mperdue
Select between b/g and clients drop
Fri Nov 03, 2006 5:41 pm
I have sanyo radio's and there is an optionto run 802.11b/g or 802.11b only or 802.11g only.
At the moment I have selected 802.11b and whenever I select 802.11b/g all the b clients drop. Is this normal or I am I not understanding the way b/g is suppost to work?
-Michael
ejansson
Fri Nov 03, 2006 9:41 pm
If you ap is in b and g mode both type of clients should be able to attach. However if any b client attaches, communications to you g clients will be draged down to that of a b client. The higher through put on g require a better signal to noise ratio, so in a noisy enviroment g clients may not attach if you have disabled some of the lower speeds. But if your set up is correct there should be no reason the clients drop.
Users browsing this forum: No registered users and 67 guests
