gtpro
Script fails on 6.34, works on 6.28
Mon Mar 20, 2017 9:31 pm
Hello, I am using the following script on 6.28:
:foreach i in=[/tool user-manager user find] do={:if ([/tool user-manager user get $i uptime-used]= 1h) do={
:log warning ("Delete user... $[/tool user-manager user get $i name]")
/tool user-manager user remove [/tool user-manager user get $i name]
But this same script does not work on 6.34.1
Any one know how to fix it for 6.34.1?. Thanks.
gtpro
Re: Script fails on 6.34, works on 6.28
Mon Mar 20, 2017 11:28 pm
Found the solution!
:foreach i in=[/tool user-manager user find] do={:if ([/tool user-manager user get $i uptime-used]=1h) do={
:log warning ("Delete user... $[/tool user-manager user get $i user]")
/tool user-manager user remove [/tool user-manager user get $i user]
So all I had to change was "name" to "user". I hope it helps others.
HarBenly
Tue Mar 21, 2017 1:46 pm
Thanks man! just the simple change and yes its working. This thread was very helpful
gtpro
Wed Mar 22, 2017 1:44 am
Good!
Users browsing this forum: Labriks and 19 guests
