MUM Europe 2020
kolorasta
24hs routeros license expiration
Tue Oct 24, 2006 4:56 pm
after 24hs the router stops working because of license expiration... after that, am i able to login in order to enter a valid license?
cmit
Tue Oct 24, 2006 5:47 pm
I don't think so...
But the 24 hours are actual uptime, i.e. if you shut your system down, the countdown stops ;)
Best regards,
Christian Meis
Best regards,
Christian Meis
kolorasta
Tue Oct 24, 2006 6:05 pm
I don't think so...
Best regards,
Christian Meis
ok... i shut it down until i pay ...
janisk
Tue Oct 24, 2006 6:27 pm
cmit is right,
after demo licence time expires only available option is to reinstall ROS, all configuration everything is lost.
balimore
Forum Veteran
Forum Veteran
Tue Oct 24, 2006 6:54 pm
I don't think so...
Best regards,
Christian Meis
no, just demo you will do this methode.
if, you are not ready to buy new key for now, you can continue with 'demo key', just login to account server at mikrotik.com and make demo key, that server will send mail you 'demo key', than paste it into routerOS. i think you will access to your router is not 24hours.
keep it your software ID
Hasbullah.com
Users browsing this forum: Bing [Bot], blue, GalaxyData, jabberd, mishja, zafarsyal, zandhaas and 141 guests
