alexgr
BGP not trying to reconnect more than once
Wed Mar 15, 2017 6:50 pm
We've noticed on MT's that when a BGP peering dies, mikrotik gets stuck on the open sent state forever.
In order to make again this peering come online you need to manually disable and then enable this peer.
While its stuck on open sent state, it will not send any packets at all to the other peer even if you leave it like this for days.
This has been seen with both older and latest firmware on cloudcore's.
Normally no one would see this problem because if your Peer tries to reconnect with you, then after a few seconds you will see this peering up and running. However there are situations in which the other peer has its configuration set to Passive.
So since MT doesn't try to reconnect and the other Peer won't try due to configuration, these Peering's stay forever down until you manually take action.
Initially I thought this was BFD specific but after testing without BFD it turned out that it will occur even without BFD.
So my question is, do I need to make some specific setting in order for the MT to try to reconnect to the other Peer or is it a bug that hasn't been observed before ?
savage
Re: BGP not trying to reconnect more than once
Thu Mar 16, 2017 9:15 am
We're seeing the same thing, and I've posted about it before as well...
IMHO, a bug.
Regards,
Chris
pe1chl
Tue Jun 06, 2017 8:34 pm
I have seen it happen as well. As you write, only when one side is passive.
Did you already try to report it to the support mail address?
avdvyver01
Fri Aug 11, 2017 11:51 am
I emailed support about this issue - feedback below:
Yes, it is a known problem, it tries multiple times except that with each try and failure interval between tries increase.
Currently solution for this problem when interval becomes too high is only disable/enable.
This will change in ROS v7.
From what I can see, the BGP peer does not seem to automatically retry - even if I leave it for long (hours) periods of time. Disable / enable immediately resolves the issue (not ideal but it works - ultimately I need reconnect / recovery to be automated).
savage
Fri Aug 11, 2017 11:53 am
Yup. Precisely the same story here, and the same "v7" fix -shrugs-
ROS v7 better be truly awesome, because damn, there's a lot of many, many serious issues depending on it.
Regards,
Chris
Cha0s
Sun Aug 13, 2017 4:49 pm
I have the same issue on multiple devices/archs.
JimmyNyholm
Thu Aug 17, 2017 11:29 am
I've seen it to but then again the other side is passive. if the syn packet get lost then the process is stuck it's not obeying syn timeout and resetting itself and trying again.
maxsaf
Mon Nov 26, 2018 5:37 pm
Is that issue still presents in the latest ROS or fixed already?
pe1chl
Mon Nov 26, 2018 5:40 pm
As the latest RouterOS is still a v6.x and not v7, I'm afraid it still happens...
It usually is only a problem when the link is down for extended time, not when simply rebooting or doing some reconfig.
fox1047
Wed Dec 05, 2018 9:52 am
Here is a script that i put in scheduler to automatically restart BGP when it's stuck.
I figured that it might be helpful to someone until this bug is fixed.
To use it you need to change antifilter to your BGP peer name.
/routing bgp peer {
	:local Peer [:pick [find name="antifilter"] 0]
	:local PeerState [get [:pick [find name="antifilter"] 0] state]
	:if ($PeerState = "opensent") do={
			disable $Peer;
			enable $Peer;
			:log warning "BGP peer restarted by script";
lazyroy
Thu Sep 19, 2019 6:02 pm
Rewritten version of previous script with no hardcoded peer name
/routing bgp peer {
   :foreach peer in [find state="opensent"] do={
      :log warning "Restart stuck BGP Peer: $([get $peer name])"
      disable $peer
      enable $peer
volkirik
Tue Jul 14, 2020 4:41 pm
awesome. thanks.
saved my life. i can have a sleep now
/routing bgp peer {
   :foreach peer in [find state!="established" and disabled=no] do={
      disable $peer
      :delay 100ms
      enable $peer
Users browsing this forum: No registered users and 16 guests
