mohsen1981
CAPsMAN superchannel support
Thu Feb 23, 2017 11:06 am
Does CAPsMAN support superchannel frequencies?
p3rad0x
Long time Member
Long time Member
Re: CAPsMAN superchannel support
Tue Feb 28, 2017 9:52 am
I think you should be able to manually add a frequency and just enter the supper channel ones you are planning to use
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
marlab
Sat Mar 02, 2019 9:25 pm
I just tried with CAPSMAN 2 and ROS v6.44 - if you do so, there is "unsupported channel" message" with CAPSMAN 2.
I know it's an old thread, just I could not find solution elsewhere.
Users browsing this forum: Baidu [Spider], dadda, quackyo and 55 guests
