ErfanDL
The connection between the two SXT on the vehicle
Sun Jan 08, 2017 12:26 pm
Hi friends.
can SXT5HpND communicate with another SXT5HpND on the vehicle with 80 Km/h speed ?
the SXT's Is installed at the same height and same way.
dadoremix
Re: The connection between the two SXT on the vehicle
Sun Jan 08, 2017 12:27 pm
If you have LOS.. yes
Why not
Sent from my iPhone using Tapatalk Pro
ErfanDL
Sun Jan 08, 2017 12:28 pm
Why not
what the mean about LOS ?
dadoremix
Sun Jan 08, 2017 12:30 pm
https://en.m.wikipedia.org/wiki/Line-of ... ropagation
ErfanDL
Sun Jan 08, 2017 12:36 pm
thanks for answer. if I have LOS what about speed ? the vehicle is metro train with 80 Km/h speed
dadoremix
Sun Jan 08, 2017 12:43 pm
And the other side is what?
Fix antenna?
Who will rotate sxt on train?
Speed is not problem
ErfanDL
Sun Jan 08, 2017 12:52 pm
Fix antenna?
the paint
( sorry my paint is not good :D )
dadoremix
Sun Jan 08, 2017 12:55 pm
That will not work
Tunnel is how long?
No los there
ErfanDL
Sun Jan 08, 2017 12:59 pm
That will not work
Tunnel is how long?
No los there
I can installing multiple SXT on the tunnel for each 200 meter. the tunnel length is 20 KM
and for this project OMNI antenna is better or sector SXT ?
sup5
Sun Jan 08, 2017 2:17 pm
I'd say this won't work, because of roaming issues (ie. handover issues) and interference issues
You might be better using Ubiquity's Zero-Handoff APs
or Meru's (now Fortinet) Seamless Roaming approach.
With Microcell architecure and without extended Roaming support you're lost here.
ErfanDL
Sun Jan 08, 2017 3:25 pm
thanks for answer. which unifi model 5Ghz is recommended ? is unifi support mirkotik hotspot ?
sup5
Sun Jan 08, 2017 3:38 pm
I am not familiar with the Upiquity products. I just know that there is support for zero-handoff roaming.
Mikrotik Hotspot works as long as you establish a Layer-2 Connection between End-User and Hotspot Gateway.
This might include ordinary bridging, tunneling with EoIP/L2TP or MPLS/VPLS
shahbazian
Trainer
Trainer
Mon Jan 09, 2017 1:12 pm
Scan-list in stations, limit to APs frequency.
And use mode=station-roaming for zero handoff
Sent from my SM-G928C using Tapatalk
Learn MikroTik to improve your network.
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE )
MikroTik Certified Trainer & Consultant
RIPE NCC Trainer
ErfanDL
Mon Jan 09, 2017 1:14 pm
thanks MR.shahbazian for reply
what about microwave radios ? for example dragonwave devices
ErfanDL
Tue Jan 10, 2017 8:30 am
nobody any idea ?
shahbazian
Trainer
Trainer
Tue Jan 10, 2017 11:46 am
Use device like OmniTik for AP; because when approach the AP and when getting away AP, don't lose connection to AP
RIPE NCC Trainer
ErfanDL
Tue Jan 10, 2017 12:26 pm
can omnitik roaming fast wireless network from ap to ap (dynamic WDS )? for example I installing OMNITIK on train and many OMNITIK on the tunnel, is roaming fast between the two omnitik's ? the train speed is 32 km/h up to 70 km/h
thnaks
shahbazian
Trainer
Trainer
Re: RE: Re: The connection between the two SXT on the vehicle
Tue Jan 10, 2017 1:33 pm
thnaks
OmniTik better than SXT for AP in this solution, because SXT cover one side but OmniTik cover two side of AP.
In configuration no deference between SXT and OmniTik.
RIPE NCC Trainer
ErfanDL
Re: RE: Re: RE: Re: The connection between the two SXT on the vehicle
Tue Jan 10, 2017 1:35 pm
thnaks
What about train speed? Can omnitik communicating with 70 km/h speed?
shahbazian
Trainer
Trainer
Tue Jan 10, 2017 1:36 pm
In wireless interface advance tab, set distance=indoor in APs and Stations
RIPE NCC Trainer
shahbazian
Trainer
Trainer
Re: RE: Re: RE: Re: RE: Re: The connection between the two SXT on the vehicle
Tue Jan 10, 2017 1:38 pm
thnaks
I don't test that...
RIPE NCC Trainer
shahbazian
Trainer
Trainer
Tue Jan 10, 2017 1:39 pm
thnaks
I didn't test that...
RIPE NCC Trainer
ErfanDL
Wed Jan 11, 2017 9:36 pm
Please help.
@jarda
jarda
Tue Feb 14, 2017 6:46 pm
Sorry for delay as my time to spend here on forum is quite limited during last weeks... Do you have any progression in this interesting area?
Users browsing this forum: No registered users and 21 guests
