AGriffiths73
Two DVRs
Wed Feb 01, 2017 2:31 pm
Hi
We have two DVR (one DVR, one HVR) onsite and I can only get one to work at a time via our Mikrotik RB. I have duplicated the NAT rules and amended the settings so they work for each system, but when I have both plugged in, only one is accessible.
Is there a way to have the two systems accessible via the LAN and WAN, or will I need a different router?
TIA.
Andrew.
JB172
Re: Two DVRs
Wed Feb 01, 2017 2:38 pm
Did the DVRs have different ip address?
Post an /export hide-sensitive of your router
AGriffiths73
Re: Two DVRs
Wed Feb 01, 2017 2:48 pm
DVR 1 = 192.168.1.140 ports 888 and 9000 and 554
HVR 1 = 192.168.1.141 ports 8888 and 9100 and 554
both have masq rules for the subnet 192.168.1.0/24 to their IPs
Both have DNSNAT rules for their ports for the external IP to each internal IP
I'll try and get an export off in a few mins.
chechito
Re: Two DVRs
Wed Feb 01, 2017 11:27 pm
if you are using the same public ip you have an issue with 554 port because is duplicated on both dvrs
p3rad0x
Long time Member
Long time Member
Re: Two DVRs
Thu Feb 02, 2017 11:45 am
Change the rstp port on the second DVR to 555 and you will be set
