alaa2003
l2tp client issue- connecting
Tue Mar 07, 2017 8:16 pm
hello
i have router: RB2011UiAS-2HnD
version: 6.38.1 (stable)
bug is:
when my router shutdown suddenly or some times i did reboot after it back i noticed that my l2tp not able to reconnect
it stuck on connecting then disconnected & so on
it did not give any reason of disconnect in log screen
i checked the remote Mtik (server) Log , there is no incoming connection , that mean issue not from mtik Server
how can i fix issue temporarily:
from client : i disconnect my l2tp client for 10 minutes , then re-connect (enable) it again --->> it connected like a charm
so i need this bug fixed parmently by new SW
regards
Alaa
alaa2003
Re: l2tp client issue- connecting
Tue Mar 07, 2017 11:14 pm
after enable debug to l2tp
found (from) appear ip is: 0.0.0.0:1701
after set DMZ to mtik router ip from Modem
((from)) ip changed to Mtik router IP:1701 instead of 0.0.0.0:1701
l2tp connected , Under monitoring
alaa2003
Mon Mar 13, 2017 8:25 am
after monitoring >> issue still exist
issue come when local ip become like : 0.0.0.0:1721 instead of numeric
notice ( it happened also after Modem restarted)
Hensarj
Mon Mar 20, 2017 4:50 pm
Same issue here..... Need help :(
tabraham
Mon Mar 20, 2017 7:51 pm
schedule this script to run every 5-10 minutes (Or you can also schedule to run this script to run only in startup). I have scheduled to run it every 10 mins.
The script checks the L2TP and does nothing if it is running, but if the connection is not running, it disables the interface and waits for 5 mins and then automatically enables it.
* change the line "l2tp-out1" to your l2tp interface name...
* change the delay value "300" to your desired seconds...
This code can be used for any PPP interfaces just need the change the type of interface as well as the name to work
:if ([/interface l2tp-client get l2tp-out1 running]=true) do={:log warning "l2tp-out1 is running perfectly";} else={:log warning "l2tp-out1 NOT running"; :interface l2tp-client disable l2tp-out1; :delay 300; :interface l2tp-client enable l2tp-out1;};
P.S. Attention Mikrotik Admins. I believe, if I am not wrong, that this is a bug in the new firmware (6.3). My old machines running in legacy firmware never had this problem.
alaa2003
Fri Jun 23, 2017 12:40 am
Hensarj thx for ping & confirm bug
dear tabraham, thanks for cool script
currently issue exist even with last SW 6.39.2
bug as shown 0.0.0.0 instead of router IP
Ozzone
Fri Jun 23, 2017 1:35 am
idlemind
Tue Jun 27, 2017 7:12 am
Are you sure your PPPoE setup is re-establishing correctly? I ran a test w/6.40rc24 with just L2TP server and client machines. They re-established fine whenever I killed a link in the middle between the server and client.
PPPoE should have a timeout value set very much like L2TP and the messages you are highlighting with the value 0.0.0.0/0 are irrelevant. You can see from the complete log below that the 0.0.0.0/0 destination is not important at least in the scope o the error. I'd have to dive into it more to see if there is a logical reason for the 0.0.0.0/0 value or if the error is just poorly formatted. Either way that alone does not indicate the problem.
TLDR; verify that your PPPoE client is re-establishing correctly. You may need to define a timeout value in either or both of the PPPoE client or server. This may require a call to your ISP or whoever runs the PPPoE server.
[admin@l2tp-client1] >
03:54:19 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 192.168.1.6:1701
03:54:19 echo: l2tp,debug,packet tunnel-id=3, session-id=0, ns=9, nr=7
03:54:19 echo: l2tp,debug,packet (M) Message-Type=HELLO
03:54:27 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 192.168.1.6:1701
03:54:27 echo: l2tp,debug,packet tunnel-id=3, session-id=0, ns=9, nr=7
03:54:27 echo: l2tp,debug,packet (M) Message-Type=HELLO
(33 messages discarded)
03:54:35 echo: l2tp,debug tunnel 5 entering state: wait-ctl-reply
03:54:35 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:35 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:35 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:35 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:35 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:35 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:35 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:35 echo: l2tp,debug,packet (M) Host-Name="l2tp-client1"
03:54:35 echo: l2tp,debug,packet Vendor-Name="MikroTik"
03:54:35 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:35 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:36 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:36 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:36 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:36 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:36 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:36 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:36 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:36 echo: l2tp,debug,packet (M) Host-Name="l2tp-client1"
03:54:36 echo: l2tp,debug,packet Vendor-Name="MikroTik"
03:54:36 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:36 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:37 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:37 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:37 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:37 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:37 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:37 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:37 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:37 echo: l2tp,debug,packet (M) Host-Name="l2tp-client1"
03:54:37 echo: l2tp,debug,packet Vendor-Name="MikroTik"
03:54:37 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:37 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:39 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:39 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:39 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:39 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:39 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:39 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:39 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:39 echo: l2tp,debug,packet (M) Host-Name="l2tp-client1"
03:54:39 echo: l2tp,debug,packet Vendor-Name="MikroTik"
03:54:39 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:39 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:43 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:43 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:43 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:43 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:43 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:43 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:43 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:43 echo: l2tp,debug,packet (M) Host-Name="l2tp-client1"
03:54:43 echo: l2tp,debug,packet Vendor-Name="MikroTik"
03:54:43 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:43 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:51 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:54:51 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:54:51 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:54:51 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:54:51 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:54:51 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:54:51 echo: l2tp,debug,packet Firmware-Revision=0x1
03:54:51 echo: l2tp,debug,packet (M) Host-Name="l2tp-client1"
03:54:51 echo: l2tp,debug,packet Vendor-Name="MikroTik"
03:54:51 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=5
03:54:51 echo: l2tp,debug,packet (M) Receive-Window-Size=4
03:54:59 echo: l2tp,debug tunnel 5 received no replies, disconnecting
03:54:59 echo: l2tp,debug tunnel 5 entering state: dead
03:54:59 echo: l2tp,debug session 1 entering state: dead
03:54:59 echo: l2tp,ppp,info l2tp-client1: terminating... - session closed
03:54:59 echo: l2tp,ppp,debug l2tp-client1: LCP lowerdown
03:54:59 echo: l2tp,ppp,debug l2tp-client1: LCP down event in starting state
03:54:59 echo: l2tp,ppp,info l2tp-client1: disconnected
(2 messages discarded)
03:55:00 echo: l2tp,debug tunnel 6 entering state: wait-ctl-reply
03:55:00 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 0.0.0.0:1701
03:55:00 echo: l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
03:55:00 echo: l2tp,debug,packet (M) Message-Type=SCCRQ
03:55:00 echo: l2tp,debug,packet (M) Protocol-Version=0x01:00
03:55:00 echo: l2tp,debug,packet (M) Framing-Capabilities=0x1
03:55:00 echo: l2tp,debug,packet (M) Bearer-Capabilities=0x0
03:55:00 echo: l2tp,debug,packet Firmware-Revision=0x1
03:55:00 echo: l2tp,debug,packet (M) Host-Name="l2tp-client1"
03:55:00 echo: l2tp,debug,packet Vendor-Name="MikroTik"
03:55:00 echo: l2tp,debug,packet (M) Assigned-Tunnel-ID=6
03:55:00 echo: l2tp,debug,packet (M) Receive-Window-Size=4
(99 messages discarded)
03:55:01 echo: l2tp,ppp,debug,packet l2tp-client1: sent IPCP ConfReq id=0x8
03:55:01 echo: l2tp,ppp,debug,packet <addr 172.16.1.61>
03:55:01 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd MPLSCP ConfAck id=0x4
03:55:01 echo: l2tp,ppp,debug l2tp-client1: MPLSCP opened
03:55:01 echo: l2tp,ppp,info l2tp-client1: connected
03:55:01 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd CCP ConfAck id=0x4
03:55:01 echo: l2tp,ppp,debug,packet <mppe 1000040>
03:55:01 echo: l2tp,ppp,debug l2tp-client1: CCP opened
03:55:01 echo: l2tp,ppp,info l2tp-client1: using encoding - MPPE128 stateless
03:55:01 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd IPCP ConfAck id=0x8
03:55:01 echo: l2tp,ppp,debug l2tp-client1: IPCP opened
03:56:01 echo: l2tp,debug,packet (M) Message-Type=HELLO
03:56:01 echo: l2tp,debug,packet rcvd control message from 192.168.1.2:1701 to 192.168.1.6:1701
03:56:01 echo: l2tp,debug,packet tunnel-id=6, session-id=0, ns=2, nr=4
03:56:01 echo: l2tp,debug,packet sent control message (ack) to 192.168.1.2:1701 from 192.168.1.6:1701
03:56:01 echo: l2tp,debug,packet tunnel-id=4, session-id=0, ns=5, nr=3
03:56:01 echo: l2tp,debug,packet rcvd control message (ack) from 192.168.1.2:1701 to 192.168.1.6:1701
03:56:01 echo: l2tp,debug,packet tunnel-id=6, session-id=0, ns=3, nr=5
03:56:01 echo: l2tp,ppp,debug,packet l2tp-client1: sent LCP EchoReq id=0x0
03:56:01 echo: l2tp,ppp,debug,packet <magic 0x7de9507a>
03:56:01 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd LCP EchoRep id=0x0
03:56:01 echo: l2tp,ppp,debug,packet <magic 0x66331cb9>
03:56:31 echo: l2tp,ppp,debug,packet l2tp-client1: rcvd LCP EchoReq id=0x0
03:56:31 echo: l2tp,ppp,debug,packet <magic 0x66331cb9>
03:56:31 echo: l2tp,ppp,debug,packet l2tp-client1: sent LCP EchoRep id=0x0
03:56:31 echo: l2tp,ppp,debug,packet <magic 0x7de9507a>
03:57:01 echo: l2tp,debug,packet sent control message to 192.168.1.2:1701 from 192.168.1.6:1701
03:57:01 echo: l2tp,debug,packet tunnel-id=4, session-id=0, ns=5, nr=3
03:57:01 echo: l2tp,debug,packet (M) Message-Type=HELLO
03:57:01 echo: l2tp,debug,packet rcvd control message from 192.168.1.2:1701 to 192.168.1.6:1701
03:57:01 echo: l2tp,debug,packet tunnel-id=6, session-id=0, ns=3, nr=5
03:57:01 echo: l2tp,debug,packet sent control message (ack) to 192.168.1.2:1701 from 192.168.1.6:1701
03:57:01 echo: l2tp,debug,packet tunnel-id=4, session-id=0, ns=6, nr=4
03:57:01 echo: l2tp,debug,packet rcvd control message (ack) from 192.168.1.2:1701 to 192.168.1.6:1701
03:57:01 echo: l2tp,debug,packet tunnel-id=6, session-id=0, ns=4, nr=6
Sidius
Sun Apr 28, 2019 2:11 pm
I have the same issue with new 6.44.1 and 6.44.3.
I have 6.44.1 putted as VPN server in my main site.
And i have 6.44.3 is far from in village.
In village i have do not so stable internet connection and it's disappear often.
So when internet connection is disappear and bring back my l2tp connection is not establish
Logs from Mikrotik on server side 6.44.1
11:12:15 ipsec,info respond new phase 1 (Identity Protection): server.ip[500]<=>client.ip[500]
11:12:25 ipsec,info the packet is retransmitted by client.ip[500].
11:12:35 ipsec,info the packet is retransmitted by client.ip[500].
11:12:38 ipsec,error phase1 negotiation failed due to time up server.ip[500]<=>client.ip[500] bddf6a38eef103ca:7a4209342a239ce7
and so on
Logs from Mikrotik on client side 6.44.3
11:12:42 l2tp,ppp,info l2tp-out1: initializing...
11:12:42 l2tp,ppp,info l2tp-out1: connecting...
11:12:45 ipsec,info initiate new phase 1 (Identity Protection): client.ip[500]<=>server.ip[500]
11:13:09 l2tp,ppp,info l2tp-out1: terminating... - session closed
11:13:09 l2tp,ppp,info l2tp-out1: disconnected
11:13:10 ipsec,info ISAKMP-SA deleted client.ip[500]-server.ip[500] spi:spi:bddf6a38eef103ca:0000000000000000 rekey:1
and so on
When i disable l2tp-out1 for a several minutes and re-enable it - it's connect without any problems.
So maybe there are any solutions to fix it?
sindy
Sat May 04, 2019 11:00 pm
It looks like some connection in a firewall needs to die on timeout to allow things to start happening properly. What the log at 6.44.1 says is that the machine receives retransmissions of the first IPsec packet aimed to establish the connection from the initiator after it has responded to the first one to arrive, which suggests that the responses never reach the initiator.
So while that situation exists, what does /ip firewall connection print detail where dst-address~":(500|1701|4500)\$" or src-address~":(500|1701|4501)\$" show at both ends?
Users browsing this forum: Amazon [Bot] and 36 guests
