kshitijminhas
Poor Bandwidth over RouterBoard WLAN
Tue Jan 03, 2017 8:04 pm
I am using RouterBoard 911 5HacD in ap bridge mode. I am essentially using this board to create a WiFi out of EdgeRouterX (https://www.ubnt.com/edgemax/edgerouter-x/).
I am getting 0.8 Mbps download and 3.81 Mbps upload speeds (ping 17 ms) when over routerboard's wifi.
If I hardwire my computer to the EdgeRouter I get, 52/42 Mbps (down/up). And if I connect a different Access Point on the EdgeRouter, I get 26/23 Mbps over WLAN.
Any changes I can make to improve the WLAN bandwidth of the Routerboard? You can find some settings screenshots attached.
kshitijminhas
Re: Poor Bandwidth over RouterBoard WLAN
Wed Jan 04, 2017 7:12 pm
Hi, any response will be appreciated.
scampbell
Trainer
Trainer
Fri Feb 10, 2017 10:36 pm
Try setting channel to 20MHz Ceee and protocol=802.11. Also check no other wireless devices are using 5180 Ceee.
Ensure your wireless security profile does not use TKIP. Just AES is best and wpa2-psk only.
Sent from my iPhone using Tapatalk
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
Users browsing this forum: No registered users and 123 guests
