Jorbu
Issue CAPsMAN controlling 5Ghz radios on 6.38 and 6.39rc
Sat Jan 07, 2017 2:03 am
Upgraded my CAPsMAN controller (RB1100AH) to version 6.39rc7. This is controlling one wAP AC, one hAP AC lite, and one hAP AC. Once the upgrade happens, I see my 5Ghz network start to feel slow, and all my devices are unable to associate at the higher MCS. Doing a bit of troubleshooting, I'm unable to get them to work properly. Had to downgrade to 6.37.3 in order to make it work. Here's the configuration of one of the 5Ghz CAP in 6.39rc7:
 1 M BR name="AP02-MasterBR-5Ghz" mac-address=E4:8D:8C:D5:41:6C arp-timeout=auto radio-mac=E4:8D:8C:D5:41:6C master-interface=none
        configuration.mode=ap configuration.ssid="Jorbu" configuration.max-sta-count=30 configuration.multicast-helper=default
        configuration.tx-chains=0,1,2 configuration.rx-chains=0,1,2 configuration.guard-interval=any
        configuration.country=united states configuration.distance=indoors configuration.hw-retries=0
        configuration.hw-protection-mode=none security.authentication-types=wpa2-psk security.encryption=aes-ccm
        security.group-encryption=aes-ccm security.passphrase="password" l2mtu=1600 datapath.client-to-client-forwarding=yes
        datapath.bridge=bridge1 channel.width=20 channel.band=5ghz-a/n/ac channel.extension-channel=Ceee
Here's the effect of that configuration on the interface details, please note the "current rate set" section:
        security.group-encryption=aes-ccm security.passphrase="password" datapath=JorbuDatapath l2mtu=1600
        datapath.client-to-client-forwarding=yes datapath.bridge=bridge1 channel.width=20 channel.band=5ghz-a/n/ac
        channel.extension-channel=Ceee rates.vht-basic-mcs="" rates.vht-supported-mcs="" current-state="running-ap"
        current-channel="5260/20-Ceee/ac/DP(23dBm)" current-rate-set="OFDM:6-54 BW:1x-2x HT:0-23" current-basic-rate-set="OFDM:6"
After downgrading to 6.37.3, the interface started up the same exact way. I had to recreate the "Configuration" object in order to make it work properly. Here is the config in 6.37.3
 1 M BR name="AP02-MasterBR-5Ghz" mtu=1500 l2mtu=1600 mac-address=E4:8D:8C:D5:41:6C arp=enabled arp-timeout=auto
        radio-mac=E4:8D:8C:D5:41:6C master-interface=none configuration.mode=ap configuration.ssid="Jorbu"
        configuration.country=united states configuration.distance=indoors security.authentication-types=wpa2-psk
        security.encryption=aes-ccm security.group-encryption=aes-ccm security.passphrase="password"
Here's the interface details, note the "current-rate-set" property (6.37 seems to print out a lot less detail than the newer version):
        radio-mac=E4:8D:8C:D5:41:6C master-interface=none configuration=Configuration_Jorbu5Ghz current-state="running-ap"
        current-channel="5260/20-Ceee/ac/DP(23dBm)" current-rate-set="OFDM:6-54 BW:1x-4x HT:0-23 VHTMCS:SS1=0-9,SS2=0-9,SS3=0-9"
Please note, I was also able to reproduce this issue in v6.38; and have not found a way to allow the 5Ghz radios to reach the higher MCS in either 6.38 or 6.39rc7.
Aside from downgrading, has anyone found a workaround for this?
intelfx
Re: Issue CAPsMAN controlling 5Ghz radios on 6.38 and 6.39rc
Sat Jan 14, 2017 4:34 am
Same issue here (RB2011 as controller, wAP ac as AP). Moreover, my QCA6174 card consistently gets a firmware crash when exposed to such AP; it took me over an hour to understand what's going on...
Just set them manually.
/caps-man interface set YOUR-AP rates.vht-supported-mcs=mcs0-9,mcs0-9,mcs0-9
(repeat that "mcs0-9" once for each spatial stream you have on the AP in question)
nz_monkey
Sat Jan 14, 2017 9:21 am
This is a known issue and should be fixed in 6.39rc12
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
Jorbu
Tue Jan 17, 2017 9:56 pm
Updated to RC13, all appears to be working fine. Radios now advertise SGI too:
Users browsing this forum: MulderSk and 42 guests
