PaulsMT
Dude Telegram notification example
Mon Jan 09, 2017 10:59 am
Currently it's not possible to use HTTP POST method from Dude/RouterOS, so here is some workaround example how to use Telegram, to send messages using HTTP GET method:
http://wiki.mikrotik.com/wiki/Manual:Th ... am_Example
Suggestions / requests will be appreciated.
turnip
Re: Dude Telegram notification example
Tue Jan 10, 2017 2:58 am
That's a great solution... I'm having trouble though - I can run the /tool fetch command from the command line and it works fine, but nothing happens when I run it from The Dude. I've tried pressing Test, and I've tried unplugging a router to see what happens, and the command never executes. Can't see anything in the logs. Any ideas?
turnip
Tue Jan 10, 2017 4:23 am
Never mind, just noticed this:
Changes in v6.39rc7:
*) Fixed - Tool fetch didn't work with notification - execute on server
Upgrading now
sparker
Wed Jan 18, 2017 7:42 am
Upgrading now
OR
:execute {/tool fetch url="https://api.telegram.org/botXXXXXX:AsG7sapGXDS1aHi_RllzgU9oJUm2wyKyHVw/sendMessage\?chat_id=1231231&text=[TimeAndDate] Service [Probe.Name] on [Device.Name] ([Device.CustomField1] - [Device.CustomField2]) is now [Service.Status] ([Service.ProblemDescription])" keep-result=no}
this option works for older versions
Sorry for my English.
dricks
Wed Feb 15, 2017 8:21 am
I configured all and is working!!!
Correct code for Version 6.38.1 - Please update de wiki
 /tool fetch url="https://api.telegram.org/botXXXXXXX:AAFZJtaHT_of7tV9IPEyK9R9XXXXFtk9_Ap-Pvk/sendMessage\?chat_id=XXXXXX&text=[TimeAndDate] Nodo: [Device.Name], Status: [Service.Status]" keep-result=no
Gretting
Pablo
Sorry for my bad English
amt
Long time Member
Long time Member
Wed Feb 22, 2017 1:44 pm
what should be the chat_id= ??
thanks
Shadeofspirit
Wed Feb 22, 2017 2:02 pm
thanks
after creating the bot you can write to him. from browser you can see the id of this chat (you can use https://api.telegram.org/botXXXXXXXXXXX ... getUpdates )
You should find "«chat»:{«id»:YYYYYYY"
YYYYYYY - is your chat_id
MTCNA, MTCWE
amt
Long time Member
Long time Member
Wed Feb 22, 2017 3:35 pm
thank you verymuch... its work. I would like to ask another question, is possible to do this on viber also ?
Thanks.
Shadeofspirit
Thu Feb 23, 2017 3:26 pm
Thanks.
yes you can. +37544five44340five
MTCNA, MTCWE
tamigi
Mon Feb 27, 2017 7:57 pm
What's the problem in settings .
tomasi
Wed Mar 01, 2017 10:23 pm
I've tested the hyperlink, that it's inside the fetch command:
https://api.telegram.org/bot123456789:AAQFb1byb3LEwMes_TQeCM1k5wsFb_VguhG/sendMessage\?chat_id=123456789&text=Hello
But It doesn't even send the Hello message to the group the bot is participating.
The webpage says: "{"ok":false,"error_code":404,"description":"Not Found: method not found"}"
In Mikrotik terminal, it says: failure: closing connection: <400 Bad Request> 149.154.167.200:443 (4)
Am I doing something wrong? Do I need any additional step to allow the bot start a message?
Thanks! :?
FlavioCamacho
Trainer
Trainer
Thu Mar 02, 2017 2:53 am
What do you think of adapting the dude to send messages through Whatsapp it is much more popular than the telegran.
Mikrotik Training Partner
amt
Long time Member
Long time Member
Thu Mar 02, 2017 10:24 am
or viber...
soonwai
Thu Mar 02, 2017 6:28 pm
or viber...
You can do the same with Viber. Use a Viber "Public Account". I haven't tried yet as it's only available for selected countries.
Telegram is so far the easiest and most accessible.
irghost
Thu Mar 02, 2017 7:24 pm
Thanks! :?
/tool fetch url="https://api.telegram.org/botxxxxxxxxxxxxxx:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/sendmessage?chat_id=xxxxxx&text=Hi" keep-result=no
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
marnem
Fri Mar 03, 2017 6:13 pm
/tool fetch url="https://api.telegram.org/bot<tokenbot>?chat_id=-1001099321185&text=[RECOVER] [TimeAndDate]; [Device.Name]: [Device.FirstAddress]; Status: [Service.Status] ([Service.ProblemDescription])" keep-result=no
for me this work... in my situation i've created a channel with other my coworker...this is a great solution for notification, very reactive!
and then you can evolute your bot with some scripts, notification db ecc.ecc.
great thing
vinu
Sun Apr 23, 2017 7:38 pm
Thanks! :?
HI
issue fixed??
tomasi
Tue Apr 25, 2017 9:16 pm
The issue was fixed, adding a minus sign before the chat ID:
before:
after:
https://api.telegram.org/bot123456789:AAQFb1byb3LEwMes_TQeCM1k5wsFb_VguhG/sendMessage\?chat_id=-123456789&text=Hello
joca
Thu May 04, 2017 3:25 pm
before:
after:
remove \ from "sendMessage\?chat_id="
alisc
Thu Jul 27, 2017 7:29 pm
hi
how to send file ( backup file ) via Telegram ?
I'm not English
my english not so good , excuse me
Morcegolas
Sun Jul 30, 2017 8:23 pm
Gretting
Pablo
I tried this with RouterOS and I receive the messages on telegram, but not the time, device name and status, maybe because in RouterOS its difrent from Dude, is there any chance to get this working also on RouterOS?
hi
I have automated backups and also like the option to send send via telegram, automated or via command in telegram.
Thanks.
Morcegolas
Fri Aug 04, 2017 12:14 am
I already tried so send the file with the two following commands, but get the error code 404, I think the URL is wrong, no ones knows how to send the backup file to telegram?
/tool fetch url="https://api.telegram.org/bot<MyBotApi>/ ... day.backup” keep-result=no
Thanks.
gangz
Thu Aug 17, 2017 2:06 pm
Hi all!
May be it is offtopic, but i am using telegram notifications from my CCR (not Dude) whrough this URL:
/tool fetch url="https://api.telegram.org/bot<BotToken>/ ... id=<ChatId with "-">&text=Very_Impotant_Tunnel_Up"
Also, I wrote an article about this, but it is on russian...
https://www.1spla.ru/blog/telegram_bot_for_mikrotik
indjov
Tue Sep 12, 2017 4:07 pm
That script will work with NetWacht?
alisc
Tue Sep 12, 2017 9:10 pm
How to call admin number ?
I'm not English
alisc
Tue Sep 19, 2017 7:42 pm
Do you have a solution to call admins when it event?
I'm not English
amt
Long time Member
Long time Member
Wed Sep 20, 2017 12:24 am
Yes.. you can use it at netwatch
benjamimgois
Tue Oct 10, 2017 9:56 pm
I have followed the instructions but it doesn´t work. To see what´s happening i tried the fetch command on the command line but i always receive the following error:
[admin@Dude_x86] > /tool fetch url="https://api.telegram.org/bot<TOKEN_BOT>\?chat_id=348399094&text=HelloWorld!" keep-result=no
  status: failed
failure: closing connection: <502 Bad Gateway> 149.154.167.200:443 (4)
Any ideas ???
Telecomunications Engineer
Cisco CCNP, CCNA, CCDP, CCDA
Shadeofspirit
Tue Oct 10, 2017 10:03 pm
  status: failed
Any ideas ???
it looks like you had made a mistake in token)
MTCNA, MTCWE
Shadeofspirit
Tue Oct 10, 2017 10:07 pm
  status: failed
Any ideas ???
the command to send is:
/tool fetch url="https://api.telegram.org/botXXXXX:YYYYY ... text=Hello World" keep-result=no
where XXXXX is your bot id
YYYYY bot token
ZZZZZ chat id
MTCNA, MTCWE
benjamimgois
Tue Oct 10, 2017 10:50 pm
YYYYY bot token
ZZZZZ chat id
Sorry man, i didn´t write it right on the last post, but that´s exactly what i typed... I was calling token the entire <BOT_ID>:<BOT_TOKEN> ... my mistake. I created the bot using botfather and followed the tutorial, i still got the 502 bad gateway error.
/tool fetch url="https://api.telegram.org/bot<BOT_ID>:<BOT_TOKEN>\?chat_id=348399094&text=Hello World !" keep-result=no
What am i doing wrong ?
Shadeofspirit
Tue Oct 10, 2017 10:54 pm
YYYYY bot token
ZZZZZ chat id
first of all:
/sendMessage? before chat_id
the second is, that you can use it in script (create test scrip with only command to send message), because from command line on mikrotik it wouldn't work
MTCNA, MTCWE
benjamimgois
Wed Oct 11, 2017 2:49 pm
first of all:
So the line should look like this ?
/tool fetch url="https://api.telegram.org/bot<BOT_ID>:<BOT_TOKEN>/sendMessage?=Hello World\?chat_id=348399094" keep-result=no
Shadeofspirit
Wed Oct 11, 2017 2:58 pm
first of all:
no, as i had posted:
/tool fetch url="https://api.telegram.org/botXXXXX:YYYYY/sendMessage?chat_id=ZZZZZ&text=Hello World" keep-result=no
MTCNA, MTCWE
benjamimgois
Wed Oct 11, 2017 4:55 pm
first of all:
Well, i tried as you said and now i receive a 404 not found error message. Now i´m posting my bot ID and TOKEN.
[admin@Dude_x86] > /tool fetch url="https://api.telegram.org/bot<BOT_ID>:<BOT_TOKEN=Hello World" keep-result=no
  status: failed
failure: closing connection: <404 Not Found> 149.154.167.198:443 (4)
When i type the URL https://api.telegram.org/bot<BOT_ID>:<BOT_TOKEN/getme on the browser followed by the "getme " i got the following statement
{"ok":true,"result":{"id":BOT_ID,"is_bot":true,"first_name":"xxxx","username":"xxxxxxx"}}
What am i missing here ?
Shadeofspirit
Wed Oct 11, 2017 5:17 pm
Please, write there if you get message in telegram.
If you get - all is correct in your config.
read my previous message - this command can be used in script, but not in command line
MTCNA, MTCWE
benjamimgois
Wed Oct 11, 2017 5:29 pm
Shadeofspirit, i receive your message. Thanks for the help man, i´ll try it on a script as you said.
I worked !!! Thanks for the help Shade !
Shadeofspirit
Wed Oct 11, 2017 5:34 pm
if you want, i can send you script that i used for sending message by skype, telegram, viber, e-mail
and i suggest you to delete your message on forum with your bot token
MTCNA, MTCWE
benjamimgois
Wed Oct 11, 2017 6:15 pm
Yes, could you send me please ? you can post it here on the forum or by gmail if you prefer
benjamim.gois@gmail.com
icecybe
Tue Oct 24, 2017 1:45 pm
Hi hi, team.
I'm stuck on same problem, or similar to this one.
When i test dude notification all working ok, but when some switch in dude lost , the chat bot is silent.
And i dont know where can be the mistake, because all is working but bot in the chat sleeping :)
Any information needed ?
Shadeofspirit
Tue Oct 24, 2017 2:00 pm
Hi hi, team.
did you select this type of notification for this device?
MTCNA, MTCWE
icecybe
Tue Oct 24, 2017 2:37 pm
You mean in : Notification > Advanced tab ? Yes click them all. Is there anywhere else i can check them ?
icecybe
Tue Oct 24, 2017 2:39 pm
/tool fetch url="https://api.telegram.org/botxxxxxxxxx:y ... 1212&text=[Probe.Name] on [Device.Name] now [Service.Status] ([Service.ProblemDescription])"
It work's when i try test, it send's message in chat, but when swich drop nothing happens
Shadeofspirit
Tue Oct 24, 2017 2:56 pm
so, if you had created it notifications for all status changing you want(for example with name "telegram"), than, if you want to have it for all devices. go to settings-polling. make sure that "enabled" is marked and that in the list of notifications there is mark near "telegram"
if you want to have it only for particular device: open this device, polling. make sure that there are marks near "polling", 'use notifications' and 'telegram'
MTCNA, MTCWE
icecybe
Tue Oct 24, 2017 3:18 pm
Damn Dude !!! You are a genious.
Thank's a lot for this small but HUGE help. It work's
tangram
Sun Mar 04, 2018 9:55 am
Why does the ? disappear when you paste in terminal ?
/tool fetch "https://api.telegram.org/botblablabla/s ... thissatest" keep-result=no
turns to /tool fetch "https://api.telegram.org/botblablabla/s ... thissatest" keep-result=no ..can't even write it manually.
This command in terminal fails. I had to make a script just to make it work - don't know yet if you can use this as a global variable.
Bc234
Sun May 13, 2018 10:10 pm
Hai all.. i have ros 6.41.2 on ccr.. notif from netwatch run.. but when notif from dude.. nothing happen.. any sugestion ?
Sent from my HTC One_E8 dual sim using Tapatalk
blackhold
Mon May 14, 2018 9:29 pm
I have configured telegram notifications on dude and the manual have an error
https://wiki.mikrotik.com/wiki/Manual:T ... am_Example
the correct example would be
/tool fetch url="https://api.telegram.org/bot309683994:A ... pleMessage" keep-result=no
instead of:
you have to add "-" sign before chat_id number.
jessequijano
Sat Jun 09, 2018 3:38 am
Any chance to refine this example to include some way for it to check the previous state of the device? or maybe suggestions on increasing my tiggers to avoid getting repetitive "up" status messages when I have never received any down messages on that device? dont get me wrong... I get correct down messages when things actually go down (I only probe with ping and routeros management(when it is an RB)) but I get repetitive up messages.
honestly if there was a way to ONLY get down messages id be fine with that also
edit: duh!!!!! just looked at dude and i can remove "up" messages.
vitorbessa
Mon Sep 24, 2018 2:01 am
The problem is at the moment of entering the interrogation (?), Mikrotik exchanges "sendMessage? Chat_id" with "sendMessagechat_id".
Forgive me for my English.
rarenakal
Wed Nov 21, 2018 6:37 am
have you test on older The Dude versions ?? such as v3.6 ??
3rcom
Sun Dec 02, 2018 3:41 pm
i'm running the dude 6.42.10 on ccr1016 .. but the notification for down device not show up .. only up notification in telegram
i use the script from the wiki .. any suggestion ?
Onlineallthetime
Thu Jan 24, 2019 1:03 am
I had the same problem in my dude server (6.43.8). The fetch tool didn't works when i pressed the "test" button, but you need to execute that command on a terminal in your dude's winbox to see a result or another possible ideas. The link must be in quotes! Don't forget that!
/tool fetch url="https://api.telegram.org/botXXXXX/sendM ... xt=HiThere"
ComNet
Wed Apr 24, 2019 5:01 pm
I tested with 6.44.3 (cannot use other version because incompatible of any devices) and dont work!! Help!!!
jfoster1
Tue Apr 30, 2019 7:03 pm
Here is my experience with telegram notifications.
My Setup:
I have two Dude servers, hex (mmimps) and CCR1009-8g-1S-1S+ (tile) both on 6.44.2
I can get the telegram bot to work perfect on the hex except if I enter the command via CLI Terminal. I get
status: failed
failure: closing connection: <404 Not Found> 149.154.167.220:443 (4)
But I setup a notification and the test button and real world alerts works.
The second dude server on the CCR should be identical the setup as the hex but I get this message if I type the same command via CLI Terminal
status: failed
failure: ssl connection error: internal error (6)
But I setup the notification tool identical to the hex and the test button or the real alerts don't work.
From both routers I can ping external IP's and DNS names no problem so I'm not totally sure what could cause a ssl connection error.
jfoster1
Sat May 11, 2019 12:31 am
I would like to send an update on how I fixed my issues.
My firewall had telegram.com blocked through the content filter. One dude server was exempt and the other dude server wasnt.
sri2007
Mon Sep 16, 2019 7:46 am
Hello everyone, the code is actually working in RouterOS 6.43.16; but if you want to add a biggest message, you'll need to add %20 instead of a space; so please update the Wiki.
New code from text:
text=Time:%20[Time];%20Device:%20[Device.FirstAddress];%20Status:%20[Service.Status]"
MikroTik Support and Consultancy - Español / English +593 93 924 1262
https://www.safenet.ec/consultoria.html/ support@safenet.ec
algisr
Fri Dec 06, 2019 3:10 am
Can anyone post a VIBER fetch command?
Got working Slack fetch command, got working Microsoft Teams command, read that it's easy with telegram and WhatsApp... To bad that I need one for the Viber but cannot crack that one out.
lucasimo88
Wed Jan 01, 2020 9:05 pm
New code from text:
Try this
&text=🖥 Device: [Device.FirstAddress] - <b>[Device.Name]</b>;%0A⏰ Time: [Time];%0Aℹ Status: <b>[Service.Status]</b>&parse_mode=HTML" keep-result=no
ipaulponce
Mon Feb 03, 2020 5:58 pm
New code from text:
Hello!! im using the same version! can you share the command you are using in notifications?
Regards!
mh6562086
Sun Mar 01, 2020 12:00 pm
Notifications in telegrams are of interest only for notifications to come not in private messages but in general chat. Configured as indicated above in private messages come and if in the chat then gives an error. Maybe someone came across this?
company
Mon May 04, 2020 9:12 am
I read several times this topic, and checked my config several times too, but I can't find my fail. I have internet, the bot, the chat_id, the group in Tg, … but I have no response in Telegram.
In this picture, it is my configuration in The Dude, I have The Dude on a VM with free license, and I did the notification config in TheDude and in the devices:
Picture:
https://www.dropbox.com/s/9qnwxk703s8u2 ... a.JPG?dl=0
/tool fetch mode=https url="https://api.telegram.org/bottokenHTTPAPIreceived/sendMessage\?chat_id=-idreceived&text=TEST" keep-result=no
In the other hand, if I try from the terminal of the router I receive the message:
/tool fetch mode=https url="https://api.telegram.org/bottokenHTTPAPIreceived/sendMessage?chat_id=-idreceived&text=TEST" keep-result=no
status: failed
Please , can you help me.
lucasimo88
Wed May 06, 2020 10:59 am
/tool fetch url="https://api.telegram.org/bot123456789:ABCD1efghiL2mnouPqRsT3uvZAB_4CdEFgh/sendMessage?chat_id=-123456789&text=asdasdasd&parse_mode=HTML" keep-result=no
check your link whith this...
in your first link and screenshoot there is an error here: sendMessage\?chat
nikc
Thu Sep 10, 2020 11:50 am
I'm trying to get this going also ... I have a string that when i paste it into the browser it works a charm, but when i try with the below string I get a 404 - any ideas folks, thanks !
/tool fetch url="https://api.telegram.org/bot##57155671: ... _mode=HTML" keep-result=no
Users browsing this forum: No registered users and 18 guests
