hugomon
Re: Usage GPON module SFP in Spain
Thu Nov 28, 2019 6:51 pm
Hi, I have problems with my ONT Alcatel-Lucent O-010S-P, I can't even connect by SSH. I have tried 192.168.1.10, among others, but there is no ping.
Does anyone know this model, and if it is compatible?
hugomon
My model ONT G-010S-P responds to pings in Mikrotik. Please check my steps.
1. Assign sfp1 as WAN interface (it will remove sfp1 from the bridge)
2. G-010S-P and other models will not expose ethernet interface unless fiber cable is connected (link-ok, rate 1Gbps)
[admin@MikroTik] > interface ethernet monitor sfp1
                    status: link-ok
          auto-negotiation: done
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: SC
       sfp-link-length-9um: 20000m
           sfp-vendor-name: ALCATELLUCENT
3. Add IP address to the sfp1 interface
[admin@MikroTik] > ip address add address=192.168.1.15/24 interface=sfp1
4. [admin@MikroTik] > ping 192.168.1.10
SEQ HOST SIZE TTL TIME STATUS
0 192.168.1.10 56 64 0ms
1 192.168.1.10 56 64 0ms
2 192.168.1.10 56 64 1ms
3 192.168.1.10 56 64 3ms
5. telnet or ssh
[admin@MikroTik] > system telnet 192.168.1.10
[admin@MikroTik] > system ssh user=ONTUSER address=192.168.1.10
Thank you for your reply JeanPierre!; I will try this week and report here with the result.
AndreHro
Thu Nov 28, 2019 9:03 pm
Hi, is there someone out there selling Zisa's or Carlitos SFP?
I tried contacting Zisa but they wouldn't sell me one.
Hi there,
I have the ZISA one. It won't work with my provider so I don't need it. Interested?
Best Regards.
Which provide do you use?
I’m interested if it’s not Movistar in Madrid.
spaxton
Thu Nov 28, 2019 9:44 pm
Hi there,
Best Regards.
[/quote]
My provider is outside of Spain. It is Telekom (T-Com) in Montenegro. A part of Deutsche Telekom. Do You know anything about the modules I asked in a few previous posts? Nobody is willing to reply about.
Best Regards.
AndreHro
Thu Nov 28, 2019 10:01 pm
No, I only saw here that some people successfully running the Modul in Spain by modifying the PON LOID and Serial number to the values used from the provider. Since my provider is Movistar I ask about your provider.
I had contact to hilink they want technical details and after that no reply.
I also had contact to usourcetech about the Modul UGP-N1S
But I not really sure if it will work.
spaxton
Thu Nov 28, 2019 10:46 pm
Ok, I want to get rid of my zisa. In order to make it work here I would need to use its command line interface and I don't want to learn anymore how to do that. I need almost a plug n play option. What is Your offer?
zlobster
Fri Nov 29, 2019 2:09 am
Hola Friends
friend in Valencia asked for me help. he got good SFP stick. lot of options to modify serial\vendor\part number\ and more. sticks have open source openwrt
login web 192.168.1.57 or telnet to sfp
OEM company\\ dipperoptics\dpoptics stick numero D23446
Licensee company \\ hilinktech\ stick number HL23446
Hello friend,
I am trying to replace my huawei router for a long time. I own ZISA OP151s but it doesnt work for me. Can You, please, let me know if the module You showed here works for You? Can You attach some web interface photos?
Best Regards.
Did you tinker with your Zisa? If so, what is changed?
Is your Zisa working?
Best I can do is 25€ + something reasonable for shipping.
hugomon
Fri Nov 29, 2019 9:52 am
hugomon
                    status: link-ok
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
               sfp-rx-loss: no
5. telnet or ssh
Bad news, it doesn't work, I can obtain a link ok in the module only if I disable speed auto-negotiation, and still can't ping or ssh to the GPON.
spaxton
Fri Nov 29, 2019 10:41 am
Hello friend,
Best Regards.
The ZIsa is working. Total work hours about 6. Nothing changed, not even the firmware. The factory firmware is in it. However, the best I can do is 40 + 17 shipping to Spain. If You want the same brand new module like ZISA. For what I could investigate with my chinese friends, this module is absolutely the same as zisa and is was also produced and designed by the same factory T&W.
Best Regards.
AndreHro
Fri Nov 29, 2019 11:59 am
So for me 60 Euro including shipping would be ok.
Can you send me a message in the forum?
spaxton
Fri Nov 29, 2019 12:12 pm
HI,
I don't see an option to send You the message via forum. Please use email address spaxton.ligiston@yahoo.com . From there we can exchange details.
Best Regards.
JeanPierre
Sat Nov 30, 2019 2:04 am
hugomon
Try ip-scan to see if anything responds...
[admin@MikroTik] > tool ip-scan interface=sfp1 address-range=192.168.1.0/24
Flags: D - dhcp
  ADDRESS         MAC-ADDRESS        TIME DNS                                       SNMP                                       NETBIOS
  192.168.1.10    00:06:B5:BE:11:EF   1ms
  192.168.1.15                        0ms
Change the sfp1 interface to 192.168.0.15 and scan 192.168.0.0/24. Repeat for 192.168.2.0/24, 192.168.3.0/24, 192.168.4.0/24 networks. I've have seen document claiming 192.168.4.254, 192.168.3.10, 192.168.1.251 to be ONT's configuration IP
jondavy
Mon Dec 02, 2019 6:08 pm
note that many customers and operators use GPON
Normis, have you planned to launch any solution in the GPON? Branch, as we need OLT and ONUs from MikroTik urgent
hugomon
Tue Dec 03, 2019 11:23 am
hugomon
Flags: D - dhcp
  192.168.1.15                        0ms
You was rigth @JeanPierre, the correct IP was 192.168.2.2. After configure NAT masquerade for sfp1 I can login with user: ONTUSER and password: SUGAR2A041
That's the good news, the bad news is I can't configure anything once logged in. Nothing is displayed about the busybox and commands like onu gtcpg don't work.
Also it runs extremely slow, even when writing, becoming apparently frozen.
In any case, it's a progress, thank you.
Petronas
Tue Dec 03, 2019 3:11 pm
It seems from his images this user does not have "administrator privileges".
run cd /
run uci show
use the help commands
can you upload?  to pastebin.com
minhng99
Thu Dec 05, 2019 10:01 am
Hi, I have a uboot repo here that appears to work with the Alcatel-Lucent/Nokia GPON SFP, also the Huawei MA5671A
https://github.com/minhng99/u-boot_lantiq_falcon
more about this being discussed here: https://forum.openwrt.org/t/support-ma5 ... n/48042/21
It's not fully working yet and don't appear to work correctly with the G-010S-P (kernel panic, root= not found) but if we managed to fix this then we might be able to have a netconsole uboot working and it will be much easier to test firmware
spaxton
Tue Dec 31, 2019 5:52 pm
I managed to burn the integrated with the "sfp_i2c" commands shown above
Antonio's commands make more sense to me. He's on 14.07_ltq. I am on 12.09_ltq
** remove 12.09 variables **
fw_setenv nPassword
fw_setenv nSerial
** use 14.07 (Antonio post #210) **
fw_setenv ont_serial HWTN12345678
convert password to hex in rapidtables https://www.rapidtables.com/convert/num ... o-hex.html ---->> 0123456789 hex=30 31 32 33 34 35 36 37 38 39
uci set gpon.ploam.nPassword='0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39'
uci commit
reboot
** verify after reboot **
root@SFP:/# onu gtcsng
root@SFP:/# onu gtcpg
I write these commands and write correctly, then I check and they have not been written
Hello friend,
Have You managed to change the values and how?
Best Regards.
BackON
Fri Jan 03, 2020 1:03 pm
I have more ifo from of DFP-34G-2C2
The chipset is a ZTE ZX279125
flash memory winbond 25q128fsg
other chip is atheros but i cant see the model
in the back have a chip k24c06 1546cdx and 25l95 1707 22649
i created on openwrt forum a post about it to suppport it if is posibble
https://forum.openwrt.org/t/dfp-34g-2c2-sfp/51641
88zz88
Wed Jan 08, 2020 2:48 am
Salute comrades
Newtman
Sat Jan 25, 2020 6:00 pm
I'm from Uruguay and our ISP use similar tecnology to Spain, in consecuence I guess I can use some GPON module.
What module are working now?
Is impossible to find Zisa module, but I read few post upper, CM5671A is equivalent... But is very expensive only for an experiment, because I can't found information online about it.
Carlitoxx's module is out of stock since an year now.
Thanks!
JeanPierre
Mon Jan 27, 2020 3:15 am
Hi, I have compiled a list of popular GPON modules. Let me know if I missed something or made a mistake.
=-=-=-=-=-=-=-= Chipset: Intel/Lantiq PEB98036 =-=-=-=-=-=-=-=-=-=-=-=
FGS202
Flash 8MB, RAM 1MB, System RTOS eCos
Pros- Quick start
Cons - Flash programming/soldering required for SN/Password change. It may overheat. No graphical web interface.
=-=-=-=-=-=-=-= Chipset: Intel/Lantiq PEB98035 =-=-=-=-=-=-=-=-=-=-=-=
MA5671A
Flash 16MB, RAM 64MB, System OpenWRT
Pros - Good compatibility with Huawei and third-party vendors. Highly configurable through commands.
Cons - Hardware adapter and soldering required for full shell. No graphical web interface. Change SN/Password via command line.
G-010S-P
Pros - Good compability with Alcatel/Nokia. Web interface. Highly configurable through CLI commands
Cons - IPTV may not work with third-party vendors.
CarlitoxxPro CPGOS03-0490 / HL23446
Pros - Good web interface. Several vendor profiles. Highly configurable through CLI commands. Supports LOID
GPON-ONU-34-20BI
Pros - Good compability with several OLT. Web interface. Highly configurable through CLI commands
Good support from users on lafibre.info
The firmware is interchangeable between: FS GPON-ONU-34-20BI, Photonics SPS-34-24T-HP-TDFO, Huawei MA5671, Alcatel G-010S-P, Hilink HL23446, CarlitoxxPro CPGOS03-0490, Dasan H650SFP, DpOptics D23446
LAN interface can be switched from 1 Gbps to 2.5 Gbps(sgmii_mode variable is set to 5)
G-010S-A
Pros - Good compability with Alcatel/Nokia. Web interface. Highly configurable through commands. Capable of 1Gbps or 2.5Gbps LAN mode. Web GUI.
Cons - IPTV may not work with third-party vendors, for some routers soldering pin#6 to ground is required (info on dslreports forum - CanadaBell BCM57810S NIC)
=-=-=-=-=-=-=-= Chipset: Intel/Lantiq PEB98035 =-=-=-=-=-=-=-=-=-=-=-=-=
Zisa OP151S
Flash 8MB, RAM 64MB, System T&W Linux atop of OpenWRT 10_03 or 12_09
Pros - Good web interface. A lot of commands.
Cons - It may overheat. Security considerations - some firmware is pre-filled with TR-069 servers.
The firmware interchangeable beetween: T&W TW2362H-CDEL, Zisa OP151S, D-LINK DPN-100, Zyxel PMG3000-D20B, CM5671A, Eltex NTU-SFP-100, Calix 100-03903
=-=-=-=-=-=-=-=-=-=-=-= Chipset: ZTE ZX279125 =-=-=-=-=-=-=-=-=-=-=-=-=-=
ZTE DFP-34G-2C2
Flash 16MB, RAM 32MB, System ZTE Linux
Pros - Extensive graphical network interface (GUI). Supports HGU(Router mode) and LOID.
Cons - Limited number CLI of commands.
Other products:
EXOT - DFP-3422
=-=-=-=-=-=-=-=-=-=-=-= System on Chip (SoC): Realtek 9601x =-=-=-=-=-=-=-=-=-=-=-=-=-=
RTL9601x SoC features MIPS CPU Core RTL8672, an embedded RAM, Network, PON Controllers inside one QFN package.
Flash 8/16MB, System Linux version 2.6.30.9 - Realtek RSDK-1.5.6p2 - luna SDK V1.9.0
Pros - Extensive graphical network interface (GUI), supports LOID, HGU(Router mode), SN, password, MAC change. Low ambient temperature.
Cons- Web interface, SN change, and dual support for EPON/GPON will vary depending on how the final vendor configured the module.
Several product families built upon Realtek RSDK-1.5.6p2 are available:
RTL9601B
Technicolor AFM0002TIM, Hisense LTE3415-SCA+
Package QFN88, UART pins 30/31
RTL9601CI
Google Fiber GFLT210, Cigtech G-97S, Hisense LTE3415-SH+, Ubiquiti UF-Instant, VSOL V2801F, OPTON GP801R, BAUDCOM BD-1234-SFM, Carlitoxx CPGOS03-0490 v2.0, EXOT - EGS1, T&W TWCGPON657, CM5671A
2.5Gb HSGMII support in some modules.
Package QFN76, UART pins 12/13
RTL9601D
ODI DFP-34X-2C2-v05
2.5Gb HSGMII Support enabled.
Package QFN88, UART pins 24/25
Newtman
Wed Jan 29, 2020 5:08 pm
Thanks JeanPierre!!! Nice compilation of information.
MA5671A is very affordable and I understand work well. Isn't problem for my solder the EEPROM and read it. I have got a R809F with the correct sockets.
Any advice?
Thanks!
JeanPierre
Thu Jan 30, 2020 8:43 pm
My advice?
Intel/Lantiq 98035 if you are not afraid of programming and, for some modules, soldering. They sometimes appear on Canadian(ebay.ca) or Italian(ebay.it) national ebay websites.
I forgot to add that Intel chip 98035 has LAN interface that can be switched from 1 Gbps to 2.5 Gbps. Important for users whose ISPs offer higher speeds than 1Gbps. This applies only to modules with OpenWRT(sgmii_mode variable is set to 5)
The best Intel/langiq module was sold by CarlitoxxPro and Hilink. Unfortunately, they don't have them in stock. Since HL23446 firmware is available I will try to load it on my g-010s-p sfp module and see how it works!
For the rest, probably DFP-34G-2C2. It has a rich web interface. The module is available under different names but the casing has a distinctive appearance. Just look at the photos from previous posts. It says "PON STICK V01" on the board. A large number of these modules are available on aliexpress in the "anddear" shop
A few users here have these modules but we have not enough reports on how they work. The modules may not work with ISP's who check software versions.
kapook007
Sun Feb 23, 2020 12:00 pm
device MA5671A
isp1 use SN+password authentication > working for MA5671A / use fw_setenv ont_serial and uci set gpon.ploam.nPassword
isp2 use LOID+CHECKCODE authentication > not working for MA5671A
how to change LOID+CHECKCODE for MA5671A ?
JeanPierre
Tue Feb 25, 2020 2:54 am
LOID - 1-24 characters
CHECKCODE(LOID PASSWORD) - 1-12 characters
If the firmware supports LOID authentication LOID+CHECKCODE parameters can be updated by changing two variables: omci_loid and omci_lpwd
fw_setenv omci_loid xxxxxxxxxxxxx
fw_setenv omci_lpwd xxxxxxxxxxxx
If LOID is disabled in the firmware try alternative software from CarlitoxxPro CPGOS03-0490
kapook007
Wed Feb 26, 2020 6:31 am
fw_setenv omci_loid xxxxxxxxxxxxx not working
fw_setenv omci_lpwd xxxxxxxxxxxx not working
Need backup firmware CPGOS03-0490
mtd0-mtd5
T T
JeanPierre
Thu Feb 27, 2020 6:51 am
HL23446 shared above should be the same as CPGOS03-0490
xh116
Tue Mar 03, 2020 7:47 am
Hi
Do you have hl23446 firmware to download, My module is brick by mistake without backup...
Thanks in advance
piku
Tue Mar 03, 2020 7:52 am
Hi everyone,
I'm a GPON SFP ONU user in China, which is the country of most SFP hardware producing country.
According to what I know, most SFP use TW2312 as master chip (like Zisa OP151s,TW2312H-CDEL), which is manufacted by T&W, Shenzhen, China.
I have Zisa OP151s, TW2312H-CDEL and I believe CM5671A they all have same hardware.
Unfortunately most of them are end of life and the developer group was dismissed.
The problem I have is my SFP don't support some OMCI command. This makes it available to some ISPs, but not others.
I'd like to try your firmwares to workout a solution.
By the way, a former engineer of T&W create a new SFP ONU which use Realtek master chip, support GPON, EPON, SN, snid, loid, MAC, with only $38.
piku
Tue Mar 03, 2020 8:27 am
As mentioned above,ZTE is another manufacturers in China. As far as I am concerned, The framwork of ZX279125 is not same as lantiq.
What are your specific problems?
JeanPierre
Tue Mar 03, 2020 4:07 pm
It looks that modules SPS3424THPTDFO, MA5671A, G-010S-P, CPGOS03-0490, H650SFP, HL23446 share the same MTD partition mapping.
root@SFP:/# cat /proc/mtd
dev: size erasesize name
mtd0: 00040000 00010000 "uboot"
mtd1: 00080000 00010000 "uboot_env"
mtd2: 00740000 00010000 "linux"
mtd3: 0061eedc 00010000 "rootfs"
mtd4: 00370000 00010000 "rootfs_data"
mtd5: 00800000 00010000 "image1"
Combine MTD parts from different modules to create the firmware
root@ubuntu:/# cat mtd0.bin mtd1.bin mtd2.bin mtd5.bin > firmware.bin
root@ubuntu:/# ls -l
-rw-r--r-- 1 root root 16777216 Nov 12 09:51 firmware.bin
JeanPierre
Tue Mar 03, 2020 4:10 pm
Can you share a photo or name of the new SFP ONU with Realtek chip?
piku
Wed Mar 04, 2020 7:38 am
As your wish.
Left: G/Epon sfp with Realtek master chip
Right: TW2362H
I'll dismante it later because it is in use.
JeanPierre
Wed Mar 04, 2020 6:05 pm
Right: TW2362H
Thanks.
I'm intrigued by what model of chip is used to make this SFP module. Is it possible that RTL9601C was used?
I found more pictures and setup screens
https://www.chiphell.com/thread-2184048-1-1.html
Can you recommend a place to buy this Realtek SFP.
piku
Thu Mar 05, 2020 4:07 am
Thanks.
Yes the thread of chiphell is correct.
# cat /proc/cpuinfo
system type             : RTL8672
processor               : 0
cpu model               : 56322
BogoMIPS                : 112.23
tlb_entries             : 64
mips16 implemented      : yes
# cat /proc/version
Linux version 2.6.30.9 (root@ubuntu12) (gcc version 4.4.6 (Realtek RSDK-1.5.6p2) ) #9 Thu Oct 24 20:18:35 CST 2019 [luna SDK V1.9.0]
# cat /proc/mtd
mtd0: 00040000 00001000 "boot"
mtd1: 00002000 00001000 "env"
mtd2: 00002000 00001000 "env2"
mtd3: 0003c000 00001000 "config"
mtd4: 00300000 00001000 "k0"
mtd5: 004c0000 00001000 "r0"
mtd6: 00300000 00001000 "k1"
mtd7: 004c0000 00001000 "r1"
mtd8: 00001000 00001000 "Partition_008"
mtd9: 00001000 00001000 "Partition_009"
mtd10: 00001000 00001000 "Partition_010"
mtd11: 00001000 00001000 "Partition_011"
mtd12: 00300000 00001000 "linux"
mtd13: 004c0000 00001000 "rootfs"
# cat /proc/meminfo
MemTotal:          16944 kB
MemFree:            5352 kB
# dmesg
/bin/sh: dmesg: not found
Unfortunately it is only sold in mainland of China and the price goes up recently. Please refer here (interest irrelevant)
It is incompatible with CCR's SFP+. Only a few PCIe card tested and compatible, too.
So it is about $52+$32 postage with Universal Postal Union if you really want.
By the way, I really don't think it's worth it. A S/EPON modem with gigabytes port only $40 with shipping.
kapook007
Sat Mar 07, 2020 11:54 am
Bad news for DFP-34G-2C2
route mode only
how change to bridge mode with vlan support ?
piku
Mon Mar 09, 2020 2:12 pm
....(sorry for reduce)
route mode only
ODI said bridge mode is not allowed by ZTE's warrant. Sorry.
[delete]But the function of bridge mode exists, maybe just need to complement some webpage files. ODI said they're trying.[/delete]
update 13 Mar:
A friend send me one of this sfp and I did some dig.
IT IS BRIDGED BY DEFAULT like a SFU, just don't create any connect in WAN Connection page.
It works with one of my ISP but not another, same like Lantiq.
It is not work with CCR1009's SFP+, only SFP works.
Newtman
Fri Mar 13, 2020 3:37 pm
Hello!
I finally receive my first Mikrotik and SFP, a RB960PGS and MA5671A.
I'm fully noob with Mikrotik but after a couple of hours I logged in to the SFP via SSH.
My SFP need the fibber connected, the default IP is 192.168.1.10, credentials are root / admin123
After this I tried set my serial number and password without luck. The commands fw_setenv didn't work... But I found the command "set" work, but I don't know the name of the variables (I tried with "print" and other words like this)
I don't find manual or similar, commands like help or man are disable too... But I found this log.
root@192.168.1.10's password:
Welcome Visiting Huawei Home Gateway
Copyright by Huawei Technologies Co., Ltd.
# display_log
2018-04-30 21:18:21 Software successfully upgraded. Source version: V8R017C00S201. Target version: V8R017C00S206
If necessary I can read the EEPROM with my R809F, but I prefer not solder.
Anyone have experience with this dongle?
Thanks!!
piku
Fri Mar 13, 2020 5:23 pm
Hello!
# display_log
Thanks!!
Yes. It's almost same as SmartAX MA5671. try
set sn snid 5CA858829BE1
Newtman
Fri Mar 13, 2020 5:42 pm
Hello!
# display_log
Thanks!!
Thanks piku, I will try tomorrow.
Have you got a full manual of this sfp?
Thanks!!!
piku
Sat Mar 14, 2020 7:05 am
Thanks!!!
Sorry.
Huawei design it is to configurate from olt, not for separate work. So there is no official manual for commands.
JeanPierre
Tue Mar 17, 2020 9:46 pm
I believe the "set" command only works with DyingGasp variable
# set nDyingGaspEnable enable
Result:Success
# set nDyingGaspEnable disable
Result:Success
kapook007
Tue Mar 24, 2020 5:13 pm
i try firmware
i have some problem about firmware for ma5671a
H650SFP image0 rev. 14_07
-working same ont
root@SFP:/# onu ploamsg
errorcode=0 curr_state=5
HL23446 notworking
-not found gpon signal
errorcode=0 curr_state=1
anyone have problem with me ?
JeanPierre
Tue Mar 24, 2020 7:11 pm
i try firmware
HL23446 notworking
@kapook007
Try this. It works for me
root@SFP:/# fw_setenv ont_serial HWTC1122334455
root@SFP:/# fw_setenv target oem-generic
root@SFP:/# uci set gpon.ploam.nPassword="0x31 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x39"
root@SFP:/# uci commit
root@SFP:/# reboot
It should keep the login 192.168.1.10 from MA5671A (telnet and http)
If you require more changes like model number, firmware version, MAC address, LOID have a look at Antonio's post
viewtopic.php?f=3&t=116364#p751330
piku
Wed Mar 25, 2020 2:50 pm
i try firmware
-working same ont
HL23446 notworking
O1 means not receive light. I doubt there is physical connection problem.
Dasan H650SFP is a product form Koera and SC/APC connecter is widely used in Korea, which is different from HL23446.
BTW, I'm not familiar with Korea. Just for your reference.
kapook007
Thu Mar 26, 2020 3:13 am
i try firmware
-working same ont
HL23446 notworking
i already check physical connection
my device is ma5671a 1pc install 2 firmware
1.firmware H650SFP is working
2.firmware HL23446 not found gpon signal
i try in my home
piku
Thu Mar 26, 2020 2:38 pm
i try in my home
my misunderstanding, sorry.
kapook007
Thu Mar 26, 2020 4:07 pm
Hi
HL23446 firmware not found gpon signal.
i test and got problem
HL23446 found gpon signal over -15dbm
But standart gpon signal is -20dbm to -28dbm HL23446 not found gpon signal
CarlitoxxPro CPGOS03-0490 can found gpon signal -20dbm to -28dbm ????
Anyone who can share CarlitoxxPro CPGOS03-0490 firmware.
mtd0 , mtd1 , mtd2
thanks
CarlitoxxPro
Sat Apr 04, 2020 1:38 am
We are very happy :D by announce that we are currently on manufacturing process for the newest version of GPON ONU SFP CPGOS03-0490 V2.
New Architecture, more stability and a great interoperability between multiple OLT brands and Routers/Switches with SFP and SFP+ ports. Fully tested with TriplePlay Services (Data, VoIP, IPTV).
Its Time to replace that unreliable and limited HGU / ONT by a most advanced ONU SFP with a ultra low power compsumption and ready to work on the most faster FTTH networks.
More details very soon!! Please stay tuned. :wink:
Facebook: fb.me.com/CarlitoxxPro
Twitter: @CarlitoxxPro
Telegram: t.me/CarlitoxxPro
Email: contacto [at] carlitoxxpro.com
osquetar
Sat Apr 04, 2020 2:04 am
Ya era hora!
morishe
Mon Apr 20, 2020 6:46 pm
I have also a MA5671 flashed with HL23446 firmware.
I didn't tried with the original firmware but (like yours) PLOAM state is 1.
Did you solve your problem?
Regards
i try firmware
-working same ont
HL23446 notworking
iperezandres
Mon Apr 27, 2020 7:35 pm
C'mon Carlitos, we are looking forward to receiving more information and availability of your product!!!! :D
Newtman
Tue Apr 28, 2020 2:02 am
Result:Success
Result:Success
I confirm my SFP accept set nDyingGaspEnable enable/disable.
Obvisly the problem is the firmware, I can't configure anything or modify the variables without documentation. Next month I will receive a new programmer to dump the EEPROM. Maybe change the firmware could be a solution for me.
I can't connect directly to the SFP from the LAN, buy I'm not Mikrotik expert, is my first time... I don't understand how to bridge the networks 192.168.1.0/24 and 192.168.88.0/24.
jmj
Wed Apr 29, 2020 6:05 pm
BackON
Mon May 18, 2020 6:09 pm
after checking that image in carlitoxx facebook looks like Dfp-34g-2c2 sfp module (the cage have the same screws and look the same.) this is a new chipset (ZTE) but the question is about the firmware... its going to be openwrt or custom firmware?
almeiras
Tue May 19, 2020 1:42 pm
Hello guys, I have a Nokia g-010s-p (Alcatel-Lucent). I tried to update it from OpenWRT ltq 12 to 14 via web using a file (image 0) provided in this thread but it bricked.
Any guide on how to de-brick it? It looks like I should power it with 3.3V and reach the UART pins inside (probably while keeping the SC/APC connected since it wont power on otherwise)
Also, any cheap recommended GPON stick. Carlitoxxpro and Zisa sticks seem unavailable.
Thank you very much.
JeanPierre
Tue May 19, 2020 4:11 pm
Hello almeiras
It's easy if you have a TTL adapter connected to pins 2 and 7. Look at the instructions how to make or buy one written for MA5671A in the openwrt forum. Most of them should apply in this scenario..
almeiras
Wed May 20, 2020 11:34 pm
Thank you! And how would you upload and install the firmware? (Or even a custom one). I know I can connect via screen / cu but then what? I can’t find any tutorials...
EDIT: Sorry, I found this: https://openwrt.org/docs/techref/hardware/port.serial
ivanmh
Sat May 23, 2020 8:08 pm
Hi guys, Ubiquiti have released a new SFP GPON ONU stick called "UFiber Instant (UF-Instant)".
According to its specifications, it has SGMII Ethernet LAN interface. Would this allow working with the SFP+ connection for RB4011? It would be great if someone confirms it. I am a happy owner of a RB4011iGS+5HacQ2HnD-IN, working in harmony with a UFiber Nano G, but I'm curious to know if this new UFiber Instant would work with my RB4011.
Also, if its has the same web interface as its brothers UFiber Nano G & Loco, it should work with Movistar and other ISPs that work nice with UFiber. Except of course, VLAN2 for IPTV on Movistar ....
EDIT: Sorry, I was wrong. Reading instructions for use, this UFiber Instant has no web interface and is configured from a Ubiquiti OLT. It will not work for any Spanish ISP. My fault for not read the instructions for use before...
almeiras
Tue May 26, 2020 5:11 pm
Hello again!
So I managed to open my bricked (Nokia) Alcatel-Lucent G-010S-P. I found four empty pads on the board, hopefully the UART pins that I am looking for. Now, I have two questions:
  • Does anybody know the correct pinout? At least, can anybody confirm if these are the UART pins I am looking for?
  • Which soldering iron should I get for this kind of miniature soldering?
This image shows the possible UART pins and the opening procedure:
Thank you very much for your help!
JeanPierre
Tue May 26, 2020 9:18 pm
Hello again!
Hello almeiras
The UART contacts I am aware of are connected to pins 2 and 7. On the openwrt forum, bmx39 and minhng99 shared photos of their adapters.
https://forum.openwrt.org/t/support-ma5 ... n/48042/24
Restoration of the G-010S-P module is simple. After connecting the adapter, just send the mtd2 and mtd5 firmware from the u-boot level. Our u-boot is factory unlocked. We don't have to jump over obstacles like the owners of the MA5671A module. Remember not to destroy the mtd1 partition that contains the u-boot variables calibrated for this module.
Original firmware 12.09
https://github.com/minhng99/alcatel_luc ... master/mtd
Restoration instructions I copied from here
https://forum.openwrt.org/t/support-ma5 ... n/48042/17
#transfer image mtd2 by Kermit into memory
FALCON => loadb
## Ready for binary (kermit) download to 0x80800000 at 115200 bps...
#to write mtd2(image0)
sf probe 0
sf erase C0000 740000
sf write 80800000 C0000 740000
#transfer image mtd5 by Kermit into memory
FALCON => loadb
#to write mtd5(image1)
sf probe 0
sf erase 800000 740000
sf write 80800000 800000 740000
almeiras
Tue May 26, 2020 11:39 pm
Great, thank you so much JeanPierre!
I have already ordered a couple of SFP female connectors for the soldering. My Pi Zero and I are looking forward to some UART flashing!
BackON
Fri May 29, 2020 6:31 pm
Hello
I have another sfp gpon module from Nokia. The model is G-010s-B
Intrrnal photos
Image Image
Running on 192.168.1.10 but i dont know Web user and password but ssh password is ONTUSER/SUGAR2A041. Nmap says runs on 15.05 openwrt
Image Image
i accesed it via ssh.
ONTUSER@easy98035synce1588:/# cat /proc/cpuinfo
system type             : Falcon rev A22
machine                 : EASY98035SYNCE1588 - Lantiq Falcon SFP Stick with Sync       E/1588
processor               : 0
cpu model               : MIPS 34Kc V5.6
BogoMIPS                : 265.98
wait instruction        : yes
microsecond timers      : yes
tlb_entries             : 16
extra interrupt vector  : yes
hardware watchpoint     : yes, count: 4, address/irw mask: [0x0ffc, 0x0ffc, 0x0f       fb, 0x0ffb]
isa                     : mips1 mips2 mips32r1 mips32r2
ASEs implemented        : mips16 dsp mt
shadow register sets    : 1
kscratch registers      : 0
package                 : 0
core                    : 0
VCED exceptions         : not available
VCEI exceptions         : not available
mtd2: 00c00000 00010000 "linux"
mtd3: 0013cedb 00010000 "kernel"
mtd4: 00ac3125 00010000 "rootfs"
mtd5: 00600000 00010000 "rootfs_data"
mtd6: 00c00000 00010000 "image1"
mtd7: 00200000 00010000 "configfs"
mtd8: 00300000 00010000 "logfs"
mtd9: 00200000 00010000 "extfs"
mtd10: 00010000 00010000 "ri"
mtd11: 00010000 00010000 "sfp"
mtd12: 00010000 00010000 "ribackup"
mtd13: 00010000 00010000 "reserve"
Uci Config
 uci: Entry not found
dhcp.odhcpd=odhcpd
dhcp.odhcpd.maindhcp='0'
dhcp.odhcpd.leasefile='/tmp/hosts/odhcpd'
dhcp.odhcpd.leasetrigger='/usr/sbin/odhcpd-update'
dropbear.@dropbear[0]=dropbear
dropbear.@dropbear[0].PasswordAuth='on'
dropbear.@dropbear[0].RootPasswordAuth='on'
dropbear.@dropbear[0].Port='22'
goi_config.global=goi
goi_config.global.CalibrationTimestamp='2018-04-13T10:08; script V7.6.4; OCAL V7.6.1; FW V7.6.1'
goi_config.ranges=goi
goi_config.temperature_tables=goi
goi_config.dcdc_apd=goi
goi_config.transmitter=goi
goi_config.transmit_power=goi
goi_config.transmit_power.P1_0='3387'
goi_config.transmit_power.P0_0='170'
goi_config.monitor=goi
goi_config.monitor.MPD_Calibration_PL0='3'
goi_config.monitor.MPD_Calibration_PL1='3'
goi_config.monitor.TiaGain_PL1='1'
goi_config.monitor.TiaGain_PL0='1'
goi_config.monitor.TiaGain_PL2='3'
goi_config.monitor.MPD_Calibration_PL2='2'
goi_config.monitor.Dcalref0_PL0='3050'
goi_config.monitor.Dcalref1_PL0='3146'
goi_config.monitor.Dcalref0_PL1='3047'
goi_config.monitor.Dcalref1_PL1='3118'
goi_config.monitor.Dcalref0_PL2='1260'
goi_config.monitor.Dcalref1_PL2='1254'
goi_config.monitor.Dref0_PL0='184'
goi_config.monitor.Dref1_PL0='1563'
goi_config.monitor.MPDxt_PL0='0.778036673083'
goi_config.monitor.Imodref_PL0='34.6762215795'
goi_config.monitor.Dref0_PL1='117'
goi_config.monitor.Dref1_PL1='938'
goi_config.monitor.MPDxt_PL1='0.933644007699'
goi_config.monitor.Imodref_PL1='19.6178810304'
goi_config.monitor.Dref0_PL2='258'
goi_config.monitor.Dref1_PL2='1669'
goi_config.monitor.MPDxt_PL2='4.0717252558'
goi_config.monitor.Imodref_PL2='9.80894051519'
goi_config.measurement=goi
goi_config.measurement.Tscal_ref='0.484715133905'
goi_config.measurement.RSSI_1490parabolic_ref='0'
goi_config.measurement.RSSI_1490dark_ref='0.0008544921875'
goi_config.measurement.RSSI_1490scal_ref='0.84979253112'
goi_config.omu=goi
goi_config.bosa=goi
goi_config.fcsi=goi
goi_config.fcsi.GVS='0xf653'
goi_defaults.global=goi
goi_defaults.global.CalibrationTimestamp='OCAL V7.5.0'
goi_defaults.global.TempMonitorInterval='1000'
goi_defaults.global.TempMonitorThreshold_MPDcorrection='3'
goi_defaults.global.LaserAgeStoreCycle='43200'
goi_defaults.global.Polarity_Rx='0'
goi_defaults.global.Polarity_Bias='1'
goi_defaults.global.Polarity_Mod='1'
goi_defaults.global.Temp_IntCorr_AlarmYellow_Set='390'
goi_defaults.global.Temp_IntCorr_AlarmYellow_Clear='370'
goi_defaults.global.Temp_IntCorr_AlarmRed_Set='420'
goi_defaults.global.Temp_IntCorr_AlarmRed_Clear='400'
goi_defaults.global.TransmitLevelCheckInterval='1000'
goi_defaults.global.OpticMode='undefined'
goi_defaults.ranges=goi
goi_defaults.ranges.TableTemp_ExtCorr_Min='223'
goi_defaults.ranges.TableTemp_ExtCorr_Max='423'
goi_defaults.ranges.TableTemp_ExtNom_Min='200'
goi_defaults.ranges.TableTemp_ExtNom_Max='450'
goi_defaults.ranges.TableTemp_IntCorr_Min='223'
goi_defaults.ranges.TableTemp_IntCorr_Max='473'
goi_defaults.ranges.TableTemp_IntNom_Min='200'
goi_defaults.ranges.TableTemp_IntNom_Max='450'
goi_defaults.ranges.Ibias_Max='60'
goi_defaults.ranges.Imod_Max='80'
goi_defaults.ranges.Iavg_Max='200'
goi_defaults.ranges.IbiasImod_Max='120'
goi_defaults.ranges.CInt_Bias_Max='7'
goi_defaults.ranges.CInt_Mod_Max='7'
goi_defaults.ranges.VAPD_Min='20'
goi_defaults.ranges.VAPD_Max='60'
goi_defaults.ranges.Power_Measure_Min='0.30'
goi_defaults.ranges.Overcurrent_Ibias_Thr='60'
goi_defaults.ranges.Overcurrent_Imod_Thr='80'
goi_defaults.ranges.Overcurrent_IbiasImod_Thr='100'
goi_defaults.temperature_tables=goi
goi_defaults.temperature_tables.Tci_Ith_low='50'
goi_defaults.temperature_tables.Tci_Ith_high='40'
goi_defaults.temperature_tables.Tci_SE_low='-200'
goi_defaults.temperature_tables.Tci_SE_high='-100'
goi_defaults.temperature_tables.Tcd_Ith_low='30'
goi_defaults.temperature_tables.Tcd_Ith_high='30'
goi_defaults.temperature_tables.Tcd_SE_low='30'
goi_defaults.temperature_tables.Tcd_SE_high='30'
goi_defaults.temperature_tables.VAPD_scal_ref_low='0.09'
goi_defaults.temperature_tables.VAPD_scal_ref_high='0.09'
goi_defaults.dcdc_apd=goi
goi_defaults.dcdc_apd.VAPD_enable='0'
goi_defaults.dcdc_apd.Rdiv_low='10000'
goi_defaults.dcdc_apd.Rdiv_high='294000'
goi_defaults.dcdc_apd.VAPD_offset='3.0'
goi_defaults.dcdc_apd.VAPD_ext_inductivity='12'
goi_defaults.dcdc_apd.VAPD_ext_supply='3.30'
goi_defaults.dcdc_apd.VAPD_efficiency='50'
goi_defaults.dcdc_apd.VAPD_current_limit='2.00'
goi_defaults.transmitter=goi
goi_defaults.transmitter.TxEnableDelay='8'
goi_defaults.transmit_power=goi
goi_defaults.transmit_power.P0_0='180'
goi_defaults.transmit_power.P1_0='3820'
goi_defaults.transmit_power.P0_1='90'
goi_defaults.transmit_power.P1_1='1910'
goi_defaults.transmit_power.P0_2='45'
goi_defaults.transmit_power.P1_2='955'
goi_defaults.monitor=goi
goi_defaults.monitor.TiaGain_PL0='2'
goi_defaults.monitor.TiaGain_PL1='3'
goi_defaults.monitor.TiaGain_PL2='3'
goi_defaults.monitor.MPD_Calibration_PL0='3'
goi_defaults.monitor.MPD_Calibration_PL1='2'
goi_defaults.monitor.MPD_Calibration_PL2='2'
goi_defaults.monitor.ImodScalCorr_PL0='1.0'
goi_defaults.monitor.ImodScalCorr_PL1='1.0'
goi_defaults.monitor.ImodScalCorr_PL2='1.0'
goi_defaults.monitor.Dcalref0_PL0='3930'
goi_defaults.monitor.Dcalref1_PL0='4000'
goi_defaults.monitor.Dcalref0_PL1='1160'
goi_defaults.monitor.Dcalref1_PL1='1230'
goi_defaults.monitor.Dcalref0_PL2='1160'
goi_defaults.monitor.Dcalref1_PL2='1230'
goi_defaults.monitor.Dref0_PL0='180'
goi_defaults.monitor.Dref1_PL0='1910'
goi_defaults.monitor.Dref0_PL1='280'
goi_defaults.monitor.Dref1_PL1='2540'
goi_defaults.monitor.Dref0_PL2='200'
goi_defaults.monitor.Dref1_PL2='1270'
goi_defaults.monitor.PowerSave='1'
goi_defaults.monitor.rogue_onu_interburst='0'
goi_defaults.monitor.RogueAlarm_Threshold_P0='20'
goi_defaults.monitor.RogueAlarm_Threshold_P1='120'
goi_defaults.monitor.MPDxt_PL0='-1'
goi_defaults.monitor.MPDxt_PL1='-1'
goi_defaults.monitor.MPDxt_PL2='-1'
goi_defaults.monitor.Imodref_PL0='36.0'
goi_defaults.monitor.Imodref_PL1='18.0'
goi_defaults.monitor.Imodref_PL2='9.0'
goi_defaults.measurement=goi
goi_defaults.measurement.Tscal_ref='0.550'
goi_defaults.measurement.pnR='1.0'
goi_defaults.measurement.pnIsource='1'
goi_defaults.measurement.Supply_voltage_Enable='1'
goi_defaults.measurement.RSSI_1550_Enable='0'
goi_defaults.measurement.RF_1550_Enable='0'
goi_defaults.measurement.DAC_1550_Enable='0'
goi_defaults.measurement.RSSI_1490mode='1'
goi_defaults.measurement.RSSI_1490shunt_res='4990'
goi_defaults.measurement.RSSI_1490dark_corr='1.20'
goi_defaults.measurement.RSSI_1550vref='1'
goi_defaults.measurement.RF_1550vref='1'
goi_defaults.measurement.RSSI_1490scal_ref='0.07'
goi_defaults.measurement.RSSI_1550scal_ref='0.10'
goi_defaults.measurement.RF_1550scal_ref='0.10'
goi_defaults.measurement.RSSI_1490parabolic_ref='0.08'
goi_defaults.measurement.RSSI_1490dark_ref='0.002'
goi_defaults.measurement.RSSI_autolevel='0'
goi_defaults.measurement.RSSI_1490threshold_low='40'
goi_defaults.measurement.RSSI_1490threshold_high='70'
goi_defaults.measurement.Tbosa_source='1'
goi_defaults.measurement.Vdd_scal='0.5'
goi_defaults.measurement.V0K_Tref='1200'
goi_defaults.omu=goi
goi_defaults.omu.SignalDetectAvailable='1'
goi_defaults.omu.SignalDetectPort='2'
goi_defaults.omu.LolThreshold_set='20'
goi_defaults.omu.LolThreshold_clear='20'
goi_defaults.omu.LaserSignalSingleEnded='1'
goi_defaults.bosa=goi
goi_defaults.bosa.LoopMode='2'
goi_defaults.bosa.LolThreshold_set='20'
goi_defaults.bosa.LolThreshold_clear='20'
goi_defaults.bosa.LosThreshold_set='0.0005'
goi_defaults.bosa.LosThreshold_clear='0.0010'
goi_defaults.bosa.RxOverloadThreshold='0.2000'
goi_defaults.bosa.CInt_Bias_init='2'
goi_defaults.bosa.CInt_Mod_init='2'
goi_defaults.bosa.PICtrl='0x00004049'
goi_defaults.bosa.UpdateThreshold_Bias='2'
goi_defaults.bosa.UpdateThreshold_Mod='2'
goi_defaults.bosa.LearningThreshold_Bias='99'
goi_defaults.bosa.LearningThreshold_Mod='99'
goi_defaults.bosa.StableThreshold_Bias='2'
goi_defaults.bosa.StableThreshold_Mod='2'
goi_defaults.bosa.ResetThreshold_Bias='70'
goi_defaults.bosa.ResetThreshold_Mod='70'
goi_defaults.fcsi=goi
goi_defaults.fcsi.GVS='0xF653'
gpon.ploam=gpon
gpon.ploam.nPassword='0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20'
gpon.ploam.nT01='11000'
gpon.ploam.nT02='100'
gpon.ploam.nRogueMsgIdUpstreamReset='255'
gpon.ploam.nRogueMsgRepeatUpstreamReset='3'
gpon.ploam.nRogueMsgIdDeviceReset='255'
gpon.ploam.nRogueMsgRepeatDeviceReset='3'
gpon.ploam.nRogueEnable='0'
gpon.gtc=gpon
gpon.gtc.bDlosEnable='0'
gpon.gtc.bDlosInversion='0'
gpon.gtc.nDlosWindowSize='0'
gpon.gtc.nDlosTriggerThreshold='0'
gpon.gtc.ePower='0'
gpon.gtc.nLaserGap='0'
gpon.gtc.nLaserOffset='0'
gpon.gtc.nLaserEnEndExt='0'
gpon.gtc.nLaserEnStartExt='0'
gpon.gtc.nDyingGaspHyst='0'
gpon.gtc.nDyingGaspMsg='0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00'
gpon.gtc.nDyingGaspEnable='0'
gpon.gpe=gpon
gpon.gpe.nPeNumber='6'
gpon.gpe.nDSCP_MappingRule='0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 '
ieee_1588.ptp_sync=ieee_1588
ieee_1588.ptp_sync.delay_mechanism='-E'
ieee_1588.ptp_sync.network_transport='-2'
ieee_1588.ptp_sync.timestamping='-H'
ieee_1588.ptp_sync.cfg_file='/etc/g_8275_1.conf'
ieee_1588.ptp_sync.interface='lct0'
ieee_1588.ptp_sync.log_level='6'
ieee_1588.tod2phc=ieee_1588
ieee_1588.tod2phc.xpectd_mc_name='Intel PON TOD'
ieee_1588.tod2phc.xpectd_sc_name='Intel F24S'
ieee_1588.tod2phc.master_clock='/dev/ptp0'
ieee_1588.tod2phc.slave_clock='/dev/ptp1'
ieee_1588.tod2phc.offset='0'
ieee_1588.tod2phc.time_thr='20'
ieee_1588.tod2phc.sync_offset='-14'
ieee_1588.tod2phc.log_level='6'
ieee_1588.tod2phc.threshold='0.00002'
ieee_1588.tod2ktimer=ieee_1588
ieee_1588.tod2ktimer.xpectd_phc_name='Intel PON TOD'
ieee_1588.tod2ktimer.auto_cfg='-a'
ieee_1588.tod2ktimer.synch_sys_clk='-r'
ieee_1588.tod2ktimer.phc_clk='/dev/ptp0'
ieee_1588.tod2ktimer.domain_num='24'
ieee_1588.tod2ktimer.offset='0'
ieee_1588.tod2ktimer.log_level='6'
network.loopback=interface
network.loopback.ifname='lo'
network.loopback.proto='static'
network.loopback.ipaddr='127.0.0.1'
network.loopback.netmask='255.0.0.0'
network.globals=globals
network.globals.ula_prefix='auto'
network.lct=interface
network.lct.ifname='lct0'
network.lct.netmask='255.255.255.0'
network.lct.proto='static'
network.lct.macaddr='ac:9a:96:00:00:00'
network.lct.gateway='192.168.2.1'
network.lct.ipaddr='192.168.1.10'
network.host=interface
network.host.ifname='host'
network.host.proto='static'
network.host.ipaddr='0.0.0.0'
network.host.netmask='0.0.0.0'
network.host.macaddr='ac:9a:96:00:02:00'
network.host6=interface
network.host6.ifname='@host'
network.host6.proto='static'
nmea.message=nmea
nmea.message.nmea_format='1'
nmea.message.time_offset='19'
omci.default=omci
omci.default.mib_file='/etc/mibs/data_2g_8q.ini'
omci.default.status_file='/tmp/omci_status'
omci.iphost=omci
omci.iphost.enabled='1'
omci.iphost.committed='32000 2048'
omci.iphost.peak='32000 2048'
omci.iphost.color_aware='0'
omci.iphost.mode='0'
rpcd.@login[0]=login
rpcd.@login[0].username='root'
rpcd.@login[0].password='$p$root'
rpcd.@login[0].read='*'
rpcd.@login[0].write='*'
sfp_eeprom.default=sfp_eeprom
sfp_eeprom.default.eeprom='0'
sfp_eeprom.default.vendor_name='Lantiq'
sfp_eeprom.default.vendor_partno='Part Number'
sfp_eeprom.default.vendor_rev='0000'
sfp_eeprom.default.vendor_oui='AC:9A:96'
sfp_eeprom.default.serial_no='no serial number'
sfp_eeprom.default.datecode='150414'
sfp_eeprom.default.addr_eeprom_0='0x80'
sfp_eeprom.default.addr_eeprom_1='0x51'
sfp_pins.@pin[0]=pin
sfp_pins.@pin[0].name='tx_fault'
sfp_pins.@pin[0].pin='2'
sfp_pins.@pin[0].restriction='ASC_TX'
sfp_pins.@pin[1]=pin
sfp_pins.@pin[1].name='tx_disable'
sfp_pins.@pin[1].pin='1'
sfp_pins.@pin[2]=pin
sfp_pins.@pin[2].name='los'
sfp_pins.@pin[2].pin='3'
sfp_pins.@pin[3]=pin
sfp_pins.@pin[3].name='mod_def'
sfp_pins.@pin[3].pin='41'
synce.ethernet=synce
synce.ethernet.nSyncE_Mode='1'
synce.ethernet.bSyncE_SGMII_Squelch='0'
synce_pins.@pin[0]=pin
synce_pins.@pin[0].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[0].pin='43'
synce_pins.@pin[1]=pin
synce_pins.@pin[1].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[1].pin='44'
synce_pins.@pin[2]=pin
synce_pins.@pin[2].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[2].pin='43'
synce_pins.@pin[3]=pin
synce_pins.@pin[3].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[3].pin='44'
synce_pins.@pin[4]=pin
synce_pins.@pin[4].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[4].pin='43'
synce_pins.@pin[5]=pin
synce_pins.@pin[5].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[5].pin='44'
synce_pins.@pin[6]=pin
synce_pins.@pin[6].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[6].pin='43'
synce_pins.@pin[7]=pin
synce_pins.@pin[7].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[7].pin='44'
synce_pins.@pin[8]=pin
synce_pins.@pin[8].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[8].pin='43'
synce_pins.@pin[9]=pin
synce_pins.@pin[9].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[9].pin='44'
synce_pins.@pin[10]=pin
synce_pins.@pin[10].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[10].pin='43'
synce_pins.@pin[11]=pin
synce_pins.@pin[11].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[11].pin='44'
synce_pins.@pin[12]=pin
synce_pins.@pin[12].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[12].pin='43'
synce_pins.@pin[13]=pin
synce_pins.@pin[13].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[13].pin='44'
synce_pins.@pin[14]=pin
synce_pins.@pin[14].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[14].pin='43'
synce_pins.@pin[15]=pin
synce_pins.@pin[15].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[15].pin='44'
synce_pins.@pin[16]=pin
synce_pins.@pin[16].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[16].pin='43'
synce_pins.@pin[17]=pin
synce_pins.@pin[17].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[17].pin='44'
synce_pins.@pin[18]=pin
synce_pins.@pin[18].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[18].pin='43'
synce_pins.@pin[19]=pin
synce_pins.@pin[19].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[19].pin='44'
synce_pins.@pin[20]=pin
synce_pins.@pin[20].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[20].pin='43'
synce_pins.@pin[21]=pin
synce_pins.@pin[21].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[21].pin='44'
synce_pins.@pin[22]=pin
synce_pins.@pin[22].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[22].pin='43'
synce_pins.@pin[23]=pin
synce_pins.@pin[23].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[23].pin='44'
synce_pins.@pin[24]=pin
synce_pins.@pin[24].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[24].pin='43'
synce_pins.@pin[25]=pin
synce_pins.@pin[25].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[25].pin='44'
synce_pins.@pin[26]=pin
synce_pins.@pin[26].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[26].pin='43'
synce_pins.@pin[27]=pin
synce_pins.@pin[27].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[27].pin='44'
synce_pins.@pin[28]=pin
synce_pins.@pin[28].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[28].pin='43'
synce_pins.@pin[29]=pin
synce_pins.@pin[29].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[29].pin='44'
synce_pins.@pin[30]=pin
synce_pins.@pin[30].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[30].pin='43'
synce_pins.@pin[31]=pin
synce_pins.@pin[31].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[31].pin='44'
synce_pins.@pin[32]=pin
synce_pins.@pin[32].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[32].pin='43'
synce_pins.@pin[33]=pin
synce_pins.@pin[33].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[33].pin='44'
synce_pins.@pin[34]=pin
synce_pins.@pin[34].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[34].pin='43'
synce_pins.@pin[35]=pin
synce_pins.@pin[35].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[35].pin='44'
synce_pins.@pin[36]=pin
synce_pins.@pin[36].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[36].pin='43'
synce_pins.@pin[37]=pin
synce_pins.@pin[37].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[37].pin='44'
synce_pins.@pin[38]=pin
synce_pins.@pin[38].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[38].pin='43'
synce_pins.@pin[39]=pin
synce_pins.@pin[39].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[39].pin='44'
synce_pins.@pin[40]=pin
synce_pins.@pin[40].name='nGPIO_ExtPLL_LD'
synce_pins.@pin[40].pin='43'
synce_pins.@pin[41]=pin
synce_pins.@pin[41].name='nGPIO_ExtPLL_CF'
synce_pins.@pin[41].pin='44'
system.@system[0]=system
system.@system[0].timezone='UTC'
system.@system[0].hostname='easy98035synce1588'
system.ntp=timeserver
system.ntp.server='0.openwrt.pool.ntp.org' '1.openwrt.pool.ntp.org' '2.openwrt.pool.ntp.org' '3.openwrt.pool.ntp.org'
system.ntp.enabled='1'
system.ntp.enable_server='0'
BackON
Fri May 29, 2020 9:29 pm
dmesg log
ONTUSER@easy98035synce1588:/# dmesg
[    0.000000] Linux version 3.18.44 (buildmgr@AONT27) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 15.05_ltq) ) #1 Mon Aug 21 17:16:12 CST 2017
[    0.000000] SoC: Falcon rev A22
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 00019556 (MIPS 34Kc)
[    0.000000] MIPS: machine is EASY98035SYNCE1588 - Lantiq Falcon SFP Stick with SyncE/1588
[    0.000000] e=memsize=64
[    0.000000] e=initrd_start=0xA0000000
[    0.000000] e=initrd_size=0x0
[    0.000000] e=flash_start=0x00000000
[    0.000000] e=flash_size=0x0
[    0.000000] e=ethaddr=ac:9a:96:00:00:00
[    0.000000] MEMSIZE = 67108864
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 04000000 @ 00000000 (usable)
[    0.000000] User-defined physical RAM map:
[    0.000000]  memory: 03f00000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x03efffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x03efffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x03efffff]
[    0.000000] On node 0 totalpages: 16128
[    0.000000] free_area_init_node: node 0, pgdat 80361d50, node_mem_map 81009840
[    0.000000]   Normal zone: 126 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 16128 pages, LIFO batch:3
[    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16002
[    0.000000] Kernel command line: rootfstype=squashfs,jffs2 ip=192.168.1.10:192.168.1.100:192.168.2.1::::off ethaddr=ac:9a:96:00:00:00 machtype=EASY98035SYNCE1588 vpe1_load_addr=0x83f00000 vpe1_mem=1M mem=63M mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(linux),12288k(image1),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve) quiet console= console=ttyLTQ0,115200 init=/etc/preinit
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Writing ErrCtl register=00018252
[    0.000000] Readback ErrCtl register=00018252
[    0.000000] Memory: 59856K/64512K available (2858K kernel code, 145K rwdata, 564K rodata, 192K init, 199K bss, 4656K reserved)
[    0.000000] NR_IRQS:328
[    0.000000] Setting up vectored interrupts
[    0.000000] CPU Clock: 400MHz
[    0.032000] Calibrating delay loop... 265.98 BogoMIPS (lpj=531968)
[    0.036000] pid_max: default: 32768 minimum: 301
[    0.036000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.036000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.040000] pinctrl core: initialized pinctrl subsystem
[    0.044000] NET: Registered protocol family 16
[    0.056000] pinctrl-falcon pinctrl: Init done
[    0.064000] FALC(tm) ON GPIO Driver, (C) 2012 Lantiq Deutschland Gmbh
[    0.068000] Switched to clocksource MIPS
[    0.072000] NET: Registered protocol family 2
[    0.072000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072000] TCP: Hash tables configured (established 1024 bind 1024)
[    0.072000] TCP: reno registered
[    0.072000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.072000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.072000] NET: Registered protocol family 1
[    0.072000] RPC: Registered named UNIX socket transport module.
[    0.072000] RPC: Registered udp transport module.
[    0.072000] RPC: Registered tcp transport module.
[    0.072000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.072000] EASY98000 LED driver, Version 1.0.1 (c) Copyright 2013, Lantiq Deutschland GmbH
[    0.072000] Wired TLB entries for Linux read_c0_wired() = 0
[    0.072000] config3 0x2425 MT 1
[    0.072000] MVPControl 0x2, STLB 0 VPC 1 EVP 0
[    0.072000] mvpconf0 0xb8008403, PVPE 1 PTC 3 M 1
[    0.076000] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.076000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.076000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.076000] msgmni has been set to 116
[    0.080000] io scheduler noop registered
[    0.080000] io scheduler deadline registered (default)
[    0.080000] 1e100c00.serial: ttyLTQ0 at MMIO 0x1e100c00 (irq = 104, base_baud = 0) is a lantiq,asc
[    0.080000] console [ttyLTQ0] enabled
[    0.080000] bootconsole [early0] disabled
[    0.116000] m25p80 spi0.0: found mx25l25635e, expected s25fl129p0
[    0.116000] m25p80 spi0.0: mx25l25635e (32768 Kbytes)
[    0.116000] 11 cmdlinepart partitions found on MTD device sflash
[    0.116000] Creating 11 MTD partitions on "sflash":
[    0.116000] 0x000000000000-0x000000040000 : "uboot"
[    0.116000] 0x000000040000-0x0000000c0000 : "uboot_env"
[    0.116000] 0x0000000c0000-0x000000cc0000 : "linux"
[    0.144000] 2 uimage-fw partitions found on MTD device linux
[    0.144000] 0x0000000c0000-0x0000001fcedb : "kernel"
[    0.144000] 0x0000001fcedb-0x000000cc0000 : "rootfs"
[    0.144000] mtd: device 4 (rootfs) set to be root filesystem
[    0.144000] 1 squashfs-split partitions found on MTD device rootfs
[    0.144000] 0x0000006c0000-0x000000cc0000 : "rootfs_data"
[    0.148000] 0x000000cc0000-0x0000018c0000 : "image1"
[    0.148000] 0x0000018c0000-0x000001ac0000 : "configfs"
[    0.148000] 0x000001ac0000-0x000001dc0000 : "logfs"
[    0.152000] 0x000001dc0000-0x000001fc0000 : "extfs"
[    0.152000] 0x000001fc0000-0x000001fd0000 : "ri"
[    0.152000] 0x000001fd0000-0x000001fe0000 : "sfp"
[    0.156000] 0x000001fe0000-0x000001ff0000 : "ribackup"
[    0.156000] 0x000001ff0000-0x000002000000 : "reserve"
[    0.156000] wdt 1f8803f0.watchdog: Init done
[    0.160000] TCP: cubic registered
[    0.160000] NET: Registered protocol family 17
[    0.160000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    0.160000] 8021q: 802.1Q VLAN Support v1.8
[   12.212000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[   12.216000] Freeing unused kernel memory: 192K (80380000 - 803b0000)
[   14.852000] init: Console is alive
[   16.032000] pps_core: LinuxPPS API ver. 1 registered
[   16.032000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   16.032000] PTP clock support registered
[   16.944000] init: - preinit -
[   17.552000] jffs2: notice: (293) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   17.608000] jffs2: notice: (295) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   18.480000] random: mktemp urandom read with 72 bits of entropy available
[   21.728000] procd: - early -
[   22.440000] procd: - ubus -
[   23.448000] procd: - init -
[   24.856000] g_board_hw_version 87
[   24.856000] ri module install
[   24.860000] IFXOS, Version 1.6.9 (c) Copyright 2009, Lantiq Deutschland GmbH
[   24.948000] NET: Registered protocol family 10
[   24.956000] i2c /dev entries driver
[   24.964000] Custom GPIO-based I2C driver version 0.1.1
[   24.964000] i2c-gpio i2c-gpio.0: using pins 37 (SDA) and 38 (SCL)
[   24.968000] i2c_driver_major is 247
[   24.968000] This board has 1 i2c bus, 0 bus is expanded by PCA9554i2c driver install.
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_mac_mc_port_delete (err 0)
[   25.048000] kigmp: Unknown symbol onu_mod_open (err 0)
[   25.048000] kigmp: Unknown symbol netdev_rem_igmp_snooping_rx_callback (err 0)
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_filter_add (err 0)
[   25.048000] kigmp: Unknown symbol netdev_set_igmp_snooping_rx_callback (err 0)
[   25.048000] kigmp: Unknown symbol onu_mod_close (err 0)
[   25.048000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_filter_add (err 0)
[   25.048000] kigmp: Unknown symbol gpe_ext_vlan_get (err 0)
[   25.048000] kigmp: Unknown symbol gpe_table_entry_get (err 0)
[   25.048000] kigmp: Unknown symbol gpe_ext_vlan_set (err 0)
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_port_add (err 0)
[   25.048000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_port_add (err 0)
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_mac_mc_port_add (err 0)
[   25.048000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_port_delete (err 0)
[   25.048000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_port_delete (err 0)
[   25.052000] F24S Driver, Version 1.2.0
[   25.124000] Intel PON Chipset Optic Driver, version 7.6.2.0
[   25.132000] GPON SFP I2C Slave Driver, Version 2.4.0 (c) Copyright 2015, Lantiq Beteiligungs-GmbH & Co. KG
[   25.236000] [sfp_i2c] vpe code <sfp_i2c_vpe.bin> with size <3352 bytes> loaded!
[   25.236000] VPE loader: VPE1 running successfully
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_mac_mc_port_delete (err 0)
[   25.252000] kigmp: Unknown symbol onu_mod_open (err 0)
[   25.252000] kigmp: Unknown symbol netdev_rem_igmp_snooping_rx_callback (err 0)
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_filter_add (err 0)
[   25.252000] kigmp: Unknown symbol netdev_set_igmp_snooping_rx_callback (err 0)
[   25.252000] kigmp: Unknown symbol onu_mod_close (err 0)
[   25.252000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_filter_add (err 0)
[   25.252000] kigmp: Unknown symbol gpe_ext_vlan_get (err 0)
[   25.252000] kigmp: Unknown symbol gpe_table_entry_get (err 0)
[   25.252000] kigmp: Unknown symbol gpe_ext_vlan_set (err 0)
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_port_add (err 0)
[   25.252000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_port_add (err 0)
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_mac_mc_port_add (err 0)
[   25.252000] kigmp: Unknown symbol gpe_short_fwd_ipv4_mc_port_delete (err 0)
[   25.252000] kigmp: Unknown symbol gpe_long_fwd_ipv6_mc_port_delete (err 0)
[   25.636000] watchdog: add to proc fs ok
[   25.636000] Intel PON Chipset Base Driver, Version 7.6.2.0
[   25.660000] Intel PON Chipset Ethernet Driver, Version 7.6.2.0
[   25.664000] Registered Intel PON TOD PTP clock
[   25.700000] igmpdrv k_igmp_drv_init
[   25.700000] igmpmap IgmpMapFilterConfig IPTV Filter mode changed from 1 to 5
[   25.708000] igmpdb igmpdbthreadinit Enter DB create the thread.
[   25.724000] [onu] Now netdev have set Snooping Call Back.
[   25.724000] successfully insert igmp dev module
[   32.860000] random: nonblocking pool is initialized
[   41.888000] [onu] GPHY Firmware loaded into RAM (phy11g.bin)
[   42.416000] [onu] PE[255] firmware loaded v15.9.8.4
[   44.920000] [f24s]: Registered Intel F24S PTP clock
[   44.920000] libphy: Falcon MDIO: probed
[   44.936000] IPv6: ADDRCONF(NETDEV_UP): host: link is not ready
[   44.988000] [f24s]: lct0: Intel F24S Switch driver attached (irq=10).
[   44.996000] [onu_netdev]: onu_netdev_probe: connect to phy at falcon_mdio:1f
[   45.092000] IPv6: ADDRCONF(NETDEV_UP): lct0: link is not ready
[   45.996000] IPv6: ADDRCONF(NETDEV_CHANGE): lct0: link becomes ready
[   47.776000] IPv6: ADDRCONF(NETDEV_UP): lct0: link is not ready
[   48.068000] IPv6: ADDRCONF(NETDEV_UP): lct0: link is not ready
[   48.996000] IPv6: ADDRCONF(NETDEV_CHANGE): lct0: link becomes ready
[   64.016000] IPv6: ADDRCONF(NETDEV_UP): host: link is not ready
[   64.140000]
[   64.140000] Set board info type = 255
[   64.156000] Reset igmp snooping.
[   65.044000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.064000] igmpltq Cfg Vlan Action with itf:1 Error.
[   65.068000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.076000] igmpltq Cfg Vlan Action with itf:2 Error.
[   65.080000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.100000] igmpltq Cfg Vlan Action with itf:3 Error.
[   65.104000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.120000] igmpltq Cfg Vlan Action with itf:4 Error.
[   65.124000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   65.144000] igmpltq Cfg Vlan Action with itf:5 Error.
[   65.148000] igmpltq hal_kernel_cfg_mcast_vlan_action  There is no Gemport found for Mulitcast.
[   67.956000] get OperatorID=XXXX and start long time light status
fw_printenv
ONTUSER@easy98035synce1588:/# fw_printenv
a0_image=3FE46956AAAA_a0.bin
a2_iaddr=0x1FD0000
a2_image=3FE46956AAAA_a2.bin
act_img_addr=0xBF20003C
addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off
addmisc=setenv bootargs ${bootargs} ethaddr=${ethaddr} machtype=${machtype}  vpe1_load_addr=0x83f00000 vpe1_mem=1M mem=63M ${mtdparts} quiet
addmtdparts0=setenv mtdparts mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(linux),12288k(image1),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve)
addmtdparts1=setenv mtdparts mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(image0),12288k(linux),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve)
asc0=3
baudrate=115200
boot_image=run boot_image${c_img};
boot_image0=run kernel0_from_sf flashargs addip addmtdparts0 addmisc && bootm ${ram_addr}
boot_image1=run kernel1_from_sf flashargs addip addmtdparts1 addmisc && bootm ${ram_addr}
boot_image_err=setenv kernel_offs ${kernel0_offs};httpd && setenv image0_is_valid 1
bootargs=rootfstype=squashfs,jffs2 ip=192.168.1.10:192.168.1.100:192.168.2.1::::off ethaddr=ac:9a:96:00:00:00 machtype=EASY98035SYNCE1588 vpe1_load_addr=0x83f00000 vpe1_mem=1M mem=63M mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(linux),12288k(image1),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve) quiet
bootcmd=run flash_flash
bootdelay=5
c_img=0
commit=0
config_iaddr=0x18C0000
env_offs=0x40000
env_offs_redund=0x80000
ethact=RGMII1
ethprime=RGMII1
flash_flash=run select_image boot_image
flashargs=setenv bootargs rootfstype=squashfs,jffs2
gatewayip=192.168.2.1
goi_calibrated=1
goi_config=begin-base64 644 goi_config@H4sIAB8BAAACA+1YS0/bQBDOtfkVW3HICbPvR60eUh4VKi2IpOGAkLVxnGA1@jiPbofTfd5YEMHagVWmjlnouHs/szrevbzzrqAh30nkRhzuTNA4KO5xGwdTm@URZk0TgYguaF+VXrWYJBJOc3T5DqExOp7nQmRQsTRSVtIdzagCzywmYItY4/@9T/39k8fbZeladF6ebKF9lI0SwsUXtrZJELFZYT63+YRikfRrIjHcZS99n2/@7Wxvj7qwQsHp/oGzbKF+lMzR+YcLHx0Wl+h80QWttw/K2U7idAvxzvOLNsPG@Vx6X3DfUU4r5uN1q5O+Q6Cn+P5/6v8h/SRVu+P+P8T9p+P8y+H9l56NgOPpN@7P8J/pd0SRz/hcKy4f9m+D96wH/H8xXbB92TveDd3i3TfTSATwI6HzhCS58z@TzPdEPlF8R8y9h/AcLxWQjzKf8gALUIVkJ5QLBjwnxHW1P8bEdxQ4L/nf5jO@xvHkJgEs1c3ynzIu73IBJ9LxXzX3/81Ie7njCDYfdSbTdGinnfYr90VIZ2jX@TuNhZp3ej5MIVgoK/g7FRG9jvk1Yn+A3WPsoD7N4XqCB8qTHfXS82z1avhAf@HZyt1E77AVbmyo28YiygzogAcJFFy1q02mAUjsIAytNqP4iWJ3FRRNkjnmCe@fnXO26mdkACjDmNalWzY2YjClRhJOouLtNT5IxRGpbUJTo5crKf85IG/H9v3@Nl7ZyTo7fsROf4ADfnrv3wvtFGo2vBogFrjmIysf4XJtPzdwzNXafs5HiF7b@DwZCqFyPd+MTvOS7HyTRFftqgETIhxO/LpYODDdKjZmUimFdanKYpCP3C3M5@Pe5JSCkULhZG1HHdLhBVxwW7YboOSxysYQwuNZDZpDHrYF1Q40mitCYY1rAO@6zZL6DqsWx8pTR0XHNzDiigqqCj3vEeFJsbTWBuOBRHEVI9yZHMgVwJ3+9Lx@ymFv3P8eNy2uuYKOjBlcWqnTXu8wINzguc3sMJ3G4ar9miYjm325jQYZXQvO@DSVarQtXRtbcKEMFHClaGXWaLCqWYZrbimkc5vE9wvtBD2Jej6WAM9HcUhpp@pJFGavIdZGLmDgAcAAA=@====@
gphy0_phyaddr=0
hwconfig=RGMII1:phyaddr=31
image0_addr=0xB00C0000
image0_is_valid=1
image1_addr=0xB0800000
image1_is_valid=1
image_name=g010sb
import_uboot_env=env import -t ${ram_addr} ${filesize}
ipaddr=192.168.1.10
kernel0_from_sf=sf probe 0;sf read ${ram_addr} ${kernel0_offs} ${max_kernel_size}
kernel0_offs=0xC0000
kernel1_from_sf=sf probe 0;sf read ${ram_addr} ${kernel1_offs} ${max_kernel_size}
kernel1_offs=0xCC0000
load_kernel=tftpboot ${ram_addr} ${tftppath}${image_name}-uImage
load_uboot=tftpboot ${ram_addr} ${tftppath}u-boot.img
load_uboot_env=tftp ${ram_addr} ${tftppath}u-boot.env
load_uboot_env_y=loady ${ram_addr}
log_iaddr=0x1AC0000
magic_addr=0xBF200038
magic_val=0xDEADBEEF
max_kernel_size=180000
mtdparts=mtdparts=sflash:256k(uboot)ro,512k(uboot_env),12288k(linux),12288k(image1),2048k(configfs),3072k(logfs),2048k(extfs),64k(ri),64k(sfp),64k(ribackup),64k(reserve)
net_nfs=run load_kernel nfsargs addip addmtdparts0 addmisc;bootm ${ram_addr}
netconsole=set stderr nulldev;set stdin nc,serial;set stdout nc,serial
next_active=0
nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath},${nfsoptions}
nfsoptions=rsize=1024,wsize=1024
preboot=gpio clear 100
ram_addr=80F00000
reserve_iaddr=0x1FF0000
reset_uboot_env=env default -f -a; saveenv
ri_hiaddr=0x1FC0000
ri_image=3FE46956AAAA_ri.bin
ri_siaddr=0x1FE0000
save_uboot=sf probe 0;sf erase 0 40000;sf write ${ram_addr} 0 ${filesize}
select_image=if test -n $commit  ; then else setenv commit  _err;saveenv;fi;if test -n $image0_is_valid ; then else setenv image0_is_valid 1;saveenv;fi;if test -n $image1_is_valid ; then else setenv image1_is_valid 0;saveenv;fi;if itest *${magic_addr} == ${magic_val} ; then if itest *${act_img_addr} == 0 ; then setenv next_active 0;fi;if itest *${act_img_addr} == 1 ; then setenv next_active 1;fi;mw ${magic_addr} 0x0;mw ${act_img_addr} 0x0;fi;if test $next_active = -1 ; then setenv c_img $commit;else setenv c_img $next_active;if test $next_active != $commit ;then if test $next_active = 0 ;then setenv next_active 1;setenv image0_is_valid 0;setenv commit 1;else setenv next_active 0;setenv image1_is_valid 0;setenv commit 0;fi;saveenv;fi;fi;exit 0
serverip=192.168.1.100
start_netconsole=if test -n ${ncip}; then echo 'check for netconsole'; if ping ${ncip}; then run netconsole; echo 'netconsole enabled'; fi; fi
stderr=serial
stdin=serial
stdout=serial
update_A0=gpio clear 102;tftpboot ${ram_addr} ${tftppath}${a0_image};eeprom write 50 ${ram_addr} 0 ${filesize}
update_A2=tftpboot ${ram_addr} ${tftppath}${a2_image};sf probe 0;sf erase ${a2_iaddr} +${filesize};sf write ${ram_addr} ${a2_iaddr} ${filesize}
update_configfs=tftpboot ${ram_addr} ${tftppath}configfs.image;sf probe 0;sf erase ${config_iaddr} +${filesize};sf write ${ram_addr} ${config_iaddr} ${filesize}
update_image0=tftpboot ${ram_addr} ${tftppath}${image_name}-squashfs.image;sf probe 0;sf erase ${kernel0_offs} +${filesize};sf write ${ram_addr} ${kernel0_offs} ${filesize}
update_image1=tftpboot ${ram_addr} ${tftppath}${image_name}-squashfs.image;sf probe 0;sf erase ${kernel1_offs} +${filesize};sf write ${ram_addr} ${kernel1_offs} ${filesize}
update_logfs=tftpboot ${ram_addr} ${tftppath}logfs.image;sf probe 0;sf erase ${log_iaddr} +${filesize};sf write ${ram_addr} ${log_iaddr} ${filesize}
update_openwrt=run update_system
update_ri=tftpboot ${ram_addr} ${tftppath}${ri_image};sf probe 0;sf erase ${ri_hiaddr} +${filesize};sf write ${ram_addr} ${ri_hiaddr} ${filesize};sf erase ${ri_siaddr} +${filesize};sf write ${ram_addr} ${ri_siaddr} ${filesize}
update_system=run update_image0 && setenv commit 0 && setenv image0_is_valid 1 && saveenv
update_uboot=run load_uboot && run save_uboot
update_uboot_env=run load_uboot_env && run import_uboot_env && saveenv
update_uboot_env_y=run load_uboot_env_y && run import_uboot_env && saveenv
update_uboot_y=loady ${ram_addr} && run save_uboot
ver=U-Boot 2015.04-lantiq-gpon-1.3.7.1 (Aug 21 2017 - 17:12:42)
boot_fail=0
maybe can be compatible with
https://downloads.openwrt.org/releases/ ... pgrade.bin
BackON
Re: Usage GPON module SFP in Spain
Fri May 29, 2020 10:12 pm
Finally i got to the web acess to G-010S-B module user adminadmin password ALC#FGU
this is the web page only i can change SLID and password. all other command works like the g-010s-p tomorrow im going to test it in my gpon line
BackON
Sat May 30, 2020 3:35 pm
Hi again
G-010s-b doesnt work on ftth in spain maybe the missing synce? I going to try to disable it in the firmware and check it again.
Any suggestions?
JeanPierre
Mon Jun 08, 2020 10:07 pm
There have been several reports about new modules with Realtek chips: Ubiquiti UFiber-Instant, V-Solutions - V2801F and many more. I've updated my list of GPON modules.
viewtopic.php?f=3&t=116364&p=771961#p771961
Does anyone know the difference between RTL8672 and RTL9601C. I suppose RTL8672 is the main processor and RTL9601C is dedicated to GPON processing. All clones of modules with Realtek chip have the similar partition layout.
# cat /proc/mtd
mtd5: 004b0000 00001000 "r0"
mtd7: 004b0000 00001000 "r1"
mtd8: 00010000 00001000 "hw"
mtd9: 00010000 00001000 "sec"
mtd13: 004b0000 00001000 "rootfs"
Brief datasheet for V-SOL V2801F listed the RTL9601C as the main chipset.
https://www.vsolcn.com/1ge-sfp-onu-p00193p1.html
mgarcia
Sat Jun 13, 2020 2:53 pm
Dear all.
a few hours ago I ran Zisa with Tilera.
I have heard some comments that were incompatible and I can now confirm that it is certainly compatible.
You can browse my old post regarding the ZISA OP151S. I have made it work by changing only the firmware I mentioned earlier, modifying MAC, SERIAL NUMBER, LoID, and PLOAM PASSWORD / IDONT.
To connect to Zisa ONT:
- create a bridge without STP with ports where laptop connected and Zisa connected
- Add an IP in laptop LAN in 192.168.1.2 (f. Example)
- Connect Zisa ONT to the Fiber from ISP wait untill links UP. if till down after some time reeboot router with all connected.
- Type in webbrowser 192.168.1.1 user: admin pass: admin upgrade firmware mentioned on my last posts from web.
after updated: Make sure your Zisa fiber Link is UP. If not just wait a while or reboot router as mentioned.
- Telnet to 192.168.1.1
user: twmanu - pass: twmanu
- type "?" without wuotes for the menu options.
We just will need manufactory menu to work.
Enter to manufactory menu:
- type: "manufactoy" and press enter
"show ?" without quotes to show all options to check
"set ?" without quotes to show all options to set.
SERIAL NUMBER:
Inside Manufactory menu:
- type: "show sn" = shows Actual SN
- type: "set sn CCCCXXXXXXXX" with your serial number
confirm change with "show SN" command
LoID and Password:
inside Manufactory menu:
- type: "show ctc info" (shows actual info) in blank normally
- type: "set ctc loid XXXXXXXXXXXXXXXXXXXXXXXX" (in ASCII Format)
- type: "set ctc password XXXXXXXXXXXXXXXXXXXX" (20digit) without "0x"
If your Loid is in HEX just use one online HEX to ASCII converter.
confirm with "show ctc info" command
after all settings remove from created bridge SFP port and reboot router. ont will connect properly.
I hope all this settings would be fine for all ISP in spain.
After this you should add the corresponding VLAN/ PPPoE if needed from wour ISP in the SFP port to work.
Waiting for Zisa Users who can check this in the forum!
Kind regards!
iperezandres
Sat Jun 13, 2020 3:12 pm
This is great! Thanks for all the info and detail. My one and only question is: where can I buy a ZISA OP151S module? It seems to be out of stock in all the stores I checked...
Thanks.
mgarcia
Sat Jun 13, 2020 3:38 pm
Thanks.
I bought in Alibaba.
Kind regards,
BackON
Sat Jun 27, 2020 1:38 am
hello again
I got several SFP but im not able to connect (zisa op151s g-010s-a g010s-b dfp-34g-2c2) i put the slid on the zisa with the slid and serial but its stuck on 05 state in init.
y tested too the ZTE and the nokia module but im not able to connect. in g-010s-a says error from omci manager
My original ont is a g-010g-p only i have a HEX SLID and serial number
Sob
Wed Jul 15, 2020 4:10 pm
Out of curiosity, what's with the secrecy? You know, the "mail us if you want to know anything", instead of simply making the info public.
Come on people, do you really have to quote full posts? It's annoying and in most cases useless.
Petronas
Thu Jul 23, 2020 8:49 pm
Hello. :D
Here is Carlitos' stick. GPON ONU SFP (CPGOS03-0490 v2.0)
Memory processor photos and others Realtek RTL 9601 - Winbond 25Q64JVIQ
Many values can be modified via WebUI and Telnet
You can also change the serial number of the stick by Telnet
Very stable, The only annotation I see is the warm-up, but the same thing happens in other modules
:shock:
I recommend it, get in touch with CarlitoxxPro.
Good quality.
Regards.
JeanPierre
Thu Jul 23, 2020 10:07 pm
Hello. :D
:shock:
Good quality.
Regards.
Great post. Thank you for sharing all these photos with us. We see what is inside the stick :D
It seems CarlitoxxPro has put a lot of work into the module customization and testing to make sure it works with all popular OLT models.
JeanPierre
Fri Jul 24, 2020 4:59 pm
Hi Petronas
Can you share more about Realtek RTL9601C.
What does it display?
cat /proc/cpuinfo
cat /proc/mtd
Petronas
Sat Jul 25, 2020 1:57 pm
Here, drop this !!!
Hi Petronas
cat /proc/cpuinfo
cat /proc/mtd
vuducdong
Mon Jul 27, 2020 5:38 pm
I’m sent email to you but not reply ???
JacquesL
Mon Jul 27, 2020 6:08 pm
The system type is RTL8672 , so very similar to the CarlitoxxPro module. Have you tried to understand more? One can telnet to 192.168.1.1 ubnt/ubnt . Apparenly some of the parameters can be set using the flash command. I am wondering if there is a way to get it to work as well
JacquesL
Mon Jul 27, 2020 10:57 pm
Good quality.
Petronas, what user ID and password are you using? I can get the webpage to load on 192.168.1.1 or use telnet but cpAdmin/cpAdmin or cpUser/cpUser is not accepted. I'd like to be able to test the module after waiting so long :)
thank you
JacquesL
Tue Jul 28, 2020 6:13 pm
I've been able to make progress with the UFiber-Instant ONU module: it can definitely reach Operation State (o5) on the Movistar (Huwaei) ONT in Spain
However I had to go in the diag system and manually overwrite the PLOAM password, because the flash command limits the GPON_PLOAM_PASSWD to 10 characters in the settings that survive reboots. Still WIP ...
karman
Fri Jul 31, 2020 4:40 am
I received DFP-34X-2C2 and can confirm is working just perfect with pepephone ISP (S/N and Password).
Has anyone had any problem with this module or its twin DFP-34G-2C2 with other spanish ISP?
Petronas
Fri Aug 07, 2020 4:30 pm
Good quality.
thank you
As I said before you can change all the parameters and configurations, via web and telnet.and accept registration in OLT
Get in touch with carlitos, you will find the solution, with the most powerful complete device and support.
Don't waste your time anymore, you have the solution in your hand.
slarner
Mon Aug 10, 2020 3:17 pm
How did you go about accessing the SFP? Ive got it in a Mikrotik atm it just shows the module is present. Does it have an IP you can SSH to it on?
http://www.countybroadband.net
Provider of wireless broadband in Essex and Suffolk UK
vuducdong
Tue Aug 11, 2020 12:10 pm
Did you find the temperature of the SFP...?
msatter
Tue Aug 11, 2020 1:22 pm
Did you find the temperature of the SFP combined with the RB760igs too high when using it? It felt very hot, unable to touch it
viewtopic.php?f=3&t=132258&p=670687&hil ... nk#p671105
[IN READ-ONLY MODE]
Loving my freedom and so, no PayPal, no TikTok, no Meta/Facebook/Instagram/WhatsApp, no Apple and no Alphabet/Google, no Amazon/Cloudfront/AWS.
Running: RouterOS 7.6beta8 and 7.2.1 / Winbox 3.37 64bits
JacquesL
Fri Aug 14, 2020 11:42 pm
You were right Petronas. CarlitoxxPro helped me and the module is working perfectly with Vodafone fiber here in Madrid.
One gotcha, the VPN was not 100 but 24. There are apparently 2 types of connections for Vodafone.
JacquesL
Fri Aug 14, 2020 11:45 pm
The default IP is 192.168.1.1 . You need to add an address like 192.168.1.10/24 to your SFP module
Or you can use an SFP/Ethernet media converter and connect your computer to set it up
Vircurus
Sun Aug 16, 2020 2:48 pm
Hello. :D
:shock:
Good quality.
Regards.
hello, you can make a backup of the mtd blocks and put them here
Gnubyte
Wed Aug 19, 2020 3:25 pm
Hi all,
This thread is tremendous. Really.
I learned a lot of very acurate and exclusive things.
I ordered several kind of GPON SFP, and I will test it asap.
Gnubyte
Wed Aug 19, 2020 6:16 pm
I Just ordered a CCR2004-1G-12S+2XS
We will soon know if it is exactly adaptable.
Gnubyte
Thu Aug 20, 2020 3:30 pm
For information, I got a response from CalitoxxPro, apparently more reachable with FB Messenger. I'm waiting some news.
Gnubyte
Fri Aug 21, 2020 9:45 am
For information, I just paid a CarlitoxxPro GPON SFP ONU, they are available.
diablonet
Wed Aug 26, 2020 10:37 am
Hello I own some Zisa modules but after around 15 to 20 days, my mikrotik CCR1016-12S-1S+ (tile) get stuck and the only way to make it work again is by power cycle the mikrotik, have you experienced any issue?
Dear all.
SERIAL NUMBER:
LoID and Password:
Kind regards!
JacquesL
Wed Aug 26, 2020 10:43 am
I can confirm that CarlitoxxPro's module works perfectly with Vodafone and Movistar fibre. Getting the 600Mb/s symmetrical speed in both cases.
diablonet
Wed Aug 26, 2020 11:07 am
Hello all, according to this info:
=-=-=-=-=-=-=-= Chipset: Intel/Lantiq PEB98035 =-=-=-=-=-=-=-=-=-=-=-=-=
Zisa OP151S
Flash 8MB, RAM 64MB, System T&W Linux atop of OpenWRT 10_03 or 12_09
Pros - Good web interface. A lot of commands.
Cons - It may overheat. Security considerations - some firmware is pre-filled with TR-069 servers.
The firmware interchangeable beetween: T&W TW2362H-CDEL, Zisa OP151S, D-LINK DPN-100, Zyxel PMG3000-D20B, CM5671A, Eltex NTU-SFP-100, Calix 100-03903
I own a Zisa OP151S but after around 15 days it hangs my Mikrotik Tile CCR1016-12S-1S+ fw 6.40.9, I dont know if a fw update on mikrotik or a fw update on zisa may solve the issue, I customize the ont serial and password on the sfp gpon onu, so I need that feature, since the info says I can interchange the firmware with one of the following: T&W TW2362H-CDEL, Zisa OP151S, D-LINK DPN-100, Zyxel PMG3000-D20B, CM5671A, Eltex NTU-SFP-100, Calix 100-03903.
Is any of those replacement firmware support the customizations I require on the gpon serial and password? in order to use it with my mikrotik.
Any suggestion? thank you in advance
iperezandres
Wed Aug 26, 2020 11:41 am
I have O2 (movistar in the end) and I am having troubles making it work. I have an Alcatel ONT I240G-T, I have extracted its serial number from its label (ALCL...) and the PLOAM using telnet (F2018....).
I have followd CarlitoxxPro manual, but the PPPoE session does not connect.
I have the SFP interface on, the VLAN6 under that interface, and the PPPoE session over the VLAN6.
Any clue of what I might be doing wrong?
Thanks.
diablonet
Fri Aug 28, 2020 12:15 am
Hello JacquesL, in my country I have availability for the Ubiquiti U-Fiber Instant for 48 USD, much cheaper than the Carlitoxx, can you please share how did you managed to change some parameters via CLI? my ips just requieres SERIAL NUMBER (ALCLXXXXXXXX) and PASSWORD (less than 10 characters in ASCII MODE), maybe it runs for my purpose, thank you
iperezandres
Fri Aug 28, 2020 9:59 am
What ONT did you have before the change? I have an Alcatel i240g-t and I have been told that my provider (O2) needs to unblock the administrative state at the OTL so I can work with Carlitoxx SFP module. I have already made the request, but I don't really count on the provider doing it... Is there any other alternative?
pajal2006
Mon Aug 31, 2020 2:03 am
Iperezandres
Hi, I'm in the same situation as your iperezandres if you get something tell me. Thank you.
iperezandres
Mon Aug 31, 2020 4:34 pm
I am waiting for O2 to reply to my request about the administrative state, but not luck so far...
Gnubyte
Tue Sep 01, 2020 12:17 pm
Some news -
CarlitoxxPro ONU authentifies Orange FFTH to O5 with PLOAM and huawei profile BUT it is not recognized completely by the CCR2004, and it do not synchronize 2,5Gbps SFP side.
I follow my tests
CarlitoxxPro
Thu Sep 03, 2020 4:11 pm
Some news -
I follow my tests
Hi Gnubyte, as may you already know, that SFP only has 1GE, so links for more than 1Gbps is not supported by the interface. apart of that think that you are using an SFP into an SFP+ port the auto-negotiation can fail by an issue in the router software (ROS), you can find many issues related with that on the forum and on the internet,
if you check the Mikrotik SFP support table, there is mentioned this: https://wiki.mikrotik.com/wiki/MikroTik ... lity_table
did you tried to set manual link speed to 1Gbps full-duplex to the SFP+ port?
out of that, take in mind to than all devices of the link need to support and be configured to negotiate the full-duplex at 2.5G to the link be established successfully.
Related to the "is not recognized completely by the CCR2004", what is the issue that you observed?
can be related to this? viewtopic.php?f=3&t=165386
xoy74
Tue Sep 08, 2020 2:27 am
Thanks for your work on different GPON SFP modules.
I have a couple of MA5671A from Bell Canada. I can SSH into them at 192.168.1.10 but haven't been able to find any useful commands that could be used inside the SSH session. Are they documented anywhere that you know of ?
spaxton
Tue Sep 15, 2020 9:58 am
Hello guys,
I have tested so far:
ZISA OP151S
DFP-34G-2C2
DIPPER OPTICS D23446-SSHE
HUAWEI HG8010H (not SFP. Pure bridge device with one ETH port)
All of the tested resulted the same!
With all of these modules and HUAWEI device I can get O5 state for GPON and I can access the native VLAN on the ethernet which is dedicated for IPTV but no tagged traffic is coming out on the other side of the stick or LAN port of HG8010H. I tried to make a WAN interface on DFP-34G-2C2 with the same VLAN IDs and it could access it but making a pure bridge was never successful. This made me believe that there is some QinQ with the default VLAN ID so it works as a WAN interface on DFP-34G-2C2 or HUAWEI HG8245H but does not work if I try to access VLANs via mikrotik or any other managed network device. Other users experienced the same.
OR... Alll the above mentioned modules does not work in transparent mode.
Therefore, I believe, not even CarlitoxxPro latest stick will work if I don't find out what is the problem with these.
Can anyone help me out with this? I believe this may help others too.
Best Regards.
Gnubyte
Tue Sep 15, 2020 3:38 pm
Some news -
I follow my tests
When I set it non autonegociated 1Gbps Full Duplex, It runs in (R) state. But, Orange don't give the IP. I'm going to force the serial.
Even 1Gb FDX.
It can be related, so I added my vote.
pajal2006
Wed Sep 16, 2020 12:23 pm
Good, have you answered something in O2 ??? ... Movistar does not want to do it to me. I have the CarlitoxxxPro SFP of paperweight.
iperezandres
Wed Sep 16, 2020 12:34 pm
Pretty much the same here. I have talked quite some times to O2 but still they cannot figure out who should I be talking to. It is being escalated internally, but does not look good...
I am also talking to CarlitoXXPro because my GPON is always in O5 state, regardless of the PLOAM that I configure. I have confirmed with the O2 technician that the PLOAM I have is the correct one, but if I set a fake one, the GPON shows O5 anyway, so I am also wondering if the GPON is defective. No luck so far.
karman
Thu Sep 17, 2020 4:42 pm
Hello guys,
ZISA OP151S
DFP-34G-2C2
Best Regards.
Maybe I can help. I have the DFP-34X-2C2 (which is the same as DFP-34G-2C2 but supports both EPON and GPON). You should NOT create WAN connection. If you do it the SFP will act as a router. You should leave it without WAN connection to get bridge access and pass all VLANs to the attached device.
In my case my ISP provider offers internet in VLAN20, so I have to make sure that the SFP port accepts traffic from VLAN20 (virtual interface vlan 20?).
ranpha
Thu Sep 17, 2020 5:28 pm
Hello guys,
ZISA OP151S
DFP-34G-2C2
Best Regards.
Do you have to put VLAN information in 'Application ---> Multicast ---> VLAN Configuration' section? I have the exact same GPON stick but cannot connect to the Internet via PPPoE at all.
karman
Thu Sep 17, 2020 6:24 pm
Hello guys,
ZISA OP151S
DFP-34G-2C2
Best Regards.
Nope, works plainly. PPPoE is not a matter of the ONU but the router on it's proper virtual vlan interface.
spaxton
Thu Sep 17, 2020 9:38 pm
Hi, Many thanks for reply! I did everything like it should be. I have no WAN connections on the stick itself. However, if I try to add WAN connections then I am able to open all VLANs on the stick itself but when all WANs are removed, I am not able (mikrotik doesn't detect any VLAN tags) to access VLANs. It seems like it doesn't work as a bridge. Native (untagged traffic dedicated for IPTV) VLAN is available but no tagged traffic. If You know what to do, I will give You access to my PC and will pay You for a successful setup.
Best Regards.
ranpha
Fri Sep 18, 2020 7:08 am
Ok, so all I have to do is to put the OLT password in the SFP, and then put a VLAN interface on the SFP socket in routerOS, then run a PPPoE dialer on that VLAN interface?
IGMP snooping has to be enabled on the GPON stick?
valemal
Fri Sep 18, 2020 12:37 pm
Hey. You can help me? I configured my PON STICK ONU SFP module via telnet and killed the firmware. Can you give me the firmware?Image
spaxton
Fri Sep 18, 2020 2:41 pm
I am willing to pay for a successful setup for at least one of these devices:
DFP-34G-2C2
I need VLANs available in mikrotik. I know VLAN IDs, except DPOptics, other two can successfully register to OLT. With DPOptics I never achieved a successful registration to OLT.
All I get now is one untagged VLAN which is IPTV.
Is there anyone interested and willing to help?
Florian
Sat Sep 19, 2020 7:54 pm
So it's limited at 1g ? In France (and i guess others countries too) Orange, SFR, Bouygues, offer more than 1gb now, still on gpon tech.
- Sorry for my english -
wiper
Sun Sep 20, 2020 4:18 am
Hi, I bought the module "CarlitoxxPro GPON ONU SFP (CPGOS03-0490 v2.0)", I want to share some of my conclusions after doing many tests.
- It is not 100% compatible with all Mikrotik routers, as comrade Gnubyte commented, the module is not always detected by the router, you have to remove and reconnect the module several times until it works.
- The SFP module does not have a link until the fiber cable is connected, therefore it is not possible to configure it or check the status if the optical fiber fails, for example due to a damaged cable.
- The module status screen always indicates O5, it never changes.
- Needs to takes a long time to sync and connect with the OLT.
- Sometimes the module crashes, link is UP but not responding.
- It is not possible to do Port Forwarding, nor have I been able to receive RIP routing, I would say that the bridge does not work well.
It is not an easy task, but once connected and synchronized with the OLT, all the VLANs work and the transfer speed is correct.
In my opinion it does not work 100% well, I would not install it in a production environment, at the moment it is only valid for tests or as a paperweight.
If anyone is interested in buying this module, mine is for sale, contact me, we can surely reach an agreement.
Greetings.
spaxton
Mon Sep 21, 2020 9:54 am
Greetings.
You reported a lot of bugs for it. However, port forwarding should not be done on the module itself. This module should work as a pure bridge. For me will be enough if it works stable inside of the media converter cage. Send me Your offer in pm including shipping costs to Montenegro and a payment method.
By the way... Have You ever had a module which worked for You? Which one was it and how did You configure it? I offered to pay to the one who can make a working configuration with certain modules mentioned in this thread but nobody answered. It seems that nobody ever made it work or nobody wants money.
Best Regards.
karman
Tue Sep 22, 2020 2:49 pm
DFP-34G-2C2
Actually as the ONU SFP acts as bridge you should think of it as a TRUNK. All VLANs passthrough it to the 'next stage', in this case the router, so you should have one virtual interface per vlan.
I'm sorry but I'm no mikrotik expert, I'm unable to help yuo with the exact needed steps.
sotirone
Thu Sep 24, 2020 10:00 pm
Greetings.
I would like to buy the SFP. Please send me a PM. Thanks!
sotirone
Fri Sep 25, 2020 8:29 pm
Has anyone tried CarlitoxxPro's SFP with pfSense?
Is the OS important or not? Is there a driver that needs to be loaded?
Does it work with Mellanox 10Gb SFP+ adapters? (specifically the Mellanox ConnectX-3).
CarlitoxxPro
Tue Sep 29, 2020 5:37 pm
Greetings.
Hi wiper,
We have a few questions about all the issues that you are describing here:
1- Did you tested the GPON ONU SFP into a media converter (E.g: TPLINK MC220L) to discard that you have issues with your hardware(router) or with your unit(SFP)?, did you measure the voltages delivered to the SFP are inside recommended values? the issues reported by Gnubyte is related to well-known issues between SFP devices into SFP+ ports (also mentioned by Mikrotik). Related the SFP details displayed in winbox, that is related to viewtopic.php?f=3&t=165386&p=812901 (Again is not a SFP issue, is related to how was made the firmware of the router and how it reads the eeprom values)
2- Depend on the router model/brand the FO could be required to be connected to the router and be detected the link to make it possible to access to the SFP Web/Telnet. That is entirely dependent on how was designed the firmware of the router, not the SFP itself.
3- Witch OLT brand/model you are trying to connect?, if you have the SFP ONU connected to your router (at least 1 minute too boot the embedded OS) and after, you connect the FO to the SFP, the authentication time with the OLT should be in less than a few seconds. Can you explain detailed the steps that you follow?
4- In what scenario the SFP Crashes? What temperature, BIAS voltage have? with/whit out FO connected? can be more explicit with that.
5- The SFP works like a traditional ONT, is a fully bridge device L2. if you don't receive some specific traffic like IGMP for IPTV, did you check if all tripleplay services was correctly/fully provisioned from the OLT? That could be a bad provisioned profile from OLT, did you have more details from your ISP support team?
Please don't hesitate to contact us and provide all the details of your test and the information that you receive from your ISP, to diagnose better your issues.
Thanks and kindest regards.
Facebook: fb.me.com/CarlitoxxPro
Twitter: @CarlitoxxPro
Telegram: t.me/CarlitoxxPro
Email: contacto [at] carlitoxxpro.com
CarlitoxxPro
Tue Sep 29, 2020 5:45 pm
Hi ranpha,
Normally in the GPON ONU SFP is not required to enable "IGMP snooping" because their works as a full bridge L2 device, not work as router mode where you need to enable that feature, apart from the SFP only have one GE and that will be the only interface that will handle multicast traffic all the time.
Kindest Regards.
CarlitoxxPro
Tue Sep 29, 2020 6:07 pm
Hi sotirone we have several customers using our GPON ONU SFP with pfSense but with other pcie cards like CHELSIO COMMUNICATIONS 110-1120-40 10GBASE-X and some others use the BCM57810S NIC models doing some modifications on the card and in the software to enable the compatibility with SFP transceivers from 3rd party brands, not only HP or Dell. on internet you could find more details about that.
we not tested yet none of that cards by ourselves.
NOTE: We no promote any non-certified modifications and take no responsibility for any damages caused by this kind of modifications in a working hardware. all of that is under your on risk and responsibility.
if you are interested on acquire a GPON ONU SFP unit, please send to us an email, we are glad to attend you.
Kindest Regards.
Gnubyte
Thu Oct 01, 2020 7:42 pm
I have some news.
Carlitoxxpro connects O5, but CCR 2004 don't register it correctly.
I built a bridge with a Dell N20KJ dual SFP+, on a linux box, patched the linux kernel module, the other side of the bridge connected to the WAN port of the CCR2004 and the carlitoxxpro stick connects.
But, it's not 2.5 Gbps enabled, as far as I know.
If it could, it would.
Carlitoxxpro, if you have any telnet trick to enable 2.5Gbps synchro, you win.
CarlitoxxPro
Thu Oct 01, 2020 9:22 pm
I have some news.
Hi Gnubyte
as may you already know the GPON ONU SFP transceivers only have 1GE (Physically) and only are capable to negotiated data-rates up to 1Gbps (1.25 theoretically) on the Ethernet side (LAN) even if they are capable to work up to 2.5Gbps (for downstream) on the optical side (PON) as described on the GPON Standards.
In the traditional ONUs (ONT or HGU) is possible to take the advantage of the 2.5Gbps data-rates (downstream speeds) because they have multiple GE interfaces (Physically) but even in this case, each Ethernet is only capable to work at 1Gbps.
Now, in the XG-PON, XGS-PON and NG-PON2 technologies are being designed transceivers over SFP+ interfaces to makes capable to work with Multi-GE interfaces on the Ethernet side also.
So, there not exist "magic tricks" to change that, I've recommend you to take a look at the standard definitions (IEEE 802.3ab - 1000Base-T) and (IEEE 802.3ae - 10GBase-xx) to understand better how it works.
Kindest regards.
Gnubyte
Sun Oct 04, 2020 5:56 pm
Hi Gnubyte
Kindest regards.
Hi CarlitoxxPro,
Your ONU SFP is functional. It does what it was proposed for, inserting itself into an SFP or SFP + interface and directly connecting the physical link by optical fiber, by registering itself in a GPON tree. Within this perimeter, it is functional, 100% useful. It does what I bought it for. As such, it remains in my collection of ONU SFP (because I have, in fact, some)
But, and this is not your responsibility, it is not recognized by the Mikrotik CCR2004. This is sad. Whether we raise the question of activation at 2.5Gbps according to HGSMII, the question does not seem to arise with your ONU because, beyond the desire to activate it at 2.5Gpbs, the Mikrotik CCR2004 does not even recognize it . No doubt this is related to the reasons you cited in your feature request for which I voted for.
So, strictly from a business point of view, I am a happy customer. However, I cannot insert it into my Mikrotik equipment.
I do not hide that my main quest, to connect my fiber link directly without operator equipment, is linked to my desire to have the second Gbps that I pay to Orange France, but that the equipment does not allow me to use.
To achieve my goals, I needed to connect my fiber to an SFP interface, and your CarlitoxxPro does it, but not on my CCR2004.
If I have not been able to directly connect the CarlitoxxPro to my CCR 2204, which, I repeat, only understands 1 or 10Gbps, I installed, in a small low power server, a Dell N20KJ chipset card BCM57810S, dual SFP +, and I configured a bridge between the two. My fiber therefore arrives in my CarlitoxxPro, bridged to a 10Gbps SFP Single-mode Fiber interface, and this 10Gbps link is routed in my CCR2004 which takes care of the particular authentication of Orange France from my home (question of DHCP requests in COS = 6).
This is the reason why I affirm that my CarlitoxxPro module is functional, with PLOAM filled in and SN changed.
It is probably up to Mikrotik to include the right Linux kernel module patches to directly integrate the possibility of inserting the CarlitoxxPro directly. Unfortunately, there is no possible activation of 2,5Gbps by HSGMII on CCR 2004, according to the feedback I received from support after my bug report on the beta version which crashed by checking the 2.5Gbps box (yet present), for reasons described as material at this time.
With the 10Gbps bridge that I put in place, I broke away from the Linux kernel module types of CCR, to use a much more up-to-date 5.8 kernel on the bridge, and provide CCR 2004 with what it gladly accepts, a flow in a 10Gbps fiber optic link.
Now, thanks to this bridge, I can certify that the CarlitoxxPro works, and since it is only one of my almost eclectic collection, I have others that work. I don't have any at 2.5Gbps yet, as they are rare, but since some are known to be compatible, I won't be long. I will then only have to configure them on my workstation, which is also equipped with a BCM57810S card, then place them on the bridge, to achieve my goals. And the day the XGsPON fiber is deployed, I would only have to change the ONU.
sotirone
Tue Oct 06, 2020 8:08 pm
Hi, I have compiled a list of popular GPON modules. Let me know if I missed something or made a mistake.
=-=-=-=-=-=-=-= Chipset: Intel/Lantiq PEB98036 =-=-=-=-=-=-=-=-=-=-=-=
FGS202
Flash 8MB, RAM 1MB, System RTOS eCos
Pros- Quick start
Cons - Flash programming/soldering required for SN/Password change. It may overheat. No graphical web interface.
MA5671A
Flash 16MB, RAM 64MB, System OpenWRT
Pros - Good compatibility with Huawei and third-party vendors. Highly configurable through commands.
Cons - Hardware adapter and soldering required for full shell. No graphical web interface. Change SN/Password via command line.
G-010S-P
Pros - Good compability with Alcatel/Nokia. Web interface. Highly configurable through CLI commands
Cons - IPTV may not work with third-party vendors.
CarlitoxxPro CPGOS03-0490 / HL23446
Pros - Good web interface. Several vendor profiles. Highly configurable through CLI commands. Supports LOID
The firmware is interchangeable between: Source Photonics SPS-34-24T-HP-TDFO, Huawei MA5671, Alcatel G-010S-P, Hilink HL23446, CarlitoxxPro CPGOS03-0490, Dasan H650SFP, DpOptics D23446
LAN interface can be switched from 1 Gbps to 2.5 Gbps(sgmii_mode variable is set to 5)
G-010S-A
Pros - Good compability with Alcatel/Nokia. Web interface. Highly configurable through commands. Capable of 1Gbps or 2.5Gbps LAN mode. Web GUI.
Cons - IPTV may not work with third-party vendors, for some routers soldering pin#6 to ground is required (info on dslreports forum - CanadaBell BCM57810S NIC)
What is the difference between G-010S-P and G-010S-A? Their specs seem identical so the G-010S-A should be compatible with the firmware the G-010S-P is compatible, no?
Also, what about the Nokia G-010S-B? Does anyone have any idea if it can be flashed with CarlitoXXPro's firmware? Maybe BackON can provide some more info on the G-010S-B?
Hello
I have another sfp gpon module from Nokia. The model is G-010s-B
Edit: Also, can somebody provide me with the CarlitoXXPro SFP manual? I want to have a look at what settings are available to see if it is compatible with my weird EPON ISP.
JeanPierre
Wed Oct 07, 2020 4:16 am
G-010S-P - older hardware design
G-010S-A - current Nokia GPON 1310nm/1490nm module
G-010S-B - GPON module with 1588v2 & SyncE support (use case: mobile networks backhaul)
Keep in mind that two modules were/are available in Carllitos's offer
original based on Lantiq 98035 and v2.0 based on Realtek RTL9601C/RTL8672
Gnubyte
Wed Oct 07, 2020 8:39 am
(Hi JeanPierre)
If anybody have any spare, I'm buyer of a lantiq based Carlitoxxpro v1 or an Alcatel-Lucent G-010S-P.
Sotirone, PM me for the manual.
Gnubyte
Wed Oct 07, 2020 9:39 am
JeanPierre, do you have expérience about O-010S-P ?
sotirone
Wed Oct 07, 2020 2:36 pm
So can the G-010S-B be used for FTTH GPON/EPON or is it using different standards?
JeanPierre
Wed Oct 07, 2020 3:26 pm
Not personally, very little info about this Broadcom GPON module
https://rsaxvc.net/blog/2020/8/21/Alcat ... rdown.html
JeanPierre
Wed Oct 07, 2020 3:43 pm
Not by an ordinary user. It is intended for mobile network operators. It requires a specialized router, an accurate clock source and the documentation from the vendor.
jangdong
Sun Oct 11, 2020 2:03 am
hi, @JeanPierre
How to change LOID and LOId password for G-010S-A or 010S-P?
JeanPierre
Mon Oct 12, 2020 5:11 pm
hi, @JeanPierre
In Canada and most of Europe the serial number is the basic method of authentication. LOID is more popular in Asia.
The firmware we have may not have LOID enabled. Check your variables: ONTUSER@SFP:~# fw_printenv to see if you have something that resembles a LOID
DFP-34G-2C2, HL23446, D23446, V2801F, BD-1234-SFM modules are a much better choice if you are looking for LOID support.
Nokia or Alcatel-Lucent are known for adding proprietary extensions to the OMCI stack. They do not use the OMCI daemon that comes with the SDK, instead they rely on their own All-in-One OMCI_MGR_Bin.
If you really want to use G-010S-P or G-010S-A remember that this can cause problems in obtaining an IP address if OLT is not Nokia or Alcatel. One of the users had to modify the startup script to work with OLT from another manufacturer.
viewtopic.php?f=3&t=116364#p760625
Always back up your mtd partitions before modifying SFP scripts!
For G-010S-A to allow future recovery access
root@SFP:/# fw_setenv bootdelay 5
root@SFP:/# fw_setenv asc0 0
root@SFP:/# fw_setenv preboot
Gnubyte
Mon Oct 12, 2020 5:43 pm
Hi JeanPierre,
Your personal preferences dont let people leave you any MP. Of course you should know that.
Could you post whatever firmware backups you have? This would be useful, mainly for interface models that are no longer manufactured.
Many thanks for your advices.
JeanPierre
Mon Oct 12, 2020 5:48 pm
Hi JeanPierre,
Sorry Gnubyte but I was receiving so much spam. Had to disable MP. I don't many backups. Let me check and I let you know in couple days(busy at work)
jangdong
Wed Oct 14, 2020 1:22 am
hi, @JeanPierre
Dear JeanPiere,
G-010S-A has the same firmware with G-010S-P or SOURCEPHOTONICS_SPS3424THPTDFO ?
and I see 2 command line (Related to LOID and LOID password):
fw_setenv omci_loid xxxxxxxxxxxxx
fw_setenv omci_lpwd xxxxxxxxxxxx
can be used in the ssh of G-010S-A but command (uci commit) cann't use, I don't know why.
is it any different than when using with fw_setenv omci and uci set?
Thanks for help.
sotirone
Thu Oct 15, 2020 9:14 am
Hello, has anyone played around with U-Fiber Instant? I need it for EPON but from what I can see it does not support it. Has anyone tried to flash it with other firmware? What firmware could it be flashed with?
torkue
Thu Oct 22, 2020 5:48 pm
Thanks Mett for sharing your experiance!
Do you might know if the CarlitoxxPro SFP Module supports 2,5Gbps (HSGMII Mode) in any combination with any Mikrotik router or switch?
As it is said Deutsche Telekom provisioning 1100 Mbits/s in the 1G plan, it might be worth a try push the line to it's limits and remove the 1G LAN (940mbps) "bottleneck" from the external ONT.
I've currently the previous ONT from Telekom (Huawei 8010u), but I expect the process of cloning the S/N to the SFP would be very similar.
CarlitoxxPro
Fri Oct 23, 2020 1:19 pm
The GPON ONU SFP works in SGMII mode, and only have 1GE (1.25gbps),
Also Mikrotik doesn't support SFP at 2.5Gbps in their routers/switches by the moment. even if you connect into the SFP+ ports an SFP transceiver.
BackON
Tue Oct 27, 2020 10:40 pm
Hello Im having issues with some SFP module (my isp is movistar only checks serial and ploam password)
Zisa OP151s i configure the serial number and password but its Stuck in O5 State
G-010S-A i cant change serial number and the password how i can change it?
DFP-34G-2C2 im having issues with the SLID because says that is wrong. where i set the ploam password? in GPON serial number password or in the SLID password module? i cant set hex mode and to ascii converted hex the password.
what are the SLID ID and default password when there are no checks?
I have another SFP module (technicolor AFM0002tim)
jangdong
Sun Nov 01, 2020 4:45 am
hi, @JeanPierre
"DFP-34G-2C2, HL23446, D23446, V2801F, BD-1234-SFM modules are a much better choice if you are looking for LOID support." and
"Nokia or Alcatel-Lucent are known for adding proprietary extensions to the OMCI stack. They do not use the OMCI daemon that comes with the SDK"
If I want to be compatible with Alcatel OLT , will these SFPs have to use the OMCI stack, right?
piku
Thu Nov 12, 2020 12:12 pm
Hi Gnubyte
Kindest regards.
Hi CarlitoxxPro,
I don't think it can work on a SFP+ port (except Mikrotik CRS). Please try SFP port and auto negotion to 1Gbps (no 1.25G)
sotirone
Thu Nov 12, 2020 8:14 pm
I ordered and I am currently waiting for my CarlitoXXPro SFP ONU to arrive. Can you help me clear some things out?
First of all, I am using a Brocade ICX6450 switch and a pfSense router. The ONU is going to be plugged into the Brocade switch so that it acts as a media converter.
My ISP uses EPON. I am not sure yet how the authentication takes place.
The ISP router has a single fiber physical interface. On that interface, they run a bridge (that has no IP address) and 3 virtual interfaces.
The virtual interfaces are:
1. TR_069 on VLAN 0 (probably meaning LAN). MAC address: XXXXXXXXXXXX
2. INTERNET_VLAN on VLAN 303. MAC address XXXXXXXXXXXY
3. VoIP_VLAN on VLAN 304. MAC address XXXXXXXXXXXZ
My thinking:
I am going to plug the ONU in an SFP port on the switch which will be tagged for VLANs 303 and 304 and untagged for a random VLAN (1000) so that it does not communicate with other devices on the LAN (VLAN 1).
The pfSense will have 4 ethernet interfaces connected to the switch. One will be LAN, one will be on an untagged VLAN 303 port, one on untagged VLAN 304 port and the last one untagged for VLAN 1000. I cannot use a single "WAN" interface with VLANs on it on pfSense because it does not have the ability to set up VLANs with MAC addresses different to the physical interface MAC and I don't want my ISP to see that the MAC addresses changed.
The pfSense interface that will be on untagged 303 port will receive a public IPv4 DHCP address.
The pfSense interface that will be on untagged 304 port will receive a private IPv4 DHCP address that the ISP uses for VoIP.
The pfSense interface that will be on untagged 1000 port will receive a private IPv4 DHCP address that the ISP uses for TR_069 (regardless that TR_069 will be off on pfSense).
Questions:
1. What IP address should I set on the ONU for LAN?
2. How will pfSense be able to communicate with the Web interface on the ONU? Will I have to set a second static IP address on the untagged 1000 interface to be able to connect to the ONU Web interface?
3. Let's say I set 192.168.55.1/24 as a static IP on the ONU for LAN and a second (static this time) IP for the pfSense interface connected to untagged port 1000 at 192.168.55.2/24. Will my ISP be able to see these two addresses on their private (TR_069) network?
4. Is there or should there be a management VLAN option on the Carlito SFP so No.3 would not be of a concern?
almeiras
Mon Nov 16, 2020 11:41 pm
Restoration instructions I copied from here
https://forum.openwrt.org/t/support-ma5 ... n/48042/17
Hello JeanPierre, I'm back in action. I managed to connect the UART to my computer, but I get no shell prompt, just some console messages (see attached pic). How can I insert the commands that appear in the instructions ("FALCON => sf probe 0"...) in the prompt and perform the kermit transfers? Thank you!
One more question: is there any newer/better version for the firmware? I'm trying to restore the original 12.09, but I previously had no luck modifying variables, and my ISP's OLT kept rejecting me.
CarlitoxxPro
Tue Nov 17, 2020 12:26 am
My thinking:
Questions:
Hi sotirone,
The VLAN interfaces share the same MAC address from the physical interface so, you don't need to assign different MAC addresses or use separated ethernet interfaces for each VLAN, apart from that you don't need to TAG/UNTAG the VLANS in your switch , if you want to isolate the SFP port and the ethernet port (WAN) in your switch you can use "Port Isolation" feature that makes than the traffic of these ports are not being shared with the rest of the ports of the bridge.
apart from that, as we describe in the configuration manual, the VLANs and the connection types (PPPoE or IPoE) should be managed in the router because the GPON ONU SFP works in fully transparent mode, so the VLAN tags will pass through the SFP directly to your router, your switch should only work as a bridge (or media converter) between the fiber line and your router.
Kindest Regards
sotirone
Tue Nov 17, 2020 11:48 am
Hi sotirone,
Kindest Regards
No, the VLAN interfaces on the ISP provided router do not share the same MAC address with the physical interface. They are set up with the last digit being different. That is why I want to assign different MAC addresses per VLAN on pfSense, so that there is no obvious change to the ISP after I remove their router.
The switch will work only as a bridge but I need to pass the different VLANs to different ports so that pfSense can have an interface on every VLAN with the respective MAC address.
Never mind that, my main concern is that your SFP is programmed to give its bridge interface an IP address. Since there is no firewall or NAT between the ISP's internal network and your SFP, the ISP could see that IP address with an ARP scan and try to access it. That will reveal the existance of the SFP on the network, something that many ISPs will not like.
I think the bridge interface on the SFP should have no IP address and instead have the option of a management VLAN so that we can have access to the SFP without exposing it to the ISP's internal network.
Also, is there an option to change the bridge interface MAC address on the SFP? Because your manual is not very helpful.
kbzajunior
Tue Nov 17, 2020 4:37 pm
Hi from Spain!
¿How to write PLOAM PASSWORD if via telnet is limited to 10 characters? ¿What mean diag system on UF-Instant? Thanks!
CarlitoxxPro
Fri Nov 20, 2020 2:13 am
Hi sotirone,
Kindest Regards
Hi sotirone, the administrative IP address of the GPON ONU SFP is only exposed to the LAN side (SFP), not to the PON side, this is not reachable from the Internet VLAN. also, this is a password protected webservice.
You need to know that all ONU/HGU have 2 MAC addresses (or more): 1 for the PON Side and the other(s) are for the GE/VLAN (LAN Side).
So here are the only reasons for what you should mimic these MAC addresses:
1- PON Mac: If the OLT has enabled the MAC filtering to avoid rogue ONT/HGU. (rarely used by the ISPs).
2- GE/VLAN Mac: if you have static IP contracted, these MAC addresses should be configured in your router side where is running the DHCP or PPPoE client whos negotiating the connection. (in this case not in the SFP because it works in L2 as a traditional ONU)
apart from that you ISP always will know that you changed his HGU/ONT, because are different hardware/software devices, the TR069 (For Administration) will no longer available for him and they already know via OMCI what are the details of the ONU.
The MAC address in the GPON ONU SFP can be modified but that is not a common thing required for work with the GPON ONU SFP and most of ISP, so, for this reason, we did not explain more complex configurations in the "Basic Configuration Manual".
We recommend you to read more about the GPON Standard to understand better his basics.
https://www.itu.int/rec/T-REC-G.984.1
https://www.itu.int/rec/T-REC-G.984.2
https://www.itu.int/rec/T-REC-G.984.3
https://www.itu.int/rec/T-REC-G.984.4
Kindest Regards.
dmfr
Wed Nov 25, 2020 3:40 pm
May I ask on any progress you made on this device ? (if still around)
I found several limitations with this module myself :
- OMCI daemon (omci_app) seem heavily UBNT customized, it actively forces GPON_SN upon launch. Can override with diag (gpon set serialnumber) but won't survive reboot.
- GPON_PLOAM_PASSWD > 10 chars requires diag override as well (gpon set password)
- even more disappointing, OMCI daemon crashes upon gpon onu-state reaches O5.
I suspect UBNT omci_app custom "extensions" makes it incompatible with Nokia / Alcatel / Huawei /... OMCI negociation.
That leaves OMCI stack incomplete so no chance any traffic can go through.
Don't know how to change profile if that's even possible.
As last report i will try eventually to "flash set" all MIB_TABLE values copied from a working V2801F (same RTL8672 chipset).
Not too much hope though, limitations are likely hardcoded into ubnt's omci_app.
It won't solve the GPON_SN override either...
raffav
Sun Nov 29, 2020 7:51 pm
How you get the password used in the ont?
I have ffth in Brazil and I'm trying to figure out how to replace the ont but but I guess it's almost impossible since I don't have any authentication used and any passwords
Sent from my Moto Z3 Play using Tapatalk
almeiras
Mon Nov 30, 2020 4:45 pm
Hello again!
So I managed to open my bricked (Nokia) Alcatel-Lucent G-010S-P. I found four empty pads on the board, hopefully the UART pins that I am looking for. Now, I have two questions:
  • Does anybody know the correct pinout? At least, can anybody confirm if these are the UART pins I am looking for?
  • Which soldering iron should I get for this kind of miniature soldering?
Thank you very much for your help!
Hello almeiras
The UART contacts I am aware of are connected to pins 2 and 7. On the openwrt forum, bmx39 and minhng99 shared photos of their adapters.
https://forum.openwrt.org/t/support-ma5 ... n/48042/24
Restoration of the G-010S-P module is simple. After connecting the adapter, just send the mtd2 and mtd5 firmware from the u-boot level. Our u-boot is factory unlocked. We don't have to jump over obstacles like the owners of the MA5671A module. Remember not to destroy the mtd1 partition that contains the u-boot variables calibrated for this module.
Original firmware 12.09
https://github.com/minhng99/alcatel_luc ... master/mtd
#transfer image mtd2 by Kermit into memory
FALCON => loadb
## Ready for binary (kermit) download to 0x80800000 at 115200 bps...
#to write mtd2(image0)
sf probe 0
sf erase C0000 740000
sf write 80800000 C0000 740000
#transfer image mtd5 by Kermit into memory
FALCON => loadb
#to write mtd5(image1)
sf probe 0
sf erase 800000 740000
sf write 80800000 800000 740000
@JeanPierre I tried everything, but I can't get a u-boot prompt like you ("FALCON =>"), just some messages regarding version and RAM. Do I have to press any specific key during the startup process? I triple-checked the Rx physical connection and seems OK. Thank you.
Markg23
Mon Nov 30, 2020 5:04 pm
Hello Almeiras,
I think the module behaves like the Huawei MA1567A, if the bootloader is locked (like seems to me is your case) you need to short the flashchip (pins 4 and 5) during bootup to stop boot process and to show boot menu.
see this post: https://forum.openwrt.org/t/support-ma5 ... n/48042/24
JeanPierre
Mon Nov 30, 2020 11:22 pm
Hello, sorry for the late response, I was busy these days.
Please try keys Ctrl+C during the startup process.
almeiras
Tue Dec 01, 2020 1:00 pm
Awesome, thank you @JeanPierre, that did it. I don't know how you guys know such things, I looked everywhere in the Internet.
I'll post when I upload the fw. For now, I leave you this pic to clarify the pinout even further for noobs like me. The module is on the right, and the observer has to watch from the bottom.
almeiras
Thu Dec 03, 2020 11:09 pm
Hello Almeiras,
Thank you @Markg23, but no short needed, Nokia Alcatel-Lucent is factory unlocked.
@JeanPierre, IT WORKED!! My SFP is back to life! It was confusing trying to connect via "screen" and "kermit" alternative, but I did it thanks to your help and this tutorial for the kermit client part: https://openwrt.org/docs/guide-user/ins ... ing.serial
Last time I messed up because I was desperate with the stock firmware (some variables in the GUI, others in the CLI, different files and commands). Now I hope I don't mess up again. I'll go more carefully.
JeanPierre
Fri Dec 04, 2020 12:56 am
Nice to hear that you brought SFP back to life :) Lantiq modules are almost impossible to break. Besides, we have an openwrt and microtik forum with a lot of useful information, shared by so many enthusiastic users!
almeiras
Fri Dec 04, 2020 1:27 am
@JeanPierre, I came up with the same problems I got before bricking it: can't find nSerial and nPassword because no value matches the expected lenght. This is the GPONCFG.txt I obtained from my ZTE F680 from YOIGO Spain (masmovil):
<Tbl name="GPONCFG" RowCount="1">
	<Row No="0">
		<DM name="ViewName" val="IGD.GPON" AccessAttr="0"/>
		<DM name="Vendor_ID" val="ZTEG" AccessAttr="0"/>
		<DM name="Vendor_Specific" val="xx:xx:xx:xx:xx:xx" AccessAttr="0"/>
		<DM name="Loid" val="XXXXXXXXX" AccessAttr="0"/> # 9 chars, I thought it had to be 10
		<DM name="LoidPwd" val="XXXXXX" AccessAttr="0"/> # 6 chars, another password, what the heck is this?
		<DM name="LoidState" val="0" AccessAttr="0"/>
		<DM name="Password" val="XXXXXXXXX" AccessAttr="0"/> # Come on, another password, 9 chars, different than Loid.
		<DM name="RegisterID" val="1" AccessAttr="0"/>
		<DM name="SfThreshold" val="5" AccessAttr="0"/>
		<DM name="SdThreshold" val="9" AccessAttr="0"/>
		<DM name="MTU" val="1536" AccessAttr="0"/>
		<DM name="MTU_MAX" val="2000" AccessAttr="0"/>
		<DM name="MTU_MIN" val="1518" AccessAttr="0"/>
		<DM name="GemPort_Max" val="32" AccessAttr="0"/>
		<DM name="Tcont_Max" val="8" AccessAttr="0"/>
		<DM name="TcontQueue_Max" val="8" AccessAttr="0"/>
		<DM name="PwFlag" val="0" AccessAttr="0"/>
		<DM name="HexPassword" val="XXXXXX" AccessAttr="0"/> # Yet another pass. This one coincides with LoidPwd
	</Row>
</Tbl>
The file DevInfo.txt brings other possible nSerial:
<Tbl name="DevInfo" RowCount="1">
	<Row No="0">
		<DM name="ManuFacturer" val="ZTE" AccessAttr="0"/>
		<DM name="ManuFacturerOui" val="XXXXXX" AccessAttr="0"/>
		<DM name="ModelName" val="F680" AccessAttr="0"/>
		<DM name="Description" val="HomeGateWay" AccessAttr="0"/>
		<DM name="ProductClass" val="F680" AccessAttr="0"/>
		<DM name="SerialNumber" val="ZTEEXXXXXXXXXXX" AccessAttr="0"/> # Possible nSerial, but ZTEE differs from ZTEG. Plus then come 11 chars
		<DM name="HardwareVerTag" val="" AccessAttr="0"/>
		<DM name="BootVer" val="V4.0.10" AccessAttr="0"/>
		<DM name="HardwareVer" val="V4.0" AccessAttr="0"/>
		<DM name="SoftwareVer" val="ZTEGXXXXXXXXX" AccessAttr="0"/> # Another possible nSerial, but ZTEE differs from ZTEG. Plus then come 9 chars
		<DM name="SpecVer" val="1.0" AccessAttr="0"/>
		<DM name="WiFiFirmwareVer" val="" AccessAttr="0"/>
		<DM name="DSPFirmwareVer" val="" AccessAttr="0"/>
		<DM name="ModelFirmwareVer" val="" AccessAttr="0"/>
		<DM name="ProvisioningCode" val="" AccessAttr="0"/>
		<DM name="VerDate" val="2017-09-15 11:27:17" AccessAttr="0"/>
		<DM name="CfgLable" val="" AccessAttr="0"/>
		<DM name="HostName" val="atadeviceXX:XX:XX:XX:XX:XX" AccessAttr="0"/>
		<DM name="SaveFlag" val="1" AccessAttr="0"/>
		<DM name="FirstUseDate" val="2018-12-07T12:46:49" AccessAttr="0"/>
		<DM name="DomainName" val="Home" AccessAttr="0"/>
		<DM name="SoftwareVerExtent" val="XXXXXXXXXX" AccessAttr="0"/> # This one has 10 chars.
		<DM name="ManuFacturerURL" val="http://www.zte.com" AccessAttr="0"/>
		<DM name="DeviceURL" val="http://www.zte.com" AccessAttr="0"/>
		<DM name="Contact" val="" AccessAttr="0"/>
		<DM name="Location" val="" AccessAttr="0"/>
		<DM name="DeviceSummary" val="" AccessAttr="0"/>
		<DM name="OnuMode" val="1" AccessAttr="0"/>
	</Row>
</Tbl>
_(important fields deliberately obfuscated)_
Any ideas? Thanks a lot.
jangdong
Fri Dec 04, 2020 5:23 pm
	<Row No="0">
	</Row>
</Tbl>
	<Row No="0">
	</Row>
</Tbl>
ZTEExxxxx is SN for equipment
ZTEGxxxxx is SN for PON
You can try to see the hidden information, with F12 key or right mouse to choose Inspect to see while using Web browser as Chrome or Firefox.
almeiras
Sat Dec 05, 2020 12:22 am
Thank you @jangdong, I'll pick ZTEG then, but I don't know which field I should put for "nSerial" after ZTEG since @JeanPierre said "nSerial is vendor+8 characters", ...and none of them is 8 characters long. Any bet?
And for "nPassword"? Same problem, it should be 10 chars, but none fits exactly.
jangdong
Sat Dec 05, 2020 3:08 am
Hi, Almeiras
- nSerial: you can see at the bottom of ZTE F680 device found (on manufacturer's label). It's mean GPON SN, include 4 chars for VENDOR ID: ZTEG and 8 chars.
Example: ZTEGC8542ADE
https://1drv.ms/u/s!Aj92Tq0G8WHPhvhxLTw ... Q?e=1aVhFO
- nPassword: maximum is 10 chars, that means it could be less than 10
almeiras
Sun Dec 06, 2020 1:42 am
@jangdong thank you so much! I got "nSerial" right just looking at the case! "onu gtcsng" responds correctly (yes!).
@Petronas, @JeanPierre, I read you discussing blank response to "onu gtcsng". In my case, "fw_setenv nPassword XXXXX" also appears to do nothing. BUT the web GUI offers a field for GPON password. That one seems to fill in the gpon.ploam.nPassword parameter. It only works when using hex as someone stated before (in my case 9 chars), but seems to be valid (web field and parameter are coherent).
The thing is, even though I have valid serial and password, I still couln't get fixed ploamsg 5...
Then I revised the info I dumped from my F680 and tried "uci set network.wan.macaddr xx:xx:xx:xx:xx:xx", "fw_setenv ont_serial ZTEEXXXXXXXXXXX"; "fw_setenv omci_loid XXXXXXXX" and "fw_setenv omci_lpwd XXXXXX". PLOAM state kept changing from 2 to 5.
Any recommended course of action? I feel so close... Thank you.
PS: Do you know what are "image0_version", "omci_version" and "fw_setenv target oem-generic"
zry98
Mon Dec 28, 2020 9:27 pm
For anyone having trouble setting up DFP-34X-2C2 / DFP-34G-2C2 with Movistar's 10 bytes hexadecimal GPON password (aka idONT, `f20XXXXXXXXXXX000000`), I did some reverse engineering and wrote a tool to do that: https://github.com/zry98/DFP-34X-2C2
Update: After communicating with the developer from ODI, it is confirmed that the current version (with `PON STICK V01` printed on PCB near the SFP connector) is IMPOSSIBLE to use a hexadecimal GPON PLOAM password even with it set in tagparam using this program, due to the implementations of /lib/libdb.so and /bin/gpon_omci. And ODI is not planning to release an upgraded firmware in the future (they have already developed a newer model with hex password support). Therefore, this product can not be used with ISPs like Movistar Spain.
Anime4000
Tue Dec 29, 2020 11:39 am
Sorry for hijacking this thread,
I have related question regarding GPON SFP.
You see, I have DFP-34G-2C2, I have manage to set Serial Number and PLOAM Password and GPON Status is O5 (Authenticated), however I can't get any luck PPPoE connected via VLAN 621 under sfp1.
My ISP have explicit OMCI Provisioning, assigning a bridge to LAN Port 2 and disable other LAN port, since SFP only have one Ethernet, how to fix this?
Gnubyte
Wed Dec 30, 2020 3:57 pm
Hi all,
Just to warn you all that, at this moment, some French users on https://lafibre.info suffer from a difference of point of view, between us and a supplier, Shenzhen Hilink Technology Company, known to sell the HL23446, known, in the near past, to be Lantiq based.
At this moment, we only received ZTE non HSGMII compliant items.
They communicate manual PDF that states about Lantiq chipset, but send ZTE 1Gbps limited ones.
Stay warned.
I will update this post as the subject takes its course.
The French subject about FTTH, 2Gbps and Mikrotik is there: https://lafibre.info/remplacer-livebox/ ... -en-2gbps/
I reach this:
I use a G-010S-A inserted in a HSGMII compliant BMC57810S 2x SFP+ PCIe card, to manage a bridge to link it to a CCR2004.
JeanPierre
Thu Dec 31, 2020 2:08 am
Hi all,
Stay warned.
I reach this:
Please keep us posted!
Hilink sourced HL23446 from Dipper Optics. In the past it was difficult to order samples directly from dpoptics cause they didn't want to talk to small players (orders less than 100 units).
Maybe it's easier now?
http://www.dpoptics.com/col.jsp?id=287
They advertise four versions of the GPON modules - UPC/APC connector, Commercial/Industrial temperatures.
D23446-SSCE SC/UPC 0~70°C
D23446-SSHE SC/UPC -40~85°C
D23446-STCE SC/APC 0~70°C
D23446-STHE SC/APC -40~85°C
http://www.dpoptics.com/Datasheet-D2344 ... 170426.pdf
sotirone
Thu Dec 31, 2020 10:13 am
My Carlito SFP finally arrived after almost two months! Thanks COVID!
It works fine with my EPON ISP. It also works fine with my Brocade ICX 6450 switch but I had to manually set the port to 1Gb instead of 10Gb.
I have one problem though. My ISP uses VLAN 0 (probably LAN) on the fiber line for TR_069 and VoIP.
While I can get a DHCP IP on the Internet VLAN, I cannot get a DHCP IP on VLAN 0 (LAN). Is that the way the XPON SFP is designed or am I doing something wrong?
Edit: Also, forgot to mention that bandwidth control does not work. I have to set a limiter on my pfSense router, otherwise my speed is the full 1Gbps the fiber line and ONU can provide. I am supposed to be limited to 300Mbps because that is what I am paying the ISP for.
Anime4000
Thu Dec 31, 2020 9:51 pm
which carlitoxxpro model that you bought?
sotirone
Sat Jan 02, 2021 10:33 am
Happy new year! I bought the CPGOS03-0490 v2.0
almeiras
Sun Jan 03, 2021 4:18 am
I'm so tired of messing with my G-010S-P... is there a way of installing another firmware, maybe the Zisa one?
PS: or at least safely remove all the variables that I introduced... my uci and fw_env are a mess.
piku
Sun Jan 03, 2021 10:57 am
I don't think it will works. ZISA and G-010 have difference type of nand.
almeiras
Mon Jan 04, 2021 1:45 am
Hi, I continue not to sleep because of my G-010S-P. This thing has been on my desk for over a year now. I really wish to ditch my F680.
No matter what I do with nPassword variables, "onu gtcpg" returns empty password:
root@SFP:~# onu gtcpg
errorcode=0 password=
In contrast, the web GUI shows the same HEX password I typed in "gpon.ploam.nPassword", so it might be OK after all.
There is also another variable, "fw_setenv nPassword" that I use for the password (not really sure if HEX or ASCII). Does anybody know which one is correct? (OpenWRTv12)
Thank you.
PS: (EDITING SOME MISTAKES) Just another piece of information: It has been said that PLOAM passwords are up to 10 ASCII chars (or 20 HEX numbers). Well, I have seen ONTs in Spain using this template for HEX password:
- 0xF2018 (the year when the ONT was installed for the first time, in my case 2018)
- Nine random HEX chars (probably from serial or something
- Six HEX zeros
So, if your PLOAM pass is ABCDE1234, it is stored like this: 0xF2018ABCDE1234000000.
As you can see, that makes for 20 HEX numbers, this is, 10 ASCII chars.
piku
Re: Usage GPON module SFP in Spain
Sun Jan 17, 2021 2:40 pm
Thank you.
- Six HEX zeros
Some one tell me ZISA could set it as hex value. May be change a ZISA's EEPROM and flash ZISA's rom if you really want to try?
fyi. Usource said the value without quote shuld be a decimal in command line, may be 0xF2018ABCDE1234000000 should input -1008372297770060800 ?
almeiras
Tue Jan 19, 2021 12:07 am
Hi @piku! It's great to get advice from you!
I'm totally up to the task of flashing the Zisa fw in my G-010S-P. I already found it here: https://www.dropbox.com/s/dl/v1sxo2js25 ... -010s-p.7z, but the u-boot environment variables (mtd1 I think) are in plain text. Do you know how to convert it to the binary needed for kermit? One more thing, the addresses are the same as with the stock G-010S-P, aren't they?
Thank you.
PS: I'll try "fw_setenv nSerial" in decimal as soon as I can.
almeiras
Fri Jan 22, 2021 1:59 am
So, I'm having a lot of trouble because my IdONT / PLOAM password is not 10 chars long, but just 9. I tried with the Nokia ONT (both SFP G-010S-P and standard G-010G-S) with no luck. Then it hit me: my current router is ZTE F680, so I bought a standalone ONT from the same brand: ZTE F601. I found some interesting info using this device:
    Default GPON LOID is the same in both ZTE devices: 123456789.
      Default LOID password is the same in both ZTE devices: 123456.
        Different SN.
          SN password (IdONT / PLOAM password) is also different, but ALSO 9 CHARS LONG!!!
          So I filled in the info I had extracted from the original router... and in no time I got "GPON State Authentication Success".
          What's up with these 9-char-passwords from ZTE? How do people translate them to standard 10 ASCII / 20 HEX PLOAM passwords? I already tried filling in with 0x00, 0x30, both on the left, and on the right. @piku mentioned converting it to DEC, but I don't understand how.
          By the way, my carrier (Yoigo under Movistar network) doesn't verify the MAC address.
          Petronas
          Fri Feb 05, 2021 5:17 pm
          Someone has the stick -->> Ubiquiti - U-Fiber Instan
          Someone can put some pictures of the real interior , the motherboard and internal specifications
          Very grateful.
          guipoletto
          Fri Feb 05, 2021 7:22 pm
          Very grateful.
          UBNT went out of their way to *activelly block* the UF-Instant from registering at any OLT that is not UBNT's. A first, as i've never seen a manufacturer do that.
          fuck them
          88zz88
          Sat Feb 06, 2021 6:04 pm
          Very grateful.
          fuck them
          It was published a few months ago in the Russian forum.
          user=Firezone said:
          UF-instant has very good cooling: thermal contact to the case through the thermally conductive layer on both sides of the board, shorter case, connector to the optics SC/APC (many people won't need adapters). Telnet to 192.168.1.1, login/password ubnt/ubnt. There is ssh (disabled by default). It won't let me in via http.
          In UF-instant the omci_app is customised so that the SerialNumber is taken from the /proc/ubnthal/sn file which is exposed by the driver ubnthal.ko. The driver generates SN by concatenating the letters UBNT and the last 4 bytes of the MAC address. The MAC address itself is taken from the mtd9 "sec" partition at offset 0xA022.
          So, to change SN you will have to patch ubnthal.ko and match the MAC address to "sec" partition, or modify omci_app.
          NeoPhyTex360
          Mon Feb 15, 2021 11:56 am
          Planning to buy a DFP-34G-2C2 for Movistar, this: https://es.aliexpress.com/item/4000536994357.html
          Do you think it will be the updated version? I need the hex capabilities.
          Or what could it be the new version of this to buy and use with movistar?
          Petronas
          Mon Feb 15, 2021 2:49 pm
          Be careful friend with the Chinese market.
          They cook anything , that's why in this line with the help of all we analyze the equipment, don't be fooled by the outside appearance. Otherwise you have a nice paperweight.
          I recommend something with the possibility of returning the article.
          It looks like a clone
          NeoPhyTex360
          Tue Feb 16, 2021 1:46 pm
          Then probably wait a while and will purchase carlitos one (I thought to buy another because it was a bit expensive now).
          piku
          Thu Feb 18, 2021 3:12 pm
          No that's from ODI and I believe it has ZTE's chipset. 'Cause ZTE will not open source code to ODI, I don't think it will be upgraded.
          I'll do my best to try to get one
          piku
          Thu Feb 18, 2021 3:26 pm
                Different SN.
                  Sorry for the confusion.
                  LOID and password are ascii string with variable length.
                  SNID is same as device's sn, which is 4 upper letters + 8 hex value, and 4 upper letters can be converted to their ascii value, then you get a hex value which looks like a sting with 16 letters and digis.
                  PLOAM (aka password of snid) is 10 length digit
                  But sometimes operators need longer strings and customized equipment to ensure that they are not replaced.
                  These are what I remember, please correct me if something is wrong
                  piku
                  Thu Feb 18, 2021 3:42 pm
                  I'm not familiar with your requirement but try to learn about USource's products?
                  obenturk
                  Fri Feb 19, 2021 9:25 pm
                  Hi all,
                  I have UF Instant and I would like to use it instead of Ericsson T063G ONT
                  I accessed T063G via usb-serial converter and took following parameters
                  00-T06xG-gpon: st
                  PLOAM:
                           STATE:           Operation (O5)
                           SERIAL:          0x4552534e0003fc39
                           ONU ID:          5
                           US QOS Method:   FLOW
                           PASSWD:          0x20202020202020202020
                           TXQ DEPTH:       0
                           AES KEY:         67a1313e 20a8642c b02b13a 550015bb
                  BER:
                           INTERVAL:        5000
                           COUNT:           0
                  OVERHEAD & EQD:
                           GUARD BITS :     0x40
                           N PREAMBLE1:     0x0
                           N PREAMBLE2:     0x0
                           PATTERN 3:       0xaa
                           CELL DELIM:      0xab 59 83
                           SN MASK:         DISABLED
                           EXTRA SN:        0x0
                           TX PWR MODE:     0x0
                           USE PRE EQD:     ENABLED
                           PRE EQDELAY:     0x0
                           EQDELAY:         0x2edc9
                           EXT BURST:       ENABLED
                           PRE TYPE3 NUM:   0xb
                           TYPE3 NUM:       0x8
                  SN & PWR:
                           SNREQRX:         7
                           SNREQTHRESH:     10
                           PWRLVL:          0
                           PWRADJ:          0
                  INDEX MAC               BPT FID DSPQ SAACT DAACT AGE
                  125   e0:63:da:e5:1c:a6 60  60  0    0     0     0
                  497   00:02:3b:10:28:b3 0   3   0    0     0     0
                  To access UF Instant I gave 192.168.1.10/24 to SFP and I used the telnet 192.168.1.1 23 command and wrote following parameters which I obtained from T063G
                  flash set GPON_SN ERSN0003fc39
                  flash set PON_VENDOR_ID ERSN
                  flash set ELAN_MAC_ADDR e063dae51ca6
                  flash set GPON_PLOAM_PASSWD "          "
                  From router I also added sfp.157 vlan and pppoe2 from sfp.157.
                  After all setting I could not receive an IP for PPPOE2 :(
                  Could you please comment what am I missing?
                  Thanks in advance.
                  Barrakud
                  Fri Feb 19, 2021 10:19 pm
                  Hello.
                  I understand correctly?
                  that this module will not be able to receive streams of ip tv. since it is 1490 \ 1330.
                  after all, ip tv is broadcast at 1550 length.
                  Or am I not understanding something?
                  CarlitoxxPro
                  Tue Feb 23, 2021 10:50 am
                        Different SN.
                          Hi Almeiras, you have a big confusion, let me clarify a bit what are all these parameters and his length
                          1- SN: is the serial number of the device that contains 12 ASCII characters or 16 HEX characters, in any case, the first 4 characters (in ASCII) or the first 8 characters (in HEX) are the Vendor ID and the rest of the characters (in HEX ever) are part of the MAC address or product identifier. Example: HWTC28B04E9A (in ASCII mode) or 4857544328B04E9A (in HEX mode)
                          as you can see is only converted the first 4 bytes.
                          2- Ploam Password / SLID / GPON Password / ONTid: is the GPON password used for authenticated with the OLT (if his use it, some ISP no require or use it), are a random 10 bytes long (until 10), that's mean 10 characters (ASCII mode) or 20 characters (HEX mode), Example: ga1385dfr9 (in ASCII) or 67613133383564667239 (in HEX), sometimes the ISP use short passwords in ASCII, so if you are configuring the Ploam Password in ASCII mode you only need to insert the characters that the ISP defined, nothing more, but in case that you are configuring that password in HEX mode you need to complete the missing values with zeroes until the 20 characters, Example: abcd123 (in ASCII) or 61626364313233000000 (in HEX), another thing that you need to know is that no all the time you can't convert the Ploam Passwords in HEX mode to ASCII mode due to the Ploam password can contain random octets, for example, the Ploam passwords used by Movistar/O2 in spain where the passwords have this pattern F2019023298756000000 (in HEX) but no have valid ASCII convertion.
                          3- LOID and LOID_PW: Is the Logical Identifier, another authentication method that can be used or not by the ISP, this is 24 bytes long + 12 bytes long for the CHECKCODE (LOID_PW), commonly is based on ASCII characters but the definition says that can be random octets.
                          so, to resume, the ISP can use one of this 4 methods to authenticate the ONU:
                          1- SN only
                          2- Ploam Password only
                          3- SN + Ploam Password
                          4- LOID + CHECKCODE (LOID_PW)
                          By default the ONUs ZTE (and others), have pre-filled the LOID and LOID_PW fields by a default string 123456789 and 123456, that doesn't mean that this authentication method will be used by the OLT, the OLT only will take the values that it requires and all other values will be ignored.
                          I hope this clarifies you a bit more.
                          Kindest Regards.
                          piku
                          Tue Feb 23, 2021 10:55 am
                          Hi all,
                          00-T06xG-gpon: st
                          PLOAM:
                                   ONU ID:          5
                                   US QOS Method:   FLOW
                                   TXQ DEPTH:       0
                          BER:
                                   INTERVAL:        5000
                                   COUNT:           0
                          OVERHEAD & EQD:
                                   GUARD BITS :     0x40
                                   N PREAMBLE1:     0x0
                                   N PREAMBLE2:     0x0
                                   PATTERN 3:       0xaa
                                   SN MASK:         DISABLED
                                   EXTRA SN:        0x0
                                   TX PWR MODE:     0x0
                                   PRE EQDELAY:     0x0
                                   EQDELAY:         0x2edc9
                                   EXT BURST:       ENABLED
                                   PRE TYPE3 NUM:   0xb
                                   TYPE3 NUM:       0x8
                          SN & PWR:
                                   SNREQRX:         7
                                   SNREQTHRESH:     10
                                   PWRLVL:          0
                                   PWRADJ:          0
                          Thanks in advance.
                          check the status of your sfp pon first (if it's O5). and are you means pppoe connect establised but no ip get?
                          CarlitoxxPro
                          Tue Feb 23, 2021 11:12 am
                          Hello.
                          Hi Barrakud
                          Most of GPON ONU SFP are not capable to work with CATV (1550nm), only IPTV sent via TriplePlay VLAN (1330/1490nm).
                          The traditional ONTs (with CATV support) have an internal separate module to convert and bridge the CATV lambda (1550nm) into the coaxial port and letting pass the rest of the lambdas (1330/1490nm) to the ONT optical header, in the picture below you will see that in the CATV module enter 2 fibers together (red and white).
                          piku
                          Tue Feb 23, 2021 11:28 am
                          Hello.
                          yes you need a Optical Splitter and two different devices to deal with it.
                          almeiras
                          Tue Feb 23, 2021 1:35 pm
                          BEST. EXPLANATION. EVER. Specially the Ploam Password part. BIG THANK YOU!
                          Damn it. I should totally have bought your ONT when I had the chance.
                          I converted to HEX and filled with 0s both on the left and on the right. Nothing. The only thing that works is using an F601 (same brand as the default ZTE F680 shitty CPE). I'll have to live with this, and put the Nokia G-010s-p inside a drawer.
                                Different SN.
                                  1- SN only
                                  Kindest Regards.
                                  JeanPierre
                                  Wed Feb 24, 2021 1:16 am
                                  Put it on ebay and offer shipping to France. Many users want this module and no one offers it at an reasonable price.
                                  obenturk
                                  Wed Feb 24, 2021 9:23 am
                                  Could you please provide the code that I can check the state of PON?
                                  I could not find it even I search diag command.
                                  Thanks.
                                  Hi all,
                                  00-T06xG-gpon: st
                                  PLOAM:
                                           ONU ID:          5
                                           US QOS Method:   FLOW
                                           TXQ DEPTH:       0
                                  BER:
                                           INTERVAL:        5000
                                           COUNT:           0
                                  OVERHEAD & EQD:
                                           GUARD BITS :     0x40
                                           N PREAMBLE1:     0x0
                                           N PREAMBLE2:     0x0
                                           PATTERN 3:       0xaa
                                           SN MASK:         DISABLED
                                           EXTRA SN:        0x0
                                           TX PWR MODE:     0x0
                                           PRE EQDELAY:     0x0
                                           EQDELAY:         0x2edc9
                                           EXT BURST:       ENABLED
                                           PRE TYPE3 NUM:   0xb
                                           TYPE3 NUM:       0x8
                                  SN & PWR:
                                           SNREQRX:         7
                                           SNREQTHRESH:     10
                                           PWRLVL:          0
                                           PWRADJ:          0
                                  Thanks in advance.
                                  Petronas
                                  Thu Feb 25, 2021 1:19 am
                                  Thanks.
                                  Hi all,
                                  00-T06xG-gpon: st
                                  PLOAM:
                                           ONU ID:          5
                                           US QOS Method:   FLOW
                                           TXQ DEPTH:       0
                                  BER:
                                           INTERVAL:        5000
                                           COUNT:           0
                                  OVERHEAD & EQD:
                                           GUARD BITS :     0x40
                                           N PREAMBLE1:     0x0
                                           N PREAMBLE2:     0x0
                                           PATTERN 3:       0xaa
                                           SN MASK:         DISABLED
                                           EXTRA SN:        0x0
                                           TX PWR MODE:     0x0
                                           PRE EQDELAY:     0x0
                                           EQDELAY:         0x2edc9
                                           EXT BURST:       ENABLED
                                           PRE TYPE3 NUM:   0xb
                                           TYPE3 NUM:       0x8
                                  SN & PWR:
                                           SNREQRX:         7
                                           SNREQTHRESH:     10
                                           PWRLVL:          0
                                           PWRADJ:          0
                                  Thanks in advance.
                                  Post #342
                                  root@SFP:/# onu ploamsg
                                  The execution lines depend on distro linux or embedded system.......
                                  If you could give more data, we could help what partition structure the model has UF Instant
                                  Info cpu model -->> cat /proc/cpuinfo
                                  view partitions -->> cat /proc/mtd
                                  THX
                                  Barrakud
                                  Re: Использование модуля GPON SFP в Испании
                                  Thu Feb 25, 2021 8:06 pm
                                  Hello.
                                  Hi Barrakud
                                  hello Carlos. thanks for your clarification.
                                  if i don't chase cable tv. But I will focus on SFP modules 1490 \ 1310, will the ip tv work in full?
                                  I received your answer to my email, I saw it late, it also got into spam.
                                  Barrakud
                                  Thu Feb 25, 2021 9:33 pm
                                  I will clarify the information.
                                  my provider, when connecting pon, put pon terminal huawei HG8120H
                                  in bridge mode.
                                  Internet is thrown on LAN1
                                  ip tv on lan2
                                  OLT Huawei Ma5680t.
                                  authorization at OLT is carried out by serial number.
                                  the tr069 service bothers me.
                                  Will the OLT disconnect sfp?
                                  and how to pass so many ports to the SFP ??
                                  obenturk
                                  Sat Feb 27, 2021 10:40 am
                                  Post: #496
                                  Edit: Today I entered gpon serial number and ploam password random number and checked again status of gpon surprisingly it became O5 so what does that mean?
                                  onu ploamsg does not work for UF Instant. Below you may find chipset and partition.
                                  I think I found as in diag application gpon get onu-state
                                  # onu ploamsg
                                  /bin/sh: onu: not found
                                  # cat /proc/cpuinfo
                                  system type             : RTL8672
                                  processor               : 0
                                  cpu model               : 56322
                                  BogoMIPS                : 112.23
                                  tlb_entries             : 64
                                  mips16 implemented      : yes
                                  # cat /proc/mtd
                                  dev:    size   erasesize  name
                                  mtd0: 00040000 00001000 "boot"
                                  mtd1: 00002000 00001000 "env"
                                  mtd2: 00002000 00001000 "env2"
                                  mtd3: 0003c000 00001000 "config"
                                  mtd4: 00300000 00001000 "k0"
                                  mtd5: 004b0000 00001000 "r0"
                                  mtd6: 00300000 00001000 "k1"
                                  mtd7: 004b0000 00001000 "r1"
                                  mtd8: 00010000 00001000 "hw"
                                  mtd9: 00010000 00001000 "sec"
                                  mtd10: 00001000 00001000 "Partition_010"
                                  mtd11: 00001000 00001000 "Partition_011"
                                  mtd12: 00300000 00001000 "linux"
                                  mtd13: 004b0000 00001000 "rootfs"
                                  UF-Instant take the operation state (O5) with flash set commands and also with following diag commands.
                                  But even it is O5 I could not get IP for PPPoE from sfp.157 port. Internet is behind vlan 157.
                                  # diag
                                  RTK.0> gpon set serialnumber ERSN0003fc39
                                  RTK.0> gpon set password-hex 20202020202020202020
                                  RTK.0> gpon get onu-state
                                  ONU state: Operation State(O5)
                                  Below I am also adding more info from Ericsson T63G. Additionally I am suspicious about mac address because after reboot of UF-Instant Serial# and Password remains but ELAN mac address changes to default value.
                                  00-T06xG-omci: prmib
                                  ONTDAT 0000
                                          sync      = 0
                                  SLCH 0101
                                          act       = 34
                                          exp       = 34
                                          expptcnt  = 0
                                          expeqid   = 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
                                          aceqid    = 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
                                          protprofpt= 0
                                          invprotsw = 0
                                          arc       = 0
                                          interval  = 0
                                  SLCH 0102
                                          act       = 32
                                          exp       = 32
                                          expptcnt  = 0
                                          protprofpt= 0
                                          invprotsw = 0
                                          arc       = 0
                                          interval  = 0
                                  SUB 0101
                                          type      = 34
                                          np        = 4
                                          ser       = 45 52 53 4e 00 03 fc 39
                                          ver       = 48 31 2e 30 46 31 2e 30 20 20 20 20 20 20
                                          vid       = 45 52 53 4e
                                          admin     = 0
                                          oper      = 0
                                          fmode     = 0
                                          eqid      = 4b 44 55 31 33 37 35 32 37 52 31 41 20 20 20 20 20 20 20 20
                                          cdconf    = 0
                                          tcobufnum = 0
                                          tpqnum    = 0
                                          ttschednu = 0
                                          pshdovr   = 0
                                  SUB 0102
                                          type      = 32
                                          np        = 2
                                          vid       = 45 52 53 4e
                                          admin     = 0
                                          oper      = 0
                                          fmode     = 0
                                          cdconf    = 0
                                          tcobufnum = 0
                                          tpqnum    = 0
                                          ttschednu = 0
                                          pshdovr   = 0
                                  SFTIMG 0000
                                          ver       = 34 2e 38 2e 33 2e 31 00 00 00 00 00 00 00
                                          cs        = 0
                                          as        = 0
                                          vs        = 1
                                  SFTIMG 0001
                                          ver       = 34 2e 31 33 2e 31 2e 35 00 00 00 00 00 00
                                          cs        = 1
                                          as        = 1
                                          vs        = 1
                                  ETHUNI 0101
                                          exp       = 34
                                          act       = 34
                                          autoneg   = 0
                                          loop      = 0
                                          admin     = 0
                                          oper      = 0
                                          dup       = 3
                                          mfs       = 2048
                                          mode      = 0
                                          pause     = 0
                                          ethernet  = 0
                                          arc       = 0
                                          interval  = 0
                                          pppoe     = 0
                                          poe       = 0
                                  ETHUNI 0102
                                          exp       = 34
                                          act       = 34
                                          autoneg   = 0
                                          loop      = 0
                                          admin     = 0
                                          oper      = 1
                                          dup       = 0
                                          mfs       = 2048
                                          mode      = 0
                                          pause     = 0
                                          ethernet  = 0
                                          arc       = 0
                                          interval  = 0
                                          pppoe     = 0
                                          poe       = 0
                                  ETHUNI 0103
                                          exp       = 34
                                          act       = 34
                                          autoneg   = 0
                                          loop      = 0
                                          admin     = 0
                                          oper      = 1
                                          dup       = 0
                                          mfs       = 2048
                                          mode      = 0
                                          pause     = 0
                                          ethernet  = 0
                                          arc       = 0
                                          interval  = 0
                                          pppoe     = 0
                                          poe       = 0
                                  ETHUNI 0104
                                          exp       = 34
                                          act       = 34
                                          autoneg   = 0
                                          loop      = 0
                                          admin     = 0
                                          oper      = 1
                                          dup       = 0
                                          mfs       = 2048
                                          mode      = 0
                                          pause     = 0
                                          ethernet  = 0
                                          arc       = 0
                                          interval  = 0
                                          pppoe     = 0
                                          poe       = 0
                                  MACBRDGPRF 0001
                                          span      = 0
                                          learn     = 1
                                          atm       = 0
                                          prio      = 1
                                          age       = 1536
                                          hello     = 256
                                          delay     = 1024
                                          unkdisc   = 0
                                          depth     = 0
                                          macage    = 0
                                  MACBRDGPRF 0005
                                          span      = 0
                                          learn     = 1
                                          atm       = 0
                                          prio      = 1
                                          age       = 1536
                                          hello     = 256
                                          delay     = 1024
                                          unkdisc   = 0
                                          depth     = 0
                                          macage    = 0
                                  MACBRDGCFG 0001
                                          mac       = 00 00 00 00 00 00
                                          prio      = 0
                                          root      = 00 00 00 00 00 00 00 00
                                          cost      = 0
                                          count     = 0
                                          port      = 0
                                          hello     = 0
                                          delay     = 0
                                  MACBRDGCFG 0005
                                          prio      = 0
                                          cost      = 0
                                          count     = 0
                                          port      = 0
                                          hello     = 0
                                          delay     = 0
                                  MACBRDGPORTCFG 0001
                                          svcprf    = 0005
                                          port      = 1
                                          tpt       = 4
                                          tpp       = 0000
                                          prio      = 0
                                          cost      = 1
                                          span      = 0
                                          encap     = 0
                                          discard   = 1
                                          pmac      = 00 00 00 00 00 00
                                          tdout     = 0000
                                          tdin      = 0000
                                  MACBRDGPORTCFG 0002
                                          svcprf    = 0005
                                          port      = 2
                                          tpt       = 5
                                          tpp       = 0001
                                          prio      = 0
                                          cost      = 1
                                          span      = 0
                                          encap     = 1
                                          discard   = 1
                                          tdout     = 0000
                                          tdin      = 0000
                                  MACBRDGPORTCFG 0003
                                          svcprf    = 0001
                                          port      = 1
                                          tpt       = 1
                                          tpp       = 0101
                                          prio      = 0
                                          cost      = 1
                                          span      = 0
                                          encap     = 0
                                          discard   = 1
                                          tdout     = 0000
                                          tdin      = 0000
                                  MACBRDGPORTCFG 0004
                                          svcprf    = 0001
                                          port      = 2
                                          tpt       = 5
                                          tpp       = 0002
                                          prio      = 0
                                          cost      = 1
                                          span      = 0
                                          encap     = 1
                                          discard   = 1
                                          tdout     = 0000
                                          tdin      = 0000
                                  MACBRDGPORTCFG 0005
                                          svcprf    = 0001
                                          port      = 3
                                          tpt       = 5
                                          tpp       = 0003
                                          prio      = 0
                                          cost      = 1
                                          span      = 0
                                          encap     = 1
                                          discard   = 1
                                          tdout     = 0000
                                          tdin      = 0000
                                  MACBRDGPORTCFG 0006
                                          svcprf    = 0001
                                          port      = 4
                                          tpt       = 6
                                          tpp       = 0001
                                          prio      = 0
                                          cost      = 1
                                          span      = 0
                                          encap     = 1
                                          discard   = 1
                                          tdout     = 0000
                                          tdin      = 0000
                                  MACBRDGDSTDATA 0001
                                          cost      = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          state     = 0
                                  MACBRDGDSTDATA 0002
                                          state     = 0
                                  MACBRDGDSTDATA 0003
                                          state     = 0
                                  MACBRDGDSTDATA 0004
                                          state     = 0
                                  MACBRDGDSTDATA 0005
                                          state     = 0
                                  MACBRDGDSTDATA 0006
                                          state     = 0
                                  MACBRDGFLTRTAB 0001
                                          fe        = 00 00 00 00 00 00 00 00
                                  MACBRDGFLTRTAB 0002
                                  MACBRDGFLTRTAB 0003
                                  MACBRDGFLTRTAB 0004
                                  MACBRDGFLTRTAB 0005
                                  MACBRDGFLTRTAB 0006
                                  MACBRDGTBLDATA 0001
                                          brgtab    = 00 00 00 00 00 00 00 00
                                  MACBRDGTBLDATA 0002
                                  MACBRDGTBLDATA 0003
                                  MACBRDGTBLDATA 0004
                                  MACBRDGTBLDATA 0005
                                  MACBRDGTBLDATA 0006
                                  PATHTRMPOTS 0201
                                          admin     = 0
                                          vc        = 0000
                                          arc       = 0
                                          interval  = 0
                                          z         = 0
                                          tp        = 0
                                          rg        = 0
                                          tg        = 0
                                          op        = 0
                                          hk        = 1
                                          pht       = 0
                                  PATHTRMPOTS 0202
                                          admin     = 0
                                          vc        = 0000
                                          arc       = 0
                                          interval  = 0
                                          z         = 0
                                          tp        = 0
                                          rg        = 236
                                          tg        = 216
                                          op        = 0
                                          hk        = 0
                                          pht       = 0
                                  VOICESVCPRF 0001
                                          at        = 255
                                          jt        = 20
                                          jbm       = 60
                                          eci       = 1
                                          pvar      = 74 74
                                  VLANTAGCFG 0001
                                          usm       = 2
                                          ust       = 49198
                                          dsm       = 1
                                          tpt       = 1
                                          tpp       = 0000
                                  VLANTAGCFG 0101
                                          usm       = 0
                                          ust       = 0
                                          dsm       = 0
                                          tpt       = 0
                                          tpp       = 0101
                                  VLANFLTRDATA 0003
                                          ent       = 00 4b 00 9d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          fo        = 3
                                          ve        = 2
                                  VLANFLTRDATA 0004
                                          ent       = 00 9d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          fo        = 16
                                          ve        = 1
                                  VLANFLTRDATA 0005
                                          ent       = 80 4b 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          fo        = 16
                                          ve        = 1
                                  IPHOSTCFG 0000
                                          ipo       = 0
                                          mac       = c8 35 b8 48 31 20
                                          id        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          ip        = 0.0.0.0
                                          mask      = 0.0.0.0
                                          gateway   = 0.0.0.0
                                          dns1      = 0.0.0.0
                                          dns2      = 0.0.0.0
                                          ca        = 0.0.0.0
                                          cm        = 0.0.0.0
                                          cg        = 0.0.0.0
                                          cdns1     = 0.0.0.0
                                          cdns2     = 0.0.0.0
                                          dom       = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          host      = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                  IPHOSTCFG 0001
                                          ipo       = 6
                                          ip        = 0.0.0.0
                                          mask      = 0.0.0.0
                                          gateway   = 0.0.0.0
                                          dns1      = 0.0.0.0
                                          dns2      = 0.0.0.0
                                          ca        = 0.0.0.0
                                          cm        = 0.0.0.0
                                          cg        = 0.0.0.0
                                          cdns1     = 0.0.0.0
                                          cdns2     = 0.0.0.0
                                  TCPUDPCFGDAT 0001
                                          port      = 5060
                                          pcol      = 17
                                          tos       = 0
                                          host      = 0000
                                  NETADDR 0001
                                          secptr    = ffff
                                          addrptr   = 0001
                                  VOIPCFGDAT 0000
                                          asp       = 3
                                          sp        = 0
                                          acm       = 1
                                          scm       = 0
                                          cfgptr    = ffff
                                          cfgstate  = 0
                                          rtrvprf   = 0
                                          prfver    = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                  VOIPCTP 0001
                                          usrprot   = 0001
                                          pptp      = 0201
                                          voipmep   = 0001
                                          signal    = 1
                                  VOIPLSTAT 0201
                                          codec     = 0
                                          serverstat= 1
                                          sessiontype= 0
                                          period1   = 0
                                          period2   = 0
                                          dest1     = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          dest2     = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                  VOIPLSTAT 0202
                                          codec     = 0
                                          serverstat= 13
                                          sessiontype= 0
                                          period1   = 0
                                          period2   = 0
                                  VOIPMEDIAPRF 0001
                                          faxmode   = 0
                                          vservp    = 0001
                                          cs1       = 8
                                          pps1      = 20
                                          ss1       = 0
                                          cs2       = 8
                                          pps2      = 20
                                          ss2       = 0
                                          cs3       = 8
                                          pps3      = 20
                                          ss3       = 0
                                          cs4       = 8
                                          pps4      = 20
                                          ss4       = 0
                                          oobdtmf   = 1
                                          rtpptr    = 0001
                                  RTPPRF 0001
                                          lportmin  = 40000
                                          lportmax  = 60000
                                          dscpmark  = 46
                                          piggyback = 0
                                          tone      = 172
                                          dtmf      = 1
                                          cas       = 220
                                  DIALPLAN 0001
                                          dpcur     = 0
                                          dpmax     = 34
                                          cdt       = 10000
                                          pdt       = 16000
                                          dpform    = 3
                                          dptable   = 09 01 2e 7c 5b 78 2a 23 5d 2e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          0/1 30 5 0000 09012e7c5b782a235d2e0000000000000000000000000000000000000000
                                          0/1 30 5 0000 08017c3178787c323030787878787c5b322d395d7878787878787c303078
                                          0/1 30 5 0000 0701322d355d7878787878787878787c313078783030782e7c3131387878
                                          0/1 30 5 0000 060178787878787c313078785b322d395d7878787878787c31307878305b
                                          0/1 30 5 0000 05017c2a7878237c2a2378782a782e237c23237c305b322d385d78787878
                                          0/1 30 5 0000 04012e2a782e237c2a78782a787878782a782a78237c2a2a787c2a2a7878
                                          0/1 30 5 0000 0301395d5b302d392a5d2e237c2a2a78787c2a237878237c2a2378782a78
                                          0/1 30 5 0000 02012378782a78787878237c2a78782a782e2a782e237c5b2a235d5b302d
                                          0/1 30 5 0000 010178237c2a78782a787878782a782e2a782e2a782e237c2a2a78787c2a
                                          0/1 30 5 0000 00012a2a237c2a78782a787878782a782e2a782e237c237878237c2a2378
                                  APPLSVCPRF 0001
                                          cid       = 27
                                          cw        = 1
                                          cprog     = 3840
                                          cpres     = 0
                                          dirconn   = 0
                                          dirconnuri= 0001
                                          blauri    = ffff
                                          cfuri     = ffff
                                  FEATCODE 0001
                                          ccw       = 00 00 00 00 00
                                          ch        = 00 00 00 00 00
                                          cp        = 00 00 00 00 00
                                          cidsact   = 00 00 00 00 00
                                          cidsdeact = 00 00 00 00 00
                                          dnda      = 00 00 00 00 00
                                          dndd      = 00 00 00 00 00
                                          dndpc     = 00 00 00 00 00
                                          esn       = 31 31 32 00 00
                                          is        = 00 00 00 00 00
                                  AUTHMETH 0001
                                          vs        = 1
                                          usr1      = 2b 39 30 32 36 32 32 39 30 39 37 31 34 40 74 74 69 6d 73 63 6f 72 65 2e 63
                                          pwd       = 39 37 31 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          realm     = 74 74 69 6d 73 63 6f 72 65 2e 63 6f 6d 2e 74 72 00 00 00 00 00 00 00 00 00
                                          usr2      = 6f 6d 2e 74 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                  SIPUACFG 0001
                                          psa       = 0000
                                          opsap     = 0000
                                          pdns      = 0.0.0.0
                                          sdns      = 0.0.0.0
                                          conn      = 0001
                                          expire    = 3600
                                          renew     = 300
                                          uri       = 0000
                                          ss        = 0
                                          sr        = 0000
                                          vend      = 00 00 00 00
                                          srt       = 00 00 00 00 00
                                          sotc      = 0
                                          suf       = 0
                                          prot      = 0000
                                  SIPUSRDAT 0001
                                          sipua     = 0001
                                          uaor      = 0004
                                          dnam      = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          am        = 0001
                                          vm        = ffff
                                          vmexp     = 3600
                                          ndp       = 0001
                                          asp       = 0001
                                          fc        = 0001
                                          vf        = 0201
                                          rt        = 0
                                          roh       = 0
                                  LSTRING 0001
                                          np        = 0
                                          p1        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p2        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p3        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p4        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p5        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p6        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p7        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p8        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p9        = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p10       = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p11       = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p12       = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p13       = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p14       = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          p15       = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                  LSTRING 0002
                                          np        = 2
                                          p1        = 73 72 76 40 6b 6f 73 65 6b 6f 79 2e 6b 6f 63 61 65 6c 69 2e 74 74 69 6d 73
                                          p2        = 63 6f 72 65 2e 63 6f 6d 2e 74 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                  LSTRING 0003
                                          np        = 1
                                          p1        = 74 74 69 6d 73 63 6f 72 65 2e 63 6f 6d 2e 74 72 00 00 00 00 00 00 00 00 00
                                  LSTRING 0004
                                          np        = 1
                                          p1        = 2b 39 30 32 36 32 32 39 30 39 37 31 34 00 00 00 00 00 00 00 00 00 00 00 00
                                  ONTDBG 0000
                                          cmdfmt    = 0
                                          cmd       = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          reply     = 0
                                  EQUIP 0000
                                          sense     = 0
                                          contact   = 0
                                  OPTMON 8000
                                          id        = 4f 50 47 50 2d 33 34 2d 41 34 42 33 53 56 00 00
                                          rxp       = 54601
                                          txp       = 215
                                          temp      = 64
                                          bc        = 11856
                                          volt      = 3244
                                          rfp       = 0
                                  DOT1XCFG 0000
                                          cidprefix = 0000
                                          fbpolicy  = 1
                                          as1       = 0000
                                          secret1   = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          as2       = 0000
                                          secret2   = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          as3       = 0000
                                          secret3   = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                          proxy     = 0.0.0.0
                                  DOT1XPORT 0101
                                          ena       = 0
                                          areg      = 0
                                          paestate  = 0
                                          backstate = 5
                                          adir      = 1
                                          odir      = 1
                                          status    = 2
                                          quiet     = 60
                                          stimeout  = 60
                                          rperiod   = 0
                                          reauth    = 0
                                          kt        = 0
                                  DOT1XPORT 0102
                                          ena       = 0
                                          areg      = 0
                                          paestate  = 0
                                          backstate = 5
                                          adir      = 1
                                          odir      = 1
                                          status    = 2
                                          quiet     = 60
                                          stimeout  = 60
                                          rperiod   = 0
                                          reauth    = 0
                                          kt        = 0
                                  DOT1XPORT 0103
                                          ena       = 0
                                          areg      = 0
                                          paestate  = 0
                                          backstate = 5
                                          adir      = 1
                                          odir      = 1
                                          status    = 2
                                          quiet     = 60
                                          stimeout  = 60
                                          rperiod   = 0
                                          reauth    = 0
                                          kt        = 0
                                  DOT1XPORT 0104
                                          ena       = 0
                                          areg      = 0
                                          paestate  = 0
                                          backstate = 5
                                          adir      = 1
                                          odir      = 1
                                          status    = 2
                                          quiet     = 60
                                          stimeout  = 60
                                          rperiod   = 0
                                          reauth    = 0
                                          kt        = 0
                                  ONTG 0000
                                          vid       = 45 52 53 4e
                                          traffic   = 1
                                          vpcrs     = 0
                                          battery   = 0
                                          admin     = 0
                                          oper      = 0
                                  ONT2G 0000
                                          omccver   = 132
                                          vpc       = 20 20
                                          seccap    = 1
                                          secmode   = 1
                                          prioq     = 32
                                          sched     = 0
                                          opmode    = 1
                                          tgempidn  = 30
                                          uptime    = 0
                                          cap       = 32512
                                          cmode     = 4
                                  TCONT 8000
                                          allocid   = 5
                                          mode      = 1
                                          sched     = 1
                                  TCONT 8001
                                          allocid   = 276
                                          mode      = 1
                                          sched     = 1
                                  TCONT 8002
                                          allocid   = 277
                                          mode      = 1
                                          sched     = 1
                                  TCONT 8003
                                          allocid   = 278
                                          mode      = 1
                                          sched     = 1
                                  TCONT 8004
                                          allocid   = 279
                                          mode      = 1
                                          sched     = 1
                                  TCONT 8005
                                          allocid   = 280
                                          mode      = 1
                                          sched     = 1
                                  TCONT 8006
                                          allocid   = 255
                                          mode      = 1
                                          sched     = 1
                                  TCONT 8007
                                          allocid   = 255
                                          mode      = 1
                                          sched     = 1
                                  ANIG 8000
                                          srind     = 1
                                          tcont     = 8
                                          gblen     = 48
                                          prep      = 4
                                          wrep      = 0
                                          sfthresh  = 5
                                          sdthresh  = 9
                                          arc       = 0
                                          interval  = 0
                                          osl       = 0
                                          lrot      = 255
                                          urot      = 255
                                          ort       = 0
                                          tol       = 0
                                          ltot      = 0
                                          utot      = 0
                                  UNIG 0101
                                          cfg       = 0
                                          admin     = 0
                                          mcap      = 0
                                          nomciid   = 0000
                                          raopt     = 0000
                                  UNIG 0102
                                          cfg       = 0
                                          admin     = 0
                                          mcap      = 0
                                          nomciid   = 0000
                                          raopt     = 0000
                                  UNIG 0103
                                          cfg       = 0
                                          admin     = 0
                                          mcap      = 0
                                          nomciid   = 0000
                                          raopt     = 0000
                                  UNIG 0104
                                          cfg       = 0
                                          admin     = 0
                                          mcap      = 0
                                          nomciid   = 0000
                                          raopt     = 0000
                                  UNIG 0201
                                          cfg       = 0
                                          admin     = 0
                                          mcap      = 0
                                          nomciid   = 0000
                                          raopt     = 0000
                                  UNIG 0202
                                          cfg       = 0
                                          admin     = 0
                                          mcap      = 0
                                          nomciid   = 0000
                                          raopt     = 0000
                                  GEMIWTRM 0001
                                          gptr      = 0001
                                          ino       = 1
                                          svcprf    = 0005
                                          intp      = 0000
                                          pptpc     = 0
                                          oper      = 0
                                          galprfptr = 0001
                                          loopback  = 0
                                  GEMIWTRM 0002
                                          gptr      = 0002
                                          ino       = 1
                                          svcprf    = 0001
                                          intp      = 0000
                                          pptpc     = 0
                                          oper      = 0
                                          galprfptr = 0002
                                          loopback  = 0
                                  GEMIWTRM 0003
                                          gptr      = 0003
                                          ino       = 1
                                          svcprf    = 0001
                                          intp      = 0000
                                          pptpc     = 0
                                          oper      = 0
                                          galprfptr = 0003
                                          loopback  = 0
                                  GEMPORTCTP 0001
                                          portid    = 309
                                          tcgptr    = 8002
                                          dir       = 3
                                          tmu       = 800a
                                          td        = 0000
                                          nuni      = 0
                                          pqd       = 0000
                                  GEMPORTCTP 0002
                                          portid    = 306
                                          tcgptr    = 8004
                                          dir       = 3
                                          tmu       = 8014
                                          td        = 0001
                                          nuni      = 0
                                          pqd       = 0000
                                  GEMPORTCTP 0003
                                          portid    = 322
                                          tcgptr    = 8001
                                          dir       = 3
                                          tmu       = 8011
                                          td        = 0000
                                          nuni      = 0
                                          pqd       = 0000
                                  GEMPORTCTP 0004
                                          portid    = 4065
                                          tcgptr    = 8003
                                          dir       = 2
                                          tmu       = 8003
                                          td        = 0000
                                          nuni      = 0
                                          pqd       = 0000
                                  GALETHP 0001
                                          mgps      = 1530
                                  GALETHP 0002
                                          mgps      = 1530
                                  GALETHP 0003
                                          mgps      = 1530
                                  GALETHP 0004
                                          mgps      = 1530
                                  PRIOQG 8000
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 00 00 00
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8001
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 01 00 00
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8002
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 02 00 00
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8003
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 03 00 00
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8004
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 04 00 00
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8005
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 05 00 00
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8006
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 06 00 00
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8007
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 07 00 00
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8008
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 00 00 01
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8009
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 01 00 01
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 800a
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 02 00 01
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 800b
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 03 00 01
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 800c
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 04 00 01
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 800d
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 05 00 01
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 800e
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 06 00 01
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 800f
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 07 00 01
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8010
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 00 00 02
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8011
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 01 00 02
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8012
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 02 00 02
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8013
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 03 00 02
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8014
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 04 00 02
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8015
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 05 00 02
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8016
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 06 00 02
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8017
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 07 00 02
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8018
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 00 00 03
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 8019
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 01 00 03
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 801a
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 02 00 03
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 801b
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 03 00 03
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 801c
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 04 00 03
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 801d
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 05 00 03
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 801e
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 06 00 03
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  PRIOQG 801f
                                          qconf     = 1
                                          maxqsz    = 1000
                                          allocqsz  = 100
                                          rstint    = 2710
                                          dct       = 2710
                                          related   = 80 07 00 03
                                          tsp       = 0000
                                          weight    = 1
                                          bpc       = 0
                                          bpt       = 0
                                          bpot      = 0
                                          bpcqt     = 0
                                  GEMTD 0001
                                          sir       = 0
                                          pir       = 1024000
                                  MCGEMIWTRM 0001
                                          gptr      = 0004
                                          ino       = 1
                                          svcprf    = 0001
                                          intp      = 0000
                                          pptpc     = 0
                                          oper      = 0
                                          galprfptr = 0004
                                          loopback  = 0
                                          mcat      = 00 00 00 00 00 00 00 00 00 00 00 00
                                  FILEXFR 0000
                                          tp        = 2
                                          ft        = 0
                                          fi        = 0
                                          lfn       = 0000
                                          uri       = 0000
                                          trig      = 0
                                          status    = 0
                                          mcgemiw   = 0000
                                          vlan      = 0
                                          size      = 0
                                          dlt       = 0
                                  00-T06xG-ploam: flow
                                  FID CFG HW      TCONT     TD  QID PORT  AID  TYPE   BRIDGE DIR  ENCR USVLAN    DSVLAN    PBMSK
                                  0   1   VALID   0  (8000) 0   0   5     5    OMCI   0      FD   NONE 0000/TRAN 0000/TRAN 00
                                  1   1   VALID   2  (8002) 0   1   309   277  HOST   5      FD   AES  4070/STRP 4070/QINQ 00
                                  2   1   VALID   1  (8001) 0   2   322   276  BRIDGE 1      FD   AES  32843/MARK 0000/TRAN 00
                                  3   1   VALID   4  (8004) 1   2   306   279  BRIDGE 1      FD   AES  0157/MARK 0000/TRAN 00
                                  4   1   VALID   3  (8003) 0   0   4065  278  IGMP   1      DNST NONE 4076/TRAN 4076/TRAN 00
                                  00-T06xG-bridge: port
                                  BRIDGE BINST PORT BTYPE  PCPMSK
                                  0      1     0004 MCSRC  0000
                                  0      1     0003 VLAN   0000
        157 ff
                                  0      1     0002 VLAN   0000
        75 ff
                                  0      1     0101 ETHLAN 0000
                                  1      5     0001 802.1d 0000
                                  00-T06xG-packinfo: print
                                  type     T63G
                                  mac      C8:35:B8:48:31:20
                                  serial   0x0003FC39
                                  hwrev    1.0
                                  fwrev    1.0
                                  hwcompat 1.0
                                  fwcompat 1.0
                                  clei     KDU137527R1A
                                  Thanks.
                                  Hi all,
                                  00-T06xG-gpon: st
                                  PLOAM:
                                           ONU ID:          5
                                           US QOS Method:   FLOW
                                           TXQ DEPTH:       0
                                  BER:
                                           INTERVAL:        5000
                                           COUNT:           0
                                  OVERHEAD & EQD:
                                           GUARD BITS :     0x40
                                           N PREAMBLE1:     0x0
                                           N PREAMBLE2:     0x0
                                           PATTERN 3:       0xaa
                                           SN MASK:         DISABLED
                                           EXTRA SN:        0x0
                                           TX PWR MODE:     0x0
                                           PRE EQDELAY:     0x0
                                           EQDELAY:         0x2edc9
                                           EXT BURST:       ENABLED
                                           PRE TYPE3 NUM:   0xb
                                           TYPE3 NUM:       0x8
                                  SN & PWR:
                                           SNREQRX:         7
                                           SNREQTHRESH:     10
                                           PWRLVL:          0
                                           PWRADJ:          0
                                  Thanks in advance.
                                  Post #342
                                  THX
                                  obenturk
                                  Sat Mar 06, 2021 9:41 pm
                                  I found some files in a folder that has serial and gpon mac.
                                  Could you please help how can I change them ?
                                  Thanks.
                                  # cd /proc/ubnthal/
                                  # cat bom
                                  2825-7
                                  # cat ids
                                  eec6:0777
                                  # cat mac_eth0
                                  18:e8:29:f5:dd:d1
                                  # cat mac_gpon
                                  18:e8:29:f5:dd:d1
                                  # cat sn
                                  UBNT29f5ddd1
                                  # cat sn_raw
                                  55424e5429f5ddd1
                                  # ls -l
                                  -rw-r--r--    1 ubnt     0               0 Jan  1 00:03 bom
                                  -rw-r--r--    1 ubnt     0               0 Jan  1 00:03 ids
                                  -rw-r--r--    1 ubnt     0               0 Jan  1 00:03 mac_eth0
                                  -rw-r--r--    1 ubnt     0               0 Jan  1 00:03 mac_gpon
                                  -rw-r--r--    1 ubnt     0               0 Jan  1 00:03 sn
                                  -rw-r--r--    1 ubnt     0               0 Jan  1 00:03 sn_raw
                                  Petronas
                                  Sun Mar 07, 2021 6:43 pm
                                  You can read here what it means here, it is produced by many variables
                                  Forum Huawei...
                                  https://forum.huawei.com/carrier/en/thr ... 3-1-1.html
                                  Document how to work
                                  https://www.mdpi.com/2076-3417/8/10/1934/pdf
                                  Maybe it is better to change the firmware for one that works, with many more configuration variables
                                  The file architecture is very compatible with other models, according to the image you sent. "cpu and partition"
                                  What type of memory package is mounted? So ask for some inside pictures to see if you can make a reflash, and not complicate life so much.
                                  We also know that Ubiquity uses its own locks to be connected to each other, so I repeat, maybe it is better to change the software partition
                                  Look post 479 & 480
                                  Regards
                                  obenturk
                                  Tue Mar 09, 2021 8:30 am
                                  Hi Petronas,
                                  Flash Chip : MX25L12835FZ2I-10G
                                  IC1 : RTL8290
                                  IC2 : RTL9601CI
                                  Additional I/O : TG, TV, TR, TT (Does these mean Ground, + , Receive, Transmit ?)
                                  # cat /proc/cpuinfo
                                  processor               		: 0
                                  cpu model               	: 56322
                                  BogoMIPS               	: 112.23
                                  tlb_entries             		: 64
                                  # cat /proc/mtd
                                  Does anyone knows that it is possible to read&write MX25L12835 with SPI-USB programmer tool?
                                  r00t
                                  Long time Member
                                  Long time Member
                                  Tue Mar 09, 2021 3:32 pm
                                  You may get UBOOT or similar bootloader if you connect using UART pins (unless they disabled it). Pinout should be:
                                  TG = GND
                                  TV = voltage (3.3V, don't have to use it)
                                  TR = RX
                                  TT = TX
                                  Just use 3.3V USB2UART adapter, make sure it's not 5V one...
                                  obenturk
                                  Thu Mar 11, 2021 9:07 pm
                                  I could not connect via USB2UART adapter. I believe I also need to power up module via SFP pins. Later I will try one more shot.
                                  sn and mac was written on /proc/ubnthal folder
                                  /etc/init.d/rcS has following codes
                                  Any comment if I change following code with manual one to remove /proc/ubnthal ingredients and rewrite them via cat command ?
                                  /bin/mount -t proc proc /proc
                                  #!/bin/sh
                                  ### rc2
                                  /bin/mount -t ramfs ramfs /var
                                  /bin/mount -t sysfs sysfs /sys
                                  mkdir /var/tmp
                                  mkdir /var/log
                                  mkdir /var/run
                                  mkdir /var/lock
                                  mkdir /var/config
                                  mkdir /var/hw
                                  mkdir /var/ct
                                  mkdir /var/ct/tmp
                                  ifconfig lo 127.0.0.1
                                  route add -net 127.0.0.0 netmask 255.255.255.0 lo
                                  /bin/nv setenv bootcount 0
                                  mount -t jffs2 /dev/mtdblock3 /var/config
                                  # Try formating the paration if fails
                                  if [ $? != 0 ]; then
                                      echo "Error: failed to mount /dev/mtdblock3 onto /var/config"
                                      echo "Trying to format /dev/mtd3"
                                      umount -f /var/config
                                      echo "Erasing partition... "
                                      flash_eraseall "/dev/mtd3"
                                          echo "Error: failed to format dev/mtd3"
                                          exit 3
                                      else
                                          echo "Format ok, trying to mount again..."
                                          # exit if fails
                                              echo "Error: Failed to mount /dev/mtdblock3 onto /var/config"
                                              exit 4
                                          fi
                                      fi
                                  fi
                                  mount -t jffs2 -o ro /dev/mtdblock8 /var/hw
                                  if [[ -f /var/hw/europa.data ]]; then
                                          if ! cmp /var/config/europa.data /var/hw/europa.data -s; then
                                                  echo "Copy /var/hw/europa.data /var/config/europa.data"
                                                  cp -f /var/hw/europa.data /var/config/europa.data
                                          fi
                                  elif [[ ! -f  /var/config/europa.data ]]; then
                                      echo "Warning: File /var/hw/europa.data nor /var/config/europa.data doesn't exist!!!. Generating."
                                      /bin/europacli open default
                                  fi
                                  ### rc3
                                  /bin/insmod /lib/modules/ubnthal.ko
                                  if grep -q rst2dfl=1 /proc/cmdline; then
                                          rm -rf /var/config/*
                                          echo "reset to default"
                                  fi
                                  configd&
                                  ### rc10
                                  echo 200 > /proc/sys/net/core/netdev_max_backlog
                                  echo 600 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established
                                  echo 1 > /proc/sys/kernel/panic
                                  echo 10 > /proc/sys/net/ipv4/tcp_keepalive_intvl
                                  echo 3 > /proc/sys/net/ipv4/tcp_keepalive_probes
                                  echo 10 > /proc/sys/net/ipv4/tcp_keepalive_time
                                  echo 60 > /proc/sys/net/netfilter/nf_conntrack_tcp_timeout_time_wait
                                  echo 1 > /proc/sys/net/ipv4/ip_forward
                                  ### rc21
                                  SWVER0=$(/bin/nv getenv -q sw_version0)
                                  SWVER1=$(/bin/nv getenv -q sw_version1)
                                  SWACT=$(/bin/nv getenv -q sw_active)
                                  FWVER=$(awk -F" " '{print $1}' /etc/version)
                                  if [[ "$SWVER0" == "0" ]] && [[ "$SWVER1" == "0" ]]; then
                                          /bin/nv setenv sw_version0 $FWVER
                                          /bin/nv setenv sw_version1 $FWVER
                                          echo "All SW_VERSION are 0, set to " $FWVER
                                  fi
                                  if [[ "$SWACT" == "0" ]]; then
                                          if [[ "$SWVER0" != "$FWVER" ]]; then
                                                  echo "sw_version0 is not the same, set to " $FWVER
                                          fi
                                  elif [[ "$SWACT" == "1" ]]; then
                                          if [[ "$SWVER1" != "$FWVER" ]]; then
                                                  echo "sw_version1 is not the same, set to " $FWVER
                                          fi
                                  fi
                                  /bin/sh /etc/scripts/config_xmlconfig.sh -b
                                  insmod /lib/modules/omcidrv.ko
                                  insmod /lib/modules/pf_rtk.ko
                                  ### rc22
                                  startup
                                  ### rc32
                                  insmod /lib/modules/europa_drv.ko PON_MODE=1 I2C_PORT=1 INTR_PIN=0 TXDIS_PIN=13 TXPWR_PIN=15
                                  echo 1 > proc/lan_sds/lan_sds_cfg
                                  sn=$(cat /proc/ubnthal/sn)
                                  echo "sn $sn" > /proc/lan_sds/lan_sds_ident
                                  mac=$(cat /proc/ubnthal/mac_gpon)
                                  echo "oui $mac" > /proc/lan_sds/lan_sds_ident
                                  echo 1 > /proc/lan_sds/sfp_app
                                  sfpapp &
                                  ### rc33
                                  /etc/runomci.sh
                                  /bin/pondetect &
                                  ### rc34
                                  echo 1 > /proc/watchdog/watchdog_flag
                                  /bin/echo 2048 > /proc/sys/vm/min_free_kbytes
                                  ### rc60
                                  /bin/ubnt-syscfg service reload
                                  ### rc61
                                  /bin/ubnt-watchdog &
                                  ### rc63
                                  echo ONU BOOT FINISHED
                                  Petronas
                                  Mon Mar 15, 2021 4:16 pm
                                  #!/bin/sh
                                  ### rc2
                                  mkdir /var/tmp
                                  mkdir /var/log
                                  mkdir /var/run
                                  mkdir /var/lock
                                  mkdir /var/config
                                  mkdir /var/hw
                                  mkdir /var/ct
                                  mkdir /var/ct/tmp
                                          exit 3
                                      else
                                          # exit if fails
                                              exit 4
                                          fi
                                      fi
                                  fi
                                          fi
                                  fi
                                  ### rc3
                                  fi
                                  configd&
                                  ### rc10
                                  ### rc21
                                  fi
                                          fi
                                          fi
                                  fi
                                  ### rc22
                                  startup
                                  ### rc32
                                  sfpapp &
                                  ### rc33
                                  /etc/runomci.sh
                                  /bin/pondetect &
                                  ### rc34
                                  ### rc60
                                  ### rc61
                                  ### rc63
                                  Ubiquiti does not use OMCI open protocol but relies on the private and proprietary protocol.
                                  You should be able to connect by Pinout should
                                  And unlock the stick
                                  Test with program Tera Term
                                  https://ttssh2.osdn.jp/manual/4/en/
                                  https://osdn.net/projects/ttssh2/releases/
                                  espetoet
                                  Sat Mar 27, 2021 3:13 pm
                                  Hi, I'm new to the forum. I am looking to buy an SFP G-010S-A that is being sold by Aliexpress. '' Actually, I wanted to buy a CarlitoxxPro CPGOS03-0490 v2.0, but the price is very high for shipping to Brazil ''. Well I don't know if the G-010S-A will work with my ISP. I am from Brazil and I have a local fiber Internet. Could anyone tell if there is a way to know what type of configuration my ISP uses. serial number, mac address, PLOAM (SLID) or some other that I can't say. My ISP installed a Nokia G-140W-H modem. I want to use it in conjunction with a RB 4011. And if some power indicates a better and more configurable than I mentioned. or if someone has one to sell and send it to brazil. thanks. I used Google Translator.
                                  jangdong
                                  Sun Mar 28, 2021 7:29 am
                                  if you check web interface of Nokia G-140W-H modem (LOID and password blank) then you do not need to care about these 2 parameters anymore,
                                  you just change Serial number with SSH, and change SLID with web interface. Thus, the authentication is successful.
                                  On Mikrotik 4011, you need to set up the following: turn off Auto Negotiation and manually adjust with Full duplex 1Gbps. Thus, the sfp port on the Rb4011 is uplink.
                                  espetoet
                                  Sun Mar 28, 2021 7:38 am
                                  Thanks for the answer. on the page of the modem where the slid has a numbering but I did not find the password. look at the picture.
                                  espetoet
                                  Sun Mar 28, 2021 7:46 am
                                  apart from that model g-010s-a. there is another one with more configuration options. and another thing would the Carlitoxxpro firmware be compatible with the g-010s-a model?
                                  jangdong
                                  Sun Mar 28, 2021 9:35 am
                                  You can use developer tools on web browser to see hidden password
                                  obenturk
                                  Sun Mar 28, 2021 4:28 pm
                                  Petronas,
                                  I can connect internal uart pins with the help of external 3v3 power source.
                                  Following information started to flow and it is continuously tranmitting same info. what can be the next step ?
                                  how can I enter command mode?
                                  Thanks.
                                  RTL9601C
                                  PRELOADER Bismarck 3.5
                                  II: SVN:5077c, Build_date:19110109, Toolkit:rsdk-1.5.6-5281-EB-2.6.30-0.9.30.3-131105
                                  II: Disable OCP Timeout Monitor
                                  II: Disable LX Timeout Monitor
                                  II: Enable Triple Synchronizer
                                  II:cg_cpu_clk_init done
                                  II:cg_spif_clk_init done
                                  II: CPU 112MHz (450/4/0), MEM 400MHz, LX 200MHz, SPIF 25MHz
                                  II: NOR SPI-F... C22018/MMIO16-1/ModeC done
                                  AK: DRAM AUTO CALIBRATION
                                  AK: ZQ Calibration Passed
                                  AK: MR0: 0x00100b62
                                  AK: MR1: 0x00110040
                                  AK: MR2: 0x00120000
                                  AK: MR3: 0x00130000
                                  AK: clear dwdqor
                                  AK: bit:00, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001510)=0x51e0f00
                                  AK: bit:01, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001514)=0x51e0f00
                                  AK: bit:02, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001518)=0x51e0f00
                                  AK: bit:03, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb800151c)=0x51e0f00
                                  AK: bit:04, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001520)=0x61e0f00
                                  AK: bit:05, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001524)=0x51e0f00
                                  AK: bit:06, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001528)=0x61e0f00
                                  AK: bit:07, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb800152c)=0x51e0f00
                                  AK: bit:08, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001530)=0x51e0f00
                                  AK: bit:09, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001534)=0x61e0f00
                                  AK: bit:10, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001538)=0x51e0f00
                                  AK: bit:11, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb800153c)=0x61e0f00
                                  AK: bit:12, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001540)=0x61e0f00
                                  AK: bit:13, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001544)=0x51e0f00
                                  AK: bit:14, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001548)=0x61e0f00
                                  AK: bit:15, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb800154c)=0x51e0f00
                                  AK: bit:16, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001550)=0x1e0f00
                                  AK: bit:17, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001554)=0x1e0f00
                                  AK: bit:18, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001558)=0x1e0f00
                                  AK: bit:19, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(29):  (0xb800155c)=0x1c0e00
                                  AK: bit:20, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001560)=0x1e0f00
                                  AK: bit:21, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001564)=0x1e0f00
                                  AK: bit:22, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001568)=0x1e0f00
                                  AK: bit:23, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(29):  (0xb800156c)=0x1c0e00
                                  AK: bit:24, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001570)=0x1e0f00
                                  AK: bit:25, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001574)=0x1e0f00
                                  AK: bit:26, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001578)=0x1e0f00
                                  AK: bit:27, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb800157c)=0x1e0f00
                                  AK: bit:28, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001580)=0x1e0f00
                                  AK: bit:29, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb8001584)=0x1e0f00
                                  AK: bit:30, max_w_s(00), max_w_len(19), max_r_s(00), max_r_len(31):  (0xb8001588)=0x1e0f00
                                  AK: bit:31, max_w_s(00), max_w_len(17), max_r_s(00), max_r_len(31):  (0xb800158c)=0x1e0f00
                                  AK: DQ enable delay sync with DQ delay tap.
                                      0xb80015D0=0x05050505, 0xb80015D4=0x05060506, 0xb80015D8=0x06050605, 0xb80015DC=0x05060506
                                  AK: Disable read after write function
                                  AK: dram auto calibrtaion is done
                                  II: MEM_PROBE_OK
                                  II: MEM_XLAT_OK
                                  II: MEM_TO_REG_OK
                                  II: MEM_CAL_OK
                                  II: Change Stack from 0x9f007ff8 to 0x80efffe0
                                  II: Decompressing U-Boot (0x81c00000 <- 0x9fc19a20)... (186 KB <- 71 KB) OK
                                  II: Starting U-boot...
                                  U-Boot 2011.12.NA (Nov 01 2019 - 09:40:17) 359-b87
                                  Board: RTL9601C / CPU:112MHz / LX:200MHx / MEM:400MHz / Type:DDR2
                                  DRAM: 32 MB
                                  SPI-F: C22018/MMIO16-1/ModeX 1x16 MB (plr_flash_info @ 81c2d9a8)
                                  Loading 8192B env. variables from offset 0x40000
                                  Loading 8192B env. variables from offset 0x42000
                                  Loaded 8192B env. variables from offset 0x40000
                                  Net:   LUNA GMAC
                                  Erasing SPI flash...Erasing 8192 B from 00042000... .100% ~ 00043fff/8192 B
                                  Writing to SPI flash...Writing 8192 B from 81adbe78 to 00042000... ...............................................................100% ~ 00043fff/8192 B
                                  Writing 1 B from 81adde80 to 00040004... 100% ~ 00040004/1 B
                                  done
                                  Valid environment: 2
                                  Hit any key to stop autoboot:  0
                                  ## Booting kernel from Legacy Image at 94080000 ...
                                     Image Name:   Linux Kernel Image
                                     Created:      2019-11-01   9:44:09 UTC
                                     Image Type:   MIPS Linux Kernel Image (lzma compressed)
                                     Data Size:    1017779 Bytes = 993.9 KB
                                     Load Address: 80000000
                                     Entry Point:  80000000
                                     Verifying Checksum ... OK
                                     Uncompressing Kernel Image ... OK
                                  Starting kernel ...
                                  Linux version 2.6.30.9 (builder@9026d26c1d06) (gcc version 4.4.6 (Realtek RSDK-1.5.6p2) ) #1 Fri Nov 1 09:41:28 UTC 2019 [luna SDK V1.9.0]
                                  RTL9602C PLL
                                  CPU revision is: 0000dc02
                                  Determined physical RAM map:
                                   memory: 01700000 @ 00000000 (usable)
                                   memory: 00700000 @ 01800000 (usable)
                                  II: Kernel command line modified: mtdparts=rtk_spi_nor_mtd ->   mtdparts=physmap-flash
                                  Zone PFN ranges:
                                    Normal   0x00000000 -> 0x00001f00
                                  Movable zone start PFN for each node
                                  early_node_map[2] active PFN ranges
                                      0: 0x00000000 -> 0x00001700
                                      0: 0x00001800 -> 0x00001f00
                                  Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 7618
                                  Kernel command line: console=ttyS0,115200   mtdparts=physmap-flash:256K(boot),8K(env),8K(env2),240K(config),3M(k0)ro,4800K(r0)ro,3M(k1),4800K(r1),64K(hw),64K(sec),4K@0ro,4K@0ro,3M@512K(linux),4800K@3584K(rootfs) root=31:5
                                  root_dev_setup line 180 root: 31:5
                                  icache: 64kB/32B, dcache: 32kB/32B, scache: 0kB/0B
                                  NR_IRQS:128
                                  PID hash table entries: 128 (order: 7, 512 bytes)
                                  console [ttyS0] enabled
                                  Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
                                  Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
                                  Memory: 19816k/30720k available (2624k kernel code, 10904k reserved, 637k data, 104k init, 0k highmem)
                                  Calibrating delay loop... 112.23 BogoMIPS (lpj=561152)
                                  Mount-cache hash table entries: 512
                                  IMEM section size = 0x1050
                                  net_namespace: 528 bytes
                                  NET: Registered protocol family 16
                                  bio: create slab <bio-0> at 0
                                  Sangoma WANPIPE Router v1.1 (c) 1995-2000 Sangoma Technologies Inc.
                                  NET: Registered protocol family 2
                                  IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
                                  TCP established hash table entries: 1024 (order: 1, 8192 bytes)
                                  TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
                                  TCP: Hash tables configured (established 1024 bind 1024)
                                  TCP reno registered
                                  CONFIG_LUNA_SOC_GPIO: gpio_init()
                                  luna_capabilities_init
                                  ************ Watchdog Setting ****************
                                  WDT_E=0, (1-enable, 0-disable)
                                  LX(MHz)=200
                                  WDT_CLK_SC=0
                                  PH1_TO=0
                                  PH2_TO=0
                                  WDT_RESET_MODE=0
                                  >>>>> arch/rlx/bsp_rtl8686/board.c, 178: set GPIO_6 high to enable RTL8290
                                  >>>>> arch/rlx/bsp_rtl8686/board.c, 182: set GPIO_35/LOS_O/RSVD1 as output low
                                  >>>>> arch/rlx/bsp_rtl8686/board.c, 186: set GPIO_40/TX_FAULT as output low
                                  >>>>> arch/rlx/bsp_rtl8686/board.c, 190: set GPIO_41/DIS_TX as input
                                  luna_clocksource_init: High Resolution Timer Clock = 4000000, BSP_HT_DIVISOR=50
                                  netlog: listening on port 4660
                                  squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                  JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
                                  msgmni has been set to 38
                                  alg: No test for stdrng (krng)
                                  io scheduler cfq registered (default)
                                  Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
                                  serial8250: ttyS0 at MMIO 0x0 (irq = 49) is a 16550A
                                  8686 Ethernet driver v0.0.1 (Feb 17, 2012)[Dual Band Disable]
                                  TX[256,64,64,64,64] , RX[256,128,128,32,32,32]
                                  eth0 (): not using net_device_ops yet
                                  eth0: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
                                  eth0.2 (): not using net_device_ops yet
                                  eth0.2: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
                                  eth0.3 (): not using net_device_ops yet
                                  eth0.3: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
                                  nas0 (): not using net_device_ops yet
                                  nas0: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
                                  pon0 (): not using net_device_ops yet
                                  pon0: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
                                  RTL8686 GMAC Probing..
                                  first entry: 0, portmask 127, rx: 802896a8
                                  Init RTK Driver Module....OK
                                  Init RTK Core Dev Module....OK
                                   rtdrv_init !!! for netfilter
                                  pkt_redirect_init complete
                                  interrupt broadcaster init ok!
                                  u32 classifier
                                  nf_conntrack version 0.5.0 (480 buckets, 1920 max)
                                  ip_tables: (C) 2000-2006 Netfilter Core Team
                                  TCP cubic registered
                                  NET: Registered protocol family 17
                                  Bridge firewalling registered
                                  Ebtables v2.0 registered
                                  802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
                                  All bugs added by David S. Miller <davem@redhat.com>
                                  Realtek GPIO Driver for Flash Reload Default
                                  physmap platform flash device: 0b000000 at 14000000
                                  Luna SPI NOR FLASH G3 driver-MXIC/C22018/MMIO16-1 <5>master->name physmap-flash
                                  cmd: cmdlinepart
                                  14 cmdlinepart partitions found on MTD device physmap-flash
                                  Creating 14 MTD partitions on "physmap-flash":
                                  0x000000000000-0x000000040000 : "boot"
                                  0x000000040000-0x000000042000 : "env"
                                  0x000000042000-0x000000044000 : "env2"
                                  0x000000044000-0x000000080000 : "config"
                                  0x000000080000-0x000000380000 : "k0"
                                  0x000000380000-0x000000830000 : "r0"
                                  0x000000830000-0x000000b30000 : "k1"
                                  0x000000b30000-0x000000fe0000 : "r1"
                                  0x000000fe0000-0x000000ff0000 : "hw"
                                  0x000000ff0000-0x000001000000 : "sec"
                                  0x000000000000-0x000000001000 : "Partition_010"
                                  0x000000000000-0x000000001000 : "Partition_011"
                                  0x000000080000-0x000000380000 : "linux"
                                  0x000000380000-0x000000830000 : "rootfs"
                                  VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
                                  Freeing unused kernel memory: 104k freed
                                  init started: BusyBox v1.12.4 (2019-11-01 09:41:51 UTC)
                                  starting pid 28, tty '': '/etc/init.d/rcS'
                                  ubnthal: module license 'Proprietary' taints kernel.
                                  Disabling lock debugging due to kernel taint
                                  SN: UBNT29f5ddd1
                                  Region: 255
                                  ------ [-b]Bootup_config ------
                                  set_msgqueue_max_size:180> set msgqidds.msg_qbytes=20600 OK
                                  Wait counter for configd initialize 'MsgQ' and 'Shm': 95
                                  Fetch mib data (type 8) from program code.
                                  Fetch mib data (type 2) from program code.
                                  Pre-fetch mib data from program default done.
                                  Checking input file [/var/config/lastgood_hs.xml].
                                  [OK] Valid config file!
                                  ***** config_parser(): dfname=[/etc/config_default_hs.xml](0) loaded *****
                                  ***** config_parser(): fname=[/var/config/lastgood_hs.xml](0) loaded *****
                                  [xml_INFO]: Load HS configuration success.
                                  Checking input file [/var/config/lastgood.xml].
                                  ***** config_parser(): dfname=[/etc/config_default.xml](0) loaded *****
                                  ***** config_parser(): fname=[/var/config/lastgood.xml](0) loaded *****
                                  [xml_INFO]: Load CS configuration success.
                                  omci platform attached!
                                  register_gpon_evt_state: register gpon event state Successfully !
                                  xml_mib_update():...
                                  MIB chain descriptors checking (total 7) ok !
                                     CMD: /bin/ifconfig eth0 hw ether 18e829f5ddd1
                                     CMD: /bin/brctl addbr br0
                                  ------ [-u cs]Update cs setting ------
                                  ------ [-u hs]Update hs setting ------
                                     CMD: /bin/ifconfig br0 hw ether 18e829f5ddd1
                                     CMD: /bin/brctl stp br0 off
                                     CMD: /bin/brctl setfd br0 1
                                     CMD: /bin/brctl setageing br0 7200
                                     CMD: /bin/brctl addif br0 eth0
                                  device eth0 entered promiscuous mode
                                     CMD: /bin/ifconfig br0 192.168.1.1 netmask 255.255.255.0 mtu 1500
                                     CMD: /bin/ifconfig eth0 up
                                  re8670_open 3336
                                  br0: port 1(eth0) entering learning state
                                  [xml_INFO]: Update cs configuration success.
                                  [xml_INFO]: Update hs configuration success.
                                  #!/bin/sh
                                  ### rc2
                                  mkdir /var/tmp
                                  mkdir /var/log
                                  mkdir /var/run
                                  mkdir /var/lock
                                  mkdir /var/config
                                  mkdir /var/hw
                                  mkdir /var/ct
                                  mkdir /var/ct/tmp
                                          exit 3
                                      else
                                          # exit if fails
                                              exit 4
                                          fi
                                      fi
                                  fi
                                          fi
                                  fi
                                  ### rc3
                                  fi
                                  configd&
                                  ### rc10
                                  ### rc21
                                  fi
                                          fi
                                          fi
                                  fi
                                  ### rc22
                                  startup
                                  ### rc32
                                  sfpapp &
                                  ### rc33
                                  /etc/runomci.sh
                                  /bin/pondetect &
                                  ### rc34
                                  ### rc60
                                  ### rc61
                                  ### rc63
                                  obenturk
                                  Sun Mar 28, 2021 4:41 pm
                                  Ok I can enter command mode.
                                  Could you please provide info how can I backup firmware and upload which firmware?
                                  Thanks.
                                  Hit any key to stop autoboot:  0  0
                                  9601C#           help
                                  ?               - alias for 'help'
                                  base            - print or set address offset
                                  bdinfo          - print Board Info structure
                                  boot            - boot default, i.e., run 'bootcmd'
                                  bootd           - boot default, i.e., run 'bootcmd'
                                  bootm           - boot application image from memory
                                  bootp           - boot image via network using BOOTP/TFTP protocol
                                  btg             - bus traffic generator sub-system
                                  cmp             - memory compare
                                  coninfo         - print console devices and information
                                  cp              - memory copy
                                  crc32           - checksum calculation
                                  echo            - echo args to console
                                  editenv         - edit environment variable
                                  env             - environment handling commands
                                  exit            - exit script
                                  false           - do nothing, unsuccessfully
                                  go              - start application at address 'addr'
                                  help            - print command description/usage
                                  iminfo          - print header information for application image
                                  imxtract        - extract a part of a multi-image
                                  itest           - return true/false on integer compare
                                  loadb           - load binary file over serial line (kermit mode)
                                  loads           - load S-Record file over serial line
                                  loady           - load binary file over serial line (ymodem mode)
                                  loop            - infinite loop on address range
                                  md              - memory display
                                  mdram_test      - mdram_test   - do DRAM test.
                                  mflash_test     - mflash_test   - do flash test.
                                  mm              - memory modify (auto-incrementing address)
                                  mtest           - simple RAM read/write test
                                  mw              - memory write (fill)
                                  nm              - memory modify (constant address)
                                  ping            - send ICMP ECHO_REQUEST to network host
                                  printenv        - print environment variables
                                  reset           - Perform RESET of the CPU
                                  reset_all       - Perform whole chip RESET of the CPU
                                  reset_sw        - Perform software RESET
                                  run             - run commands in an environment variable
                                  saveenv         - save environment variables to persistent storage
                                  setenv          - set environment variables
                                  sf              - SPI flash sub-system
                                  showvar         - print local hushshell variables
                                  sleep           - delay execution for some time
                                  source          - run script from memory
                                  test            - minimal test like /bin/sh
                                  tftpboot        - boot image via network using TFTP protocol
                                  tftpsrv         - act as a TFTP server and boot the first received file
                                  true            - do nothing, successfully
                                  upimgtar        - update kernel and rootfs by tar format on luna platform
                                  upimgtarh       - update kernel and rootfs by UBNT format on luna platform
                                  upvmimg         - update kernel and rootfs by vmimg format on luna platform
                                  urescue         - start TFTP server and wait for firmware
                                  version         - print monitor, compiler and linker version
                                  xf              - xmodem to flash
                                  obenturk
                                  Sun Mar 28, 2021 6:37 pm
                                  printenv result
                                  How can I dump flash ?
                                  9601C# printenv
                                  b0=setenv bootargs ${bootargs_base} ${mtdparts0} ${rst2dfl_flg}; bootm ${img0_kernel}
                                  b1=setenv bootargs ${bootargs_base} ${mtdparts1} ${rst2dfl_flg}; bootm ${img1_kernel}
                                  baudrate=115200
                                  boot_by_commit=if itest.s ${sw_commit} == 0;then run set_act0;run b0;else run set_act1;run b1;fi
                                  boot_by_tryactive=if itest.s ${sw_tryactive} == 0;then setenv sw_tryactive 2;setenv sw_active 0;saveenv;run en_wdt;run b0;else setenv sw_tryactive 2;setenv sw_active 1;saveenv;run en_wdt;run b1;fi
                                  bootargs_base=console=ttyS0,115200
                                  bootcmd=if itest.s ${sw_tryactive} == 2; then run boot_by_commit;else run boot_by_tryactive;fi
                                  bootcount=1
                                  bootdelay=0
                                  bootlimit=10
                                  en_wdt=mw b8003268 e7c00000
                                  erase_cfgfs=sf erase ${fl_cfgfs} +${fl_cfgfs_sz}
                                  erase_env=sf erase ${fl_env} +${fl_env_sz};sf erase ${fl_env2} +${fl_env_sz}
                                  ethact=LUNA GMAC
                                  ethaddr=18:E8:29:F5:DD:D1
                                  fileaddr=80000000
                                  filesize=31B038
                                  fl_boot_sz=40000
                                  fl_cfgfs=44000
                                  fl_cfgfs_sz=3c000
                                  fl_env=40000
                                  fl_env2=42000
                                  fl_env_sz=2000
                                  fl_hw=fe0000
                                  fl_hw_sz=10000
                                  fl_kernel1=80000
                                  fl_kernel1_sz=300000
                                  fl_kernel2=830000
                                  fl_kernel2_sz=300000
                                  fl_rootfs1=380000
                                  fl_rootfs1_sz=4b0000
                                  fl_rootfs2=b30000
                                  fl_rootfs2_sz=4b0000
                                  fl_sec=ff0000
                                  fl_sec_sz=10000
                                  ftfp_base=80000000
                                  fx1000_init=mw bb000084 00000048
                                  img0_kernel=94080000
                                  img1_kernel=94830000
                                  ipaddr=192.168.1.20
                                  mtdparts0=mtdparts=rtk_spi_nor_mtd:256K(boot),8K(env),8K(env2),240K(config),3M(k0)ro,4800K(r0)ro,3M(k1),4800K(r1),64K(hw),64K(sec),4K@0ro,4K@0ro,3M@512K(linux),4800K@3584K(rootfs) root=31:5
                                  mtdparts1=mtdparts=rtk_spi_nor_mtd:256K(boot),8K(env),8K(env2),240K(config),3M(k0),4800K(r0),3M(k1)ro,4800K(r1)ro,64K(hw),64K(sec),4K@0ro,4K@0ro,3M@8384K(linux),4800K@11456K(rootfs) root=31:7
                                  netmask=255.255.255.0
                                  serverip=192.168.1.19
                                  set_act0=if itest.s ${sw_active} != 0;then setenv sw_active 0;saveenv;fi
                                  set_act1=if itest.s ${sw_active} != 1;then setenv sw_active 1;saveenv;fi
                                  sgmii_init=mw bb000084 00000044
                                  stderr=serial
                                  stdin=serial
                                  stdout=serial
                                  sw_active=0
                                  sw_commit=0
                                  sw_crc0=67b567f2
                                  sw_crc1=67b567f2
                                  sw_tryactive=2
                                  sw_valid0=1
                                  sw_version0=v4.1.0.359-b87.191101.0940
                                  sw_version1=v4.1.0.359-b87.191101.0940
                                  upb=tftpboot ${ftfp_base} plr.img && crc32 ${fileaddr} ${filesize} && sf erase 0 +${fl_boot_sz} && sf write ${fileaddr} 0 ${filesize}
                                  upgrade=tftpboot 80000000 UF-INSTANT.img && upimgtarh ${fileaddr} ${filesize}
                                  upk=tftpboot ${ftfp_base} uImage && crc32 ${fileaddr} ${filesize} && sf erase ${fl_kernel1} +${fl_kernel1_sz} && sf write ${fileaddr} ${fl_kernel1} ${filesize}
                                  upk1=tftpboot ${ftfp_base} uImage && crc32 ${fileaddr} ${filesize} && sf erase ${fl_kernel2} +${fl_kernel2_sz} && sf write ${fileaddr} ${fl_kernel2} ${filesize}
                                  upr=tftpboot ${ftfp_base} rootfs && crc32 ${fileaddr} ${filesize} && sf erase ${fl_rootfs1} +${fl_rootfs1_sz} && sf write ${fileaddr} ${fl_rootfs1} ${filesize}
                                  upr1=tftpboot ${ftfp_base} rootfs && crc32 ${fileaddr} ${filesize} && sf erase ${fl_rootfs2} +${fl_rootfs2_sz} && sf write ${fileaddr} ${fl_rootfs2} ${filesize}
                                  upt=tftpboot 80000000 img.tar && upimgtar ${fileaddr} ${filesize}
                                  upv=tftp 80000000 vm.img;upvmimg ${fileaddr}
                                  yu=loady 80000000 && cp.b 80000000 81000000 ${filesize} && cmp.b 80000000 81000000 ${filesize} && sf erase 0 ${filesize} && sf write 80000000 0 ${filesize}
                                  Environment size: 3364/8187 bytes
                                  obenturk
                                  Sat Apr 03, 2021 11:57 pm
                                  I think I succeed to dump the flash.
                                  I uploaded it to github https://github.com/obenturk/ufinstant
                                  9601C# sf probe 0
                                  9601C# sf read 0x80000000 0x0 0x1000000
                                  9601C# md.b 0x80000000 0x1000000
                                  80000000: 0b f0 55 ac 00 00 00 00 00 00 00 00 00 00 00 00    ..U.............
                                  80000010: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
                                  80000020: 30 33 34 33 03 00 05 00 9f c1 99 40 9f c1 99 c0    0343.......@....
                                  graphine
                                  Mon Apr 05, 2021 1:25 am
                                  I got a ma5671a.
                                  Does blue latch means sc/upc and green latch sc/apc?
                                  Also, is it possible to do pppoe authentification on the module (to not work as l2 bridge).
                                  For those who have it, what temperatures are you seeing?
                                  galvesribeiro
                                  Re: Usage GPON module SFP in Spain
                                  Mon Apr 12, 2021 4:40 am
                                  Hey! I'm from Brazil as well. Trying to do the same here in São Paulo to remove "Vivo Fibra" ISP modem. Have you able to buy any of those SFPs?
                                  jjeziorny
                                  Sat Apr 17, 2021 11:04 pm
                                  obentutk,
                                  Did you have any success with the UF-Instant?
                                  I'm trying to get one to with with DIGI Mobile in Spain, managed to get to o5 as well but can't get pppoe interface to come up.
                                  One think I'm not sure is the GPON password. The one I extracted from existing ONT is 14 HEX characters, however the SFP requires 20 chars input. I tried padding with 0s before and after the 14 chars I have but no result. I can extract ASCII from the ONT as well but it has some chars that are not printable, might need to see why my OS is not printing them.
                                  jjeziorny
                                  Tue Apr 20, 2021 1:21 am
                                  so I got a bit further.
                                  copy /proc/ubnthal to /var/config/ubnthal
                                  # mkdir /var/config/ubnthal
                                  # cp /proc/ubnthal/* /var/config/ubnthal
                                  edit the files in /var/config/ubnthal with the settings from your ONT then mount /proc/ubnthal with the new directory
                                  # mount --bind /var/config/ubnthal /proc/ubnthal
                                  kill lldpResponder, it will respawn with the new MAC
                                  not sure if it's necessary, but might as well
                                  # killall lldpResponder
                                  at this point you can kill omci_app and it will grab the new values. It will initiate the downstram and upstream flows, but unfortunately it dies during the MIB_CreateSnapshot
                                  # killall -9 omci_app
                                  # omci_app -f off 0 -m disable -d off -d 2
                                  # diag
                                  RTK.0> gpon show ds-flow
                                       GPON ONU MAC D/S Flow Status
                                  Flow ID | GEM Port | Type | Multicast | AES
                                       64 |       10 | OMCI |           |
                                  RTK.0> gpon show us-flow
                                      GPON ONU MAC U/S Flow Status
                                  Flow ID | GEM Port | Type | TCont
                                       64 |       10 | OMCI |    16
                                  MIB_CreateSnapshot: TableId 94 [mib_base.c:1505 MIB_CreateSnapshot]
                                  MIB_CreateSnapshot: TableId 95 [mib_base.c:1505 MIB_CreateSnapshot]
                                  MIB_CreateSnapshot: TableId 96 [mib_base.c:1505 MIB_CreateSnapshot]
                                  MIB_CreateSnapshot: TableId 97 [mib_base.c:1505 MIB_CreateSnapshot]
                                  MIB_CreateSnapshot: TableId 98 [mib_base.c:1505 MIB_CreateSnapshot]
                                  MIB_CreateSnapshot: TableId 99 [mib_base.c:1505 MIB_CreateSnapshot]
                                  MIB_CreateSnapshot: TableId 100 [mib_base.c:1505 MIB_CreateSnapshot]
                                  MIB_CreateSnapshot: TableId 101 [mib_base.c:1505 MIB_CreateSnapshot]
                                  MIB_CreateSnapshot: TableId 102 [mib_base.c:1505 MIB_CreateSnapshot]
                                  Assertion Failed:size == MIB_GetAttrSize(tableIndex, attrIndex), file MIB/src/mib_base.c, line 1492, pid 593
                                  Aborted
                                  galvesribeiro
                                  Tue Apr 20, 2021 7:49 am
                                  Hello folks!
                                  Today I have Ubiquiti UF-Loco and a TP-Link XZ000-G3 ONUs working on my ISP replacing their modem.
                                  Got a couple of the G-010S-A.
                                  I'm trying to make them work with a UDM-Pro with my ISP in Brazil (Vivo - a Telefonica company) of which sends internet on VLan 10.
                                  The ISP uses a Huawei OLT. I'm able to change the SLID, which is what the ISP uses to authenticate the device and the devices get to status O5 pretty quickly. However, it doesn't go far from that.
                                  For whatever reason it seems that the OLT is sending the VLan commands thru the OMCI but it isn't working.
                                  I've tried to update the firmware to the latest we have on GitHub https://github.com/hwti/G-010S-A without making any difference.
                                  The funny thing is that I didn't had to do anything on both UF-Loco and TP-Link to make them work besides set the SLID.
                                  I've attached the OMCI logs and I would appreciate if anyone can shed a light on what is going on with my case.
                                  Thanks!
                                  galvesribeiro
                                  Tue Apr 20, 2021 7:52 am
                                  # diag
                                       64 |       10 | OMCI |           |
                                       64 |       10 | OMCI |    16
                                  Aborted
                                  I wish I could get UF-Instant so I could drop this mess of G-010S-A :)
                                  espetoet
                                  Tue Apr 20, 2021 10:09 pm
                                  Hello my Nokia G-010S-A arrived and I even put in my rb 4011 I made the manual settings you told me. I put my UN serial from the isp with the command below
                                  ritool set MfrID ALCL
                                  ritool set G984Serial FBC64B1C
                                  but after I restarted SFP it stopped responding to pinging ip 192.168.1.10. what could I have done wrong. and has some way to reset because I can't access the ssh interface or the web
                                  Looking at the GITHUB manual there was no such command (ritool dump) and logically he didn't even record the settings I made, but I can't access it anymore.
                                  galvesribeiro
                                  Tue Apr 20, 2021 10:51 pm
                                  Which GitHub manual are you referring to?
                                  espetoet
                                  Tue Apr 20, 2021 11:17 pm
                                  this link https://github.com/hwti/G-010S-A
                                  galvesribeiro
                                  Tue Apr 20, 2021 11:19 pm
                                  Ah ok, the firmware repo. Got it, thanks!
                                  I'm still trying to get it to work with Vivo here in São Paulo... I hope someone will see me question above and from the logs are able to tell me what else am I missing...
                                  espetoet
                                  Tue Apr 20, 2021 11:21 pm
                                  I am from Brazil. you would have the firmware dump of this model to send me
                                  espetoet
                                  Tue Apr 20, 2021 11:22 pm
                                  I have a more accurate EPROM recorder than the full dump
                                  galvesribeiro
                                  Tue Apr 20, 2021 11:49 pm
                                  I don't have an EEPROM recorder with me... If there is a way to dump things from within SSH, I can send it to you.
                                  I've only updated the image1 with the `3FE47111BFHB32` firmware, made it boot from it and then have the SLID set to the one from the original Vivo modem.
                                  I'm able to get O5 status, which means the authentication worked with the ISP OLT but unfortunately there is not much after that.
                                  I'm attaching the logs here in case you find anything interesting.
                                  espetoet
                                  Wed Apr 21, 2021 6:43 pm
                                  Now mine stopped responding, nor does it detect in the mikrotik anymore.
                                  jjeziorny
                                  Mon Apr 26, 2021 6:50 pm
                                  So, today I got a couple of technicolor AFM0002tim SFPs I bought on eBay and I'm glad to inform these worked just fine with my provider in Spain.
                                  These where pretty cheap, so a good deal really.
                                  The only tricky part is that the busybox on these devices don't come with vi or any other editor as far as I could tell, and they don't have scp either, so I had to find another method to edit the config.
                                  Once you have network access to them from your computer (could do from the router itself also I assume, and could be done with sed also, but I was a bit lazy)
                                  ssh admin@192.168.2.1 "cat /var/config/lastgood.xml" > lastgood.xml
                                  ssh admin@192.168.2.1 "cat /var/config/lastgood_hs.xml" > lastgood_hs.xml
                                  edit the files locally, the upload them again
                                  cat lastgood.xml | ssh sfp00 -T "cat > /var/config/lastgood.xml"
                                  cat lastgood_hs.xml | ssh sfp00 -T "cat > /var/config/lastgood_hs.xml"
                                  Now reboot the SFP and it should work. You can confirm by checking the SN being used by the omci_app command
                                  # ps | grep omci
                                    344 admin    18100 S    omci_app -s <your SN will be here> -f off -m disable -d off -t
                                    582 admin    18100 S    omci_app -s <your SN will be here> -f off -m disable -d off -t
                                    583 admin    18100 S    omci_app -s <your SN will be here> -f off -m disable -d off -t
                                    845 admin    18100 S    omci_app -s <your SN will be here> -f off -m disable -d off -t
                                    846 admin    18100 S    omci_app -s <your SN will be here> -f off -m disable -d off -t
                                    847 admin    18100 S    omci_app -s <your SN will be here> -f off -m disable -d off -t
                                    956 admin    18100 S    omci_app -s <your SN will be here> -f off -m disable -d off -t
                                  And checking you have flows on gpon
                                  # diag
                                        0 |     2047 |  ETH |         * |
                                        1 |      278 |  ETH |           |   *
                                        2 |      279 |  ETH |           |   *
                                        3 |      280 |  ETH |           |   *
                                       32 |       10 | OMCI |           |   *
                                  At this point, it's the routers job (configure VLAN, PPPoE, etc)
                                  Markg23
                                  Mon Apr 26, 2021 8:26 pm
                                  Hello jjeziorny, Wich provider do you have in Spain movi star, voda fone, oran ge, jazz tel? I have jazz tel, Will it work? Do you have to did any unlock on the device before it works? I also have read that the module could get quite hot, even 90 º Celsius, Have you measured the temp?
                                  I own a Huawe MA5671A, and afeter unlocked it works quite well on RB4011.
                                  I also own a Sercomm FGS202, but I'am still testing it...
                                  Plan to buy another modules for test, but its quite hard to found anything cheap on ebay or ali express... Currently I'm searching for info about Hisense XG-PON1-ONU-N1 LTF7221-BH+ but can't find anything yet.
                                  jjeziorny
                                  Tue Apr 27, 2021 11:23 am
                                  Hi Mark
                                  My provider is DIGI Mobile, they use the Moviestar network. Did't have to unlock anything on this device, just update the two config files mentioned with the required info. In my case just the SN was required really, as it seems DIGI is not using PLOAM authentication at all.
                                  Yes, the device feels a bit hot, but haven't measured the temperature yet. I can touch with my finger and not get burned at least.
                                  Was looking for a SNMP interface to monitor it's temperature but it does not have one from the looks of it.
                                  I also bought a DS xPON ONU STICK (Universal GPON/EPON GEPON ONU) on ebay, but this one costed 120 USD whilst the techicolor I paid 33,50 for 2 units, including postage.
                                  Will compare things and make a decision which ones to keep using.
                                  Still have the Ubiquiti UF-Instant which didn't work due to all the locks UB did in this unit, might return it or might keep and try to hack the firmware to unlock it. They all seem to have the same apps in the firmware, so I think it would be possible.
                                  JJ
                                  jjeziorny
                                  Tue Apr 27, 2021 11:30 am
                                  Just found the temperature, I guess I can build a manual monitor for it
                                  # cat /proc/optical_info
                                  Temperature: 60.351563C
                                  Voltage: 3.212100V
                                  Tx Power: 2.577266dBm
                                  Rx Power: -18.210231dBm
                                  Bias: 10.866000mA
                                  jjeziorny
                                  Tue Apr 27, 2021 6:24 pm
                                  Not exactly what you are looking for but for the time being... a cheap solution (30euro) and it talks to NaranjaES
                                  Do you have a TP-LINK TX-6610 work fine with Orange Spain? We also want this solution but with the SFP of Mikrotik or other manufacturers.
                                  When you installed this ONU, Did you have to talk witn Orange Spain for change? or you only, change the IdONT and all oK ¿?¿?
                                  It synchronizes fast and works well on the optical level. SN and password was taken from my Livebox Fibra (Arcadyan PRV3399B-B-LT) Call to support was not needed.
                                  When I switched to TX-6610 existing routing was still in place. New DHCP renewal/request is currently not possible. It fails the DHCP Option 90 - Authentication.
                                  I found plenty of information on French forums about their Option 90 format (fti/xxxxxx) but not much of information on Spanish forums.
                                  Chinese marketplace website - aliexpress, lists many affordable SFP modules from diffrent manufacturers. I am going to order 2 SFP modules and try to read/write the SN location. Will report back.
                                  Hi crc666,
                                  How did you get the info out of the PRV3399B-B-LT? I assume you did via UART?
                                  Just got one installed and when opened it noticed three possible UART ports (AJ4, J5 and JC3), can you confirm which one you used and the pinout for it please?
                                  JJ
                                  jjeziorny
                                  Tue Apr 27, 2021 7:19 pm
                                  Here's picture of the PRV3399B-B-LT.
                                  Anyone has any info about the JTAG port to be for accessing this device or a another method to extract ONT information???
                                  galvesribeiro
                                  Wed Apr 28, 2021 6:20 pm
                                  @jjeziorny / @obenturk How did you got to the UF-Instant terminal?
                                  I've built this tool https://github.com/Unifi-Tools/UFiber.Configurator that allow full configuration of UF-Loco and UF-Instant.
                                  I just received an UF-Instant and I'm looking to adapt the tool to allow the same changes on UF-Instant but I first would need a terminal.
                                  I've read on previous posts here that the IP is 192.168.1.1 and ubnt/ubnt for password. I've put it on my USW-24P switch and have set my machine to an IP on that same network but I'm unable to telnet or even ping it.
                                  I can see some of the SFP information on the switch without the power and signal regardless of the fiber being connected or not...
                                  Anyone has a clue? I think I can get it to work with my tool if I have a terminal...
                                  Thank you!
                                  galvesribeiro
                                  Wed Apr 28, 2021 9:08 pm
                                  Aha! I've got a TP-Link media converter and plugged the UF-Instant to it and now I can access the telnet! Yay!
                                  Now need to fins how enable SSH on it... Anyone got that successfully?
                                  galvesribeiro
                                  Wed Apr 28, 2021 9:44 pm
                                  Progress... SSH enabled with `/bin/dropbear -R &`...
                                  Now need to find which files need to be patched in order to make the tool to work correctly and change SLID, MAC, Serial, etc...
                                  ToTheCLI
                                  Thu Apr 29, 2021 1:14 am
                                  Good Work
                                  Do you think it is possible to patch the UFiber Instant and change SN so that it survives a reboot?
                                  galvesribeiro
                                  Thu Apr 29, 2021 2:47 am
                                  Good Work
                                  Yes, it will be possible. I just need to find out how to make the partition writeable... The patch somehow is working, but I need to test into the SFP module to be 100% sure.
                                  I was hoping others who had more time/experience tinkering with this module would be ale to tell me that :/
                                  In other words, the tool is already updated. Now all we need is to be able to write back...
                                  Any help would be appreciated!
                                  PS: To permanently enable SSH you need to:
                                  flash set SERVICE_SSH_ENABLE 1
                                  and just reboot.
                                  ToTheCLI
                                  Thu Apr 29, 2021 3:09 am
                                  That is what I feared as there is no way to do that by SSH that I know of.
                                  galvesribeiro
                                  Thu Apr 29, 2021 3:28 am
                                  Im not sure, because other data is persistent...
                                  galvesribeiro
                                  Thu Apr 29, 2021 5:29 am
                                  Okey... Got O5 but can't get PPoE to pass thru it...
                                  One thing I note is that after a few seconds after connected the fiber on UF-Instant, looks like omci_app dies for whatever reason, and then some watchdog reboot the SFP module a few seconds later.
                                  Not sure it is related to the lack of the serial being set or something else...
                                  jjeziorny
                                  Thu Apr 29, 2021 11:27 am
                                  @galvesribeiro,
                                  That's the main issue with the UF-Instant. UB has locked it down by customizing omci_app so that, from what I noticed, if you tinker with the SN the device will reboot after a little while. So I think the best approach here would be to modify the firmware on the device and/or just copy a different omci_app into it and try to run that instead.
                                  jjeziorny
                                  Thu Apr 29, 2021 12:32 pm
                                  So, I've made some progress with connecting to Republica Movil.
                                  First of all, didn't really need to get JTAG access to the Livebox+ router to extract the info (but I managed that also, so will post details after).
                                  The PLOAM_PASSWD and GPON_SN are both visible on the web interface itself. After putting these on the technicolor SFP I got some progress. I can see flows are created, but I still can't get a response to DHCP thorugh the VLAN 832 (same used by Orange).
                                  The thing I did notice is that the flows don't have multicast and AES marked in any of them, the other connection (DIGI Mobile) does have it. So not sure if negotiation is not complete (maybe missing LOID user/pass) or this SFP is not compatible with the Orange network or perhaps simply because they don't use AES (find it hard to believe).
                                  Republica Movil
                                        0 |      156 |  ETH |           |
                                        1 |      157 |  ETH |           |
                                        2 |      158 |  ETH |           |
                                        3 |     4095 |  ETH |           |
                                       32 |       68 | OMCI |           |
                                  DIGI Mobile
                                        1 |      278 |  ETH |           |   *
                                        2 |      279 |  ETH |           |   *
                                        3 |      280 |  ETH |           |   *
                                  Anyone got GPON SFP working with Orange or any provider that uses the Orange network? If so, did you need anything else other than PLOAM_PASSWD and GPON_SN ?
                                  ToTheCLI
                                  Thu Apr 29, 2021 12:55 pm
                                  @galvesribeiro,
                                  Can that be done by SSH?
                                  jjeziorny
                                  Thu Apr 29, 2021 2:22 pm
                                  @galvesribeiro,
                                  Yes it could, I don't have the UF-instant plugged right now but I remember seeing a command to flash an image to the device inside it (will check again later).
                                  Nevertheless, one could upload a different omci_app via ssh to a writeable folder (/var/config is one iirc) then manually run it.
                                  I do plan to run more tests to try and get the UF-instant working in the future. But right now am focusing on the Technicolor ones.
                                  jjeziorny
                                  Thu Apr 29, 2021 2:43 pm
                                  Republica Movil
                                        0 |      156 |  ETH |           |
                                        1 |      157 |  ETH |           |
                                        2 |      158 |  ETH |           |
                                        3 |     4095 |  ETH |           |
                                       32 |       68 | OMCI |           |
                                  DIGI Mobile
                                        1 |      278 |  ETH |           |   *
                                        2 |      279 |  ETH |           |   *
                                        3 |      280 |  ETH |           |   *
                                  So, from reading previous posts Orange does require to match the software version on the ONT.
                                  I got the version from the router (AR_LBFIBRA_sp-00.03.05.221), however cannot find the right VARIABLE to set it.
                                  Post #210 shows a command used on that device to set it, but I don't have that command on mine
                                  fw_setenv image0_version AR_LBFIBRA_sp-00.03.04.091
                                  fw_setenv image1_version AR_LBFIBRA_sp-00.03.04.095
                                  So basically I need the equivalent of image0_version in the lastgood.xml or lastgood_hs.xml file.
                                  galvesribeiro
                                  Thu Apr 29, 2021 5:26 pm
                                  Hummm so the restart is related to the change on the SN? I don't know, not sure to be honest.
                                  The thing is that even if I leave it untouched, with its original value, it does reboot when I plug the fiber. If I leave the fiber disconnected it never reboots.
                                  The only thing related to the firmware that I've saw is this:
                                  # ubnt-syscfg help
                                  Usage: help <cmd>
                                  	<cmd>:
                                  		help
                                  		adminPassword
                                  		cpuUsage
                                  		firmware
                                  		gpon
                                  		lan
                                  		laserInfo
                                  		memInfo
                                  		onuName
                                  		provisioningFlag
                                  		reboot
                                  		restoreDefault
                                  		saveConfig
                                  		service
                                  		uptime
                                  # ubnt-syscfg firmware
                                  Usage: firmware <option>
                                           option: fullString
                                                   hash [fw]
                                                   releaseTime [fw]
                                                   string
                                                   version [fw]
                                           fw:     optional firmware string
                                  Theoretically all my ISP cares is the SLID/PLOAM password and I see the omci_app starting with -p and the password.
                                  Even without changing the MAC (which would reflect on the SN), once I connect the fiber, it would crash all the instances of omci_app and after a bit reboot the module.
                                  I've see this repo https://github.com/obenturk/ufinstant from @obenturk but I'm not sure how far he got on getting a firmware to be loadable on the module.
                                  On a side note, I got one of the G-010S-A and wasn't able to make it work either (https://github.com/hwti/G-010S-A/issues/6).
                                  I'm inclined to get one of the CarlitoxxPro modules even it being so more expensive than others, it looks like the more customizable one. However, I'm worried if I will end up with the same situation of the G-010S-A...
                                  jjeziorny
                                  Fri Apr 30, 2021 3:17 pm
                                  So, my battle to get the technicolor to work with Republica movil (orange lowcost) continues.
                                  I believe the missing piece for me is the Software Version, and I found a command to update it (/bin/nv). I also found a command to show me the MIB table from the omci, and after some testing I relaised the maximum lenght for sw_ver is 13 chars, but the one extracted from my router is longer.
                                  Setting software version
                                  # nv setenv sw_version1 AR_LBFIBRA_sp-00.03.05.221
                                  # nv setenv sw_version0 AR_LBFIBRA_sp-00.03.05.221
                                  # reboot
                                  Checking applied version, showoing only the first 13 charaters are applied.
                                  # omcicli mib get SWImage
                                  # XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                                  SWImage
                                  SWImage
                                  EntityID: 0x00
                                  Active: 0
                                  Committed: 0
                                  Valid: 1
                                  Version: AR_LBFIBRA_sp
                                  ProductCode:
                                  ImageHash: 0x00000000000000000000000000000000
                                  SWImage
                                  EntityID: 0x01
                                  Active: 1
                                  Committed: 1
                                  Valid: 1
                                  ProductCode:
                                  Perhaps wat I need is to set the version 00.03.05.221 and then the ProductCode AR_LBFIBRA_sp, but I haven' t been able to find a variable to use with nv setenv that would update the ProductCode
                                  I start trying with omcicli mib set now, but so far no luck
                                  # omcicli mib
                                  Usage: omcicli mib [cmd]
                                    create    : create MIB ME
                                      {classId, entityId, "value of all SBC attributes"}
                                    delete    : delete MIB ME
                                      {classId, entityId}
                                    set       : set MIB ME attribute
                                      {classId, entityId, attrName, attrValue}
                                    get       : get all MIB or any single ME class
                                      [all | classId | tableName[, entityId]]
                                    getcurr   : get PM MIB current accumulations
                                      {classId | tableName[, entityId]}
                                    getalm    : get all alarm or any single ME class
                                      [classId[, entityId]]
                                    getattr   : get specefic attribute for any single ME class
                                      [classId, entityId, attributeId]
                                    reset     : trigger MIB reset
                                  # omcicli mib set {SWImage,00,ProductCode,AR_LBFIBRA_sp}
                                  ### The above returns the help from the command
                                  ToTheCLI
                                  Sun May 02, 2021 10:08 pm
                                  # ubnt-syscfg help
                                  Usage: help <cmd>
                                  	<cmd>:
                                  		help
                                  		adminPassword
                                  		cpuUsage
                                  		firmware
                                  		gpon
                                  		lan
                                  		laserInfo
                                  		memInfo
                                  		onuName
                                  		provisioningFlag
                                  		reboot
                                  		restoreDefault
                                  		saveConfig
                                  		service
                                  		uptime
                                           option: fullString
                                                   hash [fw]
                                                   releaseTime [fw]
                                                   string
                                                   version [fw]
                                  Any progress on the UFiber Instant?
                                  Immick
                                  Fri May 07, 2021 8:09 am
                                  ODI said bridge mode is not allowed by ZTE's warrant. Sorry.
                                  Well, I bought DFP-34G-2C2 from here and its web interface allows to choose between router and bridge:
                                  But the problem is the SN is not editable in web interface:
                                  Though it can be change via telnet commands:
                                  flash set GPON_SN XXXXXXXXXXXX
                                  flash default cs
                                  reboot
                                  Where XXXXXXXXXXXX - 4 letter of vendor (in my case it's HWTC as I have Huawei HG8120H) + last 8 digits of its actual serial number.
                                  Anyway I cannot get O5 (it stucks on "O3 Initial Status") for unknown reasons. I definitely know that my ISP makes authentication only by SN but it doesn't work :(
                                  Any ideas please?
                                  Thank you!
                                  Markg23
                                  Fri May 07, 2021 9:41 pm
                                  # reboot
                                  Hi jjeziorny. I have a MA5671A configured for Jazz tel Spain (Orange network) and I need to config 3 values extracted from my original ONT: MAC, Serial Number and ONT ID. I believe you don't need to set sw_version.
                                  Today I received my AFM0002TIM and my plan is to configure it for Jazz tel, as a backup of the MA5671A.
                                  fabio1999ita
                                  Sun May 09, 2021 6:02 pm
                                  Hi, I have problems with my ONT Alcatel-Lucent O-010S-P, I can't even connect by SSH. I have tried 192.168.1.10, among others, but there is no ping.
                                  Does anyone know this model, and if it is compatible?
                                  hugomon
                                  My model ONT G-010S-P responds to pings in Mikrotik. Please check my steps.
                                  1. Assign sfp1 as WAN interface (it will remove sfp1 from the bridge)
                                  2. G-010S-P and other models will not expose ethernet interface unless fiber cable is connected (link-ok, rate 1Gbps)
                                  [admin@MikroTik] > interface ethernet monitor sfp1
                                                      status: link-ok
                                            auto-negotiation: done
                                                        rate: 1Gbps
                                                 full-duplex: yes
                                             tx-flow-control: no
                                             rx-flow-control: no
                                                 advertising:
                                    link-partner-advertising:
                                          sfp-module-present: yes
                                                 sfp-rx-loss: no
                                                    sfp-type: SFP-or-SFP+
                                          sfp-connector-type: SC
                                         sfp-link-length-9um: 20000m
                                             sfp-vendor-name: ALCATELLUCENT
                                  3. Add IP address to the sfp1 interface
                                  [admin@MikroTik] > ip address add address=192.168.1.15/24 interface=sfp1
                                  4. [admin@MikroTik] > ping 192.168.1.10
                                  SEQ HOST SIZE TTL TIME STATUS
                                  0 192.168.1.10 56 64 0ms
                                  1 192.168.1.10 56 64 0ms
                                  2 192.168.1.10 56 64 1ms
                                  3 192.168.1.10 56 64 3ms
                                  5. telnet or ssh
                                  [admin@MikroTik] > system telnet 192.168.1.10
                                  [admin@MikroTik] > system ssh user=ONTUSER address=192.168.1.10
                                  do you know if it is possible whit MA5671A stick?
                                  espetoet
                                  Thu May 13, 2021 2:52 pm
                                  Hello my sfp G-010S-A has stopped working. well there I bought a CarlitoxxPro CPGOS03-0490 v2.0. however or plug it into the SFP input it is not identified, but it appears ok link and present module, I am using a RB 4011, I made the necessary settings to access the interface via ip 192.168.1.1 but it does not access, in ping this is giving a timout. well I took my tplink media converter mc220l to see if it is not defective in gbic. identified and accessed normal by ip. will be that the module CarlitoxxPro is not compatible with mikrotik. another thing my mikrotik is not defective being that I have other gbic and identifies normal.
                                  espetoet
                                  Thu May 13, 2021 3:06 pm
                                  hello could you give me your whatsapp or email, to answer a question. I'm from Brazil too
                                  jjeziorny
                                  Fri May 14, 2021 10:30 am
                                  # reboot
                                  HI mark23
                                  Good to know, might have to switch from Republica movil to Jazztel as I'm still stuck at o5 and no DHCP IP responses after 3 weeks trying all I can.
                                  I've been reading a lot on a french forum where they say Orange (at least there) uses DHCP Authentication (Option 90) as well as needing to tag prioity 6 on DHCP packets.
                                  The prio6 can be achieved on the Ubiquiti router using a modified dhclient3 and egress-qos config on the interface.
                                  However for the Auth you need a password which apparently users in France got it by calling Orange and they send a letter with the so called fti/ password, there's eve a script and online site where you can confirm the fti/xxxxxx password to a hex string (there's a specific lenght) to use as DHCP Option 90.
                                  I contacted Republica movil asking for this password, at first they said the password I need is in the sticker (ie. the wifi and router admin password), and after a while explaining that's not what I need and the angent saying she had no idea about other password she tried to escalate and eventually said they don't have the password I'm looking for. So, they kind of admited there is a password, but it' s not something they give to users as they don't even have it. I pushed for more escalations but so far no luck. (still have tinny bit of hope)
                                  Other than they giving me the password, I have UART access to the original router and am trying to find it somewhere in the router, but no luck yet.
                                  The strange part thou, is that if I put the livebox router in ONT mode I can then get a DHCIP IP on the Ubiquiti on VLAN 832 withouth any special configuration on DHCP or on egres prio.
                                  So either the ONT in the router is rewriting packets with this values or these are not required at all and the reason I don't get a DHCP response is some incompatibility with this SFP in the Orange network.
                                  Do let us know if you have any luck with AFM0002TIM in the Jazztel network please. In the meantime I ordered yet another SFP from aliexpress and I also have one here which I bricked and need to try and recover (post for help comming after this)
                                  jjeziorny
                                  Fri May 14, 2021 10:33 am
                                  Need to help trying to get UART access to an SFP I locked myself out (missing " in the ip address session of lastgood.xml )
                                  Obentuk, perhaps you can help as you got access to the ubiquiti which I believe could be similar pintout as it uses the same chip.
                                  So, anyone has ideas on which pins to use to get UART access to the following SFP, or how to identify the required pins?
                                  galvesribeiro
                                  Fri May 21, 2021 1:40 am
                                  Folks, had anyone had a poor customer support experience with @CarlitoxxPro ?
                                  They where fast to put the order and collect the money, but it is about a week that I received their GPON stick and I'm trying to contact them for support and they just don't reply emails...
                                  Tried to reach them by Telegram and I only get this:
                                  🔧⚙ CarlitoxxPro 🛰🧰, [19 May 2021 16:38:20]:
                                  Hi Gutenberg, thanks for contacting us.
                                  Currently, we are experiencing some delay in our responses due to the high demand for the product, please keep wait a bit for the answer of our engineer. He will answer your emails asap.
                                  thanks for your patience...
                                  I can't see how the demand for buying a product would affect its customer support. Unless ofc we can't rely on it and it is the same person doing everything...
                                  HellMind
                                  Fri May 21, 2021 11:04 pm
                                  HellMind
                                  Sat May 22, 2021 12:24 am
                                  Spanish:
                                  Debes poner el router en modo bridge o en este modelo es monousuario si no recuerdo mal.
                                  Tienes que configurar en el mikrotik tanto la vlan2 (voz) como la vlan6 (datos), en la vlan2 levantas un dhcp y en la 6 el cliente ppoe.
                                  Para que la voz pueda pasar debes realizar unas cuantas configuraciones en el router. Te dejo un ejemplo https://www.alferez.es/configurar-hgu-m ... ar-voz-ip/ (si los administradores lo ven oportuno eliminen el enlace)
                                  English:
                                  You must put the router in bridge mode or in this model is monousuario if I remember correctly.
                                  You have to configure in the mikrotik both the vlan2 (voice) and the vlan6 (data), in the vlan2 you raise a dhcp and in the 6 the client ppoe.
                                  In order for the voice to pass you must make a few configurations on the router. I leave you an example https://www.alferez.es/configurar-hgu-m ... ar-voz-ip/ (if the administrators see fit, delete the link)
                                  Me gustaria saber si esto funciona con un HG8245U, no logro connect un softphone, telecom argentina
                                  JeanPierre
                                  Sun May 23, 2021 6:29 pm
                                  Another module based on the T&W design (TW2362H-CDEL)
                                  https://www.twsz.com/en/
                                  These were quite popular as Zisa OP-151S until supplies ran out. I'm curious what software version these modules have.
                                  espetoet
                                  Mon May 31, 2021 4:00 pm
                                  I bought one too and their support is time consuming. I still haven't managed to make mine work on my isp.
                                  pmgcosta
                                  Wed Jun 02, 2021 4:05 pm
                                  I have change my crappy router with an Huawei ONT HG8012h
                                  For that i have change my serialnumber + password
                                  Serial 5054494E91194A08 (PTIN91194A08)
                                  Password: " " ascii / "20" in hex
                                  Configured WAN using RJ45 to SFP 1gb with VLAN 12 (settings for FTTH Meo Provider in Portugal) and everthing works.
                                  But a want to replace the ONT HG8012h with an AFM0002TIM SFP,
                                  I have change se serialnumber and password using this
                                  lastgood.xml
                                  <Value Name="GPON_PLOAM_PASSWD" Value=" "/>
                                  lastgood_hs.xml
                                  <Value Name="GPON_SN" Value="PTIN91194A08"/>
                                  Uploading the changes
                                  cat lastgood.xml | ssh admin@192.168.2.1 -T "cat > /var/config/lastgood.xml"
                                  cat lastgood_hs.xml | ssh admin@192.168.2.1 -T "cat > /var/config/lastgood_hs.xml"
                                  And now i have this on SFP
                                  # diag
                                  RTK.0> gpon get onu-state
                                  ONU state: Operation State(O5)
                                  RTK.0>
                                        0 |     4095 |  ETH |           |
                                       32 |       45 | OMCI |           |
                                  RTK.0>
                                  But i don't have wan ip from dhcp (vlan 12) any sugestion ?
                                  Thats my current config:
                                  lastgood.xml
                                   <Config Name="ROOT">
                                   <Dir Name="MIB_TABLE">
                                    <Value Name="WAN_MODE" Value="7"/>
                                    <Value Name="LAN_IP_ADDR" Value="192.168.2.1"/>
                                    <Value Name="LAN_SUBNET" Value="255.255.255.0"/>
                                    <Value Name="LAN_ENABLE_IP2" Value="0"/>
                                    <Value Name="LAN_IP_ADDR2" Value="192.168.100.1"/>
                                    <Value Name="LAN_SUBNET2" Value="255.255.255.0"/>
                                    <Value Name="LAN_RIP" Value="0"/>
                                    <Value Name="LAN_AUTOSEARCH" Value="0"/>
                                    <Value Name="DNS_MODE" Value="0"/>
                                    <Value Name="DNS1" Value="0.0.0.0"/>
                                    <Value Name="DNS2" Value="0.0.0.0"/>
                                    <Value Name="DNS3" Value="0.0.0.0"/>
                                    <Value Name="ADSL_MODE" Value="83"/>
                                    <Value Name="ADSL_OLR" Value="3"/>
                                    <Value Name="USER_NAME" Value="user"/>
                                    <Value Name="USER_PASSWORD" Value="user"/>
                                    <Value Name="DEVICE_TYPE" Value="0"/>
                                    <Value Name="INIT_LINE" Value="1"/>
                                    <Value Name="INIT_SCRIPT" Value="1"/>
                                    <Value Name="SNMP_SYS_NAME" Value="PON Bridge"/>
                                    <Value Name="VC_AUTOSEARCH" Value="0"/>
                                    <Value Name="BR_AGEING_TIME" Value="7200"/>
                                    <Value Name="BR_STP_ENABLED" Value="0"/>
                                    <Value Name="MP_MODE" Value="4"/>
                                    <Value Name="SPC_ENABLED" Value="0"/>
                                    <Value Name="SPC_IPTYPE" Value="0"/>
                                    <Value Name="MULTI_LINGUAL_STATE" Value="101"/>
                                    <Value Name="UPNP" Value="0"/>
                                    <Value Name="UPNP_EXT_ITF" Value="255"/>
                                    <Value Name="SYSLOG_LOG_LEVEL" Value="0"/>
                                    <Value Name="SYSLOG_DISPLAY_LEVEL" Value="0"/>
                                    <Value Name="SUSER_NAME" Value="admin"/>
                                    <Value Name="SUSER_PASSWORD" Value="system"/>
                                    <Value Name="ADSL_TONE" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="DIRECT_BRIDGE_MODE" Value="1"/>
                                    <Value Name="ADSL_HIGH_INP" Value="0"/>
                                    <Value Name="SYSLOG" Value="0"/>
                                    <Value Name="MAXLOGLEN" Value="16384"/>
                                    <Value Name="ADSLDBG" Value="0"/>
                                    <Value Name="MIB_ETH_MAC_CTRL" Value="0"/>
                                    <Value Name="MIB_WLAN_MAC_CTRL" Value="0"/>
                                    <Value Name="LOID" Value="user"/>
                                    <Value Name="LOID_PASSWD" Value="password"/>
                                    <Value Name="OMCI_DBGLVL" Value="0"/>
                                    <Value Name="OMCI_LOGFILE" Value="0"/>
                                    <Value Name="OMCI_PORT_TYPE" Value="1"/>
                                    <Value Name="DUAL_MGMT_MODE" Value="0"/>
                                    <Value Name="OMCI_CUSTOM_BDP" Value="0"/>
                                    <Value Name="OMCI_CUSTOM_RDP" Value="0"/>
                                    <Value Name="OMCI_CUSTOM_MCAST" Value="0"/>
                                    <Value Name="OMCI_CUSTOM_ME" Value="0"/>
                                    <Value Name="RTK_IGMP_DBGEN" Value="0"/>
                                    <Value Name="RTK_IGMP_DROPV1" Value="1"/>
                                    <Value Name="RTK_IGMP_VIDTYPE" Value="0"/>
                                    <Value Name="RTK_IGMP_TAGDECISION" Value="0"/>
                                    <Value Name="VLAN_CFG_TYPE" Value="0"/>
                                    <Value Name="VLAN_MANU_MODE" Value="0"/>
                                    <Value Name="VLAN_MANU_TAG_VID" Value="65535"/>
                                    <Value Name="VLAN_MANU_TAG_PRI" Value="255"/>
                                    <Value Name="DHCP_PORT_FILTER" Value="0"/>
                                    <Value Name="NTP_EXT_ITF" Value="65535"/>
                                    <Value Name="RTK_DEVID_MANUFACTURER" Value=""/>
                                    <Value Name="RTK_DEVID_OUI" Value=""/>
                                    <Value Name="RTK_DEVID_PRODUCTCLASS" Value=""/>
                                    <Value Name="RTK_DEVINFO_SPECVER" Value=""/>
                                    <Value Name="RTK_DEVINFO_SWVER" Value=""/>
                                    <Value Name="RTK_DEVINFO_HWVER" Value=""/>
                                    <Value Name="DEVICE_NAME" Value="RTK_GW"/>
                                   </Dir>
                                   <Dir Name="ATM_VC_TBL"> <!--index=0-->
                                    <Value Name="ifIndex" Value="130816"/>
                                    <Value Name="VPI" Value="5"/>
                                    <Value Name="QoS" Value="0"/>
                                    <Value Name="VCI" Value="35"/>
                                    <Value Name="PCR" Value="6000"/>
                                    <Value Name="SCR" Value="0"/>
                                    <Value Name="MBS" Value="0"/>
                                    <Value Name="CDVT" Value="0"/>
                                    <Value Name="Encap" Value="1"/>
                                    <Value Name="NAPT" Value="1"/>
                                    <Value Name="ChannelMode" Value="0"/>
                                    <Value Name="BridgeType" Value="0"/>
                                    <Value Name="pppUser" Value=""/>
                                    <Value Name="pppPasswd" Value=""/>
                                    <Value Name="pppAuth" Value="0"/>
                                    <Value Name="pppACName" Value=""/>
                                    <Value Name="pppServiceName" Value=""/>
                                    <Value Name="pppConnectType" Value="0"/>
                                    <Value Name="pppIdleTime" Value="0"/>
                                    <Value Name="enableIGMP" Value="0"/>
                                    <Value Name="ChannelAddrType" Value="0"/>
                                    <Value Name="RIP" Value="0"/>
                                    <Value Name="LocalIPAddr" Value="0.0.0.0"/>
                                    <Value Name="RemoteIPAddr" Value="0.0.0.0"/>
                                    <Value Name="DefaultGW" Value="0"/>
                                    <Value Name="MTU" Value="1500"/>
                                    <Value Name="ChannelStatus" Value="1"/>
                                    <Value Name="SubnetMask" Value="0.0.0.0"/>
                                    <Value Name="Ipunnum" Value="0"/>
                                    <Value Name="DNSMode" Value="0"/>
                                    <Value Name="DNSV4IPAddr1" Value="0.0.0.0"/>
                                    <Value Name="DNSV4IPAddr2" Value="0.0.0.0"/>
                                    <Value Name="vlan" Value="0"/>
                                    <Value Name="vid" Value="0"/>
                                    <Value Name="vprio" Value="0"/>
                                    <Value Name="vpass" Value="0"/>
                                    <Value Name="itfGroup" Value="0"/>
                                    <Value Name="cpePppIfIndex" Value="0"/>
                                    <Value Name="cpeIpIndex" Value="0"/>
                                    <Value Name="WanName" Value=""/>
                                    <Value Name="applicationtype" Value="4"/>
                                    <Value Name="MacAddr" Value="ac4afe7b2c7b"/>
                                   </Dir>
                                   <Dir Name="SW_PORT_TBL"> <!--index=0-->
                                    <Value Name="PVCInterface" Value="65535"/>
                                    <Value Name="InterfaceGroup" Value="0"/>
                                    <Value Name="PVID" Value="0"/>
                                    <Value Name="LinkMode" Value="4"/>
                                    <Value Name="VLAN on LAN Enabled" Value="0"/>
                                    <Value Name="VLAN on LAN InterfaceGroup" Value="0"/>
                                    <Value Name="VID" Value="0"/>
                                   </Dir>
                                   <Dir Name="SW_PORT_TBL"> <!--index=1-->
                                    <Value Name="PVID" Value="1"/>
                                   </Dir>
                                   <Dir Name="MAC_BASE_DHCP_TBL">
                                   </Dir>
                                   <Dir Name="AUTO_PVC_SEARCH_TBL"> <!--index=0-->
                                    <Value Name="VPI" Value="0"/>
                                   </Dir>
                                   <Dir Name="AUTO_PVC_SEARCH_TBL"> <!--index=1-->
                                    <Value Name="VPI" Value="8"/>
                                   </Dir>
                                   <Dir Name="AUTO_PVC_SEARCH_TBL"> <!--index=2-->
                                    <Value Name="VCI" Value="43"/>
                                   </Dir>
                                   <Dir Name="AUTO_PVC_SEARCH_TBL"> <!--index=3-->
                                    <Value Name="VCI" Value="51"/>
                                   </Dir>
                                   <Dir Name="AUTO_PVC_SEARCH_TBL"> <!--index=4-->
                                    <Value Name="VCI" Value="59"/>
                                   </Dir>
                                   <Dir Name="AUTO_PVC_SEARCH_TBL"> <!--index=5-->
                                   </Dir>
                                   <Dir Name="AUTO_PVC_SEARCH_TBL"> <!--index=6-->
                                   </Dir>
                                   <Dir Name="AUTO_PVC_SEARCH_TBL"> <!--index=7-->
                                   </Dir>
                                   <Dir Name="PPPOE_SESSION_TBL">
                                   </Dir>
                                   <Dir Name="RIP_TBL">
                                   </Dir>
                                   <Dir Name="DHCP_RESERVED_IPADDR_TBL">
                                   </Dir>
                                   <Dir Name="EPON_LLID_TBL">
                                   </Dir>
                                  </Config>
                                  lastgood_hs.xml
                                   <Dir Name="HW_MIB_TABLE">
                                    <Value Name="SUPER_NAME" Value="adsl"/>
                                    <Value Name="SUPER_PASSWORD" Value="realtek"/>
                                    <Value Name="ELAN_MAC_ADDR" Value="ac4afe7b2c78"/>
                                    <Value Name="WLAN_MAC_ADDR" Value="00e04c076802"/>
                                    <Value Name="WAN_PHY_PORT" Value="4"/>
                                    <Value Name="HW_RF_TYPE" Value="7"/>
                                    <Value Name="HW_WLAN0_TX_POWER_CCK_A" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="HW_WLAN0_TX_POWER_CCK_B" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="HW_WLAN0_TX_POWER_HT40_1S_A" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="HW_WLAN0_TX_POWER_HT40_1S_B" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="HW_WLAN0_TX_POWER_DIFF_HT40_2S" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="HW_WLAN0_TX_POWER_DIFF_HT20" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="HW_WLAN0_TX_POWER_DIFF_OFDM" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="HW_WLAN0_11N_TSSI1" Value="0"/>
                                    <Value Name="HW_WLAN0_11N_TSSI2" Value="0"/>
                                    <Value Name="HW_WLAN0_11N_THER" Value="0"/>
                                    <Value Name="HW_WLAN0_11N_THER_2" Value="0"/>
                                    <Value Name="HW_WLAN0_11N_PA_TYPE" Value="0"/>
                                    <Value Name="HW_WLAN0_REG_DOMAIN" Value="1"/>
                                    <Value Name="HW_WLAN0_11N_TRSWITCH" Value="0"/>
                                    <Value Name="HW_WLAN0_11N_TRSWPAPE_C9" Value="0"/>
                                    <Value Name="HW_WLAN0_11N_TRSWPAPE_CC" Value="0"/>
                                    <Value Name="HW_ANT_DIVERSITY" Value="0"/>
                                    <Value Name="HW_TX_ANT" Value="0"/>
                                    <Value Name="HW_CS_THRESHOLD" Value="11"/>
                                    <Value Name="HW_CCA_MODE" Value="1"/>
                                    <Value Name="HW_PHY_TYPE" Value="0"/>
                                    <Value Name="HW_WLAN_LED_TYPE" Value="7"/>
                                    <Value Name="BYTE" Value="255"/>
                                    <Value Name="WORD" Value="65535"/>
                                    <Value Name="DWORD" Value="4294967295"/>
                                    <Value Name="INT1" Value="2147483647"/>
                                    <Value Name="INT2" Value="-2147483648"/>
                                    <Value Name="WIFI_SUPPORT" Value="0"/>
                                    <Value Name="HW_SERIAL_NO" Value="000000000002"/>
                                    <Value Name="HW_FON_KEYWORD" Value="63,62,68,4a,75,3c,65,cd,7b,75,e5,2d,a9,80,72,8c,97,fc,bd,9b,37,51,d9,e3,82,92,68,a1,07,ae,a0,b5"/>
                                    <Value Name="HW_WLAN0_11N_XCAP" Value="0"/>
                                    <Value Name="HW_WLAN0_11N_XCAP_2" Value="0"/>
                                    <Value Name="HW_WLAN0_11N_TARGET_PWR" Value="0"/>
                                    <Value Name="LAN_SDS_MODE" Value="1"/>
                                    <Value Name="PON_MODE" Value="1"/>
                                    <Value Name="PON_LED_SPEC" Value="0"/>
                                    <Value Name="CALI_RESULT_0" Value="03,04,01,00,00,00,02,00,00,00,00,03,0d,00,14,c8,00,00,00,00,54,65,63,68,6e,69,63,6f,6c,6f,72,20,20,20,20,20,00,00,00,00,41,46,4d,30,30,30,32,20,20,20,20,20,20,20,20,20,31,2e,30,20,05,1e,00,98,00,1a,00,00,55,37,4c,37,42,30,30,34,34,38,34,20,20,20,20,20,31,37,31,31,30,37,20,20,68,f0,08,10,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="CALI_RESULT_1" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="CALI_RESULT_2" Value="5f,00,f6,00,5a,00,fb,00,8c,a0,75,30,88,b8,79,18,c3,50,00,00,9c,40,00,00,9b,83,1f,07,7b,87,27,10,07,cb,00,0d,06,31,00,10,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,3f,80,00,00,00,00,00,00,01,00,00,00,01,00,00,00,01,00,00,00,01,00,00,00,00,00,00,a1,29,65,71,49,00,00,00,00,00,00,ff,ff,ff,ff,02,00,10,40,00,ff,10,40,ab,ba,00,00,00,ba,a3,d0,c5,01"/>
                                    <Value Name="CALI_RESULT_3" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,ff,c0,00,00,ff,c0,00,00"/>
                                    <Value Name="CALI_RESULT_4" Value="ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,6a,bb,5c,60,fc,13,00,00,8c,02,1a,40,ff,00,00,00,8c,07,00,35,c0,ff,fa,fa,00,52,fc,00,00,00,09,a0,00,00,0b,24,19,00,9a,00,de,0a,00,00,00,00,00,43,00,ff,ff,ff,ff,00,00,00,00,c0,01,61,c1,49,00,a0,fe,e9,01,a6,00,00,17,e6,00,00,00,00,05,a9,f9,3d,42,00,00,00,04,c0,02,c4,14,e0,1c,00,cd,00,ce,80,00,00,00,00,00,00,00,00"/>
                                    <Value Name="CALI_RESULT_5" Value="31,00,31,00,31,40,31,80,31,80,31,c0,32,00,32,00,32,40,32,80,32,80,32,c0,33,00,33,00,33,40,33,80,33,80,33,c0,34,00,34,00,34,40,34,80,34,80,34,c0,35,00,35,00,35,40,36,80,37,80,38,80,39,c0,3a,c0,3c,00,3d,00,3e,40,3f,40,40,80,41,80,42,80,43,c0,44,c0,46,00,47,00,48,40,4a,80,4d,40,50,40,53,00,55,c0,58,80,5b,40,5e,00,60,c0,63,80,66,40,69,00,6c,00,6e,c0,71,80,74,40,77,00,79,c0,7c,80,7f,40"/>
                                    <Value Name="CALI_RESULT_6" Value="01,40,01,80,01,80,01,c0,02,00,02,40,02,80,02,c0,03,00,03,00,03,40,03,80,03,c0,04,00,04,40,04,80,04,80,04,c0,05,00,05,40,05,80,05,c0,05,c0,06,00,06,40,06,80,06,c0,07,80,08,80,09,80,0a,40,0b,40,0c,00,0d,00,0d,c0,0e,c0,0f,c0,10,80,11,80,12,40,13,40,14,00,15,00,16,00,16,c0,17,c0,18,80,19,80,1a,40,1b,40,1c,40,1d,00,1e,00,1e,c0,1f,c0,20,80,21,80,22,80,23,40,24,40,25,00,26,00,26,c0,27,c0"/>
                                    <Value Name="CALI_RESULT_7" Value="8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,8c,7c,03,7f,66,82,c9,86,2c,89,8f,8c,f2,90,55,93,b8,95,0f,96,66,97,bd,99,14,9a,6b,9b,c2,9d,19,9e,70,9f,c7,a1,1e,a2,75,a3,cc,a5,23,a6,7a,a7,d1,a9,28,aa,7f,ab,d6,ad,2d,ae,84,af,db,b1,32,b2,89,b3,b0"/>
                                    <Value Name="CALI_RESULT_8" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,10"/>
                                    <Value Name="CALI_RESULT_9" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                   </Dir>
                                  </Config>
                                  nunomflora
                                  Tue Jun 15, 2021 2:02 pm
                                  lastgood.xml
                                  lastgood_hs.xml
                                  # diag
                                  RTK.0>
                                        0 |     4095 |  ETH |           |
                                       32 |       45 | OMCI |           |
                                  RTK.0>
                                  lastgood.xml
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                  </Config>
                                  lastgood_hs.xml
                                   </Dir>
                                  </Config>
                                  You my friend have the same problem that me and 5 more that I know, O5 but no internet from MEO, this has been something that we have been playing for some time now and didn't come up with any solution you can find me in telegram (@r4cc00n) if you whant and join our group :)
                                  pmgcosta
                                  Tue Jul 06, 2021 4:15 am
                                  i can't find that group
                                  lastgood.xml
                                  lastgood_hs.xml
                                  # diag
                                  RTK.0>
                                        0 |     4095 |  ETH |           |
                                       32 |       45 | OMCI |           |
                                  RTK.0>
                                  lastgood.xml
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                  </Config>
                                  lastgood_hs.xml
                                   </Dir>
                                  </Config>
                                  jjeziorny
                                  Wed Jul 14, 2021 8:17 pm
                                  Been a while since I lasted posted updated on my attempts.
                                  After 3 months trying to get my Ubiquity to work with Orange/Jazztel fibre, I finally got it working!
                                  The issue was SFP compatibility, even thou the Tecnicolor did got to O5 with the fibre, it never got response on packets (DHCP leaves the router but no replies). I always though this was realted to DHCP authentication I've read on french forums that Orange uses. But today I got a G-010S-A configured and it worked fine.
                                  Perhaps there something can be changed on the SFP config itself to make it work with Orange, there are a lot of config options on the two config files which could potentially make it compatible. If anyone spots anything which could potentially work on the bellow files let me know.
                                  lastgood_hs.xml
                                    <Value Name="ELAN_MAC_ADDR" Value="946ab05e0433"/>
                                    <Value Name="GPON_SN" Value="ARLTXXXXXXX"/>
                                    <Value Name="CALI_RESULT_0" Value="03,04,01,00,00,00,02,00,00,00,00,03,0d,00,14,c8,00,00,00,00,54,65,63,68,6e,69,63,6f,6c,6f,72,20,20,20,20,20,00,00,00,00,41,46,4d,30,30,30,32,20,20,20,20,20,20,20,20,20,31,2e,30,20,05,1e,00,98,00,1a,00,00,55,48,50,39,38,30,30,32,38,30,32,20,20,20,20,20,31,39,30,38,30,36,20,20,68,f0,08,1c,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="CALI_RESULT_2" Value="5f,00,f6,00,5a,00,fb,00,8c,a0,75,30,88,b8,79,18,c3,50,00,00,9c,40,00,00,9b,83,1f,07,7b,87,27,10,07,cb,00,0d,06,31,00,10,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,3f,80,00,00,00,00,00,00,01,00,00,00,01,00,00,00,01,00,00,00,01,00,00,00,00,00,00,a1,24,e9,7b,49,00,02,00,00,00,00,ff,ff,ff,ff,02,00,00,40,00,ff,00,40,ab,ba,00,00,00,ba,a3,d0,c5,01"/>
                                    <Value Name="CALI_RESULT_4" Value="ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,6a,bb,5c,60,fc,13,00,00,8c,02,1a,40,ff,00,00,00,ac,0f,80,3b,40,ff,fa,fa,00,52,fc,00,00,00,09,a0,00,00,0b,24,19,00,9a,00,de,0a,00,00,00,00,00,43,00,ff,ff,ff,ff,00,00,00,00,c0,01,61,c1,49,00,a0,fe,e9,01,a6,00,00,0c,ee,00,00,00,00,04,e9,f9,87,42,00,00,00,08,e0,05,5c,15,90,1f,10,ce,00,d0,00,00,00,00,00,00,00,00,00"/>
                                    <Value Name="CALI_RESULT_5" Value="37,c0,37,c0,38,00,38,00,38,40,38,80,38,80,38,c0,38,c0,39,00,39,00,39,40,39,80,39,80,39,c0,39,c0,3a,00,3a,00,3a,40,3a,40,3a,80,3a,c0,3a,c0,3b,00,3b,00,3b,40,3b,40,3b,80,3b,c0,3e,00,40,80,43,00,45,80,48,00,4a,80,4d,00,4f,80,51,c0,54,40,56,c0,59,40,5b,c0,5e,40,60,c0,64,00,67,80,6b,00,6d,c0,70,00,72,80,74,c0,77,00,79,40,7b,80,7d,c0,80,40,82,80,84,c0,87,00,89,40,8b,80,8e,00,90,40,92,80"/>
                                    <Value Name="CALI_RESULT_6" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,00,c0,01,40,01,c0,02,00,02,80,03,00,03,40,03,c0,04,40,04,80,05,00,05,80,07,40,09,00,0a,80,0c,40,0e,00,0f,c0,11,80,13,40,15,00,16,c0,18,80,1a,40,1c,00,1d,c0,1f,80,21,40,22,c0,24,80,26,40,28,00,29,c0,2b,80,2d,40,2f,00,30,c0,32,80,34,40,36,00,37,c0,39,80,3b,00,3c,c0,3e,80,40,40,42,00,43,c0,45,80"/>
                                    <Value Name="CALI_RESULT_7" Value="ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,ac,aa,a7,a5,a3,a3,a3,a3,a3,a3,a3,a3,a3,a3,a3,a3,a3,a3,7c,03,7f,66,82,c9,86,2c,89,8f,8c,f2,90,55,93,b8,95,0f,96,66,97,bd,99,14,9a,6b,9b,c2,9d,19,9e,70,9f,c7,a1,1e,a2,75,a3,cc,a5,23,a6,7a,a7,d1,a9,28,aa,7f,ab,d6,ad,2d,ae,84,af,db,b1,32,b2,89,b3,b0"/>
                                   </Dir>
                                  </Config>
                                  lastgood.xml
                                    <Value Name="LAN_IP_ADDR" Value="192.168.2.5"/>
                                    <Value Name="LAN_SUBNET" Value="255.255.255.252"/>
                                    <Value Name="SYSLOG_DISPLAY_LEVEL" Value="3"/>
                                    <Value Name="SYSLOG" Value="1"/>
                                    <Value Name="LOID" Value="123456789"/>
                                    <Value Name="LOID_PASSWD" Value="123456"/>
                                    <Value Name="GPON_PLOAM_PASSWD" Value="xxxxxx"/>
                                    <Value Name="OMCI_OLT_MODE" Value="1"/>
                                    <Value Name="OMCI_LOGFILE" Value="1"/>
                                    <Value Name="OMCI_CUSTOM_ME" Value="1"/>
                                    <Value Name="OMCI_SW_VER1" Value="v0.03.05.221"/>
                                    <Value Name="OMCI_SW_VER2" Value="v0.03.05.221"/>
                                    <Value Name="OMCC_VER" Value="128"/>
                                    <Value Name="OMCI_TM_OPT" Value="2"/>
                                    <Value Name="OMCI_EQID" Value="AR_LBFIBRA_sp"/>
                                    <Value Name="OMCI_ONT_VER" Value="R02"/>
                                    <Value Name="OMCI_LOGFILE_MASK" Value="0"/>
                                    <Value Name="OMCI_VENDOR_ID" Value="ALRT">
                                   </Dir>
                                    <Value Name="MacAddr" Value="ac4afe980af5"/>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                  </Config>
                                  ToTheCLI
                                  Thu Jul 29, 2021 12:05 pm
                                  I have an xPON SFP V2801F, I can achieve O5 But no Internet connection I suspect I have to Clone Mac Address of Original Huawei ONT and HWVER So I need VS_AUTH_KEY to stop reboot when I change ELAN_MAC and HWVER Parameters.
                                  HWVER:172D.A
                                  Please help generate VS_AUTH_KEY.
                                  valemal
                                  Fri Jul 30, 2021 4:55 pm
                                  deleted
                                  BackON
                                  Sat Jul 31, 2021 6:40 pm
                                  Finally i got sucesfull changing in UF-INSTANT the Ploam password and serial number. The procedure its the same as the AFM0002TIM module but with some diferences
                                  You have a vi editor embebedd(so you dont need to download file)
                                  connect via telnet 192.168.1.1 user pass ubnt/ubnt and you need to modify 3 files /var/config/lastgood.xml /var/config/lastgood_mp_hs2.xml /var/config/lastgood_hs.xml
                                  in the hs and mp_hs file you need to modify gpon_sn (needs to be the same ) and in lastgood.xml you need to modify the ploam password.
                                  i havent tried yet because my router has some issues with the eeprom that doesnt recognize it but im goin to try it on a media converter
                                  ToTheCLI
                                  Sun Aug 01, 2021 11:44 am
                                  I have an xPon SFP and I get to O5 and see Flows but PPPoE is not connecting.
                                  OMCI Log
                                  0x2a5e Ontg SyncTime(0x0000)
                                  0x2a5e Ontg SyncTimeRsp(0x0000,Result=0x0)
                                  0x2a5f OntData MibReset(0x0000)
                                  0x2a5f OntData MibResetRsp(0x0000,Result=0x0)
                                  0x0000 EthUni AVC(0x0401)
                                  I suspect the issue is here from the Log as every time there is Ontg Synctime request MibReset is sent and the log loops.
                                  Does anyone understand this syntax?
                                  Attached is full log.
                                  yerebakan
                                  Sun Aug 29, 2021 12:13 am
                                  Same as me. I get 05 status but not take IP when Vlan is correct. Send Carlitoxx to debug, he said not connect any port. They want me to take dump in my ont. I did it. But I dont get response. I am waiting.
                                  kswong
                                  Fri Sep 03, 2021 7:07 am
                                  flash default cs
                                  reboot
                                  Any ideas please?
                                  Thank you!
                                  flash set PON_VENDOR_ID HWTC
                                  flash set GPON_ONU_MODEL HG8120H
                                  kswong
                                  Fri Sep 03, 2021 7:11 am
                                  lastgood.xml
                                  lastgood_hs.xml
                                  # diag
                                  RTK.0>
                                        0 |     4095 |  ETH |           |
                                       32 |       45 | OMCI |           |
                                  RTK.0>
                                  lastgood.xml
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                   </Dir>
                                  </Config>
                                  lastgood_hs.xml
                                   </Dir>
                                  </Config>
                                  flash set GPON_ONU_MODEL HG8012H
                                  true
                                  Sun Sep 26, 2021 7:45 pm
                                  Hi everyone, just registered to say I had success using a Nokia G-010S-P and Carlitoxx firmware V1 with Movistar Chile, connecting to an Alcatel OLT. This thread has been incredibly useful, thanks everyone!
                                  manias21
                                  Fri Oct 15, 2021 1:44 pm
                                  alguien tiene el user y pass del sfp de carlitosxxpro??
                                  Does anyone have the user and pass of the sfp of carlitosxxpro?
                                  sotirone
                                  Mon Nov 01, 2021 12:48 pm
                                  Can the CarlitoXXPro module be switched to NAT instead of bridge?
                                  AlanFinotty
                                  Tue Nov 09, 2021 7:10 pm
                                  Does anyone have any idea how I can access my Sercomm FGS202 via telnet?
                                  zry98
                                  Sat Nov 13, 2021 5:16 am
                                  For anyone trying to use a hexadecimal PLOAM password (idONT) on modules based on Realtek RTL8672 and/or RTL9601C chipset (including V-SOL V2801F, NanTianWeiShi, Ubiquiti U-Fiber Instant, ODI newer model, etc.), although the normal WebUI and flash / xmlconfig / mib command doesn't allow you to set a hexadecimal password containing unprintable characters (for example a password for Movistar Spain: 0xF2021030405678000000), but there is still a way to use it since
                                  /bin/omci_app
                                  still accepts and will work well with hexadecimal password as an argument value in command line.
                                  1. Flash a custom firmware (you can find information about customizing firmware here: https://gist.github.com/Anime4000/522b0 ... y-firmware) with an already modified script in step 2, or flash a firmware including a text editor like vim, some modules' firmwares may already have one. If you couldn't find a way to flash, maybe
                                  sed
                                  can also do the trick by replacing string.
                                  2. Edit the script /etc/runomci.sh, find the argument part
                                  $gpon_ploam_pwd_set
                                  in the last line (it should start with
                                  omci_app -s $gpon_sn...
                                  ) or in the middle of file
                                  gpon_ploam_pwd_set="-p $gpon_ploam_pwd"
                                  . Change it to
                                  "$(echo -ne '\xf2\x02\x10...')"
                                  which is your escaped hexadecimal password. For example, if your idONT is 0xF2021030405678000000, it should be
                                  "$(echo -ne '\xf2\x02\x10\x30\x40\x56\x78\x00\x00\x00')"
                                  3. Done! (For some ISPs, you may also need to enable the OMCI fake ok option by flash set OMCI_FAKE_OK 1 or similar command.)
                                  If the original last line in your runomci.sh looks like this (on a NanTianWeiShi module, shouldn't be very different on other modules):
                                  omci_app -s $gpon_sn -f $(get_omci_log_format) -m $(get_omci_dual_mgmt_mode) -d $(get_omci_dbg_level) -t $(get_omci_dev_type) $gpon_ploam_pwd_set $gpon_loid_set $gpon_loidPwd_set $(get_omci_cus_conf) $(get_omci_iot_vlan_cfg) $(get_omci_veip_slot_id_conf) $(get_omci_voice_vendor) &
                                  the final result should be like this:
                                  omci_app -s $gpon_sn -f $(get_omci_log_format) -m $(get_omci_dual_mgmt_mode) -d $(get_omci_dbg_level) -t $(get_omci_dev_type) -p "$(echo -ne '\xf2\x02\x10\x30\x40\x56\x78\x00\x00\x00')" $gpon_loid_set $gpon_loidPwd_set $(get_omci_cus_conf) $(get_omci_iot_vlan_cfg) $(get_omci_veip_slot_id_conf) $(get_omci_voice_vendor) &
                                  dwnldr
                                  Mon Dec 13, 2021 10:13 pm
                                  Dear Friends,
                                  i would like to throw away my bridged Huawei EchoLife HG8145 which i received from my ISP (Telekom, country Slovakia). The connection is made with my private router via PPPoE dialing with received username/password. Sadly, the is no proper way avoid using the received Huawei, so im interested in SFU by Carlitoxx. Since my knowledge, the authentication method should be here in Slovakia also Serial Number of the device. This can be found on Huawei on the sticker. But as you mentioned, maybe there is some secondary authentification, the PLOAM password. Im sorry for my dumb question, but what this password is ? Is it something what can i found with some debugging from Huawei ? Since if i need to ask it from ISP, there would be no chance to receive anything.
                                  Thank you very much !
                                  Greetings
                                  #1 hap ac3
                                  #2 rb951g-2HnD
                                  hEX lite
                                  PL7411-2nD
                                  RBSXTsq2nD
                                  rajkosto
                                  Fri Dec 17, 2021 2:48 pm
                                  the PLOAM password is just the SLID and you can see it in System Tools -> ONT Authentication on your Huawei ONT if you use the non-restricted webgui user (the password for which you can find googling for your specific model, might even be set by ISP to something, in which case someone has to have figured it out on that ISP first)
                                  dwnldr
                                  Wed Dec 22, 2021 10:41 pm
                                  @rajkosto Thank you very much for your answer !
                                  #1 hap ac3
                                  #2 rb951g-2HnD
                                  hEX lite
                                  PL7411-2nD
                                  RBSXTsq2nD
                                  rajkosto
                                  Tue Dec 28, 2021 7:51 pm
                                  can the MikroTik CRS305-1G-4S+IN 10G Switch run the SFP ONTs in 2.5g/1.25g mode ? It has 4 SFP+ ports
                                  what about the SwitchOS-only CSS610-8G-2S+ or CSS326-24G-2S ?
                                  Also, do those modules which do work on 2.5g/1.25g mode work fine on the cheap SFP (not +) to 1gbps ethernet media converters ?
                                  kresozg
                                  Fri Dec 31, 2021 4:33 pm
                                  Dear colleagues,
                                  today we were testing Sercomm FGS202 with Mikrotik CCR1009 ROS 6.49.2
                                  Mikrotik CCR1009 doesnt recognize the module. i have tried SFP and SFP 10G slot. its the same.
                                  I have also tested it on another CCR1009 with the same results.
                                  It works in every RB2011 that i have tested with ROS 6.49.2... Do you have an idea what to do?
                                  Best regards
                                  manias21
                                  Sat Apr 16, 2022 8:54 pm
                                  After a few months of going round and round, yes, I have already found a solution that shows the result in the isps of Spain, I connect with movistar, vodafone, orange and those who arrive...
                                  the sfp stick is clearly from ODI and its firmware, on top of that it is compatible with mikrotik, tell me I already have two with O2 and one more with movistar.
                                  It's not for advertising or anything like that, but.... it's clear that what works in mikrotik has to be published here so that the rest can delegate a solution with everyone's collaboration.
                                  firmware needed.. sfp-stik
                                  M114_sfp_ODI_220304.tar
                                  The rest of the information necessary to complete the mentioned information...
                                  https://github.com/Anime4000/RTL960x
                                  Anime4000
                                  Fri Apr 29, 2022 4:51 pm
                                  I have compile list of device that support 2.5Gb GPON SFP
                                  https://github.com/Anime4000/RTL960x/bl ... s/2.5Gb.md
                                  CCR2004-1G-12S+2XS and CRS305-1G-4S+IN support DFP-34X-2C2 in 2.5Gb Mode
                                  I would recommend DFP-34X-2C2 SFP because it's cheaper, active firmware development, PVID...
                                  V2801F based SFP can cause trouble when HiSGMII PHY/MAC mismatch, attaching UART very hard for V2801F.
                                  TWCGPON657 can use V2801F firmware, also cheaper to buy, can change MAC Address for EPON users
                                  TWCGPON657 has UART pin ready in case of lock-out.
                                  JeanPierre
                                  Fri May 06, 2022 9:29 pm
                                  Thank you Anime4000 for your work. I have updated the list of popular SFP modules at the top of the page with more information about the Realtek RTL960x series.
                                  =-=-=-=-=-=-=-=-=-=-=-= System on Chip (SoC): Realtek 9601x =-=-=-=-=-=-=-=-=-=-=-=-=-=
                                  RTL9601x SoC features MIPS CPU Core RTL8672, an embedded RAM, Network, PON Controllers inside one QFN package.
                                  Flash 8/16MB, System Linux version 2.6.30.9 - Realtek RSDK-1.5.6p2 - luna SDK V1.9.0
                                  Pros - Extensive graphical network interface (GUI), supports LOID, HGU(Router mode), SN, password, MAC change. Low ambient temperature.
                                  Cons- Web interface, SN change, and dual support for EPON/GPON will vary depending on how the final vendor configured the module.
                                  Several product families built upon Realtek RSDK-1.5.6p2 are available:
                                  RTL9601B
                                  Technicolor AFM0002TIM, Hisense LTE3415-SCA+
                                  Package QFN88, UART pins 30/31
                                  RTL9601CI
                                  Google Fiber GFLT210, Cigtech G-97S, Hisense LTE3415-SH+, Ubiquiti UF-Instant, VSOL V2801F, OPTON GP801R, BAUDCOM BD-1234-SFM, Carlitoxx CPGOS03-0490 v2.0, EXOT - EGS1, T&W TWCGPON657, CM5671A
                                  2.5Gb HSGMII support in some modules.
                                  Package QFN76, UART pins 12/13
                                  RTL9601D
                                  ODI DFP-34X-2C2-v05
                                  2.5Gb HSGMII Support enabled.
                                  Package QFN88, UART pins 24/25
                                  ivanmh
                                  Wed Jun 01, 2022 10:04 pm
                                  Thank you very much @Anime4000 for your great work.
                                  After reading your GitHub repository, with a bit of trial and error and after installing the firmware version V1.0-220527, I managed to get my recently purchased SFP XPON ONU DFP-34X-2C2 working perfectly with my Internet provider (ISP) O2 from Spain . I bought it from the seller Fibershow @ AliExpress, and it took about two weeks to arrive at home in Madrid (Spain).
                                  It had firmware V1.0-220304 from stock, so I didn't have to do anything to enter the PLOAM in hexadecimal (20 characters). It was very easy to get O5 ONU State, but unfortunately it didn't authenticate and connect PPPoE interface to have Internet. But surprisingly, it did get IP address 10.25.x.x for VoIP (VLAN3), being able to make and receive calls to the landline (phone). So undoubtedly the SFP XPON ONU was authenticated to the OLT, but for some reason it was not able to authenticate and connect PPPoE interface to have access to the Internet.
                                  The next step was to modify the OCMI identity to try to fool the OLT, without success.
                                  The next step was to update to firmware V1.0-220414, and try both fake OCMI and stock OMCI, with no success.
                                  Finally, I tried updating to firmware V1.0-220527 downloaded from GitHub Anime4000 repository, with stock OMCI and it was a success, since I had authentication, PPPoE connection and Internet (VLAN6). Also VOIP (VLAN3) works perfectly. I use Mikrotik RB4011iGS+5HacQ2HnD-IN using its SFP+ port, and RouterOS 7.2.3
                                  It does not have any special configuration to make it work, with the OCMI and the stock GPON configuration (except the PLOAM, obviously)
                                  The performance of the Internet connection is as expected, there is no difference with the previous ONU UFiber Nano G. My FTTH subscription is 600 Mbps.
                                  Unfortunately, I cannot test if Movistar+ IPTV (VLAN2) works, since O2 does not have IPTV.
                                  I hope this information helps other people in a similar situation, especially those who want to use O2 Spain or Movistar
                                  And once again give my thanks to Anime4000 for their great contribution to my success. I definitely recommend their GitHub https://github.com/Anime4000/RTL960x/
                                  copyliu
                                  Thu Jun 09, 2022 11:24 am
                                  Thank you for your awesome work. One question is about the 2.5Gbps support for the RB5009/RB4011, it says "NEVER" on the document, does that mean we have to wait for Mikrotik to add support for it or it will never be supported in the future (e.g. due to switch chip limitations) ?
                                  Anime4000
                                  Re: Usage GPON module SFP in Spain
                                  Sun Jun 19, 2022 10:09 am
                                  What I know about my RB5009, it support 10Gb at operates at a lower signaling rate (1/4) by using Mikrotik S+RJ10, this mean SFP+ support 2500base-T
                                  Problem is, RB5009 didn't support HiSGMII/2500base-X... RTL960x ONU SFP require intermediate RTL8221B chipset to convert HiSGMII/2500base-X to 2500base-T to fool RB5009 thinking RJ45 SFP+
                                  There will be new ONU SFP called LXT-010S-H that rival V-SOL V2801F, CarlitoxxPro CPGOS03-0490 v2.0 at same price range! Industrial Grade with-stand 85°C at 24/7/365 runtime, with RTL8221B chip sit between RTL9601D and SFP+ Host that enable 2500base-T support, newer Linux kernel, wide support OLT profile to fake OMCI Info, EthUni (4-port ONU LAN Emulation), custom VLAN mapping, PVID and much more.
                                  Chano
                                  Mon Jun 20, 2022 9:07 pm
                                  Hello Ivanmh
                                  I've followed the updates you mention, and it does raise its voice, but not PPPoE.
                                  In addition to the iDont, what other parameters must be changed?
                                  Thank you
                                  DeviceLocksmith
                                  Tue Jun 21, 2022 8:56 pm
                                  The switch in CCR2116 7.4b4 becomes unresponsive when hardcoding SFP+ port to 2.5Gbps when DFP-34X-2C2 is plugged in (with any 2.5Gbps LAN SDS mode). The router itself remains up and accessible by serial interface, but all ports on a built it switch become unresponsive.
                                  xemeitor
                                  Tue Jun 21, 2022 10:35 pm
                                  Hi, I also have Movistar and I did the same steps as you did and it doesn't work, don't know if you did something else besides the ploam password. Thanks in advance.
                                  ivanmh
                                  Thu Jun 23, 2022 9:40 pm
                                  Hello Ivanmh
                                  Thank you
                                  All the configuration I have on the GPON SFP is stock. The key point was to update the firmware to "M114_sfp_ODI_hybrid_220527.tar" available in the Anime4000 GitHub repository. Although it seems that this firmware is for router mode, by default it works for me in bidge mode. I have had no problems in that regard, and the performance is consistent with the bridge mode.
                                  If you have raised VoIP (VLAN3), it is almost certain that you have authenticated with the OLT (O5 state), but for some reason that I do not know, it does not raise PPPoE.
                                  However, I insist, I got to the same point, and the solution was to install the firmware "M114_sfp_ODI_hybrid_220527.tar". From that moment on the game changed and I didn't have to do anything else on the SFP GPON stick.
                                  This is my actual configuration, obfuscating for security certain information such as the PLOAM or the MAC serial number:
                                  login: admin
                                  Password: **********
                                  BusyBox v1.12.4 (2022-05-27 10:39:03 CST) built-in shell (ash)
                                  Enter 'help' for a list of built-in commands.
                                  # cat /etc/version
                                  V1.0-220527 --  Fri May 27 10:41:36 CST 2022
                                  # flash get PON_VENDOR_ID
                                  PON_VENDOR_ID=ODI
                                  # flash get HW_CWMP_MANUFACTURER
                                  HW_CWMP_MANUFACTURER=ODI
                                  # flash get HW_CWMP_PRODUCTCLASS
                                  HW_CWMP_PRODUCTCLASS=DFP-34X-2C2
                                  # flash get HW_HWVER
                                  HW_HWVER=V2.0
                                  # flash get OMCI_VEIP_SLOT_ID
                                  OMCI_VEIP_SLOT_ID=255
                                  # flash get OMCI_OLT_MODE
                                  OMCI_OLT_MODE=0
                                  # flash get OMCI_FAKE_OK
                                  OMCI_FAKE_OK=0
                                  # flash get OMCI_SW_VER1
                                  OMCI_SW_VER1=V1.0-220527
                                  # flash get OMCI_SW_VER2
                                  OMCI_SW_VER2=V1.0-220304
                                  # flash get GPON_ONU_MODEL
                                  GPON_ONU_MODEL=DFP-34X-2C2
                                  # flash get GPON_SN
                                  GPON_SN=XPON22050123
                                  # flash get GPON_PLOAM_PASSWD
                                  GPON_PLOAM_PASSWD=f2018001234567000000
                                  # flash get ELAN_MAC_ADDR
                                  ELAN_MAC_ADDR=321b1234ac3b
                                  As you can see, there is nothing out of the ordinary. Although I must clarify that I am certain that the OLT of my GPON 1:64 branch is from the manufacturer Huawei. I am very afraid that if Movistar in your GPON 1:64 branch is from the manufacturer Alcatel, you will have to use a fake OMCI configuration.
                                  For example, with the ONU UFiber Nano G, it worked perfectly with a Huawei OLT, but with Alcatel there are users who have reported incompatibility.
                                  JeanPierre
                                  Sat Jun 25, 2022 12:32 am
                                  I followed the link provided. The manufacturer replied that SFP ONUs cannot support 2500base-T. The RTL8221B is designed for normal size ONTs as they only have room to add an RJ-45 port.
                                  It is possible that the RB5009 will add support for 2500Gbps with auto-negotiation disabled, as they have done with other models, though it took 2-3 years before support materialized.
                                  The existing switch chip 88E6393X used in RB5009 supports 2500BASE-X natively
                                  Marvell® Link Street® 88E6393X device is a single-chip, 11-Port
                                  Ethernet Switch with eight integrated 10/100/1000Mbps
                                  Ethernet transceivers and 3 high speed SerDes interfaces
                                  supporting USXGMII, 10GBASE-R, 5GBASE-R, 2500BASE-X,
                                  1000BASE-X, SGMII.
                                  piku
                                  Thu Jul 14, 2022 1:59 am
                                  Disassemble a Huawei MA671a, for your reference
                                  true
                                  Wed Jul 20, 2022 8:03 am
                                  Just searched all over the known sites (including the well documented french and italian forums) about this subject so I'm posting here for further reference.
                                  I had compatibility problems with the Nokia G-010S-P using Carlitoxx V1 Firmware and a Mikrotik RB4011, but the same module worked hassle free for 100+ days using a Hex S. Had to turn off auto negotiation and force 1 Gbps full duplex to sync, but the module was disconecting after few seconds, so I realized the problem was the EEPROM emulation. This was fixed commenting the start command in /etc/init.d/sfp_eeprom.sh and now the problems are gone.
                                  Next stop: hsgmii (?)
                                  grayver
                                  Thu Jul 21, 2022 3:48 am
                                  Hello! I'm trying to use UF-Instant with RB5009, but it doesn't see it. WinBox just reports that SFP module is present, but neither any other information available (vendor, model, serial, etc), nor module itself is accessible. RouterOS version is 7.3.1. Has anyone succeeded linking them?
                                  valemal
                                  Mon Jul 25, 2022 1:12 am
                                  SFP module not detected after reboot
                                  ToTheCLI
                                  Thu Jul 28, 2022 1:52 am
                                  1000BASE-X, SGMII.
                                  I Hope Mikrotik add support on RB5009 for 2500BASE-X on SFP+ Port
                                  grayver
                                  Fri Jul 29, 2022 12:42 am
                                  I have some progress with that. I turned off auto-negotiation on SFP port and set speed to 1Gbps full duplex - it didn't work. But when I turned on auto-negotiation back (leaving last manual speed value to 1Gbps full duplex) - it worked! Now I can telnet to the UF-Instant. Moreover, I got O5 after setting PLOAM password and appropriate OMCI_OLT_MODE (my ISP authorizes only by PLOAM password). However, I'm having the following issues now:
                                  1. UF-Instant repeatedly reboots after few minutes of uptime with optic cable plugged in. When I plug out the cable it stops rebooting.
                                  2. I can't get the IP-address from my ISP. However, UF-Loco works well and gets the IP with the similar settings.
                                  dexxter00
                                  Sun Aug 07, 2022 10:02 am
                                  Hello guys!
                                  I'am using DFP-34X-2C2 with 220414 firmware.
                                  I have problem with OMCI provisioning only 10mbit upstream channel. Downstream is ok and I'm getting 95mbit.
                                  Setting OMCI_TM_OPT = 0 and the OMCI does not send MIB 280 (TrafficDescriptor).
                                  OLT is Huawei, stock ONT is also Huawei.
                                  Anyone have any suggestion what I can try next?
                                  alexandrerpo
                                  Wed Sep 07, 2022 12:33 pm
                                  I bought an Xpon dfp-34x-2c2 and here in Brazil I need to send the serial number in Hexadecimal format to the OLT. However, the Xpon dfp-34x-2c2 only allows you to put it in HWTCA1B2C3D4 format.
                                  When putting in Hex, do not enter the last 4 characters in Hex, leaving 48575443A1B2.
                                  Is there any way to put all Hex in GPON SN
                                  Last edited by alexandrerpo on Wed Sep 07, 2022 12:43 pm, edited 2 times in total.
                                  Users browsing this forum: Bing [Bot], Semrush [Bot] and 9 guests
