MUM Europe 2020
tiger4020
Tower 1 to Tower 2 transport data
Thu Feb 23, 2017 1:08 pm
Hello everyone,
I have Image
The radios at tower 1 are connected fine to tower 2. I get speeds of above 35Mbps. But the data being pulled at tower 2 when I connect the ptp to the AP's (via a switch) does not exceed 6Mbps.
Getting a lot of customer complains from clients connected to tower 2 AP's.
After studying my case it looks like I need a router at tower 2 instead of a switch.
Please guide me how do I go about this.
Thank you.
Sent from my SAMSUNG-SM-G935A using Tapatalk
IPANetEngineer
Trainer
Trainer
Re: Tower 1 to Tower 2 transport data
Thu Feb 23, 2017 6:25 pm
Ideally you need a router at each tower and start with OSPF. BGP is really ideal in the long term as OSPF quickly becomes unmanageable for traffic engineering but you can get started with OSPF. because you are PPPoE based, you can use EoIP until you are comfortable enough to use VPLS over OSPF which is the best way.
Take a look at this example:
http://wiki.mikrotik.com/wiki/Manual:OSPF-examples
And then build it virtually with CHR in GNS3 before you try to convert in production. We use GNS3 so much to validate networks for our consulting that we have entire servers dedicated to it so we can spin up dozens of routers if need be.
https://www.gns3.com/
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
tiger4020
Thu Feb 23, 2017 6:30 pm
I tried OSPF but at the main router I won't see the tower 2 router under main router neighbor list.
InoX
Fri Feb 24, 2017 12:00 am
I'm pretty sure you have a wireless problem not bridge/routing problem.
tiger4020
Fri Feb 24, 2017 3:33 pm
It was a switch problem.. installed a new mikrotik in bridge mode.. Everything is back to normal.. but with the increasing number of users on tower 2 I need to setup OSPF.
InoX
Fri Feb 24, 2017 7:34 pm
But a mikrotik in bridge mode is like a software switch. Are you sure your switch wasn't a bad one?
tiger4020
Fri Feb 24, 2017 7:43 pm
I am sure it went bad..
Users browsing this forum: No registered users and 34 guests
