MUM Europe 2020
sebac
[solved] Atheros 108Mbps with EoIP?
Fri Nov 10, 2006 12:08 am
I have 2 Microtic boxes. Both with atheros based card.
I wont to connect them with 108Mbps but in Winbox there is only 54Mbps!?
The cards are set to 2437..
Help?
Info: Atheros AR5213 (TP-Link card).
Equis
Forum Veteran
Forum Veteran
Fri Nov 10, 2006 12:52 am
Whats is set for band? is it turbo?
sebac
Fri Nov 10, 2006 9:16 am
am... confused right now...
Yes, there is : 2.4GHz-G-turbo activated but on other side i get only 54Mbps?!
In winbox in Data Rates section i get only 54Mbps (as i read it is normal and will work on 108Mbps on f=2437MHz but it does not)..
Help?
More info:
TP-Link TL-WN651G SuperG 108Mbps
PS. Got Gigabyte GN-WPEAG 108Mbps, 802.11b/g PCI card... Same thing!
Many thanks
Setsquare
Fri Nov 10, 2006 9:26 am
It doesent show 108mbit, it still says 54mbit when you use turbo but speed is faster.
normis
Fri Nov 10, 2006 9:27 am
you will never get 108Mbits, that is marketing trick. 108Is air rate, not real rate. You can hope for something like 70-80 in ideal conditions.
sebac
Mon Nov 27, 2006 3:36 pm
ok. now i see. Thanks.
I didn't make G+ connection jet but i'll try later. Thanks on support
Users browsing this forum: erlinden and 44 guests
