wil
ipv6 link local address @ bridge
Mon Jan 23, 2017 7:24 pm
Is it new behavior in v6.38 that the bridge interfaces only get a IPv6 link local address if auto-mac=yes? This got me wondering why my router advertisement stopped working after the upgrade from v6.37.3 for a moment. Can anybody confirm my assumption?
Greetings,
Wil
Sob
Re: ipv6 link local address @ bridge
Tue Jan 24, 2017 1:33 am
Quick test with CHR 6.38.1 looks ok:
[sob@test] /interface bridge> print
 0  R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto
      mac-address=00:0C:29:48:04:BA protocol-mode=rstp priority=0x8000 auto-mac=yes
      admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6
      ageing-time=5m
 1  R name="bridge2" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto
      mac-address=FE:12:34:56:78:90 protocol-mode=rstp priority=0x8000 auto-mac=no
      admin-mac=FE:12:34:56:78:90 max-message-age=20s forward-delay=15s transmit-hold-count=6
      ageing-time=5m
[sob@test] /interface bridge> /ipv6 address print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
 #    ADDRESS                                     FROM-POOL INTERFACE                 ADVERTISE
 3 DL fe80::20c:29ff:fe48:4ba/64                            bridge1                   no
 4 DL fe80::fc12:34ff:fe56:7890/64                          bridge2                   no
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
wil
Wed Jan 25, 2017 1:46 am
I tried to reproduce the issue on another router. But I could not reproduce the missing link local address on the bridge interface regardless of auto-mac yes or no. Maybe it was just a glitch with my configuration that has been carried over from ROS v5 times. Anyway thanks for taking a look!
Bye,
Wil
Majklik
Wed Jan 25, 2017 6:40 pm
This is probably a long time problem. I'm seeing problem with missing link local address on the bridge from time of the ROS5.2x version. Sometimes, after ROS starts there are missing link local address on the one or more bridge interfaces. Very similar problem with VRRP interfaces - link local address is showed but do not works.
One possible solution is script which in loop disable/enable bridge interface until link local address is assigned (on VRRP is problem solved after transit among master/slave/master states).
Related to the IPv6 link local addreess: I'm missing possibility to add manual IPv6 link local address. For example on the PtP link where one end to have fe80::1 and second fe80::2...
Users browsing this forum: cedie, LynxChaus, RackKing and 144 guests
