep 09, 2018 1:55 pm
The one with OpenWRT installed already gives you more options in the configuration.
d3m0
Sun Sep 09, 2018 4:55 pm
Do you mean that zisa module can be flashed with openwrt?
Cascuda
Mon Sep 10, 2018 12:05 pm
You need the CalitosxxPro "GPON-ONU-STICK-CPGOS03-0490" module to use openwrt.
andreacoppini
Trainer
Trainer
Wed Oct 03, 2018 7:14 pm
So I've tried to do this again on a new Orange Spain connection, but this time I can't get it past the INIT stage.
I did change the Serial Number and the PLOAN (ONT Password) on the ZISA SFP, but I suspect that Orange are no checking for firmware version too, but I don't know how to change these on the ZISA.
My Orange Livebox has "AR_LBFIBRA_sp-00.03.05.211D" which seems to have been compiled on Wed Jun 20 17:04:34 2018.
Does anyone know how to change the reported firmware version on the ZISA?
PS: I got in touch with Carlitoxx to buy their SFP, but they are currently out of stock. I'll buy their SFP as soon as they get stock anyway, as theirs is compatible with CCRs and is much easier to configure.
grawerpl
Mon Nov 05, 2018 3:56 am
@Cascuda is there a reason why you blocking access to your page https://www.valero-torres.es form other countries like Poland ?? every time i try i get "403 forbidden access"???
Cascuda
Wed Nov 14, 2018 1:18 pm
Sorry, but i've not blocked any country. It is possible that your public address is on a blacklist, then you can not connect to my website.
Chupaka
Wed Nov 14, 2018 1:57 pm
I get only "Sorry, your request cannot be accepted." (http 403) in my office, in my home and on my phone via mobile operator. Looks like your blacklist is quite big :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Miracle
Wed Nov 14, 2018 1:59 pm
Only 127.0.0.1 in white list
Cascuda
Wed Nov 14, 2018 5:44 pm
Can you try again ? I've purge the blacklist :D
Chupaka
Wed Nov 14, 2018 5:46 pm
Works now =)
grawerpl
Fri Nov 16, 2018 12:46 am
Now its working :P
Delboy
Sat Dec 08, 2018 3:02 am
Those who bought gpon sfp stick from CarlitoxxPro (CPGOS03-0490), can someone upload flash dump of firmware from it?
d3m0
Sun Dec 23, 2018 3:22 pm
I have a spare Zisa gpon module for sale. If there is someone interested please PM me.
Free shipping to Spain :)
mohands
Tue Jan 01, 2019 11:39 am
is this carlito one or what ?
andreacoppini
Trainer
Trainer
Tue Jan 01, 2019 12:09 pm
Not the carlito one. This is the ZISA module. The one referenced in the above documents before Carlito developed their own SFP (which is never available :-( )
d3m0
Tue Jan 01, 2019 1:09 pm
Yeah that’s right, the first one
mohands
Tue Jan 01, 2019 1:12 pm
contact carlito on facebook, I think he ship, I have this one S-Gpon-Onu from mikrotik, but I don't know why mikrotik doesn't make it easy to change S/N and other papramters to suit ISP ones. Most of ISPs use autoconfiguration for their onu units, and it's impossible that they can allow yours to access their networks
mrspeccy
Tue Feb 19, 2019 2:04 pm
Hi, unfortunately I cannot send you PMs for unclear reasons. I am interested in buying this Zisa module if still available. How much for shipping to Denmark be?
d3m0
Wed Feb 20, 2019 4:50 pm
I cannot send you PM also. Please give me an email or Skype.
thanks!
andreacoppini
Trainer
Trainer
Wed Feb 20, 2019 4:51 pm
Andrea at tacoppini dot com
mrspeccy
Mon Mar 04, 2019 9:38 am
Sorry for the late reply. I was not informed about your post by e-mail and just saw it by coincidence - something seems to be wrong with the forum software.
My e-mail address is hans.laude (at) web.de
fushigi
Tue Mar 19, 2019 2:49 am
Donde puedo conseguir el módulo SFP ONU Stick CPGOS03-0490
Estoy interesado en uno para mí RB4011iGS+RM
Gracias
Where can I get the SFP module ONU Stick CPGOS03-0490
I am interested in one for me RB4011iGS + RM
Thank you
Enviado desde mi SM-G965F mediante Tapatalk
mrspeccy
Tue Mar 19, 2019 9:28 am
@Cascuda
How did you create the modified firmware images for the ZISA OP151S that can be downloaded from https://www.valero-torres.es/? I can study the structure of the files with binwalk, find header, kernel and squashfs and can modify everything with the firmware-mod-kit (https://github.com/rampageX/firmware-mod-kit/wiki). However, the repacked image won't be accepted due to a checksum mismatch.
It seems to me that the first 1024 bytes of the firmware files contain a couple of checksums, e.g. at addresses
0x68
0x208
0x21c
0x220
How are these checksums computed? Any ideas?
elpeter
Tue Mar 19, 2019 11:14 am
Hello everyone!
I'm interested in getting rid of the "All-In-One" router from Movistar and I got excited reading this post and CarlitoxxPro&Valero's work thinking hat there's a slighyhly chance to do it. I was thinking in buying the Mikrotik SFP GPON ONU but I've seen here that there's no way to change it's SN and so on to make the OLT think that it's one of it's ONTs so my question here is, where can I manage to get one of hte Zisa's SFP GPON ONT? I wrote directly to Zisa but they're out of stock and I wrote also to CarlitoxxPro but no answer yet (I wrote to him yesterday thoug).
Thanks for the all the work and keep up the nice job :)
Regards,
Pedro
andreacoppini
Trainer
Trainer
Tue Mar 19, 2019 12:52 pm
Hola Pedro, I have a ZISA stick I’m selling. It used to work for me perfectly on Orange in Barcelona, but I have since moved to Sevilla and moved my Orange service with me and it doesn’t work here. I think the providers have tightened up their ONT checks in the ‘newer’ rollouts - or I’m just unlucky.
Send me an email (scroll up a bit, I wrote it in a previous message), and we can agree on a price.
fushigi
Fri Mar 22, 2019 3:55 am
Aún lo tienes?
d3m0
Fri Mar 22, 2019 10:11 am
Aún lo tienes?
Si, aun lo tengo. Mandame un privado
fushigi
Fri Mar 22, 2019 7:17 pm
Aún lo tienes?
No me me deja mandar mp
d3m0
Sat Mar 23, 2019 1:03 am
Aún lo tienes?
Escríbeme a demo2k6 arroba gmail.com
elpeter
Tue Mar 26, 2019 2:01 pm
Did anybody manage to get the Zisa GPON working with Movistar? If so, please do you mind to share it with us? some screenshots or some Mikrotik terminal commands would be highly appreciated.
Thanks!!
fushigi
Sat Mar 30, 2019 6:53 pm
Has anyone tried the FGS202 GPON SFP ONT module?
mgarcia
Fri Apr 05, 2019 1:46 am
Dear all,
after a long fight with this Zisa SFP I´ll explain my situation:
My Hardware: Mikrotik CCR1036-12G-4S (ROS 6.44.2) + ZISA OP151S
When received the modeule I had to update the firmware to be able change LoID/PloamPWD/IdONT.
After that, logged by Telnet and updated Serial Number by the one of my Mitrastar and cloned also MAC of my ONT. Still not working. (i changed MAC of SFP1) by terminal in my Mikrotik.
I used the steps explained in the link below. Except the mac address change that was my decision after test all other possibilities.
I Can say that I didn't update files nº2 and nº3 that are mentioned in te link. I'm not sure that are extremely necessary in my scenario with Movist.
LOGED IN MITRASTAR by WEB:
192.168.1.1/instalación: 1234/"Mitrastar Password"
- Here we can read IDont, serial and MAC address.
LOGED IN MITRASTAR by SSH: admin/"Mitrastar pass"
> ponshowmac (shows ONT mac address)
> transmitterinfo ( shows vendor name, vendor SN in Mitrastar )
mine shows:
Vendor Name: MSTC_GN25L95
Vendor SN: S180Yxxxxxxxx
I'm not 100% sure but I think there are around 4 left possible causes that are affecting me:
1st: Serial Number to change in Zisa are the ones shown in Mitrastar by ("transmitterinfo" command or the one shown in 192.168.1.1/instalación)
- I can imagine the one in 192.168.1.1/instalación. is the only one that have 4 letters and 8 characters.
2nd: MAC address have to be changed? if true Could we use Mikrotik Terminal? or is can be changed by telnet in Zisa Gpon? I'll still checking.
3rd: Sometimes when Mikrotik shows SFP info like voltage etc.. Mikrotik reboots. (tile/rOS incompatibility) link goes up when fiber plug.. seems all ok. but. (not always shows sfp parameters) I think the most provable cause of fail.
4th: and the most strange thing: we know that this ISP I mentioned uses vlan 6,3,2. when we setup by web interface in Mitrastar router all vlans are created as that vlan ID's.
but: by SSH when in Mitrastar I type command below shows:
> vlantable
Upstream:
TCONT_number GEMport VLAN_id UNI_interface Service Name
273 273 950 ppp0.1 6
274 274 5 veip0.3 2
276 276 3 veip0.2 3
ID 950?
ID 5?
I'll still fighting
Many thanks!
Alferez
Fri Apr 05, 2019 4:03 pm
Zisa is not compatible with Tilera, I have not tried it, but that is what was said.
fushigi
Fri Apr 05, 2019 9:08 pm
Dear all,
Where did you buy the ZISA OP151S module?
mgarcia
Sat Apr 06, 2019 2:03 am
Dear all,
Answering Fushigi: I bought in Alibaba. I bought it for 60€ aprox + premium shipping 4 days. + tax = around 120€ aprox.
well: finally the problem was the firmware version. after update and changing (idONT, Serial Number, MAC ) services are working in Movist. ISP in Spain, for sure the rest also will work. I don't know if MAC have to be changed, but I did it for safety. I heard that ID and Serial are enough.
Firmware Link: segurasoft.es/zisa/TW2362H-CDEL-TW-R01B010D35befddf-CN.squashfs.upf
I have vlan6, vlan3 working, except vlan2 (TV) what for sure is something wrong in my Mikrotik configuration.
when all ready and tested I'll post news.
kind regards to all, and keep pushing!
Error0x29A
Sat Apr 13, 2019 2:37 am
I tried. Module itself is compatible, same Lantiq(Intel) family chipset PEB98036ETV13 (like OP151S)
Facing similar problem as previously: changing Serial Number to match the one from Livebox Fibra.
One of users posted flash dumps if anyone wants to take a closer look.
https://forum.turris.cz/t/orange-france ... ter/3776/4
Error0x29A
Thu Apr 18, 2019 7:32 pm
How is your experience with Zisa? On the Alibaba they mention after-sale support and access to the firmware.
Can you get different firmware versions or ask them to make one, specifically for your needs?
mgarcia
Thu Apr 18, 2019 10:41 pm
Still waiting answer.. I sent some mail but nothing.
If finally you use Zisa try default firmware, my problem was a firmware that became in freezes when trying to upgrade idONT by web, then I found a list of all telnet menu options and was easy to manage in telnet.
after upgrading my firmware to the one I posted few days ago, upgrading idONT from web was fine and the rest by telnet.
Now works really fine the following:
PPPoE over vlan6 for Data, vlan3 for VoIP that works fine also.
What I'm still trying is setup the vlan2 wich is used for IPTV. I have all routes in RIP, interfaces in IGMP Proxy setting etc. All config required by the ISP was configured and checked.
I Understand that if Vlan3 wich is used for VoIP service works vlan2 would be fine too. I don't know if wrong setup by my side or ISP change some setting in that service because was just contracted 2 or 3 weeks ago.
If someone is fighting also with this we can work together.
zlobster
Fri Apr 19, 2019 12:31 pm
Can anyone please post a link where this OP151S can be bought?
All I'm getting some fishy hits on Google... :roll:
saper2
Fri Apr 19, 2019 12:56 pm
Like mgarcia have written, you can find it on Alibaba: https://www.alibaba.com/trade/search?fs ... ext=op151s
Sent from my VTR-L29 using Tapatalk
Error0x29A
Fri Apr 19, 2019 3:24 pm
and don't forget to check "Ready to Ship" option otherwise you will get many irrelevant results.
fushigi
Fri Apr 19, 2019 9:57 pm
Until June they do not have loose units to send in Alibaba.
At least they will be bulk orders.
I got in touch with ZISA CO LTD.
(How many you want to buy for OP151S? because the sample is out of the stocked,so just can provide with bulk orders,there is quantity limit,but the price will lower.)
zlobster
Fri Apr 19, 2019 11:37 pm
Thanks, everyone!
I just want 1 or 2 to try outsmarting the Huawei OLT.
I have a great success with UBNT (hence my avatar) but I will be extremely happy if I can get a working SFP, in order to consolidate the devices needed.
saper2
Sat Apr 20, 2019 1:42 am
You mean ONU/ONT , OLT is in ISP cabinet :)
I'm sorry for off-topic, I hope you're forgive my curiosity ;) : Can you tell what Huawei ONT model you've got from ISP?
zlobster
Sat Apr 20, 2019 9:30 am
No, I really meant outsmarting the OLT (by tricking it to think it is working with an original EchoLife, while it is not).
saper2
Sun Apr 21, 2019 12:49 pm
Right, sorry :) I don't know how I missed the "outsmarting" word :? - my mistake.
Could you share what ONT (the model) you got from ISP ?
zlobster
Sun Apr 21, 2019 1:49 pm
HG8245H by Huehuehuewie
saper2
Sun Apr 21, 2019 3:16 pm
Thanks, the Huehuehuewie made my day ImageImageImage Image
portmap
Tue Apr 23, 2019 12:56 am
I’ve got the hg8311 and the zisa gpon stick, i’m trying to get the gpon stick to work and get rid of the huawei device, how can I determine what the idONT, Serial Number, MAC is for the hg8311?
and is that all I need for the gpon stick to work?
Thanks!
Error0x29A
Tue Apr 23, 2019 2:59 am
Thanks!
Look at the box and label. Most information should be there. Huawei devices use the same format:
MAC: 8866390A1F9B
GPON Serial Number: HWTC071F9B93
GPON password should be 10 digits long if listed in ASCII format: 4703578867 or hex(34 37 30 33 35 37 38 38 36 37)
Where is it located?
It will depend on the device or provider. I would start by login to the device by using web and telnet and looking around.
login: 192.168.100.1
username: root
password: admin
Error0x29A
Sat Jun 15, 2019 2:58 am
Has anyone was able to get OP151S modules lately?
I get signals that only supplier is out and will only resume production with minimum order of 100
Are there any other alternatives available?
iperezandres
Sat Jun 15, 2019 10:32 am
I've seen it in alibaba for 60-70$, minimum 1 unit.
Error0x29A
Wed Jun 19, 2019 3:19 am
Thanks.
Even it shows 1 unit, they are Out of Stock at this moment.
iperezandres
Wed Jun 19, 2019 10:27 am
Good to know, we will have to wait...
AntonioLON
Sun Jul 14, 2019 8:38 pm
Hola Friends
Very happy to find this forum. My ZIZA OP151S is working well for my girlfriend in Madrid. I did the serial change and other changes :D
On github I collected packing software for Ziza https://github.com/kovalenko/SFP-GPON
fushigi
Tue Jul 16, 2019 2:33 pm
Alibaba msg
(We need to collect 50pcs to produce,it's minimum quantity,at this moment,there is only 30pcs demand from clients)
Is someone else going to buy?
https://app.alibaba.com/dynamiclink?tou ... cene=buyer
zlobster
Tue Jul 16, 2019 2:56 pm
Alibaba msg
Count me in! I can pay later for my piece(s) via PayPal later.
I may even get 2 SFP.
AntonioLON
Mon Jul 29, 2019 6:46 pm
Hola Friends
friend in Valencia asked for me help. he got good SFP stick. lot of options to modify serial\vendor\part number\ and more. sticks have open source openwrt
login web 192.168.1.57 or telnet to sfp
OEM company\\ dipperoptics\dpoptics stick numero D23446
Licensee company \\ hilinktech\ stick number HL23446
andreacoppini
Trainer
Trainer
Mon Jul 29, 2019 7:13 pm
Where did you buy it?
AntonioLON
Mon Jul 29, 2019 7:41 pm
let me check with friend, I think it was alibabba
saper2
Mon Jul 29, 2019 7:56 pm
Hola Friends
Here is this SFP Image :
http://www.dpoptics.com/col.jsp?id=290 (in main menu is link to their Alibaba account).
Here is hilink:
https://www.hilinktech.com/pon-sfp-xfp/ ... h-mac.html
Error0x29A
Thu Aug 15, 2019 5:11 pm
sticks have open source openwrt login web 192.168.1.57 or telnet to sfp
What is the benefit of running openwrt on SFP? There's no wireless.
saper2
Thu Aug 15, 2019 8:56 pm
Openwrt is is for routers (for routing) not just for managing ap wifi. Openwrt have that same purpose like RouterOS from Mikrotik, but openwrt is open source
vdias
Mon Aug 19, 2019 12:58 pm
Hola Friends
How can i buy this SFP? Does your friend have it working with movistar?
AntonioLON
Tue Aug 20, 2019 1:13 am
Hola Friend,
contact companies on alibaba. our friend saper2 gives link to dipperoptics. other company also lives on alibaba
https://hilinktech.en.alibaba.com/search/product?SearchText=stick
chinese friends are not easy. they want to sell 50, 30, 20 pieces to you. stay on alibaba messenger, she will goto manager, after 1-2 hour maybe sell 1 piece
5 euros more gives you SFP temperature Industrial
my friend in Valencia lucky. all working cause good OLT in community.
HL23446 is Alcatel clone. lot of options to configure serial number/vendorID/MAC and 3 profiles for OLT
i Ask my friend to send some examplas
vdias
Wed Aug 21, 2019 11:40 am
Shop owner replied saying that they don't have APC type sfp... does the UPC version work here in Spain?
saper2
Wed Aug 21, 2019 11:43 am
You mean fiber optic connector SC/APC? Then just use patchcord cable with SC/APC to SC/UPC connectors (and SC/APC adapter).
Alferez
Wed Aug 21, 2019 11:55 am
You only need this cable:
Green: SC/APC
Blue: SC/UPC
saper2
Wed Aug 21, 2019 12:03 pm
Green: SC/APC
Blue: SC/UPC
Yes exactly.
I mentioned adapter because in my country ISP's rarely install a wall SC/APC socket, instead they attach directly to fiber cable (that going directly from wall) the SC/APC plug to the router.
vdias
Thu Aug 22, 2019 4:46 pm
Chinese seller answer: "Sorry, dear. My engineer told me that our GPON stick can't compatible with Mikrotik"
1 second after... she send me this invoice... don't really understand...
fushigi
Thu Aug 22, 2019 5:14 pm
The model is hl23446-sshe
I have also asked for one.
vdias
Thu Aug 22, 2019 6:18 pm
i bit expensive... :(
Error0x29A
Thu Aug 22, 2019 6:24 pm
$30 shipping, that's a lot. Unless you are in hurry. 14 days by China Air should not be more than $10-$12
Regarding compatibility with Mikrotik. I had the same problem with SFP FGS202. It works on some models and firmwares and sometimes it does not.
According to SFP MSA specifications pin 6 on SFP modules should be connected to the ground. Pin 6 is called MOD_ABS (module absent)
When inserted into a router by providing the ground on that particular pin, it will indicate the module presence. If firmware algorithm is more advanced(bigger size) it may try to detect SFP module by other means.
On some SFP they don't provide the ground on pin 6 because is used to output diagnostic data over uart-serial protocol.
If you have a chance, ask the engineer how the pin 6(mod_abs) is connected.
fushigi
Thu Aug 22, 2019 7:56 pm
Error0x29A
Thu Aug 22, 2019 9:15 pm
Note 3, Grounded in Module
These specs are not always followed by manufacturers. Large clients may request different pin assignments.
On some networking site they did comparison of several GPON modules. Not all of them had ground connected to pin 6.
fushigi
Thu Aug 22, 2019 9:23 pm
They sent me those specifications.
saper2
Thu Aug 22, 2019 9:41 pm
In datasheet is pinout, pin 6 is connected to ground
Error0x29A
Thu Aug 22, 2019 9:57 pm
Great. Can't wait for reviews and configuration guides :)
saper2
Thu Aug 22, 2019 10:38 pm
Look at sshe file, there is how to connect to the sfp and get optical link parameters (and how to put them into excel) - I just scrolled through the file only so I might be wrong
Setting access to module on mikrotik might be a tricky but possible ( I managed to setup hg612 with access to it via single cable , while all guides was saying that is not possible with only one cable).
Error0x29A
Fri Aug 23, 2019 1:39 am
Look at sshe file, there is how to connect to the sfp and get optical link parameters (and how to put them into excel) - I just scrolled through the file only so I might be wrong Image
The document have some interesting information. I wish I had a module in my hands to experiment with :)
Part about using SmartBits 600B performance testing certainly will not apply to me. Can't afford such equipment. On the page 4 they included instructions about optical calibration by transmitting 1.25G of random 1's and 0's continuosly toward network. IMO those lines should be removed.
Error0x29A
Mon Sep 09, 2019 6:35 pm
Any updates? Did you receive the Gpon-hl23446-sshe module?
How well is it working with Orange or Movistar?
MrAlester
Tue Sep 17, 2019 5:43 am
Hi, is there someone out there selling Zisa's or Carlitos SFP?
I tried contacting Zisa but they wouldn't sell me one.
AntonioLON
Sun Sep 22, 2019 9:07 pm
Hola Friends,
I share configuration guide for you for SFP modulo D23446/HL23446
D23446/HL23446 initial configuration V.01
Warning!!!
Do not modify any optical parameters(GOI). Avoid direct exposure to a laser beam!
Network stack will become available approximately 80 seconds after power up.
Run the Telnet software on PC, such as the TeraTerm
https://osdn.net/projects/ttssh2/releases/
Set the Host as <192.168.1.57> (the GPON STICK’s IP address), choose the Service as <Telnet> and connect
Quick Setup (Serial Number and GPON password change)
fw_setenv ont_serial ARLT12345678
uci set gpon.ploam.nPassword='0x30 0x36 0x32 0x32 0x38 0x36 0x53 0x30 0x34 0x34'
uci commit
reboot
1. Build Info
OpenWrt - (14.07_ltq) --- Lantiq Edition for GPON
Linux SFP 3.10.49
2. Partition layout
dev:    size   erasesize  name
mtd0: 00040000 00010000 "uboot"
mtd1: 00080000 00010000 "uboot_env"
mtd2: 00740000 00010000 "linux"
mtd3: 00618322 00010000 "rootfs"
mtd4: 00420000 00010000 "rootfs_data"
mtd5: 00800000 00010000 "image1"
3. Flash Info
uboot -     0x040000
uboot_env - 0x080000
image0 -    0x740000
image1 -    0x800000
total -    0x1000000 16MB
4. Memory (DRAM) info
memory size - 0x4000000 64MB
5. Display all GPON Stick variables. Copy and store it in a safe place
root@SFP:/# fw_printenv
root@SFP:/# uci show
6. Verify if the u-boot environment variable 'target' is set
root@SFP:/# fw_printenv target
target=oem-generic
Each configuration value if present in the startup file sys.sh will be overwritten
Conventions:
# - \s is used to place a space (ASCII 0x20)
# - \0 is used to place ASCII 0
# - enclose "a b c" in quotes (either single or double) to interpret it as one attribute
Display and edit the file /etc/init.d/sys.sh with your current ONT values
root@SFP:/# cat /etc/init.d/sys.sh
       oem-generic)
                uci set sys.target.name=oem-generic
                uci set sys.features.mib_customized=1
                uci set sys.features.igmp_fast_leave=1
                uci set sys.features.dying_gasp_enabled=0
                uci set sys.features.suppress_power_level=0
                uci set sys.features.eeprom_sync_option='1'
                uci set sys.mib.vendor_id='ARLT'                    # 4 char Vendor ID left-aligned
                uci set sys.mib.ont_version='ARLTLBFIB2.0.0'   # 14 char Hardware Version left-aligned padded with zeros
                uci set sys.mib.equipment_id='PRV3399B_B_LT\0\0\0'  # 16 char model name left-aligned padded with zeros
use vi editor to update Vendor ID, Hardware Version, Model Name
root@SFP:/# vi /etc/init.d/sys.sh
7. Update serial number, password, MAC address, image version
fw_setenv image0_version AR_LBFIBRA_sp-00.03.04.091
fw_setenv image1_version AR_LBFIBRA_sp-00.03.04.095
uci set network.host.macaddr='e4:3e:d7:69:be:ef'
uci commit
reboot
8.Emulated EEPROM commands
sfp_i2c command will automatically calculate correct A0h checksums at offsets 63(0x3F) 95(0x5F)
indexes [-i] are written in decimal and converted to hex
a. Display stored soft eeprom data values
root@SFP:/# uci show sfp_eeprom.default.data_eeprom_0
b. Reset eeprom to default values (LANTIQ,NO_PART_NUMBER,0001,NO_SERIAL_NUMBER,140101)
root@SFP:/# sfp_i2c -d yes
c. Write to eeprom your ONT values
sfp_i2c -i 0 -s "HUWAWAWEI"         # 16 bytes(ASCII) Vendor Name left-aligned
sfp_i2c -i 1 -s "PRV3399B_B_LT"     # 16 bytes(ASCII) Part Number left-aligned
sfp_i2c -i 2 -s "0001"              #  4 bytes(ASCII) Part Number Rev. left-aligned
sfp_i2c -i 3 -s "ARLT567890123456"  # 16 bytes(ASCII) Serial Number left-aligned
sfp_i2c -i 4 -s "181224"            # 8 bytes Date Code(mandatory)
sfp_i2c -i 36 -w 0xe43ed7 -4 -m 0x00FFFFFF          # 3 bytes MAC address Vendor OUI
8. For some applications LAN port speed can be set to 2.5G
a. Set LAN port speed to 2.5G
fw_setenv sgmii_mode 5
b. Remove LAN port speed 2.5G (back to default 1G)
9. asc0 mode pin configuration
Turn off UART. Set pin#6 of 20 to low(module availability indication)
fw_setenv asc0 1
Troubleshooting (bricked device)
Set asc0 to 0 temporarily, change back asc0 to 1 when finished.
fw_setenv asc0 0
Connect USB UART adapter to pin#3 of 20(RX) and pin#6 of 20(TX)
Press SPACE to delay and Ctrl-C to abort autoboot in 5 seconds to modify environment variables
FALCON => printenv asc0
asc0=1
FALCON => setenv asc0 0
FALCON => saveenv
Saving Environment to SPI Flash...
SF: Detected GD25Q127C with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Erasing SPI flash...Writing to SPI flash...done
Valid environment: 1
Ignore Ctrl-C, wait for the full console (asc0=0) then press Enter
root@SFP:/#
fushigi
Mon Sep 23, 2019 8:18 pm
Hola Friends,
Warning!!!
uci commit
reboot
1. Build Info
Linux SFP 3.10.49
2. Partition layout
3. Flash Info
uboot -     0x040000
image0 -    0x740000
image1 -    0x800000
target=oem-generic
Conventions:
       oem-generic)
uci commit
reboot
fw_setenv asc0 1
fw_setenv asc0 0
asc0=1
FALCON => saveenv
root@SFP:/#
I can't get into telnet. :(
Putting on the host pc 192.168.1.1 and destination 192.168.1.57
If the easiest doesn't work for me.
Edit
My PON unit has IP 192.168.1.1
fushigi
Mon Sep 23, 2019 9:35 pm
Hola Friends,
Warning!!!
uci commit
reboot
1. Build Info
Linux SFP 3.10.49
2. Partition layout
3. Flash Info
uboot -     0x040000
image0 -    0x740000
image1 -    0x800000
target=oem-generic
Conventions:
       oem-generic)
uci commit
reboot
fw_setenv asc0 1
fw_setenv asc0 0
asc0=1
FALCON => saveenv
root@SFP:/#
It works and with mikrotik
MASMOVIL
It is another model that sent me is entered by web and is configured as an ONT ZTE.
Error0x29A
Mon Sep 23, 2019 11:07 pm
fushigi, please explain. Your model from the picture is not HL23446. What did you get?
I want to get one for myself before week ends.
Error0x29A
Mon Sep 23, 2019 11:19 pm
oem-generic)
The configuration code is somewhat similar to https://www.valero-torres.es/2018/09/08 ... de-orange/
As CarlitoxxPro explained in another post only 1-2 companies make original sfp. Rest are clones.
fushigi
Mon Sep 23, 2019 11:27 pm
They sold me this HL-190822
Error0x29A
Tue Sep 24, 2019 11:06 pm
Good for you. Another happy fiber user :)
Search on the "DFP-34G-2C2" keyword from your picture brings a Chinese company named usourcetech. They could be the original supplier.
http://www.usourcetech.com/web/userfiles/download/GPONSTICKSFPCLASSB-2B_Rev01.pdf
I'm more concerned with advanced configuration screens. GPON sticks like Zisa, Hilink, CarlitoxxPro have many options important for Orange/Jazztel users.
What do you have on the PON screen? Anything more if telnet is used?
fushigi
Wed Sep 25, 2019 12:41 am
http://www.usourcetech.com/web/userfile ... _Rev01.pdf
PON
LOID and SN can be changed.
Telnet screenshot
DeVlL
Wed Sep 25, 2019 12:01 pm
PON
Telnet screenshot
Good. How does the SFP module behave? Does it get very hot? Can you give me more information?
I have the pepephone connection (orange network) and I want to remove the ONT. I'm waiting for CarlitosPRO to have stock but it never arrives.
Thank you
Error0x29A
Wed Sep 25, 2019 5:28 pm
fushigi,thank you for your time answering our questions.
In the previous post you mentioned RB4011. Does that mean your new HL-190822 works with RB4011? What is the Mikrotik software version ?
fushigi
Wed Sep 25, 2019 7:00 pm
Mikrotik model: RB4011iGS+
RouterOS: 6.45.6
fushigi
Wed Sep 25, 2019 7:08 pm
PON
Telnet screenshot
Thank you
I have it working 2 days and for the time being fine.
The stick is at 54 ° with room temperature of 27 ° I have it in a rack.
DeVlL
Wed Sep 25, 2019 9:21 pm
PON
Telnet screenshot
Thank you
Okay. It seems to look very good.
The model I buy is the HL-190822? And above it has a web interface to configure it easily.
What was the cost with shipping costs (I am from Spain like you)
Regards
fushigi
Wed Sep 25, 2019 9:24 pm
Some heatsinks and temperature going down xD
fushigi
Wed Sep 25, 2019 9:28 pm
PON
Telnet screenshot
Thank you
Regards
Only 79 $ with shipping to Barcelona
DeVlL
Fri Sep 27, 2019 11:44 am
PON
Telnet screenshot
Thank you
Regards
Okay. It is well priced. How do I buy it and what payment method do I use?
Petronas
Tue Oct 01, 2019 2:32 pm
I have the dpoptics model and it doesn't work, :(
comment on my experience
Buy at " DPOPTICS D23446 STHE " company, and sendme " SOURCEPHOTONICS SPS3424THPTDFO " .
Oh my god !! :?
I look inside stick and are from third-party manufacturers, look pictures :oops:
In this equipment the configuration is only done by telnet and I do not have access to the configurator via the Web. The IP is 192.168.1.10 and does not work.
I have a beautiful paperweight.
Any help would be welcome.
To whom the support now belongs to dpoptics? or sourcephotonics ?
Be careful with the Chinese, there is a mobsters between them, they are not honest.
fushigi
Tue Oct 01, 2019 6:47 pm
Buy at " DPOPTICS D23446-STHE " company, and sendme " SOURCEPHOTONICS SPS3424THPTDFO " .
Oh my god !! :?
https://ibb.co/zXbZd8y
Have you tested with IP 192.168.1.1 , 192.168.1.50 and enter via telnet, web ?
JeanPierre
Tue Oct 01, 2019 9:16 pm
Oh my god !! :?
Long time reader of this forum first time poster
SPS3424THPTDFO and telnet IP is 192.168.1.10 reminds me our Alcatel units. same login IP, same serial SPS on unconfigured units. In Canada we are connected to Nokia/Alcatel or Huawei optical splitters. ISP supplies users with three types of units Huawei - ma5671a Alcatel/Nokia - g-010s-a or g-010s-p
Don't worry what you see on the Mikrotik screen. it uses i2c bus to read eprom's "burned" serial number. Your gpon module will get serial and password from environment variables area.
My tv box came originally with g-010s-a which later I swapped for g-010s-p. The unit is very well tuned(important if you live far from the optical splitter)
pass and snumber change took me 5 minutes. very easy, couple of commands and you are set. Check my notes
onu gtcsng ------------>>> display gtc serial number (gtc_serial_number_get)
onu gtcpg ------------->>> display gtc password (gtc_password_get)
Login as ONTUSER@192.168.1.10 (protocol ssh) or telnet 192.168.1.10 (protocol telnet)
BusyBox v1.19.4 (2015-02-14 18:25:19 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
ATTITUDE ADJUSTMENT (Attitude Adjustment, 12.09_ltq)
root@SFP:/# onu gtcsng
errorcode=0 serial_number=ALCL98765432
root@SFP:/# onu gtcpg
errorcode=0 password=1234567890
root@SFP:/#
Set password and serial
root@SFP:/# fw_setenv nPassword 1234567890
root@SFP:/# fw_setenv nSerial ALCL98765432
Erase nSerial/nPassword
nSerial is vendor+8 characters
nPassword is exactly 10 characters
Petronas
Tue Oct 01, 2019 9:46 pm
Oh my god !! :?
Hello.
Yes I test 192.168.1.1, and others
Only conect 192.168.1.10 ssh, does not connect via web any Ip
I do a port scanner and Ip that is the only available 192.168.1.10 that sends the stick
No web service is active.
I Just connect via ssh enter the commands to configure the manual, without success.
my locality Spain too
It seems that we have different versions of firmware
Error0x29A
Wed Oct 02, 2019 12:04 am
Hello.
I did a Google search. ONTUSER is a login name for Alcatel-Lucent ONT
https://www.adslzone.net/foro/fibra-opt ... 252/page-2
Please tell us your partition setup. Someone must have similar firmware. Execute command cat /proc/mtd
OpenWrt - (14.07_ltq) --- Lantiq Edition for GPON is the same firmware version like posted by AntonioLON in the post #210
Did you try his quick setup commands?
text to hex converter https://online-toolz.com/tools/text-hex-convertor.php
Petronas
Wed Oct 02, 2019 4:04 pm
Oh my god !! :?
root@SFP:/#
Thx.. 8)
I managed to burn the integrated with the "sfp_i2c" commands shown above
But command strings don't work.writing.
:oops: :evil:
If they can read but do not write, I check again and they are not recorded.
JeanPierre
Wed Oct 02, 2019 4:48 pm
Antonio's commands make more sense to me. He's on 14.07_ltq. I am on 12.09_ltq
** remove 12.09 variables **
fw_setenv nPassword
fw_setenv nSerial
** use 14.07 (Antonio post #210) **
fw_setenv ont_serial HWTN12345678
convert password to hex in rapidtables https://www.rapidtables.com/convert/num ... o-hex.html ---->> 0123456789 hex=30 31 32 33 34 35 36 37 38 39
uci set gpon.ploam.nPassword='0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39'
uci commit
reboot
** verify after reboot **
Petronas
Wed Oct 02, 2019 8:24 pm
fw_setenv nPassword
fw_setenv nSerial
uci commit
reboot
I write these commands and write correctly, then I check and they have not been written
JeanPierre
Wed Oct 02, 2019 10:46 pm
Without an actual unit in my hand I'm out of ideas. You may wish to dump and examine results of uci show and fw_printenv. List directories /etc/config and /etc/init.d
Examine closely files gpon sys onu.sh for env names used by the system. If possible post them on pastebin.com for others to see
Error0x29A
Wed Oct 02, 2019 10:58 pm
Petronas,
Two questions. Did you ask the Chinese company for setup instructions? What is your Mikrotik model and software version?
Thank you.
Petronas
Thu Oct 03, 2019 9:35 pm
:D
SFP_GPON "uci show"
https://pastebin.com/pxqkL9S0
SFP_GPON "fw_printenv"
https://pastebin.com/Fjc6f3dX
SFP_GPON " List directories /etc/config and /etc/init.d "
https://pastebin.com/XkdVFskn
What path are the files on? files gpon sys onu.sh ??
I write several emails to the seller and not answer, just sendme a small useless manual, with only ONTUSER and password.
Saying that the configuration of the equipment is also done by Web Page.
Also I understand that ONTUSER is a user with administrator privileges but is not superuser, root. :?:
Mk model: CRS125-24G-1S
Firm: 6.45.6 (stable)
JeanPierre
Fri Oct 04, 2019 6:47 am
onu.sh and sys.sh are in /etc/init.d gpon in /etc/config
One variable inside of fw_printenv on the pastebin site has some private info, I recommend to remove it.
Maybe http daemon is on port 8080 or 8000
root@SFP:/# ps | grep http
Try netstat for verifcation of all running programs with open ports
root@SFP:/# netstat -antp
Is 66 a typo? (from your uci show) nPassword must be exactly 10 characters, each prefixed with 0x
gpon.ploam.nPassword=66 0x32 0x30 0x31 0x32
In fw_printenv I see too many potentially conflicting variables present in your environment which make sense for my g-010s-p module. Start by removing duplicates and errors.
root@SFP:/# fw_setenv image0_verison
If your provider decided not use a password, I recommend applying 10 zeros.
root@SFP:/# uci set gpon.ploam.nPassword='0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30'
root@SFP:/# uci commit
root@SFP:/# reboot
connect fiber when ready and check the registration status looking for 5
root@SFP:/# onu ploamsg
errorcode=0 curr_state=5 previous_state=4 elapsed_msec=30428
if curr_state=5 you may continue with vlan pppoe/dhcp setup.
I hope it helps. I used Antonio's notes and my g-010s-p module for comparison. Some variables and commands may react differently on each module version.
DeVlL
Fri Oct 04, 2019 2:22 pm
Good lords. I asked the manufacturer of alibaba the hl23446-sshe and I was asked the connector I want for the STICK.
Looking at the previous messages of this thread there are two.
Green: SC / APC
Blue: SC / UPC
The one that puts the ISPs in Spain is the Verde: SC / APC, right?
saper2
Fri Oct 04, 2019 3:08 pm
Mostly sfp modules have SC/UPC (blue). In plastic modems you can find APC (green), or (blue) UPC. So, if you have a green APC plug from wall , you just need a SC APC to SC UPC patchcord and SC APC (simplex) adapter.
Sorry, I can't answer exactly what you want to know, but using adapter and patchcord works fine, if you don't have yet fiber then look for what you need after you have installed modem from ISP because they can install modem with SC/APC or SC/UPC (depends what they have at hand)
Petronas
Sat Oct 05, 2019 9:07 pm
root@SFP:/# reboot
sys.sh
https://pastebin.com/86kXkL7R
gpon
https://pastebin.com/69WDpWbR
ps | grep http
https://pastebin.com/KcEJP3nP
netstat -antp
https://pastebin.com/iiMgV4Mz
onu ploamsg
https://pastebin.com/QFFqbd7c
In my stick, the HTTP service to configure is not activated.
I do not understand very well the string to be introduced is more than 10 characters but my record is more. although I change it for HEX data.
JeanPierre
Sun Oct 06, 2019 2:48 am
Thank you for the last picture. HG8240 has already converted values to hex. Examples with fake numbers.
00f201200048 -->> serial number
f2012000443688011024 --->> gpon password f2 01 20 00 44 36 88 01 10 24
prefix each pair in password with 0x
0xf2 0x01 0x20 0x00 0x44 0x36 0x88 0x01 0x10 0x24
root@SFP:/# uci set gpon.ploam.nPassword='0xf2 0x01 0x20 0x00 0x44 0x36 0x88 0x01 0x10 0x24'
root@SFP:/# fw_setenv ont_serial 00f201200048
root@SFP:/# reboot
osquetar
Sun Oct 06, 2019 10:36 am
Yeah, but I need that my Mikrotik, with a transceiver S-85DLC05D inside, works. Only one device and only one power unit.
If the next RouterOS 6.xx or 7.00 don't do so, why to continue with Mikrotik? Sure I'll find another brand.
Any advice?
msatter
Sun Oct 06, 2019 5:31 pm
This thread goes about using a SFP in a Mikrotik, which should not be posible because the ISP/provider does not allow that to happen using their service.
Now it is posible if not easy.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47.1 / Winbox 3.24 / MikroTik APP 1.3.14
AntonioLON
Sun Oct 06, 2019 6:41 pm
Holla msatter,
Spaniards Italians French are about life. always easy to work SFP with Mikrotik in those countries. i work in London now. cameras surveillance firewalls gates. in diciembre i come back to Spain. money is better here but i don't want a paranoid life.
Petronas
Mon Oct 07, 2019 6:49 pm
root@SFP:/# reboot
:shock: Sorry, Now I understand the syntax.. :oops:
Change "curr_state=5"
https://pastebin.com/vHBZ1ug4
command " gtop+e "
MikroUser
Mon Oct 07, 2019 7:33 pm
PON
Telnet screenshot
Thank you
Regards
Hi, what is default telnet password for DFP-34G-2C2, root\admin not working :(
Petronas
Mon Oct 07, 2019 7:37 pm
I have another problem seems not to be well registered.
## Error: "Target" not defined
look file cat /etc/init.d/sys.sh to be empty :?:
Change mouth input sfp1 does not work
fushigi
Mon Oct 07, 2019 9:42 pm
Thank you
Regards
Hello Image
Here it is.
root\Pon521
MikroUser
Mon Oct 07, 2019 11:43 pm
root\Pon521
Thanks, logged in. have you any ideas how to make this sfp work with bdcom olt? I always got GPON State Init State, mikrotik shows link ok, but pppoe doesnt up (
Petronas
Tue Oct 08, 2019 7:59 pm
I disassemble the stick. :shock: :roll:
So that we can all identify the different Chinese teams and clones.
Here are more pictures 8)
Enjoy the show :roll:
https://mega.nz/#!AUYQWYAY!qIu1il8-umT6 ... -lnCzMFEv0
Model Chips & Laser transceiver :
Winbond 25Q128JVEQ (W25Q128JVEQ) -->> https://www.winbond.com/resource-files/ ... 20plus.pdf
ISSI 1735 IS43DR16320E -->>http://www.issi.com/WW/pdf/43-46DR86400E-16320E.pdf
Intel S912NN07 SLLC5
DSN 181 9 1120-022420-01
Maybe someone else can put pictures of their equipment sticks around here. :-D :lol:
Petronas
Thu Oct 17, 2019 4:23 pm
Someone can put pictures of their optical stick here ?
JeanPierre
Thu Oct 17, 2019 9:57 pm
g-010s-a
https://ibb.co/hWRkTHw
g-010s-p and ma5671a
https://ibb.co/Gtxf14G
op151s top and bottom
DeVlL
Fri Oct 18, 2019 11:51 am
Regards
Hello Image
Here it is.
root\Pon521
I'm going to buy the module from the same supplier that I bought and I have a question. Did you have to buy a fiber optic cable SC / APC to SC / UPC right?
Regards
msatter
Fri Oct 18, 2019 12:22 pm
Normally you need to get the sc/upc (blue) and the difference you can read about here:
http://www.fiber-optic-cable-sale.com/f ... c-upc.html
Running:
Lisendra
Sat Oct 19, 2019 10:13 am
Regards
can you provide url again to buy the module with web interface?
best regards,
JeanPierre
Mon Oct 21, 2019 5:33 am
DFP-34G-2C2
DFP-34G-2C2
Hi MikroUser, fushigi, AntonioLON, DeVlL
If it is not too inconvenient for you, please provide software images for HL23446 and DFP-34G-2C2. In the past I have successfully reflashed images between different brands. As long they have similar hardware design, processor, RAM and flash size, it will work fine. Chinese sfp are usually generic. Should not contain private informations.
At minimum, images of "uboot_env" and "linux/image0" known as mtd1 and mtd2 are needed for this test. For your own backup save all partitions except: rootfs rootfs_data
sfp partition mapping can be obtained by command.
root@SFP:/# cat proc/mtd
mtd3: 0061eedc 00010000 "rootfs"
mtd4: 00370000 00010000 "rootfs_data"
to transfer mtd partition search for and use live linux distribution. e.g. Ubuntu
On the linux computer setup a fixed IP (same subnet as sfp stick) e.g. 192.168.1.12. Open terminal.
root@ubuntu:/# nc -l -p 4444 > mtd1.bin
-l listen
-p port number
now on the sfp stick send the mtd to the linux pc
root@SFP:/# cat /dev/mtd1 | nc 192.168.1.12 4444
Repeat for mtd2. Zip the files and post it on the Mega.nz site
For testing I will use sfp modules popular in Canada: g-010s-a, g-010s-p and ma5671a. If all works well I will share the flash and recovery procedure after all tests are done.
jblankfeld
Mon Oct 21, 2019 12:36 pm
Hello friends,
Thank you for this great thread. I'm also interested in replacing SERCOMM FGS202 that is provided by Orange, my ISP.
The module works fine in a Mikrotik hAP AC but it does not work on a board I have (ClearFog GT 8K) that runs mainline linux (no link detected)
Did you eventually manage to have one of the clone working ? Is it stable enough ? I'd like to purchase HL23446 of DFP-34G-2C2 but I'd like some of your inputs first.
Thank you guys.
fushigi
Mon Oct 21, 2019 6:32 pm
Picture of DFP-34G-2C2
Error0x29A
Mon Oct 21, 2019 7:44 pm
fushigi, do you know technical specification for this ponstick? Can you post what you get when dmesg command is used?
dimcom
Tue Oct 22, 2019 12:03 pm
You do not know how to change the pon sn of the ma5671a module. Access to it is available only on port 22 via CLI
Petronas
Tue Oct 22, 2019 8:01 pm
DFP-34G-2C2
DFP-34G-2C2
-l listen
-p port number
8)
Here is my backup file 8)
SOURCEPHOTONICS_SPS3424THPTDFO
https://mega.nz/#!YE5jDKJT!k_exNoXRLmHT ... yU5bvyhuJw
JeanPierre
Tue Oct 22, 2019 11:21 pm
Hi Petronas,
Thank you for posting flash images. Do you mind sharing ssh password @192.168.1.10 for this image?
mtd3.bin(rootfs) and mtd4.bin(rootfs_data) may contain running system info. mtd1.bin may contain serial info. These commands should be used to erase it before running an image dump.
root@SFP:/# fw_setenv sfp_a0_low_128
Petronas
Wed Oct 23, 2019 12:35 pm
Hi Petronas,
Reupload file inside pw
AntonioLON
Wed Oct 23, 2019 4:01 pm
images for HL23446
[/quote]
hola amigo. i see to it when i am back in Spain
JeanPierre
Wed Oct 23, 2019 11:28 pm
Hi Petronas,
Thank you for sharing the login pass. I locked myself out for a day :lol: I agree with you, this image version is limited, no http. We need an image from Hilink HL23446 or Carlitoxx CPGOS03-0490 to have many configuration options. Maybe someone will post it.
Petronas
Thu Oct 24, 2019 6:33 pm
Hi Petronas,
It is a pleasure also your help with the commands and advice, :)
I activate the web interface, but with few configuration options. :roll:
I followed this guide
https://www.dslreports.com/forum/r32458588-
Inform the people who read us in the forum. !!
Be careful with the command lines you can leave the stick dead even via web. Changing some settings may make it dead and not operational !!! .
If you don't know what you do ...
JeanPierre
Thu Oct 24, 2019 11:04 pm
I'm out of town this and next week.The user shell is limited. Let me check after I'm back.
JeanPierre
Thu Oct 24, 2019 11:09 pm
Hi Petronas,
Great pictures. Good contribution.
The web interface has more options than one would hope for.
Delboy
Sun Oct 27, 2019 2:47 am
@Petronas
Thanks for the image dump
Also note that even the SoC is the same, optical transmitter may not be the same across different brands and models, and that is why goi_config variables exist.
I have Alcatel G-010S-P that were cheap on ebay some time ago, and managed to re flash it with zisa firmware and got a working gpon sync.
JeanPierre
Sun Oct 27, 2019 3:15 pm
@Delboy
Flashing between G-010S-P and SPS3424THPTDFO or Carlitoxx CPGOS03-0490 is easy. Same partition layout. Flash is 16MB
I looked up the Zisa OP151S. It has different partition layout and smaller flash (8MB)
root@SFP:/# cat /proc/mtd
mtd0: 00060000 00010000 "Boot"
mtd1: 00010000 00010000 "Env"
mtd2: 00390000 00010000 "ImageA"
mtd3: 00390000 00010000 "ImageB"
mtd4: 00060000 00010000 "Config"
mtd5: 00010000 00010000 "SECTION_EGIS"
mtd6: 00250000 00010000 "rootfs"
mtd7: 00010000 00010000 "rootfs_data"
How did you manage to re-flash it with zisa firmware and transfer goi_config from your G-010S-P
mrspeccy
Thu Oct 31, 2019 2:22 pm
Hi all,
I have internet via GPON provider here in Denmark and would like to replace its fiber modem with a GPON stick that fits into my router. I contacted HiLink and thought they would send me the HL23446. What I received is a GPON stick that carries the following information on its sticker:
GPON_ONU_STICK
1.244 Gbps 1310nm/1490nm
S/N HLZ2019092XXXXX (I masked the last 5 digits of this serial number).
That's all. No real product number/name.
Any idea what kind of hardware this is? The stick does have a web interface on port 80 and a telnet interface on port 23 as well, but I do not know how to log in. Combinations admin/admin etc. do not work. Also, the IP of the stick is 192.168.1.1 which, as I understand, is different from the 192.168.1.57 of the HL23446.
Error0x29A
Thu Oct 31, 2019 3:29 pm
Hi all,
GPON_ONU_STICK
Did you try root\Pon521
Can you post a picture of the stick. It will be easier to identify...
mrspeccy
Thu Oct 31, 2019 4:36 pm
You mean root as username and Pon521 as password? Does not work, unfortunately. Here is an image
https://ibb.co/DbYSMgW
Error0x29A
Re: Usage GPON module SFP in Spain
Thu Oct 31, 2019 5:39 pm
ssh login also fails? Contact the hilink. They provided pass to fushigi and others
Can someone identify the main chip from the post #258 by fushigi?
viewtopic.php?f=3&t=116364#p756126
Delboy
Thu Oct 31, 2019 5:55 pm
I flashed whole 8MB flash from zisa Op151s to image1 partition of G-010S-P. I think i had to change something to get egis partition to mount, but i'm not sure as i did this a year ago.
Also I had to set some u-boot env variables to properly boot zisa firmware
addmtdparts0=setenv mtdparts mtdparts=sflash:256k(uboot)ro,512k(uboot_env),7424k(linux),8192k(image1)
addmtdparts1=setenv mtdparts mtdparts=sflash:256k(uboot)ro,512k(uboot_env),7424k(image0),384k(Boot)ro,64k(Env),3648k(ImageA),3648k(ImageB),384k(Config),64k(SECTION_EGIS),2368k@13568k(rootfs) ACTIVE=B softMode=NORMAL
boot_image0=run kernel0_from_sf flashargs addip addmtdparts0 addmisc && bootm ${ram_addr}
boot_image1=run kernel1_from_sf flashargs addmtdparts1 addmisc && bootm ${ram_addr}
image1_addr=0xB0800000
image1_is_valid=0
image1_version=3.2.16_160606
kernel1_from_sf=sf probe 0;sf read ${ram_addr} ${kernel1_offs} ${max_kernel_size}
kernel1_offs=0xC00200
For goi_config I had copied files to egis partition in /tmp/egis/ but i'm not sure if that is all that needs to be done to make it right, as some optic variables I got from running "otop" on both firmwares are different.
To test new image, it is best to boot default alcatel firmware and from it's shell set env variable to boot from image1 only once, that way if something fails on reboot, it boots back to alcatel fw:
fw_setenv flash_flash "setenv flash_flash run select_image boot_image && saveenv && run boot_image1"
Link for image1 partition dump and u-boot env variables: https://www.dropbox.com/s/v1sxo2js25t0c ... -p.7z?dl=1
spaxton
Fri Nov 01, 2019 10:17 am
Hello everyone,
It's been a long time since I wrote a message to this thread. Long time since I tried to make this work for the first time but I was trying constantly from time to time...
I have Zisa OP151s and yesterday I finally figured out that all changes I made were successful and the module register to OLT but it doesn't open VLANs. DHCP client works fine on the interface itself and I could open IPTV but VoIP and internet are tagged traffic and this module doesn't forward it for some reason. After some time (lets say one hour) it obtained an IP address on VoIP VLAN but after restart I had the same situation like I described above.
Anyone had this experience?
It seems like the module has some bugs..
Anybody knows why it behaves like this?
Best Regards,
mrspeccy
Fri Nov 01, 2019 4:41 pm
There is no ssh service on my stick. I have written to HiLink and am waiting for reply.
Error0x29A
Fri Nov 01, 2019 9:51 pm
Hello everyone,
Best Regards,
hello spaxton, did you clone original ONT MAC address to your Microtik WAN interface? DHCP servers may not respond with IP assignment if MAC address is wrong.
can you install and run tcpdump on your Zisa OP151S LAN/WAN interfaces and look for Vlan frames?
big thanks to user Petronas for sharing the link on how to install extra packages and plenty of pictures
viewtopic.php?f=3&p=758116#p756735
http://archive.openwrt.org/barrier_brea ... ages/base/
spaxton
Sat Nov 02, 2019 12:08 am
Hello Error0x29A,
Many thanks for Your reply!
Well, I didn't clone the MAC address but I also think there is no need (by bridging the telecom router, I can get an IP address on my laptop or any other device). Here is the scenario:
ONT status is O5
sfp1 obtains IP address of IPTV (until today I didn't test if it really works but the receiver updates the clock. No TV channel streaming available)
VLAN1 (VoIP) "hardly" obtains an IP address (It actually obtains an IP address after some time and it will obtain it again after this if I disable and enable the interface. I am able to ping the gateway)
VLAN2 (Internet) gets nothing. It doesn't "see" the PPPoE server on the other side
What concerns me is if the SFP ZISA OP151S has some bugs or I may misconfigured it. Please check the screenshot and let me know what for are UP FEC, DOWN FEC, ENCRYPT and why they are disabled?
Best Regards
Error0x29A
Sat Nov 02, 2019 12:49 am
Forward Error Correction (FEC) feature can improve the quality and reach of an optical link allowing the receiver to detect and correct transmission errors.
Every ONT receives each downstream frame and picks up only that data addressed to it by the OLT. Optionally, FEC coding and AES encryption are applied to the user data.
They are optional, on my Spanish provider they are also not turned on. I don't have much experience in troubleshooting PPPoE over Vlan, I get IP from DHCP over Vlan.
Have a look at OP151S Orange ES setup and link to firmwares
spaxton
Sat Nov 02, 2019 2:23 pm
Thanks for explanation.
I remember this Valero Torres page. This was available even before I bought the module. Maybe one year ago. Now I am not sure if his firmware is newer or older than the one I have in the module already. Also, he has 3 files... Active software, passive software, firmware. To be honest, I have no idea what for 3 files are used. :D :D :D
Is it easy to upgrade?
Error0x29A
Sat Nov 02, 2019 8:10 pm
I posted the link for comparison. With only one SFP in my router I don't feel comfortable loading another firmware. Yet. I leave it to other guys in this thread :D
No significant difference between all three files. First firmware is a factory generic. Second and third have firmware version names tailored for Orange ES.
In my opinion to solve the issue - put yourself in the middle. 1. Install tcpdump on OP151S. 2. login to OP151S 3. capture traffic on the sfp interface. 4. look for VLANS and PPPoE data.
Petronas
Mon Nov 04, 2019 7:30 pm
You can explain something better like you do. :?: :?:
how to transfer the image, how to mount the unit., step by step
I am doing a full backup to my stick.
I can resurrect the stick in failure, full backup
*** The party starts taking a seat and popcorn watching the show. :lol: **
AntonioLON
Mon Nov 04, 2019 8:08 pm
hola amigos
i propose move discusion to openwrt forum, more help, more more flashing/uboot experts
https://forum.openwrt.org/c/hardware-qu ... mendations
JeanPierre
Tue Nov 05, 2019 7:58 am
Hi Delboy
Thank you for your explanation, so there is more is involved than simple re-flash. It's easy to get this module bricked when messing with a firmware. I did it again this weekend :shock: not going to risk it anymore, got a brand new G-010S-P from a local bussiness. It is running hardcoded Alcatel omci manager and parser. Had to uncomment couple lines to switch to a generic omci daemon to receive IP address. Edit the file /etc/init.d/omcid.sh if you run into similar problem (O5 received but no IP address)
OMCID_BIN=/opt/lantiq/bin/omcid
#OMCI_MGR_BIN=/opt/lantiq/bin/omciLibMgr
#OMCI_PARSER_BIN=/opt/lantiq/bin/omciLibParser
${OMCID_BIN} -d3 ${uni2lan} -p $mib_file -o$omcc_version > /dev/console 2> /dev/console &
# ${OMCI_MGR_BIN} > /dev/console 2> /dev/console &
# sleep 5
# ${OMCI_PARSER_BIN} > /dev/console 2> /dev/console &
JeanPierre
Tue Nov 05, 2019 8:05 am
That's exactly what I need. Where did you get "mod tweezers" ?
JeanPierre
Tue Nov 05, 2019 8:07 am
hola amigos
I agree. Much better venue.
JeanPierre
Tue Nov 05, 2019 8:25 pm
My first try running OP151S on G-010S-P failed :( still investigating...
SF: Detected S25FL128S_64K with page size 256 Bytes, erase size 64 KiB, total 16 MiB
SF: 1572864 bytes @ 0xc00200 Read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
On my new stick G-010S-P i applied recovery options in case it is bricked again, good also for SPS3424THPTDFO and MA5671A with full shell access
removing 'intput 100' from preboot enables "Press SPACE to delay and Ctrl-C "
root@SFP:/# fw_setenv preboot gpio input 105\;gpio input 106\;gpio input 107\;gpio input 108\;gpio set 3
root@SFP:/# fw_setenv bootdelay 5
root@SFP:/# fw_setenv asc0 0
now i can connect USB serial UART adapter to stick's PIN2(tx) and PIN7(rx)
with access to uboot shell I can change environment variables
ROM: V1.1.4
ROM: CFG 0x00000006
ROM: SFLASH-4
Chip:  FALCON-S (A22)
Bootmode: 0x06
Reset cause: Software
CPU Clock: 400 MHz
Net:   SGMII, SERDES [PRIME]
gpio: pin 105 (gpio 105) value is 0
gpio: pin 106 (gpio 106) value is 1
gpio: pin 107 (gpio 107) value is 1
gpio: pin 108 (gpio 108) value is 1
gpio: pin 3 (gpio 3) value is 1
FALCON =>
FALCON =>
FALCON => printenv
spaxton
Tue Nov 05, 2019 11:56 pm
Hello friend,
where did you buy this SFP module? I see it has many options. Did you buy it like this or you installed this firmware in it and can this be installed in zisa op151s? Please jelp with some info or link where this is available to buy.
Best Regards.
JeanPierre
Wed Nov 06, 2019 9:08 am
Save backup of mtd1 and fw_printenv. apply recovery procedure from post #288
do not use for production (missing calibration files)
@Delboy
thank you for sharing with us these steps
Steps for running OP151S image on G-010S-P
fw_setenv addmtdparts1 setenv mtdparts mtdparts=sflash:256k\(uboot\)ro,512k\(uboot_env\),7424k\(image0\),384k\(Boot\)ro,64k\(Env\),3648k\(ImageA\),3648k\(ImageB\),384k\(Config\),64k\(SECTION_EGIS\),2368k@13568k\(rootfs\) ACTIVE=B softMode=NORMAL
fw_setenv image1_version 3.2.16_160606
fw_setenv kernel1_offs 0xC00200
fw_setenv image1_addr 0xB0C00200
transfer the mtd5 uploaded by Delboy. on linux pc must have ssh server running (sshd)
sfp stick
root@SFP:/# cd /tmp/
root@SFP:/# scp jean@192.168.1.12:/tmp/mtd5 mtd5
root@SFP:/tmp# mtd -e image1 write mtd5 image1
Unlocking image1 ...
Erasing image1 ...
Writing from mtd5 to image1 ...
root@SFP:/tmp#
reboot into OP151S. telnet 192.168.1.1 as admin/admin
enter linux shell
T&W# linuxshell
start the optics script
root@SFP:/# /etc/init.d/optic.sh start
spaxton
Tue Nov 12, 2019 1:21 pm
Hello Friends,
I have found some new SFP module to buy and it has the same interface like DFP-34G-2C2 . Please take a look...
I have seen in this thread someone had an experience with this kind of module. Please, can someone confirm if this kind of module works or not. I need IPTV, Telephony and Internet (last two things are delivered via different VLANs)
Best Regards.
minhng99
Fri Nov 15, 2019 3:30 pm
Hi Delboy
# sleep 5
Thank you, PPPoE dialing worked for me after this
minhng99
Sat Nov 16, 2019 10:15 am
Anyone know how I could do IGMP forwarding (multicast) with this Openwrt-based stick? I have a Sercomm and it worked fine but this Openwrt-based one fromm Nokia doesn't
Petronas
Thu Nov 21, 2019 3:02 pm
Sorry delay.... all this took a while
It is a creation made by me.
Use the normal clamp and place some very thin pins on the pliers.
It works with the chip soldered on the board, I can read and write. Happy !!
I use the programmer CH341A for my chip
Also have another programmer "minipro" but need to update and be more expensive and will have to wait to be updated, for now I am working with the CH341A.
I would like to expand the menus and improve the firmware but I am not an OpenWrt expert just a baby of Linux and have no knowledge of an expert, so I am limited. Now I look more confident and be able to open a new discussion in the OpenWrt forum.
In case of breaking something I can start over again
All this would not have started if mikrotik had finished its SFP GPON ONU which seems to be a shame that the product is discontinued.
Maybe with a simple stick update job it would have been enough
It would be a great product if they were back to support and new modules .
Maybe someone from mikrotik could read this great thread and see the needs of the Users
Thanks for the explanations.
hugomon
Mon Nov 25, 2019 3:56 pm
Hi, I have problems with my ONT Alcatel-Lucent O-010S-P, I can't even connect by SSH. I have tried 192.168.1.10, among others, but there is no ping.
Does anyone know this model, and if it is compatible?
AndreHro
Wed Nov 27, 2019 12:28 am
Hi everybody. I’m also interested in replacing a Movistar router by a Mikrotik hex S and sfp module. I could get one UGP-N1S GPON like mention above. Hope it will work.
Does anybody know if it’s possible to use this configuration for ipv6 too? So for my understanding over the gpon stick a pppoe connection is initiated and I get a IP address?
spaxton
Wed Nov 27, 2019 11:56 pm
Hola Friends
Hello friend,
I am trying to replace my huawei router for a long time. I own ZISA OP151s but it doesnt work for me. Can You, please, let me know if the module You showed here works for You? Can You attach some web interface photos?
Best Regards.
spaxton
Thu Nov 28, 2019 12:04 am
Hi there,
I have the ZISA one. It won't work with my provider so I don't need it. Interested?
Best Regards.
spaxton
Thu Nov 28, 2019 12:10 am
Guys,
Can anyone confirm that DFP-34G-2C2 actually works? Changing serial, VLANs? IPTV ? Everything works with it?
Best Regards.
JeanPierre
Thu Nov 28, 2019 6:51 am
hugomon
My model ONT G-010S-P responds to pings in Mikrotik. Please check my steps.
1. Assign sfp1 as WAN interface (it will remove sfp1 from the bridge)
2. G-010S-P and other models will not expose ethernet interface unless fiber cable is connected (link-ok, rate 1Gbps)
[admin@MikroTik] > interface ethernet monitor sfp1
                    status: link-ok
          auto-negotiation: done
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: SC
       sfp-link-length-9um: 20000m
           sfp-vendor-name: ALCATELLUCENT
3. Add IP address to the sfp1 interface
[admin@MikroTik] > ip address add address=192.168.1.15/24 interface=sfp1
4. [admin@MikroTik] > ping 192.168.1.10
SEQ HOST SIZE TTL TIME STATUS
0 192.168.1.10 56 64 0ms
1 192.168.1.10 56 64 0ms
2 192.168.1.10 56 64 1ms
3 192.168.1.10 56 64 3ms
5. telnet or ssh
[admin@MikroTik] > system telnet 192.168.1.10
[admin@MikroTik] > system ssh user=ONTUSER address=192.168.1.10
hugomon
Thu Nov 28, 2019 6:51 pm
hugomon
                    status: link-ok
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
               sfp-rx-loss: no
5. telnet or ssh
Thank you for your reply JeanPierre!; I will try this week and report here with the result.
AndreHro
Thu Nov 28, 2019 9:03 pm
Hi there,
Best Regards.
Which provide do you use?
I’m interested if it’s not Movistar in Madrid.
spaxton
Thu Nov 28, 2019 9:44 pm
Hi there,
Best Regards.
[/quote]
My provider is outside of Spain. It is Telekom (T-Com) in Montenegro. A part of Deutsche Telekom. Do You know anything about the modules I asked in a few previous posts? Nobody is willing to reply about.
Best Regards.
AndreHro
Thu Nov 28, 2019 10:01 pm
No, I only saw here that some people successfully running the Modul in Spain by modifying the PON LOID and Serial number to the values used from the provider. Since my provider is Movistar I ask about your provider.
I had contact to hilink they want technical details and after that no reply.
I also had contact to usourcetech about the Modul UGP-N1S
http://www.usourcetech.com/web/userfile ... _Rev01.pdf . But I not really sure if it will work.
spaxton
Thu Nov 28, 2019 10:46 pm
Ok, I want to get rid of my zisa. In order to make it work here I would need to use its command line interface and I don't want to learn anymore how to do that. I need almost a plug n play option. What is Your offer?
zlobster
Fri Nov 29, 2019 2:09 am
Hola Friends
Hello friend,
Best Regards.
Did you tinker with your Zisa? If so, what is changed?
Is your Zisa working?
Best I can do is 25€ + something reasonable for shipping.
hugomon
Fri Nov 29, 2019 9:52 am
hugomon
                    status: link-ok
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
               sfp-rx-loss: no
5. telnet or ssh
Bad news, it doesn't work, I can obtain a link ok in the module only if I disable speed auto-negotiation, and still can't ping or ssh to the GPON.
spaxton
Fri Nov 29, 2019 10:41 am
Hola Friends
Hello friend,
Best Regards.
The ZIsa is working. Total work hours about 6. Nothing changed, not even the firmware. The factory firmware is in it. However, the best I can do is 40 + 17 shipping to Spain. If You want the same brand new module like ZISA, please find it here https://www.aliexpress.com/item/33014127133.html. For what I could investigate with my chinese friends, this module is absolutely the same as zisa and is was also produced and designed by the same factory T&W.
Best Regards.
AndreHro
Fri Nov 29, 2019 11:59 am
So for me 60 Euro including shipping would be ok.
Can you send me a message in the forum?
spaxton
Fri Nov 29, 2019 12:12 pm
HI,
I don't see an option to send You the message via forum. Please use email address spaxton.ligiston@yahoo.com . From there we can exchange details.
Best Regards.
JeanPierre
Sat Nov 30, 2019 2:04 am
hugomon
Try ip-scan to see if anything responds...
[admin@MikroTik] > tool ip-scan interface=sfp1 address-range=192.168.1.0/24
Flags: D - dhcp
  ADDRESS         MAC-ADDRESS        TIME DNS                                       SNMP                                       NETBIOS
  192.168.1.10    00:06:B5:BE:11:EF   1ms
  192.168.1.15                        0ms
Change the sfp1 interface to 192.168.0.15 and scan 192.168.0.0/24. Repeat for 192.168.2.0/24, 192.168.3.0/24, 192.168.4.0/24 networks. I've have seen document claiming 192.168.4.254, 192.168.3.10, 192.168.1.251 to be ONT's configuration IP
jondavy
Mon Dec 02, 2019 6:08 pm
note that many customers and operators use GPON
Normis, have you planned to launch any solution in the GPON? Branch, as we need OLT and ONUs from MikroTik urgent
hugomon
Tue Dec 03, 2019 11:23 am
hugomon
Flags: D - dhcp
  192.168.1.15                        0ms
You was rigth @JeanPierre, the correct IP was 192.168.2.2. After configure NAT masquerade for sfp1 I can login with user: ONTUSER and password: SUGAR2A041
That's the good news, the bad news is I can't configure anything once logged in. Nothing is displayed about the busybox and commands like onu gtcpg don't work.
Also it runs extremely slow, even when writing, becoming apparently frozen.
In any case, it's a progress, thank you.
Petronas
Tue Dec 03, 2019 3:11 pm
It seems from his images this user does not have "administrator privileges".
run cd /
run uci show
use the help commands
can you upload?  to pastebin.com
minhng99
Thu Dec 05, 2019 10:01 am
Hi, I have a uboot repo here that appears to work with the Alcatel-Lucent/Nokia GPON SFP, also the Huawei MA5671A
https://github.com/minhng99/u-boot_lantiq_falcon
more about this being discussed here: https://forum.openwrt.org/t/support-ma5 ... n/48042/21
It's not fully working yet and don't appear to work correctly with the G-010S-P (kernel panic, root= not found) but if we managed to fix this then we might be able to have a netconsole uboot working and it will be much easier to test firmware
spaxton
Tue Dec 31, 2019 5:52 pm
fw_setenv nPassword
fw_setenv nSerial
uci commit
reboot
Hello friend,
Have You managed to change the values and how?
Best Regards.
BackON
Fri Jan 03, 2020 1:03 pm
I have more ifo from of DFP-34G-2C2
The chipset is a ZTE ZX279125
flash memory winbond 25q128fsg
other chip is atheros but i cant see the model
in the back have a chip k24c06 1546cdx and 25l95 1707 22649
i created on openwrt forum a post about it to suppport it if is posibble
https://forum.openwrt.org/t/dfp-34g-2c2-sfp/51641
88zz88
Wed Jan 08, 2020 2:48 am
Salute comrades
to your collection of GPON images working with Mikrotik SFP routers.
DASAN H650SFP - same hardware as SPS3424THPTDFO, MA5671A, G-010S-P
image login - ssh 192.168.1.10 ONTUSER/password unknown unless decoded from
ONTUSER:$6$mYQnmn3MLtYla6rV$DIlnn6XmGATG4RGr8U1O7mw8UQ/sZqOp4kPkSY672KmTjS4gvPIz1l3aLtQrPIxoe2q10pX4d.zmuzHtlrYux1:16934:0:99999:7:::
H650SFP image0 rev. 14_07
http://s000.tinyupload.com/index.php?fi ... 9384744300
H650SFP image1 rev. 14_07
http://s000.tinyupload.com/index.php?fi ... 6685759864
G-010S-P
image login - ssh 192.168.1.10 ONTUSER/SUGAR2A041
G-010S-P image0 rev. 14_07
http://s000.tinyupload.com/index.php?fi ... 6227675874
G-010S-P image1 rev.14_07
http://s000.tinyupload.com/index.php?fi ... 1873659888
HL23446
image login - telnet 192.168.1.57 no password
HL23446 image0 rev.14_07
http://s000.tinyupload.com/index.php?fi ... 4338451129
HL23446 image1 rev.14_07
http://s000.tinyupload.com/index.php?fi ... 3576121597
Newtman
Sat Jan 25, 2020 6:00 pm
I'm from Uruguay and our ISP use similar tecnology to Spain, in consecuence I guess I can use some GPON module.
What module are working now?
Is impossible to find Zisa module, but I read few post upper, CM5671A is equivalent... But is very expensive only for an experiment, because I can't found information online about it.
Carlitoxx's module is out of stock since an year now.
Thanks!
JeanPierre
Mon Jan 27, 2020 3:15 am
Hi, I have compiled a list of popular GPON modules. Let me know if I missed something or made a mistake.
=-=-=-=-=-=-=-= Chipset: Intel/Lantiq PEB98036 =-=-=-=-=-=-=-=-=-=-=-=
FGS202
Flash 8MB, RAM 1MB, System RTOS eCos
Pros- Quick start
Cons - Flash programming/soldering required for SN/Password change. It may overheat. No graphical web interface.
=-=-=-=-=-=-=-= Chipset: Intel/Lantiq PEB98035 =-=-=-=-=-=-=-=-=-=-=-=
MA5671A
Flash 16MB, RAM 64MB, System OpenWRT
Pros - Good compatibility with Huawei and third-party vendors. Highly configurable through commands.
Cons - Hardware adapter and soldering required for full shell. No graphical web interface. Change SN/Password via command line.
G-010S-P
Pros - Good compability with Alcatel/Nokia. Web interface. Highly configurable through CLI commands
Cons - IPTV may not work with third-party vendors.
CarlitoxxPro CPGOS03-0490 / HL23446
Pros - Good web interface. Several vendor profiles. Highly configurable through CLI commands. Supports LOID
The firmware is interchangeable between: Source Photonics SPS-34-24T-HP-TDFO, Huawei MA5671, Alcatel G-010S-P, Hilink HL23446, CarlitoxxPro CPGOS03-0490, Dasan H650SFP, DpOptics D23446
LAN interface can be switched from 1 Gbps to 2.5 Gbps(sgmii_mode variable is set to 5)
G-010S-A
Pros - Good compability with Alcatel/Nokia. Web interface. Highly configurable through commands. Capable of 1Gbps or 2.5Gbps LAN mode.
Cons - IPTV may not work with third-party vendors, for some routers soldering pin#6 to ground is required(info on dslreports - CanadaBell)
=-=-=-=-=-=-=-= Chipset: Intel/Lantiq PEB98035 =-=-=-=-=-=-=-=-=-=-=-=-=
Zisa OP151S
Flash 8MB, RAM 64MB, System T&W Linux atop of OpenWRT 10_03 or 12_09
Pros - Good web interface. A lot of commands.
Cons - It may overheat. Security considerations - some firmware is pre-filled with TR-069 servers.
The firmware interchangeable beetween: T&W TW2362H-CDEL, Zisa OP151S, D-LINK DPN-100, Zyxel PMG3000-D20B, CM5671A, Eltex NTU-SFP-100, Calix 100-03903
=-=-=-=-=-=-=-=-=-=-=-= Chipset: ZTE ZX279125 =-=-=-=-=-=-=-=-=-=-=-=-=-=
ZTE DFP-34G-2C2
Flash 16MB, RAM 32MB, System ZTE Linux
Pros - Extensive graphical network interface (GUI). Supports HGU(Router mode) and LOID.
Cons - Limited number CLI of commands.
Other products:
EXOT - DFP-3422
=-=-=-=-=-=-=-=-=-=-=-= Chipset: Realtek RTL8672 and/or RTL9601C =-=-=-=-=-=-=-=-=-=-=-=-=-=
RTL8672 Network Processor SoC controler
RTL9601C Ethernet/PON network bridge processor
Flash 16MB, System Linux version 2.6.30.9 - Realtek RSDK-1.5.6p2 - luna SDK V1.9.0
Pros - Extensive graphical network interface (GUI), supports LOID, HGU(Router mode), SN, password, MAC change. Low ambient temperature.
Cons- Web interface, SN change, and dual support for EPON/GPON will vary depending on how the final vendor configured the module.
Several product families built upon Realtek RSDK-1.5.6p2 are available:
1. V-SOL V2801F, C-Data FD511GX-RM0, OPTON GP801R, BAUDCOM BD-1234-SFM
2. Ubiquiti - U-Fiber Instant, (ssh CLI only)
3. EXOT - EGS1
Newtman
Wed Jan 29, 2020 5:08 pm
Thanks JeanPierre!!! Nice compilation of information.
MA5671A is very affordable and I understand work well. Isn't problem for my solder the EEPROM and read it. I have got a R809F with the correct sockets.
Any advice?
Thanks!
JeanPierre
Thu Jan 30, 2020 8:43 pm
My advice?
Intel/Lantiq 98035 if you are not afraid of programming and, for some modules, soldering. They sometimes appear on Canadian(ebay.ca) or Italian(ebay.it) national ebay websites.
I forgot to add that Intel chip 98035 has LAN interface that can be switched from 1 Gbps to 2.5 Gbps. Important for users whose ISPs offer higher speeds than 1Gbps. This applies only to modules with OpenWRT(sgmii_mode variable is set to 5)
The best Intel/langiq module was sold by CarlitoxxPro and Hilink. Unfortunately, they don't have them in stock. Since HL23446 firmware is available I will try to load it on my g-010s-p sfp module and see how it works!
For the rest, probably DFP-34G-2C2. It has a rich web interface. The module is available under different names but the casing has a distinctive appearance. Just look at the photos from previous posts. It says "PON STICK V01" on the board. A large number of these modules are available on aliexpress in the "anddear" shop
A few users here have these modules but we have not enough reports on how they work. The modules may not work with ISP's who check software versions.
kapook007
Sun Feb 23, 2020 12:00 pm
device MA5671A
isp1 use SN+password authentication > working for MA5671A / use fw_setenv ont_serial and uci set gpon.ploam.nPassword
isp2 use LOID+CHECKCODE authentication > not working for MA5671A
how to change LOID+CHECKCODE for MA5671A ?
JeanPierre
Tue Feb 25, 2020 2:54 am
LOID - 1-24 characters
CHECKCODE(LOID PASSWORD) - 1-12 characters
If the firmware supports LOID authentication LOID+CHECKCODE parameters can be updated by changing two variables: omci_loid and omci_lpwd
fw_setenv omci_loid xxxxxxxxxxxxx
fw_setenv omci_lpwd xxxxxxxxxxxx
If LOID is disabled in the firmware try alternative software from CarlitoxxPro CPGOS03-0490
kapook007
Wed Feb 26, 2020 6:31 am
fw_setenv omci_loid xxxxxxxxxxxxx not working
fw_setenv omci_lpwd xxxxxxxxxxxx not working
Need backup firmware CPGOS03-0490
mtd0-mtd5
T T
JeanPierre
Thu Feb 27, 2020 6:51 am
HL23446 shared above should be the same as CPGOS03-0490
xh116
Tue Mar 03, 2020 7:47 am
Salute comrades
G-010S-P
HL23446
Hi
Do you have hl23446 firmware to download, My module is brick by mistake without backup...
Thanks in advance
piku
Tue Mar 03, 2020 7:52 am
Hi everyone,
I'm a GPON SFP ONU user in China, which is the country of most SFP hardware producing country.
According to what I know, most SFP use TW2312 as master chip (like Zisa OP151s,TW2312H-CDEL), which is manufacted by T&W, Shenzhen, China.
I have Zisa OP151s, TW2312H-CDEL and I believe CM5671A they all have same hardware.
Unfortunately most of them are end of life and the developer group was dismissed.
The problem I have is my SFP don't support some OMCI command. This makes it available to some ISPs, but not others.
I'd like to try your firmwares to workout a solution.
By the way, a former engineer of T&W create a new SFP ONU which use Realtek master chip, support GPON, EPON, SN, snid, loid, MAC, with only $38.
piku
Tue Mar 03, 2020 8:27 am
As mentioned above,ZTE is another manufacturers in China. As far as I am concerned, The framwork of ZX279125 is not same as lantiq.
What are your specific problems?
JeanPierre
Tue Mar 03, 2020 4:07 pm
It looks that modules SPS3424THPTDFO, MA5671A, G-010S-P, CPGOS03-0490, H650SFP, HL23446 share the same MTD partition mapping.
Combine MTD parts from different modules to create the firmware
root@ubuntu:/# cat mtd0.bin mtd1.bin mtd2.bin mtd5.bin > firmware.bin
root@ubuntu:/# ls -l
-rw-r--r-- 1 root root 16777216 Nov 12 09:51 firmware.bin
JeanPierre
Tue Mar 03, 2020 4:10 pm
Can you share a photo or name of the new SFP ONU with Realtek chip?
piku
Wed Mar 04, 2020 7:38 am
As your wish.
Left: G/Epon sfp with Realtek master chip
Right: TW2362H
I'll dismante it later because it is in use.
JeanPierre
Wed Mar 04, 2020 6:05 pm
Right: TW2362H
Thanks.
I'm intrigued by what model of chip is used to make this SFP module. Is it possible that RTL9601C was used?
I found more pictures and setup screens
https://www.chiphell.com/thread-2184048-1-1.html
Can you recommend a place to buy this Realtek SFP.
piku
Thu Mar 05, 2020 4:07 am
Thanks.
Yes the thread of chiphell is correct.
# cat /proc/cpuinfo
system type             : RTL8672
processor               : 0
cpu model               : 56322
BogoMIPS                : 112.23
tlb_entries             : 64
mips16 implemented      : yes
# cat /proc/version
Linux version 2.6.30.9 (root@ubuntu12) (gcc version 4.4.6 (Realtek RSDK-1.5.6p2) ) #9 Thu Oct 24 20:18:35 CST 2019 [luna SDK V1.9.0]
# cat /proc/mtd
mtd0: 00040000 00001000 "boot"
mtd1: 00002000 00001000 "env"
mtd2: 00002000 00001000 "env2"
mtd3: 0003c000 00001000 "config"
mtd4: 00300000 00001000 "k0"
mtd5: 004c0000 00001000 "r0"
mtd6: 00300000 00001000 "k1"
mtd7: 004c0000 00001000 "r1"
mtd8: 00001000 00001000 "Partition_008"
mtd9: 00001000 00001000 "Partition_009"
mtd10: 00001000 00001000 "Partition_010"
mtd11: 00001000 00001000 "Partition_011"
mtd12: 00300000 00001000 "linux"
mtd13: 004c0000 00001000 "rootfs"
# cat /proc/meminfo
MemTotal:          16944 kB
MemFree:            5352 kB
# dmesg
/bin/sh: dmesg: not found
Unfortunately it is only sold in mainland of China and the price goes up recently. Please refer here (interest irrelevant)
It is incompatible with CCR's SFP+. Only a few PCIe card tested and compatible, too.
So it is about $52+$32 postage with Universal Postal Union if you really want.
By the way, I really don't think it's worth it. A S/EPON modem with gigabytes port only $40 with shipping.
kapook007
Sat Mar 07, 2020 11:54 am
Bad news for DFP-34G-2C2
route mode only
how change to bridge mode with vlan support ?
piku
Mon Mar 09, 2020 2:12 pm
....(sorry for reduce)
route mode only
ODI said bridge mode is not allowed by ZTE's warrant. Sorry.
[delete]But the function of bridge mode exists, maybe just need to complement some webpage files. ODI said they're trying.[/delete]
update 13 Mar:
A friend send me one of this sfp and I did some dig.
IT IS BRIDGED BY DEFAULT like a SFU, just don't create any connect in WAN Connection page.
It works with one of my ISP but not another, same like Lantiq.
It is not work with CCR1009's SFP+, only SFP works.
Newtman
Fri Mar 13, 2020 3:37 pm
Hello!
I finally receive my first Mikrotik and SFP, a RB960PGS and MA5671A.
I'm fully noob with Mikrotik but after a couple of hours I logged in to the SFP via SSH.
My SFP need the fibber connected, the default IP is 192.168.1.10, credentials are root / admin123
After this I tried set my serial number and password without luck. The commands fw_setenv didn't work... But I found the command "set" work, but I don't know the name of the variables (I tried with "print" and other words like this)
I don't find manual or similar, commands like help or man are disable too... But I found this log.
root@192.168.1.10's password:
Welcome Visiting Huawei Home Gateway
Copyright by Huawei Technologies Co., Ltd.
# display_log
2018-04-30 21:18:21 Software successfully upgraded. Source version: V8R017C00S201. Target version: V8R017C00S206
If necessary I can read the EEPROM with my R809F, but I prefer not solder.
Anyone have experience with this dongle?
Thanks!!
piku
Fri Mar 13, 2020 5:23 pm
Hello!
# display_log
Thanks!!
Yes. It's almost same as SmartAX MA5671. try
set sn snid 5CA858829BE1
Newtman
Fri Mar 13, 2020 5:42 pm
Hello!
# display_log
Thanks!!
Thanks piku, I will try tomorrow.
Have you got a full manual of this sfp?
Thanks!!!
piku
Sat Mar 14, 2020 7:05 am
Thanks!!!
Sorry.
Huawei design it is to configurate from olt, not for separate work. So there is no official manual for commands.
JeanPierre
Tue Mar 17, 2020 9:46 pm
I believe the "set" command only works with DyingGasp variable
# set nDyingGaspEnable enable
Result:Success
# set nDyingGaspEnable disable
Result:Success
kapook007
Tue Mar 24, 2020 5:13 pm
i try firmware
i have some problem about firmware for ma5671a
-working same ont
HL23446 notworking
-not found gpon signal
errorcode=0 curr_state=1
anyone have problem with me ?
JeanPierre
Tue Mar 24, 2020 7:11 pm
i try firmware
HL23446 notworking
@kapook007
Try this. It works for me
root@SFP:/# fw_setenv ont_serial HWTC1122334455
root@SFP:/# fw_setenv target oem-generic
root@SFP:/# uci set gpon.ploam.nPassword="0x31 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x39"
root@SFP:/# reboot
It should keep the login 192.168.1.10 from MA5671A (telnet and http)
If you require more changes like model number, firmware version, MAC address, LOID have a look at Antonio's post
viewtopic.php?f=3&t=116364#p751330
piku
Wed Mar 25, 2020 2:50 pm
i try firmware
-working same ont
HL23446 notworking
O1 means not receive light. I doubt there is physical connection problem.
Dasan H650SFP is a product form Koera and SC/APC connecter is widely used in Korea, which is different from HL23446.
BTW, I'm not familiar with Korea. Just for your reference.
kapook007
Thu Mar 26, 2020 3:13 am
i try firmware
-working same ont
HL23446 notworking
i already check physical connection
my device is ma5671a 1pc install 2 firmware
1.firmware H650SFP is working
2.firmware HL23446 not found gpon signal
i try in my home
piku
Thu Mar 26, 2020 2:38 pm
i try in my home
my misunderstanding, sorry.
kapook007
Thu Mar 26, 2020 4:07 pm
Hi
HL23446 firmware not found gpon signal.
i test and got problem
HL23446 found gpon signal over -15dbm
But standart gpon signal is -20dbm to -28dbm HL23446 not found gpon signal
CarlitoxxPro CPGOS03-0490 can found gpon signal -20dbm to -28dbm ????
Anyone who can share CarlitoxxPro CPGOS03-0490 firmware.
mtd0 , mtd1 , mtd2
thanks
CarlitoxxPro
Sat Apr 04, 2020 1:38 am
We are very happy :D by announce that we are currently on manufacturing process for the newest version of GPON ONU SFP CPGOS03-0490 V2.
New Architecture, more stability and a great interoperability between multiple OLT brands and Routers/Switches with SFP and SFP+ ports. Fully tested with TriplePlay Services (Data, VoIP, IPTV).
Its Time to replace that unreliable and limited HGU / ONT by a most advanced ONU SFP with a ultra low power compsumption and ready to work on the most faster FTTH networks.
More details very soon!! Please stay tuned. :wink:
Facebook
Twitter
Telegram
Facebook: fb.me.com/CarlitoxxPro
Twitter: @CarlitoxxPro
Telegram: t.me/CarlitoxxPro
Email: contacto [at] carlitoxxpro.com
osquetar
Sat Apr 04, 2020 2:04 am
Ya era hora!
morishe
Mon Apr 20, 2020 6:46 pm
I have also a MA5671 flashed with HL23446 firmware.
I didn't tried with the original firmware but (like yours) PLOAM state is 1.
Did you solve your problem?
Regards
i try firmware
-working same ont
HL23446 notworking
iperezandres
Mon Apr 27, 2020 7:35 pm
C'mon Carlitos, we are looking forward to receiving more information and availability of your product!!!! :D
Newtman
Tue Apr 28, 2020 2:02 am
Result:Success
Result:Success
I confirm my SFP accept set nDyingGaspEnable enable/disable.
Obvisly the problem is the firmware, I can't configure anything or modify the variables without documentation. Next month I will receive a new programmer to dump the EEPROM. Maybe change the firmware could be a solution for me.
I can't connect directly to the SFP from the LAN, buy I'm not Mikrotik expert, is my first time... I don't understand how to bridge the networks 192.168.1.0/24 and 192.168.88.0/24.
jmj
Wed Apr 29, 2020 6:05 pm
BackON
Mon May 18, 2020 6:09 pm
after checking that image in carlitoxx facebook looks like Dfp-34g-2c2 sfp module (the cage have the same screws and look the same.) this is a new chipset (ZTE) but the question is about the firmware... its going to be openwrt or custom firmware?
almeiras
Tue May 19, 2020 1:42 pm
Hello guys, I have a Nokia g-010s-p (Alcatel-Lucent). I tried to update it from OpenWRT ltq 12 to 14 via web using a file (image 0) provided in this thread but it bricked.
Any guide on how to de-brick it? It looks like I should power it with 3.3V and reach the UART pins inside (probably while keeping the SC/APC connected since it wont power on otherwise)
Also, any cheap recommended GPON stick. Carlitoxxpro and Zisa sticks seem unavailable.
Thank you very much.
JeanPierre
Tue May 19, 2020 4:11 pm
Hello almeiras
It's easy if you have a TTL adapter connected to pins 2 and 7. Look at the instructions how to make or buy one written for MA5671A in the openwrt forum. Most of them should apply in this scenario..
almeiras
Wed May 20, 2020 11:34 pm
Thank you! And how would you upload and install the firmware? (Or even a custom one). I know I can connect via screen / cu but then what? I can’t find any tutorials...
EDIT: Sorry, I found this: https://openwrt.org/docs/techref/hardware/port.serial
ivanmh
Sat May 23, 2020 8:08 pm
Hi guys, Ubiquiti have released a new SFP GPON ONU stick called "UFiber Instant (UF-Instant)".
According to its specifications, it has SGMII Ethernet LAN interface. Would this allow working with the SFP+ connection for RB4011? It would be great if someone confirms it. I am a happy owner of a RB4011iGS+5HacQ2HnD-IN, working in harmony with a UFiber Nano G, but I'm curious to know if this new UFiber Instant would work with my RB4011.
Also, if its has the same web interface as its brothers UFiber Nano G & Loco, it should work with Movistar and other ISPs that work nice with UFiber. Except of course, VLAN2 for IPTV on Movistar ....
EDIT: Sorry, I was wrong. Reading instructions for use, this UFiber Instant has no web interface and is configured from a Ubiquiti OLT. It will not work for any Spanish ISP. My fault for not read the instructions for use before...
almeiras
Tue May 26, 2020 5:11 pm
Hello again!
So I managed to open my bricked (Nokia) Alcatel-Lucent G-010S-P. I found four empty pads on the board, hopefully the UART pins that I am looking for. Now, I have two questions:
  • Does anybody know the correct pinout? At least, can anybody confirm if these are the UART pins I am looking for?
  • Which soldering iron should I get for this kind of miniature soldering?
This image shows the possible UART pins and the opening procedure:
Thank you very much for your help!
JeanPierre
Tue May 26, 2020 9:18 pm
Hello again!
Hello almeiras
The UART contacts I am aware of are connected to pins 2 and 7. On the openwrt forum, bmx39 and minhng99 shared photos of their adapters.
https://forum.openwrt.org/t/support-ma5 ... n/48042/24
Restoration of the G-010S-P module is simple. After connecting the adapter, just send the mtd2 and mtd5 firmware from the u-boot level. Our u-boot is factory unlocked. We don't have to jump over obstacles like the owners of the MA5671A module. Remember not to destroy the mtd1 partition that contains the u-boot variables calibrated for this module.
Original firmware 12.09
https://github.com/minhng99/alcatel_luc ... master/mtd
Restoration instructions I copied from here
https://forum.openwrt.org/t/support-ma5 ... n/48042/17
#transfer image mtd2 by Kermit into memory
FALCON => loadb
## Ready for binary (kermit) download to 0x80800000 at 115200 bps...
#to write mtd2(image0)
sf probe 0
sf erase C0000 740000
sf write 80800000 C0000 740000
#transfer image mtd5 by Kermit into memory
FALCON => loadb
#to write mtd5(image1)
sf probe 0
sf erase 800000 740000
sf write 80800000 800000 740000
almeiras
Tue May 26, 2020 11:39 pm
Great, thank you so much JeanPierre!
I have already ordered a couple of SFP female connectors for the soldering. My Pi Zero and I are looking forward to some UART flashing!
BackON
Fri May 29, 2020 6:31 pm
Hello
I have another sfp gpon module from Nokia. The model is G-010s-B
Intrrnal photos
Image Image
Running on 192.168.1.10 but i dont know Web user and password but ssh password is ONTUSER/SUGAR2A041. Nmap says runs on 15.05 openwrt
Image Image
i accesed it via ssh.
ONTUSER@easy98035synce1588:/# cat /proc/cpuinfo
system type             : Falcon rev A22
machine                 : EASY98035SYNCE1588 - Lantiq Falcon SFP Stick with Sync       E/1588
processor               : 0
cpu model               : MIPS 34Kc V5.6
BogoMIPS                : 265.98
wait instruction        : yes
microsecond timers      : yes
tlb_entries             : 16
extra interrupt vector  : yes
hardware watchpoint     : yes, count: 4, address/irw mask: [0x0ffc, 0x0ffc, 0x0f       fb, 0x0ffb]
isa                     : mips1 mips2 mips32r1 mips32r2
ASEs implemented        : mips16 dsp mt
shadow register sets    : 1
kscratch registers      : 0
package                 : 0
core                    : 0
VCED exceptions         : not available
VCEI exceptions         : not available
dev:    size   erasesize  name
mtd0: 00040000 00010000 "uboot"
mtd1: 00080000 00010000 "uboot_env"
mtd2: 00c00000 00010000 "linux"
mtd3: 0013cedb 00010000 "kernel"
mtd4: 00ac3125 00010000 "rootfs"
mtd5: 00600000 00010000 "rootfs_data"
mtd6: 00c00000 00010000 "image1"
mtd7: 00200000 00010000 "configfs"
mtd8: 00300000 00010000 "logfs"
mtd9: 00200000 00010000 "extfs"
mtd10: 00010000 00010000 "ri"
mtd11: 00010000 00010000 "sfp"
mtd12: 00010000 00010000 "ribackup"
mtd13: 00010000 00010000 "reserve"
Uci Config
 uci: Entry not found
dhcp.odhcpd=odhcpd
dhcp.odhcpd.maindhcp='0'
dhcp.odhcpd.leasefile='/tmp/hosts/odhcpd'
dhcp.odhcpd.leasetrigger='/usr/sbin/odhcpd-update'
dropbear.@dropbear[0]=dropbear
dropbear.@dropbear[0].PasswordAuth='on'
dropbear.@dropbear[0].RootPasswordAuth='on'
dropbear.@dropbear[0].Port='22'
goi_config.global=goi
goi_config.global.CalibrationTimestamp='2018-04-13T10:08; script V7.6.4; OCAL V7.6.1; FW V7.6.1'
goi_config.ranges=goi
goi_config.temperature_tables=goi
goi_config.dcdc_apd=goi
goi_config.transmitter=goi
goi_config.transmit_power=goi
goi_config.transmit_power.P1_0='3387'
goi_config.transmit_power.P0_0='170'
goi_config.monitor=goi
goi_config.monitor.MPD_Calibration_PL0='3'
goi_config.monitor.MPD_Calibration_PL1='3'
goi_config.monitor.TiaGain_PL1='1'
goi_config.monitor.TiaGain_PL0='1'
goi_config.monitor.TiaGain_PL2='3'
goi_config.monitor.MPD_Calibration_PL2='2'
goi_config.monitor.Dcalref0_PL0='3050'
goi_config.monitor.Dcalref1_PL0='3146'
goi_config.monitor.Dcalref0_PL1='3047'
goi_config.monitor.Dcalref1_PL1='3118'
goi_config.monitor.Dcalref0_PL2='1260'
goi_config.monitor.Dcalref1_PL2='1254'
goi_config.monitor.Dref0_PL0='184'
goi_config.monitor.Dref1_PL0='1563'
goi_config.monitor.MPDxt_PL0='0.778036673083'
goi_config.monitor.Imodref_PL0='34.6762215795'
goi_config.monitor.Dref0_PL1='117'
goi_config.monitor.Dref1_PL1='938'
goi_config.monitor.MPDxt_PL1='0.933644007699'
goi_config.monitor.Imodref_PL1='19.6178810304'
goi_config.monitor.Dref0_PL2='258'
goi_config.monitor.Dref1_PL2='1669'
goi_config.monitor.MPDxt_PL2='4.0717252558'
goi_config.monitor.Imodref_PL2='9.80894051519'
goi_config.measurement=goi
goi_config.measurement.Tscal_ref='0.484715133905'
goi_config.measurement.RSSI_1490parabolic_ref='0'
goi_config.measurement.RSSI_1490dark_ref='0.0008544921875'
goi_config.measurement.RSSI_1490scal_ref='0.84979253112'
goi_config.omu=goi
goi_config.bosa=goi
goi_config.fcsi=goi
goi_config.fcsi.GVS='0xf653'
goi_defaults.global=goi
goi_defaults.global.CalibrationTimestamp='OCAL V7.5.0'
goi_defaults.global.TempMonitorInterval='1000'
goi_defaults.global.TempMonitorThreshold_MPDcorrection='3'
goi_defaults.global.LaserAgeStoreCycle='43200'
goi_defaults.global.Polarity_Rx='0'
goi_defaults.global.Polarity_Bias='1'
goi_defaults.global.Polarity_Mod='1'
goi_defaults.global.Temp_IntCorr_AlarmYellow_Set='390'
goi_defaults.global.Temp_IntCorr_AlarmYellow_Clear='370'
goi_defaults.global.Temp_IntCorr_AlarmRed_Set='420'
goi_defaults.global.Temp_IntCorr_AlarmRed_Clear='400'
goi_defaults.global.TransmitLevelCheckInterval='1000'
goi_defaults.global.OpticMode='undefined'
goi_defaults.ranges=goi
goi_defaults.ranges.TableTemp_ExtCorr_Min='223'
goi_defaults.ranges.TableTemp_ExtCorr_Max='423'
goi_defaults.ranges.TableTemp_ExtNom_Min='200'
goi_defaults.ranges.TableTemp_ExtNom_Max='450'
goi_defaults.ranges.TableTemp_IntCorr_Min='223'
goi_defaults.ranges.TableTemp_IntCorr_Max='473'
goi_defaults.ranges.TableTemp_IntNom_Min='200'
goi_defaults.ranges.TableTemp_IntNom_Max='450'
goi_defaults.ranges.Ibias_Max='60'
goi_defaults.ranges.Imod_Max='80'
goi_defaults.ranges.Iavg_Max='200'
goi_defaults.ranges.IbiasImod_Max='120'
goi_defaults.ranges.CInt_Bias_Max='7'
goi_defaults.ranges.CInt_Mod_Max='7'
goi_defaults.ranges.VAPD_Min='20'
goi_defaults.ranges.VAPD_Max='60'
goi_defaults.ranges.Power_Measure_Min='0.30'
goi_defaults.ranges.Overcurrent_Ibias_Thr='60'
goi_defaults.ranges.Overcurrent_Imod_Thr='80'
goi_defaults.ranges.Overcurrent_IbiasImod_Thr='100'
goi_defaults.temperature_tables=goi
goi_defaults.temperature_tables.Tci_Ith_low='50'
goi_defaults.temperature_tables.Tci_Ith_high='40'
goi_defaults.temperature_tables.Tci_SE_low='-200'
goi_defaults.temperature_tables.Tci_SE_high='-100'
goi_defaults.temperature_tables.Tcd_Ith_low='30'
goi_defaults.temperature_tables.Tcd_Ith_high='30'
goi_defaults.temperature_tables.Tcd_SE_low='30'
goi_defaults.temperature_tables.Tcd_SE_high='30'
goi_defaults.temperature_tables.VAPD_scal_ref_low='0.09'
goi_defaults.temperature_tables.VAPD_scal_ref_high='0.09'
goi_defaults.dcdc_apd=goi
goi_defaults.dcdc_apd.VAPD_enable='0'
goi_defaults.dcdc_apd.Rdiv_low='10000'
goi_defaults.dcdc_apd.Rdiv_high='294000'
goi_defaults.dcdc_apd.VAPD_offset='3.0'
goi_defaults.dcdc_apd.VAPD_ext_inductivity='12'
goi_defaults.dcdc_apd.VAPD_ext_supply='3.30'
goi_defaults.dcdc_apd.VAPD_efficiency='50'
goi_defaults.dcdc_apd.VAPD_current_limit='2.00'
goi_defaults.transmitter=goi
goi_defaults.transmitter.TxEnableDelay='8'
goi_defaults.transmit_power=goi
goi_defaults.transmit_power.P0_0='180'
goi_defaults.transmit_power.P1_0='3820'
goi_defaults.transmit_power.P0_1='90'
goi_defaults.transmit_power.P1_1='1910'
goi_defaults.transmit_power.P0_2='45'
goi_defaults.transmit_power.P1_2='955'
goi_defaults.monitor=goi
goi_defaults.monitor.TiaGain_PL0='2'
goi_defaults.monitor.TiaGain_PL1='3'
goi_defaults.monitor.TiaGain_PL2='3'
goi_defaults.monitor.MPD_Calibration_PL0='3'
goi_defaults.monitor.MPD_Calibration_PL1='2'
goi_defaults.monitor.MPD_Calibration_PL2='2'
goi_defaults.monitor.ImodScalCorr_PL0='1.0'
goi_defaults.monitor.ImodScalCorr_PL1='1.0'
goi_defaults.monitor.ImodScalCorr_PL2='1.0'
goi_defaults.monitor.Dcalref0_PL0='3930'
goi_defaults.monitor.Dcalref1_PL0='4000'
goi_defaults.monitor.Dcalref0_PL1='1160'
goi_defaults.monitor.Dcalref1_PL1='1230'
goi_defaults.monitor.Dcalref0_PL2='1160'
goi_defaults.monitor.Dcalref1_PL2='1230'
goi_defaults.monitor.Dref0_PL0='180'
goi_defaults.monitor.Dref1_PL0='1910'
goi_defaults.monitor.Dref0_PL1='280'
goi_defaults.monitor.Dref1_PL1='2540'
goi_defaults.monitor.Dref0_PL2='200'
goi_defaults.monitor.Dref1_PL2='1270'
goi_defaults.monitor.PowerSave='1'
goi_defaults.monitor.rogue_onu_interburst='0'
goi_defaults.monitor.RogueAlarm_Threshold_P0='20'
goi_defaults.monitor.RogueAlarm_Threshold_P1='120'
goi_defaults.monitor.MPDxt_PL0='-1'
goi_defaults.monitor.MPDxt_PL1='-1'
goi_defaults.monitor.MPDxt_PL2='-1'
goi_defaults.monitor.Imodref_PL0='36.0'
goi_defaults.monitor.Imodref_PL1='18.0'
goi_defaults.monitor.Imodref_PL2='9.0'
goi_defaults.measurement=goi
goi_defaults.measurement.Tscal_ref='0.550'
goi_defaults.measurement.pnR='1.0'
goi_defaults.measurement.pnIsource='1'
goi_defaults.measurement.Supply_voltage_Enable='1'
goi_defaults.measurement.RSSI_1550_Enable='0'
goi_defaults.measurement.RF_1550_Enable='0'
goi_defaults.measurement.DAC_1550_Enable='0'
goi_defaults.measurement.RSSI_1490mode='1'
goi_defaults.measurement.RSSI_1490shunt_res='4990'
goi_defaults.measurement.RSSI_1490dark_corr='1.20'
goi_defaults.measurement.RSSI_1550vref='1'
goi_defaults.measurement.RF_1550vref='1'
goi_defaults.measurement.RSSI_1490scal_ref='0.07'
goi_defaults.measurement.RSSI_1550scal_ref='0.10'
goi_defaults.measurement.RF_1550scal_ref='0.10'
goi_defaults.measurement.RSSI_1490parabolic_ref='0.08'
goi_defaults.measurement.RSSI_1490dark_ref='0.002'
goi_defaults.measurement.RSSI_autolevel='0'
goi_defaults.measurement.RSSI_1490threshold_low='40'
goi_defaults.measurement.RSSI_1490threshold_high='70'
goi_defaults.measurement.Tbosa_source='1'
goi_defaults.measurement.Vdd_scal='0.5'
goi_defaults.measurement.V0K_Tref='1200'
goi_defaults.omu=goi
goi_defaults.omu.SignalDetectAvailable='1'
goi_defaults.omu.SignalDetectPort='2'
goi_defaults.omu.LolThreshold_set='20'
goi_defaults.omu.LolThreshold_clear='20'
goi_defaults.omu.LaserSignalSingleEnded='1'
goi_defaults.bosa=goi
goi_defaults.bosa.LoopMode='2'
goi_defaults.bosa.LolThreshold_set='20'
goi_defaults.bosa.LolThreshold_clear='20'
goi_defaults.bosa.LosThreshold_set='0.0005'
goi_defaults.bosa.LosThreshold_clear='0.0010'
goi_defaults.bosa.RxOverloadThreshold='0.2000'
goi_defaults.bosa.CInt_Bias_init='2'
goi_defaults.bosa.CInt_Mod_init='2'
goi_defaults.bosa.PICtrl='0x00004049'
goi_defaults.bosa.UpdateThreshold_Bias='2'
goi_defaults.bosa.UpdateThreshold_Mod='2'
goi_defaults.bosa.LearningThreshold_Bias='99'
goi_defaults.bosa.LearningThreshold_Mod='99'
goi_defaults.bosa.StableThreshold_Bias='2'
goi_defaults.bosa.StableThreshold_Mod='2'
goi_defaults.bosa.ResetThreshold_Bias='70'
goi_defaults.bosa.ResetThreshold_Mod='70'
goi_defaults.fcsi=goi
goi_defaults.fcsi.GVS='0xF653'
gpon.ploam=gpon
gpon.ploam.nPassword='0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20'
gpon.ploam.nT01='11000'
gpon.ploam.nT02='100'
gpon.ploam.nRogueMsgIdUpstreamReset='255'
gpon.ploam.nRogueMsgRepeatUpstreamReset='3'
gpon.ploam.nRogueMsgIdDeviceReset='255'
gpon.ploam.nRogueMsgRepeatDeviceReset='3'
gpon.ploam.nRogueEnable='0'
gpon.gtc=gpon
gpon.gtc.bDlosEnable='0'
gpon.gtc.bDlosInversion='0'
gpon.gtc.nDlosWindowSize='0'
gpon.gtc.nDlosTriggerThreshold='0'
gpon.gtc.ePower='0'
gpon.gtc.nLaserGap='0'
gpon.gtc.nLaserOffset='0'
gpon.gtc.nLaserEnEndExt='0'
gpon.gtc.nLaserEnStartExt='0'
gpon.gtc.nDyingGaspHyst='0'
gpon.gtc.nDyingGaspMsg='0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00'
gpon.gtc.nDyingGaspEnable='0'
gpon.gpe=gpon
gpon.gpe.nPeNumber='6'
gpon.gpe.nDSCP_MappingRule='0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 '
ieee_1588.ptp_sync=ieee_1588
ieee_1588.ptp_sync.delay_mechanism='-E'
ieee_1588.ptp_sync.network_transport='-2'
ieee_1588.ptp_sync.timestamping='-H'
ieee_1588.ptp_sync.cfg_file='/etc/g_8275_1.conf'
ieee_1588.ptp_sync.interface='lct0'
ieee_1588.ptp_sync.log_level='6'
ieee_1588.tod2phc=ieee_1588
ieee_1588.tod2phc.xpectd_mc_name='Intel PON TOD'
ieee_1588.tod2phc.xpectd_sc_name='Intel F24S'
ieee_1588.tod2phc.master_clock='/dev/ptp0'
ieee_1588.tod2phc.slave_clock='/dev/ptp1'
ieee_1588.tod2phc.offset='0'
ieee_1588.tod2phc.time_thr='20'
ieee_1588.tod2phc.sync_offset='-14'
ieee_1588.tod2phc.log_level='6'
ieee_1588.tod2phc.threshold='0.00002'
ieee_1588.tod2ktimer=ieee_1588
ieee_1588.tod2ktimer.xpectd_phc_name='Intel PON TOD'
ieee_1588.tod2ktimer.auto_cfg='-a'
ieee_1588.tod2ktimer.synch_sys_clk='-r'
ieee_1588.tod2ktimer.phc_clk='/dev/ptp0'
ieee_1588.tod2ktimer.domain_num='24'
ieee_1588.tod2ktimer.offset='0'
ieee_1588.tod2ktimer.log_level='6'
network.loopback=interface
network.loopback.ifname='lo'
network.loopback.proto='static'
network.loopback.ipaddr='127.0.0.1'
network.loopback.netmask='255.0.0.0'
network.globals=globals
network.globals.ula_prefix='auto'
network.lct=interface
network.lct.ifname='lct0'
network.lct.netmask='255.255.255.0'
network.lct.proto='static'
network.lct.macaddr='ac:9a:96:00:00:00'
network.lct.gateway='192.168.2.1'
network.lct.ipaddr='192.168.1.10'
network.host=interface
network.host.ifname='host'
network.host.proto='static'
network.host.ipaddr='0.0.0.0'
network.host.netmask='0.0.0.0'
network.host.macaddr='ac:9a:96:00:02:00'
network.host6=interface
network.host6.ifname='@host'
network.host6.proto='static'
nmea.message=nmea
nmea.message.nmea_format='1'
nmea.message.time_offset='19'
omci.default=omci
omci.default.mib_file='/etc/mibs/data_2g_8q.ini'
omci.default.status_file='/tmp/omci_status'
omci.iphost=omci
omci.iphost.enabled='1'
omci.iphost.committed='32000 2048'
omci.iphost.peak='32000 2048'
omci.iphost.color_aware='0'
omci.iphost.mode='0'
rpcd.@login[0]=login
rpcd.@login[0].username='root'
rpcd.@login[0].password='$p$root'
rpcd.@login[0].read='*'
rpcd.@login[0].write='*'
sfp_eeprom.default=sfp_eeprom
sfp_eeprom.default.eeprom='0'
sfp_eeprom.default.vendor_name='Lantiq'
sfp_eeprom.default.vendor_partno='Part Number'
sfp_eeprom.default.vendor_rev='0000'
sfp_eeprom.default.vendor_oui='AC:9A:96'
sfp_eeprom.default.serial_no='no serial number'
sfp_eeprom.default.datecode='150414'
sfp_eeprom.default.addr_eeprom_0='0x80'
sfp_eeprom.default.addr_eeprom_1='0x51'
sfp_pins.@pin[0]=pin
sfp_pins.@pin[0].name='tx_fault'
sfp_pins.@pin[0].pin='2'
sfp_pins.@pin[0].restriction='ASC_TX'
sfp_pins.@pin[1]=pin
sfp_pins.@pin[1].name='tx_disable'
sfp_pins.@pin[1].pin='1'
sfp_pins.@pin[2]=pin
sfp_pins.@pin[2].name='los'
sfp_pins.@pin[2].pin='3'
sfp_pins.@pin[3]=pin
sfp_pins.@pin[3].name='mod_def'
sfp_pins.@pin[3].pin='41'
synce.ethernet=synce
synce.ethernet.nSyncE_Mode='1'
synce.ethernet.bSyncE_SGMII_Squelch='0'
synce_pins.@pin[0]=pin
synce_pins.@pin[0].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[0].pin='43'
synce_pins.@pin[1]=pin
synce_pins.@pin[1].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[1].pin='44'
synce_pins.@pin[2]=pin
synce_pins.@pin[2].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[2].pin='43'
synce_pins.@pin[3]=pin
synce_pins.@pin[3].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[3].pin='44'
synce_pins.@pin[4]=pin
synce_pins.@pin[4].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[4].pin='43'
synce_pins.@pin[5]=pin
synce_pins.@pin[5].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[5].pin='44'
synce_pins.@pin[6]=pin
synce_pins.@pin[6].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[6].pin='43'
synce_pins.@pin[7]=pin
synce_pins.@pin[7].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[7].pin='44'
synce_pins.@pin[8]=pin
synce_pins.@pin[8].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[8].pin='43'
synce_pins.@pin[9]=pin
synce_pins.@pin[9].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[9].pin='44'
synce_pins.@pin[10]=pin
synce_pins.@pin[10].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[10].pin='43'
synce_pins.@pin[11]=pin
synce_pins.@pin[11].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[11].pin='44'
synce_pins.@pin[12]=pin
synce_pins.@pin[12].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[12].pin='43'
synce_pins.@pin[13]=pin
synce_pins.@pin[13].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[13].pin='44'
synce_pins.@pin[14]=pin
synce_pins.@pin[14].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[14].pin='43'
synce_pins.@pin[15]=pin
synce_pins.@pin[15].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[15].pin='44'
synce_pins.@pin[16]=pin
synce_pins.@pin[16].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[16].pin='43'
synce_pins.@pin[17]=pin
synce_pins.@pin[17].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[17].pin='44'
synce_pins.@pin[18]=pin
synce_pins.@pin[18].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[18].pin='43'
synce_pins.@pin[19]=pin
synce_pins.@pin[19].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[19].pin='44'
synce_pins.@pin[20]=pin
synce_pins.@pin[20].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[20].pin='43'
synce_pins.@pin[21]=pin
synce_pins.@pin[21].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[21].pin='44'
synce_pins.@pin[22]=pin
synce_pins.@pin[22].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[22].pin='43'
synce_pins.@pin[23]=pin
synce_pins.@pin[23].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[23].pin='44'
synce_pins.@pin[24]=pin
synce_pins.@pin[24].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[24].pin='43'
synce_pins.@pin[25]=pin
synce_pins.@pin[25].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[25].pin='44'
synce_pins.@pin[26]=pin
synce_pins.@pin[26].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[26].pin='43'
synce_pins.@pin[27]=pin
synce_pins.@pin[27].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[27].pin='44'
synce_pins.@pin[28]=pin
synce_pins.@pin[28].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[28].pin='43'
synce_pins.@pin[29]=pin
synce_pins.@pin[29].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[29].pin='44'
synce_pins.@pin[30]=pin
synce_pins.@pin[30].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[30].pin='43'
synce_pins.@pin[31]=pin
synce_pins.@pin[31].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[31].pin='44'
synce_pins.@pin[32]=pin
synce_pins.@pin[32].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[32].pin='43'
synce_pins.@pin[33]=pin
synce_pins.@pin[33].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[33].pin='44'
synce_pins.@pin[34]=pin
synce_pins.@pin[34].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[34].pin='43'
synce_pins.@pin[35]=pin
synce_pins.@pin[35].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[35].pin='44'
synce_pins.@pin[36]=pin
synce_pins.@pin[36].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[36].pin='43'
synce_pins.@pin[37]=pin
synce_pins.@pin[37].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[37].pin='44'
synce_pins.@pin[38]=pin
synce_pins.@pin[38].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[38].pin='43'
synce_pins.@pin[39]=pin
synce_pins.@pin[39].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[39].pin='44'
synce_pins.@pin[40]=pin
synce_pins.@pin[40].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[40].pin='43'
synce_pins.@pin[41]=pin
synce_pins.@pin[41].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[41].pin='44'
system.@system[0]=system
system.@system[0].timezone='UTC'
system.@system[0].hostname='easy98035synce1588'
system.ntp=timeserver
system.ntp.server='0.openwrt.pool.ntp.org' '1.openwrt.pool.ntp.org' '2.openwrt.pool.ntp.org' '3.openwrt.pool.ntp.org'
system.ntp.enabled='1'
system.ntp.enable_server='0'
BackON
Fri May 29, 2020 9:29 pm
dmesg log
ONTUSER@easy98035synce1588:/# dmesg
[    0.000000] Linux version 3.18.44 (buildmgr@AONT27) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 15.05_ltq) ) #1 Mon Aug 21 17:16:12 CST 2017
[    0.000000] SoC: Falcon rev A22
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 00019556 (MIPS 34Kc)
[    0.000000] MIPS: machine is EASY98035SYNCE1588 - Lantiq Falcon SFP Stick with SyncE/1588
[    0.000000] e=memsize=64
[    0.000000] e=initrd_start=0xA0000000
[    0.000000] e=initrd_size=0x0
[    0.000000] e=flash_start=0x00000000
[    0.000000] e=flash_size=0x0
[    0.000000] e=ethaddr=ac:9a:96:00:00:00
[    0.000000] MEMSIZE = 67108864
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 04000000 @ 00000000 (usable)
[    0.000000] User-defined physical RAM map:
[    0.000000]  memory: 03f00000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x03efffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x03efffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x03efffff]
[    0.000000] On node 0 totalpages: 16128
[    0.000000] free_area_init_node: node 0, pgdat 80361d50, node_mem_map 81009840
[    0.000000]   Normal zone: 126 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 16128 pages, LIFO batch:3
[    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16002
[    0.000000] Kernel command line: rootfstype=squashfs,jffs2 ip=192.168.1.10:192.168.1.100:192.168.2.1::::off ethaddr=ac:9a:96:00:00:00 machtype=EASY98035SYNCE1588 vpe1_load_addr=0x83f00000 vpe1_mem=1M mem=63M mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(linux),12288k(image1),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve) quiet console= console=ttyLTQ0,115200 init=/etc/preinit
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Writing ErrCtl register=00018252
[    0.000000] Readback ErrCtl register=00018252
[    0.000000] Memory: 59856K/64512K available (2858K kernel code, 145K rwdata, 564K rodata, 192K init, 199K bss, 4656K reserved)
[    0.000000] NR_IRQS:328
[    0.000000] Setting up vectored interrupts
[    0.000000] CPU Clock: 400MHz
[    0.032000] Calibrating delay loop... 265.98 BogoMIPS (lpj=531968)
[    0.036000] pid_max: default: 32768 minimum: 301
[    0.036000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.036000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.040000] pinctrl core: initialized pinctrl subsystem
[    0.044000] NET: Registered protocol family 16
[    0.056000] pinctrl-falcon pinctrl: Init done
[    0.064000] FALC(tm) ON GPIO Driver, (C) 2012 Lantiq Deutschland Gmbh
[    0.068000] Switched to clocksource MIPS
[    0.072000] NET: Registered protocol family 2
[    0.072000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072000] TCP: Hash tables configured (established 1024 bind 1024)
[    0.072000] TCP: reno registered
[    0.072000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.072000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.072000] NET: Registered protocol family 1
[    0.072000] RPC: Registered named UNIX socket transport module.
[    0.072000] RPC: Registered udp transport module.
[    0.072000] RPC: Registered tcp transport module.
[    0.072000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.072000] EASY98000 LED driver, Version 1.0.1 (c) Copyright 2013, Lantiq Deutschland GmbH
[    0.072000] Wired TLB entries for Linux read_c0_wired() = 0
[    0.072000] config3 0x2425 MT 1
[    0.072000] MVPControl 0x2, STLB 0 VPC 1 EVP 0
[    0.072000] mvpconf0 0xb8008403, PVPE 1 PTC 3 M 1
[    0.076000] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.076000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.076000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.076000] msgmni has been set to 116
[    0.080000] io scheduler noop registered
[    0.080000] io scheduler deadline registered (default)
[    0.080000] 1e100c00.serial: ttyLTQ0 at MMIO 0x1e100c00 (irq = 104, base_baud = 0) is a lantiq,asc
[    0.080000] console [ttyLTQ0] enabled
[    0.080000] bootconsole [early0] disabled
[    0.116000] m25p80 spi0.0: found mx25l25635e, expected s25fl129p0
[    0.116000] m25p80 spi0.0: mx25l25635e (32768 Kbytes)
[    0.116000] 11 cmdlinepart partitions found on MTD device sflash
[    0.116000] Creating 11 MTD partitions on "sflash":
[    0.116000] 0x000000000000-0x000000040000 : "uboot"
[    0.116000] 0x000000040000-0x0000000c0000 : "uboot_env"
[    0.116000] 0x0000000c0000-0x000000cc0000 : "linux"
[    0.144000] 2 uimage-fw partitions found on MTD device linux
[    0.144000] 0x0000000c0000-0x0000001fcedb : "kernel"
[    0.144000] 0x0000001fcedb-0x000000cc0000 : "rootfs"
[    0.144000] mtd: device 4 (rootfs) set to be root filesystem
[    0.144000] 1 squashfs-split partitions found on MTD device rootfs
[    0.144000] 0x0000006c0000-0x000000cc0000 : "rootfs_data"
[    0.148000] 0x000000cc0000-0x0000018c0000 : "image1"
[    0.148000] 0x0000018c0000-0x000001ac0000 : "configfs"
[    0.148000] 0x000001ac0000-0x000001dc0000 : "logfs"
[    0.152000] 0x000001dc0000-0x000001fc0000 : "extfs"
[    0.152000] 0x000001fc0000-0x000001fd0000 : "ri"
[    0.152000] 0x000001fd0000-0x000001fe0000 : "sfp"
[    0.156000] 0x000001fe0000-0x000001ff0000 : "ribackup"
[    0.156000] 0x000001ff0000-0x000002000000 : "reserve"
[    0.156000] wdt 1f8803f0.watchdog: Init done
[    0.160000] TCP: cubic registered
[    0.160000] NET: Registered protocol family 17
[    0.160000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    0.160000] 8021q: 802.1Q VLAN Support v1.8
[   12.212000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[   12.216000] Freeing unused kernel memory: 192K (80380000 - 803b0000)
[   14.852000] init: Console is alive
[   16.032000] pps_core: LinuxPPS API ver. 1 registered
[   16.032000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   16.032000] PTP clock support registered
[   16.944000] init: - preinit -
[   17.552000] jffs2: notice: (293) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   17.608000] jffs2: notice: (295) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   18.480000] random: mktemp urandom read with 72 bits of entropy available
[   21.728000] procd: - early -
[   22.440000] procd: - ubus -
[   23.448000] procd: - init -
[   24.856000] g_board_hw_version 87
[   24.856000] ri module install
[   24.860000] IFXOS, Version 1.6.9 (c) Copyright 2009, Lantiq Deutschland GmbH
[   24.948000] NET: Registered protocol family 10
[   24.956000] i2c /dev entries driver
[   24.964000] Custom GPIO-based I2C driver version 0.1.1
[   24.964000] i2c-gpio i2c-gpio.0: using pins 37 (SDA) and 38 (SCL)
[   24.968000] i2c_driver_major is 247
[   24.968000] This board has 1 i2c bus, 0 bus is expanded by PCA9554i2c driver install.
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_mac_mc_port_delete (err 0)
[   25.048000] kigmp: Unknown symbol onu_mod_open (err 0)
[   25.048000] kigmp: Unknown symbol netdev_rem_igmp_snooping_rx_callback (err 0)
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_filter_add (err 0)
[   25.048000] kigmp: Unknown symbol netdev_set_igmp_snooping_rx_callback (err 0)
[   25.048000] kigmp: Unknown symbol onu_mod_close (err 0)
[   25.048000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_filter_add (err 0)
[   25.048000] kigmp: Unknown symbol gpe_ext_vlan_get (err 0)
[   25.048000] kigmp: Unknown symbol gpe_table_entry_get (err 0)
[   25.048000] kigmp: Unknown symbol gpe_ext_vlan_set (err 0)
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_port_add (err 0)
[   25.048000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_port_add (err 0)
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_mac_mc_port_add (err 0)
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_port_delete (err 0)
[   25.048000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_port_delete (err 0)
[   25.052000] F24S Driver, Version 1.2.0
[   25.124000] Intel PON Chipset Optic Driver, version 7.6.2.0
[   25.132000] GPON SFP I2C Slave Driver, Version 2.4.0 (c) Copyright 2015, Lantiq Beteiligungs-GmbH & Co. KG
[   25.236000] [sfp_i2c] vpe code <sfp_i2c_vpe.bin> with size <3352 bytes> loaded!
[   25.236000] VPE loader: VPE1 running successfully
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_mac_mc_port_delete (err 0)
[   25.252000] kigmp: Unknown symbol onu_mod_open (err 0)
[   25.252000] kigmp: Unknown symbol netdev_rem_igmp_snooping_rx_callback (err 0)
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_filter_add (err 0)
[   25.252000] kigmp: Unknown symbol netdev_set_igmp_snooping_rx_callback (err 0)
[   25.252000] kigmp: Unknown symbol onu_mod_close (err 0)
[   25.252000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_filter_add (err 0)
[   25.252000] kigmp: Unknown symbol gpe_ext_vlan_get (err 0)
[   25.252000] kigmp: Unknown symbol gpe_table_entry_get (err 0)
[   25.252000] kigmp: Unknown symbol gpe_ext_vlan_set (err 0)
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_port_add (err 0)
[   25.252000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_port_add (err 0)
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_mac_mc_port_add (err 0)
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_port_delete (err 0)
[   25.252000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_port_delete (err 0)
[   25.636000] watchdog: add to proc fs ok
[   25.636000] Intel PON Chipset Base Driver, Version 7.6.2.0
[   25.660000] Intel PON Chipset Ethernet Driver, Version 7.6.2.0
[   25.664000] Registered Intel PON TOD PTP clock
[   25.700000] igmpdrv k_igmp_drv_init
[   25.700000] igmpmap IgmpMapFilterConfig IPTV Filter mode changed from 1 to 5
[   25.708000] igmpdb igmpdbthreadinit Enter DB create the thread.
[   25.724000] [onu] Now netdev have set Snooping Call Back.
[   25.724000] successfully insert igmp dev module
[   32.860000] random: nonblocking pool is initialized
[   41.888000] [onu] GPHY Firmware loaded into RAM (phy11g.bin)
[   42.416000] [onu] PE[255] firmware loaded v15.9.8.4
[   44.920000] [f24s]: Registered Intel F24S PTP clock
[   44.920000] libphy: Falcon MDIO: probed
[   44.936000] IPv6: ADDRCONF(NETDEV_UP): host: link is not ready
[   44.988000] [f24s]: lct0: Intel F24S Switch driver attached (irq=10).
[   44.996000] [onu_netdev]: onu_netdev_probe: connect to phy at falcon_mdio:1f
[   45.092000] IPv6: ADDRCONF(NETDEV_UP): lct0: link is not ready
[   45.996000] IPv6: ADDRCONF(NETDEV_CHANGE): lct0: link becomes ready
[   47.776000] IPv6: ADDRCONF(NETDEV_UP): lct0: link is not ready
[   48.068000] IPv6: ADDRCONF(NETDEV_UP): lct0: link is not ready
[   48.996000] IPv6: ADDRCONF(NETDEV_CHANGE): lct0: link becomes ready
[   64.016000] IPv6: ADDRCONF(NETDEV_UP): host: link is not ready
[   64.140000]
[   64.140000] Set board info type = 255
[   64.156000] Reset igmp snooping.
[   65.044000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.064000] igmpltq Cfg Vlan Action with itf:1 Error.
[   65.068000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.076000] igmpltq Cfg Vlan Action with itf:2 Error.
[   65.080000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.100000] igmpltq Cfg Vlan Action with itf:3 Error.
[   65.104000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.120000] igmpltq Cfg Vlan Action with itf:4 Error.
[   65.124000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.144000] igmpltq Cfg Vlan Action with itf:5 Error.
[   65.148000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   67.956000] get OperatorID=XXXX and start long time light status
fw_printenv
ONTUSER@easy98035synce1588:/# fw_printenv
a0_image=3FE46956AAAA_a0.bin
a2_iaddr=0x1FD0000
a2_image=3FE46956AAAA_a2.bin
act_img_addr=0xBF20003C
addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off
addmisc=setenv bootargs ${bootargs} ethaddr=${ethaddr} machtype=${machtype}  vpe1_load_addr=0x83f00000 vpe1_mem=1M mem=63M ${mtdparts} quiet
addmtdparts0=setenv mtdparts mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(linux),12288k(image1),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve)
addmtdparts1=setenv mtdparts mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(image0),12288k(linux),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve)
asc0=3
baudrate=115200
boot_image=run boot_image${c_img};
boot_image0=run kernel0_from_sf flashargs addip addmtdparts0 addmisc && bootm ${ram_addr}
boot_image1=run kernel1_from_sf flashargs addip addmtdparts1 addmisc && bootm ${ram_addr}
boot_image_err=setenv kernel_offs ${kernel0_offs};httpd && setenv image0_is_valid 1
bootargs=rootfstype=squashfs,jffs2 ip=192.168.1.10:192.168.1.100:192.168.2.1::::off ethaddr=ac:9a:96:00:00:00 machtype=EASY98035SYNCE1588 vpe1_load_addr=0x83f00000 vpe1_mem=1M mem=63M mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(linux),12288k(image1),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve) quiet
bootcmd=run flash_flash
bootdelay=5
c_img=0
commit=0
config_iaddr=0x18C0000
env_offs=0x40000
env_offs_redund=0x80000
ethact=RGMII1
ethprime=RGMII1
flash_flash=run select_image boot_image
flashargs=setenv bootargs rootfstype=squashfs,jffs2
gatewayip=192.168.2.1
goi_calibrated=1
goi_config=begin-base64 644 goi_config@H4sIAB8BAAACA+1YS0/bQBDOtfkVW3HICbPvR60eUh4VKi2IpOGAkLVxnGA1@jiPbofTfd5YEMHagVWmjlnouHs/szrevbzzrqAh30nkRhzuTNA4KO5xGwdTm@URZk0TgYguaF+VXrWYJBJOc3T5DqExOp7nQmRQsTRSVtIdzagCzywmYItY4/@9T/39k8fbZeladF6ebKF9lI0SwsUXtrZJELFZYT63+YRikfRrIjHcZS99n2/@7Wxvj7qwQsHp/oGzbKF+lMzR+YcLHx0Wl+h80QWttw/K2U7idAvxzvOLNsPG@Vx6X3DfUU4r5uN1q5O+Q6Cn+P5/6v8h/SRVu+P+P8T9p+P8y+H9l56NgOPpN@7P8J/pd0SRz/hcKy4f9m+D96wH/H8xXbB92TveDd3i3TfTSATwI6HzhCS58z@TzPdEPlF8R8y9h/AcLxWQjzKf8gALUIVkJ5QLBjwnxHW1P8bEdxQ4L/nf5jO@xvHkJgEs1c3ynzIu73IBJ9LxXzX3/81Ie7njCDYfdSbTdGinnfYr90VIZ2jX@TuNhZp3ej5MIVgoK/g7FRG9jvk1Yn+A3WPsoD7N4XqCB8qTHfXS82z1avhAf@HZyt1E77AVbmyo28YiygzogAcJFFy1q02mAUjsIAytNqP4iWJ3FRRNkjnmCe@fnXO26mdkACjDmNalWzY2YjClRhJOouLtNT5IxRGpbUJTo5crKf85IG/H9v3@Nl7ZyTo7fsROf4ADfnrv3wvtFGo2vBogFrjmIysf4XJtPzdwzNXafs5HiF7b@DwZCqFyPd+MTvOS7HyTRFftqgETIhxO/LpYODDdKjZmUimFdanKYpCP3C3M5@Pe5JSCkULhZG1HHdLhBVxwW7YboOSxysYQwuNZDZpDHrYF1Q40mitCYY1rAO@6zZL6DqsWx8pTR0XHNzDiigqqCj3vEeFJsbTWBuOBRHEVI9yZHMgVwJ3+9Lx@ymFv3P8eNy2uuYKOjBlcWqnTXu8wINzguc3sMJ3G4ar9miYjm325jQYZXQvO@DSVarQtXRtbcKEMFHClaGXWaLCqWYZrbimkc5vE9wvtBD2Jej6WAM9HcUhpp@pJFGavIdZGLmDgAcAAA=@====@
gphy0_phyaddr=0
hwconfig=RGMII1:phyaddr=31
image0_addr=0xB00C0000
image0_is_valid=1
image1_addr=0xB0800000
image1_is_valid=1
image_name=g010sb
import_uboot_env=env import -t ${ram_addr} ${filesize}
ipaddr=192.168.1.10
kernel0_from_sf=sf probe 0;sf read ${ram_addr} ${kernel0_offs} ${max_kernel_size}
kernel0_offs=0xC0000
kernel1_from_sf=sf probe 0;sf read ${ram_addr} ${kernel1_offs} ${max_kernel_size}
kernel1_offs=0xCC0000
load_kernel=tftpboot ${ram_addr} ${tftppath}${image_name}-uImage
load_uboot=tftpboot ${ram_addr} ${tftppath}u-boot.img
load_uboot_env=tftp ${ram_addr} ${tftppath}u-boot.env
load_uboot_env_y=loady ${ram_addr}
log_iaddr=0x1AC0000
magic_addr=0xBF200038
magic_val=0xDEADBEEF
max_kernel_size=180000
mtdparts=mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(linux),12288k(image1),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve)
net_nfs=run load_kernel nfsargs addip addmtdparts0 addmisc;bootm ${ram_addr}
netconsole=set stderr nulldev;set stdin nc,serial;set stdout nc,serial
next_active=0
nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath},${nfsoptions}
nfsoptions=rsize=1024,wsize=1024
preboot=gpio clear 100
ram_addr=80F00000
reserve_iaddr=0x1FF0000
reset_uboot_env=env default -f -a; saveenv
ri_hiaddr=0x1FC0000
ri_image=3FE46956AAAA_ri.bin
ri_siaddr=0x1FE0000
save_uboot=sf probe 0;sf erase 0 40000;sf write ${ram_addr} 0 ${filesize}
select_image=if test -n $commit  ; then else setenv commit  _err;saveenv;fi;if test -n $image0_is_valid ; then else setenv image0_is_valid 1;saveenv;fi;if test -n $image1_is_valid ; then else setenv image1_is_valid 0;saveenv;fi;if itest *${magic_addr} == ${magic_val} ; then if itest *${act_img_addr} == 0 ; then setenv next_active 0;fi;if itest *${act_img_addr} == 1 ; then setenv next_active 1;fi;mw ${magic_addr} 0x0;mw ${act_img_addr} 0x0;fi;if test $next_active = -1 ; then setenv c_img $commit;else setenv c_img $next_active;if test $next_active != $commit ;then if test $next_active = 0 ;then setenv next_active 1;setenv image0_is_valid 0;setenv commit 1;else setenv next_active 0;setenv image1_is_valid 0;setenv commit 0;fi;saveenv;fi;fi;exit 0
serverip=192.168.1.100
start_netconsole=if test -n ${ncip}; then echo 'check for netconsole'; if ping ${ncip}; then run netconsole; echo 'netconsole enabled'; fi; fi
stderr=serial
stdin=serial
stdout=serial
update_A0=gpio clear 102;tftpboot ${ram_addr} ${tftppath}${a0_image};eeprom write 50 ${ram_addr} 0 ${filesize}
update_A2=tftpboot ${ram_addr} ${tftppath}${a2_image};sf probe 0;sf erase ${a2_iaddr} +${filesize};sf write ${ram_addr} ${a2_iaddr} ${filesize}
update_configfs=tftpboot ${ram_addr} ${tftppath}configfs.image;sf probe 0;sf erase ${config_iaddr} +${filesize};sf write ${ram_addr} ${config_iaddr} ${filesize}
update_image0=tftpboot ${ram_addr} ${tftppath}${image_name}-squashfs.image;sf probe 0;sf erase ${kernel0_offs} +${filesize};sf write ${ram_addr} ${kernel0_offs} ${filesize}
update_image1=tftpboot ${ram_addr} ${tftppath}${image_name}-squashfs.image;sf probe 0;sf erase ${kernel1_offs} +${filesize};sf write ${ram_addr} ${kernel1_offs} ${filesize}
update_logfs=tftpboot ${ram_addr} ${tftppath}logfs.image;sf probe 0;sf erase ${log_iaddr} +${filesize};sf write ${ram_addr} ${log_iaddr} ${filesize}
update_openwrt=run update_system
update_ri=tftpboot ${ram_addr} ${tftppath}${ri_image};sf probe 0;sf erase ${ri_hiaddr} +${filesize};sf write ${ram_addr} ${ri_hiaddr} ${filesize};sf erase ${ri_siaddr} +${filesize};sf write ${ram_addr} ${ri_siaddr} ${filesize}
update_system=run update_image0 && setenv commit 0 && setenv image0_is_valid 1 && saveenv
update_uboot=run load_uboot && run save_uboot
update_uboot_env=run load_uboot_env && run import_uboot_env && saveenv
update_uboot_env_y=run load_uboot_env_y && run import_uboot_env && saveenv
update_uboot_y=loady ${ram_addr} && run save_uboot
ver=U-Boot 2015.04-lantiq-gpon-1.3.7.1 (Aug 21 2017 - 17:12:42)
boot_fail=0
maybe can be compatible with
https://downloads.openwrt.org/releases/ ... pgrade.bin
BackON
Re: Usage GPON module SFP in Spain
Fri May 29, 2020 10:12 pm
Finally i got to the web acess to G-010S-B module user adminadmin password ALC#FGU
this is the web page only i can change SLID and password. all other command works like the g-010s-p tomorrow im going to test it in my gpon line
BackON
Sat May 30, 2020 3:35 pm
Hi again
G-010s-b doesnt work on ftth in spain maybe the missing synce? I going to try to disable it in the firmware and check it again.
Any suggestions?
JeanPierre
Mon Jun 08, 2020 10:07 pm
There have been several reports about new modules with Realtek chips: Ubiquiti UFiber-Instant, V-Solutions - V2801F and many more. I've updated my list of GPON modules.
viewtopic.php?f=3&t=116364&p=771961#p771961
Does anyone know the difference between RTL8672 and RTL9601C. I suppose RTL8672 is the main processor and RTL9601C is dedicated to GPON processing. All clones of modules with Realtek chip have the similar partition layout.
# cat /proc/mtd
mtd5: 004b0000 00001000 "r0"
mtd7: 004b0000 00001000 "r1"
mtd8: 00010000 00001000 "hw"
mtd9: 00010000 00001000 "sec"
mtd13: 004b0000 00001000 "rootfs"
Brief datasheet for V-SOL V2801F listed the RTL9601C as the main chipset.
https://www.vsolcn.com/1ge-sfp-onu-p00193p1.html
mgarcia
Sat Jun 13, 2020 2:53 pm
Dear all.
a few hours ago I ran Zisa with Tilera.
I have heard some comments that were incompatible and I can now confirm that it is certainly compatible.
You can browse my old post regarding the ZISA OP151S. I have made it work by changing only the firmware I mentioned earlier, modifying MAC, SERIAL NUMBER, LoID, and PLOAM PASSWORD / IDONT.
To connect to Zisa ONT:
- create a bridge without STP with ports where laptop connected and Zisa connected
- Add an IP in laptop LAN in 192.168.1.2 (f. Example)
- Connect Zisa ONT to the Fiber from ISP wait untill links UP. if till down after some time reeboot router with all connected.
- Type in webbrowser 192.168.1.1 user: admin pass: admin upgrade firmware mentioned on my last posts from web.
after updated: Make sure your Zisa fiber Link is UP. If not just wait a while or reboot router as mentioned.
- Telnet to 192.168.1.1
user: twmanu - pass: twmanu
- type "?" without wuotes for the menu options.
We just will need manufactory menu to work.
Enter to manufactory menu:
- type: "manufactoy" and press enter
"show ?" without quotes to show all options to check
"set ?" without quotes to show all options to set.
SERIAL NUMBER:
Inside Manufactory menu:
- type: "show sn" = shows Actual SN
- type: "set sn CCCCXXXXXXXX" with your serial number
confirm change with "show SN" command
LoID and Password:
inside Manufactory menu:
- type: "show ctc info" (shows actual info) in blank normally
- type: "set ctc loid XXXXXXXXXXXXXXXXXXXXXXXX" (in ASCII Format)
- type: "set ctc password XXXXXXXXXXXXXXXXXXXX" (20digit) without "0x"
If your Loid is in HEX just use one online HEX to ASCII converter.
confirm with "show ctc info" command
after all settings remove from created bridge SFP port and reboot router. ont will connect properly.
I hope all this settings would be fine for all ISP in spain.
After this you should add the corresponding VLAN/ PPPoE if needed from wour ISP in the SFP port to work.
Waiting for Zisa Users who can check this in the forum!
Kind regards!
iperezandres
Sat Jun 13, 2020 3:12 pm
This is great! Thanks for all the info and detail. My one and only question is: where can I buy a ZISA OP151S module? It seems to be out of stock in all the stores I checked...
Thanks.
mgarcia
Sat Jun 13, 2020 3:38 pm
Thanks.
I bought in Alibaba.
Kind regards,
BackON
Sat Jun 27, 2020 1:38 am
hello again
I got several SFP but im not able to connect (zisa op151s g-010s-a g010s-b dfp-34g-2c2) i put the slid on the zisa with the slid and serial but its stuck on 05 state in init.
y tested too the ZTE and the nokia module but im not able to connect. in g-010s-a says error from omci manager
My original ont is a g-010g-p only i have a HEX SLID and serial number
Sob
Wed Jul 15, 2020 4:10 pm
Out of curiosity, what's with the secrecy? You know, the "mail us if you want to know anything", instead of simply making the info public.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Petronas
Thu Jul 23, 2020 8:49 pm
Hello. :D
Here is Carlitos' stick. GPON ONU SFP (CPGOS03-0490 v2.0)
Memory processor photos and others Realtek RTL 9601 - Winbond 25Q64JVIQ
Many values can be modified via WebUI and Telnet
You can also change the serial number of the stick by Telnet
Very stable, The only annotation I see is the warm-up, but the same thing happens in other modules
:shock:
I recommend it, get in touch with CarlitoxxPro.
Good quality.
Regards.
JeanPierre
Thu Jul 23, 2020 10:07 pm
Hello. :D
:shock:
Good quality.
Regards.
Great post. Thank you for sharing all these photos with us. We see what is inside the stick :D
It seems CarlitoxxPro has put a lot of work into the module customization and testing to make sure it works with all popular OLT models.
JeanPierre
Fri Jul 24, 2020 4:59 pm
Hi Petronas
Can you share more about Realtek RTL9601C.
What does it display?
cat /proc/cpuinfo
cat /proc/mtd
Petronas
Sat Jul 25, 2020 1:57 pm
Here, drop this !!!
Hi Petronas
cat /proc/cpuinfo
cat /proc/mtd
vuducdong
Mon Jul 27, 2020 5:38 pm
Facebook
Twitter
Telegram
I’m sent email to you but not reply ???
JacquesL
Mon Jul 27, 2020 6:08 pm
The system type is RTL8672 , so very similar to the CarlitoxxPro module. Have you tried to understand more? One can telnet to 192.168.1.1 ubnt/ubnt . Apparenly some of the parameters can be set using the flash command. I am wondering if there is a way to get it to work as well
JacquesL
Mon Jul 27, 2020 10:57 pm
Good quality.
Petronas, what user ID and password are you using? I can get the webpage to load on 192.168.1.1 or use telnet but cpAdmin/cpAdmin or cpUser/cpUser is not accepted. I'd like to be able to test the module after waiting so long :)
thank you
JacquesL
Tue Jul 28, 2020 6:13 pm
I've been able to make progress with the UFiber-Instant ONU module: it can definitely reach Operation State (o5) on the Movistar (Huwaei) ONT in Spain
However I had to go in the diag system and manually overwrite the PLOAM password, because the flash command limits the GPON_PLOAM_PASSWD to 10 characters in the settings that survive reboots. Still WIP ...
karman
Fri Jul 31, 2020 4:40 am
I received DFP-34X-2C2 and can confirm is working just perfect with pepephone ISP (S/N and Password).
Has anyone had any problem with this module or its twin DFP-34G-2C2 with other spanish ISP?
Petronas
Fri Aug 07, 2020 4:30 pm
Good quality.
thank you
As I said before you can change all the parameters and configurations, via web and telnet.and accept registration in OLT
Get in touch with carlitos, you will find the solution, with the most powerful complete device and support.
Don't waste your time anymore, you have the solution in your hand.
slarner
Mon Aug 10, 2020 3:17 pm
How did you go about accessing the SFP? Ive got it in a Mikrotik atm it just shows the module is present. Does it have an IP you can SSH to it on?
http://www.countybroadband.net
Provider of wireless broadband in Essex and Suffolk UK
vuducdong
Tue Aug 11, 2020 12:10 pm
Did you find the temperature of the SFP combined with the RB760igs too high when using it? It felt very hot, unable to touch it
msatter
Tue Aug 11, 2020 1:22 pm
[/quote]
[/quote]
viewtopic.php?f=3&t=132258&p=670687&hil ... nk#p671105
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47.1 / Winbox 3.24 / MikroTik APP 1.3.14
Users browsing this forum: YaCy [Bot] and 27 guests
