Bitrek
The radiation patterns for some boards
Wed Jan 11, 2017 3:27 pm
Here, some of the radiation pattern of antennas Mikrotik (Omnitik 5, QRT-5AC, SextantG, SXT Lite 5, SXT SA 5).
You can download it from:
https://yadi.sk/d/uj3UkKzF38R7DJ
normis
Re: The radiation patterns for some boards
We already provide ANT files, which Radio Mobile can read. I guess you just converted the same? Which program uses this MSI format?
megadimasty
Wed Jan 11, 2017 3:38 pm
Hi Normis!
This files is result of precise and hard work. We digitized your graphical antennas pattern by some soft and then build MSI file format (based on UBNT template)
If possible check them. Maybe some wrong. All of this patterns not public found in ANT or MSI format.
This file is plain text format and easy convert to ANT format
just remember for zero point of ANT is on 90 degree of diagramm
Bitrek team
Bitrek
Wed Jan 11, 2017 7:35 pm
This is patterns for mANT30
https://yadi.sk/d/qbA00Qxf38U2am
andressis2k
Mon Jan 16, 2017 3:37 pm
Where can I find these files?
At routerboard.com I've only found mANT 19s
Regards
normis
Mon Jan 16, 2017 3:40 pm
megadimasty
Wed Jan 18, 2017 7:08 pm
We provide data files only for products that not have it
welcome to share
Bitrek team
rmnalk
Mon Apr 03, 2017 8:05 pm
The radiation patterns for Mant19s shows this, is this correct?.
megadimasty
Mon Apr 10, 2017 8:16 pm
To Rmnalk
Hi! Strange pattern. Why dB scale only up to 20 dBi when gain is 30 dBi
Attached file show right pattern with firs and second side lobe
Maybe this pattern not Lg scale
ndor
Mon Apr 10, 2017 8:58 pm
mANT19 is an sector antenna with an opening of 120 degrees .
This radiation pattern is too narrow .
megadimasty
Wed Apr 12, 2017 11:14 am
My mistake. Sorry. Wrong read about mant19
rmnalk
Thu Apr 20, 2017 1:53 am
Hi, this file is downloaded from https://i.mt.lv/routerboard/files/16090 ... attern.ant and read with radiomobile version 11.6.5, Could someone do this procedure and post the result?.
Regards.
normis
Thu Apr 20, 2017 12:04 pm
Regards.
you have manually entered the gain as 20.
pattern shape will be the same, no matter the gain, the radio waves don't stop :)
abernier
Wed Nov 08, 2017 4:01 pm
Antenna patterns at https://mikrotik.com/product/RBLHG-5nD:
160721104257pattern.ant
160721104238pattern.ant
When I put on radio mobile. It says that LHG has 99,9dbi gain antenna !!!! : I set antenna gain =0 dbi in the configuration system and a I select antenna type= 160721104257pattern.ant
Does the same thing happen to someone else?
Wrong pattern?
Thanks in advance
dhcpy
Tue Jun 19, 2018 1:01 am
Hello all!
Newbie question here.
where can I find radiation patterns of current mikrotik wireless SOHO devices, in just a graphic format? I mean, no need for a file, just for picking a correct device for my scenario. But on product pages I cant seem to find the radiation pattern.
I looked into brochures, don't have it. Quick setup either. wAP ac for instance.
thanks!
chechito
Tue Jun 19, 2018 1:28 am
Hello all!
thanks!
x2
tibobo
Wed Jul 25, 2018 7:16 pm
Hello all!
thanks!
x2
x3
megadimasty
Wed Nov 28, 2018 10:29 am
LHG5 radiation pattern https://yadi.sk/d/1fzzjnJuqXnFBQ
P.S. in original ANT files main power level is up to 24dB - for correct use pattern data need to decrease on it
Users browsing this forum: No registered users and 16 guests
