Hello All,
I am new to mikrotik. I want to know what is the difference between CCR and CRS. Model number of CCR is CCR1009-8G-1S-PC and CRS is CRS226-24G-2S+RM.
Depends if you plan to shape the traffic, limit speed, control the users, etc. If all they need is internet access, then sure, it will be more than enough. If you need to do heavy tasks that load the CPU, then you could look at other series.Hello there!
VERY new to MikroTik and planning to buy. I have this question based on your answers though...
For a network where i have around 30 people, will a CRS326-24G-2S+RM suffice in sharing internet traffic?
CCR is a powerful router. Good for routing, filtering, shaping. Excellent CPU.
CRS is a switch. Good for packet switching at wire speeds where you do not need any filtering, shaping or routing. It can also do routing, but light loads and for a few of the ports at a time.
CCR1009 should be powerful enough for your setup. It really depends how much firewall, queues and other processing you are doing.this is my traffic can you help me which ccr should i buy ?
