Wyz4k
[BUG] Watchdog timer does not disable properly
Wed Jan 25, 2017 10:05 am
Hi there,
Just found a bug with the watch dog timer that is present in v6.38 at least.
Setup:
Set a watch dog timer to ping an address, say 8.8.8.8. Tick enable watchdog timer.
So far this works as intended.
However if you go back and untick watchdog timer, it still resets if it's unable to ping 8.8.8.8.
You have to remove the IP as well to get it to stop resetting.
sinisa
Re: [BUG] Watchdog timer does not disable properly
Mon Apr 08, 2019 4:58 pm
This is still the same in 6.44.2
Hi there,
Setup:
Phyllo
Fri Jul 12, 2019 11:13 pm
Not to bring a dead thread to life again, but I have to echo that this bug definitely still exists.
ovidiu
Sun Sep 29, 2019 3:19 pm
6.45.3 I have this problem too
Zacharias
Sun Sep 29, 2019 8:42 pm
That is no Bug...
If you enable the watchdog timer then if the device for some reason gets unresponsive for a minute it will recover by rebooting it self..
If you set a watch address, if it wont reply 6 sequential pings the device will also auto reboot.... if you don't set a watch address then this feature is disabled.
As you can see those are two different features...
https://wiki.mikrotik.com/wiki/Manual:System/Watchdog
Users browsing this forum: grizlik911 and 82 guests
