strods
Winbox 3.11 released!
Fri Feb 17, 2017 12:44 pm
What's new in v3.11:
*) fixed wireless interface tabs, HT MCS tab was not shown in 5g/n/ac mode;
*) ask for confirmation when exiting or disconnecting in Safe Mode;
*) fixed problem where context menu Add command could not be selected if it had submenu;
*) fixed problem where ip accounting settings were allways disabled;
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
dgnevans
Re: Winbox 3.11 released!
Fri Feb 17, 2017 12:54 pm
ip accounting
is working again from within winbox
raffav
Fri Feb 17, 2017 1:16 pm
@strods,
just curios how this work
, why take like a 1 day to be available via Winbox
i why do not follow the ROS versioning like. the 3ed dot for fix 3.10.x
juliokato
Fri Feb 17, 2017 1:54 pm
For upload files the Drag and drop is not working!
Bug introduced in v3.10.
[Solution]
I found the problem, it should not be run as administrator mode.
thanks for bagaroon and andriys
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
baragoon
Fri Feb 17, 2017 1:55 pm
But still no Current TX Power in 5g/n/ac mode.
baragoon
Fri Feb 17, 2017 1:57 pm
Works well with wine :shock:
andriys
Fri Feb 17, 2017 2:08 pm
Works fine for me in both 3.10 and 3.11 on Win7 and Win10.
andriys
Fri Feb 17, 2017 2:10 pm
I believe this is not related to WinBox, rather a limitation of the newer (802.11ac-capable) chipsets or drivers.
andriys
Fri Feb 17, 2017 2:11 pm
CDN, I guess.
strods
Fri Feb 17, 2017 2:38 pm
raffav - This is due to cache between upgrade server and your computer;
juliokato - We can not reproduce such issue and seems that others does not have it too;
baragoon - This is not supported for ac wireless cards.
honzam
Fri Feb 17, 2017 4:18 pm
And when it will be supported?
LAN, FTTx, Wireless. ISP operator
strods
Fri Feb 17, 2017 4:20 pm
It is not known yet.
Please remember that this topic is about Winbox only!
pcunite
Fri Feb 17, 2017 4:27 pm
I appreciate the hard work, MikroTik.
planetcoop
Fri Feb 17, 2017 5:27 pm
I don't seem to be able to launch winbox 3.11 with any comparability setting or none of them? Anyone having that issue?
Windows 10 Enterprise 64bit 14393.693
NOTE: i had the same issue with 3.9 but was quickly replaced with 3.10. :)
shahbazian
Trainer
Trainer
Fri Feb 17, 2017 7:50 pm
wireless snooper result don't indented in winbox 3.x
please fix this issue.
send from my Mobile phone using Tapatalk
Learn MikroTik to improve your network.
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE )
MikroTik Certified Trainer & Consultant
RIPE NCC Trainer
bratislav
Sat Feb 18, 2017 12:15 am
What do you mean ...
It seams OK to me ...
shahbazian
Trainer
Trainer
Re: RE: Re: Winbox 3.11 released!
Sat Feb 18, 2017 12:53 am
Check this results in winbox 2.x to see difference.
RIPE NCC Trainer
infused
Sat Feb 18, 2017 7:24 am
Any chance of the shortcuts coming back? I ask every release... every release I have further RSI :D
alexjhart
Re: RE: Winbox 3.11 released!
Sat Feb 18, 2017 7:31 am
Good job on the safe mode confirmation :)
Alex Hart
The Brothers WISP
Micropower
Sat Feb 25, 2017 4:24 pm
" ERROR: RoMON Agent not found. Add it to Managed List." Locks out Winbox ! Deleting the MicroTik folder in %appdata% used to fix it. Not now.
Locked out of the entire network on my primary Windoze PC.Adding valid agents does not help.
Also not clear about the Master Password on the Romon Menu. Perhaps that just locks down
Romon for this session/PC? Is this documented anywhere?
R1CH
Forum Veteran
Forum Veteran
Tue Feb 28, 2017 2:32 pm
Could winbox upgrades could be offered over HTTPS? It's very dangerous to download and automatically run a .exe file over HTTP.
Vlad2
Sun Mar 12, 2017 6:06 pm
1) when you add or change the comment to the pppoe profile (the account on the pppoe-out) then after saving the comment - the interface is re-connected, why? Is it really so necessary?
2) At the expense of screen resolution, somewhere I read that sometimes I do not have enough, sometimes I will also agree, when I have to go and work remotely through an ultrabook with a resolution of 1366 x 768 - it's not always convenient to work, do not throw the ultrabook into garbage ? (Especially since it is on iCore7 and RAM-8Gb with SSD disk). It's not my fault that the manufacturer has saved so much on the matrix as a whole. I believe that while the ROS itself is developing, the utility for administration(Winbox) itself should also be developed. Therefore, the adaptation, the ability to copy a part of the logs (lines) to the buffer and a number of other useful options will not prevent such a convenient program as Winbox
3) Also I would like to still ask for a work-in-progress and that comments can be given to PPTP / L2TP sessions to users, or at least comments showing those that were installed when creating a user. This is not enough, especially pedantic as I
4) Well, a very substantial and necessary request. When you open IP-Routes there the non-working / unavailable routes are highlighted in blue, it's good, but there are routes that are working, accessible, but have a distance more than usual, say "2" or "3" and higher, they have the status - available, but since the distance The other, they also glow blue, and begins at eye level confusion, have to check that where, PLEASE make these routes different from inaccessible and say, highlight them in a different color, say amber. After all, when you work in the SSH console, there are a lot of colors, so why not do a little more convenient and enjoyable work in Winbox.
Thanks and sorry for terribal English
Am using at works and home
3 x CCR1016-12G
RB2011,RB3011
RB951/952,RB760
hAP lite and other devices
raffav
Tue Mar 14, 2017 3:36 pm
@strods and any mk support team
Hello, any change to improve the find box?
it will be much more practical if when we search for something, it only show up the matches or at least highlight the lines instead of only the matched word
thanks
0ldman
Thu Apr 06, 2017 4:48 am
Anyone else having issues opening Winbox?
It will open (or if it is already open) and when I swap networks it will hang for a good 5 minutes with "not responding", then it will eventually come up and work, though sometimes it does it again if I hit refresh.
Initially I thought it was doing that because I didn't have an IP address but this is not the case. I've never had this problem on older versions.
athlonxp78
Sat Apr 08, 2017 11:35 pm
I have this issue, and in my case was caused after the update of our ubnt netwotk to v6.0.3, roll back to v5.6.15 and now all is working normal again.
felted67
Sun Apr 09, 2017 4:34 pm
Hi everyone,
I tried winbox 3.11 with remote access to a "new" domain, ending with toplevel com.de (sub.domain.com.de).
Well, no connection possible this try. Perhaps winbox 3.11 isn´t able to handle such domains (com.de-ending) ?
Thanx and Greetz from Germany.......Detlef
Cha0s
Sun Apr 09, 2017 8:09 pm
Hi everyone,
I highly doubt this is a winbox issue. Check your DNS resolver if it can actually resolve the domain.
If it does, can you connect to the IP directly instead of the domain?
felted67
Sun Apr 09, 2017 10:56 pm
thank you for your kind response. Well, DNS-resolver is working fine
and accessing via IP is also possible without any error.
So I agree to your doubts about winbox 8=)
Perhaps this could me crosschecked by mikrotik ?
Thanks.......Detlef
Cha0s
Sun Apr 09, 2017 11:01 pm
I just created an entry on my hosts file (foo.bar.com.de) and connected with winbox to foo.bar.com.de domain without problem.
jtl
Fri Apr 21, 2017 9:03 am
Do you think Winbox can have higher font size in the future for HiDPI displays?
Running it on OS X with Wine on a Macbook Pro
msatter
Request behavior of Winbox 3.11
Sun Apr 23, 2017 2:35 pm
Desired behavior of Winbox for fields:
- if there is a default value and the field is left blank on apply, insert default value
- if the field is optional and when the field is left blank on apply, then disable it
This would make RouterOS much easier to use and also reduce the number of forum postings because of surprisingly behavior due to not knowing what the default setting is and an open empty optional field blocking the other settings made.
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet, no Amazon/Cloudfront/AWS.
Running:
RouterOS 6.49Beta / Winbox 3.27 64bits
Melbar
Mon Apr 24, 2017 10:00 pm
Winbox 3.11 does not start under Windows 10. After specifying the target IP and the login data the window disappears without error message. Winbox 3.8 is the last version which works with me. However modal windows for this version ( v3.8 ) do not function since the last Windows update.
MfG
alexjhart
Mon Apr 24, 2017 10:30 pm
MfG
3.11 connects fine on Windows 10 for me. I've been using it for a bit now. It is probably a poorly handled error. I've seen that before.
Alex Hart
The Brothers WISP
doneware
Trainer
Trainer
Mon Apr 24, 2017 10:45 pm
i was on an MTCIPv6 course. the slide-deck also says, that Winbox with link-local addresses does work as a substitute for MAC-Winbox, if the device does not have IPv4 address, and indeed it does.
there is however a small issue, and i am not quite sure whether it's a winbox issue or windows issue.
discovery function in winbox is supposed to detect & decode inbound MNDP advertisements. however in ipv6 only setup (windows has no ipv4 enabled) the connected routeros devices are not detected, although the MNDP advertisements are emitted by the device (packet capture shows it clearly).
[bat@hgw] > /tool sniffer packet print detail
 0 time=25.113 num=1 direction=tx src-mac=FE:E5:B6:92:A0:28
   dst-mac=33:33:00:00:00:01 interface=lan
   src-address=fe80::fce5:b6ff:fe92:a028:5678 (discovery)
   dst-address=ff02::1:5678 (discovery) protocol=ipv6 ip-protocol=udp
   size=187 cpu=0 fp=no ip-packet-size=133 ttl=1
they do arrive to my computer (MBA running macOS with IPv4 stack is disabled), but the "wine-bottled winbox" doesn't receives them:
dot:~ bat$ tcpdump -i en0 -n -v -vv -vvv udp and port 5678
tcpdump: listening on en0, link-type EN10MB (Ethernet), capture size 262144 bytes
21:35:07.595116 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 153)
    10.0.5.1.56668 > 255.255.255.255.5678: [udp sum ok] UDP, length 125
21:35:07.596189 IP6 (hlim 1, next-header UDP (17) payload length: 133) fe80::fce5:b6ff:fe92:a028.5678 > ff02::1.5678: [udp sum ok] UDP, length 125
the problem can be recreated with real windows installation as well, did it during the training but i don't have no access to windows computers here.
Is it possible, that winbox does not listen for IPv6 MNDP datagrams? did anybody have similar experiences?
#TR0359
ajack46
Thu Apr 27, 2017 5:04 pm
It is working with me on windows 7 with 3.10
antispam
Mon May 01, 2017 9:58 pm
Winbox 3.11 fails to connect over MAC address on my Windows 10 PC with many NIC. Works fine over IP, once the device has an IP address.
craigroser
Thu May 04, 2017 7:10 am
new in ROS 6.39 is this *) capsman - added EAP identity to registration table;
I can't see it, am i looking in the wrong place? capsman -> registration table -> right click ->show columns
EDIT: Nevermind found this
What's new in 6.40rc2 (2017-Apr-28 05:24):
*) winbox - added "eap-identity" to CAPsMAN registration table;
*) capsman - fixed EAP identity reporting in “registration-table”;
freemannnn
Long time Member
Long time Member
Thu May 04, 2017 8:06 am
so where is this? can u tell as with a screenshot?
mikronsultiK
Fri May 12, 2017 11:35 am
It seems that up to 6.39.1 no EAP Identity column was added in CAPsMAN context menu. while it's availble as attribute in CLI
/capsman registration-table print detail
IP Networking / Mikrotik Consultant
mikronsultik [at] gmail.com
skype mikronsultik
Melbar
Fri May 12, 2017 8:59 pm
I get the following error on Windows 10 with Winbox v3.11:
Code: Select all
Name der fehlerhaften Anwendung: winbox3.11.exe, Version: 0.0.0.0, Zeitstempel: 0x382f3815
Name des fehlerhaften Moduls: winbox3.11.exe, Version: 0.0.0.0, Zeitstempel: 0x382f3815
Ausnahmecode: 0xc0000005
Fehleroffset: 0x0001fa51
ID des fehlerhaften Prozesses: 0x1474
Startzeit der fehlerhaften Anwendung: 0x01d2cb44c67eda47
Pfad der fehlerhaften Anwendung: C:\...\winbox3.11.exe
Pfad des fehlerhaften Moduls: C:\...\winbox3.11.exe
Berichtskennung: 4e57bdb7-e31a-49e8-865d-fff2fa15a718
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
Report.wer:
Code: Select all
Version=1
EventType=APPCRASH
EventTime=131390812234732884
ReportType=2
Consent=1
UploadTime=131390812393841495
ReportStatus=268435456
ReportIdentifier=c1b142b5-0067-4f6d-bd10-90f50a9e1468
IntegratorReportIdentifier=6928f804-def3-4481-a54f-774c08f22285
Wow64Host=34404
Wow64Guest=332
NsAppName=winbox3.11.exe
AppSessionGuid=00005b6c-0001-0034-5a2a-c75f3fcbd201
TargetAppId=W:000652350af861535ab09a1921ee1a7722070000ffff!00006ef48eca4f0eecbae3607278fb5035634db182ad!winbox3.11.exe
TargetAppVer=1999//11//14:22:30:45!1876b1!winbox3.11.exe
BootId=4294967295
ServiceSplit=3539031
TargetAsId=777
Response.BucketId=2306f86015d2793bf2160b77aef5e1a7
Response.BucketTable=1
Response.LegacyBucketId=108767038065
Response.type=4
Sig[0].Name=Anwendungsname
Sig[0].Value=winbox3.11.exe
Sig[1].Name=Anwendungsversion
Sig[1].Value=0.0.0.0
Sig[2].Name=Anwendungszeitstempel
Sig[2].Value=382f3815
Sig[3].Name=Fehlermodulname
Sig[3].Value=winbox3.11.exe
Sig[4].Name=Fehlermodulversion
Sig[4].Value=0.0.0.0
Sig[5].Name=Fehlermodulzeitstempel
Sig[5].Value=382f3815
Sig[6].Name=Ausnahmecode
Sig[6].Value=c0000005
Sig[7].Name=Ausnahmeoffset
Sig[7].Value=0001fa51
DynamicSig[1].Name=Betriebsystemversion
DynamicSig[1].Value=10.0.15063.2.0.0.256.48
DynamicSig[2].Name=Gebietsschema-ID
DynamicSig[2].Value=1031
DynamicSig[22].Name=Zusatzinformation 1
DynamicSig[22].Value=1318
DynamicSig[23].Name=Zusatzinformation 2
DynamicSig[23].Value=13180585e2346aa29e3cbf2471dab9bc
DynamicSig[24].Name=Zusatzinformation 3
DynamicSig[24].Value=2e4f
DynamicSig[25].Name=Zusatzinformation 4
DynamicSig[25].Value=2e4f988f1cf87c85990d7c25ba8183ea
UI[2]=C:\...\winbox3.11.exe
UI[3]=winbox3.11.exe funktioniert nicht mehr
UI[4]=Windows kann online nach einer Lösung für das Problem suchen.
UI[5]=Online nach einer Lösung suchen und das Programm schließen
UI[6]=Später online nach einer Lösung suchen und das Programm schließen
UI[7]=Programm schließen
LoadedModule[0]=C:\...\winbox3.11.exe
LoadedModule[1]=C:\WINDOWS\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\WINDOWS\System32\KERNEL32.DLL
LoadedModule[3]=C:\WINDOWS\System32\KERNELBASE.dll
LoadedModule[4]=C:\Program Files\Bitdefender\Bitdefender 2017\Active Virus Control\Avc3_00119_026\avcuf32.dll
LoadedModule[5]=C:\WINDOWS\System32\ADVAPI32.DLL
LoadedModule[6]=C:\WINDOWS\System32\msvcrt.dll
LoadedModule[7]=C:\WINDOWS\System32\sechost.dll
LoadedModule[8]=C:\WINDOWS\System32\RPCRT4.dll
LoadedModule[9]=C:\WINDOWS\System32\SspiCli.dll
LoadedModule[10]=C:\WINDOWS\System32\CRYPTBASE.dll
LoadedModule[11]=C:\WINDOWS\System32\bcryptPrimitives.dll
LoadedModule[12]=C:\WINDOWS\System32\COMDLG32.DLL
LoadedModule[13]=C:\WINDOWS\System32\combase.dll
LoadedModule[14]=C:\WINDOWS\System32\ucrtbase.dll
LoadedModule[15]=C:\WINDOWS\System32\shcore.dll
LoadedModule[16]=C:\WINDOWS\System32\USER32.dll
LoadedModule[17]=C:\WINDOWS\System32\win32u.dll
LoadedModule[18]=C:\WINDOWS\System32\GDI32.dll
LoadedModule[19]=C:\WINDOWS\System32\gdi32full.dll
LoadedModule[20]=C:\WINDOWS\System32\msvcp_win.dll
LoadedModule[21]=C:\WINDOWS\System32\SHLWAPI.dll
LoadedModule[22]=C:\WINDOWS\System32\SHELL32.dll
LoadedModule[23]=C:\WINDOWS\System32\cfgmgr32.dll
LoadedModule[24]=C:\WINDOWS\System32\windows.storage.dll
LoadedModule[25]=C:\WINDOWS\System32\kernel.appcore.dll
LoadedModule[26]=C:\WINDOWS\System32\powrprof.dll
LoadedModule[27]=C:\WINDOWS\System32\profapi.dll
LoadedModule[28]=C:\WINDOWS\System32\OLE32.dll
LoadedModule[29]=C:\WINDOWS\System32\WS2_32.dll
LoadedModule[30]=C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.15063.0_none_8b4e86125c6fbfec\COMCTL32.DLL
LoadedModule[31]=C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
LoadedModule[32]=C:\WINDOWS\SYSTEM32\WININET.DLL
LoadedModule[33]=C:\WINDOWS\System32\IMM32.DLL
LoadedModule[34]=C:\WINDOWS\system32\uxtheme.dll
LoadedModule[35]=C:\WINDOWS\System32\MSCTF.dll
LoadedModule[36]=C:\WINDOWS\System32\OLEAUT32.dll
LoadedModule[37]=C:\WINDOWS\system32\dwmapi.dll
LoadedModule[38]=K:\WinTemp\ammemb.dll
LoadedModule[39]=C:\WINDOWS\SYSTEM32\version.dll
LoadedModule[40]=C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.15063.0_none_583b8639f462029f\comctl32.DLL
LoadedModule[41]=C:\WINDOWS\System32\TextInputFramework.dll
LoadedModule[42]=C:\WINDOWS\System32\CoreUIComponents.dll
LoadedModule[43]=C:\WINDOWS\System32\CoreMessaging.dll
LoadedModule[44]=C:\WINDOWS\SYSTEM32\ntmarta.dll
LoadedModule[45]=C:\WINDOWS\SYSTEM32\wintypes.dll
LoadedModule[46]=C:\WINDOWS\SYSTEM32\usermgrcli.dll
LoadedModule[47]=C:\WINDOWS\system32\mswsock.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
FriendlyEventName=Nicht mehr funktionsfähig
ConsentKey=APPCRASH
AppPath=C:\...\winbox3.11.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=DA65CC80C150432E4464A152C40DB872
MetadataHash=-1610144767
Debug info:
Eine Ausnahme (erste Chance) bei 0x0042b124 in winbox3.11.exe: 0xC0000005: Zugriffsverletzung beim Lesen an Position 0xfeeefee2.
Unbehandelte Ausnahme bei 0x0042b124 in winbox3.11.exe: 0xC0000005: Zugriffsverletzung beim Lesen an Position 0xfeeefee2.
Disassembly:
Code: Select all
0042B124 add ecx,dword ptr [eax-0Ch]
ferm
Fri May 26, 2017 1:35 pm
Winbox has a bug - in Windows 10 Pro 64-bit with Anniversary Update cannot click on buttons inside DialogBoxes.
otgooneo
Trainer
Trainer
Wed May 31, 2017 7:24 am
v3.11 doesn`t have code signing certificate.
Want to learn more and more...
null31
Wed May 31, 2017 8:03 am
http://drive.google.com/open?id=0BwXRNm ... Dl6NTZfOGc
Fixed image link.
otgooneo
Trainer
Trainer
Wed May 31, 2017 9:42 am
@null31 Appreciated your help.
Railander
Thu Jun 01, 2017 11:26 am
Winbox has a bug - in Windows 10 64-bit with Anniversary Update cannot click on buttons inside DialogBoxes.
can confirm this bug, though i suspect it's a windows bug rather than winbox.
dialog/confirmation boxes cannot be interacted with on windows 10 creators update. examples of such boxes are "do you want to reboot the router? yes/no", "do you want to upgrade the firmware? yes/no", and even the manual file upload window. even clicking the X to close the window does nothing, you need to manually terminate it from the windows taskbar.
a workaround is performing these from the CLI.
have tried on both my PCs upgrade to the creators update and both reproduce this problem 100% of the time, while my other PCs without the update have no problem whatsoever.
Jivo
Thu Jun 01, 2017 4:25 pm
Windows 10 Pro Creator's Edition: When error pops-up, pressing OK button does not do anything and pop-up cannot be closed in any other way than closing Winbox. I have noticed that Winbox works regardless of opened and frozen pop-up in most cases.
Does anyone else have this problem?
BR,
Jivo
ferm
Fri Jun 02, 2017 6:01 pm
I have the same problem as Jivo. I wrote about it in #41.
Melbar
Sun Jun 04, 2017 6:54 pm
I have the problem as well.
Matess
Wed Jun 07, 2017 12:33 am
I have contacted MS support.
it is a known bug and maybe it will be fixed within 30 days.
For now it is recomended downgrading back - control panel, recovery, get back to previsios version of windows 10. (dont know this exactly - translating from cz to en)
It is possible to do it with in 10 days (i think) after upgrade. You can upgrade to newer version when it is fixed.
Tejen
Wed Jun 28, 2017 6:29 pm
schadom
Mon Jul 31, 2017 2:57 am
Winbox 3.11 currently misses the "Dst. Address" filter attribute under IPv6 => Routes
Maybe this could be added in v3.12
slimmerwifi
Tue Aug 01, 2017 6:24 pm
I would like to request that copying and pasting within winbox (using CTRL+C/CTRL+V) is added. Easier then right clicking and pressing copy and paste every time.
Not sure why it doesn't work (3.11, Windows 10)
We manage 50+ corporate wifi networks in the Netherlands using Mikrotik & Cloudcore equipment.
alexjhart
Tue Aug 01, 2017 7:23 pm
Amen!
Sent from my SM-G930T using Tapatalk
Alex Hart
The Brothers WISP
Sob
Tue Aug 01, 2017 7:41 pm
WinBox of course does have keyboard shortcuts for clipboard operations. But it's true that they don't work everywhere.
All kinds of editable fields are fine (simple edits like Address in IP address dialog, editable comboxes like Chain in firewall rules; I'm not sure right now if there are more types).
But there are some places where they don't work:
1) Read-only fields (e.g. in System->Resources dialog). Copy should work, but it doesn't.
2) Terminal. Nothing at all.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
Chupaka
Wed Aug 02, 2017 8:30 am
Well, at least, Shift+Insert works for Paste :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Sob
Wed Aug 02, 2017 6:05 pm
Oops, my bad. But that's good news, it means we're almost there. It will be hard to please fans of Ctrl+X/C/V, because Ctrl+X already triggers safe mode and Ctrl+C interrupts actions. But we know there's only one set of true clipboard shortcuts, right? :) And Ctrl+Ins and Shift+Del don't conflict with anything.
Earltaylor
Sat Aug 05, 2017 1:20 pm
DNS-resolver is working fine.
ovdeathiam
Sun Aug 06, 2017 3:04 pm
I've noticed that Winbox doesn't use UTF-8 for comments, although these work well when using SSH, Telnet or even Tik-App on Android.
I use an external API to identify IPs for incoming connections (country, city, company it's registered to) and some of these look unreadable in Winbox.
Can I request a fix for it?
grizly
Fri Aug 11, 2017 10:25 am
On Windows8 I can run it, but cannot connect to any of my routers, if I try an older version, it says I need to update, which gives me 3.11.. when I try and connect I get the error:
ERROR: no roteros.jg found
Not sure what that means, Google hasn't been forthcoming. Possibly a picture with a typo? routeros.jpg?
I'm able to connect by using my linux machine and wine.. typical that wine is better than windows 8.. but still.
I tried deleting APPDATA/Roaming/Mikrotik folder, no difference.
Can't connect to any of my RB1200 or RB912UAG's or my RB953GS.. hmm.
pe1chl
Mon Aug 14, 2017 4:06 pm
Feature request: an option to store the session state (window size/pos, column selection/width etc) on the router flash.
Of course it should not include login passwords etc. This would be very useful when managing the same router from
different machines, without mechanism to access the same .viw files from the different machines.
Cha0s
Mon Aug 14, 2017 4:09 pm
+1
TomjNorthIdaho
Wed Aug 23, 2017 1:51 am
Feature request for Winbox
I would like to see a new feature in Winbox which will allow the following:
1) - Winbox to a Mikrotik
2) - In that Mikrotik, go to IP - Neighbors
3) - When looking at the IP-Neighbors screen , you currently have the option to (Ping, MAC Ping, Telnet, MAC Telnet, Torch).
- - - I would like to see two new options ( Winbox to MAC & Winbox to IP )
Additionally - to the two above requests , is it also possible to have two more options (Proxy Winbox to MAC & Proxy Winbox to IP).
Sometimes, the Windows based computer may not be able to Winbox to a neighbor seen on another Mikrotik. This is where a Proxy Winbox (via the Mikrotik man-in-the-middle) would come in very handy.
North Idaho Tom Jones
andriys
Wed Aug 23, 2017 10:59 am
Isn't it what RoMON is meant to be used for?
pe1chl
Wed Aug 23, 2017 11:58 am
Feature request: change the "select columns" widget so that is is possible to tick/untick several column entries without having to open the widget every time.
E.g. make it bring up a dialog with all column names and checkmarks (arranged so it fits on the screen) and an OK button to submit all changes and close it.
TomjNorthIdaho
Wed Aug 23, 2017 7:32 pm
To be honest, I have never tested or played with RoMON.
However in my brief reading about RoMON, it appears that RoMON needs to be an enabled service on every Mikrotik (possibly on all networks, including those networks not directly connected to my office network equipment).
I have no idea what effects my entire network would experience if enabled the RoMON service on 1,000+ Mikrotiks.
I think it would be easier to have an option in winbox to use a url something like this: winbox 192.168.56.1 at 10.1.3.55 or winbox 22.22.22.12.34.56 at 172.16.11.30 (or some any combination) - and have the ability for winbox to offer those proxy winbox connections when looking at ip neighbors.
((Interesting old email feature somewhat related - it is possible (with correct server configurations) to send an email with a destination email address like this: somebody@somewhere.com@whoknowswhere.com@wonka.net@44.33.22.11@mydomain.com . This type of an email address allows you to choose the email path for SMTP delivery. I think something like this built natively into Winbox and ROS could be very handy.
I will have to take a closer look at RoMON, however I would like to see a native winbox proxy support in Winbox and ROS without the need to turn on an additional network service in other Mikrotiks.
alexjhart
Wed Aug 23, 2017 9:53 pm
Yes, also drag and drop column ordering. Either an easy to open widget as pe1chl describes here for selecting columns, or the addition of right click on the columns to get the list.
For example, want to see fcs errors on all interfaces at once? The current interface is especially frustrating for things like this.
After bringing up the interface list and selecting the ethernet tab:
1. click the down arrow
2. hover over show columns
3. struggle/convince the interface to scroll to the bottom of the very long list
4. select the tx column
5. repeat for rx column
Want other rx/tx error types? 10 steps for each of those. Uh-oh! now you have to remove some columns or resize several to see the ones you want because too many are selected...
I'd rather the pain-free alternatives suggested above!
Alex Hart
The Brothers WISP
pe1chl
Wed Aug 23, 2017 10:03 pm
That is of course why I request that feature... it requires a lot of clicking and mouse movement to add or remove a single column, and often you want to do many.
E.g. I often start with removing all FP counter columns because I have FP disabled anyway. Just to make room. And then add suitable columns.
To make it all worse, the settings are per-PC per-router. So my PC at home does not share the settings with the PC at work (see other request above) and for each router I manage on either PC I need to re-do those settings. Maybe it would be possible to copy some .viw at the beginning, but there is nothing to make a change to a bunch of sessions at the same time.
So I feel I waste a lot of time on interface customization, and everything that helps reduce that would be welcome.
PatrickDunn
Mon Aug 28, 2017 12:50 pm
What is really the use of winbox?
BartoszP
Mon Aug 28, 2017 1:18 pm
Winbox = GUI configuration manager for Mikrotik's products. Much more comfortable/usable than WWW version which is WebFig.
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
Vlad2
Sun Sep 03, 2017 5:29 am
Dear developers, faced with such a problem. Occasionally it is necessary to maintain router installed far and working on satellite communications.
The connection is stable (at 100 ping only 1-2 loss), but the speed is very slow - from 750мс to 2500мс. And the problem is,
when connected to the router via Winbox you should maybe just 5-10 seconds to do the Disconnect, but maybe after 40-60 sec.
And so, intermittently and continuously. This is very annoying.
Immediately anticipate Your questions:
Routers model 952 (them more ten), these problems were there and on 6.38.5 and on and on 6.40.2 and 6.40.3. Winbox 3.11, also tried with different systems(OS Wins), and with different providers.
And more proof that the problem is in the connection Protocol Winbox - launched session via SSH service to routers - more than 6 hours and the session is not impacted.
Therefore, please perform all this if possible, and adjust for Winbox connection timeout on the gap bigger.
Addition:
on 3 different remote routers configured tunnels (GRE) to the Central router and inside the tunnels allowed different IP traffic. Traffic was not interrupted, everything worked normally. BUT the connection to the routers(via Winbox) for the remote IP addressing through the tunnels - the same as it was, was a spontaneous disconnect even inside the tunnel.
From this we can draw conclusions that other IP protocols are not affected and work correctly, and only the connection Protocol to the routers somehow sensitive either to speed or to delay, or something inside Winbox broke.
Thanks in advance and sorry for English
3 x CCR1016-12G
RB2011,RB3011
RB951/952,RB760
Wallace33
Thu Sep 07, 2017 12:05 pm
Hello
James
PatrickDunn
Wed Sep 13, 2017 4:41 pm
How this work? :(
twowaygj
Thu Oct 26, 2017 5:10 am
I have a dozen or so RB3011 routers in service and have GRE tunnels to each from our main location. But when I open Winbox there are a couple of routers that do not show up in my router list, either by MAC or IP address. As far as I can tell they are set up like all of the rest, but those two don't show up in the list. I can access either router by IP address if I type it in and login and communicate with them just fine, but no matter how many times i refresh the list the two routers do no show up.
WinBos 3.11
All routers have 6.40.0 firmware
win 10 and win 7 pro machines.
Any ideas?
Thanks,
Chris
pe1chl
Thu Oct 26, 2017 10:50 am
I never knew different than that I need to manually add all routers that are not local to the network... I would be surprised when they show up automatically being behind GRE tunnels.
I just type the input fields one time and do add/set and it is in the list.
twowaygj
Thu Oct 26, 2017 9:38 pm
Yes, pe1chl, that works for my managed list. But all of the remote routers show up in my neighbors list, except for those two sites.
Not sure why? Thanks
pe1chl
Thu Oct 26, 2017 10:51 pm
I have no idea. None of my non-local routers show up in my neighbors list automatically.
The only situation where I could see that happen is when EoIP is used. Not with GRE.
JimmyNyholm
Sun Oct 29, 2017 8:35 pm
WinBos 3.11
Any ideas?
Thanks,
Chris
/ip neighbor export ? Check to se if it is configured differently....
Begetan
Mon Oct 30, 2017 10:28 am
WinBox 3.11 together with ROS 6.40.4 doesn't show hardware acceleration flag on the: "IP -> IPsec -> Installed SAs"
WebFig does.
viewtopic.php?f=2&t=127066&p=625508
Is there eny open issue about that?
twowaygj
Wed Nov 01, 2017 12:05 am
Jimmy,
I did /ip neighbor export on one that works and one that doesn't and they both show up as discovery=no? SO they appear to be the same there anyway.
JimmyNyholm
Sat Nov 04, 2017 4:32 pm
Jimmy,
The interfaces that you need the router to be found on should not be in list as discovery=no.
/ip neighbor discovery print
will print you all interfaces with their status as to if discovery is enabled on them or not. change the settings to suit your needs.
One thing is winbox able to find router: This is IP Discover.
If winbox traffic will be accepted after klicking or manualy trying to connect is another one.
IP - /ip service (enabled) and perhaps restricted. User maybe ip restricted. (IP Firewal rules inbound, related established outbound)
MAC - tool macserver check settings here. no firewall here but due to mac bridged segment only.
If you don't solve it create a new thread posting your configs so we may help you with your specific problem that is not related to this winbox version.
vecernik87
Forum Veteran
Forum Veteran
Mon Nov 13, 2017 2:05 am
reporting same error as #41, #45, #46 and many others: some popups are not clickable - cant click yes/no, neither close the popup. Running Winbox 3.11 on Windows 10 Pro x64 (15063.632)
According to #49, MS promised the fix but it didnt arrive yet. (has been several month, guess no fix from MS will come ever).
Personally, I believe it is in Mikrotik's hands to fix this. Apparently they use some unusual api because this is the only app I use which is affected since creators update. In addition, most of boxes inside winbox work. Only some (question-style-popups) do not. This suggests that implementing all popups same way will make things work again. Did anyone get official statement from mikrotik in regards to this issue?
rushlife
Mon Nov 13, 2017 11:24 am
Hi guys, it is here some list of shortcuts for using with winbox ?
Support winbox actually some shortcuts ? I could be superb.
bestia
Tue Nov 21, 2017 5:28 pm
I can't figure out how to winbox to my Mikrotik router (OS 6.38.1 Routerboard RB435G) There is no 'search' or '...' next to 'connect to' --- everything I read seems to state this exists, but I don't see it. I've tried via router IP, but nothing. I'm connecting via laptop/RJ45 ... and have the wifi turned off. I can get a MAC under the 'neighbors' tab, but doesn't connect to that MAC.
IF I can get in, I think I can get my LIFX bulbs to work. I think because it's hanging off my cable modem, it's in bridged mode and isn't handing out DHCP... there might be a UDP Port that needs to be open too (57900?)
IF anyone out there can lend some advice, that will save me throwing this thing in the garbage and buying a new one at Best Buy that has an interface I can access and configure.
Cheers, Bestia
freemannnn
Long time Member
Long time Member
Tue Nov 28, 2017 12:22 pm
can you make right click "copy" able in tools ip scan. i want to copy mac addresses and i have to do it by hand one by one.
Cha0s
Tue Nov 28, 2017 12:26 pm
+1
TomosRider
Fri Dec 01, 2017 6:18 pm
Hello guys.
Maybe helpful hint: Can WInbox have a bar where you can see actual version of ROS of router you manage?
Cha0s
Fri Dec 01, 2017 6:21 pm
The title bar of the winbox window already contains the username@IP, hostname(identity), RB model and architecture and finally the ROS version.
Caci99
Fri Dec 08, 2017 1:49 pm
Strangely enough, today the winbox 3.11 was reported as virus form Avira, containing traces of TR/AD.Swrort.absza. This has to be a false positive, I have being using winbox 3.11 since when it came out with the same antivirus protection. An update of Avira might have caused the problem.
-Toni-
Don't crash the ambulance, whatever you do
chuky0
Fri Dec 15, 2017 6:18 am
winbox stopped seeing my Mikrotik devices ipv6 addresses in neighbor tab. I used to be able to login with the ipv6 address and did so just for the fun of it. This happened once before and resolved on reboot of my hEX router. It did not resolve this time with a reboot.There have been no configuration changes made by me, those v6 addresses just stopped showing up in winbox its own. ipv6 is still working fine. I have not lost any functionality using only the v4 login, but I would like to know why it is no longer an option. When i put link local address in the connect to field in brackets I can connect fine. So, I was wondering what gives. ImageCapture
bestazy
Thu Jan 04, 2018 2:01 pm
Thanks for great app but sometimes the app just freezes for no reason and I have to force quit it. Sometimes it freezes when copying or cutting text (eg. in the script editor). Sometimes it continues to allow me to open windows and click buttons but then after a while I realise it has crapped out. Sometimes L2 discovery doesn't work when I launch the app. Sometimes my saved routers just don't work. Whenever I enter an incorrect password (or the app crashes) the entire app quits and I have to relaunch the app in Wine, retype the router IP, etc.
How to get Winbox running more acceptably in Wine on Mac OS?
rushlife
Sat Jan 06, 2018 9:48 am
up
Caci99
Mon Jan 29, 2018 8:59 pm
Having trouble since a couple of days ago sorting saved routers by "Note" column. Using winbox 3.11 on Win7, but being using it like this for a long time and did not have this issue. Now that I'm trying to add a new router and a note for it, will put it always last, unless I add a 0 before the note will bring it to the top.
What might be causing it?
-Toni-
pe1chl
Mon Jan 29, 2018 9:20 pm
You clicked on the Note header to cause it to be sorted by Note.
Click on the column header you want to use for sorting, you can sort on 2 different colums this way.
This is indicated by the arrow in the column header.
Caci99
Mon Jan 29, 2018 10:59 pm
It is not that. The sorting on the Note column somehow is not behaving as it should. Even if I go and click on Group column, which is empty and click on Note it still puts the new entry at the bottom, where it shouldn't be.
-Toni-
strods
Thu Feb 01, 2018 3:22 pm
Winbox 3.12 has been released:
viewtopic.php?f=21&t=130319
Users browsing this forum: No registered users and 9 guests
