MUM Europe 2020
Diganet
Overclocking issues
Fri Nov 03, 2006 11:23 pm
I have 2 RB532As running 2.9.34. If i try to overclock any of them, they jump fine to 330MHz (tried both BIOS and Console) but reset either after a short time or after powercycling/reboot. In BIOS i can see it sets 330MHz as safe frequency even after reboot/powercycling, but never keeps it even if i told it so..
Why?
/Henrik
stealth
Re: Overclocking issues
Wed Nov 08, 2006 11:06 am
Why?
/Henrik
I had the same problem on 2.9.32. About month ago, I posted that on this forum. Someone from mikrotik wrote that they tried to fix broblem when RB532 is interferencing with other devices on about 100Mhz frequency by force disabling 333Mhz frequency setting. They definety shoud add this to official changelog. After several days someone delete this thread, becase someone don't really like when there is posts about mikrotik problems at all. I downgrade to 2.9.28 where 333Mhz option works fine.
Are you sure you are setting frequency the right way ? because on 2.9.32 there was no 333mhz option at all.
set frequency, keep-frequency, plug off power, plug on
Diganet
Fri Nov 10, 2006 1:08 am
Why?
/Henrik
Solved it, maybe i just should have read instructions carefully instead of using logic.. set frequency, power off/on, keep frequency, then it works..
/Henrik
Users browsing this forum: No registered users and 23 guests
